path: root/net/ipx
2014-02-12ipx: implement shutdown()Sabrina Dubroca
IPX doesn't implement shutdown, which poses a problem to some users: https://bugzilla.kernel.org/show_bug.cgi?id=67841 This patch is heavily based on the shutdown implementation for unix sockets. Reported-by: Bruno Jesus <00cpxxx@gmail.com> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/net_namespace.h ↵Rashika Kheria
from net/ipx/af_ipx.c Move prototype declaration of function to header file include/net/net_namespace.h from net/ipx/af_ipx.c because they are used by more than one file. This eliminates the following warning in net/ipx/sysctl_net_ipx.c: net/ipx/sysctl_net_ipx.c:33:6: warning: no previous prototype for ‘ipx_register_sysctl’ [-Wmissing-prototypes] net/ipx/sysctl_net_ipx.c:38:6: warning: no previous prototype for ‘ipx_unregister_sysctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/datalink.h from ↵Rashika Kheria
net/ipx/af_ipx.c Move prototype declarations of function to header file include/net/datalink.h from net/ipx/af_ipx.c because they are used by more than one file. This eliminates the following warning in net/ipx/pe2.c: net/ipx/pe2.c:20:24: warning: no previous prototype for ‘make_EII_client’ [-Wmissing-prototypes] net/ipx/pe2.c:32:6: warning: no previous prototype for ‘destroy_EII_client’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/ipx.h from ↵Rashika Kheria
net/ipx/af_ipx.c Move prototype declaration of functions to header file include/net/ipx.h from net/ipx/af_ipx.c because they are used by more than one file. This eliminates the following warning in net/ipx/ipx_route.c:33:19: warning: no previous prototype for ‘ipxrtr_lookup’ [-Wmissing-prototypes] net/ipx/ipx_route.c:52:5: warning: no previous prototype for ‘ipxrtr_add_route’ [-Wmissing-prototypes] net/ipx/ipx_route.c:94:6: warning: no previous prototype for ‘ipxrtr_del_routes’ [-Wmissing-prototypes] net/ipx/ipx_route.c:149:5: warning: no previous prototype for ‘ipxrtr_route_skb’ [-Wmissing-prototypes] net/ipx/ipx_route.c:171:5: warning: no previous prototype for ‘ipxrtr_route_packet’ [-Wmissing-prototypes] net/ipx/ipx_route.c:261:5: warning: no previous prototype for ‘ipxrtr_ioctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to include/net/ipx.h from net/ipx/ipx_route.cRashika Kheria
Move prototype definition of function to header file include/net/ipx.h from net/ipx/ipx_route.c because they are used by more than one file. This eliminates the following warning from net/ipx/af_ipx.c: net/ipx/af_ipx.c:193:23: warning: no previous prototype for ‘ipxitf_find_using_net’ [-Wmissing-prototypes] net/ipx/af_ipx.c:577:5: warning: no previous prototype for ‘ipxitf_send’ [-Wmissing-prototypes] net/ipx/af_ipx.c:1219:8: warning: no previous prototype for ‘ipx_cksum’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-15net: proc_fs: trivial: print UIDs as unsigned intFrancesco Fusco
UIDs are printed in the proc_fs as signed int, whereas they are unsigned int. Signed-off-by: Francesco Fusco <ffusco@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-14userns: Print out socket uids in a user namespace aware fashion.Eric W. Biederman
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Sridhar Samudrala <sri@us.ibm.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-19ipx: move peII functionsstephen hemminger
The Ethernet II wrapper is only used by IPX protocol, may have once been used by Appletalk but not currently. Therefore it makes sense to move it to the IPX dust bin and drop the exports. Build tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-19ipx: Remove spurious NULL checking in ipx_ioctl().David S. Miller
We already unconditionally dereference 'sk' via lock_sock(sk) earlier in this function, and our caller (sock_do_ioctl()) makes takes similar liberties. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-15net: delete all instances of special processing for token ringPaul Gortmaker
We are going to delete the Token ring support. This removes any special processing in the core networking for token ring, (aside from net/tr.c itself), leaving the drivers and remaining tokenring support present but inert. The mass removal of the drivers and net/tr.c will be in a separate commit, so that the history of these files that we still care about won't have the giant deletion tied into their history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-21ipx: fix ipx_release()Eric Dumazet
Commit b0d0d915d1d1a0 (remove the BKL) added a regression, because sock_put() can free memory while we are going to use it later. Fix is to delay sock_put() _after_ release_sock(). Reported-by: Ingo Molnar <mingo@elte.hu> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-05ipx: remove the BKLArnd Bergmann
This replaces all instances of lock_kernel in the IPX code with lock_sock. As far as I can tell, this is safe to do, because there is no global state that needs to be locked in IPX, and the code does not recursively take the lock or sleep indefinitely while holding it. Compile-tested only. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: netdev@vger.kernel.org
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-10net: ipx: use seq_list_foo() helpersLi Zefan
Simplify seq_file code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-07net/ipx: push down BKL into a ipx_dgram_opsArnd Bergmann
Making the BKL usage explicit in ipx makes it more obvious where it is used, reduces code size and helps getting rid of the BKL in common code. I did not analyse how to kill lock_kernel from ipx entirely, this will involve either proving that it's not needed, or replacing with a proper mutex or spinlock, after finding out which data structures are protected by the lock. Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: David S. Miller <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: netdev@vger.kernel.org Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21ipx: use constant for strings and desciptorStephen Hemminger
Fix compiler warning about non-const format string. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-28[IPX]: Use proc_create() to setup ->proc_fops firstWang Chen
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Simple ctl_table to ctl_path conversions.Pavel Emelyanov
This patch includes many places, that only required replacing the ctl_table-s with appropriate ctl_paths and call register_sysctl_paths(). Nothing special was done with them. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[IPX]: Use existing sock refcnt debugging infrastructurePavel Emelyanov
Just like in the af_packet.c, the ipx_sock_nr variable is used for debugging purposes. Switch to using existing infrastructure. Thanks to Arnaldo for pointing this out. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-17Fix incorrect prototype for ipxrtr_route_packet()David Woodhouse
The function ipxrtr_route_packet() takes a 'len' argument of type size_t. However, its prototype in af_ipx.c incorrectly suggests that the corresponding argument is of type 'int' instead. Discovered by building with --combine and letting the compiler see it all at once. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
