Remove dead code from tcp_v6_connect()
For same reasons than in commit 12e25e1041d0 ("tcp: remove redundant
checks"), we can remove redundant checks done for timewait sockets.
tcp_v4_rcv() checks the following before calling tcp_v4_do_rcv():
if (th->doff < sizeof(struct tcphdr) / 4)
goto bad_packet;
if (!pskb_may_pull(skb, th->doff * 4))
goto discard_it;
So following check in tcp_v4_do_rcv() is redundant
and "goto csum_err;" is wrong anyway.
if (skb->len < tcp_hdrlen(skb) || ...)
goto csum_err;
A second check can be removed after no_tcp_socket label for same reason.
Same tests can be removed in tcp_v6_do_rcv()
Note : short tcp frames are not properly accounted in tcpInErrs MIB,
because pskb_may_pull() failure simply drops incoming skb, we might
fix this in a separate patch.
Instead of doing the rt6->rt6i_node check whenever we need
to get the route's cookie. Refactor it into rt6_get_cookie().
It is a prep work to handle FLOWI_FLAG_KNOWN_NH and also
percpu rt6_info later.
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Julian Anastasov <ja@ssi.bg>
This patch removes the assumptions that the returned rt is always
a RTF_CACHE entry with the rt6i_dst and rt6i_src containing the
destination and source address. The dst and src can be recovered from
the calling site.
We may consider to rename (rt6i_dst, rt6i_src) to
(rt6i_key_dst, rt6i_key_src) later.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
drivers/net/ethernet/cadence/macb.c
drivers/net/phy/phy.c
include/linux/skbuff.h
net/ipv4/tcp.c
net/switchdev/switchdev.c
Switchdev was a case of RTNH_H_{EXTERNAL --> OFFLOAD}
renaming overlapping with net-next changes of various
sorts.
phy.c was a case of two changes, one adding a local
variable to a function whilst the second was removing
one.
tcp.c overlapped a deadlock fix with the addition of new tcp_info
statistic values.
macb.c involved the addition of two zyncq device entries.
skbuff.h involved adding back ipv4_daddr to nf_bridge_info
whilst net-next changes put two other existing members of
that struct into a union.
This patch tracks the total number of inbound and outbound segments on a
TCP socket. One may use this number to have an idea on connection
quality when compared against the retransmissions.
RFC4898 named these : tcpEStatsPerfSegsIn and tcpEStatsPerfSegsOut
These are a 32bit field each and can be fetched both from TCP_INFO
getsockopt() if one has a handle on a TCP socket, or from inet_diag
netlink facility (iproute2/ss patch will follow)
Note that tp->segs_out was placed near tp->snd_nxt for good data
locality and minimal performance impact, while tp->segs_in was placed
near tp->bytes_received for the same reason.
Join work with Eric Dumazet.
Note that received SYN are accounted on the listener, but sent SYNACK
are not accounted.
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
commit 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages
send from TIME_WAIT") added the flow label in the last TCP packets.
Unfortunately, it was not casted properly.
This patch replace the buggy shift with be32_to_cpu/cpu_to_be32.
Fixes: 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages")
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
[ 3897.923145] BUG: unable to handle kernel NULL pointer dereference at
0000000000000080
[ 3897.931025] IP: [<ffffffffa9f27686>] reqsk_timer_handler+0x1a6/0x243
There is a race when reqsk_timer_handler() and tcp_check_req() call
inet_csk_reqsk_queue_unlink() on the same req at the same time.
Before commit fa76ce7328b2 ("inet: get rid of central tcp/dccp listener
timer"), listener spinlock was held and race could not happen.
To solve this bug, we change reqsk_queue_unlink() to not assume req
must be found, and we return a status, to conditionally release a
refcount on the request sock.
This also means tcp_check_req() in non fastopen case might or not
consume req refcount, so tcp_v6_hnd_req() & tcp_v4_hnd_req() have
to properly handle this.
(Same remark for dccp_check_req() and its callers)
inet_csk_reqsk_queue_drop() is now too big to be inlined, as it is
called 4 times in tcp and 3 times in dccp.
