path: root/net/key
2008-10-01af_key: Free dumping state on socket closeTimo Teras
Fix a xfrm_{state,policy}_walk leak if pfkey socket is closed while dumping is on-going. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-12key: Use xfrm_addr_cmp() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-06-12key: Share common code path to extract address from sockaddr{}.YOSHIFUJI Hideaki
2008-06-12key: Share common code path to fill sockaddr{}.YOSHIFUJI Hideaki
2008-06-12key: Introduce pfkey_sockaddr_len() for raw sockaddr{} length.YOSHIFUJI Hideaki
2008-06-10ipsec: pfkey should ignore events when no listenersJamal Hadi Salim
When pfkey has no km listeners, it still does a lot of work before finding out there aint nobody out there. If a tree falls in a forest and no one is around to hear it, does it make a sound? In this case it makes a lot of noise: With this short-circuit adding 10s of thousands of SAs using netlink improves performance by ~10%. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-21af_key: Fix selector family initialization.Kazunori MIYAZAWA
This propagates the xfrm_user fix made in commit bcf0dda8d2408fe1c1040cdec5a98e5fcad2ac72 ("[XFRM]: xfrm_user: fix selector family initialization") Based upon a bug report from, and tested by, Alan Swanson. Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-28Audit: collect sessionid in netlink messagesEric Paris
Previously I added sessionid output to all audit messages where it was available but we still didn't know the sessionid of the sender of netlink messages. This patch adds that information to netlink messages so we can audit who sent netlink messages. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-24af_key: Fix af_key.c compiler warningBrian Haley
net/key/af_key.c: In function ‘pfkey_spddelete’: net/key/af_key.c:2359: warning: ‘pol_ctx’ may be used uninitialized in this function When CONFIG_SECURITY_NETWORK_XFRM isn't set, security_xfrm_policy_alloc() is an inline that doesn't set pol_ctx, so this seemed like the easiest fix short of using *uninitialized_var(pol_ctx). Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-22[IPSEC]: Fix catch-22 with algorithm IDs above 31Herbert Xu
As it stands it's impossible to use any authentication algorithms with an ID above 31 portably. It just happens to work on x86 but fails miserably on ppc64. The reason is that we're using a bit mask to check the algorithm ID but the mask is only 32 bits wide. After looking at how this is used in the field, I have concluded that in the long term we should phase out state matching by IDs because this is made superfluous by the reqid feature. For current applications, the best solution IMHO is to allow all algorithms when the bit masks are all ~0. The following patch does exactly that. This bug was identified by IBM when testing on the ppc64 platform using the NULL authentication algorithm which has an ID of 251. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12LSM: Make the Labeled IPsec hooks more stack friendlyPaul Moore
The xfrm_get_policy() and xfrm_add_pol_expire() put some rather large structs on the stack to work around the LSM API. This patch attempts to fix that problem by changing the LSM API to require only the relevant "security" pointers instead of the entire SPD entry; we do this for all of the security_xfrm_policy*() functions to keep things consistent. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/rndis_host.c drivers/net/wireless/b43/dma.c net/ipv6/ndisc.c
2008-03-24[IPSEC]: Fix inter address family IPsec tunnel handling.Kazunori MIYAZAWA
2008-03-03[AF_KEY]: Dump SA/SP entries non-atomicallyTimo Teras
Stop dumping of entries when af_key socket receive queue is getting full and continue it later when there is more room again. This fixes dumping of large databases. Currently the entries not fitting into the receive queue are just dropped (including the end-of-dump message) which can confuse applications. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[XFRM]: Speed up xfrm_policy and xfrm_state walkingTimo Teras
Change xfrm_policy and xfrm_state walking algorithm from O(n^2) to O(n). This is achieved adding the entries to one more list which is used solely for walking the entries. This also fixes some races where the dump can have duplicate or missing entries when the SPD/SADB is modified during an ongoing dump. Dumping SADB with 20000 entries using "time ip xfrm state" the sys time dropped from 1.012s to 0.080s. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-26[AF_KEY]: Fix oops by converting to proc_net_*().David S. Miller
To make sure the procfs visibility occurs after the ->proc_fs ops are setup, use proc_net_fops_create() and proc_net_remove(). This also fixes an OOPS after module unload in that the name string for remove was wrong, so it wouldn't actually be removed. That bug was introduced by commit 61145aa1a12401ac71bcc450a58c773dd6e2bfb9 ("[KEY]: Clean up proc files creation a bit.") Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-14[AF_KEY]: Fix bug in spdaddKazunori MIYAZAWA
This patch fix a BUG when adding spds which have same selector. Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-09[KEY]: Convert net/pfkey to use seq files.Pavel Emelyanov
The seq files API disposes the caller of the difficulty of checking file position, the length of data to produce and the size of provided buffer. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-09[KEY]: Clean up proc files creation a bit.Pavel Emelyanov
