Allow transparent sockets to be less restrictive about
the source ip of ipv6 udp packets being sent.
Google-Bug-Id: 5018138
Signed-off-by: Maciej Żenczykowski <maze@google.com>
CC: "Erik Kline" <ek@google.com>
CC: "Lorenzo Colitti" <lorenzo@google.com>
Make the case labels the same indent as the switch.
git diff -w shows 80 column reflowing,
removal of a useless break after return, and moving
open brace after case instead of separate line.
The %pK format specifier is designed to hide exposed kernel pointers,
specifically via /proc interfaces. Exposing these pointers provides an
easy target for kernel write vulnerabilities, since they reveal the
locations of writable structures containing easily triggerable function
pointers. The behavior of %pK depends on the kptr_restrict sysctl.
If kptr_restrict is set to 0, no deviation from the standard %p behavior
occurs. If kptr_restrict is set to 1, the default, if the current user
(intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG
(currently in the LSM tree), kernel pointers using %pK are printed as 0's.
If kptr_restrict is set to 2, kernel pointers using %pK are printed as
0's regardless of privileges. Replacing with 0's was chosen over the
default "(null)", which cannot be parsed by userland %p, which expects
"(nil)".
The supporting code for kptr_restrict and %pK are currently in the -mm
tree. This patch converts users of %p in net/ to %pK. Cases of printing
pointers to the syslog are not covered, since this would eliminate useful
information for postmortem debugging and the reading of the syslog is
already optionally protected by the dmesg_restrict sysctl.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Thomas Graf <tgraf@infradead.org>
Cc: Eugene Teo <eugeneteo@kernel.org>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Eric Paris <eparis@parisplace.org>
When we fast path datagram sends to avoid locking by putting
the inet_cork on the stack we use up lots of space that isn't
necessary.
This is because inet_cork contains a "struct flowi" which isn't
used in these code paths.
Split inet_cork to two parts, "inet_cork" and "inet_cork_full".
Only the latter of which has the "struct flowi" and is what is
stored in inet_sock.
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
Create two sets of port member accessors, one set prefixed by fl4_*
and the other prefixed by fl6_*
This will let us to create AF optimal flow instances.
It will work because every context in which we access the ports,
we have to be fully aware of which AF the flowi is anyways.
I intend to turn struct flowi into a union of AF specific flowi
structs. There will be a common structure that each variant includes
first, much like struct sock_common.
This is the first step to move in that direction.
Route lookups follow a general pattern in the ipv6 code wherein
we first find the non-IPSEC route, potentially override the
flow destination address due to ipv6 options settings, and then
finally make an IPSEC search using either xfrm_lookup() or
__xfrm_lookup().
__xfrm_lookup() is used when we want to generate a blackhole route
if the key manager needs to resolve the IPSEC rules (in this case
-EREMOTE is returned and the original 'dst' is left unchanged).
Otherwise plain xfrm_lookup() is used and when asynchronous IPSEC
resolution is necessary, we simply fail the lookup completely.
All of these cases are encapsulated into two routines,
ip6_dst_lookup_flow and ip6_sk_dst_lookup_flow. The latter of which
handles unconnected UDP datagram sockets.
Remove sparse warnings, using a function typedef to be able to use __rcu
annotation on mh_filter pointer.
Add __rcu annotation to :
(struct sock)->sk_filter
And use appropriate rcu primitives to reduce sparse warnings if
CONFIG_SPARSE_RCU_POINTER=y
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Avoid two atomic ops per raw_send_hdrinc() call
Avoid two atomic ops per raw6_send_hdrinc() call
There are more than a dozen occurrences of following code in the
IPv6 stack:
if (opt && opt->srcrt) {
struct rt0_hdr *rt0 = (struct rt0_hdr *) opt->srcrt;
ipv6_addr_copy(&final, &fl.fl6_dst);
ipv6_addr_copy(&fl.fl6_dst, rt0->addr);
final_p = &final;
Replace those with a helper. Note that the helper overrides final_p
in all cases. This is ok as final_p was previously initialized to
NULL when declared.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
net/bridge/br_device.c
net/bridge/br_forward.c
When queueing a skb to socket, we can immediately release its dst if
target socket do not use IP_CMSG_PKTINFO.
tcp_data_queue() can drop dst too.
