path: root/net/ipv6
2006-04-24[PATCH] IPV6: XFRM: Fix decoding session with preceding extension header(s).YOSHIFUJI Hideaki / 吉藤英明
[IPV6] XFRM: Fix decoding session with preceding extension header(s). We did not correctly decode session with preceding extension header(s). This was because we had already pulled preceding headers, skb->nh.raw + 40 + 1 - skb->data was minus, and pskb_may_pull() failed. We now have IP6CB(skb)->nhoff and skb->h.raw, and we can start parsing / decoding upper layer protocol from current position. Tracked down by Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> and tested by Kazunori Miyazawa <kazunori@miyazawa.org>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-24[PATCH] IPV6: XFRM: Don't use old copy of pointer after pskb_may_pull().YOSHIFUJI Hideaki / 吉藤英明
[IPV6] XFRM: Don't use old copy of pointer after pskb_may_pull(). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-24[PATCH] IPV6: Ensure to have hop-by-hop options in our header of &sk_buff.YOSHIFUJI Hideaki / 吉藤英明
[IPV6]: Ensure to have hop-by-hop options in our header of &sk_buff. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-13[TCP]: Fix zero port problem in IPv6Herbert Xu
When we link a socket into the hash table, we need to make sure that we set the num/port fields so that it shows us with a non-zero port value in proc/netlink and on the wire. This code and comment is copied over from the IPv4 stack as is. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-03-12[IPV4/6]: Fix UFO error propagationPatrick McHardy
When ufo_append_data fails err is uninitialized, but returned back. Strangely gcc doesn't notice it. Coverity #901 and #902 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-12[XFRM]: Fix leak in ah6_inputPatrick McHardy
tmp_hdr is not freed when ipv6_clear_mutable_options fails. Coverity #650 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-11[IPV6]: fix ipv6_saddr_score struct elementBrian Haley
The scope element in the ipv6_saddr_score struct used in ipv6_dev_get_saddr() is an unsigned integer, but __ipv6_addr_src_scope() returns a signed integer (and can return -1). Signed-off-by: Brian Haley <brian.haley@hp.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-07[NETFILTER] ip_queue: Fix wrong skb->len == nlmsg_len assumptionThomas Graf
The size of the skb carrying the netlink message is not equivalent to the length of the actual netlink message due to padding. ip_queue matches the length of the payload against the original packet size to determine if packet mangling is desired, due to the above wrong assumption arbitary packets may not be mangled depening on their original size. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-27[NETFILTER]: Restore {ipt,ip6t,ebt}_LOG compatibilityPatrick McHardy
The nfnetlink_log infrastructure changes broke compatiblity of the LOG targets. They currently use whatever log backend was registered first, which means that if ipt_ULOG was loaded first, no messages will be printed to the ring buffer anymore. Restore compatiblity by using the old log functions by default and only use the nf_log backend if the user explicitly said so. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-24[IPV6]: Do not ignore IPV6_MTU socket option.YOSHIFUJI Hideaki
Based on patch by Hoerdt Mickael <hoerdt@clarinet.u-strasbg.fr>. Signed-off-by: YOSHIFUJI Hideaki <yosufuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-24[IPV6] ip6_tunnel: release cached dst on change of tunnel paramsHugo Santos
The included patch fixes ip6_tunnel to release the cached dst entry when the tunnel parameters (such as tunnel endpoints) are changed so they are used immediatly for the next encapsulated packets. Signed-off-by: Hugo Santos <hsantos@av.it.pt> Acked-by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-18[PATCH] missing ntohs() in ip6_tunnelAl Viro
->payload_len is net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-15[NETFILTER]: nf_conntrack: attach conntrack to locally generated ICMPv6 errorYasuyuki Kozakai
Locally generated ICMPv6 errors should be associated with the conntrack of the original packet. Since the conntrack entry may not be in the hash tables (for the first packet), it must be manually attached. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-15[NETFILTER]: nf_conntrack: attach conntrack to TCP RST generated by ip6t_REJECTYasuyuki Kozakai
