commit 3f34cfae1238848fd53f25e5c8fd59da57901f4b upstream.
Syzbot reported several deadlocks in the netfilter area caused by
rtnl lock and socket lock being acquired with a different order on
different code paths, leading to backtraces like the following one:
WARNING: possible circular locking dependency detected
4.15.0-rc9+ #212 Not tainted
syzkaller041579/3682 is trying to acquire lock:
(sk_lock-AF_INET6){+.+.}, at: [<000000008775e4dd>] lock_sock
include/net/sock.h:1463 [inline]
do_ipv6_setsockopt.isra.8+0x3c5/0x39d0 net/ipv6/ipv6_sockglue.c:167
but task is already holding lock:
(rtnl_mutex){+.+.}, at: [<000000004342eaa9>] rtnl_lock+0x17/0x20
net/core/rtnetlink.c:74
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (rtnl_mutex){+.+.}:
__mutex_lock_common kernel/locking/mutex.c:756 [inline]
__mutex_lock+0x16f/0x1a80 kernel/locking/mutex.c:893
mutex_lock_nested+0x16/0x20 kernel/locking/mutex.c:908
rtnl_lock+0x17/0x20 net/core/rtnetlink.c:74
register_netdevice_notifier+0xad/0x860 net/core/dev.c:1607
tee_tg_check+0x1a0/0x280 net/netfilter/xt_TEE.c:106
xt_check_target+0x22c/0x7d0 net/netfilter/x_tables.c:845
check_target net/ipv6/netfilter/ip6_tables.c:538 [inline]
find_check_entry.isra.7+0x935/0xcf0
net/ipv6/netfilter/ip6_tables.c:580
translate_table+0xf52/0x1690 net/ipv6/netfilter/ip6_tables.c:749
do_replace net/ipv6/netfilter/ip6_tables.c:1165 [inline]
do_ip6t_set_ctl+0x370/0x5f0 net/ipv6/netfilter/ip6_tables.c:1691
nf_sockopt net/netfilter/nf_sockopt.c:106 [inline]
nf_setsockopt+0x67/0xc0 net/netfilter/nf_sockopt.c:115
ipv6_setsockopt+0x115/0x150 net/ipv6/ipv6_sockglue.c:928
udpv6_setsockopt+0x45/0x80 net/ipv6/udp.c:1422
sock_common_setsockopt+0x95/0xd0 net/core/sock.c:2978
SYSC_setsockopt net/socket.c:1849 [inline]
SyS_setsockopt+0x189/0x360 net/socket.c:1828
entry_SYSCALL_64_fastpath+0x29/0xa0
-> #0 (sk_lock-AF_INET6){+.+.}:
lock_acquire+0x1d5/0x580 kernel/locking/lockdep.c:3914
lock_sock_nested+0xc2/0x110 net/core/sock.c:2780
lock_sock include/net/sock.h:1463 [inline]
ipv6_setsockopt+0xd7/0x150 net/ipv6/ipv6_sockglue.c:922
Possible unsafe locking scenario:
CPU0 CPU1
lock(rtnl_mutex);
lock(sk_lock-AF_INET6);
lock(rtnl_mutex);
*** DEADLOCK ***
1 lock held by syzkaller041579/3682:
#0: (rtnl_mutex){+.+.}, at: [<000000004342eaa9>] rtnl_lock+0x17/0x20
The problem, as Florian noted, is that nf_setsockopt() is always
called with the socket held, even if the lock itself is required only
for very tight scopes and only for some operation.
This patch addresses the issues moving the lock_sock() call only
where really needed, namely in ipv*_getorigdst(), so that nf_setsockopt()
does not need anymore to acquire both locks.
Fixes: 22265a5c3c10 ("netfilter: xt_TEE: resolve oif using netdevice notifiers")
Reported-by: syzbot+a4c2dc980ac1af699b36@syzkaller.appspotmail.com
Suggested-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
since commit 8405a8fff3f8 ("netfilter: nf_qeueue: Drop queue entries on
nf_unregister_hook") all pending queued entries are discarded.
So we can simply remove all of the owner handling -- when module is
removed it also needs to unregister all its hooks.
