This is the 4.14.170 stable release
drivers/net/phy/phy_device.c
drivers/tty/serial/imx.c
include/linux/platform_data/dma-imx-sdma.h
net/wireless/util.c
This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
[ Upstream commit 95224166a9032ff5d08fca633d37113078ce7d01 ]
With an ebpf program that redirects packets through a vti[6] interface,
the packets are dropped because no dst is attached.
This could also be reproduced with an AF_PACKET socket, with the following
python script (vti1 is an ip_vti interface):
import socket
send_s = socket.socket(socket.AF_PACKET, socket.SOCK_RAW, 0)
# scapy
# p = IP(src='10.100.0.2', dst='10.200.0.1')/ICMP(type='echo-request')
# raw(p)
req = b'E\x00\x00\x1c\x00\x01\x00\x00@\x01e\xb2\nd\x00\x02\n\xc8\x00\x01\x08\x00\xf7\xff\x00\x00\x00\x00'
send_s.sendto(req, ('vti1', 0x800, 0, 0))
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 5311a69aaca30fa849c3cc46fb25f75727fb72d0 ]
in the same manner as commit d0f418516022 ("net, ip_tunnel: fix
namespaces move"), fix namespace moving as it was broken since commit
8d79266bc48c ("ip6_tunnel: add collect_md mode to IPv6 tunnel"), but for
ipv6 this time; there is no reason to keep it for ip6_tunnel.
Fixes: 8d79266bc48c ("ip6_tunnel: add collect_md mode to IPv6 tunnel")
Signed-off-by: William Dauchy <w.dauchy@criteo.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit 62ebaeaedee7591c257543d040677a60e35c7aec ]
After LRO/GRO is applied, SRv6 encapsulated packets have
SKB_GSO_IPXIP6 feature flag, and this flag must be removed right after
decapulation procedure.
Currently, SKB_GSO_IPXIP6 flag is not removed on End.D* actions, which
creates inconsistent packet state, that is, a normal TCP/IP packets
have the SKB_GSO_IPXIP6 flag. This behavior can cause unexpected
fallback to GSO on routing to netdevices that do not support
SKB_GSO_IPXIP6. For example, on inter-VRF forwarding, decapsulated
packets separated into small packets by GSO because VRF devices do not
support TSO for packets with SKB_GSO_IPXIP6 flag, and this degrades
forwarding performance.
This patch removes encapsulation related GSO flags from the skb right
after the End.D* action is applied.
Fixes: d7a669dd2f8b ("ipv6: sr: add helper functions for seg6local")
Signed-off-by: Yuki Taguchi <tagyounit@gmail.com>
[ Upstream commit ae7352d384a552d8c799c242e74a934809990a71 ]
Both IPv6 and 6lowpan are calling inet_frags_fini() too soon.
inet_frags_fini() is dismantling a kmem_cache, that might be needed
later when unregister_pernet_subsys() eventually has to remove
frags queues from hash tables and free them.
This fixes potential use-after-free, and is a prereq for the following patch.
Fixes: d4ad4d22e7ac ("inet: frags: use kmem_cache for inet_frag_queue")
commit 8dbd76e79a16b45b2ccb01d2f2e08dbf64e71e40 upstream.
Michal Kubecek and Firo Yang did a very nice analysis of crashes
happening in __inet_lookup_established().
Since a TCP socket can go from TCP_ESTABLISH to TCP_LISTEN
(via a close()/socket()/listen() cycle) without a RCU grace period,
I should not have changed listeners linkage in their hash table.
They must use the nulls protocol (Documentation/RCU/rculist_nulls.txt),
so that a lookup can detect a socket in a hash list was moved in
another one.
Since we added code in commit d296ba60d8e2 ("soreuseport: Resolve
merge conflict for v4/v6 ordering fix"), we have to add
hlist_nulls_add_tail_rcu() helper.
Fixes: 3b24d854cb35 ("tcp/dccp: do not touch listener sk_refcnt under synflood")
Reported-by: Michal Kubecek <mkubecek@suse.cz>
Reported-by: Firo Yang <firo.yang@suse.com>
Reviewed-by: Michal Kubecek <mkubecek@suse.cz>
Link: https://lore.kernel.org/netdev/20191120083919.GH27852@unicorn.suse.cz/
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
[stable-4.14: we also need to update code in __inet_lookup_listener() and
inet6_lookup_listener() which has been removed in 5.0-rc1.]
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit 4d42df46d6372ece4cb4279870b46c2ea7304a47 ]
When do IPv6 tunnel PMTU update and calls __ip6_rt_update_pmtu() in the end,
we should not call dst_confirm_neigh() as there is no two-way communication.
v5: No change.
v4: No change.
v3: Do not remove dst_confirm_neigh, but add a new bool parameter in
dst_ops.update_pmtu to control whether we should do neighbor confirm.
Also split the big patch to small ones for each area.
v2: Remove dst_confirm_neigh in __ip6_rt_update_pmtu.
Reviewed-by: Guillaume Nault <gnault@redhat.com>
Acked-by: David Ahern <dsahern@gmail.com>
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
[ Upstream commit 8247a79efa2f28b44329f363272550c1738377de ]
Although vti and vti6 are immune to this problem because they are IFF_NOARP
interfaces, as Guillaume pointed. There is still no sense to confirm neighbour
here.
v5: Update commit description.
v4: No change.
[ Upstream commit 7a1592bcb15d71400a98632727791d1e68ea0ee8 ]
When do tunnel PMTU update and calls __ip6_rt_update_pmtu() in the end,
v5: No Change.
v4: Update commit description
Fixes: 0dec879f636f ("net: use dst_confirm_neigh for UDP, RAW, ICMP, L2TP")
Tested-by: Guillaume Nault <gnault@redhat.com>
[ Upstream commit 675d76ad0ad5bf41c9a129772ef0aba8f57ea9a7 ]
When we do ipv6 gre pmtu update, we will also do neigh confirm currently.
This will cause the neigh cache be refreshed and set to REACHABLE before
xmit.
But if the remote mac address changed, e.g. device is deleted and recreated,
we will not able to notice this and still use the old mac address as the neigh
cache is REACHABLE.
Fix this by disable neigh confirm when do pmtu update
v5: No change.
v4: No change.
Reported-by: Jianlin Shi <jishi@redhat.com>
[ Upstream commit bd085ef678b2cc8c38c105673dfe8ff8f5ec0c57 ]
The MTU update code is supposed to be invoked in response to real
networking events that update the PMTU. In IPv6 PMTU update function
__ip6_rt_update_pmtu() we called dst_confirm_neigh() to update neighbor
confirmed time.
But for tunnel code, it will call pmtu before xmit, like:
- tnl_update_pmtu()
- skb_dst_update_pmtu()
- ip6_rt_update_pmtu()
- __ip6_rt_update_pmtu()
- dst_confirm_neigh()
If the tunnel remote dst mac address changed and we still do the neigh
confirm, we will not be able to update neigh cache and ping6 remote
will failed.