Fixes: fa76ce7328b2 ("inet: get rid of central tcp/dccp listener timer")
Reported-by: Yuchung Cheng <ycheng@google.com>
Using a timer wheel for timewait sockets was nice ~15 years ago when
memory was expensive and machines had a single processor.
This does not scale, code is ugly and source of huge latencies
(Typically 30 ms have been seen, cpus spinning on death_lock spinlock.)
We can afford to use an extra 64 bytes per timewait sock and spread
timewait load to all cpus to have better behavior.
Tested:
On following test, /proc/sys/net/ipv4/tcp_tw_recycle is set to 1
on the target (lpaa24)
Before patch :
lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0
419594
437171
While test is running, we can observe 25 or even 33 ms latencies.
lpaa24:~# ping -c 1000 -i 0.02 -qn lpaa23
1000 packets transmitted, 1000 received, 0% packet loss, time 20601ms
rtt min/avg/max/mdev = 0.020/0.217/25.771/1.535 ms, pipe 2
1000 packets transmitted, 1000 received, 0% packet loss, time 20702ms
rtt min/avg/max/mdev = 0.019/0.183/33.761/1.441 ms, pipe 2
After patch :
About 90% increase of throughput :
810442
800992
And latencies are kept to minimal values during this load, even
if network utilization is 90% higher :
1000 packets transmitted, 1000 received, 0% packet loss, time 19991ms
rtt min/avg/max/mdev = 0.023/0.064/0.360/0.042 ms
drivers/net/usb/asix_common.c
drivers/net/usb/sr9800.c
drivers/net/usb/usbnet.c
include/linux/usb/usbnet.h
net/ipv4/tcp_ipv4.c
net/ipv6/tcp_ipv6.c
The TCP conflicts were overlapping changes. In 'net' we added a
READ_ONCE() to the socket cached RX route read, whilst in 'net-next'
Eric Dumazet touched the surrounding code dealing with how mini
sockets are handled.
With USB, it's a case of the same bug fix first going into net-next
and then I cherry picked it back into net.
The ipv6 code uses a mixture of coding styles. In some instances check for NULL
pointer is done as x != NULL and sometimes as x. x is preferred according to
checkpatch and this patch makes the code consistent by adopting the latter
form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
pointer is done as x == NULL and sometimes as !x. !x is preferred according to
form.
tcp_v6_fill_cb() will be called twice if socket's state changes from
TCP_TIME_WAIT to TCP_LISTEN. That can result in control buffer data
corruption because in the second tcp_v6_fill_cb() call it's not copying
IP6CB(skb) anymore, but 'seq', 'end_seq', etc., so we can get weird and
unpredictable results. Performance loss of up to 1200% has been observed
in LTP/vxlan03 test.
This can be fixed by copying inet6_skb_parm to the beginning of 'cb'
only if xfrm6_policy_check() and tcp_v6_fill_cb() are going to be
called again.
Fixes: 2dc49d1680b53 ("tcp6: don't move IP6CB before xfrm6_policy_check()")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
ss should display ipv4 mapped request sockets like this :
tcp SYN-RECV 0 0 ::ffff:192.168.0.1:8080 ::ffff:192.0.2.1:35261
and not like this :
tcp SYN-RECV 0 0 192.168.0.1:8080 192.0.2.1:35261
We should init ireq->ireq_family based on listener sk_family,
not the actual protocol carried by SYN packet.
This means we can set ireq_family in inet_reqsk_alloc()
Fixes: 3f66b083a5b7 ("inet: introduce ireq_family")
With request socks convergence, we no longer need
different lookup methods. A request socket can
use generic lookup function.
Add const qualifier to 2nd tcp_v[46]_md5_lookup() parameter.
Since request and established sockets now have same base,
there is no need to pass two pointers to tcp_v4_md5_hash_skb()
or tcp_v6_md5_hash_skb()
Also add a const qualifier to their struct tcp_md5sig_key argument.
It is guaranteed that both tcp_v4_rcv() and tcp_v6_rcv()
run from rcu read locked sections :
ip_local_deliver_finish() and ip6_input_finish() both
use rcu_read_lock()
Also align tcp_v6_inbound_md5_hash() on tcp_v4_inbound_md5_hash()
by returning a boolean.
