Currently, there are two different methods to store an u16 integer to
the u32 data register. For example:
u32 *dest = ®s->data[priv->dreg];
1. *dest = 0; *(u16 *) dest = val_u16;
2. *dest = val_u16;
For method 1, the u16 value will be stored like this, either in
big-endian or little-endian system:
0 15 31
| Value | 0 |
For method 2, in little-endian system, the u16 value will be the same
as listed above. But in big-endian system, the u16 value will be stored
like this:
0 15 31
| 0 | Value |
So later we use "memcmp(®s->data[priv->sreg], data, 2);" to do
compare in nft_cmp, nft_lookup expr ..., method 2 will get the wrong
result in big-endian system, as 0~15 bits will always be zero.
For the similar reason, when loading an u16 value from the u32 data
register, we should use "*(u16 *) sreg;" instead of "(u16)*sreg;",
the 2nd method will get the wrong value in the big-endian system.
So introduce some wrapper functions to store/load an u8 or u16
integer to/from the u32 data register, and use them in the right
place.
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
so that conntrack core will add the needed hooks in this namespace.
The email address has changed, let's update the copyright statements.
Signed-off-by: Arturo Borrero Gonzalez <arturo@debian.org>
Don't copy relevant fields from hook state structure, instead use the
one that is already available in struct xt_action_param.
This patch also adds a set of new wrapper functions to fetch relevant
hook state structure fields.
- Add nft_pktinfo.pf to replace ops->pf
- Add nft_pktinfo.hook to replace ops->hooknum
This simplifies the code, makes it more readable, and likely reduces
cache line misses. Maintainability is enhanced as the details of
nft_hook_ops are of no concern to the recpients of nft_pktinfo.
Switch the nf_tables registers from 128 bit addressing to 32 bit
addressing to support so called concatenations, where multiple values
can be concatenated over multiple registers for O(1) exact matches of
multiple dimensions using sets.
The old register values are mapped to areas of 128 bits for compatibility.
When dumping register numbers, values are expressed using the old values
if they refer to the beginning of a 128 bit area for compatibility.
To support concatenations, register loads of less than a full 32 bit
value need to be padded. This mainly affects the payload and exthdr
expressions, which both unconditionally zero the last word before
copying the data.
Userspace fully passes the testsuite using both old and new register
addressing.
Replace the array of registers passed to expressions by a struct nft_regs,
containing the verdict as a seperate member, which aliases to the
NFT_REG_VERDICT register.
This is needed to seperate the verdict from the data registers completely,
so their size can be changed.
Make sure this fetches 16-bits port data from the register.
Remove casting to make sparse happy, not needed anymore.
Signed-off-by: leroy christophe <christophe.leroy@c-s.fr>
This resolves linking problems with CONFIG_IPV6=n:
net/built-in.o: In function `redirect_tg6':
xt_REDIRECT.c:(.text+0x6d021): undefined reference to `nf_nat_redirect_ipv6'
Reported-by: Andreas Ruprecht <rupran@einserver.de>
Reported-by: Or Gerlitz <ogerlitz@mellanox.com>
This new expression provides NAT in the redirect flavour, which is to
redirect packets to local machine.
Signed-off-by: Arturo Borrero Gonzalez <arturo.borrero.glez@gmail.com>
