transforms ahave been applied
[ Upstream commit bfc0698bebcb16d19ecfc89574ad4d696955e5d3 ]
A policy may have been set up with multiple transforms (e.g., ESP
and ipcomp). In this situation, the ingress IPsec processing
iterates in xfrm_input() and applies each transform in turn,
processing the nexthdr to find any additional xfrm that may apply.
This patch resets the transport header back to network header
only after the last transformation so that subsequent xfrms
can find the correct transport header.
Fixes: 7785bba299a8 ("esp: Add a software GRO codepath")
Suggested-by: Steffen Klassert <steffen.klassert@secunet.com>
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit acf568ee859f098279eadf551612f103afdacb4e ]
This is an old bugbear of mine:
https://www.mail-archive.com/netdev@vger.kernel.org/msg03894.html
By crafting special packets, it is possible to cause recursion
in our kernel when processing transport-mode packets at levels
that are only limited by packet size.
The easiest one is with DNAT, but an even worse one is where
UDP encapsulation is used in which case you just have to insert
an UDP encapsulation header in between each level of recursion.
This patch avoids this problem by reinjecting tranport-mode packets
through a tasklet.
Fixes: b05e106698d9 ("[IPV4/6]: Netfilter IPsec input hooks")
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
xfrm6_transport_finish rebuilds the IPv6 header based on the
original one and pushes it back without fixing skb->csum.
Therefore, CHECKSUM_COMPLETE is no longer valid and the packet
gets dropped.
Fix skb->csum by calling skb_postpush_rcsum.
Note: A valid IPv4 header has checksum 0, unlike IPv6. Thus,
the change is not needed in the sibling xfrm4_transport_finish
function.
Signed-off-by: Yossi Kuperman <yossiku@mellanox.com>
Signed-off-by: Ilan Tayari <ilant@mellanox.com>
IPv6 payload length indicates the size of the payload, including any
extension headers.
In xfrm6_transport_finish, ipv6_hdr(skb)->payload_len is set to the
payload size only, regardless of the presence of any extension headers.
After ESP GRO transport mode decapsulation, ipv6_rcv trims the packet
according to the wrong payload_len, thus corrupting the packet.
Set payload_len to account for extension headers as well.
This patch adds GRO ifrastructure and callbacks for ESP on
ipv4 and ipv6.
In case the GRO layer detects an ESP packet, the
esp{4,6}_gro_receive() function does a xfrm state lookup
and calls the xfrm input layer if it finds a matching state.
The packet will be decapsulated and reinjected it into layer 2.
Add a new helper to set the secpath to the skb.
This avoids code duplication, as this is used
in multiple places.
Since commit 1625f4529957, vti6 is broken, all input packets are dropped
(LINUX_MIB_XFRMINNOSTATES is incremented).
XFRM_TUNNEL_SKB_CB(skb)->tunnel.ip6 is set by vti6_rcv() before calling
xfrm6_rcv()/xfrm6_rcv_spi(), thus we cannot set to NULL that value in
xfrm6_rcv_spi().
A new function xfrm6_rcv_tnl() that enables to pass a value to
xfrm6_rcv_spi() is added, so that xfrm6_rcv() is not touched (this function
is used in several handlers).
CC: Alexey Kodanev <alexey.kodanev@oracle.com>
Fixes: 1625f4529957 ("net/xfrm_input: fix possible NULL deref of tunnel.ip6->parms.i_key")
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Running LTP 'icmp-uni-basic.sh -6 -p ipcomp -m tunnel' test over
openvswitch + veth can trigger kernel panic:
BUG: unable to handle kernel NULL pointer dereference
at 00000000000000e0 IP: [<ffffffff8169d1d2>] xfrm_input+0x82/0x750
[<ffffffff816d472e>] xfrm6_rcv_spi+0x1e/0x20
[<ffffffffa082c3c2>] xfrm6_tunnel_rcv+0x42/0x50 [xfrm6_tunnel]
[<ffffffffa082727e>] tunnel6_rcv+0x3e/0x8c [tunnel6]
[<ffffffff8169f365>] ip6_input_finish+0xd5/0x430
[<ffffffff8169fc53>] ip6_input+0x33/0x90
[<ffffffff8169f1d5>] ip6_rcv_finish+0xa5/0xb0
It seems that tunnel.ip6 can have garbage values and also dereferenced
without a proper check, only tunnel.ip4 is being verified. Fix it by
adding one more if block for AF_INET6 and initialize tunnel.ip6 with NULL
inside xfrm6_rcv_spi() (which is similar to xfrm4_rcv_spi()).
