This reverts commit 23e983e27aaff6357bb851d91b593d83a9a6552c which is
commit b91d532928dff2141ea9c107c3e73104d9843767 upstream.
It breaks the Android networking test suite, which works fine with the
backported patch in 4.14. So something must be off for 4.9 for this
patch, so just revert it.
Cc: Jianlin Shi <jishi@redhat.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Xin Long <lucien.xin@gmail.com>
Cc: Sasha Levin <sashal@kernel.org>
[ Upstream commit 7ddacfa564870cdd97275fd87decb6174abc6380 ]
Preethi reported that PMTU discovery for UDP/raw applications is not
working in the presence of VRF when the socket is not bound to a device.
The problem is that ip6_sk_update_pmtu does not consider the L3 domain
of the skb device if the socket is not bound. Update the function to
set oif to the L3 master device if relevant.
Fixes: ca254490c8df ("net: Add VRF support to IPv6 stack")
Reported-by: Preethi Ramachandra <preethir@juniper.net>
Signed-off-by: David Ahern <dsahern@gmail.com>
[ Upstream commit b91d532928dff2141ea9c107c3e73104d9843767 ]
After commit c2ed1880fd61 ("net: ipv6: check route protocol when
deleting routes"), ipv6 route checks rt protocol when trying to
remove a rt entry.
It introduced a side effect causing 'ip -6 route flush cache' not
to work well. When flushing caches with iproute, all route caches
get dumped from kernel then removed one by one by sending DELROUTE
requests to kernel for each cache.
The thing is iproute sends the request with the cache whose proto
is set with RTPROT_REDIRECT by rt6_fill_node() when kernel dumps
it. But in kernel the rt_cache protocol is still 0, which causes
the cache not to be matched and removed.
So the real reason is rt6i_protocol in the route is not set when
it is allocated. As David Ahern's suggestion, this patch is to
set rt6i_protocol properly in the route when it is installed and
remove the codes setting rtm_protocol according to rt6i_flags in
rt6_fill_node.
This is also an improvement to keep rt6i_protocol consistent with
rtm_protocol.
Fixes: c2ed1880fd61 ("net: ipv6: check route protocol when deleting routes")
Reported-by: Jianlin Shi <jishi@redhat.com>
Suggested-by: David Ahern <dsahern@gmail.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 0975764684487bf3f7a47eef009e750ea41bd514 ]
IPVS setups with local client and remote tunnel server need
to create exception for the local virtual IP. What we do is to
change PMTU from 64KB (on "lo") to 1460 in the common case.
Suggested-by: Martin KaFai Lau <kafai@fb.com>
Fixes: 45e4fd26683c ("ipv6: Only create RTF_CACHE routes after encountering pmtu exception")
Fixes: 7343ff31ebf0 ("ipv6: Don't create clones of host routes.")
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Acked-by: David Ahern <dsahern@gmail.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit aa8f8778493c85fff480cdf8b349b1e1dcb5f243 ]
KMSAN reported use of uninit-value that I tracked to lack
of proper size check on RTA_TABLE attribute.
I also believe RTA_PREFSRC lacks a similar check.
Fixes: 86872cb57925 ("[IPv6] route: FIB6 configuration using struct fib6_config")
Fixes: c3968a857a6b ("ipv6: RTA_PREFSRC support for ipv6 route source address selection")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit b6cdbc85234b072340b8923e69f49ec293f905dc ]
Donald reported that IPv6 route leaking between VRFs is not working.
The root cause is the strict argument in the call to rt6_lookup when
validating the nexthop spec.
ip6_route_check_nh validates the gateway and device (if given) of a
route spec. It in turn could call rt6_lookup (e.g., lookup in a given
table did not succeed so it falls back to a full lookup) and if so
sets the strict argument to 1. That means if the egress device is given,
the route lookup needs to return a result with the same device. This
strict requirement does not work with VRFs (IPv4 or IPv6) because the
oif in the flow struct is overridden with the index of the VRF device
to trigger a match on the l3mdev rule and force the lookup to its table.
The right long term solution is to add an l3mdev index to the flow
struct such that the oif is not overridden. That solution will not
backport well, so this patch aims for a simpler solution to relax the
strict argument if the route spec device is an l3mdev slave. As done
in other places, use the FLOWI_FLAG_SKIP_NH_OIF to know that the
RT6_LOOKUP_F_IFACE flag needs to be removed.
Reported-by: Donald Sharp <sharpd@cumulusnetworks.com>
[ Upstream commit 588753f1eb18978512b1c9b85fddb457d46f9033 ]
One example of when an ICMPv6 packet is required to be looped back is
when a host acts as both a Multicast Listener and a Multicast Router.
