path: root/net/l2tp
2015-01-18netlink: make nlmsg_end() and genlmsg_end() voidJohannes Berg
Contrary to common expectations for an "int" return, these functions return only a positive value -- if used correctly they cannot even return 0 because the message header will necessarily be in the skb. This makes the very common pattern of if (genlmsg_end(...) < 0) { ... } be a whole bunch of dead code. Many places also simply do return nlmsg_end(...); and the caller is expected to deal with it. This also commonly (at least for me) causes errors, because it is very common to write if (my_function(...)) /* error condition */ and if my_function() does "return nlmsg_end()" this is of course wrong. Additionally, there's not a single place in the kernel that actually needs the message length returned, and if anyone needs it later then it'll be very easy to just use skb->len there. Remove this, and make the functions void. This removes a bunch of dead code as described above. The patch adds lines because I did - return nlmsg_end(...); + nlmsg_end(...); + return 0; I could have preserved all the function's return values by returning skb->len, but instead I've audited all the places calling the affected functions and found that none cared. A few places actually compared the return value with <= 0 in dump functionality, but that could just be changed to < 0 with no change in behaviour, so I opted for the more efficient version. One instance of the error I've made numerous times now is also present in net/phonet/pn_netlink.c in the route_dumpit() function - it didn't check for <0 or <=0 and thus broke out of the loop every single time. I've preserved this since it will (I think) have caused the messages to userspace to be formatted differently with just a single message for every SKB returned to userspace. It's possible that this isn't needed for the tools that actually use this, but I don't even know what they are so couldn't test that changing this behaviour would be acceptable. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-31l2tp : multicast notification to the registered listenersBill Hong
Previously l2tp module did not provide any means for the user space to get notified when tunnels/sessions are added/modified/deleted. This change contains the following - create a multicast group for the listeners to register. - notify the registered listeners when the tunnels/sessions are created/modified/deleted. Signed-off-by: Bill Hong <bhong@brocade.com> Reviewed-by: Stephen Hemminger <stephen@networkplumber.org> Reviewed-by: Sven-Thorsten Dietrich <sven@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09ip_generic_getfrag, udplite_getfrag: switch to passing msghdrAl Viro
2014-11-24new helper: memcpy_from_msg()Al Viro
2014-11-21l2tp_eth: allow to set a specific mac addressAlexander Couzens
Signed-off-by: Alexander Couzens <lynxis@fe80.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-05net: Add and use skb_copy_datagram_msg() helper.David S. Miller
This encapsulates all of the skb_copy_datagram_iovec() callers with call argument signature "skb, offset, msghdr->msg_iov, length". When we move to iov_iters in the networking, the iov_iter object will sit in the msghdr. Having a helper like this means there will be less places to touch during that transformation. Based upon descriptions and patch from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-19l2tp: Refactor l2tp core driver to make use of the common UDP tunnel functionsAndy Zhou
Simplify l2tp implementation using common UDP tunnel APIs. Signed-off-by: Andy Zhou <azhou@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-09-05l2tp: fix missing line continuationAndy Zhou
This syntax error was covered by L2TP_REFCNT_DEBUG not being set by default. Signed-off-by: Andy Zhou <azhou@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05l2tp: fix race while getting PMTU on PPP pseudo-wireGuillaume Nault