TCP RSTs generated by the REJECT target should be associated with the conntrack of the original TCP packet. Since the conntrack entry is usually not is the hash tables, it must be manually attached. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-13[IPV6] Don't store dst_entry for RAW socketNicolas DICHTEL
Signed-off-by: Nicolas DICHTEL <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-08[IPV6]: Address autoconfiguration does not work after device down/up cycleKristian Slavov
If you set network interface down and up again, the IPv6 address autoconfiguration does not work. 'ip addr' shows that the link-local address is in tentative state. We don't even react to periodical router advertisements. During NETDEV_DOWN we clear IF_READY, and we don't set it back in NETDEV_UP. While starting to perform DAD on the link-local address, we notice that the device is not in IF_READY, and we abort autoconfiguration process (which would eventually send router solicitations). Acked-by: Juha-Matti Tapio <jmtapio@verkkotelakka.net> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-07[PATCH] net/ipv6/mcast.c NULL noise removalAl Viro
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-05Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2006-02-05[PATCH] percpu data: only iterate over possible CPUsEric Dumazet
percpu_data blindly allocates bootmem memory to store NR_CPUS instances of cpudata, instead of allocating memory only for possible cpus. As a preparation for changing that, we need to convert various 0 -> NR_CPUS loops to use for_each_cpu(). (The above only applies to users of asm-generic/percpu.h. powerpc has gone it alone and is presently only allocating memory for present CPUs, so it's currently corrupting memory). Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jens Axboe <axboe@suse.de> Cc: Anton Blanchard <anton@samba.org> Acked-by: William Irwin <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-04[NETFILTER]: Prepare {ipt,ip6t}_policy match for x_tables unificationPatrick McHardy
The IPv4 and IPv6 version of the policy match are identical besides address comparison and the data structure used for userspace communication. Unify the data structures to break compatiblity now (before it is released), so we can port it to x_tables in 2.6.17. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-04[NETFILTER]: Fix ip6t_policy address matchingPatrick McHardy
Fix two bugs in ip6t_policy address matching: - misorder arguments to ip6_masked_addrcmp, mask must be the second argument - inversion incorrectly applied to the entire expression instead of just the address comparison Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-04[NETFILTER]: Check policy length in policy match strict modePatrick McHardy
2006-02-04[NETFILTER]: Fix possible overflow in netfilters do_replace()Kirill Korotaev
netfilter's do_replace() can overflow on addition within SMP_ALIGN() and/or on multiplication by NR_CPUS, resulting in a buffer overflow on the copy_from_user(). In practice, the overflow on addition is triggerable on all systems, whereas the multiplication one might require much physical memory to be present due to the check above. Either is sufficient to overwrite arbitrary amounts of kernel memory. I really hate adding the same check to all 4 versions of do_replace(), but the code is duplicate... Found by Solar Designer during security audit of OpenVZ.org Signed-Off-By: Kirill Korotaev <dev@openvz.org> Signed-Off-By: Solar Designer <solar@openwall.com> Signed-off-by: Patrck McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-02[IPV6]: Fix illegal dst locking in softirq context.Herbert Xu
On Tue, Jan 31, 2006 at 10:24:32PM +0100, Ingo Molnar wrote: > > [<c04de9e8>] _write_lock+0x8/0x10 > [<c0499015>] inet6_destroy_sock+0x25/0x100 > [<c04b8672>] tcp_v6_destroy_sock+0x12/0x20 > [<c046bbda>] inet_csk_destroy_sock+0x4a/0x150 > [<c047625c>] tcp_rcv_state_process+0xd4c/0xdd0 > [<c047d8e9>] tcp_v4_do_rcv+0xa9/0x340 > [<c047eabb>] tcp_v4_rcv+0x8eb/0x9d0 OK this is definitely broken. We should never touch the dst lock in softirq context. Since inet6_destroy_sock may be called from that context due to the asynchronous nature of sockets, we can't take the lock there. In fact this sk_dst_reset is totally redundant since all IPv6 sockets use inet_sock_destruct as their socket destructor which always cleans up the dst anyway. So the solution is to simply remove the call. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-02[IPV6]: Don't hold extra ref count in ipv6_ifa_notifyHerbert Xu