A Multicast Router will listen on address ff02::16 for MLDv2 messages.
Currently, MLDv2 messages originating from a Multicast Listener running
on the same host as the Multicast Router are not being delivered to the
Multicast Router. This is due to dst.input being assigned the default
value of dst_discard.
This results in the packet being looped back but discarded before being
delivered to the Multicast Router.
This patch sets dst.input to ip6_input to ensure a looped back packet
is delivered to the Multicast Router.
Signed-off-by: Brendan McGrath <redmcg@redmandi.dyndns.org>
commit 76da0704507bbc51875013f6557877ab308cfd0a upstream.
In commit 242d3a49a2a1 ("ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf")
I assumed NETDEV_REGISTER and NETDEV_UNREGISTER are paired,
unfortunately, as reported by jeffy, netdev_wait_allrefs()
could rebroadcast NETDEV_UNREGISTER event until all refs are
gone.
We have to add an additional check to avoid this corner case.
For netdev_wait_allrefs() dev->reg_state is NETREG_UNREGISTERED,
for dev_change_net_namespace(), dev->reg_state is
NETREG_REGISTERED. So check for dev->reg_state != NETREG_UNREGISTERED.
Fixes: 242d3a49a2a1 ("ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf")
Reported-by: jeffy <jeffy.chen@rock-chips.com>
Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
commit 3614364527daa870264f6dde77f02853cdecd02c upstream.
rt_cookie might be used uninitialized, fix this by
initializing it.
Fixes: c5cff8561d2d ("ipv6: add rcu grace period before freeing fib6_node")
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 4e587ea71bf924f7dac621f1351653bd41e446cb ]
Commit c5cff8561d2d adds rcu grace period before freeing fib6_node. This
generates a new sparse warning on rt->rt6i_node related code:
net/ipv6/route.c:1394:30: error: incompatible types in comparison
expression (different address spaces)
./include/net/ip6_fib.h:187:14: error: incompatible types in comparison
This commit adds "__rcu" tag for rt6i_node and makes sure corresponding
rcu API is used for it.
After this fix, sparse no longer generates the above warning.
Signed-off-by: Wei Wang <weiwan@google.com>
[ Upstream commit c5cff8561d2d0006e972bd114afd51f082fee77c ]
We currently keep rt->rt6i_node pointing to the fib6_node for the route.
And some functions make use of this pointer to dereference the fib6_node
from rt structure, e.g. rt6_check(). However, as there is neither
refcount nor rcu taken when dereferencing rt->rt6i_node, it could
potentially cause crashes as rt->rt6i_node could be set to NULL by other
CPUs when doing a route deletion.
This patch introduces an rcu grace period before freeing fib6_node and
makes sure the functions that dereference it takes rcu_read_lock().
Note: there is no "Fixes" tag because this bug was there in a very
early stage.
commit f06b7549b79e29a672336d4e134524373fb7a232 upstream.
Lennert reported a failure to add different mpls encaps in a multipath
route:
$ ip -6 route add 1234::/16 \
nexthop encap mpls 10 via fe80::1 dev ens3 \
nexthop encap mpls 20 via fe80::1 dev ens3
RTNETLINK answers: File exists
The problem is that the duplicate nexthop detection does not compare
lwtunnel configuration. Add it.
Fixes: 19e42e451506 ("ipv6: support for fib route lwtunnel encap attributes")
Reported-by: João Taveira Araújo <joao.taveira@gmail.com>
Reported-by: Lennert Buytenhek <buytenh@wantstofly.org>
Acked-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Tested-by: Lennert Buytenhek <buytenh@wantstofly.org>
[ Upstream commit 242d3a49a2a1a71d8eb9f953db1bcaa9d698ce00 ]
For each netns (except init_net), we initialize its null entry
in 3 places:
1) The template itself, as we use kmemdup()
2) Code around dst_init_metrics() in ip6_route_net_init()
3) ip6_route_dev_notify(), which is supposed to initialize it after
loopback registers
Unfortunately the last one still happens in a wrong order because
we expect to initialize net->ipv6.ip6_null_entry->rt6i_idev to
net->loopback_dev's idev, thus we have to do that after we add
idev to loopback. However, this notifier has priority == 0 same as
ipv6_dev_notf, and ipv6_dev_notf is registered after
ip6_route_dev_notifier so it is called actually after
ip6_route_dev_notifier. This is similar to commit 2f460933f58e
("ipv6: initialize route null entry in addrconf_init()") which
fixes init_net.
Fix it by picking a smaller priority for ip6_route_dev_notifier.