Use dst_entry held by sk_dst_get() to retrieve tunnel's PMTU. The dst_mtu(__sk_dst_get(tunnel->sock)) call was racy. __sk_dst_get() could return NULL if tunnel->sock->sk_dst_cache was reset just before the call, thus making dst_mtu() dereference a NULL pointer: [ 1937.661598] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 [ 1937.664005] IP: [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] PGD daf0c067 PUD d9f93067 PMD 0 [ 1937.664005] Oops: 0000 [#1] SMP [ 1937.664005] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6table_filter ip6_tables iptable_filter ip_tables ebtable_nat ebtables x_tables udp_tunnel pppoe pppox ppp_generic slhc deflate ctr twofish_generic twofish_x86_64_3way xts lrw gf128mul glue_helper twofish_x86_64 twofish_common blowfish_generic blowfish_x86_64 blowfish_common des_generic cbc xcbc rmd160 sha512_generic hmac crypto_null af_key xfrm_algo 8021q garp bridge stp llc tun atmtcp clip atm ext3 mbcache jbd iTCO_wdt coretemp kvm_intel iTCO_vendor_support kvm pcspkr evdev ehci_pci lpc_ich mfd_core i5400_edac edac_core i5k_amb shpchp button processor thermal_sys xfs crc32c_generic libcrc32c dm_mod usbhid sg hid sr_mod sd_mod cdrom crc_t10dif crct10dif_common ata_generic ahci ata_piix tg3 libahci libata uhci_hcd ptp ehci_hcd pps_core usbcore scsi_mod libphy usb_common [last unloaded: l2tp_core] [ 1937.664005] CPU: 0 PID: 10022 Comm: l2tpstress Tainted: G O 3.17.0-rc1 #1 [ 1937.664005] Hardware name: HP ProLiant DL160 G5, BIOS O12 08/22/2008 [ 1937.664005] task: ffff8800d8fda790 ti: ffff8800c43c4000 task.ti: ffff8800c43c4000 [ 1937.664005] RIP: 0010:[<ffffffffa049db88>] [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] RSP: 0018:ffff8800c43c7de8 EFLAGS: 00010282 [ 1937.664005] RAX: ffff8800da8a7240 RBX: ffff8800d8c64600 RCX: 000001c325a137b5 [ 1937.664005] RDX: 8c6318c6318c6320 RSI: 000000000000010c RDI: 0000000000000000 [ 1937.664005] RBP: ffff8800c43c7ea8 R08: 0000000000000000 R09: 0000000000000000 [ 1937.664005] R10: ffffffffa048e2c0 R11: ffff8800d8c64600 R12: ffff8800ca7a5000 [ 1937.664005] R13: ffff8800c439bf40 R14: 000000000000000c R15: 0000000000000009 [ 1937.664005] FS: 00007fd7f610f700(0000) GS:ffff88011a600000(0000) knlGS:0000000000000000 [ 1937.664005] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 1937.664005] CR2: 0000000000000020 CR3: 00000000d9d75000 CR4: 00000000000027e0 [ 1937.664005] Stack: [ 1937.664005] ffffffffa049da80 ffff8800d8fda790 000000000000005b ffff880000000009 [ 1937.664005] ffff8800daf3f200 0000000000000003 ffff8800c43c7e48 ffffffff81109b57 [ 1937.664005] ffffffff81109b0e ffffffff8114c566 0000000000000000 0000000000000000 [ 1937.664005] Call Trace: [ 1937.664005] [<ffffffffa049da80>] ? pppol2tp_connect+0x235/0x41e [l2tp_ppp] [ 1937.664005] [<ffffffff81109b57>] ? might_fault+0x9e/0xa5 [ 1937.664005] [<ffffffff81109b0e>] ? might_fault+0x55/0xa5 [ 1937.664005] [<ffffffff8114c566>] ? rcu_read_unlock+0x1c/0x26 [ 1937.664005] [<ffffffff81309196>] SYSC_connect+0x87/0xb1 [ 1937.664005] [<ffffffff813e56f7>] ? sysret_check+0x1b/0x56 [ 1937.664005] [<ffffffff8107590d>] ? trace_hardirqs_on_caller+0x145/0x1a1 [ 1937.664005] [<ffffffff81213dee>] ? trace_hardirqs_on_thunk+0x3a/0x3f [ 1937.664005] [<ffffffff8114c262>] ? spin_lock+0x9/0xb [ 1937.664005] [<ffffffff813092b4>] SyS_connect+0x9/0xb [ 1937.664005] [<ffffffff813e56d2>] system_call_fastpath+0x16/0x1b [ 1937.664005] Code: 10 2a 84 81 e8 65 76 bd e0 65 ff 0c 25 10 bb 00 00 4d 85 ed 74 37 48 8b 85 60 ff ff ff 48 8b 80 88 01 00 00 48 8b b8 10 02 00 00 <48> 8b 47 20 ff 50 20 85 c0 74 0f 83 e8 28 89 83 10 01 00 00 89 [ 1937.664005] RIP [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] RSP <ffff8800c43c7de8> [ 1937.664005] CR2: 0000000000000020 [ 1939.559375] ---[ end trace 82d44500f28f8708 ]--- Fixes: f34c4a35d879 ("l2tp: take PMTU from tunnel UDP socket") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-01l2tp: Enable checksum unnecessary conversions for l2tp/UDP socketsTom Herbert
Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-31net: use inet6_iif instead of IP6CB()->iifDuan Jiong
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-07-15net: set name_assign_type in alloc_netdev()Tom Gundersen
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert all users to pass NET_NAME_UNKNOWN. Coccinelle patch: @@ expression sizeof_priv, name, setup, txqs, rxqs, count; @@ ( -alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs) +alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs) | -alloc_netdev_mq(sizeof_priv, name, setup, count) +alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count) | -alloc_netdev(sizeof_priv, name, setup) +alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup) ) v9: move comments here from the wrong commit Signed-off-by: Tom Gundersen <teg@jklm.no> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-14net/l2tp: don't fall back on UDP [get|set]sockoptSasha Levin