Mainly this removes ifdef-s from inside the ipsec_pfkey_init. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-01[PATCH] switch audit_get_loginuid() to task_struct *Al Viro
all callers pass something->audit_context Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-01-28[XFRM] xfrm_policy_destroy: Rename and relative fixes.WANG Cong
Since __xfrm_policy_destroy is used to destory the resources allocated by xfrm_policy_alloc. So using the name __xfrm_policy_destroy is not correspond with xfrm_policy_alloc. Rename it to xfrm_policy_destroy. And along with some instances that call xfrm_policy_alloc but not using xfrm_policy_destroy to destroy the resource, fix them. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-20[AF_KEY]: Fix skb leak on pfkey_send_migrate() errorPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-19[IPSEC]: Avoid undefined shift operation when testing algorithm IDHerbert Xu
The aalgos/ealgos fields are only 32 bits wide. However, af_key tries to test them with the expression 1 << id where id can be as large as 253. This produces different behaviour on different architectures. The following patch explicitly checks whether ID is greater than 31 and fails the check if that's the case. We cannot easily extend the mask to be longer than 32 bits due to exposure to user-space. Besides, this whole interface is obsolete anyway in favour of the xfrm_user interface which doesn't use this bit mask in templates (well not within the kernel anyway). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-26[IPSEC]: Temporarily remove locks around copying of non-atomic fieldsHerbert Xu
The change 050f009e16f908932070313c1745d09dc69fd62b [IPSEC]: Lock state when copying non-atomic fields to user-space caused a regression. Ingo Molnar reports that it causes a potential dead-lock found by the lock validator as it tries to take x->lock within xfrm_state_lock while numerous other sites take the locks in opposite order. For 2.6.24, the best fix is to simply remove the added locks as that puts us back in the same state as we've been in for years. For later kernels a proper fix would be to reverse the locking order for every xfrm state user such that if x->lock is taken together with xfrm_state_lock then it is to be taken within it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-22[PFKEY]: Sending an SADB_GET responds with an SADB_GETCharles Hardin
From: Charles Hardin <chardin@2wire.com> Kernel needs to respond to an SADB_GET with the same message type to conform to the RFC 2367 Section 3.1.5 Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-30[AF_KEY]: suppress a warning for 64k pages.Stephen Rothwell
On PowerPC allmodconfig build we get this: net/key/af_key.c:400: warning: comparison is always false due to limited range of data type Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Lock state when copying non-atomic fields to user-spaceHerbert Xu
This patch adds locking so that when we're copying non-atomic fields such as life-time or coaddr to user-space we don't get a partial result. For af_key I've changed every instance of pfkey_xfrm_state2msg apart from expiration notification to include the keys and life-times. This is in-line with XFRM behaviour. The actual cases affected are: * pfkey_getspi: No change as we don't have any keys to copy. * key_notify_sa: + ADD/UPD: This wouldn't work otherwise. + DEL: It can't hurt. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move common code into xfrm_alloc_spiHerbert Xu
This patch moves some common code that conceptually belongs to the xfrm core from af_key/xfrm_user into xfrm_alloc_spi. In particular, the spin lock on the state is now taken inside xfrm_alloc_spi. Previously it also protected the construction of the response PF_KEY/XFRM messages to user-space. This is inconsistent as other identical constructions are not protected by the state lock. This is bad because they in fact should be protected but only in certain spots (so as not to hold the lock for too long which may cause packet drops). The SPI byte order conversion has also been moved. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM]: xfrm audit callsJoy Latten
This patch modifies the current ipsec audit layer by breaking it up into purpose driven audit calls. So far, the only audit calls made are when add/delete an SA/policy. It had been discussed to give each key manager it's own calls to do this, but I found there to be much redundnacy since they did the exact same things, except for how they got auid and sid, so I combined them. The below audit calls can be made by any key manager. Hopefully, this is ok. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] Cleanup: DIV_ROUND_UPIlpo Järvinen
2007-08-02[PF_KEY]: Fix ipsec not working in 2.6.23-rc1-git10Joy Latten
Although an ipsec SA was established, kernel couldn't seem to find it. I think since we are now using "x->sel.family" instead of "family" in the xfrm_selector_match() called in xfrm_state_find(), af_key needs to set this field too, just as xfrm_user. In af_key.c, x->sel.family only gets set when there's an ext_hdrs[SADB_EXT_ADDRESS_PROXY-1] which I think is for tunnel. I think pfkey needs to also set the x->sel.family field when it is 0. Tested with below patch, and ipsec worked when using pfkey. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-26net/* misc endianness annotationsAl Viro