So for this ip_tunnel_xmit() case, _EVEN_ if the MTU is changed, we
should not be invoking dst_confirm_neigh() as we have no evidence
of successful two-way communication at this point.
On the other hand it is also important to keep the neigh reachability fresh
for TCP flows, so we cannot remove this dst_confirm_neigh() call.
To fix the issue, we have to add a new bool parameter for dst_ops.update_pmtu
to choose whether we should do neigh update or not. I will add the parameter
in this patch and set all the callers to true to comply with the previous
way, and fix the tunnel code one by one on later patches.
v5: No change.
v4: No change.
Suggested-by: David Miller <davem@davemloft.net>
[ Upstream commit c2027d1e17582903e368abf5d4838b22a98f2b7b ]
A recent commit allows sockets bound to a VRF to receive ipv6 link local
packets. However, it only works for UDP and worse TCP connection attempts
to the LLA with the only listener bound to the VRF just hang where as
before the client gets a reset and connection refused. Fix by adjusting
ir_iif for LL addresses and packets received through a device enslaved
to a VRF.
Fixes: 6f12fa775530 ("vrf: mark skb for multicast or link-local as enslaved to VRF")
Reported-by: Donald Sharp <sharpd@cumulusnetworks.com>
Cc: Mike Manning <mmanning@vyatta.att-mail.com>
Signed-off-by: David Ahern <dsahern@gmail.com>
deleted on device
[ Upstream commit 097f95d319f817e651bd51f8846aced92a55a6a1 ]
We configured iptables as below, which only allowed incoming data on
established connections:
iptables -t mangle -A PREROUTING -m state --state ESTABLISHED -j ACCEPT
iptables -t mangle -P PREROUTING DROP
When deleting a secondary address, current masquerade implements would
flush all conntracks on this device. All the established connections on
primary address also be deleted, then subsequent incoming data on the
connections would be dropped wrongly because it was identified as NEW
connection.
So when an address was delete, it should only flush connections related
with the address.
Signed-off-by: Tan Hu <tan.hu@zte.com.cn>
[ Upstream commit 7170a977743b72cf3eb46ef6ef89885dc7ad3621 ]
This socket field can be read and written by concurrent cpus.
Use READ_ONCE() and WRITE_ONCE() annotations to document this,
and avoid some compiler 'optimizations'.
KCSAN reported :
BUG: KCSAN: data-race in tcp_v4_rcv / tcp_v4_rcv
write to 0xffff88812220763c of 4 bytes by interrupt on cpu 0:
sk_incoming_cpu_update include/net/sock.h:953 [inline]
tcp_v4_rcv+0x1b3c/0x1bb0 net/ipv4/tcp_ipv4.c:1934
ip_protocol_deliver_rcu+0x4d/0x420 net/ipv4/ip_input.c:204
ip_local_deliver_finish+0x110/0x140 net/ipv4/ip_input.c:231
NF_HOOK include/linux/netfilter.h:305 [inline]
NF_HOOK include/linux/netfilter.h:299 [inline]
ip_local_deliver+0x133/0x210 net/ipv4/ip_input.c:252
dst_input include/net/dst.h:442 [inline]
ip_rcv_finish+0x121/0x160 net/ipv4/ip_input.c:413
ip_rcv+0x18f/0x1a0 net/ipv4/ip_input.c:523
__netif_receive_skb_one_core+0xa7/0xe0 net/core/dev.c:5010
__netif_receive_skb+0x37/0xf0 net/core/dev.c:5124
process_backlog+0x1d3/0x420 net/core/dev.c:5955
napi_poll net/core/dev.c:6392 [inline]
net_rx_action+0x3ae/0xa90 net/core/dev.c:6460
__do_softirq+0x115/0x33f kernel/softirq.c:292
do_softirq_own_stack+0x2a/0x40 arch/x86/entry/entry_64.S:1082
do_softirq.part.0+0x6b/0x80 kernel/softirq.c:337
do_softirq kernel/softirq.c:329 [inline]
__local_bh_enable_ip+0x76/0x80 kernel/softirq.c:189
read to 0xffff88812220763c of 4 bytes by interrupt on cpu 1:
sk_incoming_cpu_update include/net/sock.h:952 [inline]
tcp_v4_rcv+0x181a/0x1bb0 net/ipv4/tcp_ipv4.c:1934
run_ksoftirqd+0x46/0x60 kernel/softirq.c:603
smpboot_thread_fn+0x37d/0x4a0 kernel/smpboot.c:165
Reported by Kernel Concurrency Sanitizer on:
CPU: 1 PID: 16 Comm: ksoftirqd/1 Not tainted 5.4.0-rc3+ #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 2d819d250a1393a3e725715425ab70a0e0772a71 ]
Rajendra reported a kernel panic when a link was taken down:
[ 6870.263084] BUG: unable to handle kernel NULL pointer dereference at 00000000000000a8
[ 6870.271856] IP: [<ffffffff8efc5764>] __ipv6_ifa_notify+0x154/0x290
<snip>
[ 6870.570501] Call Trace:
[ 6870.573238] [<ffffffff8efc58c6>] ? ipv6_ifa_notify+0x26/0x40
[ 6870.579665] [<ffffffff8efc98ec>] ? addrconf_dad_completed+0x4c/0x2c0
[ 6870.586869] [<ffffffff8efe70c6>] ? ipv6_dev_mc_inc+0x196/0x260
[ 6870.593491] [<ffffffff8efc9c6a>] ? addrconf_dad_work+0x10a/0x430
[ 6870.600305] [<ffffffff8f01ade4>] ? __switch_to_asm+0x34/0x70
[ 6870.606732] [<ffffffff8ea93a7a>] ? process_one_work+0x18a/0x430
[ 6870.613449] [<ffffffff8ea93d6d>] ? worker_thread+0x4d/0x490
[ 6870.619778] [<ffffffff8ea93d20>] ? process_one_work+0x430/0x430
[ 6870.626495] [<ffffffff8ea99dd9>] ? kthread+0xd9/0xf0
[ 6870.632145] [<ffffffff8f01ade4>] ? __switch_to_asm+0x34/0x70
[ 6870.638573] [<ffffffff8ea99d00>] ? kthread_park+0x60/0x60
[ 6870.644707] [<ffffffff8f01ae77>] ? ret_from_fork+0x57/0x70
[ 6870.650936] Code: 31 c0 31 d2 41 b9 20 00 08 02 b9 09 00 00 0
addrconf_dad_work is kicked to be scheduled when a device is brought
up. There is a race between addrcond_dad_work getting scheduled and
taking the rtnl lock and a process taking the link down (under rtnl).
The latter removes the host route from the inet6_addr as part of
addrconf_ifdown which is run for NETDEV_DOWN. The former attempts
to use the host route in __ipv6_ifa_notify. If the down event removes
the host route due to the race to the rtnl, then the BUG listed above
occurs.
