path: root/net/irda
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06net/irda: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: only pass array to genl_register_family_with_ops()Johannes Berg
As suggested by David Miller, make genl_register_family_with_ops() a macro and pass only the array, evaluating ARRAY_SIZE() in the macro, this is a little safer. The openvswitch has some indirection, assing ops/n_ops directly in that code. This might ultimately just assign the pointers in the family initializations, saving the struct genl_family_and_ops and code (once mcast groups are handled differently.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14genetlink: make all genl_ops users constJohannes Berg
Now that genl_ops are no longer modified in place when registering, they can be made const. This patch was done mostly with spatch: @@ identifier ops; @@ +const struct genl_ops ops[] = { ... }; (except the struct thing in net/openvswitch/datapath.c) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) The addition of nftables. No longer will we need protocol aware firewall filtering modules, it can all live in userspace. At the core of nftables is a, for lack of a better term, virtual machine that executes byte codes to inspect packet or metadata (arriving interface index, etc.) and make verdict decisions. Besides support for loading packet contents and comparing them, the interpreter supports lookups in various datastructures as fundamental operations. For example sets are supports, and therefore one could create a set of whitelist IP address entries which have ACCEPT verdicts attached to them, and use the appropriate byte codes to do such lookups. Since the interpreted code is composed in userspace, userspace can do things like optimize things before giving it to the kernel. Another major improvement is the capability of atomically updating portions of the ruleset. In the existing netfilter implementation, one has to update the entire rule set in order to make a change and this is very expensive. Userspace tools exist to create nftables rules using existing netfilter rule sets, but both kernel implementations will need to co-exist for quite some time as we transition from the old to the new stuff. Kudos to Patrick McHardy, Pablo Neira Ayuso, and others who have worked so hard on this. 2) Daniel Borkmann and Hannes Frederic Sowa made several improvements to our pseudo-random number generator, mostly used for things like UDP port randomization and netfitler, amongst other things. In particular the taus88 generater is updated to taus113, and test cases are added. 3) Support 64-bit rates in HTB and TBF schedulers, from Eric Dumazet and Yang Yingliang. 4) Add support for new 577xx tigon3 chips to tg3 driver, from Nithin Sujir. 5) Fix two fatal flaws in TCP dynamic right sizing, from Eric Dumazet, Neal Cardwell, and Yuchung Cheng. 6) Allow IP_TOS and IP_TTL to be specified in sendmsg() ancillary control message data, much like other socket option attributes. From Francesco Fusco. 7) Allow applications to specify a cap on the rate computed automatically by the kernel for pacing flows, via a new SO_MAX_PACING_RATE socket option. From Eric Dumazet. 8) Make the initial autotuned send buffer sizing in TCP more closely reflect actual needs, from Eric Dumazet. 9) Currently early socket demux only happens for TCP sockets, but we can do it for connected UDP sockets too. Implementation from Shawn Bohrer. 10) Refactor inet socket demux with the goal of improving hash demux performance for listening sockets. With the main goals being able to use RCU lookups on even request sockets, and eliminating the listening lock contention. From Eric Dumazet. 11) The bonding layer has many demuxes in it's fast path, and an RCU conversion was started back in 3.11, several changes here extend the RCU usage to even more locations. From Ding Tianhong and Wang Yufen, based upon suggestions by Nikolay Aleksandrov and Veaceslav Falico. 12) Allow stackability of segmentation offloads to, in particular, allow segmentation offloading over tunnels. From Eric Dumazet. 13) Significantly improve the handling of secret keys we input into the various hash functions in the inet hashtables, TCP fast open, as well as syncookies. From Hannes Frederic Sowa. The key fundamental operation is "net_get_random_once()" which uses static keys. Hannes even extended this to ipv4/ipv6 fragmentation handling and our generic flow dissector. 14) The generic driver layer takes care now to set the driver data to NULL on device removal, so it's no longer necessary for drivers to explicitly set it to NULL any more. Many drivers have been cleaned up in this way, from Jingoo Han. 15) Add a BPF based packet scheduler classifier, from Daniel Borkmann. 16) Improve CRC32 interfaces and generic SKB checksum iterators so that SCTP's checksumming can more cleanly be handled. Also from Daniel Borkmann. 17) Add a new PMTU discovery mode, IP_PMTUDISC_INTERFACE, which forces using the interface MTU value. This helps avoid PMTU attacks, particularly on DNS servers. From Hannes Frederic Sowa. 18) Use generic XPS for transmit queue steering rather than internal (re-)implementation in virtio-net. From Jason Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits) random32: add test cases for taus113 implementation random32: upgrade taus88 generator to taus113 from errata paper random32: move rnd_state to linux/random.h random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized random32: add periodic reseeding random32: fix off-by-one in seeding requirement PHY: Add RTL8201CP phy_driver to realtek xtsonic: add missing platform_set_drvdata() in xtsonic_probe() macmace: add missing platform_set_drvdata() in mace_probe() ethernet/arc/arc_emac: add missing platform_set_drvdata() in arc_emac_probe() ipv6: protect for_each_sk_fl_rcu in mem_check with rcu_read_lock_bh vlan: Implement vlan_dev_get_egress_qos_mask as an inline. ixgbe: add warning when max_vfs is out of range. igb: Update link modes display in ethtool netfilter: push reasm skb through instead of original frag skbs ip6_output: fragment outgoing reassembled skb properly MAINTAINERS: mv643xx_eth: take over maintainership from Lennart net_sched: tbf: support of 64bit rates ixgbe: deleting dfwd stations out of order can cause null ptr deref ixgbe: fix build err, num_rx_queues is only available with CONFIG_RPS ...