Also, we have to release the refcnt accordingly when unregistering
loopback_dev because device exit functions are called before subsys
exit functions.
Tested-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 2f460933f58eee3393aba64f0f6d14acb08d1724 ]
Andrey reported a crash on init_net.ipv6.ip6_null_entry->rt6i_idev
since it is always NULL.
This is clearly wrong, we have code to initialize it to loopback_dev,
unfortunately the order is still not correct.
loopback_dev is registered very early during boot, we lose a chance
to re-initialize it in notifier. addrconf_init() is called after
ip6_route_init(), which means we have no chance to correct it.
Fix it by moving this initialization explicitly after
ipv6_add_dev(init_net.loopback_dev) in addrconf_init().
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 557c44be917c322860665be3d28376afa84aa936 ]
Andrey reported a fault in the IPv6 route code:
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 1 PID: 4035 Comm: a.out Not tainted 4.11.0-rc7+ #250
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff880069809600 task.stack: ffff880062dc8000
RIP: 0010:ip6_rt_cache_alloc+0xa6/0x560 net/ipv6/route.c:975
RSP: 0018:ffff880062dced30 EFLAGS: 00010206
RAX: dffffc0000000000 RBX: ffff8800670561c0 RCX: 0000000000000006
RDX: 0000000000000003 RSI: ffff880062dcfb28 RDI: 0000000000000018
RBP: ffff880062dced68 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880062dcfb28 R14: dffffc0000000000 R15: 0000000000000000
FS: 00007feebe37e7c0(0000) GS:ffff88006cb00000(0000) knlGS:0000000000000000
CR2: 00000000205a0fe4 CR3: 000000006b5c9000 CR4: 00000000000006e0
Call Trace:
ip6_pol_route+0x1512/0x1f20 net/ipv6/route.c:1128
ip6_pol_route_output+0x4c/0x60 net/ipv6/route.c:1212
Andrey's syzkaller program passes rtmsg.rtmsg_flags with the RTF_PCPU bit
set. Flags passed to the kernel are blindly copied to the allocated
rt6_info by ip6_route_info_create making a newly inserted route appear
as though it is a per-cpu route. ip6_rt_cache_alloc sees the flag set
and expects rt->dst.from to be set - which it is not since it is not
really a per-cpu copy. The subsequent call to __ip6_dst_alloc then
generates the fault.
Fix by checking for the flag and failing with EINVAL.
Fixes: d52d3997f843f ("ipv6: Create percpu rt6_info")
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
commit c2ed1880fd61a998e3ce40254a99a2ad000f1a7d upstream.
The protocol field is checked when deleting IPv4 routes, but ignored for
IPv6, which causes problems with routing daemons accidentally deleting
externally set routes (observed by multiple bird6 users).
This can be verified using `ip -6 route del <prefix> proto something`.
Signed-off-by: Mantas Mikulėnas <grawity@gmail.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
[ Upstream commit 9ed59592e3e379b2e9557dc1d9e9ec8fcbb33f16]
Trying to add an mpls encap route when the MPLS modules are not loaded
hangs. For example:
CONFIG_MPLS=y
CONFIG_NET_MPLS_GSO=m
CONFIG_MPLS_ROUTING=m
CONFIG_MPLS_IPTUNNEL=m
$ ip route add 10.10.10.10/32 encap mpls 100 via inet 10.100.1.2
The ip command hangs:
root 880 826 0 21:25 pts/0 00:00:00 ip route add 10.10.10.10/32 encap mpls 100 via inet 10.100.1.2
$ cat /proc/880/stack
[<ffffffff81065a9b>] call_usermodehelper_exec+0xd6/0x134
[<ffffffff81065efc>] __request_module+0x27b/0x30a
[<ffffffff814542f6>] lwtunnel_build_state+0xe4/0x178
[<ffffffff814aa1e4>] fib_create_info+0x47f/0xdd4
[<ffffffff814ae451>] fib_table_insert+0x90/0x41f
[<ffffffff814a8010>] inet_rtm_newroute+0x4b/0x52
modprobe is trying to load rtnl-lwt-MPLS:
root 881 5 0 21:25 ? 00:00:00 /sbin/modprobe -q -- rtnl-lwt-MPLS
and it hangs after loading mpls_router:
$ cat /proc/881/stack
[<ffffffff81441537>] rtnl_lock+0x12/0x14
[<ffffffff8142ca2a>] register_netdevice_notifier+0x16/0x179
[<ffffffffa0033025>] mpls_init+0x25/0x1000 [mpls_router]
[<ffffffff81000471>] do_one_initcall+0x8e/0x13f
[<ffffffff81119961>] do_init_module+0x5a/0x1e5
[<ffffffff810bd070>] load_module+0x13bd/0x17d6
The problem is that lwtunnel_build_state is called with rtnl lock
held preventing mpls_init from registering.