The l2tp [get|set]sockopt() code has fallen back to the UDP functions for socket option levels != SOL_PPPOL2TP since day one, but that has never actually worked, since the l2tp socket isn't an inet socket. As David Miller points out: "If we wanted this to work, it'd have to look up the tunnel and then use tunnel->sk, but I wonder how useful that would be" Since this can never have worked so nobody could possibly have depended on that functionality, just remove the broken code and return -EINVAL. Reported-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: James Chapman <jchapman@katalix.com> Acked-by: David Miller <davem@davemloft.net> Cc: Phil Turnbull <phil.turnbull@oracle.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Willy Tarreau <w@1wt.eu> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-14l2tp: Call udp_sock_createTom Herbert
In l2tp driver call common function udp_sock_create to create the listener UDP port. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-04l2tp: call udp{6}_set_csumTom Herbert
Call common functions to set checksum for UDP tunnel. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-23l2tp: Add support for zero IPv6 checksumsTom Herbert
Added new L2TP configuration options to allow TX and RX of zero checksums in IPv6. Default is not to use them. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-23net: Split sk_no_check into sk_no_check_{rx,tx}Tom Herbert
Define separate fields in the sock structure for configuring disabling checksums in both TX and RX-- sk_no_check_tx and sk_no_check_rx. The SO_NO_CHECK socket option only affects sk_no_check_tx. Also, removed UDP_CSUM_* defines since they are no longer necessary. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-23net: Eliminate no_check from protoswTom Herbert
It doesn't seem like an protocols are setting anything other than the default, and allowing to arbitrarily disable checksums for a whole protocol seems dangerous. This can be done on a per socket basis. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-12net: rename local_df to ignore_dfWANG Cong
As suggested by several people, rename local_df to ignore_df, since it means "ignore df bit if it is set". Cc: Maciej Żenczykowski <maze@google.com> Cc: Florian Westphal <fw@strlen.de> Cc: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-08l2tp: Remove UDP checksum verificationTom Herbert
Validating the UDP checksum is now done in UDP before handing packets to the encapsulation layer. Note that this also eliminates the "feature" where L2TP can ignore a non-zero UDP checksum (doing this was contrary to RFC 1122). Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-30net: ipv6: Introduce ip6_sk_dst_hoplimit.Lorenzo Colitti
This replaces 6 identical code snippets with a call to a new static inline function. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-15ipv4: add a sock pointer to ip_queue_xmit()Eric Dumazet
ip_queue_xmit() assumes the skb it has to transmit is attached to an inet socket. Commit 31c70d5956fc ("l2tp: keep original skb ownership") changed l2tp to not change skb ownership and thus broke this assumption. One fix is to add a new 'struct sock *sk' parameter to ip_queue_xmit(), so that we do not assume skb->sk points to the socket used by l2tp tunnel. Fixes: 31c70d5956fc ("l2tp: keep original skb ownership") Reported-by: Zhan Jianyu <nasa4836@gmail.com> Tested-by: Zhan Jianyu <nasa4836@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-09l2tp: take PMTU from tunnel UDP socketDmitry Petukhov
When l2tp driver tries to get PMTU for the tunnel destination, it uses the pointer to struct sock that represents PPPoX socket, while it should use the pointer that represents UDP socket of the tunnel. Signed-off-by: Dmitry Petukhov <dmgenp@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Here is my initial pull request for the networking subsystem during this merge window: 1) Support for ESN in AH (RFC 4302) from Fan Du. 2) Add full kernel doc for ethtool command structures, from Ben Hutchings. 3) Add BCM7xxx PHY driver, from Florian Fainelli. 4) Export computed TCP rate information in netlink socket dumps, from Eric Dumazet. 5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas Dichtel. 6) Convert many drivers to pci_enable_msix_range(), from Alexander Gordeev. 7) Record SKB timestamps more efficiently, from Eric Dumazet. 8) Switch to microsecond resolution for TCP round trip times, also from Eric Dumazet. 9) Clean up and fix 6lowpan fragmentation handling by making use of the existing inet_frag api for it's implementation. 