2013-10-19net: misc: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-04sched/wait: Make the __wait_event*() interface more friendlyPeter Zijlstra
Change all __wait_event*() implementations to match the corresponding wait_event*() signature for convenience. In particular this does away with the weird 'ret' logic. Since there are __wait_event*() users this requires we update them too. Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20131002092529.042563462@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-07-19net/irda: fixed style issues in irttpDragos Foianu
Applied error fixes suggested by checpatch.pl Signed-off-by: Dragos Foianu <dragos.foianu@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-16net/irda: fixed style issues in irlan_ethDragos Foianu
Applied fixes suggested by checkpatch.pl Signed-off-by: Dragos Foianu <dragos.foianu@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13net: Convert uses of typedef ctl_table to struct ctl_tableJoe Perches
Reduce the uses of this unnecessary typedef. Done via perl script: $ git grep --name-only -w ctl_table net | \ xargs perl -p -i -e '\ sub trim { my ($local) = @_; $local =~ s/(^\s+|\s+$)//g; return $local; } \ s/\b(?<!struct\s)ctl_table\b(\s*\*\s*|\s+\w+)/"struct ctl_table " . trim($1)/ge' Reflow the modified lines that now exceed 80 columns. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-19net: irda: using kzalloc() instead of kmalloc() to avoid strncpy() issue.Chen Gang
'discovery->data.info' length is 22, NICKNAME_MAX_LEN is 21, so the strncpy() will always left the last byte of 'discovery->data.info' uninitialized. When 'text' length is longer than 21 (NICKNAME_MAX_LEN), if still left the last byte of 'discovery->data.info' uninitialized, the next strlen() will cause issue. Also 'discovery->data' is 'struct irda_device_info' which defined in "include/uapi/...", it may copy to user mode, so need whole initialized. All together, need use kzalloc() instead of kmalloc() to initialize all members firstly. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-04-29Merge tag 'tty-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver update from Greg Kroah-Hartman: "Here's the big tty/serial driver merge request for 3.10-rc1 Once again, Jiri has a number of TTY driver fixes and cleanups, and Peter Hurley came through with a bunch of ldisc fixes that resolve a number of reported issues. There are some other serial driver cleanups as well. All of these have been in the linux-next tree for a while" * tag 'tty-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (117 commits) tty/serial/sirf: fix MODULE_DEVICE_TABLE serial: mxs: drop superfluous {get|put}_device serial: mxs: fix buffer overflow ARM: PL011: add support for extended FIFO-size of PL011-r1p5 serial_core.c: add put_device() after device_find_child() tty: Fix unsafe bit ops in tty_throttle_safe/unthrottle_safe serial: sccnxp: Replace pdata.init/exit with regulator API serial: sccnxp: Do not override device name TTY: pty, fix compilation warning TTY: rocket, fix compilation warning TTY: ircomm: fix DTR being raised on hang up TTY: synclinkmp: fix DTR being raised on hang up TTY: synclink_gt: fix DTR being raised on hang up TTY: synclink: fix DTR being raised on hang up serial: 8250_dw: Fix the stub for dw8250_probe_acpi() serial: 8250_dw: Convert to devm_ioremap() serial: 8250_dw: Set port capabilities based on CPR register serial: 8250_dw: Let ACPI code extract the DMA client info serial: 8250_dw: Support clk framework also with ACPI serial: 8250_dw: Enable runtime PM ...
