path: root/net/irda
2012-11-28irda: irttp: fix memory leak in irttp_open_tsap() error pathTommi Rantala
Cleanup the memory we allocated earlier in irttp_open_tsap() when we hit this error path. The leak goes back to at least 1da177e4 ("Linux-2.6.12-rc2"). Discovered with Trinity (the syscall fuzzer). Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-14Merge 3.7-rc1 into tty-linusGreg Kroah-Hartman
This syncs up the tty-linus branch to the latest in Linus's tree to get all of the UAPI stuff needed for the next set of patches to merge. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-05net, TTY: initialize tty->driver_data before usageSasha Levin
Commit 9c650ffc ("TTY: ircomm_tty, add tty install") split _open() to _install() and _open(). It also moved the initialization of driver_data out of open(), but never added it to install() - causing a NULL ptr deref whenever the driver was used. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-04silence some noisy printks in irdaDave Jones
Fuzzing causes these printks to spew constantly. Changing them to DEBUG statements is consistent with other usage in the file, and makes them disappear when CONFIG_IRDA_DEBUG is disabled. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) GRE now works over ipv6, from Dmitry Kozlov. 2) Make SCTP more network namespace aware, from Eric Biederman. 3) TEAM driver now works with non-ethernet devices, from Jiri Pirko. 4) Make openvswitch network namespace aware, from Pravin B Shelar. 5) IPV6 NAT implementation, from Patrick McHardy. 6) Server side support for TCP Fast Open, from Jerry Chu and others. 7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel Borkmann. 8) Increate the loopback default MTU to 64K, from Eric Dumazet. 9) Use a per-task rather than per-socket page fragment allocator for outgoing networking traffic. This benefits processes that have very many mostly idle sockets, which is quite common. From Eric Dumazet. 10) Use up to 32K for page fragment allocations, with fallbacks to smaller sizes when higher order page allocations fail. Benefits are a) less segments for driver to process b) less calls to page allocator c) less waste of space. From Eric Dumazet. 11) Allow GRO to be used on GRE tunnels, from Eric Dumazet. 12) VXLAN device driver, one way to handle VLAN issues such as the limitation of 4096 VLAN IDs yet still have some level of isolation. From Stephen Hemminger. 13) As usual there is a large boatload of driver changes, with the scale perhaps tilted towards the wireless side this time around. Fix up various fairly trivial conflicts, mostly caused by the user namespace changes. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits) hyperv: Add buffer for extended info after the RNDIS response message. hyperv: Report actual status in receive completion packet hyperv: Remove extra allocated space for recv_pkt_list elements hyperv: Fix page buffer handling in rndis_filter_send_request() hyperv: Fix the missing return value in rndis_filter_set_packet_filter() hyperv: Fix the max_xfer_size in RNDIS initialization vxlan: put UDP socket in correct namespace vxlan: Depend on CONFIG_INET sfc: Fix the reported priorities of different filter types sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP sfc: Fix loopback self-test with separate_tx_channels=1 sfc: Fix MCDI structure field lookup sfc: Add parentheses around use of bitfield macro arguments sfc: Fix null function pointer in efx_sriov_channel_type vxlan: virtual extensible lan igmp: export symbol ip_mc_leave_group netlink: add attributes to fdb interface tg3: unconditionally select HWMON support when tg3 is enabled. Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT" gre: fix sparse warning ...