Since the DAD sequence can not be aborted, add a check for the missing
host route in __ipv6_ifa_notify. The only way this should happen is due
to the previously mentioned race. The host route is created when the
address is added to an interface; it is only removed on a down event
where the address is kept. Add a warning if the host route is missing
AND the device is up; this is a situation that should never happen.
Fixes: f1705ec197e7 ("net: ipv6: Make address flushing on ifdown optional")
Reported-by: Rajendra Dendukuri <rajendra.dendukuri@broadcom.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 6af1799aaf3f1bc8defedddfa00df3192445bbf3 ]
This began with a syzbot report. syzkaller was injecting
IPv6 TCP SYN packets having a v4mapped source address.
After an unsuccessful 4-tuple lookup, TCP creates a request
socket (SYN_RECV) and calls reqsk_queue_hash_req()
reqsk_queue_hash_req() calls sk_ehashfn(sk)
At this point we have AF_INET6 sockets, and the heuristic
used by sk_ehashfn() to either hash the IPv4 or IPv6 addresses
is to use ipv6_addr_v4mapped(&sk->sk_v6_daddr)
For the particular spoofed packet, we end up hashing V4 addresses
which were not initialized by the TCP IPv6 stack, so KMSAN fired
a warning.
I first fixed sk_ehashfn() to test both source and destination addresses,
but then faced various problems, including user-space programs
like packetdrill that had similar assumptions.
Instead of trying to fix the whole ecosystem, it is better
to admit that we have a dual stack behavior, and that we
can not build linux kernels without V4 stack anyway.
The dual stack API automatically forces the traffic to be IPv4
if v4mapped addresses are used at bind() or connect(), so it makes
no sense to allow IPv6 traffic to use the same v4mapped class.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: Florian Westphal <fw@strlen.de>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit d23dbc479a8e813db4161a695d67da0e36557846 ]
The '.exit' functions from 'pernet_operations' structure should be marked
as __net_exit, not __net_init.
Fixes: d862e5461423 ("net: ipv6: Implement /proc/net/icmp6.")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit a84d016479896b5526a2cc54784e6ffc41c9d6f6 ]
Similar to the fix done for IPv4 in commit e5b1c6c6277d
("igmp: fix memory leak in igmpv3_del_delrec()"), we need to
make sure mca_tomb and mca_sources are not blindly overwritten.
Using swap() then a call to ip6_mc_clear_src() will take care
of the missing free.
BUG: memory leak
unreferenced object 0xffff888117d9db00 (size 64):
comm "syz-executor247", pid 6918, jiffies 4294943989 (age 25.350s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 fe 88 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<000000005b463030>] kmemleak_alloc_recursive include/linux/kmemleak.h:43 [inline]
[<000000005b463030>] slab_post_alloc_hook mm/slab.h:522 [inline]
[<000000005b463030>] slab_alloc mm/slab.c:3319 [inline]
[<000000005b463030>] kmem_cache_alloc_trace+0x145/0x2c0 mm/slab.c:3548
[<00000000939cbf94>] kmalloc include/linux/slab.h:552 [inline]
[<00000000939cbf94>] kzalloc include/linux/slab.h:748 [inline]
[<00000000939cbf94>] ip6_mc_add1_src net/ipv6/mcast.c:2236 [inline]
[<00000000939cbf94>] ip6_mc_add_src+0x31f/0x420 net/ipv6/mcast.c:2356
[<00000000d8972221>] ip6_mc_source+0x4a8/0x600 net/ipv6/mcast.c:449
[<000000002b203d0d>] do_ipv6_setsockopt.isra.0+0x1b92/0x1dd0 net/ipv6/ipv6_sockglue.c:748
[<000000001f1e2d54>] ipv6_setsockopt+0x89/0xd0 net/ipv6/ipv6_sockglue.c:944
[<00000000c8f7bdf9>] udpv6_setsockopt+0x4e/0x90 net/ipv6/udp.c:1558
[<000000005a9a0c5e>] sock_common_setsockopt+0x38/0x50 net/core/sock.c:3139
[<00000000910b37b2>] __sys_setsockopt+0x10f/0x220 net/socket.c:2084
[<00000000e9108023>] __do_sys_setsockopt net/socket.c:2100 [inline]
[<00000000e9108023>] __se_sys_setsockopt net/socket.c:2097 [inline]
[<00000000e9108023>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2097
[<00000000f4818160>] do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:296
[<000000008d367e8f>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: 1666d49e1d41 ("mld: do not remove mld souce list info when set link down")
Fixes: 9c8bb163ae78 ("igmp, mld: Fix memory leak in igmpv3/mld_del_delrec()")
[ Upstream commit 89e4130939a20304f4059ab72179da81f5347528 ]
When a dual stack tcp listener accepts an ipv4 flow,
it should not attempt to use an ipv6 header or tcp_v6_iif() helper.
Fixes: 1397ed35f22d ("ipv6: add flowinfo for tcp6 pkt_options for all cases")
Fixes: df3687ffc665 ("ipv6: add the IPV6_FL_F_REFLECT flag to IPV6_FL_A_GET")
(cherry picked from commit 94e82e56fdd379d26a8fe4d2a605c976662d8373)
[ Upstream commit b575b24b8eee37f10484e951b62ce2a31c579775 ]
When firewalld is enabled with ipv4/ipv6 rpfilter, vrf
ipv4/ipv6 packets will be dropped. Vrf device will pass
through netfilter hook twice. One with enslaved device
and another one with l3 master device. So in device may
dismatch witch out device because out device is always
enslaved device.So failed with the check of the rpfilter
and drop the packets by mistake.
Signed-off-by: Miaohe Lin <linmiaohe@huawei.com>
[ Upstream commit 01f5bffad555f8e22a61f4b1261fe09cf1b96994 ]
ip4ip6/ip6ip6 tunnels run iptunnel_handle_offloads on xmit which
can cause a possible use-after-free accessing iph/ipv6h pointer
since the packet will be 'uncloned' running pskb_expand_head if
it is a cloned gso skb.
Fixes: 0e9a709560db ("ip6_tunnel, ip6_gre: fix setting of DSCP on encapsulated packets")
Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com>
[ Upstream commit 8a3dca632538c550930ce8bafa8c906b130d35cf ]
When fixing the skb leak introduced by the conversion to rbtree, I
forgot about the special case of duplicate fragments. The condition
under the 'insert_error' label isn't effective anymore as
nf_ct_frg6_gather() doesn't override the returned value anymore. So
duplicate fragments now get NF_DROP verdict.
To accept duplicate fragments again, handle them specially as soon as
inet_frag_queue_insert() reports them. Return -EINPROGRESS which will
translate to NF_STOLEN verdict, like any accepted fragment. However,
such packets don't carry any new information and aren't queued, so we
just drop them immediately.