2013-04-25irda: irlmp_reasons[] can be staticWu Fengguang
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Acked-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19irda: small read past the end of array in debug codeDan Carpenter
The "reason" can come from skb->data[] and it hasn't been capped so it can be from 0-255 instead of just 0-6. For example in irlmp_state_dtr() the code does: reason = skb->data[3]; ... irlmp_disconnect_indication(self, reason, skb); Also LMREASON has a couple other values which don't have entries in the irlmp_reasons[] array. And 0xff is a valid reason as well which means "unknown". So far as I can see we don't actually care about "reason" except for in the debug code. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-14Merge 3.9-rc7 intp tty-nextGreg Kroah-Hartman
We want the fixes here. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12TTY: ircomm: fix DTR being raised on hang upJohan Hovold
Make sure to check ASYNC_INITIALISED before raising DTR when waking up from blocked open in ircomm_tty_block_til_ready. Currently DTR could get raised at hang up as a blocked process would raise DTR unconditionally before checking for hang up and returning. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-08TTY: ircomm, use GFP_KERNEL in ircomm_open()Mathias Krause
Hi Greg, I'm unsure if you or Dave should take that one as it's for one a TTY patch but also living under net/. So I'm uncertain and let you decide! Thanks, Mathias -- >8 -- Subject: [PATCH] TTY: ircomm, use GFP_KERNEL in ircomm_open() We're clearly running in non-atomic context as our only call site is able to call wait_event_interruptible(). So we're safe to use GFP_KERNEL here instead of GFP_ATOMIC. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-08irda: use GFP_KERNEL in irda_connect_response()Mathias Krause
The only call site of irda_connect_response() is irda_accept() -- a function called from user context only. Therefore it has no need for GFP_ATOMIC. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-08irda: use GFP_KERNEL in irda_create()Mathias Krause
irda_create() is called from user context only, therefore has no need for GFP_ATOMIC. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07irda: Fix missing msg_namelen update in irda_recvmsg_dgram()Mathias Krause
The current code does not fill the msg_name member in case it is set. It also does not set the msg_namelen member to 0 and therefore makes net/socket.c leak the local, uninitialized sockaddr_storage variable to userland -- 128 bytes of kernel stack memory. Fix that by simply setting msg_namelen to 0 as obviously nobody cared about irda_recvmsg_dgram() not filling the msg_name in case it was set. Cc: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-01Merge 3.9-rc5 into tty-nextGreg Kroah-Hartman
We need the fixes here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-21Merge 3.9-rc3 into tty-nextGreg Kroah-Hartman
2013-03-20net/irda: add missing error path release_sock callKees Cook
This makes sure that release_sock is called for all error conditions in irda_getsockopt. Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Brad Spengler <spender@grsecurity.net> Cc: stable@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-18TTY: add tty_port_tty_hangup helperJiri Slaby
It allows for cleaning up on a considerable amount of places. They did port_get, hangup, kref_put. Now the only thing needed is to call tty_port_tty_hangup which does exactly that. And they can also decide whether to consider CLOCAL or completely ignore that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-06net/irda: Raise dtr in non-blocking openPeter Hurley
DTR/RTS need to be raised, regardless of the open() mode, but not if the port has already shutdown. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-06net/irda: Use barrier to set task statePeter Hurley
Without a memory and compiler barrier, the task state change can migrate relative to the condition testing in a blocking loop. However, the task state change must be visible across all cpus prior to testing those conditions. Failing to do this can result in the familiar 'lost wakeup' and this task will hang until killed. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-06net/irda: Hold port lock while bumping blocked_openPeter Hurley
Although tty_lock() already protects concurrent update to blocked_open, that fails to meet the separation-of-concerns between tty_port and tty. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-06net/irda: Fix port open countsPeter Hurley
Saving the port count bump is unsafe. If the tty is hung up while this open was blocking, the port count is zeroed. Explicitly check if the tty was hung up while blocking, and correct the port count if not. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27irda: small read beyond end of array in debug codeDan Carpenter
charset comes from skb->data. It's a number in the 0-255 range. If we have debugging turned on then this could cause a read beyond the end of the array. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-02-21Merge tag 'tty-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial patches from Greg Kroah-Hartman: "Here's the big tty/serial driver patches for 3.9-rc1. More tty port rework and fixes from Jiri here, as well as lots of individual serial driver updates and fixes. All of these have been in the linux-next tree for a while." * tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits) tty: mxser: improve error handling in mxser_probe() and mxser_module_init() serial: imx: fix uninitialized variable warning serial: tegra: assume CONFIG_OF TTY: do not update atime/mtime on read/write lguest: select CONFIG_TTY to build properly. ARM defconfigs: add missing inclusions of linux/platform_device.h fb/exynos: include platform_device.h ARM: sa1100/assabet: include platform_device.h directly serial: imx: Fix recursive locking bug pps: Fix build breakage from decoupling pps from tty tty: Remove ancient hardpps() pps: Additional cleanups in uart_handle_dcd_change pps: Move timestamp read into PPS code proper pps: Don't crash the machine when exiting will do pps: Fix a use-after free bug when unregistering a source. pps: Use pps_lookup_dev to reduce ldisc coupling pps: Add pps_lookup_dev() function tty: serial: uartlite: Support uartlite on big and little endian systems tty: serial: uartlite: Fix sparse and checkpatch warnings serial/arc-uart: Miscll DT related updates (Grant's review comments) ... Fix up trivial conflicts, mostly just due to the TTY config option clashing with the EXPERIMENTAL removal.