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-05serial: add a new helper functionHuang Shijie
In most of the time, the driver needs to check if the cts flow control is enabled. But now, the driver checks the ASYNC_CTS_FLOW flag manually, which is not a grace way. So add a new wraper function to make the code tidy and clean. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-13TTY: ircomm_tty, add tty installJiri Slaby
This has two outcomes: * we give the TTY layer a tty_port * we do not find the info structure every time open is called on that tty Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-06Merge tty-next into 3.6-rc1Greg Kroah-Hartman
This handles the merge issue in: arch/um/drivers/line.c arch/um/drivers/line.h And resolves the duplicate patches that were in both trees do to the tty-next branch not getting merged into 3.6-rc1. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16irda: Fix typo in irdaMasanari Iida
Correct spelling typo in irda. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-16tty: move the termios object into the ttyAlan Cox
This will let us sort out a whole pile of tty related races. The alternative would be to keep points and refcount the termios objects. However 1. They are tiny anyway 2. Many devices don't use the stored copies 3. We can remove a pty special case Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12TTY: ircomm, use tty_port_close_start helperJiri Slaby
Again, the code is identical, so leverage the helper code. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12TTY: ircomm, use tty_port_close_end helperJiri Slaby
2012-06-12TTY: ircomm, define carrier routinesJiri Slaby
These will be used by the tty_port wait_til_ready later. (Now they are used by our code.) Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12TTY: ircomm, define local tty_portJiri Slaby
In some functions we use tty_port heavily. So let us have a local pointer to that variable instead of having self->port all over the code. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12TTY: ircomm, use tty from tty_portJiri Slaby
This also includes a switch to tty refcounting. It makes sure, the code no longer can access a freed TTY struct. Sometimes the only thing needed is to pass tty down to the callies. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12TTY: ircomm, revamp lockingJiri Slaby
Use self->spinlock only for ctrl_skb and tx_skb. TTY stuff is now protected by tty_port->lock. This is needed for further cleanup (and conversion to tty_port helpers). This also closes the race in the end of close. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12TTY: ircomm, use flags from tty_portJiri Slaby
Switch to tty_port->flags. And while at it, remove redefined flags for them. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12TTY: ircomm, use open counts from tty_portJiri Slaby
Switch to tty_port->count and blocked_open. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12TTY: ircomm, use close times from tty_portJiri Slaby
Switch to tty_port->close_delay and closing_wait. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12TTY: ircomm, add tty_portJiri Slaby
And use close/open_wait from there. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-04net: Remove casts to same typeJoe Perches
Adding casts of objects to the same type is unnecessary and confusing for a human reader. For example, this cast: int y; int *p = (int *)&y; I used the coccinelle script below to find and remove these unnecessary casts. I manually removed the conversions this script produces of casts with __force and __user. @@ type T; T *p; @@ - (T *)p + p Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-08TTY: remove unneeded tty->index checksJiri Slaby
Checking if tty->index is in bounds is not needed. The tty has the index set in the initial open. This is done in get_tty_driver. And it can be only in interval <0,driver->num). So remove the tests which check exactly this interval. Some are left untouched as they check against the current backing device count. (Leaving apart that the check is racy in most of the cases.) Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: remove re-assignments to tty_driver membersJiri Slaby
All num, magic and owner are set by alloc_tty_driver. No need to re-set them on each allocation site. pti driver sets something different to what it passes to alloc_tty_driver. It is not a bug, since we don't use the lines parameter in any way. Anyway this is fixed, and now we do the right thing. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-04ppp: Replace uses of <linux/if_ppp.h> with <linux/ppp-ioctl.h>Paul Mackerras
Since all that include/linux/if_ppp.h does is #include <linux/ppp-ioctl.h>, this replaces the occurrences of #include <linux/if_ppp.h> with #include <linux/ppp-ioctl.h>. It also corrects an error in Documentation/networking/l2tp.txt, where it referenced include/linux/if_ppp.h as the source of some definitions that are actually now defined in include/linux/if_pppol2tp.h. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-21irda: use msecs_to_jiffies() rather than manual calculationXi Wang