On s390x, gcc 4.8 compiles this part of tcp_v6_early_demux()
struct dst_entry *dst = sk->sk_rx_dst;
if (dst)
dst = dst_check(dst, inet6_sk(sk)->rx_dst_cookie);
to code reading sk->sk_rx_dst twice, once for the test and once for
the argument of ip6_dst_check() (dst_check() is inline). This allows
ip6_dst_check() to be called with null first argument, causing a crash.
Protect sk->sk_rx_dst access by READ_ONCE() both in IPv4 and IPv6
TCP early demux code.
Fixes: 41063e9dd119 ("ipv4: Early TCP socket demux.")
Fixes: c7109986db3c ("ipv6: Early TCP socket demux")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
tcp_v6_err() can restrict lookups to ehash table, and not to listeners.
Note this patch creates the infrastructure, but this means that ICMP
messages for request sockets are ignored until complete conversion.
One of the major issue for TCP is the SYNACK rtx handling,
done by inet_csk_reqsk_queue_prune(), fired by the keepalive
timer of a TCP_LISTEN socket.
This function runs for awful long times, with socket lock held,
meaning that other cpus needing this lock have to spin for hundred of ms.
SYNACK are sent in huge bursts, likely to cause severe drops anyway.
This model was OK 15 years ago when memory was very tight.
We now can afford to have a timer per request sock.
Timer invocations no longer need to lock the listener,
and can be run from all cpus in parallel.
With following patch increasing somaxconn width to 32 bits,
I tested a listener with more than 4 million active request sockets,
and a steady SYNFLOOD of ~200,000 SYN per second.
Host was sending ~830,000 SYNACK per second.
This is ~100 times more what we could achieve before this patch.
Later, we will get rid of the listener hash and use ehash instead.
When request sock are put in ehash table, the whole notion
of having a previous request to update dl_next is pointless.
Also, following patch will get rid of big purge timer,
so we want to delete a request sock without holding listener lock.
We can now use inet_hash() and __inet_hash() instead of private
functions.
Intent is to converge IPv4 & IPv6 inet_hash functions to
factorize code.
IPv4 sockets initialize sk_rcv_saddr and sk_v6_daddr
in this patch, thanks to new sk_daddr_set() and sk_rcv_saddr_set()
helpers.
__inet6_hash can now use sk_ehashfn() instead of a private
inet6_sk_ehashfn() and will simply use __inet_hash() in a
following patch.
When a request socket is created, we do not cache ip route
dst entry, like for timewait sockets.
Let's use sk_fullsock() helper.
Once request socks will be in ehash table, they will need to have
a valid ir_iff field.
This is currently true only for IPv6. This patch extends support
for IPv4 as well.
This means inet_diag_fill_req() can now properly use ir_iif,
which is better for IPv6 link locals anyway, as request sockets
and established sockets will propagate consistent netlink idiag_if.
Before inserting request socks into general hash table,
fill their socket family.
ireq->ir_num contains local port, use it.
Also, get_openreq4() dumping listen_sk->refcnt makes litle sense.
inet_diag_fill_req() can also use ireq->ir_num
This work adds the possibility to define a per route/destination
congestion control algorithm. Generally, this opens up the possibility
for a machine with different links to enforce specific congestion
control algorithms with optimal strategies for each of them based
on their network characteristics, even transparently for a single
application listening on all links.
For our specific use case, this additionally facilitates deployment
of DCTCP, for example, applications can easily serve internal
traffic/dsts in DCTCP and external one with CUBIC. Other scenarios
would also allow for utilizing e.g. long living, low priority
background flows for certain destinations/routes while still being
able for normal traffic to utilize the default congestion control
algorithm. We also thought about a per netns setting (where different
defaults are possible), but given its actually a link specific
property, we argue that a per route/destination setting is the most
natural and flexible.
The administrator can utilize this through ip-route(8) by appending
"congctl [lock] <name>", where <name> denotes the name of a
congestion control algorithm and the optional lock parameter allows
to enforce the given algorithm so that applications in user space
would not be allowed to overwrite that algorithm for that destination.