This to benefit from a hot cache line and avoid the receiver, possibly
on another cpu, to dirty this cache line himself.
Finally add support to detect a local IPV6_DONTFRAG event
and return the relevant data to the user if they've enabled
IPV6_RECVPATHMTU on the socket. The next recvmsg() will
return no data, but have an IPV6_PATHMTU as ancillary data.
Signed-off-by: Brian Haley <brian.haley@hp.com>
Add dontfrag argument to relevant functions for
IPV6_DONTFRAG support, as well as allowing the value
to be passed-in via ancillary cmsg data.
Documentation/feature-removal-schedule.txt
net/ipv6/netfilter/ip6t_REJECT.c
net/netfilter/xt_limit.c
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The semantic patch that was used:
// <smpl>
(NF_HOOK
|NF_HOOK_THRESH
|nf_hook
-PF_INET6,
+NFPROTO_IPV6,
// </smpl>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
Using RCU helps not touching device refcount in rawv6_bind()
struct can_proto had a capability field which wasn't ever used. It is
dropped entirely.
struct inet_protosw had a capability field which can be more clearly
expressed in the code by just checking if sock->type = SOCK_RAW.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
- skb_kill_datagram() can increment sk->sk_drops itself, not callers.
- UDP on IPV4 & IPV6 dropped frames (because of bad checksum or policy checks) increment sk_drops
In order to have better cache layouts of struct sock (separate zones
for rx/tx paths), we need this preliminary patch.
Goal is to transfert fields used at lookup time in the first
read-mostly cache line (inside struct sock_common) and move sk_refcnt
to a separate cache line (only written by rx path)
This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr,
sport and id fields. This allows a future patch to define these
fields as macros, like sk_refcnt, without name clashes.
sock_queue_rcv_skb() can update sk_drops itself, removing need for
callers to take care of it. This is more consistent since
sock_queue_rcv_skb() also reads sk_drops when queueing a skb.
This adds sk_drops managment to many protocols that not cared yet.
Create a new socket level option to report number of queue overflows
Recently I augmented the AF_PACKET protocol to report the number of frames lost
on the socket receive queue between any two enqueued frames. This value was
exported via a SOL_PACKET level cmsg. AFter I completed that work it was
requested that this feature be generalized so that any datagram oriented socket
could make use of this option. As such I've created this patch, It creates a
new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a
SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue
overflowed between any two given frames. It also augments the AF_PACKET
protocol to take advantage of this new feature (as it previously did not touch
sk->sk_drops, which this patch uses to record the overflow count). Tested
successfully by me.
Notes:
1) Unlike my previous patch, this patch simply records the sk_drops value, which
is not a number of drops between packets, but rather a total number of drops.
Deltas must be computed in user space.
2) While this patch currently works with datagram oriented protocols, it will
also be accepted by non-datagram oriented protocols. I'm not sure if thats
agreeable to everyone, but my argument in favor of doing so is that, for those
protocols which aren't applicable to this option, sk_drops will always be zero,
and reporting no drops on a receive queue that isn't used for those
non-participating protocols seems reasonable to me. This also saves us having
to code in a per-protocol opt in mechanism.
3) This applies cleanly to net-next assuming that commit
977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
This provides safety against negative optlen at the type
level instead of depending upon (sometimes non-trivial)
checks against this sprinkled all over the the place, in
each and every implementation.
Based upon work done by Arjan van de Ven and feedback
from Linus Torvalds.
Christoph Lameter pointed out that packet drops at qdisc level where not
accounted in SNMP counters. Only if application sets IP_RECVERR, drops
are reported to user (-ENOBUFS errors) and SNMP counters updated.
IP_RECVERR is used to enable extended reliable error message passing,
but these are not needed to update system wide SNMP stats.
This patch changes things a bit to allow SNMP counters to be updated,
regardless of IP_RECVERR being set or not on the socket.
Example after an UDP tx flood
# netstat -s
IP:
1487048 outgoing packets dropped
Udp:
SndbufErrors: 1487048
send() syscalls, do however still return an OK status, to not
break applications.
