path: root/net/ipv6/xfrm6_mode_tunnel.c
2008-03-24[IPSEC]: Fix inter address family IPsec tunnel handling.Kazunori MIYAZAWA
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Rename tunnel-mode functions to avoid collisions with tunnelsHerbert Xu
It appears that I've managed to create two different functions both called xfrm6_tunnel_output. This is because we have the plain tunnel encapsulation named xfrmX_tunnel as well as the tunnel-mode encapsulation which lives in the files xfrmX_mode_tunnel.c. This patch renames functions from the latter to use the xfrmX_mode_tunnel prefix to avoid name-space conflicts. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Separate inner/outer mode processing on inputHerbert Xu
With inter-family transforms the inner mode differs from the outer mode. Attempting to handle both sides from the same function means that it needs to handle both IPv4 and IPv6 which creates duplication and confusion. This patch separates the two parts on the input path so that each function deals with one family only. In particular, the functions xfrm4_extract_inut/xfrm6_extract_inut moves the pertinent fields from the IPv4/IPv6 IP headers into a neutral format stored in skb->cb. This is then used by the inner mode input functions to modify the inner IP header. In this way the input function no longer has to know about the outer address family. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Separate inner/outer mode processing on outputHerbert Xu
With inter-family transforms the inner mode differs from the outer mode. Attempting to handle both sides from the same function means that it needs to handle both IPv4 and IPv6 which creates duplication and confusion. This patch separates the two parts on the output path so that each function deals with one family only. In particular, the functions xfrm4_extract_output/xfrm6_extract_output moves the pertinent fields from the IPv4/IPv6 IP headers into a neutral format stored in skb->cb. This is then used by the outer mode output functions to write the outer IP header. In this way the output function no longer has to know about the inner address family. Since the extract functions are only called by tunnel modes (the only modes that can support inter-family transforms), I've also moved the xfrm*_tunnel_check_size calls into them. This allows the correct ICMP message to be sent as opposed to now where you might call icmp_send with an IPv6 packet and vice versa. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[INET]: Give outer DSCP directly to ip*_copy_dscpHerbert Xu
This patch changes the prototype of ipv4_copy_dscp and ipv6_copy_dscp so that they directly take the outer DSCP rather than the outer IP header. This will help us to unify the code for inter-family tunnels. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Add missing BEET checksHerbert Xu
Currently BEET mode does not reinject the packet back into the stack like tunnel mode does. Since BEET should behave just like tunnel mode this is incorrect. This patch fixes this by introducing a flags field to xfrm_mode that tells the IPsec code whether it should terminate and reinject the packet back into the stack. It then sets the flag for BEET and tunnel mode. I've also added a number of missing BEET checks elsewhere where we check whether a given mode is a tunnel or not. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move IP length/checksum setting out of transformsHerbert Xu
This patch moves the setting of the IP length and checksum fields out of the transforms and into the xfrmX_output functions. This would help future efforts in merging the transforms themselves. It also adds an optimisation to ipcomp due to the fact that the transport offset is guaranteed to be zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Use IPv6 calling convention as the convention for x->mode->outputHerbert Xu
The IPv6 calling convention for x->mode->output is more general and could help an eventual protocol-generic x->type->output implementation. This patch adopts it for IPv4 as well and modifies the IPv4 type output functions accordingly. It also rewrites the IPv6 mac/transport header calculation to be based off the network header where practical. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Set skb->data to payload in x->mode->outputHerbert Xu
This patch changes the calling convention so that on entry from x->mode->output and before entry into x->type->output skb->data will point to the payload instead of the IP header. This is essentially a redistribution of skb_push/skb_pull calls with the aim of minimising them on the common path of tunnel + ESP. It'll also let us use the same calling convention between IPv4 and IPv6 with the next patch. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Store IPv6 nh pointer in mac_header on outputHerbert Xu
Current the x->mode->output functions store the IPv6 nh pointer in the skb network header. This is inconvenient because the network header then has to be fixed up before the packet can leave the IPsec stack. The mac header field is unused on output so we can use that to store this instead. This patch does that and removes the network header fix-up in xfrm_output. It also uses ipv6_hdr where appropriate in the x->type->output functions. There is also a minor clean-up in esp4 to make it use the same code as esp6 to help any subsequent effort to merge the two. Lastly it kills two redundant skb_set_* statements in BEET that were simply copied over from transport mode. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[IPSEC]: Fix panic when using inter address familiy IPsec on loopback.Kazunori MIYAZAWA
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipipv6_hdr(), remove skb->h.ipv6hArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce ipip_hdr(), remove skb->h.ipiphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_mac_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the mac header, it is still legal to touch skb->mac.raw directly if just adding to, subtracting from or setting it to another layer header. This one also converts some more cases to skb_reset_mac_header() that my regex missed as it had no spaces before nor after '=', ugh. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF] xfrm: Use skb_set_mac_header in the memmove casesArnaldo Carvalho de Melo
2007-02-08[IPSEC]: IPv4 over IPv6 IPsec tunnelMiika Komu
This is the patch to support IPv4 over IPv6 IPsec. Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Diego Beltrami <Diego.Beltrami@hiit.fi> Signed-off-by: Kazunori Miyazawa <miyazawa@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPSEC]: output mode to take an xfrm state as input paramJamal Hadi Salim
Expose IPSEC modes output path to take an xfrm state as input param. This makes it consistent with the input mode processing (which already takes the xfrm state as a param). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] xfrm: Abstract out encapsulation modesHerbert Xu
This patch adds the structure xfrm_mode. It is meant to represent the operations carried out by transport/tunnel modes. By doing this we allow additional encapsulation modes to be added without clogging up the xfrm_input/xfrm_output paths. Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and BEET modes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
