commit dbb2483b2a46fbaf833cfb5deb5ed9cace9c7399 upstream.
In commit 6a53b7593233 ("xfrm: check id proto in validate_tmpl()")
I introduced a check for xfrm protocol, but according to Herbert
IPSEC_PROTO_ANY should only be used as a wildcard for lookup, so
it should be removed from validate_tmpl().
And, IPSEC_PROTO_ANY is expected to only match 3 IPSec-specific
protocols, this is why xfrm_state_flush() could still miss
IPPROTO_ROUTING, which leads that those entries are left in
net->xfrm.state_all before exit net. Fix this by replacing
IPSEC_PROTO_ANY with zero.
This patch also extracts the check from validate_tmpl() to
xfrm_id_proto_valid() and uses it in parse_ipsecrequest().
With this, no other protocols should be added into xfrm.
Fixes: 6a53b7593233 ("xfrm: check id proto in validate_tmpl()")
Reported-by: syzbot+0bf0519d6e0de15914fe@syzkaller.appspotmail.com
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Signed-off-by: Zubin Mithra <zsm@chromium.org>
[ Upstream commit 7c80eb1c7e2b8420477fbc998971d62a648035d9 ]
In both functions, if pfkey_xfrm_policy2msg failed we leaked the newly
allocated sk_buff. Free it on error.
Fixes: 55569ce256ce ("Fix conversion between IPSEC_MODE_xxx and XFRM_MODE_xxx.")
Reported-by: syzbot+4f0529365f7f2208d9f0@syzkaller.appspotmail.com
Signed-off-by: Jeremy Sowden <jeremy@azazel.net>
[ Upstream commit fc2d5cfdcfe2ab76b263d91429caa22451123085 ]
Attempting to avoid cloning the skb when broadcasting by inflating
the refcount with sock_hold/sock_put while under RCU lock is dangerous
and violates RCU principles. It leads to subtle race conditions when
attempting to free the SKB, as we may reference sockets that have
already been freed by the stack.
Unable to handle kernel paging request at virtual address 6b6b6b6b6b6c4b
[006b6b6b6b6b6c4b] address between user and kernel address ranges
Internal error: Oops: 96000004 [#1] PREEMPT SMP
task: fffffff78f65b380 task.stack: ffffff8049a88000
pc : sock_rfree+0x38/0x6c
lr : skb_release_head_state+0x6c/0xcc
Process repro (pid: 7117, stack limit = 0xffffff8049a88000)
Call trace:
skb_release_all+0x1c/0x38
__kfree_skb+0x1c/0x30
kfree_skb+0xd0/0xf4
pfkey_broadcast+0x14c/0x18c
pfkey_sendmsg+0x1d8/0x408
sock_sendmsg+0x44/0x60
___sys_sendmsg+0x1d0/0x2a8
__sys_sendmsg+0x64/0xb4
SyS_sendmsg+0x34/0x4c
el0_svc_naked+0x34/0x38
Kernel panic - not syncing: Fatal exception
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Sean Tranchetti <stranche@codeaurora.org>
commit 4b66af2d6356a00e94bcdea3e7fea324e8b5c6f4 upstream.
Key extensions (struct sadb_key) include a user-specified number of key
bits. The kernel uses that number to determine how much key data to copy
out of the message in pfkey_msg2xfrm_state().
The length of the sadb_key message must be verified to be long enough,
even in the case of SADB_X_AALG_NULL. Furthermore, the sadb_key_len value
must be long enough to include both the key data and the struct sadb_key
itself.
Introduce a helper function verify_key_len(), and call it from
parse_exthdrs() where other exthdr types are similarly checked for
correctness.
Signed-off-by: Kevin Easton <kevin@guarana.org>
Reported-by: syzbot+5022a34ca5a3d49b84223653fab632dfb7b4cf37@syzkaller.appspotmail.com
Cc: Zubin Mithra <zsm@chromium.org>
commit 4e765b4972af7b07adcb1feb16e7a525ce1f6b28 upstream.
If a message sent to a PF_KEY socket ended with an incomplete extension
header (fewer than 4 bytes remaining), then parse_exthdrs() read past
the end of the message, into uninitialized memory. Fix it by returning
-EINVAL in this case.
