path: root/net/ipv6/xfrm6_policy.c
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-25[IPV6]: Support Source Address Selection API (RFC5014).YOSHIFUJI Hideaki
2008-03-05[NETNS][IPV6] route6 - add netns parameter to ip6_route_outputDaniel Lezcano
Add an netns parameter to ip6_route_output. That will allow to access to the right routing table for outgoing traffic. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[IPV6] ADDRCONF: Convert ipv6_get_saddr() to ipv6_dev_get_saddr().YOSHIFUJI Hideaki
Since most users of ipv6_get_saddr() pass non-NULL as dst argument, use ipv6_dev_get_saddr() directly. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-31[NET]: should explicitely initialize atomic_t field in struct dst_opsEric Dumazet
All but one struct dst_ops static initializations miss explicit initialization of entries field. As this field is atomic_t, we should use ATOMIC_INIT(0), and not rely on atomic_t implementation. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][DST] dst: pass the dst_ops as parameter to the gc functionsDaniel Lezcano
The garbage collection function receive the dst_ops structure as parameter. This is useful for the next incoming patchset because it will need the dst_ops (there will be several instances) and the network namespace pointer (contained in the dst_ops). The protocols which do not take care of the namespaces will not be impacted by this change (expect for the function signature), they do just ignore the parameter. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM] IPv6: Fix dst/routing check at transformation.Masahide NAKAMURA
IPv6 specific thing is wrongly removed from transformation at net-2.6.25. This patch recovers it with current design. o Update "path" of xfrm_dst since IPv6 transformation should care about routing changes. It is required by MIPv6 and off-link destined IPsec. o Rename nfheader_len which is for non-fragment transformation used by MIPv6 to rt6i_nfheader_len as IPv6 name space. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Added xfrm_decode_session_reverse and xfrmX_policy_check_reverseHerbert Xu
RFC 4301 requires us to relookup ICMP traffic that does not match any policies using the reverse of its payload. This patch adds the functions xfrm_decode_session_reverse and xfrmX_policy_check_reverse so we can get the reverse flow to perform such a lookup. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: Make xfrm6_init to return an error code.Daniel Lezcano
The xfrm initialization function does not return any error code, so if there is an error, the caller can not be advise of that. This patch checks the return code of the different called functions in order to return a successful or failed initialization. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Acked-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Multiple namespaces in the all dst_ifdown routines.Denis V. Lunev
Move dst entries to a namespace loopback to catch refcounting leaks. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Merge most of the output pathHerbert Xu
As part of the work on asynchrnous cryptographic operations, we need to be able to resume from the spot where they occur. As such, it helps if we isolate them to one spot. This patch moves most of the remaining family-specific processing into the common output code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Merge common code into xfrm_bundle_createHerbert Xu
Half of the code in xfrm4_bundle_create and xfrm6_bundle_create are common. This patch extracts that logic and puts it into xfrm_bundle_create. The rest of it are then accessed through afinfo. As a result this fixes the problem with inter-family transforms where we treat every xfrm dst in the bundle as if it belongs to the top family. This patch also fixes a long-standing error-path bug where we may free the xfrm states twice. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Move flow construction into xfrm_dst_lookupHerbert Xu
This patch moves the flow construction from the callers of xfrm_dst_lookup into that function. It also changes xfrm_dst_lookup so that it takes an xfrm state as its argument instead of explicit addresses. This removes any address-specific logic from the callers of xfrm_dst_lookup which is needed to correctly support inter-family transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Replace x->type->{local,remote}_addr with flagsHerbert Xu
The functions local_addr and remote_addr are more than what they're needed for. The same thing can be done easily with flags on the type object. This patch does that and simplifies the wrapper functions in xfrm6_policy accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Make sure idev is consistent with dev in xfrm_dstHerbert Xu
Previously we took the device from the bottom route and idev from the top route. This is bad because idev may well point to a different device. This patch changes it so that we get the idev from the device directly. It also makes it an error if either dev or idev is NULL. This is consistent with the rest of the routing code which also treats these cases as errors. I've removed the err initialisation in xfrm6_policy.c because it achieves no purpose and hid a bug when an initial version of this patch neglected to set err to -ENODEV (fortunately the IPv4 version warned about it). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Set dst->input to dst_discardHerbert Xu