Only pass the void *priv parameter out of the nf_hook_ops. That is
all any of the functions are interested now, and by limiting what is
passed it becomes simpler to change implementation details.
The values of nf_hook_state.hook and nf_hook_ops.hooknum must be the
same by definition.
We are more likely to access the fields in nf_hook_state over the
fields in nf_hook_ops so with a little luck this results in
fewer cache line misses, and slightly more consistent code.
Instead of saying "net = dev_net(state->in?state->in:state->out)"
just say "state->net". As that information is now availabe,
much less confusing and much less error prone.
This patch replaces the zone id which is pushed down into functions
with the actual zone object. It's a bigger one-time change, but
needed for later on extending zones with a direction parameter, and
thus decoupling this additional information from all call-sites.
No functional changes in this patch.
The default zone becomes a global const object, namely nf_ct_zone_dflt
and will be returned directly in various cases, one being, when there's
f.e. no zoning support.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Pass the nf_hook_state all the way down into the hook
functions themselves.
Those are counterparts to nla_put_in_addr and nla_put_in6_addr.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
IP addresses are often stored in netlink attributes. Add generic functions
to do that.
For nla_put_in_addr, it would be nicer to pass struct in_addr but this is
not used universally throughout the kernel, in way too many places __be32 is
used to store IPv4 address.
Since adding a new function to seq_file (seq_has_overflowed())
there isn't any value for functions called from seq_show to
return anything. Remove the int returns of the various
print_tuple/<foo>_print_tuple functions.
Link: http://lkml.kernel.org/p/f2e8cf8df433a197daa62cbaf124c900c708edc7.1412031505.git.joe@perches.com
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Cc: netfilter-devel@vger.kernel.org
Cc: coreteam@netfilter.org
Pushing original fragments through causes several problems. For example
for matching, frags may not be matched correctly. Take following
example:
<example>
On HOSTA do:
ip6tables -I INPUT -p icmpv6 -j DROP
ip6tables -I INPUT -p icmpv6 -m icmp6 --icmpv6-type 128 -j ACCEPT
and on HOSTB you do:
ping6 HOSTA -s2000 (MTU is 1500)
Incoming echo requests will be filtered out on HOSTA. This issue does
not occur with smaller packets than MTU (where fragmentation does not happen)
</example>
As was discussed previously, the only correct solution seems to be to use
reassembled skb instead of separete frags. Doing this has positive side
effects in reducing sk_buff by one pointer (nfct_reasm) and also the reams
dances in ipvs and conntrack can be removed.
Future plan is to remove net/ipv6/netfilter/nf_conntrack_reasm.c
entirely and use code in net/ipv6/reassembly.c instead.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
Pass the hook ops to the hookfn to allow for generic hook
functions. This change is required by nf_tables.
TCP listener refactoring, part 4 :
To speed up inet lookups, we moved IPv4 addresses from inet to struct
sock_common
Now is time to do the same for IPv6, because it permits us to have fast
lookups for all kind of sockets, including upcoming SYN_RECV.
Getting IPv6 addresses in TCP lookups currently requires two extra cache
lines, plus a dereference (and memory stall).
inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6
This patch is way bigger than its IPv4 counter part, because for IPv4,
we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6,
it's not doable easily.
inet6_sk(sk)->daddr becomes sk->sk_v6_daddr
inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr
And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr
at the same offset.
We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic
macro.
Split out sequence number adjustments from NAT and move them to the conntrack
core to make them usable for SYN proxying. The sequence number adjustment
information is moved to a seperate extend. The extend is added to new
conntracks when a NAT mapping is set up for a connection using a helper.
As a side effect, this saves 24 bytes per connection with NAT in the common
case that a connection does not have a helper assigned.
Tested-by: Martin Topholm <mph@one.com>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
In commit 4cdd3408 ("netfilter: nf_conntrack_ipv6: improve fragmentation
handling"), an sk_buff leak was introduced when dealing with reassembled
packets by grabbing a reference to the original skb instead of the
reassembled skb. At this point, the leak only impacted conntracks with an
associated helper.