2007-06-07xfrm: Add security check before flushing SAD/SPDJoy Latten
Currently we check for permission before deleting entries from SAD and SPD, (see security_xfrm_policy_delete() security_xfrm_state_delete()) However we are not checking for authorization when flushing the SPD and the SAD completely. It was perhaps missed in the original security hooks patch. This patch adds a security check when flushing entries from the SAD and SPD. It runs the entire database and checks each entry for a denial. If the process attempting the flush is unable to remove all of the entries a denial is logged the the flush function returns an error without removing anything. This is particularly useful when a process may need to create or delete its own xfrm entries used for things like labeled networking but that same process should not be able to delete other entries or flush the entire database. Signed-off-by: Joy Latten<latten@austin.ibm.com> Signed-off-by: Eric Paris <eparis@parisplace.org> Signed-off-by: James Morris <jmorris@namei.org>
2007-05-19[IPSEC] pfkey: Load specific algorithm in pfkey_add rather than allHerbert Xu
This is a natural extension of the changeset [XFRM]: Probe selected algorithm only. which only removed the probe call for xfrm_user. This patch does exactly the same thing for af_key. In other words, we load the algorithm requested by the user rather than everything when adding xfrm states in af_key. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-18[IPSEC] af_key: Fix thinko in pfkey_xfrm_policy2msg()David S. Miller
Make sure to actually assign the determined mode to rq->sadb_x_ipsecrequest_mode. Noticed by Joe Perches. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-17[KEY]: Fix conversion between IPSEC_MODE_xxx and XFRM_MODE_xxx.Kazunori MIYAZAWA
We should not blindly convert between IPSEC_MODE_xxx and XFRM_MODE_xxx just by incrementing / decrementing because the assumption is not true any longer. Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org> Singed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-03-07[IPSEC]: xfrm audit hook misplaced in pfkey_delete and xfrm_del_saEric Paris
Inside pfkey_delete and xfrm_del_sa the audit hooks were not called if there was any permission/security failures in attempting to do the del operation (such as permission denied from security_xfrm_state_delete). This patch moves the audit hook to the exit path such that all failures (and successes) will actually get audited. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Venkat Yekkirala <vyekkirala@trustedcs.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-07[IPSEC]: Add xfrm policy change auditing to pfkey_spdgetEric Paris
pfkey_spdget neither had an LSM security hook nor auditing for the removal of xfrm_policy structs. The security hook was added when it was moved into xfrm_policy_byid instead of the callers to that function by my earlier patch and this patch adds the auditing hooks as well. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Venkat Yekkirala <vyekkirala@trustedcs.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-07[IPSEC]: xfrm_policy delete security check misplacedEric Paris
The security hooks to check permissions to remove an xfrm_policy were actually done after the policy was removed. Since the unlinking and deletion are done in xfrm_policy_by* functions this moves the hooks inside those 2 functions. There we have all the information needed to do the security check and it can be done before the deletion. Since auditing requires the result of that security check err has to be passed back and forth from the xfrm_policy_by* functions. This patch also fixes a bug where a deletion that failed the security check could cause improper accounting on the xfrm_policy (xfrm_get_policy didn't have a put on the exit path for the hold taken by xfrm_policy_by*) It also fixes the return code when no policy is found in xfrm_add_pol_expire. In old code (at least back in the 2.6.18 days) err wasn't used before the return when no policy is found and so the initialization would cause err to be ENOENT. But since err has since been used above when we don't get a policy back from the xfrm_policy_by* function we would always return 0 instead of the intended ENOENT. Also fixed some white space damage in the same area. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Venkat Yekkirala <vyekkirala@trustedcs.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[XFRM]: Fix OOPSes in xfrm_audit_log().David S. Miller
Make sure that this function is called correctly, and add BUG() checking to ensure the arguments are sane. Based upon a patch by Joy Latten. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] KEY: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[PFKEYV2]: Extension for dynamic update of endpoint address(es)Shinta Sugimoto
Extend PF_KEYv2 framework so that user application can take advantage of MIGRATE feature via PF_KEYv2 interface. User application can either send or receive an MIGRATE message to/from PF_KEY socket. Detail information can be found in the internet-draft <draft-sugimoto-mip6-pfkey-migrate>. Signed-off-by: Shinta Sugimoto <shinta.sugimoto@ericsson.com> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-06audit: Add auditing to ipsecJoy Latten
An audit message occurs when an ipsec SA or ipsec policy is created/deleted. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