The input function should never be invoked on IPsec dst objects. This is because we don't apply IPsec on input until after we've made the routing decision. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Only set neighbour on top xfrm dstHerbert Xu
The neighbour field is only used by dst_confirm which only ever happens on the top-most xfrm dst. So it's a waste to duplicate for every other xfrm dst. This patch moves its setting out of the loop so that only the top one gets set. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: Move nfheader_len into rt6_infoHerbert Xu
The dst member nfheader_len is only used by IPv6. It's also currently creating a rather ugly alignment hole in struct dst. Therefore this patch moves it from there into struct rt6_info. It also reorders the fields in rt6_info to minimize holes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: Only set nfheader_len for top xfrm dstHerbert Xu
We only need to set nfheader_len in the top xfrm dst. This is because we only ever read the nfheader_len from the top xfrm dst. It is also easier to count nfheader_len as part of header_len which then lets us remove the ugly wrapper functions for incrementing and decrementing header lengths in xfrm6_policy.c. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-11[IPV6] XFRM: Fix auditing rt6i_flags; use RTF_xxx flags instead of RTCF_xxx.YOSHIFUJI Hideaki
RTCF_xxx flags, defined in include/linux/in_route.h) are available for IPv4 route (rtable) entries only. Use RTF_xxx flags instead, defined in include/linux/ipv6_route.h, for IPv6 route entries (rt6_info). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Rename mode to outer_mode and add inner_modeHerbert Xu
This patch adds a new field to xfrm states called inner_mode. The existing mode object is renamed to outer_mode. This is the first part of an attempt to fix inter-family transforms. As it is we always use the outer family when determining which mode to use. As a result we may end up shoving IPv4 packets into netfilter6 and vice versa. What we really want is to use the inner family for the first part of outbound processing and the outer family for the second part. For inbound processing we'd use the opposite pairing. I've also added a check to prevent silly combinations such as transport mode with inter-family transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Store afinfo pointer in xfrm_modeHerbert Xu
It is convenient to have a pointer from xfrm_state to address-specific functions such as the output function for a family. Currently the address-specific policy code calls out to the xfrm state code to get those pointers when we could get it in an easier way via the state itself. This patch adds an xfrm_state_afinfo to xfrm_mode (since they're address-specific) and changes the policy code to use it. I've also added an owner field to do reference counting on the module providing the afinfo even though it isn't strictly necessary today since IPv6 can't be unloaded yet. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Add missing BEET checksHerbert Xu
Currently BEET mode does not reinject the packet back into the stack like tunnel mode does. Since BEET should behave just like tunnel mode this is incorrect. This patch fixes this by introducing a flags field to xfrm_mode that tells the IPsec code whether it should terminate and reinject the packet back into the stack. It then sets the flag for BEET and tunnel mode. I've also added a number of missing BEET checks elsewhere where we check whether a given mode is a tunnel or not. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the loopback device per network namespace.Eric W. Biederman
This patch makes loopback_dev per network namespace. Adding code to create a different loopback device for each network namespace and adding the code to free a loopback device when a network namespace exits. This patch modifies all users the loopback_dev so they access it as init_net.loopback_dev, keeping all of the code compiling and working. A later pass will be needed to update the users to use something other than the initial network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Dynamically allocate the loopback device, part 1.Daniel Lezcano
This patch replaces all occurences to the static variable loopback_dev to a pointer loopback_dev. That provides the mindless, trivial, uninteressting change part for the dynamic allocation for the loopback. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Acked-By: Kirill Korotaev <dev@sw.ru> Acked-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV6] MIP6: Loadable module support for MIPv6.Masahide NAKAMURA