The dst metric lookups are being done when a dst entry is already
available in order to avoid a costly lookup and still before the
algorithms are being initialized, thus overhead is very low when the
feature is not being used. While the client side would need to drop
the current reference on the module, on server side this can actually
even be avoided as we just got a flat-copied socket clone.
Joint work with Florian Westphal.
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
When xfrm6_policy_check() is used, _decode_session6() is called after some
intermediate functions. This function uses IP6CB(), thus TCP_SKB_CB() must be
prepared after the call of xfrm6_policy_check().
Before this patch, scenarii with IPv6 + TCP + IPsec Transport are broken.
Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
Reported-by: Huaibin Wang <huaibin.wang@6wind.com>
Suggested-by: Eric Dumazet <edumazet@google.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
drivers/net/ethernet/amd/xgbe/xgbe-desc.c
drivers/net/ethernet/renesas/sh_eth.c
Overlapping changes in both conflict cases.
When I cooked commit c3658e8d0f1 ("tcp: fix possible NULL dereference in
tcp_vX_send_reset()") I missed other spots we could deref a NULL
skb_dst(skb)
Again, if a socket is provided, we do not need skb_dst() to get a
pointer to network namespace : sock_net(sk) is good enough.
Reported-by: Dann Frazier <dann.frazier@canonical.com>
Bisected-by: Dann Frazier <dann.frazier@canonical.com>
Tested-by: Dann Frazier <dann.frazier@canonical.com>
Fixes: ca777eff51f7 ("tcp: remove dst refcount false sharing for prequeue mode")
After commit ca777eff51f7 ("tcp: remove dst refcount false sharing for
prequeue mode") we have to relax check against skb dst in
tcp_v[46]_send_reset() if prequeue dropped the dst.
If a socket is provided, a full lookup was done to find this socket,
so the dst test can be skipped.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=88191
Reported-by: Jaša Bartelj <jasa.bartelj@gmail.com>
Reported-by: Daniel Borkmann <dborkman@redhat.com>
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
sk_mark_napi_id() is used to record for a flow napi id of incoming
packets for busypoll sake.
We should do this only on established flows, not on listeners.
This was 'working' by virtue of the socket cloning, but doing
this on SYN packets in unecessary cache line dirtying.
Even if we move sk_napi_id in the same cache line than sk_lock,
we are working to make SYN processing lockless, so it is desirable
to set sk_napi_id only for established flows.
The commit "net: Save TX flow hash in sock and set in skbuf on xmit"
introduced the inet_set_txhash() and ip6_set_txhash() routines to calculate
and record flow hash(sk_txhash) in the socket structure. sk_txhash is used
to set skb->hash which is used to spread flows across multiple TXQs.
But, the above routines are invoked before the source port of the connection
is created. Because of this all outgoing connections that just differ in the
source port get hashed into the same TXQ.
This patch fixes this problem for IPv4/6 by invoking the the above routines
after the source port is available for the socket.
Fixes: b73c3d0e4("net: Save TX flow hash in sock and set in skbuf on xmit")
Signed-off-by: Sathya Perla <sathya.perla@emulex.com>
Commit 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line
misses") added a regression for SO_BINDTODEVICE on IPv6.
This is because we still use inet6_iif() which expects that IP6 control
block is still at the beginning of skb->cb[]
This patch adds tcp_v6_iif() helper and uses it where necessary.
Because __inet6_lookup_skb() is used by TCP and DCCP, we add an iif
parameter to it.
Acked-by: Cong Wang <cwang@twopensource.com>
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine
Pull dmaengine updates from Dan Williams:
"Even though this has fixes marked for -stable, given the size and the
needed conflict resolutions this is 3.18-rc1/merge-window material.
These patches have been languishing in my tree for a long while. The
fact that I do not have the time to do proper/prompt maintenance of
this tree is a primary factor in the decision to step down as
dmaengine maintainer. That and the fact that the bulk of drivers/dma/
activity is going through Vinod these days.
The net_dma removal has not been in -next. It has developed simple
conflicts against mainline and net-next (for-3.18).
Continuing thanks to Vinod for staying on top of drivers/dma/.