Given the potential references held by the time lwtunnel_build_state it
can not drop the rtnl lock to the load module. So, extract the module
loading code from lwtunnel_build_state into a new function to validate
the encap type. The new function is called while converting the user
request into a fib_config which is well before any table, device or
fib entries are examined.
Fixes: 745041e2aaf1 ("lwtunnel: autoload of lwt modules")
[ Upstream commit ea7a80858f57d8878b1499ea0f1b8a635cc48de7 ]
Handle failure in lwtunnel_fill_encap adding attributes to skb.
Fixes: 571e722676fe ("ipv4: support for fib route lwtunnel encap attributes")
Routes can specify an mtu explicitly or inherit the mtu from
the underlying device - this inheritance is implemented in
dst->ops->mtu handlers ip6_mtu() and ip6_blackhole_mtu().
Currently changing the mtu of a device adds mtu explicitly
to routes using that device.
ie.
# ip link set dev lo mtu 65536
# ip -6 route add local 2000::1 dev lo
# ip -6 route get 2000::1
local 2000::1 dev lo table local src ... metric 1024 pref medium
# ip link set dev lo mtu 65535
local 2000::1 dev lo table local src ... metric 1024 mtu 65535 pref medium
local 2000::1 dev lo table local src ... metric 1024 mtu 65536 pref medium
# ip -6 route del local 2000::1
After this patch the route entry no longer changes unless it already has an mtu.
There is no need: this inheritance is already done in ip6_mtu()
# ip -6 route add local 2000::2 dev lo mtu 2000
# ip -6 route get 2000::1; ip -6 route get 2000::2
local 2000::2 dev lo table local src ... metric 1024 mtu 2000 pref medium
# ip link set dev lo mtu 1501
local 2000::2 dev lo table local src ... metric 1024 mtu 1501 pref medium
local 2000::2 dev lo table local src ... metric 1024 mtu 65536 pref medium
# ip -6 route del local 2000::2
This is desirable because changing device mtu and then resetting it
to the previous value shouldn't change the user visible routing table.
Signed-off-by: Maciej Żenczykowski <maze@google.com>
CC: Eric Dumazet <edumazet@google.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Prior to this patch, ipv6 didn't do mtu lock check in ip6_update_pmtu.
It leaded to that mtu lock doesn't really work when receiving the pkt
of ICMPV6_PKT_TOOBIG.
This patch is to add mtu lock check in __ip6_rt_update_pmtu just as ipv4
did in __ip_rt_update_pmtu.
Similar to IPv4, do not consider link state when validating next hops.
Currently, if the link is down default routes can fail to insert:
$ ip -6 ro add vrf blue default via 2100:2::64 dev eth2
RTNETLINK answers: No route to host
With this patch the command succeeds.
Fixes: 8c14586fc320 ("net: ipv6: Use passed in table for nexthop lookups")
rt6_add_route_info and rt6_add_dflt_router were updated to pull the FIB
table from the device index, but the corresponding rt6_get_route_info
and rt6_get_dflt_router functions were not leading to the failure to
process RA's:
ICMPv6: RA: ndisc_router_discovery failed to add default route
Fix the 'get' functions by using the table id associated with the
device when applicable.
Also, now that default routes can be added to tables other than the
default table, rt6_purge_dflt_routers needs to be updated as well to
look at all tables. To handle that efficiently, add a flag to the table
denoting if it is has a default route via RA.
Fixes: ca254490c8dfd ("net: Add VRF support to IPv6 stack")
Three sets of overlapping changes. Nothing serious.
Since the commit below the ipmr/ip6mr rtnl_unicast() code uses the portid
instead of the previous dst_pid which was copied from in_skb's portid.
Since the skb is new the portid is 0 at that point so the packets are sent
to the kernel and we get scheduling while atomic or a deadlock (depending
on where it happens) by trying to acquire rtnl two times.
Also since this is RTM_GETROUTE, it can be triggered by a normal user.
