When we fast path datagram sends to avoid locking by putting
the inet_cork on the stack we use up lots of space that isn't
necessary.
This is because inet_cork contains a "struct flowi" which isn't
used in these code paths.
Split inet_cork to two parts, "inet_cork" and "inet_cork_full".
Only the latter of which has the "struct flowi" and is what is
stored in inet_sock.
drivers/net/tg3.c
Force dev_alloc_name() to be called from register_netdevice() by
dev_get_valid_name(). That allows to remove multiple explicit
dev_alloc_name() calls.
The possibility to call dev_alloc_name in advance remains.
This also fixes veth creation regresion caused by
84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Instead of rt->rt_{dst,src}
ctl_table_headers registered with register_net_sysctl_table should
have been unregistered with the equivalent unregister_net_sysctl_table
Signed-off-by: Lucian Adrian Grijincu <lucian.grijincu@gmail.com>
Four years ago, Patrick made a change to hold rtnl mutex during netlink
dump callbacks.
I believe it was a wrong move. This slows down concurrent dumps, making
good old /proc/net/ files faster than rtnetlink in some situations.
This occurred to me because one "ip link show dev ..." was _very_ slow
on a workload adding/removing network devices in background.
All dump callbacks are able to use RCU locking now, so this patch does
roughly a revert of commits :
1c2d670f366 : [RTNETLINK]: Hold rtnl_mutex during netlink dump callbacks
6313c1e0992 : [RTNETLINK]: Remove unnecessary locking in dump callbacks
This let writers fight for rtnl mutex and readers going full speed.
It also takes care of phonet : phonet_route_get() is now called from rcu
read section. I renamed it to phonet_route_get_rcu()
Cc: Patrick McHardy <kaber@trash.net>
Cc: Remi Denis-Courmont <remi.denis-courmont@nokia.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
For backward compatibility, we should retain the module parameters and
sysfs attributes to control the number of peer notifications
(gratuitous ARPs and unsolicited NAs) sent after bonding failover.
Also, it is possible for failover to take place even though the new
active slave does not have link up, and in that case the peer
notification should be deferred until it does.
Change ipv4 and ipv6 so they do not automatically send peer
notifications on bonding failover.
Change the bonding driver to send separate NETDEV_NOTIFY_PEERS
notifications when the link is up, as many times as requested. Since
it does not directly control which protocols send notifications, make
num_grat_arp and num_unsol_na aliases for a single parameter. Bump
the bonding version number and update its documentation.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
Acked-by: Brian Haley <brian.haley@hp.com>
Make dst_alloc() and it's users explicitly initialize the entire
entry.
The zero'ing done by kmem_cache_zalloc() was almost entirely
redundant.
Now the dst->dev, dev->obsolete, and dst->flags values can
be specified as well.
Although these are equivalent, but the skb_checksum_start_offset() is more readable.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
We lack proper synchronization to manipulate inet->opt ip_options
Problem is ip_make_skb() calls ip_setup_cork() and
ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options),
without any protection against another thread manipulating inet->opt.
Another thread can change inet->opt pointer and free old one under us.
Use RCU to protect inet->opt (changed to inet->inet_opt).
Instead of handling atomic refcounts, just copy ip_options when
necessary, to avoid cache line dirtying.
We cant insert an rcu_head in struct ip_options since its included in
skb->cb[], so this patch is large because I had to introduce a new
ip_options_rcu structure.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
When we use IPsec extended sequence numbers, we may overwrite
the last scatterlist of the associated data by the scatterlist
for the skb. This patch fixes this by placing the scatterlist
for the skb right behind the last scatterlist of the associated
data. esp4 does it already like that.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Resolved logic conflicts causing a build failure due to
drivers/net/r8169.c changes using a patch from Stephen Rothwell.
Since commit 62fa8a846d7d (net: Implement read-only protection and COW'ing
of metrics.) the kernel throws an oops.