Reproducer:
#include <linux/pfkeyv2.h>
#include <sys/socket.h>
#include <unistd.h>
int main()
int sock = socket(PF_KEY, SOCK_RAW, PF_KEY_V2);
char buf[17] = { 0 };
struct sadb_msg *msg = (void *)buf;
msg->sadb_msg_version = PF_KEY_V2;
msg->sadb_msg_type = SADB_DELETE;
msg->sadb_msg_len = 2;
write(sock, buf, 17);
commit 06b335cb51af018d5feeff5dd4fd53847ddb675a upstream.
If a message sent to a PF_KEY socket ended with one of the extensions
that takes a 'struct sadb_address' but there were not enough bytes
remaining in the message for the ->sa_family member of the 'struct
sockaddr' which is supposed to follow, then verify_address_len() read
past the end of the message, into uninitialized memory. Fix it by
returning -EINVAL in this case.
This bug was found using syzkaller with KMSAN.
Reproducer:
#include <unistd.h>
int main()
char buf[24] = { 0 };
struct sadb_address *addr = (void *)(msg + 1);
msg->sadb_msg_len = 3;
addr->sadb_address_len = 1;
addr->sadb_address_exttype = SADB_EXT_ADDRESS_SRC;
write(sock, buf, 24);
Reported-by: Alexander Potapenko <glider@google.com>
pfkey_broadcast() might be called from non process contexts,
we can not use GFP_KERNEL in these cases [1].
This patch partially reverts commit ba51b6be38c1 ("net: Fix RCU splat in
af_key"), only keeping the GFP_ATOMIC forcing under rcu_read_lock()
section.
[1] : syzkaller reported :
in_atomic(): 1, irqs_disabled(): 0, pid: 2932, name: syzkaller183439
3 locks held by syzkaller183439/2932:
#0: (&net->xfrm.xfrm_cfg_mutex){+.+.+.}, at: [<ffffffff83b43888>] pfkey_sendmsg+0x4c8/0x9f0 net/key/af_key.c:3649
#1: (&pfk->dump_lock){+.+.+.}, at: [<ffffffff83b467f6>] pfkey_do_dump+0x76/0x3f0 net/key/af_key.c:293
#2: (&(&net->xfrm.xfrm_policy_lock)->rlock){+...+.}, at: [<ffffffff83957632>] spin_lock_bh include/linux/spinlock.h:304 [inline]
#2: (&(&net->xfrm.xfrm_policy_lock)->rlock){+...+.}, at: [<ffffffff83957632>] xfrm_policy_walk+0x192/0xa30 net/xfrm/xfrm_policy.c:1028
CPU: 0 PID: 2932 Comm: syzkaller183439 Not tainted 4.13.0-rc4+ #24
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
___might_sleep+0x2b2/0x470 kernel/sched/core.c:5994
__might_sleep+0x95/0x190 kernel/sched/core.c:5947
slab_pre_alloc_hook mm/slab.h:416 [inline]
slab_alloc mm/slab.c:3383 [inline]
kmem_cache_alloc+0x24b/0x6e0 mm/slab.c:3559
skb_clone+0x1a0/0x400 net/core/skbuff.c:1037
pfkey_broadcast_one+0x4b2/0x6f0 net/key/af_key.c:207
pfkey_broadcast+0x4ba/0x770 net/key/af_key.c:281
dump_sp+0x3d6/0x500 net/key/af_key.c:2685
xfrm_policy_walk+0x2f1/0xa30 net/xfrm/xfrm_policy.c:1042
pfkey_dump_sp+0x42/0x50 net/key/af_key.c:2695
pfkey_do_dump+0xaa/0x3f0 net/key/af_key.c:299
pfkey_spddump+0x1a0/0x210 net/key/af_key.c:2722
pfkey_process+0x606/0x710 net/key/af_key.c:2814
pfkey_sendmsg+0x4d6/0x9f0 net/key/af_key.c:3650
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
___sys_sendmsg+0x755/0x890 net/socket.c:2035
__sys_sendmsg+0xe5/0x210 net/socket.c:2069
SYSC_sendmsg net/socket.c:2080 [inline]
SyS_sendmsg+0x2d/0x50 net/socket.c:2076
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x445d79
RSP: 002b:00007f32447c1dc8 EFLAGS: 00000202 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 0000000000445d79
RDX: 0000000000000000 RSI: 000000002023dfc8 RDI: 0000000000000008
RBP: 0000000000000086 R08: 00007f32447c2700 R09: 00007f32447c2700
R10: 00007f32447c2700 R11: 0000000000000202 R12: 0000000000000000
R13: 00007ffe33edec4f R14: 00007f32447c29c0 R15: 0000000000000000
Fixes: ba51b6be38c1 ("net: Fix RCU splat in af_key")
Cc: David Ahern <dsa@cumulusnetworks.com>
Acked-by: David Ahern <dsahern@gmail.com>
After rcu conversions performance degradation in forward tests isn't that
noticeable anymore.