In commit 58a317f1 ("netfilter: ipv6: add IPv6 NAT support"), the bug was
expanded to include all reassembled packets with unconfirmed conntracks.
Fix this by grabbing a reference to the proper reassembled skb. This
closes netfilter bugzilla #823.
Signed-off-by: Phil Oester <kernel@linuxace.com>
As in (842df07 ipv6: use newly introduced __ipv6_addr_needs_scope_id and
ipv6_iface_scope_id).
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Connection tracking helpers have to drop packets under exceptional
situations. Currently, the user gets the following logging message
in case that happens:
nf_ct_%s: dropping packet ...
However, depending on the helper, there are different reasons why a
packet can be dropped.
This patch modifies the existing code to provide more specific
error message in the scope of each helper to help users to debug
the reason why the packet has been dropped, ie:
nf_ct_%s: dropping packet: reason ...
Thanks to Joe Perches for many formatting suggestions.
Move the code that register/unregister l4proto to the
module_init/exit context.
Given that we have to modify some interfaces to accomodate
these changes, it is a good time to use shorter function names
for this using the nf_ct_* prefix instead of nf_conntrack_*,
that is:
nf_ct_l4proto_register
nf_ct_l4proto_pernet_register
nf_ct_l4proto_unregister
nf_ct_l4proto_pernet_unregister
We same many line breaks with it.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Move the code that register/unregister l3proto to the
that is:
nf_ct_l3proto_register
nf_ct_l3proto_pernet_register
nf_ct_l3proto_unregister
nf_ct_l3proto_pernet_unregister
Remove ambiguity of double negation.
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
Acked-by: Rick Jones <rick.jones2@hp.com>
net/ipv6/netfilter/nf_conntrack_l3proto_ipv6.c
Minor conflict due to some IS_ENABLED conversions done
in net-next.
yoshfuji points out that sk_bound_dev_if should only be provided
for link-local addresses.
IPv6 getpeer/sockname also has this test, i.e. we will now
only set sin6_scope_id if the original(!) destination
was a link-local address.
Reported-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
userspace can query the original ipv4 destination address of a REDIRECTed
connection via
getsockopt(m_sock, SOL_IP, SO_ORIGINAL_DST, &m_server_addr, &addrsize)
but for ipv6 no such option existed.
This adds getsockopt(..., IPPROTO_IPV6, IP6T_SO_ORIGINAL_DST, ...).
Without this, userspace needs to parse /proc or use ctnetlink, which
appears to be overkill.
This uses option number 80 for IP6T_SO_ORIGINAL_DST, which is spare,
to use the same number we use in the IPv4 socket option SO_ORIGINAL_DST.
#if defined(CONFIG_FOO) || defined(CONFIG_FOO_MODULE)
can be replaced by
#if IS_ENABLED(CONFIG_FOO)
Signed-off-by: Cong Wang <amwang@redhat.com>
containing fragments
ICMPv6 error messages are tracked by extracting the conntrack tuple of
the inner packet and looking up the corresponding conntrack entry. Tuple
extraction uses the ->get_l4proto() callback, which in case of fragments
returns NEXTHDR_FRAGMENT instead of the upper protocol, even for the
first fragment when the entire next header is present, resulting in a
failure to find the correct connection tracking entry.
This patch changes ipv6_get_l4proto() to use ipv6_skip_exthdr() instead
of nf_ct_ipv6_skip_exthdr() in order to skip fragment headers when the
fragment offset is zero.
The IPv6 conntrack fragmentation currently has a couple of shortcomings.
Fragmentes are collected in PREROUTING/OUTPUT, are defragmented, the
defragmented packet is then passed to conntrack, the resulting conntrack
information is attached to each original fragment and the fragments then
continue their way through the stack.
Helper invocation occurs in the POSTROUTING hook, at which point only
the original fragments are available. The result of this is that
fragmented packets are never passed to helpers.
This patch improves the situation in the following way:
- If a reassembled packet belongs to a connection that has a helper
assigned, the reassembled packet is passed through the stack instead
of the original fragments.
- During defragmentation, the largest received fragment size is stored.