Note : send() manual page explicitly says for -ENOBUFS error :
"The output queue for a network interface was full.
This generally indicates that the interface has stopped sending,
but may be caused by transient congestion.
(Normally, this does not occur in Linux. Packets are just silently
dropped when a device queue overflows.) "
This is not true for IP_RECVERR enabled sockets : a send() syscall
that hit a qdisc drop returns an ENOBUFS error.
Many thanks to Christoph, David, and last but not least, Alexey !
This replaces assignments of the type "int on LHS" = "u8 on RHS" with
simpler code. The LHS can express all of the unsigned right hand side
values, hence the assigned value can not be negative.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Change all the code that deals directly with ICMPv6 type and code
values to use u8 instead of a signed int as that's the actual data
type.
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
changed initial sk_wmem_alloc value.
We need to take into account this offset when reporting
sk_wmem_alloc to user, in PROC_FS files or various
ioctls (SIOCOUTQ/TIOCOUTQ)
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and
OutMcastOctets:
http://tools.ietf.org/html/rfc4293
But it seems we don't track those in any way that easy to separate from other
protocols. This patch adds those missing counters to the stats file. Tested
successfully by me
With help from Eric Dumazet.
Pass netns to xfrm_lookup()/__xfrm_lookup(). For that pass netns
to flow_cache_lookup() and resolver callback.
Take it from socket or netdevice. Stub DECnet to init_net.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com>
In commits 33c732c36169d7022ad7d6eb474b0c9be43a2dc1 ([IPV4]: Add raw
drops counter) and a92aa318b4b369091fd80433c80e62838db8bc1c ([IPV6]:
Add raw drops counter), Wang Chen added raw drops counter for
/proc/net/raw & /proc/net/raw6
This patch adds this capability to UDP sockets too (/proc/net/udp &
/proc/net/udp6).
This means that 'RcvbufErrors' errors found in /proc/net/snmp can be also
be examined for each udp socket.
# grep Udp: /proc/net/snmp
Udp: InDatagrams NoPorts InErrors OutDatagrams RcvbufErrors SndbufErrors
Udp: 23971006 75 899420 16390693 146348 0
# cat /proc/net/udp
sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt ---
uid timeout inode ref pointer drops
75: 00000000:02CB 00000000:0000 07 00000000:00000000 00:00000000 00000000 ---
0 0 2358 2 ffff81082a538c80 0
111: 00000000:006F 00000000:0000 07 00000000:00000000 00:00000000 00000000 ---
0 0 2286 2 ffff81042dd35c80 146348
In this example, only port 111 (0x006F) was flooded by messages that
user program could not read fast enough. 146348 messages were lost.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Change struct proto destroy function pointer to return void. Noticed
by Al Viro.
drivers/net/smc911x.c
In changeset 22dd485022f3d0b162ceb5e67d85de7c3806aa20
("raw: Raw socket leak.") code was added so that we
flush pending frames on raw sockets to avoid leaks.
The ipv4 part was fine, but the ipv6 part was not
done correctly. Unlike the ipv4 side, the ipv6 code
already has a .destroy method for rawv6_prot.
So now there were two assignments to this member, and
what the compiler does is use the last one, effectively
making the ipv6 parts of that changeset a NOP.
Fix this by removing the:
.destroy = inet6_destroy_sock,
line, and adding an inet6_destroy_sock() call to the
end of raw6_destroy().
Noticed by Al Viro.
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The program below just leaks the raw kernel socket
int main() {
int fd = socket(PF_INET, SOCK_RAW, IPPROTO_UDP);
struct sockaddr_in addr;
memset(&addr, 0, sizeof(addr));
inet_aton("127.0.0.1", &addr.sin_addr);
addr.sin_family = AF_INET;
addr.sin_port = htons(2048);
sendto(fd, "a", 1, MSG_MORE, &addr, sizeof(addr));
return 0;
Corked packet is allocated via sock_wmalloc which holds the owner socket,
so one should uncork it and flush all pending data on close. Do this in the
same way as in UDP.
Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