Here's the sleeping while atomic trace:
[ 7858.212557] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:620
[ 7858.212748] in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper/0
[ 7858.212881] 2 locks held by swapper/0/0:
[ 7858.213013] #0: (((&mrt->ipmr_expire_timer))){+.-...}, at: [<ffffffff810fbbf5>] call_timer_fn+0x5/0x350
[ 7858.213422] #1: (mfc_unres_lock){+.....}, at: [<ffffffff8161e005>] ipmr_expire_process+0x25/0x130
[ 7858.213807] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.8.0-rc7+ #179
[ 7858.213934] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 7858.214108] 0000000000000000 ffff88005b403c50 ffffffff813a7804 0000000000000000
[ 7858.214412] ffffffff81a1338e ffff88005b403c78 ffffffff810a4a72 ffffffff81a1338e
[ 7858.214716] 000000000000026c 0000000000000000 ffff88005b403ca8 ffffffff810a4b9f
[ 7858.215251] Call Trace:
[ 7858.215412] <IRQ> [<ffffffff813a7804>] dump_stack+0x85/0xc1
[ 7858.215662] [<ffffffff810a4a72>] ___might_sleep+0x192/0x250
[ 7858.215868] [<ffffffff810a4b9f>] __might_sleep+0x6f/0x100
[ 7858.216072] [<ffffffff8165bea3>] mutex_lock_nested+0x33/0x4d0
[ 7858.216279] [<ffffffff815a7a5f>] ? netlink_lookup+0x25f/0x460
[ 7858.216487] [<ffffffff8157474b>] rtnetlink_rcv+0x1b/0x40
[ 7858.216687] [<ffffffff815a9a0c>] netlink_unicast+0x19c/0x260
[ 7858.216900] [<ffffffff81573c70>] rtnl_unicast+0x20/0x30
[ 7858.217128] [<ffffffff8161cd39>] ipmr_destroy_unres+0xa9/0xf0
[ 7858.217351] [<ffffffff8161e06f>] ipmr_expire_process+0x8f/0x130
[ 7858.217581] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.217785] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.217990] [<ffffffff810fbc95>] call_timer_fn+0xa5/0x350
[ 7858.218192] [<ffffffff810fbbf5>] ? call_timer_fn+0x5/0x350
[ 7858.218415] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.218656] [<ffffffff810fde10>] run_timer_softirq+0x260/0x640
[ 7858.218865] [<ffffffff8166379b>] ? __do_softirq+0xbb/0x54f
[ 7858.219068] [<ffffffff816637c8>] __do_softirq+0xe8/0x54f
[ 7858.219269] [<ffffffff8107a948>] irq_exit+0xb8/0xc0
[ 7858.219463] [<ffffffff81663452>] smp_apic_timer_interrupt+0x42/0x50
[ 7858.219678] [<ffffffff816625bc>] apic_timer_interrupt+0x8c/0xa0
[ 7858.219897] <EOI> [<ffffffff81055f16>] ? native_safe_halt+0x6/0x10
[ 7858.220165] [<ffffffff810d64dd>] ? trace_hardirqs_on+0xd/0x10
[ 7858.220373] [<ffffffff810298e3>] default_idle+0x23/0x190
[ 7858.220574] [<ffffffff8102a20f>] arch_cpu_idle+0xf/0x20
[ 7858.220790] [<ffffffff810c9f8c>] default_idle_call+0x4c/0x60
[ 7858.221016] [<ffffffff810ca33b>] cpu_startup_entry+0x39b/0x4d0
[ 7858.221257] [<ffffffff8164f995>] rest_init+0x135/0x140
[ 7858.221469] [<ffffffff81f83014>] start_kernel+0x50e/0x51b
[ 7858.221670] [<ffffffff81f82120>] ? early_idt_handler_array+0x120/0x120
[ 7858.221894] [<ffffffff81f8243f>] x86_64_start_reservations+0x2a/0x2c
[ 7858.222113] [<ffffffff81f8257c>] x86_64_start_kernel+0x13b/0x14a
Fixes: 2942e9005056 ("[RTNETLINK]: Use rtnl_unicast() for rtnetlink unicasts")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Commit 8c14586fc320 ("net: ipv6: Use passed in table for nexthop
lookups") introduced a regression: insertion of an IPv6 route in a table
not containing the appropriate connected route for the gateway but which
contained a non-connected route (like a default gateway) fails while it
was previously working:
$ ip link add eth0 type dummy
$ ip link set up dev eth0
$ ip addr add 2001:db8::1/64 dev eth0
$ ip route add ::/0 via 2001:db8::5 dev eth0 table 20
$ ip route add 2001:db8:cafe::1/128 via 2001:db8::6 dev eth0 table 20
$ ip -6 route show table 20
default via 2001:db8::5 dev eth0 metric 1024 pref medium
After this patch, we get:
2001:db8:cafe::1 via 2001:db8::6 dev eth0 metric 1024 pref medium
Signed-off-by: Vincent Bernat <vincent@bernat.im>
Acked-by: David Ahern <dsa@cumulusnetworks.com>
Tested-by: David Ahern <dsa@cumulusnetworks.com>
Make ip6_route_input_lookup available outside of ipv6 the module
similar to ip_route_input_noref in the IPv4 world.
