path: root/net/ipv6/sit.c
2015-04-08ipv6: call iptunnel_xmit with NULL sock pointer if no tunnel sock is availableHannes Frederic Sowa
Fixes: 79b16aadea32cce ("udp_tunnel: Pass UDP socket down through udp_tunnel{, 6}_xmit_skb().") Reported-by: David S. Miller <davem@davemloft.net> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-02ipip,gre,vti,sit: implement ndo_get_iflinkNicolas Dichtel
Don't use dev->iflink anymore. CC: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31netlink: implement nla_get_in_addr and nla_get_in6_addrJiri Benc
Those are counterparts to nla_put_in_addr and nla_put_in6_addr. Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31netlink: implement nla_put_in_addr and nla_put_in6_addrJiri Benc
IP addresses are often stored in netlink attributes. Add generic functions to do that. For nla_put_in_addr, it would be nicer to pass struct in_addr but this is not used universally throughout the kernel, in way too many places __be32 is used to store IPv4 address. Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ipv6: coding style: comparison for inequality with NULLIan Morris
The ipv6 code uses a mixture of coding styles. In some instances check for NULL pointer is done as x != NULL and sometimes as x. x is preferred according to checkpatch and this patch makes the code consistent by adopting the latter form. No changes detected by objdiff. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ipv6: coding style: comparison for equality with NULLIan Morris
The ipv6 code uses a mixture of coding styles. In some instances check for NULL pointer is done as x == NULL and sometimes as !x. !x is preferred according to checkpatch and this patch makes the code consistent by adopting the latter form. No changes detected by objdiff. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/vxlan.c drivers/vhost/net.c include/linux/if_vlan.h net/core/dev.c The net/core/dev.c conflict was the overlap of one commit marking an existing function static whilst another was adding a new function. In the include/linux/if_vlan.h case, the type used for a local variable was changed in 'net', whereas the function got rewritten to fix a stacked vlan bug in 'net-next'. In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next' overlapped with an endainness fix for VHOST 1.0 in 'net'. In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter in 'net-next' whereas in 'net' there was a bug fix to pass in the correct network namespace pointer in calls to this function. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05sit: fix some __be16/u16 mismatchesEric Dumazet
Fixes following sparse warnings : net/ipv6/sit.c:1509:32: warning: incorrect type in assignment (different base types) net/ipv6/sit.c:1509:32: expected restricted __be16 [usertype] sport net/ipv6/sit.c:1509:32: got unsigned short net/ipv6/sit.c:1514:32: warning: incorrect type in assignment (different base types) net/ipv6/sit.c:1514:32: expected restricted __be16 [usertype] dport net/ipv6/sit.c:1514:32: got unsigned short net/ipv6/sit.c:1711:38: warning: incorrect type in argument 3 (different base types) net/ipv6/sit.c:1711:38: expected unsigned short [unsigned] [usertype] value net/ipv6/sit.c:1711:38: got restricted __be16 [usertype] sport net/ipv6/sit.c:1713:38: warning: incorrect type in argument 3 (different base types) net/ipv6/sit.c:1713:38: expected unsigned short [unsigned] [usertype] value net/ipv6/sit.c:1713:38: got restricted __be16 [usertype] dport Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-19tunnels: advertise link netns via netlinkNicolas Dichtel
Implement rtnl_link_ops->get_link_net() callback so that IFLA_LINK_NETNSID is added to rtnetlink messages. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-23ipv6: coding style improvements (remove assignment in if statements)Ian Morris
This change has no functional impact and simply addresses some coding style issues detected by checkpatch. Specifically this change adjusts "if" statements which also include the assignment of a variable. No changes to the resultant object files result as determined by objdiff. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-11-05fou: Fix typo in returning flags in netlinkTom Herbert
When filling netlink info, dport is being returned as flags. Fix instances to return correct value. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-03sit: Use ipip6_tunnel_init as the ndo_init function.Steffen Klassert