Summary:
1/ Step down as dmaengine maintainer see commit 08223d80df38
"dmaengine maintainer update"
2/ Removal of net_dma, as it has been marked 'broken' since 3.13
(commit 77873803363c "net_dma: mark broken"), without reports of
performance regression.
3/ Miscellaneous fixes"
* tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine:
net: make tcp_cleanup_rbuf private
net_dma: revert 'copied_early'
net_dma: simple removal
dmatest: prevent memory leakage on error path in thread
ioat: Use time_before_jiffies()
dmaengine: fix xor sources continuation
dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup()
dma: mv_xor: Remove all callers of mv_xor_slot_cleanup()
dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call
ioat: Use pci_enable_msix_exact() instead of pci_enable_msix()
drivers: dma: Include appropriate header file in dca.c
drivers: dma: Mark functions as static in dma_v3.c
dma: mv_xor: Add DMA API error checks
ioat/dca: Use dev_is_pci() to check whether it is pci device
TCP maintains lists of skb in write queue, and in receive queues
(in order and out of order queues)
Scanning these lists both in input and output path usually requires
access to skb->next, TCP_SKB_CB(skb)->seq, and TCP_SKB_CB(skb)->end_seq
These fields are currently in two different cache lines, meaning we
waste lot of memory bandwidth when these queues are big and flows
have either packet drops or packet reorders.
We can move TCP_SKB_CB(skb)->header at the end of TCP_SKB_CB, because
this header is not used in fast path. This allows TCP to search much faster
in the skb lists.
Even with regular flows, we save one cache line miss in fast path.
Thanks to Christoph Paasch for noticing we need to cleanup
skb->cb[] (IPCB/IP6CB) before entering IP stack in tx path,
and that I forgot IPCB use in tcp_v4_hnd_req() and tcp_v4_save_options().
ipv6_opt_accepted() assumes IP6CB(skb) holds the struct inet6_skb_parm
that it needs. Lets not assume this, as TCP stack might use a different
place.
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used
and there is no plan to fix it.
This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards.
Reverting the remainder of the net_dma induced changes is deferred to
subsequent patches.
Marked for stable due to Roman's report of a memory leak in
dma_pin_iovec_pages():
https://lkml.org/lkml/2014/9/3/177
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: David Whipple <whipple@securedatainnovations.ch>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: <stable@vger.kernel.org>
Reported-by: Roman Gushchin <klamm@yandex-team.ru>
Input path of TCP do not currently uses TCP_SKB_CB(skb)->tcp_flags,
which is only used in output path.
tcp_recvmsg(), looks at tcp_hdr(skb)->syn for every skb found in receive queue,
and its unfortunate because this bit is located in a cache line right before
the payload.
We can simplify TCP by copying tcp flags into TCP_SKB_CB(skb)->tcp_flags.
This patch does so, and avoids the cache line miss in tcp_recvmsg()
Following patches will
- allow a segment with FIN being coalesced in tcp_try_coalesce()
- simplify tcp_collapse() by not copying the headers.
Acked-by: Neal Cardwell <ncardwell@google.com>
Alexander Duyck reported high false sharing on dst refcount in tcp stack
when prequeue is used. prequeue is the mechanism used when a thread is
blocked in recvmsg()/read() on a TCP socket, using a blocking model
rather than select()/poll()/epoll() non blocking one.
We already try to use RCU in input path as much as possible, but we were
forced to take a refcount on the dst when skb escaped RCU protected
region. When/if the user thread runs on different cpu, dst_release()
will then touch dst refcount again.
Commit 093162553c33 (tcp: force a dst refcount when prequeue packet)
was an example of a race fix.
It turns out the only remaining usage of skb->dst for a packet stored
in a TCP socket prequeue is IP early demux.
We can add a logic to detect when IP early demux is probably going
to use skb->dst. Because we do an optimistic check rather than duplicate
existing logic, we need to guard inet_sk_rx_dst_set() and
inet6_sk_rx_dst_set() from using a NULL dst.
Many thanks to Alexander for providing a nice bug report, git bisection,
and reproducer.
Tested using Alexander script on a 40Gb NIC, 8 RX queues.
