path: root/net/irda/af_irda.c
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-09Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-08-06irda: Fix irda_getname() leakEric Dumazet
irda_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-23net: Move rx skb_orphan call to where neededHerbert Xu
In order to get the tun driver to account packets, we need to be able to receive packets with destructors set. To be on the safe side, I added an skb_orphan call for all protocols by default since some of them (IP in particular) cannot handle receiving packets destructors properly. Now it seems that at least one protocol (CAN) expects to be able to pass skb->sk through the rx path without getting clobbered. So this patch attempts to fix this properly by moving the skb_orphan call to where it's actually needed. In particular, I've added it to skb_set_owner_[rw] which is what most users of skb->destructor call. This is actually an improvement for tun too since it means that we only give back the amount charged to the socket when the skb is passed to another socket that will also be charged accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Oliver Hartkopp <olver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03irda: Sock leak on error path in irda_create.Pavel Emelyanov
Bad type/protocol specified result in sk leak. Fix is simple - release the sk if bad values are given, but to make it possible just to call sk_free(), I move some sk initialization a bit lower. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-20[IrDA]: af_irda memory leak fixesJesper Juhl
Here goes an IrDA patch against your latest net-2.6 tree. This patch fixes some af_irda memory leaks. It also checks for irias_new_obect() return value. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08[IRDA]: irda_create() nuke user triggable printkmaximilian attems
easy to trigger as user with sfuzz. irda_create() is quiet on unknown sock->type, match this behaviour for SOCK_DGRAM unknown protocol Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IrDA]: MSG_NOSIGNAL support for IrDA socketsSamuel Ortiz
2007-07-18[IrDA]: Fix IrDA build failureSamuel Ortiz
When having built-in IrDA, we hit the following error: `irda_sysctl_unregister' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irda_proc_unregister' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irsock_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irttp_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `iriap_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irda_device_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irlap_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o `irlmp_cleanup' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o make[1]: *** [.tmp_vmlinux1] Error 1 make: *** [_all] Error 2 This is due to the irda_init fix recently added, where we call __exit routines from an __init one. It is a build failure that I didn't catch because it doesn't show up when building IrDA as a module. My apologies for that. The following patch fixes that failure and is against your net-2.6 tree. I hope it can make it to the merge window, and stable@kernel.org is CCed on this mail. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA] af_irda: IRDA_ASSERT cleanupsSamuel Ortiz
In af_irda.c, the multiple IRDA_ASSERT() are either hiding bugs, useless, or returning the wrong value. Let's clean that up. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA] af_irda: irda_accept cleanupSamuel Ortiz
This patch removes a cut'n'paste copy of wait_event_interruptible from irda_accept. Signed-off-by: Samuel Ortiz <samuel@ortiz.org> Acked-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA] af_irda: Silence kernel message in irda_recvmsg_streamOlaf Kirch
This patch silences an IRDA_ASSERT in irda_recvmsg_stream, as described in http://bugzilla.kernel.org/show_bug.cgi?id=7512 irda_disconnect_indication would set sk->sk_err to ECONNRESET, and a subsequent call to recvmsg would print an irritating kernel message and return -1. When a connected socket is closed by the peer, recvmsg should return 0 rather than an error. This patch fixes this. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA] af_irda: irda_recvmsg_stream cleanupOlaf Kirch
This patch cleans up some code in irda_recvmsg_stream, replacing some homebrew code with prepare_to_wait/finish_wait, and by making the code honor sock_rcvtimeo. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: More skb_put related conversions to skb_reset_transport_headerArnaldo Carvalho de Melo
This is similar to the skb_reset_network_header(), i.e. at the point we reset the transport header pointer/offset skb->tail is equal to skb->data. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-18[IrDA]: Correctly handling socket errorOlaf Kirch
This patch fixes an oops first reported in mid 2006 - see http://lkml.org/lkml/2006/8/29/358 The cause of this bug report is that when an error is signalled on the socket, irda_recvmsg_stream returns without removing a local wait_queue variable from the socket's sk_sleep queue. This causes havoc further down the road. In response to this problem, a patch was made that invoked sock_orphan on the socket when receiving a disconnect indication. This is not a good fix, as this sets sk_sleep to NULL, causing applications sleeping in recvmsg (and other places) to oops. This is against the latest net-2.6 and should be considered for -stable inclusion. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IRDA: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IrDA]: Memory allocations cleanupsSamuel Ortiz
This patch replaces the bunch of arbitrary 64 and 128 bytes alloc_skb() calls with more accurate allocation sizes. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IrDA]: af_irda.c cleanupsSamuel Ortiz
We lock the socket when both releasing and getting a disconnected notification. In the latter case, we also ste the socket as orphan. This fixes a potential kernel bug that can be triggered when we get the disconnection notification before closing the socket. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[IrDA]: Use alloc_skb() in IrDA TX pathSamuel Ortiz
As pointed out by Christoph Hellwig, dev_alloc_skb() is not intended to be used for allocating TX sk_buff. The IrDA stack was exclusively calling dev_alloc_skb() on the TX path, and this patch fixes that. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[NET]: Fix ipx/econet/appletalk/irda ioctl crashesPetr Vandrovec
Fix kernel oopses whenever somebody issues compatible ioctl on AppleTalk, Econet, IPX or IRDA socket. For AppleTalk/Econet/IRDA it restores state in which these sockets were before compat_ioctl was introduced to the socket ops, for IPX it implements support for 4 ioctls which were not implemented before - as these ioctls use structures which match between 32bit and 64bit userspace, no special code is needed, just call 64bit ioctl handler. Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[PATCH] Typo fixesAlexey Dobriyan
Fix a lot of typos. Eyeballed by jmc@ in OpenBSD. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[NET]: Add a dev_ioctl() fallback to sock_ioctl()Christoph Hellwig
Currently all network protocols need to call dev_ioctl as the default fallback in their ioctl implementations. This patch adds a fallback to dev_ioctl to sock_ioctl if the protocol returned -ENOIOCTLCMD. This way all the procotol ioctl handlers can be simplified and we don't need to export dev_ioctl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Avoid atomic xchg() for non-error caseBenjamin LaHaise
It also looks like there were 2 places where the test on sk_err was missing from the event wait logic (in sk_stream_wait_connect and sk_stream_wait_memory), while the rest of the sock_error() users look to be doing the right thing. This version of the patch fixes those, and cleans up a few places that were testing ->sk_err directly. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
