path: root/net/l2tp/Kconfig
2010-04-03l2tp: Add debugfs files for dumping l2tp debug infoJames Chapman
The existing pppol2tp driver exports debug info to /proc/net/pppol2tp. Rather than adding info to that file for the new functionality added in this patch series, we add new files in debugfs, leaving the old /proc file for backwards compatibility (L2TPv2 only). Currently only one file is provided: l2tp/tunnels, which lists internal debug info for all l2tp tunnels and sessions. More files may be added later. The info is for debug and problem analysis only - userspace apps should use netlink to obtain status about l2tp tunnels and sessions. Although debugfs does not support net namespaces, the tunnels and sessions dumped in l2tp/tunnels are only those in the net namespace of the process reading the file. Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03l2tp: Add L2TP ethernet pseudowire supportJames Chapman
This driver presents a regular net_device for each L2TP ethernet pseudowire instance. These interfaces are named l2tpethN by default, though userspace can specify an alternative name when the L2TP session is created, if preferred. When the pseudowire is established, regular Linux networking utilities may be used to configure the interface, i.e. give it IP address info or add it to a bridge. Any data passed over the interface is carried over an L2TP tunnel. Signed-off-by: James Chapman <jchapman@katalix.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03l2tp: Add L2TPv3 IP encapsulation (no UDP) supportJames Chapman
This patch adds a new L2TPIP socket family and modifies the core to handle the case where there is no UDP header in the L2TP packet. L2TP/IP uses IP protocol 115. Since L2TP/UDP and L2TP/IP packets differ in layout, the datapath packet handling code needs changes too. Userspace uses an L2TPIP socket instead of a UDP socket when IP encapsulation is required. We can't use raw sockets for this because the semantics of raw sockets don't lend themselves to the socket-per-tunnel model - we need to Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03l2tp: Add L2TPv3 protocol supportJames Chapman
The L2TPv3 protocol changes the layout of the L2TP packet header. Tunnel and session ids change from 16-bit to 32-bit values, data sequence numbers change from 16-bit to 24-bit values and PPP-specific fields are moved into protocol-specific subheaders. Although this patch introduces L2TPv3 protocol support, there are no userspace interfaces to create L2TPv3 sessions yet. Signed-off-by: James Chapman <jchapman@katalix.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03l2tp: Split pppol2tp patch into separate l2tp and ppp partsJames Chapman
This patch splits the pppol2tp driver into separate L2TP and PPP parts to prepare for L2TPv3 support. In L2TPv3, protocols other than PPP can be carried, so this split creates a common L2TP core that will handle the common L2TP bits which protocol support modules such as PPP will use. Note that the existing pppol2tp module is split into l2tp_core and l2tp_ppp by this change. There are no feature changes here. Internally, however, there are significant changes, mostly to handle the separation of PPP-specific data from the L2TP session and to provide hooks in the core for modules like PPP to access. Signed-off-by: James Chapman <jchapman@katalix.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