2013-02-04net: remove redundant check for timer pending state before del_timerYing Xue
As in del_timer() there has already placed a timer_pending() function to check whether the timer to be deleted is pending or not, it's unnecessary to check timer pending state again before del_timer() is called. Signed-off-by: Ying Xue <ying.xue@windriver.com> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-27irda: buffer overflow in irnet_ctrl_read()Dan Carpenter
The comments here say that the /* Max event is 61 char */ but in 2003 we changed the event format and now the max event size is 75. The longest event is: "Discovered %08x (%s) behind %08x {hints %02X-%02X}\n", 12345678901 23 456789012 34567890 1 2 3 +8 +21 +8 +2 +2 +1 = 75 characters. There was a check to return -EOVERFLOW if the user gave us a "count" value that was less than 64. Raising it to 75 might break backwards compatability. Instead I removed the check and now it returns a truncated string if "count" is too low. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_flip_buffer_pushJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. Now, the one where most of tty_port_tty_get gets removed: tty_flip_buffer_push. IOW we also closed all the races in drivers not using tty_port_tty_get at all yet. Also we move tty_flip_buffer_push declaration from include/linux/tty.h to include/linux/tty_flip.h to all others while we are changing it anyway. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: move low_latency to tty_portJiri Slaby
One point is to have less places where we actually need tty pointer. The other is that low_latency is bound to buffer processing and buffers are now in tty_port. So it makes sense to move low_latency to tty_port too. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_insert_flip_stringJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. tty_insert_flip_string this time. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03treewide: Replace incomming with incoming in all comments and stringsJorrit Schippers
Signed-off-by: Jorrit Schippers <jorrit@ncode.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-11Merge tag 'tty-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull TTY/Serial merge from Greg Kroah-Hartman: "Here's the big tty/serial tree set of changes for 3.8-rc1. Contained in here is a bunch more reworks of the tty port layer from Jiri and bugfixes from Alan, along with a number of other tty and serial driver updates by the various driver authors. Also, Jiri has been coerced^Wconvinced to be the co-maintainer of the TTY layer, which is much appreciated by me. All of these have been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up some trivial conflicts in the staging tree, due to the fwserial driver having come in both ways (but fixed up a bit in the serial tree), and the ioctl handling in the dgrp driver having been done slightly differently (staging tree got that one right, and removed both TIOCGSOFTCAR and TIOCSSOFTCAR). * tag 'tty-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (146 commits) staging: sb105x: fix potential NULL pointer dereference in mp_chars_in_buffer() staging/fwserial: Remove superfluous free staging/fwserial: Use WARN_ONCE when port table is corrupted staging/fwserial: Destruct embedded tty_port on teardown staging/fwserial: Fix build breakage when !CONFIG_BUG staging: fwserial: Add TTY-over-Firewire serial driver drivers/tty/serial/serial_core.c: clean up HIGH_BITS_OFFSET usage staging: dgrp: dgrp_tty.c: Audit the return values of get/put_user() staging: dgrp: dgrp_tty.c: Remove the TIOCSSOFTCAR ioctl handler from dgrp driver serial: ifx6x60: Add modem power off function in the platform reboot process serial: mxs-auart: unmap the scatter list before we copy the data serial: mxs-auart: disable the Receive Timeout Interrupt when DMA is enabled serial: max310x: Setup missing "can_sleep" field for GPIO tty/serial: fix ifx6x60.c declaration warning serial: samsung: add devicetree properties for non-Exynos SoCs serial: samsung: fix potential soft lockup during uart write tty: vt: Remove redundant null check before kfree. tty/8250 Add check for pci_ioremap_bar failure tty/8250 Add support for Commtech's Fastcom Async-335 and Fastcom Async-PCIe cards tty/8250 Add XR17D15x devices to the exar_handle_irq override ...