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
A previous patch added l3mdev flow update making these hooks
redundant. Remove them.
Flip the IPv6 output path to use the l3mdev tx out hook. The VRF dst
is not returned on the first FIB lookup. Instead, the dst on the
skb is switched at the beginning of the IPv6 output processing to
send the packet to the VRF driver on xmit.
Link scope addresses (linklocal and multicast) need special handling:
specifically the oif the flow struct can not be changed because we
want the lookup tied to the enslaved interface. ie., the source address
and the returned route MUST point to the interface scope passed in.
Convert the existing vrf_get_rt6_dst to handle only link scope addresses.
Allow an L3 master device to act as the loopback for that L3 domain.
For IPv4 the device can also have the address 127.0.0.1.
Today mpls iptunnel lwtunnel_output redirect expects the tunnel
output function to handle fragmentation. This is ok but can be
avoided if we did not do the mpls output redirect too early.
ie we could wait until ip fragmentation is done and then call
mpls output for each ip fragment.
To make this work we will need,
1) the lwtunnel state to carry encap headroom
2) and do the redirect to the encap output handler on the ip fragment
(essentially do the output redirect after fragmentation)
This patch adds tunnel headroom in lwtstate to make sure we
account for tunnel data in mtu calculations during fragmentation
and adds new xmit redirect handler to redirect to lwtunnel xmit func
after ip fragmentation.
This includes IPV6 and some mtu fixes and testing from David Ahern.
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Several cases of overlapping changes, except the packet scheduler
conflicts which deal with the addition of the free list parameter
to qdisc_enqueue().
with the commit 8c14586fc320 ("net: ipv6: Use passed in table for
nexthop lookups"), net hop lookup is first performed on route creation
in the passed-in table.
However device match is not enforced in table lookup, so the found
route can be later discarded due to egress device mismatch and no
global lookup will be performed.
This cause the following to fail:
ip link add dummy1 type dummy
ip link add dummy2 type dummy
ip link set dummy1 up
ip link set dummy2 up
ip route add 2001:db8:8086::/48 dev dummy1 metric 20
ip route add 2001:db8:d34d::/64 via 2001:db8:8086::2 dev dummy1 metric 20
ip route add 2001:db8:8086::/48 dev dummy2 metric 21
ip route add 2001:db8:d34d::/64 via 2001:db8:8086::2 dev dummy2 metric 21
This change fixes the issue enforcing device lookup in
ip6_nh_lookup_table()
v1->v2: updated commit message title
Reported-and-tested-by: Beniamino Galvani <bgalvani@redhat.com>
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
VRF driver needs access to ip6_route_get_saddr code. Since it does
little beyond ipv6_dev_get_saddr and ipv6_dev_get_saddr is already
exported for modules move ip6_route_get_saddr to the header as an
inline.
Code move only; no functional change.
This patch introduces neighbour discovery ops callback structure. The
idea is to separate the handling for 6LoWPAN into the 6lowpan module.
These callback offers 6lowpan different handling, such as 802.15.4 short
address handling or RFC6775 (Neighbor Discovery Optimization for IPv6
over 6LoWPANs).
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Alexander Aring <aar@pengutronix.de>
IPv6 multicast and link-local addresses require special handling by the
VRF driver:
1. Rather than using the VRF device index and full FIB lookups,
packets to/from these addresses should use direct FIB lookups based on
the VRF device table.
2. fail sends/receives on a VRF device to/from a multicast address
(e.g, make ping6 ff02::1%<vrf> fail)
3. move the setting of the flow oif to the first dst lookup and revert
the change in icmpv6_echo_reply made in ca254490c8dfd ("net: Add VRF
support to IPv6 stack"). Linklocal/mcast addresses require use of the
skb->dev.
With this change connections into and out of a VRF enslaved device work
for multicast and link-local addresses work (icmp, tcp, and udp)
e.g.,
1. packets into VM with VRF config:
ping6 -c3 fe80::e0:f9ff:fe1c:b974%br1
ping6 -c3 ff02::1%br1
ssh -6 fe80::e0:f9ff:fe1c:b974%br1
2. packets going out a VRF enslaved device:
ping6 -c3 fe80::18f8:83ff:fe4b:7a2e%eth1
ping6 -c3 ff02::1%eth1
ssh -6 root@fe80::18f8:83ff:fe4b:7a2e%eth1
In IPv6 the ToS values are part of the flowlabel in flowi6 and get
extracted during fib rule lookup, but we forgot to correctly initialize
the flowlabel before the routing lookup.