Currently the logic in ipv6_ifa_notify is to hold an extra reference count for addrconf dst's that get added to the routing table. Thus, when addrconf dst entries are taken out of the routing table, we need to drop that dst. However, addrconf dst entries may be removed from the routing table by means other than __ipv6_ifa_notify. So we're faced with the choice of either fixing up all places where addrconf dst entries are removed, or dropping the extra reference count altogether. I chose the latter because the ifp itself always holds a dst reference count of 1 while it's alive. This is dropped just before we kfree the ifp object. Therefore we know that in __ipv6_ifa_notify we will always hold that count. This bug was found by Eric W. Biederman. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-31[IPV6] tcp_v6_send_synack: release the destinationEric W. Biederman
This patch fix dst reference counting in tcp_v6_send_synack Analysis: Currently tcp_v6_send_synack is never called with a dst entry so dst always comes in as NULL. ip6_dst_lookup calls ip6_route_output which calls dst_hold before it returns the dst entry. Neither xfrm_lookup nor tcp_make_synack consume the dst entry so we still have a dst_entry with a bumped refrence count at the end of this function. Therefore we need to call dst_release just before we return just like tcp_v4_send_synack does. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-24[IPV6] MLDv2: fix change records when transitioning to/from inactiveDavid L Stevens
The following patch fixes these problems in MLDv2: 1) Add/remove "delete" records for sending change reports when addition of a filter results in that filter transitioning to/from inactive. [same as recent IPv4 IGMPv3 fix] 2) Remove 2 redundant "group_type" checks (can't be IPV6_ADDR_ANY within that loop, so checks are always true) 3) change an is_in() "return 0" to "return type == MLD2_MODE_IS_INCLUDE". It should always be "0" to get here, but it improves code locality to not assume it, and if some race allowed otherwise, doing the check would return the correct result. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[NETFILTER] ip6tables: whitespace and indent cosmetic cleanupYasuyuki Kozakai
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[NETFILTER] Makefile cleanupYasuyuki Kozakai
These are replaced with x_tables matches and no longer exist. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[NETFILTER] ip[6]t_policy: Fix compilation warningsBenoit Boissinot
ip[6]t_policy argument conversion slipped when merging with x_tables Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[IPV6]: Preserve procfs IPV6 address output formatYOSHIFUJI Hideaki
Procfs always output IPV6 addresses without the colon characters, and we cannot change that. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-13[XFRM]: IPsec tunnel wildcard address supportPatrick McHardy
When the source address of a tunnel is given as 0.0.0.0 do a routing lookup to get the real source address for the destination and fill that into the acquire message. This allows to specify policies like this: spdadd 172.16.128.13/32 172.16.0.0/20 any -P out ipsec esp/tunnel/0.0.0.0-x.x.x.x/require; spdadd 172.16.0.0/20 172.16.128.13/32 any -P in ipsec esp/tunnel/x.x.x.x-0.0.0.0/require; Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-13[NET]: Use NIP6_FMT in kernel.hJoe Perches
There are errors and inconsistency in the display of NIP6 strings. ie: net/ipv6/ip6_flowlabel.c There are errors and inconsistency in the display of NIPQUAD strings too. ie: net/netfilter/nf_conntrack_ftp.c This patch: adds NIP6_FMT to kernel.h changes all code to use NIP6_FMT fixes net/ipv6/ip6_flowlabel.c adds NIPQUAD_FMT to kernel.h fixes net/netfilter/nf_conntrack_ftp.c changes a few uses of "%u.%u.%u.%u" to NIPQUAD_FMT for symmetry to NIP6_FMT Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-12[NETFILTER] x_tables: Abstraction layer for {ip,ip6,arp}_tablesHarald Welte