Fixes: a0d56cb911ca ("netfilter: ipv6: nf_defrag: fix leakage of unqueued fragments")
Signed-off-by: Guillaume Nault <gnault@redhat.com>
[ Upstream commit a0d56cb911ca301de81735f1d73c2aab424654ba ]
With commit 997dd9647164 ("net: IP6 defrag: use rbtrees in
nf_conntrack_reasm.c"), nf_ct_frag6_reasm() is now called from
nf_ct_frag6_queue(). With this change, nf_ct_frag6_queue() can fail
after the skb has been added to the fragment queue and
nf_ct_frag6_gather() was adapted to handle this case.
But nf_ct_frag6_queue() can still fail before the fragment has been
queued. nf_ct_frag6_gather() can't handle this case anymore, because it
has no way to know if nf_ct_frag6_queue() queued the fragment before
failing. If it didn't, the skb is lost as the error code is overwritten
with -EINPROGRESS.
Fix this by setting -EINPROGRESS directly in nf_ct_frag6_queue(), so
that nf_ct_frag6_gather() can propagate the error as is.
Fixes: 997dd9647164 ("net: IP6 defrag: use rbtrees in nf_conntrack_reasm.c")
commit 4ac30c4b3659efac031818c418beb51e630d512d upstream.
__udp6_lib_err() may be called when handling icmpv6 message. For example,
the icmpv6 toobig(type=2). __udp6_lib_lookup() is then called
which may call reuseport_select_sock(). reuseport_select_sock() will
call into a bpf_prog (if there is one).
reuseport_select_sock() is expecting the skb->data pointing to the
transport header (udphdr in this case). For example, run_bpf_filter()
is pulling the transport header.
However, in the __udp6_lib_err() path, the skb->data is pointing to the
ipv6hdr instead of the udphdr.
One option is to pull and push the ipv6hdr in __udp6_lib_err().
Instead of doing this, this patch follows how the original
commit 538950a1b752 ("soreuseport: setsockopt SO_ATTACH_REUSEPORT_[CE]BPF")
was done in IPv4, which has passed a NULL skb pointer to
Fixes: 538950a1b752 ("soreuseport: setsockopt SO_ATTACH_REUSEPORT_[CE]BPF")
Cc: Craig Gallek <kraig@google.com>
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Acked-by: Song Liu <songliubraving@fb.com>
Acked-by: Craig Gallek <kraig@google.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit 257a525fe2e49584842c504a92c27097407f778f upstream.
When the commit a6024562ffd7 ("udp: Add GRO functions to UDP socket")
added udp[46]_lib_lookup_skb to the udp_gro code path, it broke
the reuseport_select_sock() assumption that skb->data is pointing
to the transport header.
This patch follows an earlier __udp6_lib_err() fix by
passing a NULL skb to avoid calling the reuseport's bpf_prog.
Fixes: a6024562ffd7 ("udp: Add GRO functions to UDP socket")
Cc: Tom Herbert <tom@herbertland.com>
[ Upstream commit 65a3c497c0e965a552008db8bc2653f62bc925a1 ]
Before taking a refcount, make sure the object is not already
scheduled for deletion.
Same fix is needed in ipv6_flowlabel_opt()
Fixes: 18367681a10b ("ipv6 flowlabel: Convert np->ipv6_fl_list to RCU.")
Cc: Willem de Bruijn <willemb@google.com>
[ Upstream commit 59e3e4b52663a9d97efbce7307f62e4bc5c9ce91 ]
As it was done in commit 8f659a03a0ba ("net: ipv4: fix for a race
condition in raw_sendmsg") and commit 20b50d79974e ("net: ipv4: emulate
READ_ONCE() on ->hdrincl bit-field in raw_sendmsg()") for ipv4, copy the
value of inet->hdrincl in a local variable, to avoid introducing a race
condition in the next commit.
Signed-off-by: Olivier Matz <olivier.matz@6wind.com>
[ Upstream commit b9aa52c4cb457e7416cc0c95f475e72ef4a61336 ]
The following code returns EFAULT (Bad address):
s = socket(AF_INET6, SOCK_RAW, IPPROTO_ICMPV6);
setsockopt(s, SOL_IPV6, IPV6_HDRINCL, 1);
sendto(ipv6_icmp6_packet, addr); /* returns -1, errno = EFAULT */
The IPv4 equivalent code works. A workaround is to use IPPROTO_RAW
instead of IPPROTO_ICMPV6.
The failure happens because 2 bytes are eaten from the msghdr by
rawv6_probe_proto_opt() starting from commit 19e3c66b52ca ("ipv6
equivalent of "ipv4: Avoid reading user iov twice after
raw_probe_proto_opt""), but at that time it was not a problem because
IPV6_HDRINCL was not yet introduced.
Only eat these 2 bytes if hdrincl == 0.
Fixes: 715f504b1189 ("ipv6: add IPV6_HDRINCL option for raw sockets")
[ Upstream commit 72f7cfab6f93a8ea825fab8ccfb016d064269f7f ]
IPv6 does not consider if the socket is bound to a device when binding
to an address. The result is that a socket can be bound to eth0 and
then bound to the address of eth1. If the device is a VRF, the result
is that a socket can only be bound to an address in the default VRF.
Resolve by considering the device if sk_bound_dev_if is set.
Signed-off-by: Mike Manning <mmanning@vyatta.att-mail.com>
Reviewed-by: David Ahern <dsahern@gmail.com>
Tested-by: David Ahern <dsahern@gmail.com>
[ Upstream commit df453700e8d81b1bdafdf684365ee2b9431fb702 ]
According to Amit Klein and Benny Pinkas, IP ID generation is too weak
and might be used by attackers.
Even with recent net_hash_mix() fix (netns: provide pure entropy for net_hash_mix())
having 64bit key and Jenkins hash is risky.
It is time to switch to siphash and its 128bit keys.
Reported-by: Amit Klein <aksecurity@gmail.com>
Reported-by: Benny Pinkas <benny@pinkas.net>
[ Upstream commit 6ee02a54ef990a71bf542b6f0a4e3321de9d9c66 ]
When unloading xfrm6_tunnel module, xfrm6_tunnel_fini directly
frees the xfrm6_tunnel_spi_kmem. Maybe someone has gotten the
xfrm6_tunnel_spi, so need to wait it.
Fixes: 91cc3bb0b04ff("xfrm6_tunnel: RCU conversion")
Signed-off-by: Su Yanjun <suyj.fnst@cn.fujitsu.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit ff6ab32bd4e073976e4d8797b4d514a172cfe6cb ]
VRF netdev mtu isn't typically set and have an mtu of 65536. When the
link of a tunnel is set, the tunnel mtu is changed from 1480 to the link
mtu minus tunnel header. In the case of VRF netdev is the link, then the
tunnel mtu becomes 65516. So, fix it by not setting the tunnel mtu in
this case.