ipip6_tunnel_init() sets the dev->iflink via a call to ipip6_tunnel_bind_dev(). After that, register_netdevice() sets dev->iflink = -1. So we loose the iflink configuration for ipv6 tunnels. Fix this by using ipip6_tunnel_init() as the ndo_init function. Then ipip6_tunnel_init() is called after dev->iflink is set to -1 from register_netdevice(). Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18ipv6: fix a potential use after free in sit.cLi RongQing
pskb_may_pull() maybe change skb->data and make iph pointer oboslete, fix it by geting ip header length directly. Fixes: ca15a078 (sit: generate icmpv6 error when receiving icmpv4 error) Cc: Oussama Ghorbel <ghorbel@pivasoftware.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-07net: better IFF_XMIT_DST_RELEASE supportEric Dumazet
Testing xmit_more support with netperf and connected UDP sockets, I found strange dst refcount false sharing. Current handling of IFF_XMIT_DST_RELEASE is not optimal. Dropping dst in validate_xmit_skb() is certainly too late in case packet was queued by cpu X but dequeued by cpu Y The logical point to take care of drop/force is in __dev_queue_xmit() before even taking qdisc lock. As Julian Anastasov pointed out, need for skb_dst() might come from some packet schedulers or classifiers. This patch adds new helper to cleanly express needs of various drivers or qdiscs/classifiers. Drivers that need skb_dst() in their ndo_start_xmit() should call following helper in their setup instead of the prior : dev->priv_flags &= ~IFF_XMIT_DST_RELEASE; -> netif_keep_dst(dev); Instead of using a single bit, we use two bits, one being eventually rebuilt in bonding/team drivers. The other one, is permanent and blocks IFF_XMIT_DST_RELEASE being rebuilt in bonding/team. Eventually, we could add something smarter later. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-01sit: Set inner IP protocol in sitTom Herbert
Call skb_set_inner_ipproto to set inner IP protocol to IPPROTO_IPV6 before tunnel_xmit. This is needed if UDP encapsulation (fou) is being done. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-19sit: Setup and TX path for sit/UDP foo-over-udp encapsulationTom Herbert
Added netlink handling of IP tunnel encapulation paramters, properly adjust MTU for encapsulation. Added ip_tunnel_encap call to ipip6_tunnel_xmit to actually perform FOU encapsulation. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-24ipv6: White-space cleansing : Line LayoutsIan Morris
This patch makes no changes to the logic of the code but simply addresses coding style issues as detected by checkpatch. Both objdump and diff -w show no differences. A number of items are addressed in this patch: * Multiple spaces converted to tabs * Spaces before tabs removed. * Spaces in pointer typing cleansed (char *)foo etc. * Remove space after sizeof * Ensure spacing around comparators such as if statements. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-14sit: Fix ipip6_tunnel_lookup device matching criteriaShmulik Ladkani
As of 4fddbf5d78 ("sit: strictly restrict incoming traffic to tunnel link device"), when looking up a tunnel, tunnel's underlying interface (t->parms.link) is verified to match incoming traffic's ingress device. However the comparison was incorrectly based on skb->dev->iflink. Instead, dev->ifindex should be used, which correctly represents the interface from which the IP stack hands the ipip6 packets. This allows setting up sit tunnels bound to vlan interfaces (otherwise incoming ipip6 traffic on the vlan interface was dropped due to ipip6_tunnel_lookup match failure). Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-15net: set name_assign_type in alloc_netdev()Tom Gundersen
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert all users to pass NET_NAME_UNKNOWN. Coccinelle patch: @@ expression sizeof_priv, name, setup, txqs, rxqs, count; @@ ( -alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs) +alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs) | -alloc_netdev_mq(sizeof_priv, name, setup, count) +alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count) | -alloc_netdev(sizeof_priv, name, setup) +alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup) ) v9: move comments here from the wrong commit Signed-off-by: Tom Gundersen <teg@jklm.no> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/core/rtnetlink.c net/core/skbuff.c Both conflicts were very simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-10ipip, sit: fix ipv4_{update_pmtu,redirect} callsDmitry Popov
