path: root/net/irda/af_irda.c
2013-04-08irda: use GFP_KERNEL in irda_connect_response()Mathias Krause
The only call site of irda_connect_response() is irda_accept() -- a function called from user context only. Therefore it has no need for GFP_ATOMIC. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-08irda: use GFP_KERNEL in irda_create()Mathias Krause
irda_create() is called from user context only, therefore has no need for GFP_ATOMIC. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07irda: Fix missing msg_namelen update in irda_recvmsg_dgram()Mathias Krause
The current code does not fill the msg_name member in case it is set. It also does not set the msg_namelen member to 0 and therefore makes net/socket.c leak the local, uninitialized sockaddr_storage variable to userland -- 128 bytes of kernel stack memory. Fix that by simply setting msg_namelen to 0 as obviously nobody cared about irda_recvmsg_dgram() not filling the msg_name in case it was set. Cc: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20net/irda: add missing error path release_sock callKees Cook
This makes sure that release_sock is called for all error conditions in irda_getsockopt. Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Brad Spengler <spender@grsecurity.net> Cc: stable@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-04net: remove redundant check for timer pending state before del_timerYing Xue
As in del_timer() there has already placed a timer_pending() function to check whether the timer to be deleted is pending or not, it's unnecessary to check timer pending state again before del_timer() is called. Signed-off-by: Ying Xue <ying.xue@windriver.com> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-04silence some noisy printks in irdaDave Jones
Fuzzing causes these printks to spew constantly. Changing them to DEBUG statements is consistent with other usage in the file, and makes them disappear when CONFIG_IRDA_DEBUG is disabled. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-16irda: Fix typo in irdaMasanari Iida
Correct spelling typo in irda. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-21irda: use msecs_to_jiffies() rather than manual calculationXi Wang
Also use mod_timer() instead of direct assignment to "expires". Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-16net: Remove casts of void *Joe Perches
Unnecessary casts of void * clutter the code. These are the remainder casts after several specific patches to remove netdev_priv and dev_priv. Done via coccinelle script: $ cat cast_void_pointer.cocci @@ type T; T *pt; void *pv; @@ - pt = (T *)pv; + pt = pv; Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-04-12irda: fix locking unbalance in irda_sendmsgDave Jones
5b40964eadea40509d353318d2c82e8b7bf5e8a5 ("irda: Remove BKL instances from af_irda.c") introduced a path where we have a locking unbalance. If we pass invalid flags, we unlock a socket we never locked, resulting in this... ===================================== [ BUG: bad unlock balance detected! ] ------------------------------------- trinity/20101 is trying to release lock (sk_lock-AF_IRDA) at: [<ffffffffa057f001>] irda_sendmsg+0x207/0x21d [irda] but there are no more locks to release! other info that might help us debug this: no locks held by trinity/20101. stack backtrace: Pid: 20101, comm: trinity Not tainted 2.6.39-rc3+ #3 Call Trace: [<ffffffffa057f001>] ? irda_sendmsg+0x207/0x21d [irda] [<ffffffff81085041>] print_unlock_inbalance_bug+0xc7/0xd2 [<ffffffffa057f001>] ? irda_sendmsg+0x207/0x21d [irda] [<ffffffff81086aca>] lock_release+0xcf/0x18e [<ffffffff813ed190>] release_sock+0x2d/0x155 [<ffffffffa057f001>] irda_sendmsg+0x207/0x21d [irda] [<ffffffff813e9f8c>] __sock_sendmsg+0x69/0x75 [<ffffffff813ea105>] sock_sendmsg+0xa1/0xb6 [<ffffffff81100ca3>] ? might_fault+0x5c/0xac [<ffffffff81086b7c>] ? lock_release+0x181/0x18e [<ffffffff81100cec>] ? might_fault+0xa5/0xac [<ffffffff81100ca3>] ? might_fault+0x5c/0xac [<ffffffff81133b94>] ? fcheck_files+0xb9/0xf0 [<ffffffff813f387a>] ? copy_from_user+0x2f/0x31 [<ffffffff813f3b70>] ? verify_iovec+0x52/0xa6 [<ffffffff813eb4e3>] sys_sendmsg+0x23a/0x2b8 [<ffffffff81086b7c>] ? lock_release+0x181/0x18e [<ffffffff810773c6>] ? up_read+0x28/0x2c [<ffffffff814bec3d>] ? do_page_fault+0x360/0x3b4 [<ffffffff81087043>] ? trace_hardirqs_on_caller+0x10b/0x12f [<ffffffff810458aa>] ? finish_task_switch+0xb2/0xe3 [<ffffffff8104583e>] ? finish_task_switch+0x46/0xe3 [<ffffffff8108364a>] ? trace_hardirqs_off_caller+0x33/0x90 [<ffffffff814bbaf9>] ? retint_swapgs+0x13/0x1b [<ffffffff81087043>] ? trace_hardirqs_on_caller+0x10b/0x12f [<ffffffff810a9dd3>] ? audit_syscall_entry+0x11c/0x148 [<ffffffff8125609e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff814c22c2>] system_call_fastpath+0x16/0x1b Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) ipv4: dont create routes on down devices epic100: hamachi: yellowfin: Fix skb allocation size sundance: Fix oopses with corrupted skb_shared_info Revert "ipv4: Allow configuring subnets as local addresses" USB: mcs7830: return negative if auto negotiate fails irda: prevent integer underflow in IRLMP_ENUMDEVICES tcp: fix listening_get_next() atl1c: Do not use legacy PCI power management mac80211: fix mesh forwarding MAINTAINERS: email address change net: Fix range checks in tcf_valid_offset(). net_sched: sch_sfq: fix allot handling hostap: remove netif_stop_queue from init mac80211/rt2x00: add ieee80211_tx_status_ni() typhoon: memory corruption in typhoon_get_drvinfo() net: Add USB PID for new MOSCHIP USB ethernet controller MCS7832 variant net_sched: always clone skbs ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed. netlink: fix gcc -Wconversion compilation warning asix: add USB ID for Logitec LAN-GTJ U2A ...
2010-12-23irda: prevent integer underflow in IRLMP_ENUMDEVICESDan Rosenberg
If the user-provided len is less than the expected offset, the IRLMP_ENUMDEVICES getsockopt will do a copy_to_user() with a very large size value. While this isn't be a security issue on x86 because it will get caught by the access_ok() check, it may leak large amounts of kernel heap on other architectures. In any event, this patch fixes it. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-11irda: Remove BKL instances from af_irda.cSamuel Ortiz
Most of the times, lock_kernel() was pointless or could simply be replaced by lock_sock(). Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-30irda: Correctly clean up self->ias_obj on irda_bind() failure.David S. Miller
If irda_open_tsap() fails, the irda_bind() code tries to destroy the ->ias_obj object by hand, but does so wrongly. In particular, it fails to a) release the hashbin attached to the object and b) reset the self->ias_obj pointer to NULL. Fix both problems by using irias_delete_object() and explicitly setting self->ias_obj to NULL, just as irda_release() does. Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-07net/irda: push BKL into proto_opsArnd Bergmann
The irda driver uses the BKL implicitly in its protocol operations. Replace the wrapped proto_ops with explicit lock_kernel() calls makes the usage more obvious and shrinks the size of the object code. The calls t lock_kernel() should eventually all be replaced by other serialization methods, which requires finding out The calls t lock_kernel() should eventually all be replaced by other serialization methods, which requires finding out which data actually needs protection. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-09Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-08-06irda: Fix irda_getname() leakEric Dumazet
irda_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-23net: Move rx skb_orphan call to where neededHerbert Xu
In order to get the tun driver to account packets, we need to be able to receive packets with destructors set. To be on the safe side, I added an skb_orphan call for all protocols by default since some of them (IP in particular) cannot handle receiving packets destructors properly. Now it seems that at least one protocol (CAN) expects to be able to pass skb->sk through the rx path without getting clobbered. So this patch attempts to fix this properly by moving the skb_orphan call to where it's actually needed. In particular, I've added it to skb_set_owner_[rw] which is what most users of skb->destructor call. This is actually an improvement for tun too since it means that we only give back the amount charged to the socket when the skb is passed to another socket that will also be charged accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Oliver Hartkopp <olver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03irda: Sock leak on error path in irda_create.Pavel Emelyanov
Bad type/protocol specified result in sk leak. Fix is simple - release the sk if bad values are given, but to make it possible just to call sk_free(), I move some sk initialization a bit lower. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-20[IrDA]: af_irda memory leak fixesJesper Juhl
Here goes an IrDA patch against your latest net-2.6 tree. This patch fixes some af_irda memory leaks. It also checks for irias_new_obect() return value. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08[IRDA]: irda_create() nuke user triggable printkmaximilian attems