On output, the packet is refragmented if required. If the largest
received fragment size exceeds the outgoing MTU, a "packet too big"
message is generated, thus behaving as if the original fragments
were passed through the stack from an outside point of view.
- The ipv6_helper() hook function can't receive fragments anymore for
connections using a helper, so it is switched to use ipv6_skip_exthdr()
instead of the netfilter specific nf_ct_ipv6_skip_exthdr() and the
reassembled packets are passed to connection tracking helpers.
The result of this is that we can properly track fragmented packets, but
still generate ICMPv6 Packet too big messages if we would have before.
This patch is also required as a precondition for IPv6 NAT, where NAT
helpers might enlarge packets up to a point that they require
fragmentation. In that case we can't generate Packet too big messages
since the proper MTU can't be calculated in all cases (f.i. when
changing textual representation of a variable amount of addresses),
so the packet is transparently fragmented iff the original packet or
fragments would have fit the outgoing MTU.
IPVS parts by Jesper Dangaard Brouer <brouer@redhat.com>.
There are good reasons to supports helpers in user-space instead:
* Rapid connection tracking helper development, as developing code
in user-space is usually faster.
* Reliability: A buggy helper does not crash the kernel. Moreover,
we can monitor the helper process and restart it in case of problems.
* Security: Avoid complex string matching and mangling in kernel-space
running in privileged mode. Going further, we can even think about
running user-space helpers as a non-root process.
* Extensibility: It allows the development of very specific helpers (most
likely non-standard proprietary protocols) that are very likely not to be
accepted for mainline inclusion in the form of kernel-space connection
tracking helpers.
This patch adds the infrastructure to allow the implementation of
user-space conntrack helpers by means of the new nfnetlink subsystem
`nfnetlink_cthelper' and the existing queueing infrastructure
(nfnetlink_queue).
I had to add the new hook NF_IP6_PRI_CONNTRACK_HELPER to register
ipv[4|6]_helper which results from splitting ipv[4|6]_confirm into
two pieces. This change is required not to break NAT sequence
adjustment and conntrack confirmation for traffic that is enqueued
to our user-space conntrack helpers.
Basic operation, in a few steps:
1) Register user-space helper by means of `nfct':
nfct helper add ftp inet tcp
[ It must be a valid existing helper supported by conntrack-tools ]
2) Add rules to enable the FTP user-space helper which is
used to track traffic going to TCP port 21.
For locally generated packets:
iptables -I OUTPUT -t raw -p tcp --dport 21 -j CT --helper ftp
For non-locally generated packets:
iptables -I PREROUTING -t raw -p tcp --dport 21 -j CT --helper ftp
3) Run the test conntrackd in helper mode (see example files under
doc/helper/conntrackd.conf
conntrackd
4) Generate FTP traffic going, if everything is OK, then conntrackd
should create expectations (you can check that with `conntrack':
conntrack -E expect
[NEW] 301 proto=6 src=192.168.1.136 dst=130.89.148.12 sport=0 dport=54037 mask-src=255.255.255.255 mask-dst=255.255.255.255 sport=0 dport=65535 master-src=192.168.1.136 master-dst=130.89.148.12 sport=57127 dport=21 class=0 helper=ftp
[DESTROY] 301 proto=6 src=192.168.1.136 dst=130.89.148.12 sport=0 dport=54037 mask-src=255.255.255.255 mask-dst=255.255.255.255 sport=0 dport=65535 master-src=192.168.1.136 master-dst=130.89.148.12 sport=57127 dport=21 class=0 helper=ftp
This confirms that our test helper is receiving packets including the
conntrack information, and adding expectations in kernel-space.
The user-space helper can also store its private tracking information
in the conntrack structure in the kernel via the CTA_HELP_INFO. The
kernel will consider this a binary blob whose layout is unknown. This
information will be included in the information that is transfered
to user-space via glue code that integrates nfnetlink_queue and
ctnetlink.
This patch adds namespace support for IPv6 protocol tracker.
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
This patch prepares the namespace support for layer 3 protocol trackers.
Basically, this modifies the following interfaces:
* nf_ct_l3proto_[un]register_sysctl.
* nf_conntrack_l3proto_[un]register.