ipv4_{update_pmtu,redirect} were called with tunnel's ifindex (t->dev is a tunnel netdevice). It caused wrong route lookup and failure of pmtu update or redirect. We should use the same ifindex that we use in ip_route_output_* in *tunnel_xmit code. It is t->parms.link . Signed-off-by: Dmitry Popov <ixaphire@qrator.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-21net: tunnels - enable module autoloadingTom Gundersen
Enable the module alias hookup to allow tunnel modules to be autoloaded on demand. This is in line with how most other netdev kinds work, and will allow userspace to create tunnels without having CAP_SYS_MODULE. Signed-off-by: Tom Gundersen <teg@jklm.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-16sit: use the right netns in ioctl handlerNicolas Dichtel
Because the netdevice may be in another netns than the i/o netns, we should use the i/o netns instead of dev_net(dev). Note that netdev_priv(dev) cannot bu NULL, hence we can remove these useless checks. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-15ipv4: add a sock pointer to dst->output() path.Eric Dumazet
In the dst->output() path for ipv4, the code assumes the skb it has to transmit is attached to an inet socket, specifically via ip_mc_output() : The sk_mc_loop() test triggers a WARN_ON() when the provider of the packet is an AF_PACKET socket. The dst->output() method gets an additional 'struct sock *sk' parameter. This needs a cascade of changes so that this parameter can be propagated from vxlan to final consumer. Fixes: 8f646c922d55 ("vxlan: keep original skb ownership") Reported-by: lucien xin <lucien.xin@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/ath/ath9k/recv.c drivers/net/wireless/mwifiex/pcie.c net/ipv6/sit.c The SIT driver conflict consists of a bug fix being done by hand in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper was created (netdev_alloc_pcpu_stats()) which takes care of this. The two wireless conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-20sit: fix panic with route cache in ip tunnelsNicolas Dichtel
Bug introduced by commit 7d442fab0a67 ("ipv4: Cache dst in tunnels"). Because sit code does not call ip_tunnel_init(), the dst_cache was not initialized. CC: Tom Herbert <therbert@google.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-14net: introduce netdev_alloc_pcpu_stats() for driversWANG Cong
There are many drivers calling alloc_percpu() to allocate pcpu stats and then initializing ->syncp. So just introduce a helper function for them. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-04net: unify the pcpu_tstats and br_cpu_netstats as oneLi RongQing
They are same, so unify them as one, pcpu_sw_netstats. Define pcpu_sw_netstat in netdevice.h, remove pcpu_tstats from if_tunnel and remove br_cpu_netstats from br_private.h Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-01ipv6: fix the use of pcpu_tstats in sitLi RongQing
when read/write the 64bit data, the correct lock should be hold. Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-27ipv6: release dst properly in ipip6_tunnel_xmitLi RongQing
if a dst is not attached to anywhere, it should be released before exit ipip6_tunnel_xmit, otherwise cause dst memory leakage. Fixes: 61c1db7fae21 ("ipv6: sit: add GSO/TSO support") Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18ipv6: sit: update mtu check to take care of gso packetsEric Dumazet
While testing my changes for TSO support in SIT devices, I was using sit0 tunnel which appears to include nopmtudisc flag. But using : ip tun add sittun mode sit remote $REMOTE_IPV4 local $LOCAL_IPV4 \ dev $IFACE We get a tunnel which rejects too long packets because of the mtu check which is not yet GSO aware. erd:~# ip tunnel sittun: ipv6/ip remote 10.246.17.84 local 10.246.17.83 ttl inherit 6rd-prefix 2002::/16 sit0: ipv6/ip remote any local any ttl 64 nopmtudisc 6rd-prefix 2002::/16 This patch is based on an excellent report from Michal Shmidt. In the future, we probably want to extend the MTU check to do the right thing for GSO packets... Fixes: ("61c1db7fae21 ipv6: sit: add GSO/TSO support") Reported-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-28sit: use kfree_skb to replace dev_kfree_skbGao feng
In failure case, we should use kfree_skb not dev_kfree_skb to free skbuff, dev_kfree_skb is defined as consume_skb. Trace takes advantage of this point. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-23sit: generate icmpv6 error when receiving icmpv4 errorOussama Ghorbel