10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss. 11) Auto size SKB lengths when composing netlink messages based upon past message sizes used, from Eric Dumazet. 12) qdisc dumps can take a long time, add a cond_resched(), From Eric Dumazet. 13) Sanitize netpoll core and drivers wrt. SKB handling semantics. Get rid of never-used-in-tree netpoll RX handling. From Eric W Biederman. 14) Support inter-address-family and namespace changing in VTI tunnel driver(s). From Steffen Klassert. 15) Add Altera TSE driver, from Vince Bridgers. 16) Optimizing csum_replace2() so that it doesn't adjust the checksum by checksumming the entire header, from Eric Dumazet. 17) Expand BPF internal implementation for faster interpreting, more direct translations into JIT'd code, and much cleaner uses of BPF filtering in non-socket ocntexts. From Daniel Borkmann and Alexei Starovoitov" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits) netpoll: Use skb_irq_freeable to make zap_completion_queue safe. net: Add a test to see if a skb is freeable in irq context qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port' net: ptp: move PTP classifier in its own file net: sxgbe: make "core_ops" static net: sxgbe: fix logical vs bitwise operation net: sxgbe: sxgbe_mdio_register() frees the bus Call efx_set_channels() before efx->type->dimension_resources() xen-netback: disable rogue vif in kthread context net/mlx4: Set proper build dependancy with vxlan be2net: fix build dependency on VxLAN mac802154: make csma/cca parameters per-wpan mac802154: allow only one WPAN to be up at any given time net: filter: minor: fix kdoc in __sk_run_filter netlink: don't compare the nul-termination in nla_strcmp can: c_can: Avoid led toggling for every packet. can: c_can: Simplify TX interrupt cleanup can: c_can: Store dlc private can: c_can: Reduce register access can: c_can: Make the code readable ...
2014-03-31Merge branch 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "PREPARE_[DELAYED_]WORK() were used to change the work function of work items without fully reinitializing it; however, this makes workqueue consider the work item as a different one from before and allows the work item to start executing before the previous instance is finished which can lead to extremely subtle issues which are painful to debug. The interface has never been popular. This pull request contains patches to remove existing usages and kill the interface. As one of the changes was routed during the last devel cycle and another depended on a pending change in nvme, for-3.15 contains a couple merge commits. In addition, interfaces which were deprecated quite a while ago - __cancel_delayed_work() and WQ_NON_REENTRANT - are removed too" * 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: remove deprecated WQ_NON_REENTRANT workqueue: Spelling s/instensive/intensive/ workqueue: remove PREPARE_[DELAYED_]WORK() staging/fwserial: don't use PREPARE_WORK afs: don't use PREPARE_WORK nvme: don't use PREPARE_WORK usb: don't use PREPARE_DELAYED_WORK floppy: don't use PREPARE_[DELAYED_]WORK ps3-vuart: don't use PREPARE_WORK wireless/rt2x00: don't use PREPARE_WORK in rt2800usb.c workqueue: Remove deprecated __cancel_delayed_work()
2014-03-29workqueue: remove deprecated WQ_NON_REENTRANTZhangZhen
Tejun Heo has made WQ_NON_REENTRANT useless in the dbf2576e37 ("workqueue: make all workqueues non-reentrant"). So remove its usages and definition. This patch doesn't introduce any behavior changes. tj: minor description updates. Signed-off-by: ZhangZhen <zhenzhang.zhang@huawei.com> Sigend-off-by: Tejun Heo <tj@kernel.org> Acked-by: James Chapman <jchapman@katalix.com> Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
2014-03-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c drivers/net/xen-netback/netback.c Both the r8152 and netback conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-10l2tp: fix unused variable warningEric Dumazet
net/l2tp/l2tp_core.c:1111:15: warning: unused variable 'sk' [-Wunused-variable] Fixes: 31c70d5956fc ("l2tp: keep original skb ownership") Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-07l2tp: keep original skb ownershipEric Dumazet
There is no reason to orphan skb in l2tp. This breaks things like per socket memory limits, TCP Small queues... Fix this before more people copy/paste it. This is very similar to commit 8f646c922d550 ("vxlan: keep original skb ownership") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-06l2tp: fix userspace reception on plain L2TP socketsGuillaume Nault
