path: root/net/ipv6/xfrm6_mode_ro.c
2017-06-02ipv6: xfrm: Handle errors reported by xfrm6_find_1stfragopt()Ben Hutchings
xfrm6_find_1stfragopt() may now return an error code and we must not treat it as a length. Fixes: 2423496af35d ("ipv6: Prevent overrun when parsing v6 header options") Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Craig Gallek <kraig@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06ipv4/ipv6: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> CC: James Morris <jmorris@namei.org> CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> CC: Patrick McHardy <kaber@trash.net> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Make x->lastused an unsigned longHerbert Xu
Currently x->lastused is u64 which means that it cannot be read/written atomically on all architectures. David Miller observed that the value stored in it is only an unsigned long which is always atomic. So based on his suggestion this patch changes the internal representation from u64 to unsigned long while the user-interface still refers to it as u64. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Move x->outer_mode->output out of locked sectionHerbert Xu
RO mode is the only one that requires a locked output function. So it's easier to move the lock into that function rather than requiring everyone else to run under the lock. In particular, this allows us to move the size check into the output function without causing a potential dead-lock should the ICMP error somehow hit the same SA on transmission. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Disallow combinations of RO and AH/ESP/IPCOMPHerbert Xu
Combining RO and AH/ESP/IPCOMP does not make sense. So this patch adds a check in the state initialisation function to prevent this. This allows us to safely remove the mode input function of RO since it can never be called anymore. Indeed, if somehow it does get called we'll know about it through an OOPS instead of it slipping past silently. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Use IPv6 calling convention as the convention for x->mode->outputHerbert Xu
The IPv6 calling convention for x->mode->output is more general and could help an eventual protocol-generic x->type->output implementation. This patch adopts it for IPv4 as well and modifies the IPv4 type output functions accordingly. It also rewrites the IPv6 mac/transport header calculation to be based off the network header where practical. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Set skb->data to payload in x->mode->outputHerbert Xu
This patch changes the calling convention so that on entry from x->mode->output and before entry into x->type->output skb->data will point to the payload instead of the IP header. This is essentially a redistribution of skb_push/skb_pull calls with the aim of minimising them on the common path of tunnel + ESP. It'll also let us use the same calling convention between IPv4 and IPv6 with the next patch. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Store IPv6 nh pointer in mac_header on outputHerbert Xu
Current the x->mode->output functions store the IPv6 nh pointer in the skb network header. This is inconvenient because the network header then has to be fixed up before the packet can leave the IPsec stack. The mac header field is unused on output so we can use that to store this instead. This patch does that and removes the network header fix-up in xfrm_output. It also uses ipv6_hdr where appropriate in the x->type->output functions. There is also a minor clean-up in esp4 to make it use the same code as esp6 to help any subsequent effort to merge the two. Lastly it kills two redundant skb_set_* statements in BEET that were simply copied over from transport mode. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move RO-specific output code into xfrm6_mode_ro.cHerbert Xu
The lastused update check in xfrm_output can be done just as well in the mode output function which is specific to RO. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Some more layer header conversionsArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_set_transport_headerArnaldo Carvalho de Melo
For the cases where the transport header is being set to a offset from skb->data. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPSEC]: output mode to take an xfrm state as input paramJamal Hadi Salim
Expose IPSEC modes output path to take an xfrm state as input param. This makes it consistent with the input mode processing (which already takes the xfrm state as a param). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] STATE: Introduce route optimization mode.Masahide NAKAMURA
Route optimization is used with routing header and destination options header for Mobile IPv6. At outbound it makes header space like IPsec transport. At inbound it does nothing because exhdrs.c functions have responsibility to update skbuff information for these headers. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