[ 101.620985] BUG: unable to handle kernel NULL pointer dereference at
(null)
[ 101.621050] IP: [< (null)>] (null)
[ 101.621084] PGD 6e53c067 PUD 3dd6a067 PMD 0
[ 101.621122] Oops: 0010 [#1] SMP
[ 101.621153] last sysfs file: /sys/devices/virtual/ppp/ppp/uevent
[ 101.621192] CPU 2
[ 101.621206] Modules linked in: l2tp_ppp pppox ppp_generic slhc
l2tp_netlink l2tp_core deflate zlib_deflate twofish_x86_64
twofish_common des_generic cbc ecb sha1_generic hmac af_key
iptable_filter snd_pcm_oss snd_mixer_oss snd_seq snd_seq_device loop
snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_intel snd_hda_codec
snd_pcm snd_timer snd i2c_i801 iTCO_wdt psmouse soundcore snd_page_alloc
evdev uhci_hcd ehci_hcd thermal
[ 101.621552]
[ 101.621567] Pid: 5129, comm: openl2tpd Not tainted 2.6.39-rc4-Quad #3
Gigabyte Technology Co., Ltd. G33-DS3R/G33-DS3R
[ 101.621637] RIP: 0010:[<0000000000000000>] [< (null)>] (null)
[ 101.621684] RSP: 0018:ffff88003ddeba60 EFLAGS: 00010202
[ 101.621716] RAX: ffff88003ddb5600 RBX: ffff88003ddb5600 RCX:
0000000000000020
[ 101.621758] RDX: ffffffff81a69a00 RSI: ffffffff81b7ee61 RDI:
ffff88003ddb5600
[ 101.621800] RBP: ffff8800537cd900 R08: 0000000000000000 R09:
ffff88003ddb5600
[ 101.621840] R10: 0000000000000005 R11: 0000000000014b38 R12:
ffff88003ddb5600
[ 101.621881] R13: ffffffff81b7e480 R14: ffffffff81b7e8b8 R15:
ffff88003ddebad8
[ 101.621924] FS: 00007f06e4182700(0000) GS:ffff88007fd00000(0000)
knlGS:0000000000000000
[ 101.621971] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 101.622005] CR2: 0000000000000000 CR3: 0000000045274000 CR4:
00000000000006e0
[ 101.622046] DR0: 0000000000000000 DR1: 0000000000000000 DR2:
0000000000000000
[ 101.622087] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7:
0000000000000400
[ 101.622129] Process openl2tpd (pid: 5129, threadinfo
ffff88003ddea000, task ffff88003de9a280)
[ 101.622177] Stack:
[ 101.622191] ffffffff81447efa ffff88007d3ded80 ffff88003de9a280
ffff88007d3ded80
[ 101.622245] 0000000000000001 ffff88003ddebbb8 ffffffff8148d5a7
0000000000000212
[ 101.622299] ffff88003dcea000 ffff88003dcea188 ffffffff00000001
ffffffff81b7e480
[ 101.622353] Call Trace:
[ 101.622374] [<ffffffff81447efa>] ? ipv4_blackhole_route+0x1ba/0x210
[ 101.622415] [<ffffffff8148d5a7>] ? xfrm_lookup+0x417/0x510
[ 101.622450] [<ffffffff8127672a>] ? extract_buf+0x9a/0x140
[ 101.622485] [<ffffffff8144c6a0>] ? __ip_flush_pending_frames+0x70/0x70
[ 101.622526] [<ffffffff8146fbbf>] ? udp_sendmsg+0x62f/0x810
[ 101.622562] [<ffffffff813f98a6>] ? sock_sendmsg+0x116/0x130
[ 101.622599] [<ffffffff8109df58>] ? find_get_page+0x18/0x90
[ 101.622633] [<ffffffff8109fd6a>] ? filemap_fault+0x12a/0x4b0
[ 101.622668] [<ffffffff813fb5c4>] ? move_addr_to_kernel+0x64/0x90
[ 101.622706] [<ffffffff81405d5a>] ? verify_iovec+0x7a/0xf0
[ 101.622739] [<ffffffff813fc772>] ? sys_sendmsg+0x292/0x420
[ 101.622774] [<ffffffff810b994a>] ? handle_pte_fault+0x8a/0x7c0
[ 101.622810] [<ffffffff810b76fe>] ? __pte_alloc+0xae/0x130
[ 101.622844] [<ffffffff810ba2f8>] ? handle_mm_fault+0x138/0x380
[ 101.622880] [<ffffffff81024af9>] ? do_page_fault+0x189/0x410
[ 101.622915] [<ffffffff813fbe03>] ? sys_getsockname+0xf3/0x110
[ 101.622952] [<ffffffff81450c4d>] ? ip_setsockopt+0x4d/0xa0
[ 101.622986] [<ffffffff813f9932>] ? sockfd_lookup_light+0x22/0x90
[ 101.623024] [<ffffffff814b61fb>] ? system_call_fastpath+0x16/0x1b
[ 101.623060] Code: Bad RIP value.
[ 101.623090] RIP [< (null)>] (null)
[ 101.623125] RSP <ffff88003ddeba60>
[ 101.623146] CR2: 0000000000000000
[ 101.650871] ---[ end trace ca3856a7d8e8dad4 ]---
[ 101.651011] __sk_free: optmem leakage (160 bytes) detected.