See next patch for some numbers.
A followup patcg could then also remove genid from the policies
as we do not cache bundles anymore.
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
situations.
This patch uses refcount_inc_not_zero() instead of
atomic_inc_not_zero_hint() due to absense of a _hint()
version of refcount API. If the hint() version must
be used, we might need to revisit API.
situations.
situations.
A set of overlapping changes in macvlan and the rocker
driver, nothing serious.
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
pull request (net-next): ipsec-next 2017-06-23
1) Use memdup_user to spmlify xfrm_user_policy.
From Geliang Tang.
2) Make xfrm_dev_register static to silence a sparse warning.
From Wei Yongjun.
3) Use crypto_memneq to check the ICV in the AH protocol.
From Sabrina Dubroca.
4) Remove some unused variables in esp6.
From Stephen Hemminger.
5) Extend XFRM MIGRATE to allow to change the UDP encapsulation port.
From Antony Antony.
6) Include the UDP encapsulation port to km_migrate announcements.
From Antony Antony.
Please pull or let me know if there are problems.
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
There were many places that my previous spatch didn't find,
as pointed out by yuan linyu in various patches.
The following spatch found many more and also removes the
now unnecessary casts:
identifier p, p2;
expression len;
expression skb;
type t, t2;
+p = skb_put_zero(skb, len);
... when != p
p2 = (t2)p;
-memset(p2, 0, len);
-memset(p, 0, len);
type t, t2;
identifier p, p2;
expression skb;
t *p;
+p = skb_put_zero(skb, sizeof(t));
... when != p
p2 = (t2)p;
-memset(p2, 0, sizeof(*p));
-memset(p, 0, sizeof(*p));
expression skb, len;
-memset(skb_put(skb, len), 0, len);
+skb_put_zero(skb, len);
Apply it to the tree (with one manual fixup to keep the
comment in vxlan.c, which spatch removed.)
The default error code in pfkey_msg2xfrm_state() is -ENOBUFS. We
added a new call to security_xfrm_state_alloc() which sets "err" to zero
so there several places where we can return ERR_PTR(0) if kmalloc()
fails. The caller is expecting error pointers so it leads to a NULL
dereference.
Fixes: df71837d5024 ("[LSM-IPSec]: Security association restriction.")
There are some missing error codes here so we accidentally return NULL
instead of an error pointer. It results in a NULL pointer dereference.
Now we will force to do garbage collection if any policy removed in
xfrm_policy_flush(). But during xfrm_net_exit(). We call flow_cache_fini()
first and set set fc->percpu to NULL. Then after we call xfrm_policy_fini()
-> frxm_policy_flush() -> flow_cache_flush(), we will get NULL pointer
dereference when check percpu_empty. The code path looks like:
flow_cache_fini()
- fc->percpu = NULL
xfrm_policy_fini()
- xfrm_policy_flush()
- xfrm_garbage_collect()
- flow_cache_flush()
- flow_cache_percpu_empty()
- fcp = per_cpu_ptr(fc->percpu, cpu)
To reproduce, just add ipsec in netns and then remove the netns.
v2:
As Xin Long suggested, since only two other places need to call it. move
xfrm_garbage_collect() outside xfrm_policy_flush().
v3:
Fix subject mismatch after v2 fix.