Also use mod_timer() instead of direct assignment to "expires". Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19module_param: make bool parameters really bool (net & drivers/net)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. (Thanks to Joe Perches for suggesting coccinelle for 0/1 -> true/false). Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-21irttp: Use kmemdup rather than duplicating its implementationThomas Meyer
The semantic patch that makes this change is available in scripts/coccinelle/api/memdup.cocci. Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-26Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (79 commits) TTY: serial_core: Fix crash if DCD drop during suspend tty/serial: atmel_serial: bootconsole removed from auto-enumerates Revert "TTY: call tty_driver_lookup_tty unconditionally" tty/serial: atmel_serial: add device tree support tty/serial: atmel_serial: auto-enumerate ports tty/serial: atmel_serial: whitespace and braces modifications tty/serial: atmel_serial: change platform_data variable name tty/serial: RS485 bindings for device tree TTY: call tty_driver_lookup_tty unconditionally TTY: pty, release tty in all ptmx_open fail paths TTY: make tty_add_file non-failing TTY: drop driver reference in tty_open fail path 8250_pci: Fix kernel panic when pch_uart is disabled h8300: drivers/serial/Kconfig was moved parport_pc: release IO region properly if unsupported ITE887x card is found tty: Support compat_ioctl get/set termios_locked hvc_console: display printk messages on console. TTY: snyclinkmp: forever loop in tx_load_dma_buffer() tty/n_gsm: avoid fifo overflow in gsm_dlci_data_output tty/n_gsm: fix a bug in gsm_dlci_data_output (adaption = 2 case) ... Fix up Conflicts in: - drivers/tty/serial/8250_pci.c Trivial conflict with removed duplicate device ID - drivers/tty/serial/atmel_serial.c Annoying silly conflict between "specify the port num via platform_data" and other changes to atmel_console_init
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-09-16IRDA: Fix global type conflicts in net/irda/irsysctl.c v2Andi Kleen
The externs here didn't agree with the declarations in qos.c. Better would be probably to move this into a header, but since it's common practice to have naked externs with sysctls I left it for now. Cc: samuel@sortiz.org Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-25TTY: use tty_wait_until_sent_from_close in other driversJiri Slaby
Let's use the newly added helper to avoid stalls in drivers which are not yet ported to tty_port helpers. Those which are broken (call tty_wait_until_sent with irqs disabled) are left untouched. They are in a deeper trouble than we are trying to solve here. This includes amiserial, 68328serial, 68360serial and crisv10. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-rxon.c drivers/net/wireless/rtlwifi/pci.c net/netfilter/ipvs/ip_vs_core.c
2011-06-16net: Remove casts of void *Joe Perches
Unnecessary casts of void * clutter the code. These are the remainder casts after several specific patches to remove netdev_priv and dev_priv. Done via coccinelle script: $ cat cast_void_pointer.cocci @@ type T; T *pt; void *pv; @@ - pt = (T *)pv; + pt = pv; Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-06irda: iriap: Use seperate lockdep class for irias_objects->hb_spinlockDavid S. Miller
The SEQ output functions grab the obj->attrib->hb_spinlock lock of sub-objects found in the hash traversal. These locks are in a different realm than the one used for the irias_objects hash table itself. So put the latter into it's own lockdep class. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19irda: Fix error propagation in ircomm_lmp_connect_response()David S. Miller
The variable 'ret' is set but unused, and this pointed out that errors from irlmp_connect_response() are not propagated to the caller. Note that this is currently academic since irlmp_connect_response() always returns 0. :-) Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19irda: Kill set but unused variable 'bytes' in irlan_check_command_param()David S. Miller
2011-05-19irda: Kill set but unused variable 'clen' in ircomm_connect_indication()David S. Miller
2011-05-19irda: Kill set but unused vars 'saddr' and 'daddr' in ↵David S. Miller
irlan_provider_connect_indication() Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12net/irda/ircomm_tty.c: Use flip buffers to deliver dataAmit Virdi
use tty_insert_flip_string and tty_flip_buffer_push to deliver incoming data packets from the IrDA device instead of delivering the packets directly to the line discipline. Following later approach resulted in warning "Sleeping function called from invalid context". Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x_ethtool.c
2011-04-17irda: irproc: Fix set-but-unused variables.David S. Miller
The variable 'd' is set but unused in irda_proc_register(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17irda: irlap_event: Fix set-but-unused variables.David S. Miller
The variable 'ret' is set but unused in irlap_state_sclose(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
