path: root/net/irda
2008-07-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (1232 commits) iucv: Fix bad merging. net_sched: Add size table for qdiscs net_sched: Add accessor function for packet length for qdiscs net_sched: Add qdisc_enqueue wrapper highmem: Export totalhigh_pages. ipv6 mcast: Omit redundant address family checks in ip6_mc_source(). net: Use standard structures for generic socket address structures. ipv6 netns: Make several "global" sysctl variables namespace aware. netns: Use net_eq() to compare net-namespaces for optimization. ipv6: remove unused macros from net/ipv6.h ipv6: remove unused parameter from ip6_ra_control tcp: fix kernel panic with listening_get_next tcp: Remove redundant checks when setting eff_sacks tcp: options clean up tcp: Fix MD5 signatures for non-linear skbs sctp: Update sctp global memory limit allocations. sctp: remove unnecessary byteshifting, calculate directly in big-endian sctp: Allow only 1 listening socket with SO_REUSEADDR sctp: Do not leak memory on multiple listen() calls sctp: Support ipv6only AF_INET6 sockets. ...
2008-07-20tty: Ldisc revampAlan Cox
Move the line disciplines towards a conventional ->ops arrangement. For the moment the actual 'tty_ldisc' struct in the tty is kept as part of the tty struct but this can then be changed if it turns out that when it all settles down we want to refcount ldiscs separately to the tty. Pull the ldisc code out of /proc and put it with our ldisc code. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-3945.c net/mac80211/mlme.c
2008-07-08irda: Fix netlink error path return valueJulius Volz
Fix an incorrect return value check of genlmsg_put() in irda_nl_get_mode(). genlmsg_put() does not use ERR_PTR() to encode return values, it just returns NULL on error. Signed-off-by: Julius Volz <juliusv@google.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-20irnet_ppp: BKL pushdownArnd Bergmann
2008-06-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tg3.c drivers/net/wireless/rt2x00/rt2x00dev.c net/mac80211/ieee80211_i.h
2008-06-03irda: Sock leak on error path in irda_create.Pavel Emelyanov
Bad type/protocol specified result in sk leak. Fix is simple - release the sk if bad values are given, but to make it possible just to call sk_free(), I move some sk initialization a bit lower. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-25irda: Push BKL down into irda ioctl handlersAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-14net/irda/irnet/irnet_irda.c needs unaligned.hAndrew Morton
net/irda/irnet/irnet_irda.c: In function 'irnet_discovery_indication': net/irda/irnet/irnet_irda.c:1676: error: implicit declaration of function 'get_unaligned' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13irda: Fix a misalign access issue. (v2)Graf Yang
Replace u16ho with put/get_unaligned functions Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02irda: use get_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-30tty: The big operations reworkAlan Cox
- Operations are now a shared const function block as with most other Linux objects - Introduce wrappers for some optional functions to get consistent behaviour - Wrap put_char which used to be patched by the tty layer - Document which functions are needed/optional - Make put_char report success/fail - Cache the driver->ops pointer in the tty as tty->ops - Remove various surplus lock calls we no longer need - Remove proc_write method as noted by Alexey Dobriyan - Introduce some missing sanity checks where certain driver/ldisc combinations would oops as they didn't check needed methods were present [akpm@linux-foundation.org: fix fs/compat_ioctl.c build] [akpm@linux-foundation.org: fix isicom] [akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build] [akpm@linux-foundation.org: fix kgdb] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: switch /proc/irda/irnet to seq_file interfaceAlexey Dobriyan
Probably interface misuse, because of the way iterating over hashbin is done. However! Printing of socket number ("IrNET socket %d - ", i++") made conversion to proper ->start/->next difficult enough to do blindly without hardware. Said that, please apply. Remove useless comment while I am it. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15[IRDA]: Remove irlan_eth_send_gratuitous_arp()Adrian Bunk
Even kernel 2.2.26 (sic) already contains the #undef CONFIG_IRLAN_SEND_GRATUITOUS_ARP with the comment "but for some reason the machine crashes if you use DHCP". Either someone finally looks into this or it's simply time to remove this dead code. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/rndis_host.c drivers/net/wireless/b43/dma.c net/ipv6/ndisc.c
2008-03-26[IRDA]: Store irnet_socket termios properly.David S. Miller
It should be a "struct ktermios" not a "struct termios". Based upon a build warning reported by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[IRDA]: Use proc_create() to setup ->proc_fops firstWang Chen
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: LMP discovery timer not started by defaultRoss Burton
By default, LMP sets up a 3 seconds timer for discovery. We don't need it until discovery is set to 1. Signed-off-by: Ross Burton <ross@openedhand.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: Irport removal - part 1Adrian Bunk
This patch removes IrPORT and the old dongle drivers (all off them have replacement drivers). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: Frame length validation.Robie Basak