As pppol2tp_recv() never queues up packets to plain L2TP sockets, pppol2tp_recvmsg() never returns data to userspace, thus making the recv*() system calls unusable. Instead of dropping packets when the L2TP socket isn't bound to a PPP channel, this patch adds them to its reception queue. Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-06l2tp: fix manual sequencing (de)activation in L2TPv2Guillaume Nault
Commit e0d4435f "l2tp: Update PPP-over-L2TP driver to work over L2TPv3" broke the PPPOL2TP_SO_SENDSEQ setsockopt. The L2TP header length was previously computed by pppol2tp_l2t_header_len() before each call to l2tp_xmit_skb(). Now that header length is retrieved from the hdr_len session field, this field must be updated every time the L2TP header format is modified, or l2tp_xmit_skb() won't push the right amount of data for the L2TP header. This patch uses l2tp_session_set_header_len() to adjust hdr_len every time sequencing is (de)activated from userspace (either by the PPPOL2TP_SO_SENDSEQ setsockopt or the L2TP_ATTR_SEND_SEQ netlink attribute). Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-13net: remove unnecessary return'sstephen hemminger
One of my pet coding style peeves is the practice of adding extra return; at the end of function. Kill several instances of this in network code. I suppose some coccinelle wizardy could do this automatically. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-21ipv6: protect protocols not handling ipv4 from v4 connection/bind attemptsHannes Frederic Sowa
Some ipv6 protocols cannot handle ipv4 addresses, so we must not allow connecting and binding to them. sendmsg logic does already check msg->name for this but must trust already connected sockets which could be set up for connection to ipv4 address family. Per-socket flag ipv6only is of no use here, as it is under users control by setsockopt. Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13l2tp: make local functions staticstephen hemminger
Avoid needless export of local functions Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Acked-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next Steffen Klassert says: ==================== pull request (net-next): ipsec-next 2013-12-19 1) Use the user supplied policy index instead of a generated one if present. From Fan Du. 2) Make xfrm migration namespace aware. From Fan Du. 3) Make the xfrm state and policy locks namespace aware. From Fan Du. 4) Remove ancient sleeping when the SA is in acquire state, we now queue packets to the policy instead. This replaces the sleeping code. 5) Remove FLOWI_FLAG_CAN_SLEEP. This was used to notify xfrm about the posibility to sleep. The sleeping code is gone, so remove it. 6) Check user specified spi for IPComp. Thr spi for IPcomp is only 16 bit wide, so check for a valid value. From Fan Du. 7) Export verify_userspi_info to check for valid user supplied spi ranges with pfkey and netlink. From Fan Du. 8) RFC3173 states that if the total size of a compressed payload and the IPComp header is not smaller than the size of the original payload, the IP datagram must be sent in the original non-compressed form. These packets are dropped by the inbound policy check because they are not transformed. Document the need to set 'level use' for IPcomp to receive such packets anyway. From Fan Du. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-10ipv6: do not erase dst address with flow label destinationFlorent Fourcot
This patch is following b579035ff766c9412e2b92abf5cab794bff102b6 "ipv6: remove old conditions on flow label sharing" Since there is no reason to restrict a label to a destination, we should not erase the destination value of a socket with the value contained in the flow label storage. This patch allows to really have the same flow label to more than one destination. Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr> Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06net: Remove FLOWI_FLAG_CAN_SLEEPSteffen Klassert
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility to sleep until the needed states are resolved. This code is gone, so FLOWI_FLAG_CAN_SLEEP is not needed anymore. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-11-23inet: fix addr_len/msg->msg_namelen assignment in recv_error and rxpmtu ↵Hannes Frederic Sowa