easy to trigger as user with sfuzz. irda_create() is quiet on unknown sock->type, match this behaviour for SOCK_DGRAM unknown protocol Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IrDA]: MSG_NOSIGNAL support for IrDA socketsSamuel Ortiz
2007-07-18[IrDA]: Fix IrDA build failureSamuel Ortiz
When having built-in IrDA, we hit the following error: `irda_sysctl_unregister' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irda_proc_unregister' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irsock_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irttp_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `iriap_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irda_device_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irlap_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irlmp_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o make[1]: *** [.tmp_vmlinux1] Error 1 make: *** [_all] Error 2 This is due to the irda_init fix recently added, where we call __exit routines from an __init one. It is a build failure that I didn't catch because it doesn't show up when building IrDA as a module. My apologies for that. The following patch fixes that failure and is against your net-2.6 tree. I hope it can make it to the merge window, and stable@kernel.org is CCed on this mail. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA] af_irda: IRDA_ASSERT cleanupsSamuel Ortiz
In af_irda.c, the multiple IRDA_ASSERT() are either hiding bugs, useless, or returning the wrong value. Let's clean that up. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA] af_irda: irda_accept cleanupSamuel Ortiz
This patch removes a cut'n'paste copy of wait_event_interruptible from irda_accept. Signed-off-by: Samuel Ortiz <samuel@ortiz.org> Acked-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA] af_irda: Silence kernel message in irda_recvmsg_streamOlaf Kirch
This patch silences an IRDA_ASSERT in irda_recvmsg_stream, as described in http://bugzilla.kernel.org/show_bug.cgi?id=7512 irda_disconnect_indication would set sk->sk_err to ECONNRESET, and a subsequent call to recvmsg would print an irritating kernel message and return -1. When a connected socket is closed by the peer, recvmsg should return 0 rather than an error. This patch fixes this. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA] af_irda: irda_recvmsg_stream cleanupOlaf Kirch
This patch cleans up some code in irda_recvmsg_stream, replacing some homebrew code with prepare_to_wait/finish_wait, and by making the code honor sock_rcvtimeo. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: More skb_put related conversions to skb_reset_transport_headerArnaldo Carvalho de Melo
This is similar to the skb_reset_network_header(), i.e. at the point we reset the transport header pointer/offset skb->tail is equal to skb->data. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-18[IrDA]: Correctly handling socket errorOlaf Kirch
This patch fixes an oops first reported in mid 2006 - see http://lkml.org/lkml/2006/8/29/358 The cause of this bug report is that when an error is signalled on the socket, irda_recvmsg_stream returns without removing a local wait_queue variable from the socket's sk_sleep queue. This causes havoc further down the road. In response to this problem, a patch was made that invoked sock_orphan on the socket when receiving a disconnect indication. This is not a good fix, as this sets sk_sleep to NULL, causing applications sleeping in recvmsg (and other places) to oops. This is against the latest net-2.6 and should be considered for -stable inclusion. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IRDA: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IrDA]: Memory allocations cleanupsSamuel Ortiz
This patch replaces the bunch of arbitrary 64 and 128 bytes alloc_skb() calls with more accurate allocation sizes. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IrDA]: af_irda.c cleanupsSamuel Ortiz
We lock the socket when both releasing and getting a disconnected notification. In the latter case, we also ste the socket as orphan. This fixes a potential kernel bug that can be triggered when we get the disconnection notification before closing the socket. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[IrDA]: Use alloc_skb() in IrDA TX pathSamuel Ortiz
As pointed out by Christoph Hellwig, dev_alloc_skb() is not intended to be used for allocating TX sk_buff. The IrDA stack was exclusively calling dev_alloc_skb() on the TX path, and this patch fixes that. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