Fixes: 049f8e2 ("xfrm: Override skb->mark with tunnel->parm.i_key in xfrm_input")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
Pass a network namespace parameter into the netfilter hooks. At the
call site of the netfilter hooks the path a packet is taking through
the network stack is well known which allows the network namespace to
be easily and reliabily.
This allows the replacement of magic code like
"dev_net(state->in?:state->out)" that appears at the start of most
netfilter hooks with "state->net".
In almost all cases the network namespace passed in is derived
from the first network device passed in, guaranteeing those
paths will not see any changes in practice.
The exceptions are:
xfrm/xfrm_output.c:xfrm_output_resume() xs_net(skb_dst(skb)->xfrm)
ipvs/ip_vs_xmit.c:ip_vs_nat_send_or_cont() ip_vs_conn_net(cp)
ipvs/ip_vs_xmit.c:ip_vs_send_or_cont() ip_vs_conn_net(cp)
ipv4/raw.c:raw_send_hdrinc() sock_net(sk)
ipv6/ip6_output.c:ip6_xmit() sock_net(sk)
ipv6/ndisc.c:ndisc_send_skb() dev_net(skb->dev) not dev_net(dst->dev)
ipv6/raw.c:raw6_send_hdrinc() sock_net(sk)
br_netfilter_hooks.c:br_nf_pre_routing_finish() dev_net(skb->dev) before skb->dev is set to nf_bridge->physindev
In all cases these exceptions seem to be a better expression for the
network namespace the packet is being processed in then the historic
"dev_net(in?in:out)". I am documenting them in case something odd
pops up and someone starts trying to track down what happened.
On the output paths in particular, we have to sometimes deal with two
socket contexts. First, and usually skb->sk, is the local socket that
generated the frame.
And second, is potentially the socket used to control a tunneling
socket, such as one the encapsulates using UDP.
We do not want to disassociate skb->sk when encapsulating in order
to fix this, because that would break socket memory accounting.
The most extreme case where this can cause huge problems is an
AF_PACKET socket transmitting over a vxlan device. We hit code
paths doing checks that assume they are dealing with an ipv4
socket, but are actually operating upon the AF_PACKET one.
This patch makes no changes to the logic of the code but simply addresses
coding style issues as detected by checkpatch.
Both objdump and diff -w show no differences.
This patch removes some blank lines between the end of a function
definition and the EXPORT_SYMBOL_GPL macro in order to prevent
checkpatch warning that EXPORT_SYMBOL must immediately follow
a function.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
A number of items are addressed in this patch:
* Multiple spaces converted to tabs
* Spaces before tabs removed.
* Spaces in pointer typing cleansed (char *)foo etc.
* Remove space after sizeof
* Ensure spacing around comparators such as if statements.
The semantic patch that was used:
// <smpl>
(NF_HOOK
|NF_HOOK_THRESH
|nf_hook
-PF_INET6,
+NFPROTO_IPV6,
// </smpl>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
pass mark to all SA lookups to prepare them for when we add code
to have them search.
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
| % size old/net/ipv6/xfrm6_input.o new/net/ipv6/xfrm6_input.o
| text data bss dec hex filename
| 1026 0 0 1026 402 old/net/ipv6/xfrm6_input.o
| 947 0 0 947 3b3 new/net/ipv6/xfrm6_input.o
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
When netfilter is off the transport-mode async resumption doesn't work
because we don't push back the IP header. This patch fixes that by
moving most of the code outside of ifdef NETFILTER since the only part
that's not common is the short-circuit in the protocol handler.