functions Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage of uninitialized memory to user in recv syscalls") conditionally updated addr_len if the msg_name is written to. The recv_error and rxpmtu functions relied on the recvmsg functions to set up addr_len before. As this does not happen any more we have to pass addr_len to those functions as well and set it to the size of the corresponding sockaddr length. This broke traceroute and such. Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls") Reported-by: Brad Spengler <spender@grsecurity.net> Reported-by: Tom Labanowski Cc: mpb <mpb.mail@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: only pass array to genl_register_family_with_ops()Johannes Berg
As suggested by David Miller, make genl_register_family_with_ops() a macro and pass only the array, evaluating ARRAY_SIZE() in the macro, this is a little safer. The openvswitch has some indirection, assing ops/n_ops directly in that code. This might ultimately just assign the pointers in the family initializations, saving the struct genl_family_and_ops and code (once mcast groups are handled differently.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-18inet: prevent leakage of uninitialized memory to user in recv syscallsHannes Frederic Sowa
Only update *addr_len when we actually fill in sockaddr, otherwise we can return uninitialized memory from the stack to the caller in the recvfrom, recvmmsg and recvmsg syscalls. Drop the the (addr_len == NULL) checks because we only get called with a valid addr_len pointer either from sock_common_recvmsg or inet_recvmsg. If a blocking read waits on a socket which is concurrently shut down we now return zero and set msg_msgnamelen to 0. Reported-by: mpb <mpb.mail@gmail.com> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14genetlink: make all genl_ops users constJohannes Berg
Now that genl_ops are no longer modified in place when registering, they can be made const. This patch was done mostly with spatch: @@ identifier ops; @@ +const struct genl_ops ops[] = { ... }; (except the struct thing in net/openvswitch/datapath.c) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/qmi_wwan.c include/net/dst.h Trivial merge conflicts, both were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-19net: misc: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-11l2tp: must disable bh before calling l2tp_xmit_skb()Eric Dumazet
François Cachereul made a very nice bug report and suspected the bh_lock_sock() / bh_unlok_sock() pair used in l2tp_xmit_skb() from process context was not good. This problem was added by commit 6af88da14ee284aaad6e4326da09a89191ab6165 ("l2tp: Fix locking in l2tp_core.c"). l2tp_eth_dev_xmit() runs from BH context, so we must disable BH from other l2tp_xmit_skb() users. [ 452.060011] BUG: soft lockup - CPU#1 stuck for 23s! [accel-pppd:6662] [ 452.061757] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core pppoe pppox ppp_generic slhc ipv6 ext3 mbcache jbd virtio_balloon xfs exportfs dm_mod virtio_blk ata_generic virtio_net floppy ata_piix libata virtio_pci virtio_ring virtio [last unloaded: scsi_wait_scan] [ 452.064012] CPU 1 [ 452.080015] BUG: soft lockup - CPU#2 stuck for 23s! [accel-pppd:6643] [ 452.080015] CPU 2 [ 452.080015] [ 452.080015] Pid: 6643, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs [ 452.080015] RIP: 0010:[<ffffffff81059f6c>] [<ffffffff81059f6c>] do_raw_spin_lock+0x17/0x1f [ 452.080015] RSP: 0018:ffff88007125fc18 EFLAGS: 00000293 [ 452.080015] RAX: 000000000000aba9 RBX: ffffffff811d0703 RCX: 0000000000000000 [ 452.080015] RDX: 00000000000000ab RSI: ffff8800711f6896 RDI: ffff8800745c8110 [ 452.080015] RBP: ffff88007125fc18 R08: 0000000000000020 R09: 0000000000000000 [ 452.080015] R10: 0000000000000000 R11: 0000000000000280 R12: 0000000000000286 [ 452.080015] R13: 0000000000000020 R14: 0000000000000240 R15: 0000000000000000 [ 452.080015] FS: 00007fdc0cc24700(0000) GS:ffff8800b6f00000(0000) knlGS:0000000000000000 [ 452.080015] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 452.080015] CR2: 00007fdb054899b8 CR3: 0000000074404000 CR4: 00000000000006a0 [ 452.080015] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 452.080015] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 452.080015] Process accel-pppd (pid: 6643, threadinfo ffff88007125e000, task ffff8800b27e6dd0) [ 452.080015] Stack: [ 452.080015] ffff88007125fc28 ffffffff81256559 ffff88007125fc98 ffffffffa01b2bd1 [ 452.080015] ffff88007125fc58 000000000000000c 00000000029490d0 0000009c71dbe25e [ 452.080015] 000000000000005c 000000080000000e 0000000000000000 