Signed-off-by: Stephen Suryaputra <ssuryaextr@gmail.com>
Replace -EBUSY with -ENOSPC when handling transient busy
indication in the absence of backlog.
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
(cherry picked from commit 068c2e703577dca8cd634421f14b90959589ec85)
[ Upstream commit 95c169251bf734aa555a1e8043e4d88ec97a04ec ]
A request for a flowlabel fails in process or user exclusive mode must
fail if the caller pid or uid does not match. Invert the test.
Previously, the test was unsafe wrt PID recycling, but indeed tested
for inequality: fl1->owner != fl->owner
Fixes: 4f82f45730c68 ("net ip6 flowlabel: Make owner a union of struct pid* and kuid_t")
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 6c0afef5fb0c27758f4d52b2210c61b6bd8b4470 ]
syzbot was able to catch a use-after-free read in pid_nr_ns() [1]
ip6fl_seq_show() seems to use RCU protection, dereferencing fl->owner.pid
but fl_free() releases fl->owner.pid before rcu grace period is started.
[1]
BUG: KASAN: use-after-free in pid_nr_ns+0x128/0x140 kernel/pid.c:407
Read of size 4 at addr ffff888094012a04 by task syz-executor.0/18087
CPU: 0 PID: 18087 Comm: syz-executor.0 Not tainted 5.1.0-rc6+ #89
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x172/0x1f0 lib/dump_stack.c:113
print_address_description.cold+0x7c/0x20d mm/kasan/report.c:187
kasan_report.cold+0x1b/0x40 mm/kasan/report.c:317
__asan_report_load4_noabort+0x14/0x20 mm/kasan/generic_report.c:131
ip6fl_seq_show+0x2f8/0x4f0 net/ipv6/ip6_flowlabel.c:794
seq_read+0xad3/0x1130 fs/seq_file.c:268
proc_reg_read+0x1fe/0x2c0 fs/proc/inode.c:227
do_loop_readv_writev fs/read_write.c:701 [inline]
do_loop_readv_writev fs/read_write.c:688 [inline]
do_iter_read+0x4a9/0x660 fs/read_write.c:922
vfs_readv+0xf0/0x160 fs/read_write.c:984
kernel_readv fs/splice.c:358 [inline]
default_file_splice_read+0x475/0x890 fs/splice.c:413
do_splice_to+0x12a/0x190 fs/splice.c:876
splice_direct_to_actor+0x2d2/0x970 fs/splice.c:953
do_splice_direct+0x1da/0x2a0 fs/splice.c:1062
do_sendfile+0x597/0xd00 fs/read_write.c:1443
__do_sys_sendfile64 fs/read_write.c:1498 [inline]
__se_sys_sendfile64 fs/read_write.c:1490 [inline]
__x64_sys_sendfile64+0x15a/0x220 fs/read_write.c:1490
do_syscall_64+0x103/0x610 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x458da9
Code: ad b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f300d24bc78 EFLAGS: 00000246 ORIG_RAX: 0000000000000028
RAX: ffffffffffffffda RBX: 0000000000000004 RCX: 0000000000458da9
RDX: 00000000200000c0 RSI: 0000000000000008 RDI: 0000000000000007
RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000
R10: 000000000000005a R11: 0000000000000246 R12: 00007f300d24c6d4
R13: 00000000004c5fa3 R14: 00000000004da748 R15: 00000000ffffffff
Allocated by task 17543:
save_stack+0x45/0xd0 mm/kasan/common.c:75
set_track mm/kasan/common.c:87 [inline]
__kasan_kmalloc mm/kasan/common.c:497 [inline]
__kasan_kmalloc.constprop.0+0xcf/0xe0 mm/kasan/common.c:470
kasan_slab_alloc+0xf/0x20 mm/kasan/common.c:505
slab_post_alloc_hook mm/slab.h:437 [inline]
slab_alloc mm/slab.c:3393 [inline]
kmem_cache_alloc+0x11a/0x6f0 mm/slab.c:3555
alloc_pid+0x55/0x8f0 kernel/pid.c:168
copy_process.part.0+0x3b08/0x7980 kernel/fork.c:1932
copy_process kernel/fork.c:1709 [inline]
_do_fork+0x257/0xfd0 kernel/fork.c:2226
__do_sys_clone kernel/fork.c:2333 [inline]
__se_sys_clone kernel/fork.c:2327 [inline]
__x64_sys_clone+0xbf/0x150 kernel/fork.c:2327
Freed by task 7789:
__kasan_slab_free+0x102/0x150 mm/kasan/common.c:459
kasan_slab_free+0xe/0x10 mm/kasan/common.c:467
__cache_free mm/slab.c:3499 [inline]
kmem_cache_free+0x86/0x260 mm/slab.c:3765
put_pid.part.0+0x111/0x150 kernel/pid.c:111
put_pid+0x20/0x30 kernel/pid.c:105
fl_free+0xbe/0xe0 net/ipv6/ip6_flowlabel.c:102
ip6_fl_gc+0x295/0x3e0 net/ipv6/ip6_flowlabel.c:152
call_timer_fn+0x190/0x720 kernel/time/timer.c:1325
expire_timers kernel/time/timer.c:1362 [inline]
__run_timers kernel/time/timer.c:1681 [inline]
__run_timers kernel/time/timer.c:1649 [inline]
run_timer_softirq+0x652/0x1700 kernel/time/timer.c:1694
__do_softirq+0x266/0x95a kernel/softirq.c:293
The buggy address belongs to the object at ffff888094012a00
which belongs to the cache pid_2 of size 88
The buggy address is located 4 bytes inside of
88-byte region [ffff888094012a00, ffff888094012a58)
The buggy address belongs to the page:
page:ffffea0002500480 count:1 mapcount:0 mapping:ffff88809a483080 index:0xffff888094012980
flags: 0x1fffc0000000200(slab)
raw: 01fffc0000000200 ffffea00018a3508 ffffea0002524a88 ffff88809a483080
raw: ffff888094012980 ffff888094012000 000000010000001b 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff888094012900: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
ffff888094012980: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
>ffff888094012a00: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
ffff888094012a80: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
ffff888094012b00: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
Fixes: 4f82f45730c6 ("net ip6 flowlabel: Make owner a union of struct pid * and kuid_t")
Cc: Eric W. Biederman <ebiederm@xmission.com>
[ Upstream commit 997dd96471641e147cb2c33ad54284000d0f5e35 ]
Currently, IPv6 defragmentation code drops non-last fragments that
are smaller than 1280 bytes: see
commit 0ed4229b08c1 ("ipv6: defrag: drop non-last frags smaller than min mtu")
This behavior is not specified in IPv6 RFCs and appears to break
compatibility with some IPv6 implemenations, as reported here:
https://www.spinics.net/lists/netdev/msg543846.html
This patch re-uses common IP defragmentation queueing and reassembly
code in IP6 defragmentation in nf_conntrack, removing the 1280 byte
restriction.