2012-11-28irda: irttp: fix memory leak in irttp_open_tsap() error pathTommi Rantala
Cleanup the memory we allocated earlier in irttp_open_tsap() when we hit this error path. The leak goes back to at least 1da177e4 ("Linux-2.6.12-rc2"). Discovered with Trinity (the syscall fuzzer). Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-15TTY: call tty_port_destroy in the rest of driversJiri Slaby
After commit "TTY: move tty buffers to tty_port", the tty buffers are not freed in some drivers. This is because tty_port_destructor is not called whenever a tty_port is freed. This was an assumption I counted with but was unfortunately untrue. So fix the drivers to fulfil this assumption. To be sure, the TTY buffers (and later some stuff) are gone along with the tty_port, we have to call tty_port_destroy at tear-down places. This is mostly where the structure containing a tty_port is freed. This patch does exactly that -- put tty_port_destroy at those places. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-14Merge 3.7-rc1 into tty-linusGreg Kroah-Hartman
This syncs up the tty-linus branch to the latest in Linus's tree to get all of the UAPI stuff needed for the next set of patches to merge. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-05net, TTY: initialize tty->driver_data before usageSasha Levin
Commit 9c650ffc ("TTY: ircomm_tty, add tty install") split _open() to _install() and _open(). It also moved the initialization of driver_data out of open(), but never added it to install() - causing a NULL ptr deref whenever the driver was used. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-04silence some noisy printks in irdaDave Jones
Fuzzing causes these printks to spew constantly. Changing them to DEBUG statements is consistent with other usage in the file, and makes them disappear when CONFIG_IRDA_DEBUG is disabled. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) GRE now works over ipv6, from Dmitry Kozlov. 2) Make SCTP more network namespace aware, from Eric Biederman. 3) TEAM driver now works with non-ethernet devices, from Jiri Pirko. 4) Make openvswitch network namespace aware, from Pravin B Shelar. 5) IPV6 NAT implementation, from Patrick McHardy. 6) Server side support for TCP Fast Open, from Jerry Chu and others. 7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel Borkmann. 8) Increate the loopback default MTU to 64K, from Eric Dumazet. 9) Use a per-task rather than per-socket page fragment allocator for outgoing networking traffic. This benefits processes that have very many mostly idle sockets, which is quite common. From Eric Dumazet. 10) Use up to 32K for page fragment allocations, with fallbacks to smaller sizes when higher order page allocations fail. Benefits are a) less segments for driver to process b) less calls to page allocator c) less waste of space. From Eric Dumazet. 11) Allow GRO to be used on GRE tunnels, from Eric Dumazet. 12) VXLAN device driver, one way to handle VLAN issues such as the limitation of 4096 VLAN IDs yet still have some level of isolation. From Stephen Hemminger. 13) As usual there is a large boatload of driver changes, with the scale perhaps tilted towards the wireless side this time around. Fix up various fairly trivial conflicts, mostly caused by the user namespace changes. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits) hyperv: Add buffer for extended info after the RNDIS response message. hyperv: Report actual status in receive completion packet hyperv: Remove extra allocated space for recv_pkt_list elements hyperv: Fix page buffer handling in rndis_filter_send_request() hyperv: Fix the missing return value in rndis_filter_set_packet_filter() hyperv: Fix the max_xfer_size in RNDIS initialization vxlan: put UDP socket in correct namespace vxlan: Depend on CONFIG_INET sfc: Fix the reported priorities of different filter types sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP sfc: Fix loopback self-test with separate_tx_channels=1 sfc: Fix MCDI structure field lookup sfc: Add parentheses around use of bitfield macro arguments sfc: Fix null function pointer in efx_sriov_channel_type vxlan: virtual extensible lan igmp: export symbol ip_mc_leave_group netlink: add attributes to fdb interface tg3: unconditionally select HWMON support when tg3 is enabled. Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT" gre: fix sparse warning ...
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