ffff880071170600 [ 452.080015] Call Trace: [ 452.080015] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.080015] [<ffffffffa01b2bd1>] l2tp_xmit_skb+0x189/0x4ac [l2tp_core] [ 452.080015] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.080015] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.080015] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.080015] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.080015] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.080015] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.080015] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.080015] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.080015] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b [ 452.080015] Code: 81 48 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 <8a> 07 eb f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3 [ 452.080015] Call Trace: [ 452.080015] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.080015] [<ffffffffa01b2bd1>] l2tp_xmit_skb+0x189/0x4ac [l2tp_core] [ 452.080015] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.080015] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.080015] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.080015] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.080015] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.080015] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.080015] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.080015] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.080015] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b [ 452.064012] [ 452.064012] Pid: 6662, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs [ 452.064012] RIP: 0010:[<ffffffff81059f6e>] [<ffffffff81059f6e>] do_raw_spin_lock+0x19/0x1f [ 452.064012] RSP: 0018:ffff8800b6e83ba0 EFLAGS: 00000297 [ 452.064012] RAX: 000000000000aaa9 RBX: ffff8800b6e83b40 RCX: 0000000000000002 [ 452.064012] RDX: 00000000000000aa RSI: 000000000000000a RDI: ffff8800745c8110 [ 452.064012] RBP: ffff8800b6e83ba0 R08: 000000000000c802 R09: 000000000000001c [ 452.064012] R10: ffff880071096c4e R11: 0000000000000006 R12: ffff8800b6e83b18 [ 452.064012] R13: ffffffff8125d51e R14: ffff8800b6e83ba0 R15: ffff880072a589c0 [ 452.064012] FS: 00007fdc0b81e700(0000) GS:ffff8800b6e80000(0000) knlGS:0000000000000000 [ 452.064012] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 452.064012] CR2: 0000000000625208 CR3: 0000000074404000 CR4: 00000000000006a0 [ 452.064012] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 452.064012] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 452.064012] Process accel-pppd (pid: 6662, threadinfo ffff88007129a000, task ffff8800744f7410) [ 452.064012] Stack: [ 452.064012] ffff8800b6e83bb0 ffffffff81256559 ffff8800b6e83bc0 ffffffff8121c64a [ 452.064012] ffff8800b6e83bf0 ffffffff8121ec7a ffff880072a589c0 ffff880071096c62 [ 452.064012] 0000000000000011 ffffffff81430024 ffff8800b6e83c80 ffffffff8121f276 [ 452.064012] Call Trace: [ 452.064012] <IRQ> [ 452.064012] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8121c64a>] spin_lock+0x9/0xb [ 452.064012] [<ffffffff8121ec7a>] udp_queue_rcv_skb+0x186/0x269 [ 452.064012] [<ffffffff8121f276>] __udp4_lib_rcv+0x297/0x4ae [ 452.064012] [<ffffffff8121c178>] ? raw_rcv+0xe9/0xf0 [ 452.064012] [<ffffffff8121f4a7>] udp_rcv+0x1a/0x1c [ 452.064012] [<ffffffff811fe385>] ip_local_deliver_finish+0x12b/0x1a5 [ 452.064012] [<ffffffff811fe54e>] ip_local_deliver+0x53/0x84 [ 452.064012] [<ffffffff811fe1d0>] ip_rcv_finish+0x2bc/0x2f3 [ 452.064012] [<ffffffff811fe78f>] ip_rcv+0x210/0x269 [ 452.064012] [<ffffffff8101911e>] ? kvm_clock_get_cycles+0x9/0xb [ 452.064012] [<ffffffff811d88cd>] __netif_receive_skb+0x3a5/0x3f7 [ 452.064012] [<ffffffff811d8eba>] netif_receive_skb+0x57/0x5e [ 452.064012] [<ffffffff811cf30f>] ? __netdev_alloc_skb+0x1f/0x3b [ 452.064012] [<ffffffffa0049126>] virtnet_poll+0x4ba/0x5a4 [virtio_net] [ 452.064012] [<ffffffff811d9417>] net_rx_action+0x73/0x184 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffff810343b9>] __do_softirq+0xc3/0x1a8 [ 452.064012] [<ffffffff81013b56>] ? ack_APIC_irq+0x10/0x12 [ 452.064012] [<ffffffff81256559>] ? _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8125e0ac>] call_softirq+0x1c/0x26 [ 452.064012] [<ffffffff81003587>] do_softirq+0x45/0x82 [ 452.064012] [<ffffffff81034667>] irq_exit+0x42/0x9c [ 452.064012] [<ffffffff8125e146>] do_IRQ+0x8e/0xa5 [ 452.064012] [<ffffffff8125676e>] common_interrupt+0x6e/0x6e [ 452.064012] <EOI> [ 452.064012] [<ffffffff810b82a1>] ? kfree+0x8a/0xa3 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01b2c25>] ? l2tp_xmit_skb+0x1dd/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.064012] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.064012] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.064012] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.064012] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.064012] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.064012] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.064012] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.064012] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b [ 452.064012] Code: 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 8a 07 <eb> f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3 55 48 [ 452.064012] Call Trace: [ 452.064012] <IRQ> [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8121c64a>] spin_lock+0x9/0xb [ 452.064012] [<ffffffff8121ec7a>] udp_queue_rcv_skb+0x186/0x269 [ 452.064012] [<ffffffff8121f276>] __udp4_lib_rcv+0x297/0x4ae [ 452.064012] [<ffffffff8121c178>] ? raw_rcv+0xe9/0xf0 [ 452.064012] [<ffffffff8121f4a7>] udp_rcv+0x1a/0x1c [ 452.064012] [<ffffffff811fe385>] ip_local_deliver_finish+0x12b/0x1a5 [ 452.064012] [<ffffffff811fe54e>] ip_local_deliver+0x53/0x84 [ 452.064012] [<ffffffff811fe1d0>] ip_rcv_finish+0x2bc/0x2f3 [ 452.064012] [<ffffffff811fe78f>] ip_rcv+0x210/0x269 [ 452.064012] [<ffffffff8101911e>] ? kvm_clock_get_cycles+0x9/0xb [ 452.064012] [<ffffffff811d88cd>] __netif_receive_skb+0x3a5/0x3f7 [ 452.064012] [<ffffffff811d8eba>] netif_receive_skb+0x57/0x5e [ 452.064012] [<ffffffff811cf30f>] ? __netdev_alloc_skb+0x1f/0x3b [ 452.064012] [<ffffffffa0049126>] virtnet_poll+0x4ba/0x5a4 [virtio_net] [ 452.064012] [<ffffffff811d9417>] net_rx_action+0x73/0x184 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffff810343b9>] __do_softirq+0xc3/0x1a8 [ 452.064012] [<ffffffff81013b56>] ? ack_APIC_irq+0x10/0x12 [ 452.064012] [<ffffffff81256559>] ? _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8125e0ac>] call_softirq+0x1c/0x26 [ 452.064012] [<ffffffff81003587>] do_softirq+0x45/0x82 [ 452.064012] [<ffffffff81034667>] irq_exit+0x42/0x9c [ 452.064012] [<ffffffff8125e146>] do_IRQ+0x8e/0xa5 [ 452.064012] [<ffffffff8125676e>] common_interrupt+0x6e/0x6e [ 452.064012] <EOI> [<ffffffff810b82a1>] ? kfree+0x8a/0xa3 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01b2c25>] ? l2tp_xmit_skb+0x1dd/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.064012] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.064012] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.064012] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.064012] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.064012] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.064012] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.064012] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.064012] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b Reported-by: François Cachereul <f.cachereul@alphalink.fr> Tested-by: François Cachereul <f.cachereul@alphalink.fr> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-09ipv6: make lookups simpler and fasterEric Dumazet
TCP listener refactoring, part 4 : To speed up inet lookups, we moved IPv4 addresses from inet to struct sock_common Now is time to do the same for IPv6, because it permits us to have fast lookups for all kind of sockets, including upcoming SYN_RECV. Getting IPv6 addresses in TCP lookups currently requires two extra cache lines, plus a dereference (and memory stall). inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6 This patch is way bigger than its IPv4 counter part, because for IPv4, we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6, it's not doable easily. inet6_sk(sk)->daddr becomes sk->sk_v6_daddr inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr at the same offset. We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic macro. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-08l2tp: Fix build warning with ipv6 disabled.David S. Miller
net/l2tp/l2tp_core.c: In function ‘l2tp_verify_udp_checksum’: net/l2tp/l2tp_core.c:499:22: warning: unused variable ‘tunnel’ [-Wunused-variable] Create a helper "l2tp_tunnel()" to facilitate this, and as a side effect get rid of a bunch of unnecessary void pointer casts. Signed-off-by: David S. Miller <davem@davemloft.net>