This monster-patch tries to do the best job for unifying the data structures and backend interfaces for the three evil clones ip_tables, ip6_tables and arp_tables. In an ideal world we would never have allowed this kind of copy+paste programming... but well, our world isn't (yet?) ideal. o introduce a new x_tables module o {ip,arp,ip6}_tables depend on this x_tables module o registration functions for tables, matches and targets are only wrappers around x_tables provided functions o all matches/targets that are used from ip_tables and ip6_tables are now implemented as xt_FOOBAR.c files and provide module aliases to ipt_FOOBAR and ip6t_FOOBAR o header files for xt_matches are in include/linux/netfilter/, include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers around the xt_FOOBAR.h headers Based on this patchset we're going to further unify the code, gradually getting rid of all the layer 3 specific assumptions. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[NET]: Remove more unneeded typecasts on *malloc()Kris Katterjohn
This removes more unneeded casts on the return value for kmalloc(), sock_kmalloc(), and vmalloc(). Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[IPV6]: Avoid calling ip6_xmit() with NULL skDavid Woodhouse
The ip6_xmit() function now assumes that its sk argument is non-NULL, which isn't currently true when TCPv6 code is sending RST or ACK packets. This fixes that code to use a socket of its own for sending such packets, as TCPv4 does. (Thanks Andi for the pointer). Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[NET]: Some more missing include/etherdevice.h includesDavid S. Miller
For compare_ether_addr() Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[IPV6]: Fix modular build with netfilter enabled.David S. Miller
Also, drop __exit marker from ipv6_netfilter_fini() as this can be invoked from inet6_init() error handling paths. Based upon a report from Stephen Hemminger. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: Fix timeout sysctls on big-endian 64bit architecturesPatrick McHardy
The connection tracking timeout variables are unsigned long, but proc_dointvec_jiffies is used with sizeof(unsigned int) in the sysctl tables. Since there is no proc_doulongvec_jiffies function, change the timeout variables to unsigned int. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: net/ipv[46]/netfilter.c cleanupsPatrick McHardy
Don't wrap entire file in #ifdef CONFIG_NETFILTER, remove a few unneccessary includes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NET]: Change memcmp(,,ETH_ALEN) to compare_ether_addr()Kris Katterjohn
This changes some memcmp(one,two,ETH_ALEN) to compare_ether_addr(one,two). Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[IPV6]: Set skb->priority in ip6_output.cPatrick McHardy
Set skb->priority = sk->sk_priority as in raw.c and IPv4. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[NET]: Convert net/{ipv4,ipv6,sched} to netdev_privPatrick McHardy
2006-01-08[PATCH] slab: remove unused align parameter from alloc_percpuPekka Enberg
__alloc_percpu and alloc_percpu both take an 'align' argument which is completely ignored. snmp6_mib_init() in net/ipv6/af_inet6.c attempts to use it, but it will be ignored. Therefore, remove the 'align' argument and fixup the lone caller. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Acked-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-07[IPV6]: small cleanupsAdrian Bunk
This patch contains the following cleanups: - addrconf.c: make addrconf_dad_stop() static - inet6_connection_sock.c should #include <net/inet6_connection_sock.h> for getting the prototypes of it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[NETFILTER]: Add ipt_policy/ip6t_policy matchesPatrick McHardy
2006-01-07[NETFILTER]: Fix xfrm lookup in ip_route_me_harder/ip6_route_me_harderPatrick McHardy
ip_route_me_harder doesn't use the port numbers of the xfrm lookup and uses ip_route_input for non-local addresses which doesn't do a xfrm lookup, ip6_route_me_harder doesn't do a xfrm lookup at all. Use xfrm_decode_session and do the lookup manually, make sure both only do the lookup if the packet hasn't been transformed already. Makeing sure the lookup only happens once needs a new field in the IP6CB, which exceeds the size of skb->cb. The size of skb->cb is increased to 48b. Apparently the IPv6 mobile extensions need some more room anyway. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV4]: reset IPCB flags when neccessaryPatrick McHardy
Reset IPSKB_XFRM_TUNNEL_SIZE flags in ipip and ip_gre hard_start_xmit function before the packet reenters IP. This is neccessary so the encapsulated packets are checked not to be oversized in xfrm4_output.c again. Reset all flags in sit when a packet changes its address family. Also remove some obsolete IPSKB flags. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