Send icmpv6 error with type "destination unreachable" and code "address unreachable" when receiving icmpv4 error and sufficient data bytes are available This patch enhances the compliance of sit tunnel with section 3.4 of rfc 4213 Signed-off-by: Oussama Ghorbel <ghorbel@pivasoftware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Mostly these are fixes for fallout due to merge window changes, as well as cures for problems that have been with us for a much longer period of time" 1) Johannes Berg noticed two major deficiencies in our genetlink registration. Some genetlink protocols we passing in constant counts for their ops array rather than something like ARRAY_SIZE(ops) or similar. Also, some genetlink protocols were using fixed IDs for their multicast groups. We have to retain these fixed IDs to keep existing userland tools working, but reserve them so that other multicast groups used by other protocols can not possibly conflict. In dealing with these two problems, we actually now use less state management for genetlink operations and multicast groups. 2) When configuring interface hardware timestamping, fix several drivers that simply do not validate that the hwtstamp_config value is one the driver actually supports. From Ben Hutchings. 3) Invalid memory references in mwifiex driver, from Amitkumar Karwar. 4) In dev_forward_skb(), set the skb->protocol in the right order relative to skb_scrub_packet(). From Alexei Starovoitov. 5) Bridge erroneously fails to use the proper wrapper functions to make calls to netdev_ops->ndo_vlan_rx_{add,kill}_vid. Fix from Toshiaki Makita. 6) When detaching a bridge port, make sure to flush all VLAN IDs to prevent them from leaking, also from Toshiaki Makita. 7) Put in a compromise for TCP Small Queues so that deep queued devices that delay TX reclaim non-trivially don't have such a performance decrease. One particularly problematic area is 802.11 AMPDU in wireless. From Eric Dumazet. 8) Fix crashes in tcp_fastopen_cache_get(), we can see NULL socket dsts here. Fix from Eric Dumzaet, reported by Dave Jones. 9) Fix use after free in ipv6 SIT driver, from Willem de Bruijn. 10) When computing mergeable buffer sizes, virtio-net fails to take the virtio-net header into account. From Michael Dalton. 11) Fix seqlock deadlock in ip4_datagram_connect() wrt. statistic bumping, this one has been with us for a while. From Eric Dumazet. 12) Fix NULL deref in the new TIPC fragmentation handling, from Erik Hugne. 13) 6lowpan bit used for traffic classification was wrong, from Jukka Rissanen. 14) macvlan has the same issue as normal vlans did wrt. propagating LRO disabling down to the real device, fix it the same way. From Michal Kubecek. 15) CPSW driver needs to soft reset all slaves during suspend, from Daniel Mack. 16) Fix small frame pacing in FQ packet scheduler, from Eric Dumazet. 17) The xen-netfront RX buffer refill timer isn't properly scheduled on partial RX allocation success, from Ma JieYue. 18) When ipv6 ping protocol support was added, the AF_INET6 protocol initialization cleanup path on failure was borked a little. Fix from Vlad Yasevich. 19) If a socket disconnects during a read/recvmsg/recvfrom/etc that blocks we can do the wrong thing with the msg_name we write back to userspace. From Hannes Frederic Sowa. There is another fix in the works from Hannes which will prevent future problems of this nature. 20) Fix route leak in VTI tunnel transmit, from Fan Du. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (106 commits) genetlink: make multicast groups const, prevent abuse genetlink: pass family to functions using groups genetlink: add and use genl_set_err() genetlink: remove family pointer from genl_multicast_group genetlink: remove genl_unregister_mc_group() hsr: don't call genl_unregister_mc_group() quota/genetlink: use proper genetlink multicast APIs drop_monitor/genetlink: use proper genetlink multicast APIs genetlink: only pass array to genl_register_family_with_ops() tcp: don't update snd_nxt, when a socket is switched from repair mode atm: idt77252: fix dev refcnt leak xfrm: Release dst if this dst is improper for vti tunnel netlink: fix documentation typo in netlink_set_err() be2net: Delete secondary unicast MAC addresses during be_close be2net: Fix unconditional enabling of Rx interface options net, virtio_net: replace the magic value ping: prevent NULL pointer dereference on write to msg_name bnx2x: Prevent "timeout waiting for state X" bnx2x: prevent CFC attention bnx2x: Prevent panic during DMAE timeout ...