This patch makes MIPv6 loadable module named "mip6". Here is a modprobe.conf(5) example to load it automatically when user application uses XFRM state for MIPv6: alias xfrm-type-10-43 mip6 alias xfrm-type-10-60 mip6 Some MIPv6 feature is not included by this modular, however, it should not be affected to other features like either IPsec or IPv6 with and without the patch. We may discuss XFRM, MH (RAW socket) and ancillary data/sockopt separately for future work. Loadable features: * MH receiving check (to send ICMP error back) * RO header parsing and building (i.e. RH2 and HAO in DSTOPTS) * XFRM policy/state database handling for RO These are NOT covered as loadable: * Home Address flags and its rule on source address selection * XFRM sub policy (depends on its own kernel option) * XFRM functions to receive RO as IPv6 extension header * MH sending/receiving through raw socket if user application opens it (since raw socket allows to do so) * RH2 sending as ancillary data * RH2 operation with setsockopt(2) Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header_lenArnaldo Carvalho de Melo
For the common sequence "skb->h.raw - skb->nh.raw", similar to skb->mac_len, that is precalculated tho, don't think we need to bloat skb with one more member, so just use this new helper, reducing the number of non-skbuff.h references to the layer headers even more. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-26[IPSEC]: More fix is needed for __xfrm6_bundle_create().Noriaki TAKAMIYA
Fixed to set fl_tunnel.fl6_src correctly in xfrm6_bundle_create(). Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Acked-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[XFRM] IPV6: Fix outbound RO transformation which is broken by IPsec tunnel ↵Masahide NAKAMURA
patch. It seems to miss RO mode path by IPv6 over IPv4 IPsec tunnel patch when it changed semantics to check the mode from "xfrm[i]->props.mode != XFRM_MODE_TRANSPORT" to "xfrm[i]->props.mode == XFRM_MODE_TUNNEL" before changing address. It also makes two incline functions __xfrm6_bundle_addr_{remote,local} are used by nobody. This patch fixes it. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
2007-02-08[IPSEC]: IPv6 over IPv4 IPsec tunnelMiika Komu
This is the patch to support IPv6 over IPv4 IPsec Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Diego Beltrami <Diego.Beltrami@hiit.fi> Signed-off-by: Kazunori Miyazawa <miyazawa@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[XFRM]: misc annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[IPV6]: Make sure error handling is done when calling ip6_route_output().Ville Nuorvala
As ip6_route_output() never returns NULL, error checking must be done by looking at dst->error in stead of comparing dst against NULL. Signed-off-by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11IPsec: correct semantics for SELinux policy matchingVenkat Yekkirala
Currently when an IPSec policy rule doesn't specify a security context, it is assumed to be "unlabeled" by SELinux, and so the IPSec policy rule fails to match to a flow that it would otherwise match to, unless one has explicitly added an SELinux policy rule allowing the flow to "polmatch" to the "unlabeled" IPSec policy rules. In the absence of such an explicitly added SELinux policy rule, the IPSec policy rule fails to match and so the packet(s) flow in clear text without the otherwise applicable xfrm(s) applied. The above SELinux behavior violates the SELinux security notion of "deny by default" which should actually translate to "encrypt by default" in the above case. This was first reported by Evgeniy Polyakov and the way James Morris was seeing the problem was when connecting via IPsec to a confined service on an SELinux box (vsftpd), which did not have the appropriate SELinux policy permissions to send packets via IPsec. With this patch applied, SELinux "polmatching" of flows Vs. IPSec policy rules will only come into play when there's a explicit context specified for the IPSec policy rule (which also means there's corresponding SELinux policy allowing appropriate domains/flows to polmatch to this context). Secondly, when a security module is loaded (in this case, SELinux), the security_xfrm_policy_lookup() hook can return errors other than access denied, such as -EINVAL. We were not handling that correctly, and in fact inverting the return logic and propagating a false "ok" back up to xfrm_lookup(), which then allowed packets to pass as if they were not associated with an xfrm policy. The solution for this is to first ensure that errno values are correctly propagated all the way back up through the various call chains from security_xfrm_policy_lookup(), and handled correctly. Then, flow_cache_lookup() is modified, so that if the policy resolver fails (typically a permission denied via the security module), the flow cache entry is killed rather than having a null policy assigned (which indicates that the packet can pass freely). This also forces any future lookups for the same flow to consult the security module (e.g. SELinux) for current security policy (rather than, say, caching the error on the flow cache entry). This patch: Fix the selinux side of things. This makes sure SELinux polmatching of flow contexts to IPSec policy rules comes into play only when an explicit context is associated with the IPSec policy rule. Also, this no longer defaults the context of a socket policy to the context of the socket since the "no explicit context" case is now handled properly. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-09-22[XFRM]: Fix wildcard as tunnel sourcePatrick McHardy