Signed-off-by: Peter Oskolkov <posk@google.com>
Reported-by: Tom Herbert <tom@herbertland.com>
Cc: Eric Dumazet <edumazet@google.com>
[ Upstream commit d4289fcc9b16b89619ee1c54f829e05e56de8b9a ]
code in IPv6, removing the 1280 byte restriction.
v2: change handling of overlaps to match that of upstream.
[ Upstream commit 70b095c84326640eeacfd69a411db8fc36e8ab1a ]
IPV6=m
DEFRAG_IPV6=m
CONNTRACK=y yields:
net/netfilter/nf_conntrack_proto.o: In function `nf_ct_netns_do_get':
net/netfilter/nf_conntrack_proto.c:802: undefined reference to `nf_defrag_ipv6_enable'
net/netfilter/nf_conntrack_proto.o:(.rodata+0x640): undefined reference to `nf_conntrack_l4proto_icmpv6'
Setting DEFRAG_IPV6=y causes undefined references to ip6_rhash_params
ip6_frag_init and ip6_expire_frag_queue so it would be needed to force
IPV6=y too.
This patch gets rid of the 'followup linker error' by removing
the dependency of ipv6.ko symbols from netfilter ipv6 defrag.
Shared code is placed into a header, then used from both.
[ Upstream commit 415787d7799f4fccbe8d49cb0b8e5811be6b0389 ]
lockdep does not know that the locks used by IPv4 defrag
and IPv6 reassembly units are of different classes.
It complains because of following chains :
1) sch_direct_xmit() (lock txq->_xmit_lock)
dev_hard_start_xmit()
xmit_one()
dev_queue_xmit_nit()
packet_rcv_fanout()
ip_check_defrag()
ip_defrag()
spin_lock() (lock frag queue spinlock)
2) ip6_input_finish()
ipv6_frag_rcv() (lock frag queue spinlock)
ip6_frag_queue()
icmpv6_param_prob() (lock txq->_xmit_lock at some point)
We could add lockdep annotations, but we also can make sure IPv6
calls icmpv6_param_prob() only after the release of the frag queue spinlock,
since this naturally makes frag queue spinlock a leaf in lock hierarchy.
[ Upstream commit b2e54b09a3d29c4db883b920274ca8dca4d9f04d ]
The device type for ip6 tunnels is set to
ARPHRD_TUNNEL6. However, the ip4ip6_err function
is expecting the device type of the tunnel to be
ARPHRD_TUNNEL. Since the device types do not
match, the function exits and the ICMP error
packet is not sent to the originating host. Note
that the device type for IPv4 tunnels is set to
ARPHRD_TUNNEL.
Fix is to expect a tunnel device type of
ARPHRD_TUNNEL6 instead. Now the tunnel device
type matches and the ICMP error packet is sent
Signed-off-by: Sheena Mira-ato <sheena.mira-ato@alliedtelesis.co.nz>
[ Upstream commit bb9bd814ebf04f579be466ba61fc922625508807 ]
ipip6 tunnels run iptunnel_pull_header on received skbs. This can
determine the following use-after-free accessing iph pointer since
the packet will be 'uncloned' running pskb_expand_head if it is a
cloned gso skb (e.g if the packet has been sent though a veth device)
[ 706.369655] BUG: KASAN: use-after-free in ipip6_rcv+0x1678/0x16e0 [sit]
[ 706.449056] Read of size 1 at addr ffffe01b6bd855f5 by task ksoftirqd/1/=
[ 706.669494] Hardware name: HPE ProLiant m400 Server/ProLiant m400 Server, BIOS U02 08/19/2016
[ 706.771839] Call trace:
[ 706.801159] dump_backtrace+0x0/0x2f8
[ 706.845079] show_stack+0x24/0x30
[ 706.884833] dump_stack+0xe0/0x11c
[ 706.925629] print_address_description+0x68/0x260
[ 706.982070] kasan_report+0x178/0x340
[ 707.025995] __asan_report_load1_noabort+0x30/0x40
[ 707.083481] ipip6_rcv+0x1678/0x16e0 [sit]
[ 707.132623] tunnel64_rcv+0xd4/0x200 [tunnel4]
[ 707.185940] ip_local_deliver_finish+0x3b8/0x988
[ 707.241338] ip_local_deliver+0x144/0x470
[ 707.289436] ip_rcv_finish+0x43c/0x14b0
[ 707.335447] ip_rcv+0x628/0x1138
[ 707.374151] __netif_receive_skb_core+0x1670/0x2600
[ 707.432680] __netif_receive_skb+0x28/0x190
[ 707.482859] process_backlog+0x1d0/0x610
[ 707.529913] net_rx_action+0x37c/0xf68
[ 707.574882] __do_softirq+0x288/0x1018
[ 707.619852] run_ksoftirqd+0x70/0xa8
[ 707.662734] smpboot_thread_fn+0x3a4/0x9e8
[ 707.711875] kthread+0x2c8/0x350
[ 707.750583] ret_from_fork+0x10/0x18
[ 707.811302] Allocated by task 16982:
[ 707.854182] kasan_kmalloc.part.1+0x40/0x108
[ 707.905405] kasan_kmalloc+0xb4/0xc8
[ 707.948291] kasan_slab_alloc+0x14/0x20
[ 707.994309] __kmalloc_node_track_caller+0x158/0x5e0
[ 708.053902] __kmalloc_reserve.isra.8+0x54/0xe0
[ 708.108280] __alloc_skb+0xd8/0x400
[ 708.150139] sk_stream_alloc_skb+0xa4/0x638
[ 708.200346] tcp_sendmsg_locked+0x818/0x2b90
[ 708.251581] tcp_sendmsg+0x40/0x60
[ 708.292376] inet_sendmsg+0xf0/0x520
[ 708.335259] sock_sendmsg+0xac/0xf8
[ 708.377096] sock_write_iter+0x1c0/0x2c0
[ 708.424154] new_sync_write+0x358/0x4a8
[ 708.470162] __vfs_write+0xc4/0xf8
[ 708.510950] vfs_write+0x12c/0x3d0
[ 708.551739] ksys_write+0xcc/0x178
[ 708.592533] __arm64_sys_write+0x70/0xa0
[ 708.639593] el0_svc_handler+0x13c/0x298
[ 708.686646] el0_svc+0x8/0xc
[ 708.739019] Freed by task 17:
[ 708.774597] __kasan_slab_free+0x114/0x228
[ 708.823736] kasan_slab_free+0x10/0x18
[ 708.868703] kfree+0x100/0x3d8
[ 708.905320] skb_free_head+0x7c/0x98
[ 708.948204] skb_release_data+0x320/0x490
[ 708.996301] pskb_expand_head+0x60c/0x970
[ 709.044399] __iptunnel_pull_header+0x3b8/0x5d0
[ 709.098770] ipip6_rcv+0x41c/0x16e0 [sit]
[ 709.146873] tunnel64_rcv+0xd4/0x200 [tunnel4]
[ 709.200195] ip_local_deliver_finish+0x3b8/0x988
[ 709.255596] ip_local_deliver+0x144/0x470
[ 709.303692] ip_rcv_finish+0x43c/0x14b0
[ 709.349705] ip_rcv+0x628/0x1138
[ 709.388413] __netif_receive_skb_core+0x1670/0x2600
[ 709.446943] __netif_receive_skb+0x28/0x190
[ 709.497120] process_backlog+0x1d0/0x610
[ 709.544169] net_rx_action+0x37c/0xf68
[ 709.589131] __do_softirq+0x288/0x1018
[ 709.651938] The buggy address belongs to the object at ffffe01b6bd85580
which belongs to the cache kmalloc-1024 of size 1024
[ 709.804356] The buggy address is located 117 bytes inside of
1024-byte region [ffffe01b6bd85580, ffffe01b6bd85980)
[ 709.946340] The buggy address belongs to the page:
[ 710.003824] page:ffff7ff806daf600 count:1 mapcount:0 mapping:ffffe01c4001f600 index:0x0
[ 710.099914] flags: 0xfffff8000000100(slab)
[ 710.149059] raw: 0fffff8000000100 dead000000000100 dead000000000200 ffffe01c4001f600
[ 710.242011] raw: 0000000000000000 0000000000380038 00000001ffffffff 0000000000000000
[ 710.334966] page dumped because: kasan: bad access detected
Fix it resetting iph pointer after iptunnel_pull_header
Fixes: a09a4c8dd1ec ("tunnels: Remove encapsulation offloads on decap")
Tested-by: Jianlin Shi <jishi@redhat.com>
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit ef0efcd3bd3fd0589732b67fb586ffd3c8705806 ]
At the beginning of ip6_fragment func, the prevhdr pointer is
obtained in the ip6_find_1stfragopt func.