2013-11-14sit: fix use after free of fb_tunnel_devWillem de Bruijn
Bug: The fallback device is created in sit_init_net and assumed to be freed in sit_exit_net. First, it is dereferenced in that function, in sit_destroy_tunnels: struct net *net = dev_net(sitn->fb_tunnel_dev); Prior to this, rtnl_unlink_register has removed all devices that match rtnl_link_ops == sit_link_ops. Commit 205983c43700 added the line + sitn->fb_tunnel_dev->rtnl_link_ops = &sit_link_ops; which cases the fallback device to match here and be freed before it is last dereferenced. Fix: This commit adds an explicit .delllink callback to sit_link_ops that skips deallocation at rtnl_unlink_register for the fallback device. This mechanism is comparable to the one in ip_tunnel. It also modifies sit_destroy_tunnels and its only caller sit_exit_net to avoid the offending dereference in the first place. That double lookup is more complicated than required. Test: The bug is only triggered when CONFIG_NET_NS is enabled. It causes a GPF only when CONFIG_DEBUG_SLAB is enabled. Verified that this bug exists at the mentioned commit, at davem-net HEAD and at 3.11.y HEAD. Verified that it went away after applying this patch. Fixes: 205983c43700 ("sit: allow to use rtnl ops on fb tunnel") Signed-off-by: Willem de Bruijn <willemb@google.com> Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: "The biggest changes: - add lockdep support for seqcount/seqlocks structures, this unearthed both bugs and required extra annotation. - move the various kernel locking primitives to the new kernel/locking/ directory" * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) block: Use u64_stats_init() to initialize seqcounts locking/lockdep: Mark __lockdep_count_forward_deps() as static lockdep/proc: Fix lock-time avg computation locking/doc: Update references to kernel/mutex.c ipv6: Fix possible ipv6 seqlock deadlock cpuset: Fix potential deadlock w/ set_mems_allowed seqcount: Add lockdep functionality to seqcount/seqlock structures net: Explicitly initialize u64_stats_sync structures for lockdep locking: Move the percpu-rwsem code to kernel/locking/ locking: Move the lglocks code to kernel/locking/ locking: Move the rwsem code to kernel/locking/ locking: Move the rtmutex code to kernel/locking/ locking: Move the semaphore core to kernel/locking/ locking: Move the spinlock code to kernel/locking/ locking: Move the lockdep code to kernel/locking/ locking: Move the mutex code to kernel/locking/ hung_task debugging: Add tracepoint to report the hang x86/locking/kconfig: Update paravirt spinlock Kconfig description lockstat: Report avg wait and hold times lockdep, x86/alternatives: Drop ancient lockdep fixup message ...
2013-11-06net: Explicitly initialize u64_stats_sync structures for lockdepJohn Stultz
In order to enable lockdep on seqcount/seqlock structures, we must explicitly initialize any locks. The u64_stats_sync structure, uses a seqcount, and thus we need to introduce a u64_stats_init() function and use it to initialize the structure. This unfortunately adds a lot of fairly trivial initialization code to a number of drivers. But the benefit of ensuring correctness makes this worth while. Because these changes are required for lockdep to be enabled, and the changes are quite trivial, I've not yet split this patch out into 30-some separate patches, as I figured it would be better to get the various maintainers thoughts on how to best merge this change along with the seqcount lockdep enablement. Feedback would be appreciated! Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: James Morris <jmorris@namei.org> Cc: Jesse Gross <jesse@nicira.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Mirko Lindner <mlindner@marvell.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Roger Luethi <rl@hellgate.ch> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Simon Horman <horms@verge.net.au> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Wensong Zhang <wensong@linux-vs.org> Cc: netdev@vger.kernel.org Link: http://lkml.kernel.org/r/1381186321-4906-2-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-21ipv6: sit: add GSO/TSO supportEric Dumazet