Hosts have 24 cores, 48 hyper threads.
echo 0 >/proc/sys/net/ipv4/tcp_autocorking
for i in `seq 0 47`
do
for j in `seq 0 2`
do
netperf -H $DEST -t TCP_STREAM -l 1000 \
-c -C -T $i,$i -P 0 -- \
-m 64 -s 64K -D &
done
done
Before patch : ~6Mpps and ~95% cpu usage on receiver
After patch : ~9Mpps and ~35% cpu usage on receiver.
Reported-by: Alexander Duyck <alexander.h.duyck@intel.com>
TCP_SKB_CB(skb)->when has different meaning in output and input paths.
In output path, it contains a timestamp.
In input path, it contains an ISN, chosen by tcp_timewait_state_process()
Lets add a different name to ease code comprehension.
Note that 'when' field will disappear in following patch,
as skb_mstamp already contains timestamp, the anonymous
union will promptly disappear as well.
Acked-by: Yuchung Cheng <ycheng@google.com>
Make sure we use the correct address-family-specific function for
handling MTU reductions from within tcp_release_cb().
Previously AF_INET6 sockets were incorrectly always using the IPv6
code path when sometimes they were handling IPv4 traffic and thus had
an IPv4 dst.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Diagnosed-by: Willem de Bruijn <willemb@google.com>
Fixes: 563d34d057862 ("tcp: dont drop MTU reduction indications")
Since a8afca032 (tcp: md5: protects md5sig_info with RCU) tcp_md5_do_lookup
doesn't require socket lock, rcu_read_lock is enough. Therefore socket lock is
no longer required for tcp_v{4,6}_inbound_md5_hash too, so we can move these
calls (wrapped with rcu_read_{,un}lock) before bh_lock_sock:
from tcp_v{4,6}_do_rcv to tcp_v{4,6}_rcv.
Signed-off-by: Dmitry Popov <ixaphire@qrator.net>
For a connected socket we can precompute the flow hash for setting
in skb->hash on output. This is a performance advantage over
calculating the skb->hash for every packet on the connection. The
computation is done using the common hash algorithm to be consistent
with computations done for packets of the connection in other states
where thers is no socket (e.g. time-wait, syn-recv, syn-cookies).
This patch adds sk_txhash to the sock structure. inet_set_txhash and
ip6_set_txhash functions are added which are called from points in
TCP and UDP where socket moves to established state.
skb_set_hash_from_sk is a function which sets skb->hash from the
sock txhash value. This is called in UDP and TCP transmit path when
transmitting within the context of a socket.
Tested: ran super_netperf with 200 TCP_RR streams over a vxlan
interface (in this case skb_get_hash called on every TX packet to
create a UDP source port).
Before fix:
95.02% CPU utilization
154/256/505 90/95/99% latencies
1.13042e+06 tps
Time in functions:
0.28% skb_flow_dissect
0.21% __skb_get_hash
After fix:
94.95% CPU utilization
156/254/485 90/95/99% latencies
1.15447e+06
Neither __skb_get_hash nor skb_flow_dissect appear in perf
Signed-off-by: Tom Herbert <therbert@google.com>
Always store in snt_synack the time at which the server received the
first client SYN and attempted to send the first SYNACK.
Recent commit aa27fc501 ("tcp: tcp_v[46]_conn_request: fix snt_synack
initialization") resolved an inconsistency between IPv4 and IPv6 in
the initialization of snt_synack. This commit brings back the idea
from 843f4a55e (tcp: use tcp_v4_send_synack on first SYN-ACK), which
was going for the original behavior of snt_synack from the commit
where it was added in 9ad7c049f0f79 ("tcp: RFC2988bis + taking RTT
sample from 3WHS for the passive open side") in v3.1.
In addition to being simpler (and probably a tiny bit faster),
unconditionally storing the time of the first SYNACK attempt has been
useful because it allows calculating a performance metric quantifying
how long it took to establish a passive TCP connection.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Cc: Octavian Purdila <octavian.purdila@intel.com>
Cc: Jerry Chu <hkchu@google.com>
Acked-by: Octavian Purdila <octavian.purdila@intel.com>