Reported-by: <liam.mcbirnie@boeing.com>
The nf_conntrack_core.c fix in 'net' is not relevant in 'net-next'
because we no longer have a per-netns conntrack hash.
The ip_gre.c conflict as well as the iwlwifi ones were cases of
drivers/net/wireless/intel/iwlwifi/mvm/tx.c
net/ipv4/ip_gre.c
net/netfilter/nf_conntrack_core.c
Currently, when creating or updating a route, no check is performed
in both ipv4 and ipv6 code to the hoplimit value.
The caller can i.e. set hoplimit to 256, and when such route will
be used, packets will be sent with hoplimit/ttl equal to 0.
This commit adds checks for the RTAX_HOPLIMIT value, in both ipv4
ipv6 route code, substituting any value greater than 255 with 255.
This is consistent with what is currently done for ADVMSS and MTU
in the ipv4 code.
Move l3mdev_rt6_dst_by_oif and l3mdev_get_saddr to l3mdev.c. Collapse
l3mdev_get_rt6_dst into l3mdev_rt6_dst_by_oif since it is the only
user and keep the l3mdev_get_rt6_dst name for consistency with other
hooks.
A follow-on patch adds more code to these functions making them long
for inlined functions.
Similar to 3bfd847203c6 ("net: Use passed in table for nexthop lookups")
for IPv4, if the route spec contains a table id use that to lookup the
next hop first and fall back to a full lookup if it fails (per the fix
4c9bcd117918b ("net: Fix nexthop lookups")).
Example:
root@kenny:~# ip -6 ro ls table red
local 2100:1::1 dev lo proto none metric 0 pref medium
2100:1::/120 dev eth1 proto kernel metric 256 pref medium
local 2100:2::1 dev lo proto none metric 0 pref medium
2100:2::/120 dev eth2 proto kernel metric 256 pref medium
local fe80::e0:f9ff:fe09:3cac dev lo proto none metric 0 pref medium
local fe80::e0:f9ff:fe1c:b974 dev lo proto none metric 0 pref medium
fe80::/64 dev eth1 proto kernel metric 256 pref medium
fe80::/64 dev eth2 proto kernel metric 256 pref medium
ff00::/8 dev red metric 256 pref medium
ff00::/8 dev eth1 metric 256 pref medium
ff00::/8 dev eth2 metric 256 pref medium
unreachable default dev lo metric 240 error -113 pref medium
root@kenny:~# ip -6 ro add table red 2100:3::/64 via 2100:1::64
Route add fails even though 2100:1::64 is a reachable next hop:
root@kenny:~# ping6 -I red 2100:1::64
ping6: Warning: source address might be selected on device other than red.
PING 2100:1::64(2100:1::64) from 2100:1::1 red: 56 data bytes
64 bytes from 2100:1::64: icmp_seq=1 ttl=64 time=1.33 ms
With this patch:
2100:3::/64 via 2100:1::64 dev eth1 metric 1024 pref medium
There is a case in connected UDP socket such that
getsockopt(IPV6_MTU) will return a stale MTU value. The reproducible
sequence could be the following:
1. Create a connected UDP socket
2. Send some datagrams out
3. Receive a ICMPV6_PKT_TOOBIG
4. No new outgoing datagrams to trigger the sk_dst_check()
logic to update the sk->sk_dst_cache.
5. getsockopt(IPV6_MTU) returns the mtu from the invalid
sk->sk_dst_cache instead of the newly created RTF_CACHE clone.
This patch updates the sk->sk_dst_cache for a connected datagram sk
during pmtu-update code path.
Note that the sk->sk_v6_daddr is used to do the route lookup
instead of skb->data (i.e. iph). It is because a UDP socket can become
connected after sending out some datagrams in un-connected state. or
It can be connected multiple times to different destinations. Hence,
iph may not be related to where sk is currently connected to.
It is done under '!sock_owned_by_user(sk)' condition because
the user may make another ip6_datagram_connect() (i.e changing
the sk->sk_v6_daddr) while dst lookup is happening in the pmtu-update
code path.
For the sock_owned_by_user(sk) == true case, the next patch will
introduce a release_cb() which will update the sk->sk_dst_cache.