However, all the pointers pointing into skb header may change
when calling skb_checksum_help func with
skb->ip_summed = CHECKSUM_PARTIAL condition.
The prevhdr pointe will be dangling if it is not reloaded after
calling __skb_linearize func in skb_checksum_help func.
Here, I add a variable, nexthdr_offset, to evaluate the offset,
which does not changes even after calling __skb_linearize func.
Fixes: 405c92f7a541 ("ipv6: add defensive check for CHECKSUM_PARTIAL skbs in ip_fragment")
Signed-off-by: Junwei Hu <hujunwei4@huawei.com>
Reported-by: Wenhao Zhang <zhangwenhao8@huawei.com>
Reported-by: syzbot+e8ce541d095e486074fc@syzkaller.appspotmail.com
Reviewed-by: Zhiqiang Liu <liuzhiqiang26@huawei.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit 09db51241118aeb06e1c8cd393b45879ce099b36 ]
On ESP output, sk_wmem_alloc is incremented for the added padding if a
socket is associated to the skb. When replying with TCP SYNACKs over
IPsec, the associated sk is a casted request socket, only. Increasing
sk_wmem_alloc on a request socket results in a write at an arbitrary
struct offset. In the best case, this produces the following WARNING:
WARNING: CPU: 1 PID: 0 at lib/refcount.c:102 esp_output_head+0x2e4/0x308 [esp4]
refcount_t: addition on 0; use-after-free.
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.0.0-rc3 #2
Hardware name: Marvell Armada 380/385 (Device Tree)
[<bf0ff354>] (esp_output_head [esp4]) from [<bf1006a4>] (esp_output+0xb8/0x180 [esp4])
[<bf1006a4>] (esp_output [esp4]) from [<c05dee64>] (xfrm_output_resume+0x558/0x664)
[<c05dee64>] (xfrm_output_resume) from [<c05d07b0>] (xfrm4_output+0x44/0xc4)
[<c05d07b0>] (xfrm4_output) from [<c05956bc>] (tcp_v4_send_synack+0xa8/0xe8)
[<c05956bc>] (tcp_v4_send_synack) from [<c0586ad8>] (tcp_conn_request+0x7f4/0x948)
[<c0586ad8>] (tcp_conn_request) from [<c058c404>] (tcp_rcv_state_process+0x2a0/0xe64)
[<c058c404>] (tcp_rcv_state_process) from [<c05958ac>] (tcp_v4_do_rcv+0xf0/0x1f4)
[<c05958ac>] (tcp_v4_do_rcv) from [<c0598a4c>] (tcp_v4_rcv+0xdb8/0xe20)
[<c0598a4c>] (tcp_v4_rcv) from [<c056eb74>] (ip_protocol_deliver_rcu+0x2c/0x2dc)
[<c056eb74>] (ip_protocol_deliver_rcu) from [<c056ee6c>] (ip_local_deliver_finish+0x48/0x54)
[<c056ee6c>] (ip_local_deliver_finish) from [<c056eecc>] (ip_local_deliver+0x54/0xec)
[<c056eecc>] (ip_local_deliver) from [<c056efac>] (ip_rcv+0x48/0xb8)
[<c056efac>] (ip_rcv) from [<c0519c2c>] (__netif_receive_skb_one_core+0x50/0x6c)
The issue triggers only when not using TCP syncookies, as for syncookies
no socket is associated.
Fixes: cac2661c53f3 ("esp4: Avoid skb_cow_data whenever possible")
Fixes: 03e2a30f6a27 ("esp6: Avoid skb_cow_data whenever possible")
Signed-off-by: Martin Willi <martin@strongswan.org>
[ Upstream commit 97f0082a0592212fc15d4680f5a4d80f79a1687c ]
Set rtm_table to RT_TABLE_COMPAT for ipv6 for tables > 255 to
keep legacy software happy. This is similar to what was done for
ipv4 in commit 709772e6e065 ("net: Fix routing tables with
id > 255 for legacy software").
Signed-off-by: Kalash Nainwal <kalash@arista.com>
[ Upstream commit a843dc4ebaecd15fca1f4d35a97210f72ea1473b ]
In func check_6rd,tunnel->ip6rd.relay_prefixlen may equal to
32,so UBSAN complain about it.
