This driver presents a regular net_device for each L2TP ethernet
pseudowire instance. These interfaces are named l2tpethN by default,
though userspace can specify an alternative name when the L2TP
session is created, if preferred. When the pseudowire is established,
regular Linux networking utilities may be used to configure the
interface, i.e. give it IP address info or add it to a bridge. Any
data passed over the interface is carried over an L2TP tunnel.
Signed-off-by: James Chapman <jchapman@katalix.com>
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
Reader/write locks are discouraged because they are slower than spin
locks. So this patch converts the rwlocks used in the per_net structs
to rcu.
In L2TPv3, we need to create/delete/modify/query L2TP tunnel and
session contexts. The number of parameters is significant. So let's
use netlink. Userspace uses this API to control L2TP tunnel/session
contexts in the kernel.
The previous pppol2tp driver was managed using [gs]etsockopt(). This
API is retained for backwards compatibility. Unlike L2TPv2 which
carries only PPP frames, L2TPv3 can carry raw ethernet frames or other
frame types and these do not always have an associated socket
family. Therefore, we need a way to use L2TP sessions that doesn't
require a socket type for each supported frame type. Hence netlink is
used.
This patch adds a new L2TPIP socket family and modifies the core to
handle the case where there is no UDP header in the L2TP
packet. L2TP/IP uses IP protocol 115. Since L2TP/UDP and L2TP/IP
packets differ in layout, the datapath packet handling code needs
changes too. Userspace uses an L2TPIP socket instead of a UDP socket
when IP encapsulation is required.
We can't use raw sockets for this because the semantics of raw sockets
don't lend themselves to the socket-per-tunnel model - we need to
This patch makes changes to the L2TP PPP code for L2TPv3.
The existing code has some assumptions about the L2TP header which are
broken by L2TPv3. Also the sockaddr_pppol2tp structure of the original
code is too small to support the increased size of the L2TPv3 tunnel
and session id, so a new sockaddr_pppol2tpv3 structure is needed. In
the socket calls, the size of this structure is used to tell if the
operation is for L2TPv2 or L2TPv3.
The L2TPv3 protocol changes the layout of the L2TP packet
header. Tunnel and session ids change from 16-bit to 32-bit values,
data sequence numbers change from 16-bit to 24-bit values and PPP-specific
fields are moved into protocol-specific subheaders.
Although this patch introduces L2TPv3 protocol support, there are no
userspace interfaces to create L2TPv3 sessions yet.
When dumping L2TP PPP sessions using /proc/net/pppol2tp, get the
assigned PPP device name from PPP using ppp_dev_name().
This patch splits the pppol2tp driver into separate L2TP and PPP parts
to prepare for L2TPv3 support. In L2TPv3, protocols other than PPP can
be carried, so this split creates a common L2TP core that will handle
the common L2TP bits which protocol support modules such as PPP will
use.
Note that the existing pppol2tp module is split into l2tp_core and
l2tp_ppp by this change.
There are no feature changes here. Internally, however, there are
significant changes, mostly to handle the separation of PPP-specific
data from the L2TP session and to provide hooks in the core for
modules like PPP to access.
This patch moves the existing pppol2tp driver from drivers/net into a
new net/l2tp directory, which is where the upcoming L2TPv3 code will
live. The existing CONFIG_PPPOL2TP config option is left in its
current place to avoid "make oldconfig" issues when an existing
pppol2tp user takes this change. (This is the same approach used for
the pppoatm driver, which moved to net/atm.)
There are no code changes. The existing drivers/net/pppol2tp.c is
simply moved to net/l2tp.