Hashing SAs by source address breaks templates with wildcards as tunnel source since the source address used for hashing/lookup is still 0/0. Move source address lookup to xfrm_tmpl_resolve_one() so we can use the real address in the lookup. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add generation count to xfrm_state and xfrm_dst.David S. Miller
Each xfrm_state inserted gets a new generation counter value. When a bundle is created, the xfrm_dst objects get the current generation counter of the xfrm_state they will attach to at dst->xfrm. xfrm_bundle_ok() will return false if it sees an xfrm_dst with a generation count different from the generation count of the xfrm_state that dst points to. This provides a facility by which to passively and cheaply invalidate cached IPSEC routes during SA database changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] MIP6: Transformation support mobility header.Masahide NAKAMURA
Transformation support mobility header. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] IPV6: Restrict bundle reusingMasahide NAKAMURA
For outbound transformation, bundle is checked whether it is suitable for current flow to be reused or not. In such IPv6 case as below, transformation may apply incorrect bundle for the flow instead of creating another bundle: - The policy selector has destination prefix length < 128 (Two or more addresses can be matched it) - Its bundle holds dst entry of default route whose prefix length < 128 (Previous traffic was used such route as next hop) - The policy and the bundle were used a transport mode state and this time flow address is not matched the bundled state. This issue is found by Mobile IPv6 usage to protect mobility signaling by IPsec, but it is not a Mobile IPv6 specific. This patch adds strict check to xfrm_bundle_ok() for each state mode and address when prefix length is less than 128. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] STATE: Support non-fragment outbound transformation headers.Masahide NAKAMURA
For originated outbound IPv6 packets which will fragment, ip6_append_data() should know length of extension headers before sending them and the length is carried by dst_entry. IPv6 IPsec headers fragment then transformation was designed to place all headers after fragment header. OTOH Mobile IPv6 extension headers do not fragment then it is a good idea to make dst_entry have non-fragment length to tell it to ip6_append_data(). Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] STATE: Add a hook to obtain local/remote outbound address.Masahide NAKAMURA
Outbound transformation replaces both source and destination address with state's end-point addresses at the same time when IPsec tunnel mode. It is also required to change them for Mobile IPv6 route optimization, but we should care about the following differences: - changing result is not end-point but care-of address - either source or destination is replaced for each state This hook is a common platform to change outbound address. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add XFRM_MODE_xxx for future use.Masahide NAKAMURA
Transformation mode is used as either IPsec transport or tunnel. It is required to add two more items, route optimization and inbound trigger for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] xfrm: Undo afinfo lock proliferationHerbert Xu
The number of locks used to manage afinfo structures can easily be reduced down to one each for policy and state respectively. This is based on the observation that the write locks are only held by module insertion/removal which are very rare events so there is no need to further differentiate between the insertion of modules like ipv6 versus esp6. The removal of the read locks in xfrm4_policy.c/xfrm6_policy.c might look suspicious at first. However, after you realise that nobody ever takes the corresponding write lock you'll feel better :) As far as I can gather it's an attempt to guard against the removal of the corresponding modules. Since neither module can be unloaded at all we can leave it to whoever fixes up IPv6 unloading :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-18[IPV6] XFRM: Fix decoding session with preceding extension header(s).YOSHIFUJI Hideaki
We did not correctly decode session with preceding extension header(s). This was because we had already pulled preceding headers, skb->nh.raw + 40 + 1 - skb->data was minus, and pskb_may_pull() failed. We now have IP6CB(skb)->nhoff and skb->h.raw, and we can start parsing / decoding upper layer protocol from current position. Tracked down by Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> and tested by Kazunori Miyazawa <kazunori@miyazawa.org>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-18[IPV6] XFRM: Don't use old copy of pointer after pskb_may_pull().YOSHIFUJI Hideaki
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