The oops happens in dst_metrics_write_ptr()
include/net/dst.h:124: return dst->ops->cow_metrics(dst, p);
dst->ops->cow_metrics is NULL and causes the oops.
Provide cow_metrics() methods, like we did in commit 214f45c91bb
(net: provide default_advmss() methods to blackhole dst_ops)
Signed-off-by: Held Bernhard <berny156@gmx.de>
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
The changes introduced with git-commit a02e4b7d ("ipv6: Demark default
hoplimit as zero.") missed to remove the hoplimit initialization. As a
result, ipv6_get_mtu interprets the return value of dst_metric_raw
(-1) as 255 and answers ping6 with this hoplimit. This patche removes
the line such that ping6 is answered with the hoplimit value
configured via sysctl.
Signed-off-by: Thomas Egerer <thomas.egerer@secunet.com>
At this point, skb->data points to skb_transport_header.
So, headroom check is wrong.
For some case:bridge(UFO is on) + eth device(UFO is off),
there is no enough headroom for IPv6 frag head.
But headroom check is always false.
This will bring about data be moved to there prior to skb->head,
when adding IPv6 frag header to skb.
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
drivers/net/bnx2x/bnx2x_ethtool.c
NETDEV_NOTIFY_PEERS
It is undesirable for the bonding driver to be poking into higher
level protocols, and notifiers provide a way to avoid that. This does
mean removing the ability to configure reptitition of gratuitous ARPs
and unsolicited NAs.
The NETDEV_NOTIFY_PEERS notifier is a request to send such
advertisements following migration to a different physical link,
e.g. virtual machine migration.
The variable 'flowlabel' is set but unused in ip6t_mangle_out().
The intention here was to compare this key to the header value after
mangling, and trigger a route lookup on mismatch.
Make it so.
The variable 'target' is set but unused in compat_copy_entry_from_user().
Just kill it off.
[ipv6] Add support for RTA_PREFSRC
This patch allows a user to select the preferred source address
for a specific IPv6-Route. It can be set via a netlink message
setting RTA_PREFSRC to a valid IPv6 address which must be
up on the device the route will be bound to.
Signed-off-by: Daniel Walter <dwalter@barracuda.com>
[ipv6] Ignore looped-back NAs while in Duplicate Address Detection
If we send an unsolicited NA shortly after bringing up an
IPv6 address, the duplicate address detection algorithm
fails and the ip stays in tentative mode forever.
This is due a missing check if the NA is looped-back to us.
This reverts commit c191a836a908d1dd6b40c503741f91b914de3348.
It causes known regressions for programs that expect to be able to use
SO_REUSEADDR to shutdown a socket, then successfully rebind another
socket to the same ID.
Programs such as haproxy and amavisd expect this to work.
This should fix kernel bugzilla 32832.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits)
net: Add support for SMSC LAN9530, LAN9730 and LAN89530
mlx4_en: Restoring RX buffer pointer in case of failure
mlx4: Sensing link type at device initialization
ipv4: Fix "Set rt->rt_iif more sanely on output routes."
MAINTAINERS: add entry for Xen network backend
be2net: Fix suspend/resume operation
be2net: Rename some struct members for clarity
pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev
dsa/mv88e6131: add support for mv88e6085 switch
ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2)
be2net: Fix a potential crash during shutdown.
bna: Fix for handling firmware heartbeat failure
can: mcp251x: Allow pass IRQ flags through platform data.
smsc911x: fix mac_lock acquision before calling smsc911x_mac_read
iwlwifi: accept EEPROM version 0x423 for iwl6000
rt2x00: fix cancelling uninitialized work
rtlwifi: Fix some warnings/bugs
p54usb: IDs for two new devices
wl12xx: fix potential buffer overflow in testmode nvs push
zd1211rw: reset rx idle timer from tasklet
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
properly record sk_rxhash in ipv6 sockets (v2)
Noticed while working on another project that flows to sockets which I had open
on a test systems weren't getting steered properly when I had RFS enabled.
Looking more closely I found that:
1) The affected sockets were all ipv6
2) They weren't getting steered because sk->sk_rxhash was never set from the
incomming skbs on that socket.
This was occuring because there are several points in the IPv4 tcp and udp code
which save the rxhash value when a new connection is established. Those calls
to sock_rps_save_rxhash were never added to the corresponding ipv6 code paths.
This patch adds those calls. Tested by myself to properly enable RFS
functionalty on ipv6.
