path: root/net/ipv6/route.c
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-21[IPV6]: Flag RTF_ANYCAST for anycast routes.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2005-12-19[IPV6]: Fix route lifetime.YOSHIFUJI Hideaki
The route expiration time is stored in rt6i_expires in jiffies. The argument of rt6_route_add() for adding a route is not the expiration time in jiffies nor in clock_t, but the lifetime (or time left before expiration) in clock_t. Because of the confusion, we sometimes saw several strange errors (FAILs) in TAHI IPv6 Ready Logo Phase-2 Self Test. The symptoms were analyzed by Mitsuru Chinen <CHINEN@jp.ibm.com>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-17[IPV6]: Fib dump really needs GFP_ATOMIC.David S. Miller
Revert: 8225ccbaf01b459cf1e462047a51b2851e756bc1 Based upon a report by Yan Zheng. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-12[IPV6]: Fix unnecessary GFP_ATOMIC allocation in fib6 dumpThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-12[IPV6]: Fix rtnetlink dump infinite loopHerbert Xu
The recent change to netlink dump "done" callback handling broke IPv6 which played dirty tricks with the "done" callback. This causes an infinite loop during a dump. The following patch fixes it. This bug was reported by Jeff Garzik. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Make netlink_callback->done() optionalThomas Graf
Most netlink families make no use of the done() callback, making it optional gets rid of all unnecessary dummy implementations. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-31[IPV6]: Fix behavior of ip6_route_input() for link local addressYan Zheng
I find that linux will reply echo request destined to an address which belongs to an interface other than the one from which the request received. This behavior doesn't make sense for link local address. YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> said: Please note that sender does need to setup neighbor entry by hand to reproduce this bug. (Link-local address on eth1 is not visible on eth0, from the point of view of neighbor discovery in IPv6.) +--------+ +--------+ | sender | | router | +---+----+ +-+----+-+ |eth0 eth0| |eth1 -----+----------------------+- -+-------------- Signed-off-by: Yan Zheng <yanzheng@21cn.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org> (forwarded) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[IPV6]: V6 route events reported with wrong netlink PID and seq numberJamal Hadi Salim
Essentially netlink at the moment always reports a pid and sequence of 0 always for v6 route activities. To understand the repurcassions of this look at: http://lists.quagga.net/pipermail/quagga-dev/2005-June/003507.html While fixing this, i took the liberty to resolve the outstanding issue of IPV6 routes inserted via ioctls to have the correct pids as well. This patch tries to behave as close as possible to the v4 routes i.e maintains whatever PID the socket issuing the command owns as opposed to the process. That made the patch a little bulky. I have tested against both netlink derived utility to add/del routes as well as ioctl derived one. The Quagga folks have tested against quagga. This fixes the problem and so far hasnt been detected to introduce any new issues. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Correctly set NLM_F_MULTI without checking the pidJamal Hadi Salim
This patch rectifies some rtnetlink message builders that derive the flags from the pid. It is now explicit like the other cases which get it right. Also fixes half a dozen dumpers which did not set NLM_F_MULTI at all. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-28[IPV6]: Incorrect permissions on route flush sysctlDave Jones
On Mon, Apr 25, 2005 at 12:01:13PM -0400, Dave Jones wrote: > This has been brought up before.. http://lkml.org/lkml/2000/1/21/116 > but didnt seem to get resolved. This morning I got someone > file a bugzilla about it breaking sysctl(8). And here's its ipv6 counterpart. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