Fixes: 35db06912189 ("xfrm: do the garbage collection after flushing policy")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Reviewed-by: Xin Long <lucien.xin@gmail.com>
Add XFRMA_ENCAP, UDP encapsulation port, to km_migrate announcement
to userland. Only add if XFRMA_ENCAP was in user migrate request.
Signed-off-by: Antony Antony <antony@phenome.org>
Reviewed-by: Richard Guy Briggs <rgb@tricolour.ca>
Add UDP encapsulation port to XFRM_MSG_MIGRATE using an optional
netlink attribute XFRMA_ENCAP.
The devices that support IKE MOBIKE extension (RFC-4555 Section 3.8)
could go to sleep for a few minutes and wake up. When it wake up the
NAT mapping could have expired, the device send a MOBIKE UPDATE_SA
message to migrate the IPsec SA. The change could be a change UDP
encapsulation port, IP address, or both.
Reported-by: Paul Wouters <pwouters@redhat.com>
The sadb_x_sec_len is stored in the unit 'byte divided by eight'.
So we have to multiply this value by eight before we can do
size checks. Otherwise we may get a slab-out-of-bounds when
we memcpy the user sec_ctx.
Fixes: df71837d502 ("[LSM-IPSec]: Security association restriction.")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Both conflict were simple overlapping changes.
In the kaweth case, Eric Dumazet's skb_cow() bug fix overlapped the
conversion of the driver in net-next to use in-netdev stats.
The parsing of sadb_x_ipsecrequest is broken in a number of ways.
First of all we're not verifying sadb_x_ipsecrequest_len. This
is needed when the structure carries addresses at the end. Worse
we don't even look at the length when we parse those optional
addresses.
The migration code had similar parsing code that's better but
it also has some deficiencies. The length is overcounted first
of all as it includes the header itself. It also fails to check
the length before dereferencing the sa_family field.
This patch fixes those problems in parse_sockaddr_pair and then
uses it in parse_ipsecrequest.
A dump may come in the middle of another dump, modifying its dump
structure members. This race condition will result in NULL pointer
dereference in kernel. So add a lock to prevent that race.
Fixes: 83321d6b9872 ("[AF_KEY]: Dump SA/SP entries non-atomically")
Signed-off-by: Yuejie Shi <syjcnss@gmail.com>
Make struct pernet_operations::id unsigned.
There are 2 reasons to do so:
1)
This field is really an index into an zero based array and
thus is unsigned entity. Using negative value is out-of-bound
access by definition.
2)
On x86_64 unsigned 32-bit data which are mixed with pointers
via array indexing or offsets added or subtracted to pointers
are preffered to signed 32-bit data.
"int" being used as an array index needs to be sign-extended
to 64-bit before being used.
void f(long *p, int i)
g(p[i]);
roughly translates to
movsx rsi, esi
mov rdi, [rsi+...]
call g
MOVSX is 3 byte instruction which isn't necessary if the variable is
unsigned because x86_64 is zero extending by default.
Now, there is net_generic() function which, you guessed it right, uses
"int" as an array index:
static inline void *net_generic(const struct net *net, int id)
ptr = ng->ptr[id - 1];
And this function is used a lot, so those sign extensions add up.
Patch snipes ~1730 bytes on allyesconfig kernel (without all junk
messing with code generation):
add/remove: 0/0 grow/shrink: 70/598 up/down: 396/-2126 (-1730)
Unfortunately some functions actually grow bigger.
This is a semmingly random artefact of code generation with register
allocator being used differently. gcc decides that some variable
needs to live in new r8+ registers and every access now requires REX
prefix. Or it is shifted into r12, so [r12+0] addressing mode has to be
used which is longer than [r8]
However, overall balance is in negative direction:
function old new delta
nfsd4_lock 3886 3959 +73
tipc_link_build_proto_msg 1096 1140 +44
mac80211_hwsim_new_radio 2776 2808 +32
tipc_mon_rcv 1032 1058 +26
svcauth_gss_legacy_init 1413 1429 +16
tipc_bcbase_select_primary 379 392 +13
nfsd4_exchange_id 1247 1260 +13
nfsd4_setclientid_confirm 782 793 +11
put_client_renew_locked 494 480 -14
ip_set_sockfn_get 730 716 -14
geneve_sock_add 829 813 -16
nfsd4_sequence_done 721 703 -18
nlmclnt_lookup_host 708 686 -22
nfsd4_lockt 1085 1063 -22
nfs_get_client 1077 1050 -27
tcf_bpf_init 1106 1076 -30
nfsd4_encode_fattr 5997 5930 -67
Total: Before=154856051, After=154854321, chg -0.00%
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
Hit the following splat testing VRF change for ipsec:
[ 113.475692] ===============================
[ 113.476194] [ INFO: suspicious RCU usage. ]
[ 113.476667] 4.2.0-rc6-1+deb7u2+clUNRELEASED #3.2.65-1+deb7u2+clUNRELEASED Not tainted
[ 113.477545] -------------------------------
[ 113.478013] /work/monster-14/dsa/kernel.git/include/linux/rcupdate.h:568 Illegal context switch in RCU read-side critical section!