This patch adds a number of new IPsec audit events to meet the auditing
requirements of RFC4303. This includes audit hooks for the following events:
* Could not find a valid SA [sections 2.1, 3.4.2]
. xfrm_audit_state_notfound()
. xfrm_audit_state_notfound_simple()
* Sequence number overflow [section 3.3.3]
. xfrm_audit_state_replay_overflow()
* Replayed packet [section 3.4.3]
. xfrm_audit_state_replay()
* Integrity check failure [sections 3.4.4.1, 3.4.4.2]
. xfrm_audit_state_icvfail()
While RFC4304 deals only with ESP most of the changes in this patch apply to
IPsec in general, i.e. both AH and ESP. The one case, integrity check
failure, where ESP specific code had to be modified the same was done to the
AH code for the sake of consistency.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Acked-by: James Morris <jmorris@namei.org>
Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org>
Disable spin_lock during xfrm_type.input() function.
Follow design as IPsec inbound does.
When merging the input paths of IPsec I accidentally left a hard-coded
AF_INET for the state lookup call. This broke IPv6 obviously. This
patch fixes by getting the input callers to specify the family through
skb->cb.
Credit goes to Kazunori Miyazawa for diagnosing this and providing an
initial patch.
The IPv4 and IPv6 hook values are identical, yet some code tries to figure
out the "correct" value by looking at the address family. Introduce NF_INET_*
values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__
section for userspace compatibility.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This patch adds support for async resumptions on input. To do so, the
transform would return -EINPROGRESS and subsequently invoke the
function xfrm_input_resume to resume processing.
The nhoff field isn't actually necessary in xfrm_input. For tunnel
mode transforms we now throw away the output IP header so it makes no
sense to fill in the nexthdr field. For transport mode we can now let
the function transport_finish do the setting and it knows where the
nexthdr field is.
The only other thing that needs the nexthdr field to be set is the
header extraction code. However, we can simply move the protocol
extraction out of the generic header extraction.
We want to minimise the amount of info we have to carry around between
transforms as this simplifies the resumption process for async crypto.
As part of the work on asynchronous cryptographic operations, we need
to be able to resume from the spot where they occur. As such, it
helps if we isolate them to one spot.
This patch moves most of the remaining family-specific processing into
the common input code.
With inter-family transforms the inner mode differs from the outer
mode. Attempting to handle both sides from the same function means
that it needs to handle both IPv4 and IPv6 which creates duplication
and confusion.
This patch separates the two parts on the input path so that each
function deals with one family only.
In particular, the functions xfrm4_extract_inut/xfrm6_extract_inut
moves the pertinent fields from the IPv4/IPv6 IP headers into a
neutral format stored in skb->cb. This is then used by the inner mode
input functions to modify the inner IP header. In this way the input
function no longer has to know about the outer address family.
This patch adds a new field to xfrm states called inner_mode. The existing
mode object is renamed to outer_mode.
This is the first part of an attempt to fix inter-family transforms. As it
is we always use the outer family when determining which mode to use. As a
result we may end up shoving IPv4 packets into netfilter6 and vice versa.
What we really want is to use the inner family for the first part of outbound
processing and the outer family for the second part. For inbound processing
we'd use the opposite pairing.
I've also added a check to prevent silly combinations such as transport mode
with inter-family transforms.
Currently BEET mode does not reinject the packet back into the stack
like tunnel mode does. Since BEET should behave just like tunnel mode
this is incorrect.
This patch fixes this by introducing a flags field to xfrm_mode that
tells the IPsec code whether it should terminate and reinject the packet
back into the stack.
It then sets the flag for BEET and tunnel mode.
I've also added a number of missing BEET checks elsewhere where we check
whether a given mode is a tunnel or not.
Not every transform needs to zap ip_summed. For example, a pure tunnel
mode encapsulation does not affect the hardware checksum at all. In fact,
every algorithm (that needs this) other than AH6 already does its own
ip_summed zapping.
This patch moves the zapping into AH6 which is in line with what IPv4 does.
Possible future optimisation: Checksum the data as we copy them in IPComp.