When using a stir4200-based USB adaptor to talk to a device that uses an mcp2150, the stir4200 sometimes drops an incoming frame causing the mcp2150 to try and retransmit the lost frame. In this combination, the next frame received from the mcp2150 is often invalid - either an empty i:rsp or an IrCOMM i:rsp with an invalid clen. These corner cases are now checked. Signed-off-by: Robie Basak <rb-oss-1@justgohome.co.uk> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: Resend frames on timeout.Robie Basak
When final timer expires, it might also mean that the i:cmd wasn't received properly. If we have rejected frames, we can try to resend them. Signed-off-by: Robie Basak <rb-oss-1@justgohome.co.uk> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Simple ctl_table to ctl_path conversions.Pavel Emelyanov
This patch includes many places, that only required replacing the ctl_table-s with appropriate ctl_paths and call register_sysctl_paths(). Nothing special was done with them. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IRDA]: Use htons() where appropriate.YOSHIFUJI Hideaki
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-20[IrDA]: af_irda memory leak fixesJesper Juhl
Here goes an IrDA patch against your latest net-2.6 tree. This patch fixes some af_irda memory leaks. It also checks for irias_new_obect() return value. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08[IRDA]: irda_create() nuke user triggable printkmaximilian attems
easy to trigger as user with sfuzz. irda_create() is quiet on unknown sock->type, match this behaviour for SOCK_DGRAM unknown protocol Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-20[IRDA]: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-16[IRDA]: irda parameters warning fixes.Richard Knutsson
This patch fixes: CHECK /home/kernel/src/net/irda/parameters.c /home/kernel/src/net/irda/parameters.c:466:2: warning: Using plain integer as NULL pointer /home/kernel/src/net/irda/parameters.c:520:2: warning: Using plain integer as NULL pointer /home/kernel/src/net/irda/parameters.c:573:2: warning: Using plain integer as NULL pointer Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-16[IRDA]: irlmp_unregister_link() needs to free lsaps.Hinko Kocevar
While testing the mcs7780 based IrDA USB dongle I've stumbled upon memory leak in irlmp_unregister_link(). Hashbin for lsaps is created in irlmp_register_link and should probably be freed in irlmp_unregister_link(). Signed-off-by: Hinko Kocevar <hinko.kocevar@cetrtapot.si> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-05[IRDA]: Move ircomm_tty_line_info() under #ifdef CONFIG_PROC_FSPavel Emelyanov
The function in question is called only from ircomm_tty_read_proc, which is under this option. Move this helper to the same place. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-22[IRDA]: Compilation for CONFIG_INET=n casePavel Emelyanov
Found this occasionally. The CONFIG_INET=n is hardly ever set, but if it is the irlan_eth_send_gratuitous_arp() compilation should produce a warning about unused variable in_dev. Too pedantic? :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-19[IRDA]: Add missing "space"Joe Perches
2007-11-01[IRDA] IRNET: Fix build when TCGETS2 is defined.David S. Miller
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-26[IRDA]: Make ircomm_tty static.Adrian Bunk
ircomm_tty can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19more UTF-8 conversionsMarcin Garski
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-18Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (51 commits) [IPV6]: Fix again the fl6_sock_lookup() fixed locking [NETFILTER]: nf_conntrack_tcp: fix connection reopening fix [IPV6]: Fix race in ipv6_flowlabel_opt() when inserting two labels [IPV6]: Lost locking in fl6_sock_lookup [IPV6]: Lost locking when inserting a flowlabel in ipv6_fl_list [NETFILTER]: xt_sctp: fix mistake to pass a pointer where array is required [NET]: Fix OOPS due to missing check in dev_parse_header(). [TCP]: Remove lost_retrans zero seqno special cases [NET]: fix carrier-on bug? [NET]: Fix uninitialised variable in ip_frag_reasm() [IPSEC]: Rename mode to outer_mode and add inner_mode [IPSEC]: Disallow combinations of RO and AH/ESP/IPCOMP [IPSEC]: Use the top IPv4 route's peer instead of the bottom [IPSEC]: Store afinfo pointer in xfrm_mode [IPSEC]: Add missing BEET checks [IPSEC]: Move type and mode map into xfrm_state.c [IPSEC]: Fix length check in xfrm_parse_spi [IPSEC]: Move ip_summed zapping out of xfrm6_rcv_spi [IPSEC]: Get nexthdr from caller in xfrm6_rcv_spi [IPSEC]: Move tunnel parsing for IPv4 out of xfrm4_input ...
2007-10-18sysctl: properly register the irda binary sysctl numbersEric W. Biederman
Grumble. These numbers should have been in sysctl.h from the beginning if we ever expected anyone to use them. Oh well put them there now so we can find them and make maintenance easier. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17[IRDA]: IrCOMM discovery indication simplificationRyan Reading
From: Ryan Reading <ryanr23@gmail.com> Every IrCOMM socket is registered with the discovery subsystem, so we don't need to loop over all of them for every discovery event. We just need to do it for the registered IrCOMM socket. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IRDA]: Make the IRDA use the seq_open_private()Pavel Emelyanov
Just switch to the consolidated code Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