[ 113.479288]
[ 113.479288] other info that might help us debug this:
[ 113.479288]
[ 113.480207]
[ 113.480207] rcu_scheduler_active = 1, debug_locks = 1
[ 113.480931] 2 locks held by setkey/6829:
[ 113.481371] #0: (&net->xfrm.xfrm_cfg_mutex){+.+.+.}, at: [<ffffffff814e9887>] pfkey_sendmsg+0xfb/0x213
[ 113.482509] #1: (rcu_read_lock){......}, at: [<ffffffff814e767f>] rcu_read_lock+0x0/0x6e
[ 113.483509]
[ 113.483509] stack backtrace:
[ 113.484041] CPU: 0 PID: 6829 Comm: setkey Not tainted 4.2.0-rc6-1+deb7u2+clUNRELEASED #3.2.65-1+deb7u2+clUNRELEASED
[ 113.485422] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5.1-0-g8936dbb-20141113_115728-nilsson.home.kraxel.org 04/01/2014
[ 113.486845] 0000000000000001 ffff88001d4c7a98 ffffffff81518af2 ffffffff81086962
[ 113.487732] ffff88001d538480 ffff88001d4c7ac8 ffffffff8107ae75 ffffffff8180a154
[ 113.488628] 0000000000000b30 0000000000000000 00000000000000d0 ffff88001d4c7ad8
[ 113.489525] Call Trace:
[ 113.489813] [<ffffffff81518af2>] dump_stack+0x4c/0x65
[ 113.490389] [<ffffffff81086962>] ? console_unlock+0x3d6/0x405
[ 113.491039] [<ffffffff8107ae75>] lockdep_rcu_suspicious+0xfa/0x103
[ 113.491735] [<ffffffff81064032>] rcu_preempt_sleep_check+0x45/0x47
[ 113.492442] [<ffffffff8106404d>] ___might_sleep+0x19/0x1c8
[ 113.493077] [<ffffffff81064268>] __might_sleep+0x6c/0x82
[ 113.493681] [<ffffffff81133190>] cache_alloc_debugcheck_before.isra.50+0x1d/0x24
[ 113.494508] [<ffffffff81134876>] kmem_cache_alloc+0x31/0x18f
[ 113.495149] [<ffffffff814012b5>] skb_clone+0x64/0x80
[ 113.495712] [<ffffffff814e6f71>] pfkey_broadcast_one+0x3d/0xff
[ 113.496380] [<ffffffff814e7b84>] pfkey_broadcast+0xb5/0x11e
[ 113.497024] [<ffffffff814e82d1>] pfkey_register+0x191/0x1b1
[ 113.497653] [<ffffffff814e9770>] pfkey_process+0x162/0x17e
[ 113.498274] [<ffffffff814e9895>] pfkey_sendmsg+0x109/0x213
In pfkey_sendmsg the net mutex is taken and then pfkey_broadcast takes
the RCU lock.
Since pfkey_broadcast takes the RCU lock the allocation argument is
pointless since GFP_ATOMIC must be used between the rcu_read_{,un}lock.
The one call outside of rcu can be done with GFP_KERNEL.
Fixes: 7f6b9dbd5afbd ("af_key: locking change")
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Pull networking updates from David Miller:
1) Add TX fast path in mac80211, from Johannes Berg.