Now ipv6_gso_segment() is stackable, its relatively easy to implement GSO/TSO support for SIT tunnels Performance results, when segmentation is done after tunnel device (as no NIC is yet enabled for TSO SIT support) : Before patch : lpq84:~# ./netperf -H 2002:af6:1153:: -Cc MIGRATED TCP STREAM TEST from ::0 (::) port 0 AF_INET6 to 2002:af6:1153:: () port 0 AF_INET6 Recv Send Send Utilization Service Demand Socket Socket Message Elapsed Send Recv Send Recv Size Size Size Time Throughput local remote local remote bytes bytes bytes secs. 10^6bits/s % S % S us/KB us/KB 87380 16384 16384 10.00 3168.31 4.81 4.64 2.988 2.877 After patch : lpq84:~# ./netperf -H 2002:af6:1153:: -Cc MIGRATED TCP STREAM TEST from ::0 (::) port 0 AF_INET6 to 2002:af6:1153:: () port 0 AF_INET6 Recv Send Send Utilization Service Demand Socket Socket Message Elapsed Send Recv Send Recv Size Size Size Time Throughput local remote local remote bytes bytes bytes secs. 10^6bits/s % S % S us/KB us/KB 87380 16384 16384 10.00 5525.00 7.76 5.17 2.763 1.840 Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-01sit: allow to use rtnl ops on fb tunnelNicolas Dichtel
rtnl ops where introduced by ba3e3f50a0e5 ("sit: advertise tunnel param via rtnl"), but I forget to assign rtnl ops to fb tunnels. Now that it is done, we must remove the explicit call to unregister_netdevice_queue(), because the fallback tunnel is added to the queue in sit_destroy_tunnels() when checking rtnl_link_ops of all netdevices (this is valid since commit 5e6700b3bf98 ("sit: add support of x-netns")). Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-28IPv6 NAT: Do not drop DNATed 6to4/6rd packetsCatalin\(ux\) M. BOIE
When a router is doing DNAT for 6to4/6rd packets the latest anti-spoofing commit 218774dc ("ipv6: add anti-spoofing checks for 6to4 and 6rd") will drop them because the IPv6 address embedded does not match the IPv4 destination. This patch will allow them to pass by testing if we have an address that matches on 6to4/6rd interface. I have been hit by this problem using Fedora and IPV6TO4_IPV4ADDR. Also, log the dropped packets (with rate limit). Signed-off-by: Catalin(ux) M. BOIE <catab@embedromix.ro> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c net/bridge/br_multicast.c net/ipv6/sit.c The conflicts were minor: 1) sit.c changes overlap with change to ip_tunnel_xmit() signature. 2) br_multicast.c had an overlap between computing max_delay using msecs_to_jiffies and turning MLDV2_MRC() into an inline function with a name using lowercase instead of uppercase letters. 3) stmmac had two overlapping changes, one which conditionally allocated and hooked up a dma_cfg based upon the presence of the pbl OF property, and another one handling store-and-forward DMA made. The latter of which should not go into the new of_find_property() basic block. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-04tunnels: harmonize cleanup done on skb on rx pathNicolas Dichtel
The goal of this patch is to harmonize cleanup done on a skbuff on rx path. Before this patch, behaviors were different depending of the tunnel type. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-04tunnels: harmonize cleanup done on skb on xmit pathNicolas Dichtel
The goal of this patch is to harmonize cleanup done on a skbuff on xmit path. Before this patch, behaviors were different depending of the tunnel type. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-04skb: allow skb_scrub_packet() to be used by tunnelsNicolas Dichtel
This function was only used when a packet was sent to another netns. Now, it can also be used after tunnel encapsulation or decapsulation. Only skb_orphan() should not be done when a packet is not crossing netns. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-04iptunnels: remove net arg from iptunnel_xmit()Nicolas Dichtel
This argument is not used, let's remove it. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-30ipv4 tunnels: fix an oops when using ipip/sit with IPsecLi Hongjun
Since commit 3d7b46cd20e3 (ip_tunnel: push generic protocol handling to ip_tunnel module.), an Oops is triggered when an xfrm policy is configured on an IPv4 over IPv4 tunnel. xfrm4_policy_check() calls __xfrm_policy_check2(), which uses skb_dst(skb). But this field is NULL because iptunnel_pull_header() calls skb_dst_drop(skb). Signed-off-by: Li Hongjun <hongjun.li@6wind.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-19ipv6: wire up skb->encapsulationHannes Frederic Sowa
When pushing a new header before current one call skb_reset_inner_headers to record the position of the inner headers in the various ipv6 tunnel protocols. We later need this to correctly identify the addresses needed to send back an error in the xfrm layer. This change is safe, because skb->protocol is always checked before dereferencing data from the inner protocol. Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-08-15ipv4 tunnels: use net_eq() helper to check netnsNicolas Dichtel
It's better to use available helpers for these tests. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