Change notes:
v2:
Filtered UDP to only arm RFS on bound sockets (Eric Dumazet)
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
Make sure dst_release() is not called with error pointer. This is
similar to commit 4910ac6c526d2868adcb5893e0c428473de862b5 ("ipv4:
Don't ip_rt_put() an error pointer in RAW sockets.").
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
We currently use a percpu spinlock to 'protect' rule bytes/packets
counters, after various attempts to use RCU instead.
Lately we added a seqlock so that get_counters() can run without
blocking BH or 'writers'. But we really only need the seqcount in it.
Spinlock itself is only locked by the current/owner cpu, so we can
remove it completely.
This cleanups api, using correct 'writer' vs 'reader' semantic.
At replace time, the get_counters() call makes sure all cpus are done
using the old table.
Cc: Jan Engelhardt <jengelh@medozas.de>
ipv6 fib lookup can set RT6_LOOKUP_F_IFACE flag to restrict search
to an interface, but this flag cannot be set via struct flowi.
Also, it cannot be set via ip6_route_output: this function uses the
passed sock struct to determine if this flag is required
(by testing for nonzero sk_bound_dev_if).
Work around this by passing in an artificial struct sk in case
'strict' argument is true.
This is required to replace the rt6_lookup call in xt_addrtype.c with
nf_afinfo->route().
This is required to eventually replace the rt6_lookup call in
xt_addrtype.c with nf_afinfo->route().
My commit 6d55cb91a0020ac0 (gre: fix hard header destination
address checking) broke multicast.
The reason is that ip_gre used to get ipgre_header() calls with
zero destination if we have NOARP or multicast destination. Instead
the actual target was decided at ipgre_tunnel_xmit() time based on
per-protocol dissection.
Instead of allowing the "abuse" of ->header() calls with invalid
destination, this creates multicast mappings for ip_gre. This also
fixes "ip neigh show nud noarp" to display the proper multicast
mappings used by the gre device.
Reported-by: Doug Kehn <rdkehn@yahoo.com>
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
Acked-by: Doug Kehn <rdkehn@yahoo.com>
Two places in the kernel were doing skb->ip_summed = 0.
Change both to skb->ip_summed = CHECKSUM_NONE, which is more readable.
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
This avoids explicit cast to avoid 'discards qualifiers'
compiler warning in a netfilter patch that i've been working on.
When I was fixing issues with unregisgtering tables under /proc/sys/net/ipv6/neigh
by adding a mount point it appears I missed a critical ordering issue, in the
ipv6 initialization. I had not realized that ipv6_sysctl_register is called
at the very end of the ipv6 initialization and in particular after we call
neigh_sysctl_register from ndisc_init.
"neigh" needs to be initialized in ipv6_static_sysctl_register which is
the first ipv6 table to initialized, and definitely before ndisc_init.
This removes the weirdness of duplicate tables while still providing a
"neigh" mount point which prevents races in sysctl unregistering.
This was initially reported at https://bugzilla.kernel.org/show_bug.cgi?id=31232
Reported-by: sunkan@zappa.cx
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
commit f3c5c1bfd4308 (make ip_tables reentrant) introduced a race in
handling the stackptr restore, at the end of ipt_do_table()
We should do it before the call to xt_info_rdunlock_bh(), or we allow
cpu preemption and another cpu overwrites stackptr of original one.
A second fix is to change the underflow test to check the origptr value
instead of 0 to detect underflow, or else we allow a jump from different
hooks.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
Documentation/feature-removal-schedule.txt
Structures ip6t_replace, compat_ip6t_replace, and xt_get_revision are
copied from userspace. Fields of these structs that are
zero-terminated strings are not checked. When they are used as argument
to a format string containing "%s" in request_module(), some sensitive
information is leaked to userspace via argument of spawned modprobe
process.
The first bug was introduced before the git epoch; the second was
introduced in 3bc3fe5e (v2.6.25-rc1); the third is introduced by
6b7d31fc (v2.6.15-rc1). To trigger the bug one should have
CAP_NET_ADMIN.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
This patch adds IPsec extended sequence numbers support to esp6.
We use the authencesn crypto algorithm to handle esp with separate
encryption/authentication algorithms.
xfrm_skb_cb
To support IPsec extended sequence numbers, we split the
output sequence numbers of xfrm_skb_cb in low and high order 32 bits
and we add the high order 32 bits to the input sequence numbers.
All users are updated accordingly.
Now we have struct flowi4, flowi6, and flowidn for each address
family. And struct flowi is just a union of them all.
It might have been troublesome to convert flow_cache_uli_match() but
as it turns out this function is completely unused and therefore can
be simply removed.