UBSAN: Undefined behaviour in net/ipv6/sit.c:781:47
shift exponent 32 is too large for 32-bit type 'unsigned int'
CPU: 6 PID: 20036 Comm: syz-executor.0 Not tainted 4.19.27 #2
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1
04/01/2014
Call Trace:
dump_stack+0xca/0x13e lib/dump_stack.c:113
ubsan_epilogue+0xe/0x81 lib/ubsan.c:159
__ubsan_handle_shift_out_of_bounds+0x293/0x2e8 lib/ubsan.c:425
check_6rd.constprop.9+0x433/0x4e0 net/ipv6/sit.c:781
try_6rd net/ipv6/sit.c:806 [inline]
ipip6_tunnel_xmit net/ipv6/sit.c:866 [inline]
sit_tunnel_xmit+0x141c/0x2720 net/ipv6/sit.c:1033
__netdev_start_xmit include/linux/netdevice.h:4300 [inline]
netdev_start_xmit include/linux/netdevice.h:4309 [inline]
xmit_one net/core/dev.c:3243 [inline]
dev_hard_start_xmit+0x17c/0x780 net/core/dev.c:3259
__dev_queue_xmit+0x1656/0x2500 net/core/dev.c:3829
neigh_output include/net/neighbour.h:501 [inline]
ip6_finish_output2+0xa36/0x2290 net/ipv6/ip6_output.c:120
ip6_finish_output+0x3e7/0xa20 net/ipv6/ip6_output.c:154
NF_HOOK_COND include/linux/netfilter.h:278 [inline]
ip6_output+0x1e2/0x720 net/ipv6/ip6_output.c:171
dst_output include/net/dst.h:444 [inline]
ip6_local_out+0x99/0x170 net/ipv6/output_core.c:176
ip6_send_skb+0x9d/0x2f0 net/ipv6/ip6_output.c:1697
ip6_push_pending_frames+0xc0/0x100 net/ipv6/ip6_output.c:1717
rawv6_push_pending_frames net/ipv6/raw.c:616 [inline]
rawv6_sendmsg+0x2435/0x3530 net/ipv6/raw.c:946
inet_sendmsg+0xf8/0x5c0 net/ipv4/af_inet.c:798
sock_sendmsg_nosec net/socket.c:621 [inline]
sock_sendmsg+0xc8/0x110 net/socket.c:631
___sys_sendmsg+0x6cf/0x890 net/socket.c:2114
__sys_sendmsg+0xf0/0x1b0 net/socket.c:2152
do_syscall_64+0xc8/0x580 arch/x86/entry/common.c:290
Signed-off-by: linmiaohe <linmiaohe@huawei.com>
[ Upstream commit e3818541b49fb88650ba339d33cc53e4095da5b3 ]
IPv6 currently does not support nexthops outside of the AF_INET6 family.
Specifically, it does not handle RTA_VIA attribute. If it is passed
in a route add request, the actual route added only uses the device
which is clearly not what the user intended:
$ ip -6 ro add 2001:db8:2::/64 via inet 172.16.1.1 dev eth0
$ ip ro ls
2001:db8:2::/64 dev eth0 metric 1024 pref medium
Catch this and fail the route add:
Error: IPv6 does not support RTA_VIA attribute.
Fixes: 03c0566542f4c ("mpls: Netlink commands to add, remove, and dump routes")
[ Upstream commit 07f12b26e21ab359261bf75cfcb424fdc7daeb6d ]
If register_netdev() is failed to register sitn->fb_tunnel_dev,
it will go to err_reg_dev and forget to free netdev(sitn->fb_tunnel_dev).
BUG: memory leak
unreferenced object 0xffff888378daad00 (size 512):
comm "syz-executor.1", pid 4006, jiffies 4295121142 (age 16.115s)
00 e6 ed c0 83 88 ff ff 00 00 00 00 00 00 00 00 ................
backtrace:
[<00000000d6dcb63e>] kvmalloc include/linux/mm.h:577 [inline]
[<00000000d6dcb63e>] kvzalloc include/linux/mm.h:585 [inline]
[<00000000d6dcb63e>] netif_alloc_netdev_queues net/core/dev.c:8380 [inline]
[<00000000d6dcb63e>] alloc_netdev_mqs+0x600/0xcc0 net/core/dev.c:8970
[<00000000867e172f>] sit_init_net+0x295/0xa40 net/ipv6/sit.c:1848
[<00000000871019fa>] ops_init+0xad/0x3e0 net/core/net_namespace.c:129
[<00000000319507f6>] setup_net+0x2ba/0x690 net/core/net_namespace.c:314
[<0000000087db4f96>] copy_net_ns+0x1dc/0x330 net/core/net_namespace.c:437
[<0000000057efc651>] create_new_namespaces+0x382/0x730 kernel/nsproxy.c:107
[<00000000676f83de>] copy_namespaces+0x2ed/0x3d0 kernel/nsproxy.c:165
[<0000000030b74bac>] copy_process.part.27+0x231e/0x6db0 kernel/fork.c:1919
[<00000000fff78746>] copy_process kernel/fork.c:1713 [inline]
[<00000000fff78746>] _do_fork+0x1bc/0xe90 kernel/fork.c:2224
[<000000001c2e0d1c>] do_syscall_64+0xc8/0x580 arch/x86/entry/common.c:290
[<00000000ec48bd44>] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[<0000000039acff8a>] 0xffffffffffffffff
Signed-off-by: Mao Wenan <maowenan@huawei.com>
[ Upstream commit 87c11f1ddbbad38ad8bad47af133a8208985fbdf ]
Similar to commit 44f49dd8b5a6 ("ipmr: fix possible race resulting from
improper usage of IP_INC_STATS_BH() in preemptible context."), we cannot
assume preemption is disabled when incrementing the counter and
accessing a per-CPU variable.
Preemption can be enabled when we add a route in process context that
corresponds to packets stored in the unresolved queue, which are then
forwarded using this route [1].
Fix this by using IP6_INC_STATS() which takes care of disabling
preemption on architectures where it is needed.
[1]
[ 157.451447] BUG: using __this_cpu_add() in preemptible [00000000] code: smcrouted/2314
[ 157.460409] caller is ip6mr_forward2+0x73e/0x10e0
[ 157.460434] CPU: 3 PID: 2314 Comm: smcrouted Not tainted 5.0.0-rc7-custom-03635-g22f2712113f1 #1336
[ 157.460449] Hardware name: Mellanox Technologies Ltd. MSN2100-CB2FO/SA001017, BIOS 5.6.5 06/07/2016
[ 157.460461] Call Trace:
[ 157.460486] dump_stack+0xf9/0x1be
[ 157.460553] check_preemption_disabled+0x1d6/0x200
[ 157.460576] ip6mr_forward2+0x73e/0x10e0
[ 157.460705] ip6_mr_forward+0x9a0/0x1510
[ 157.460771] ip6mr_mfc_add+0x16b3/0x1e00
[ 157.461155] ip6_mroute_setsockopt+0x3cb/0x13c0
[ 157.461384] do_ipv6_setsockopt.isra.8+0x348/0x4060
[ 157.462013] ipv6_setsockopt+0x90/0x110
[ 157.462036] rawv6_setsockopt+0x4a/0x120
[ 157.462058] __sys_setsockopt+0x16b/0x340
[ 157.462198] __x64_sys_setsockopt+0xbf/0x160
[ 157.462220] do_syscall_64+0x14d/0x610
[ 157.462349] entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fixes: 0912ea38de61 ("[IPV6] MROUTE: Add stats in multicast routing module method ip6_mr_forward().")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Amit Cohen <amitc@mellanox.com>