2) Add TSO/GRO support to ibmveth, from Thomas Falcon
3) Move away from cached routes in ipv6, just like ipv4, from Martin
KaFai Lau.
4) Lots of new rhashtable tests, from Thomas Graf.
5) Run ingress qdisc lockless, from Alexei Starovoitov.
6) Allow servers to fetch TCP packet headers for SYN packets of new
connections, for fingerprinting. From Eric Dumazet.
7) Add mode parameter to pktgen, for testing receive. From Alexei
Starovoitov.
8) Cache access optimizations via simplifications of build_skb(), from
Alexander Duyck.
9) Move page frag allocator under mm/, also from Alexander.
10) Add xmit_more support to hv_netvsc, from KY Srinivasan.
11) Add a counter guard in case we try to perform endless reclassify
loops in the packet scheduler.
12) Extern flow dissector to be programmable and use it in new "Flower"
classifier. From Jiri Pirko.
13) AF_PACKET fanout rollover fixes, performance improvements, and new
statistics. From Willem de Bruijn.
14) Add netdev driver for GENEVE tunnels, from John W Linville.
15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso.
16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet.
17) Add an ECN retry fallback for the initial TCP handshake, from Daniel
Borkmann.
18) Add tail call support to BPF, from Alexei Starovoitov.
19) Add several pktgen helper scripts, from Jesper Dangaard Brouer.
20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa.
21) Favor even port numbers for allocation to connect() requests, and
odd port numbers for bind(0), in an effort to help avoid
ip_local_port_range exhaustion. From Eric Dumazet.
22) Add Cavium ThunderX driver, from Sunil Goutham.
23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata,
24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai.
25) Double TCP Small Queues default to 256K to accomodate situations
like the XEN driver and wireless aggregation. From Wei Liu.
26) Add more entropy inputs to flow dissector, from Tom Herbert.
27) Add CDG congestion control algorithm to TCP, from Kenneth Klette
Jonassen.
28) Convert ipset over to RCU locking, from Jozsef Kadlecsik.
29) Track and act upon link status of ipv4 route nexthops, from Andy
Gospodarek.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits)
bridge: vlan: flush the dynamically learned entries on port vlan delete
bridge: multicast: add a comment to br_port_state_selection about blocking state
net: inet_diag: export IPV6_V6ONLY sockopt
stmmac: troubleshoot unexpected bits in des0 & des1
net: ipv4 sysctl option to ignore routes when nexthop link is down
net: track link-status of ipv4 nexthops
net: switchdev: ignore unsupported bridge flags
net: Cavium: Fix MAC address setting in shutdown state
drivers: net: xgene: fix for ACPI support without ACPI
ip: report the original address of ICMP messages
net/mlx5e: Prefetch skb data on RX
net/mlx5e: Pop cq outside mlx5e_get_cqe
net/mlx5e: Remove mlx5e_cq.sqrq back-pointer
net/mlx5e: Remove extra spaces
net/mlx5e: Avoid TX CQE generation if more xmit packets expected
net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion
net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq()
net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them
net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues
net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device
This patch adds IV generator information to xfrm_state. This
is currently obtained from our own list of algorithm descriptions.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
In many places, the a6 field is typecasted to struct in6_addr. As the
fields are in union anyway, just add in6_addr type to the union and
get rid of the typecasting.
Modifying the uapi header is okay, the union has still the same size.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
This patch replaces a comma between expression statements by a semicolon.
A simplified version of the semantic patch that performs this
transformation is as follows:
// <smpl>
@r@
expression e1,e2,e;
type T;
identifier i;
e1
e2;
// </smpl>
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Commit f1370cc4 "xfrm: Remove useless secid field from xfrm_audit." changed
"struct xfrm_audit" to have either
{ audit_get_loginuid(current) / audit_get_sessionid(current) } or
{ INVALID_UID / -1 } pair.
This means that we can represent "struct xfrm_audit" as "bool".
This patch replaces "struct xfrm_audit" argument with "bool".
It seems to me that commit ab5f5e8b "[XFRM]: xfrm audit calls" is doing
something strange at xfrm_audit_helper_usrinfo().