Test:
Server (Connected UDP Socket):
Route Details:
[root@arch-fb-vm1 ~]# ip -6 r show | egrep '2fac'
2fac::/64 dev eth0 proto kernel metric 256 pref medium
2fac:face::/64 via 2fac::face dev eth0 metric 1024 pref medium
A simple python code to create a connected UDP socket:
import socket
import errno
HOST = '2fac::1'
PORT = 8080
s = socket.socket(socket.AF_INET6, socket.SOCK_DGRAM)
s.bind((HOST, PORT))
s.connect(('2fac:face::face', 53))
print("connected")
while True:
try:
data = s.recv(1024)
except socket.error as se:
if se.errno == errno.EMSGSIZE:
pmtu = s.getsockopt(41, 24)
print("PMTU:%d" % pmtu)
break
s.close()
Python program output after getting a ICMPV6_PKT_TOOBIG:
[root@arch-fb-vm1 ~]# python2 ~/devshare/kernel/tasks/fib6/udp-connect-53-8080.py
connected
PMTU:1300
Cache routes after recieving TOOBIG:
[root@arch-fb-vm1 ~]# ip -6 r show table cache
2fac:face::face via 2fac::face dev eth0 metric 0
cache expires 463sec mtu 1300 pref medium
Client (Send the ICMPV6_PKT_TOOBIG):
scapy is used to generate the TOOBIG message. Here is the scapy script I have
used:
>>> p=Ether(src='da:75:4d:36:ac:32', dst='52:54:00:12:34:66', type=0x86dd)/IPv6(src='2fac::face', dst='2fac::1')/ICMPv6PacketTooBig(mtu=1300)/IPv6(src='2fac::
1',dst='2fac:face::face', nh='UDP')/UDP(sport=8080,dport=53)
>>> sendp(p, iface='qemubr0')
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Reported-by: Wei Wang <weiwan@google.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Wei Wang <weiwan@google.com>
Vivek reported a kernel exception deleting a VRF with an active
connection through it. The root cause is that the socket has a cached
reference to a dst that is destroyed. Converting the dst_destroy to
dst_release and letting proper reference counting kick in does not
work as the dst has a reference to the device which needs to be released
as well.
I talked to Hannes about this at netdev and he pointed out the ipv4 and
ipv6 dst handling has dst_ifdown for just this scenario. Rather than
continuing with the reinvented dst wheel in VRF just remove it and
leverage the ipv4 and ipv6 versions.
Fixes: 193125dbd8eb2 ("net: Introduce VRF device driver")
Fixes: 35402e3136634 ("net: Add IPv6 support to VRF device")
The current implementation of ip6_dst_lookup_tail basically
ignore the egress ifindex match: if the saddr is set,
ip6_route_output() purposefully ignores flowi6_oif, due
to the commit d46a9d678e4c ("net: ipv6: Dont add RT6_LOOKUP_F_IFACE
flag if saddr set"), if the saddr is 'any' the first route lookup
in ip6_dst_lookup_tail fails, but upon failure a second lookup will
be performed with saddr set, thus ignoring the ifindex constraint.
This commit adds an output route lookup function variant, which
allows the caller to specify lookup flags, and modify
ip6_dst_lookup_tail() to enforce the ifindex match on the second
lookup via said helper.
ip6_route_output() becames now a static inline function build on
top of ip6_route_output_flags(); as a side effect, out-of-tree
modules need now a GPL license to access the output route lookup
functionality.
Add the support for adding expire value to routes, requested by
Tom Gundersen <teg@jklm.no> for systemd-networkd, and NetworkManager
wants it too.
implement it by adding the new RTNETLINK attribute RTA_EXPIRES.
drivers/net/ethernet/renesas/ravb_main.c
kernel/bpf/syscall.c
net/ipv4/ipmr.c
All three conflicts were cases of overlapping changes.
This reverts commit ab450605b35caa768ca33e86db9403229bf42be4.
In IPv6, we cannot inherit the dst of the original dst. ndisc packets
are IPv6 packets and may take another route than the original packet.
This patch breaks the following scenario: a packet comes from eth0 and
is forwarded through vxlan1. The encapsulated packet triggers an NS
which cannot be sent because of the wrong route.
CC: Jiri Benc <jbenc@redhat.com>
CC: Thomas Graf <tgraf@suug.ch>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Add tracepoint to show fib6 table lookups and result.
All DST_NOCACHE rt6_info used to have rt->dst.from set to
its parent.
After commit 8e3d5be73681 ("ipv6: Avoid double dst_free"),
DST_NOCACHE is also set to rt6_info which does not have
a parent (i.e. rt->dst.from is NULL).
This patch catches the rt->dst.from == NULL case.
Fixes: 8e3d5be73681 ("ipv6: Avoid double dst_free")
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Since the expires of the DST_NOCACHE rt can be set during
the ip6_rt_update_pmtu(), we also need to consider the expires
value when doing ip6_dst_check().
This patches creates __rt6_check_expired() to only
check the expire value (if one exists) of the current rt.
In rt6_dst_from_check(), it adds __rt6_check_expired() as
one of the condition check.