Currently xfrm6_rcv_spi gets the nexthdr value itself from the packet.
This means that we need to fix up the value in case we have a 4-on-6
tunnel. Moving this logic into the caller simplifies things and allows
us to merge the code with IPv4.
With all the users of the double pointers removed from the IPv6 input path,
this patch converts all occurances of sk_buff ** to sk_buff * in IPv6 input
handlers.
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org>
Now the skb->nh union has just one member, .raw, i.e. it is just like the
skb->mac union, strange, no? I'm just leaving it like that till the transport
layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or
->mac_header_offset?), ditto for ->{h,nh}.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the places where we need a pointer to the network header, it is still legal
to touch skb->nh.raw directly if just adding to, subtracting from or setting it
to another layer header.
This patch changes xfrm6_tunnel register and deregister
interface to prepare for solving the conflict of device
tunnels with inter address family IPsec tunnel.
There is no device which conflicts with IPv4 over IPv6
IPsec tunnel.
Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org>
seq argument is net-endian
XFRM_STATE_WILDRECV flag is introduced; the last resort state is set
it and receives packet which is not route optimized but uses such
extension headers i.e. Mobile IPv6 signaling (binding update and
acknowledgement). A node enabled Mobile IPv6 adds the state.
Based on MIPL2 kernel patch.
Transformation mode is used as either IPsec transport or tunnel.
It is required to add two more items, route optimization and inbound trigger
for Mobile IPv6.
This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi>
This patch adds the structure xfrm_mode. It is meant to represent
the operations carried out by transport/tunnel modes.
By doing this we allow additional encapsulation modes to be added
without clogging up the xfrm_input/xfrm_output paths.
Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and
BEET modes.
This patch removes the *_decap_state structures which were previously
used to share state between input/post_input. This is no longer
needed.
This patch removes the decap_state argument from the xfrm input hook.
Previously this function allowed the input hook to share state with
the post_input hook. The latter has since been removed.
The only purpose for it now is to check the encap type. However, it
is easier and better to move the encap type check to the generic
xfrm_rcv function. This allows us to get rid of the decap state
argument altogether.
Basically this patch moves the generic tunnel protocol stuff out of
xfrm4_tunnel/xfrm6_tunnel and moves it into the new files of tunnel4.c
and tunnel6 respectively.
The reason for this is that the problem that Hugo uncovered is only
the tip of the iceberg. The real problem is that when we removed the
dependency of ipip on xfrm4_tunnel we didn't really consider the module
case at all.
For instance, as it is it's possible to build both ipip and xfrm4_tunnel
as modules and if the latter is loaded then ipip simply won't load.
After considering the alternatives I've decided that the best way out of
this is to restore the dependency of ipip on the non-xfrm-specific part
of xfrm4_tunnel. This is acceptable IMHO because the intention of the
removal was really to be able to use ipip without the xfrm subsystem.
This is still preserved by this patch.
So now both ipip/xfrm4_tunnel depend on the new tunnel4.c which handles
the arbitration between the two. The order of processing is determined
by a simple integer which ensures that ipip gets processed before
xfrm4_tunnel.
The situation for ICMP handling is a little bit more complicated since
we may not have enough information to determine who it's for. It's not
a big deal at the moment since the xfrm ICMP handlers are basically
no-ops. In future we can deal with this when we look at ICMP caching
in general.
The user-visible change to this is the removal of the TUNNEL Kconfig
prompts. This makes sense because it can only be used through IPCOMP
as it stands.
The addition of the new modules shouldn't introduce any problems since
module dependency will cause them to be loaded.
Oh and I also turned some unnecessary pskb's in IPv6 related to this
patch to skb's.
When the innermost transform uses transport mode the decapsulated packet
is not visible to netfilter. Pass the packet through the PRE_ROUTING and
LOCAL_IN hooks again before handing it to upper layer protocols to make
netfilter-visibility symetrical to the output path.
Move nextheader offset to the IP6CB to make it possible to pass a
packet to ip6_input_finish multiple times and have it skip already
parsed headers. As a nice side effect this gets rid of the manual
hopopts skipping in ip6_input_finish.