If secid != 0 && security_secid_to_secctx(secid) != 0, the caller calls
audit_log_task_context() which basically does
secid != 0 && security_secid_to_secctx(secid) == 0 case
except that secid is obtained from current thread's context.
Oh, what happens if secid passed to xfrm_audit_helper_usrinfo() was
obtained from other thread's context? It might audit current thread's
context rather than other thread's context if security_secid_to_secctx()
in xfrm_audit_helper_usrinfo() failed for some reason.
Then, are all the caller of xfrm_audit_helper_usrinfo() passing either
secid obtained from current thread's context or secid == 0?
It seems to me that they are.
If I didn't miss something, we don't need to pass secid to
xfrm_audit_helper_usrinfo() because audit_log_task_context() will
obtain secid from current thread's context.
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
Documentation/devicetree/bindings/net/micrel-ks8851.txt
net/core/netpoll.c
The net/core/netpoll.c conflict is a bug fix in 'net' happening
to code which is completely removed in 'net-next'.
In micrel-ks8851.txt we simply have overlapping changes.
security_xfrm_policy_alloc can be called in atomic context so the
allocation should be done with GFP_ATOMIC. Add an argument to let the
callers choose the appropriate way. In order to do so a gfp argument
needs to be added to the method xfrm_policy_alloc_security in struct
security_operations and to the internal function
selinux_xfrm_alloc_user. After that switch to GFP_ATOMIC in the atomic
callers and leave GFP_KERNEL as before for the rest.
The path that needed the gfp argument addition is:
security_xfrm_policy_alloc -> security_ops.xfrm_policy_alloc_security ->
all users of xfrm_policy_alloc_security (e.g. selinux_xfrm_policy_alloc) ->
selinux_xfrm_alloc_user (here the allocation used to be GFP_KERNEL only)
Now adding a gfp argument to selinux_xfrm_alloc_user requires us to also
add it to security_context_to_sid which is used inside and prior to this
patch did only GFP_KERNEL allocation. So add gfp argument to
security_context_to_sid and adjust all of its callers as well.
CC: Paul Moore <paul@paul-moore.com>
CC: Dave Jones <davej@redhat.com>
CC: Steffen Klassert <steffen.klassert@secunet.com>
CC: Fan Du <fan.du@windriver.com>
CC: David S. Miller <davem@davemloft.net>
CC: LSM list <linux-security-module@vger.kernel.org>
CC: SELinux list <selinux@tycho.nsa.gov>
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
Acked-by: Paul Moore <paul@paul-moore.com>
There's a kmalloc with GFP_KERNEL in a helper
(pfkey_sadb2xfrm_user_sec_ctx) used in pfkey_compile_policy which is
called under rcu_read_lock. Adjust pfkey_sadb2xfrm_user_sec_ctx to have
a gfp argument and adjust the users.
iproute2 already defines a structure with that name, let's use another one to
avoid any conflict.
CC: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
This patch fixes commit d3623099d350 ("ipsec: add support of limited SA dump").
sadb_ext_min_len array should be updated with the new type (SADB_X_EXT_FILTER).
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
The goal of this patch is to allow userland to dump only a part of SA by
specifying a filter during the dump.
The kernel is in charge to filter SA, this avoids to generate useless netlink
traffic (it save also some cpu cycles). This is particularly useful when there
is a big number of SA set on the system.
Note that I removed the union in struct xfrm_state_walk to fix a problem on arm.
struct netlink_callback->args is defined as a array of 6 long and the first long
is used in xfrm code to flag the cb as initialized. Hence, we must have:
sizeof(struct xfrm_state_walk) <= sizeof(long) * 5.
With the union, it was false on arm (sizeof(struct xfrm_state_walk) was
sizeof(long) * 7), due to the padding.
In fact, whatever the arch is, this union seems useless, there will be always
padding after it. Removing it will not increase the size of this struct (and
reduce it on arm).
In the case when KMs have no listeners, km_query() will fail and
temporary SAs are garbage collected immediately after their allocation.
This causes strain on memory allocation, leading even to OOM since
temporary SA alloc/free cycle is performed for every packet
and garbage collection does not keep up the pace.
The sane thing to do is to make sure we have audience before
temporary SA allocation.
Signed-off-by: Horia Geanta <horia.geanta@freescale.com>