We add a new nf_ct_l3proto_net is used to get the pernet data of l3proto.
This adds rhe new struct nf_ip_net that is used to store the sysctl header
and l3proto_ipv4,l4proto_tcp(6),l4proto_udp(6),l4proto_icmp(v6) because the
protos such tcp and tcp6 use the same data,so making nf_ip_net as a field
of netns_ct is the easiest way to manager it.
This patch also adds init_net to struct nf_conntrack_l3proto to initial
the layer 3 protocol pernet data.
This patch prepares the namespace support for layer 4 protocol trackers.
* nf_ct_[un]register_sysctl
* nf_conntrack_l4proto_[un]register
to include the namespace parameter. We still use init_net in this patch
to prepare the ground for follow-up patches for each layer 4 protocol
tracker.
We add a new net_id field to struct nf_conntrack_l4proto that is used
to store the pernet_operations id for each layer 4 protocol tracker.
Note that AF_INET6's protocols do not need to do sysctl compat. Thus,
we only register compat sysctl when l4proto.l3proto != AF_INET6.
Standardize the net core ratelimited logging functions.
Coalesce formats, align arguments.
Change a printk then vprintk sequence to use printf extension %pV.
These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
Following error is raised (and other similar ones) :
net/ipv4/netfilter/nf_nat_standalone.c: In function ‘nf_nat_fn’:
net/ipv4/netfilter/nf_nat_standalone.c:119:2: warning: case value ‘4’
not in enumerated type ‘enum ip_conntrack_info’
gcc barfs on adding two enum values and getting a not enumerated
result :
case IP_CT_RELATED+IP_CT_IS_REPLY:
Add missing enum values
CC: David Miller <davem@davemloft.net>
Like with IPv4, TProxy needs IPv6 defragmentation but does not
require connection tracking. Since defragmentation was coupled
with conntrack, I split off the two, creating an nf_defrag_ipv6 module,
similar to the already existing nf_defrag_ipv4.
Signed-off-by: Balazs Scheidler <bazsi@balabit.hu>
Signed-off-by: KOVACS Krisztian <hidden@balabit.hu>
Make sure all printk messages have a severity level.
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
Support initializing selected parameters of new conntrack entries from a
"conntrack template", which is a specially marked conntrack entry attached
to the skb.
Currently the helper and the event delivery masks can be initialized this
way.
When fragments from bridge netfilter are passed to IPv4 or IPv6 conntrack
and a reassembly queue with the same fragment key already exists from
reassembling a similar packet received on a different device (f.i. with
multicasted fragments), the reassembled packet might continue on a different
codepath than where the head fragment originated. This can cause crashes
in bridge netfilter when a fragment received on a non-bridge device (and
thus with skb->nf_bridge == NULL) continues through the bridge netfilter
code.
Add a new reassembly identifier for packets originating from bridge
netfilter and use it to put those packets in insolated queues.
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=14805
Reported-and-Tested-by: Chong Qiao <qiaochong@loongson.cn>
delivery
Currently the same reassembly queue might be used for packets reassembled
by conntrack in different positions in the stack (PREROUTING/LOCAL_OUT),
as well as local delivery. This can cause "packet jumps" when the fragment
completing a reassembled packet is queued from a different position in the
stack than the previous ones.
Add a "user" identifier to the reassembly queue key to seperate the queues
of each caller, similar to what we do for IPv4.
Log packets dropped by helpers using the netfilter logging API. This
is useful in combination with nfnetlink_log to analyze those packets
in userspace for debugging.
Simple substitution to indicate that the fields indeed use the
NFPROTO_ space.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
Moving the structure definitions to the corresponding IPvX specific header files.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
It's deducible from skb->dev or skb->dst->dev, but we know netns at
the moment of call, so pass it down and use for finding and creating
conntracks.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
This is a preparation for sysctl netns-ization.
Move the ctl tables to the files, where the tuning
variables reside. Plus make the helpers to register
the tables.
This will simplify the later patches and will keep
similar things closer to each other.
ipv4, ipv6 and conntrack_reasm are patched differently,
but the result is all the tables are in appropriate files.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
