path: root/net/l2tp
2014-10-15l2tp: fix race while getting PMTU on PPP pseudo-wireGuillaume Nault
[ Upstream commit eed4d839b0cdf9d84b0a9bc63de90fd5e1e886fb ] Use dst_entry held by sk_dst_get() to retrieve tunnel's PMTU. The dst_mtu(__sk_dst_get(tunnel->sock)) call was racy. __sk_dst_get() could return NULL if tunnel->sock->sk_dst_cache was reset just before the call, thus making dst_mtu() dereference a NULL pointer: [ 1937.661598] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 [ 1937.664005] IP: [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] PGD daf0c067 PUD d9f93067 PMD 0 [ 1937.664005] Oops: 0000 [#1] SMP [ 1937.664005] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6table_filter ip6_tables iptable_filter ip_tables ebtable_nat ebtables x_tables udp_tunnel pppoe pppox ppp_generic slhc deflate ctr twofish_generic twofish_x86_64_3way xts lrw gf128mul glue_helper twofish_x86_64 twofish_common blowfish_generic blowfish_x86_64 blowfish_common des_generic cbc xcbc rmd160 sha512_generic hmac crypto_null af_key xfrm_algo 8021q garp bridge stp llc tun atmtcp clip atm ext3 mbcache jbd iTCO_wdt coretemp kvm_intel iTCO_vendor_support kvm pcspkr evdev ehci_pci lpc_ich mfd_core i5400_edac edac_core i5k_amb shpchp button processor thermal_sys xfs crc32c_generic libcrc32c dm_mod usbhid sg hid sr_mod sd_mod cdrom crc_t10dif crct10dif_common ata_generic ahci ata_piix tg3 libahci libata uhci_hcd ptp ehci_hcd pps_core usbcore scsi_mod libphy usb_common [last unloaded: l2tp_core] [ 1937.664005] CPU: 0 PID: 10022 Comm: l2tpstress Tainted: G O 3.17.0-rc1 #1 [ 1937.664005] Hardware name: HP ProLiant DL160 G5, BIOS O12 08/22/2008 [ 1937.664005] task: ffff8800d8fda790 ti: ffff8800c43c4000 task.ti: ffff8800c43c4000 [ 1937.664005] RIP: 0010:[<ffffffffa049db88>] [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] RSP: 0018:ffff8800c43c7de8 EFLAGS: 00010282 [ 1937.664005] RAX: ffff8800da8a7240 RBX: ffff8800d8c64600 RCX: 000001c325a137b5 [ 1937.664005] RDX: 8c6318c6318c6320 RSI: 000000000000010c RDI: 0000000000000000 [ 1937.664005] RBP: ffff8800c43c7ea8 R08: 0000000000000000 R09: 0000000000000000 [ 1937.664005] R10: ffffffffa048e2c0 R11: ffff8800d8c64600 R12: ffff8800ca7a5000 [ 1937.664005] R13: ffff8800c439bf40 R14: 000000000000000c R15: 0000000000000009 [ 1937.664005] FS: 00007fd7f610f700(0000) GS:ffff88011a600000(0000) knlGS:0000000000000000 [ 1937.664005] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 1937.664005] CR2: 0000000000000020 CR3: 00000000d9d75000 CR4: 00000000000027e0 [ 1937.664005] Stack: [ 1937.664005] ffffffffa049da80 ffff8800d8fda790 000000000000005b ffff880000000009 [ 1937.664005] ffff8800daf3f200 0000000000000003 ffff8800c43c7e48 ffffffff81109b57 [ 1937.664005] ffffffff81109b0e ffffffff8114c566 0000000000000000 0000000000000000 [ 1937.664005] Call Trace: [ 1937.664005] [<ffffffffa049da80>] ? pppol2tp_connect+0x235/0x41e [l2tp_ppp] [ 1937.664005] [<ffffffff81109b57>] ? might_fault+0x9e/0xa5 [ 1937.664005] [<ffffffff81109b0e>] ? might_fault+0x55/0xa5 [ 1937.664005] [<ffffffff8114c566>] ? rcu_read_unlock+0x1c/0x26 [ 1937.664005] [<ffffffff81309196>] SYSC_connect+0x87/0xb1 [ 1937.664005] [<ffffffff813e56f7>] ? sysret_check+0x1b/0x56 [ 1937.664005] [<ffffffff8107590d>] ? trace_hardirqs_on_caller+0x145/0x1a1 [ 1937.664005] [<ffffffff81213dee>] ? trace_hardirqs_on_thunk+0x3a/0x3f [ 1937.664005] [<ffffffff8114c262>] ? spin_lock+0x9/0xb [ 1937.664005] [<ffffffff813092b4>] SyS_connect+0x9/0xb [ 1937.664005] [<ffffffff813e56d2>] system_call_fastpath+0x16/0x1b [ 1937.664005] Code: 10 2a 84 81 e8 65 76 bd e0 65 ff 0c 25 10 bb 00 00 4d 85 ed 74 37 48 8b 85 60 ff ff ff 48 8b 80 88 01 00 00 48 8b b8 10 02 00 00 <48> 8b 47 20 ff 50 20 85 c0 74 0f 83 e8 28 89 83 10 01 00 00 89 [ 1937.664005] RIP [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp] [ 1937.664005] RSP <ffff8800c43c7de8> [ 1937.664005] CR2: 0000000000000020 [ 1939.559375] ---[ end trace 82d44500f28f8708 ]--- Fixes: f34c4a35d879 ("l2tp: take PMTU from tunnel UDP socket") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-07net/l2tp: don't fall back on UDP [get|set]sockoptSasha Levin
commit 3cf521f7dc87c031617fd47e4b7aa2593c2f3daf upstream. The l2tp [get|set]sockopt() code has fallen back to the UDP functions for socket option levels != SOL_PPPOL2TP since day one, but that has never actually worked, since the l2tp socket isn't an inet socket. As David Miller points out: "If we wanted this to work, it'd have to look up the tunnel and then use tunnel->sk, but I wonder how useful that would be" Since this can never have worked so nobody could possibly have depended on that functionality, just remove the broken code and return -EINVAL. Reported-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: James Chapman <jchapman@katalix.com> Acked-by: David Miller <davem@davemloft.net> Cc: Phil Turnbull <phil.turnbull@oracle.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-30l2tp: take PMTU from tunnel UDP socketDmitry Petukhov
[ Upstream commit f34c4a35d87949fbb0e0f31eba3c054e9f8199ba ] When l2tp driver tries to get PMTU for the tunnel destination, it uses the pointer to struct sock that represents PPPoX socket, while it should use the pointer that represents UDP socket of the tunnel. Signed-off-by: Dmitry Petukhov <dmgenp@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08inet: fix addr_len/msg->msg_namelen assignment in recv_error and rxpmtu ↵Hannes Frederic Sowa
functions [ Upstream commit 85fbaa75037d0b6b786ff18658ddf0b4014ce2a4 ] Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage of uninitialized memory to user in recv syscalls") conditionally updated addr_len if the msg_name is written to. The recv_error and rxpmtu functions relied on the recvmsg functions to set up addr_len before. As this does not happen any more we have to pass addr_len to those functions as well and set it to the size of the corresponding sockaddr length. This broke traceroute and such. Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls") Reported-by: Brad Spengler <spender@grsecurity.net> Reported-by: Tom Labanowski Cc: mpb <mpb.mail@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ] This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08inet: prevent leakage of uninitialized memory to user in recv syscallsHannes Frederic Sowa
[ Upstream commit bceaa90240b6019ed73b49965eac7d167610be69 ] Only update *addr_len when we actually fill in sockaddr, otherwise we can return uninitialized memory from the stack to the caller in the recvfrom, recvmmsg and recvmsg syscalls. Drop the the (addr_len == NULL) checks because we only get called with a valid addr_len pointer either from sock_common_recvmsg or inet_recvmsg. If a blocking read waits on a socket which is concurrently shut down we now return zero and set msg_msgnamelen to 0. Reported-by: mpb <mpb.mail@gmail.com> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04l2tp: must disable bh before calling l2tp_xmit_skb()Eric Dumazet
[ Upstream commit 455cc32bf128e114455d11ad919321ab89a2c312 ] François Cachereul made a very nice bug report and suspected the bh_lock_sock() / bh_unlok_sock() pair used in l2tp_xmit_skb() from process context was not good. This problem was added by commit 6af88da14ee284aaad6e4326da09a89191ab6165 ("l2tp: Fix locking in l2tp_core.c"). l2tp_eth_dev_xmit() runs from BH context, so we must disable BH from other l2tp_xmit_skb() users. [ 452.060011] BUG: soft lockup - CPU#1 stuck for 23s! [accel-pppd:6662] [ 452.061757] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core pppoe pppox ppp_generic slhc ipv6 ext3 mbcache jbd virtio_balloon xfs exportfs dm_mod virtio_blk ata_generic virtio_net floppy ata_piix libata virtio_pci virtio_ring virtio [last unloaded: scsi_wait_scan] [ 452.064012] CPU 1 [ 452.080015] BUG: soft lockup - CPU#2 stuck for 23s! [accel-pppd:6643] [ 452.080015] CPU 2 [ 452.080015] [ 452.080015] Pid: 6643, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs [ 452.080015] RIP: 0010:[<ffffffff81059f6c>] [<ffffffff81059f6c>] do_raw_spin_lock+0x17/0x1f [ 452.080015] RSP: 0018:ffff88007125fc18 EFLAGS: 00000293 [ 452.080015] RAX: 000000000000aba9 RBX: ffffffff811d0703 RCX: 0000000000000000 [ 452.080015] RDX: 00000000000000ab RSI: ffff8800711f6896 RDI: ffff8800745c8110 [ 452.080015] RBP: ffff88007125fc18 R08: 0000000000000020 R09: 0000000000000000 [ 452.080015] R10: 0000000000000000 R11: 0000000000000280 R12: 0000000000000286 [ 452.080015] R13: 0000000000000020 R14: 0000000000000240 R15: 0000000000000000 [ 452.080015] FS: 00007fdc0cc24700(0000) GS:ffff8800b6f00000(0000) knlGS:0000000000000000 [ 452.080015] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 452.080015] CR2: 00007fdb054899b8 CR3: 0000000074404000 CR4: 00000000000006a0 [ 452.080015] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 452.080015] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 452.080015] Process accel-pppd (pid: 6643, threadinfo ffff88007125e000, task ffff8800b27e6dd0) [ 452.080015] Stack: [ 452.080015] ffff88007125fc28 ffffffff81256559 ffff88007125fc98 ffffffffa01b2bd1 [ 452.080015] ffff88007125fc58 000000000000000c 00000000029490d0 0000009c71dbe25e [ 452.080015] 000000000000005c 000000080000000e 0000000000000000 ffff880071170600 [ 452.080015] Call Trace: [ 452.080015] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.080015] [<ffffffffa01b2bd1>] l2tp_xmit_skb+0x189/0x4ac [l2tp_core] [ 452.080015] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.080015] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.080015] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.080015] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.080015] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.080015] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.080015] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.080015] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.080015] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b [ 452.080015] Code: 81 48 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 <8a> 07 eb f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3 [ 452.080015] Call Trace: [ 452.080015] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.080015] [<ffffffffa01b2bd1>] l2tp_xmit_skb+0x189/0x4ac [l2tp_core] [ 452.080015] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.080015] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.080015] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.080015] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.080015] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.080015] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.080015] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.080015] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.080015] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b [ 452.064012] [ 452.064012] Pid: 6662, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs [ 452.064012] RIP: 0010:[<ffffffff81059f6e>] [<ffffffff81059f6e>] do_raw_spin_lock+0x19/0x1f [ 452.064012] RSP: 0018:ffff8800b6e83ba0 EFLAGS: 00000297 [ 452.064012] RAX: 000000000000aaa9 RBX: ffff8800b6e83b40 RCX: 0000000000000002 [ 452.064012] RDX: 00000000000000aa RSI: 000000000000000a RDI: ffff8800745c8110 [ 452.064012] RBP: ffff8800b6e83ba0 R08: 000000000000c802 R09: 000000000000001c [ 452.064012] R10: ffff880071096c4e R11: 0000000000000006 R12: ffff8800b6e83b18 [ 452.064012] R13: ffffffff8125d51e R14: ffff8800b6e83ba0 R15: ffff880072a589c0 [ 452.064012] FS: 00007fdc0b81e700(0000) GS:ffff8800b6e80000(0000) knlGS:0000000000000000 [ 452.064012] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 452.064012] CR2: 0000000000625208 CR3: 0000000074404000 CR4: 00000000000006a0 [ 452.064012] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 452.064012] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 452.064012] Process accel-pppd (pid: 6662, threadinfo ffff88007129a000, task ffff8800744f7410) [ 452.064012] Stack: [ 452.064012] ffff8800b6e83bb0 ffffffff81256559 ffff8800b6e83bc0 ffffffff8121c64a [ 452.064012] ffff8800b6e83bf0 ffffffff8121ec7a ffff880072a589c0 ffff880071096c62 [ 452.064012] 0000000000000011 ffffffff81430024 ffff8800b6e83c80 ffffffff8121f276 [ 452.064012] Call Trace: [ 452.064012] <IRQ> [ 452.064012] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8121c64a>] spin_lock+0x9/0xb [ 452.064012] [<ffffffff8121ec7a>] udp_queue_rcv_skb+0x186/0x269 [ 452.064012] [<ffffffff8121f276>] __udp4_lib_rcv+0x297/0x4ae [ 452.064012] [<ffffffff8121c178>] ? raw_rcv+0xe9/0xf0 [ 452.064012] [<ffffffff8121f4a7>] udp_rcv+0x1a/0x1c [ 452.064012] [<ffffffff811fe385>] ip_local_deliver_finish+0x12b/0x1a5 [ 452.064012] [<ffffffff811fe54e>] ip_local_deliver+0x53/0x84 [ 452.064012] [<ffffffff811fe1d0>] ip_rcv_finish+0x2bc/0x2f3 [ 452.064012] [<ffffffff811fe78f>] ip_rcv+0x210/0x269 [ 452.064012] [<ffffffff8101911e>] ? kvm_clock_get_cycles+0x9/0xb [ 452.064012] [<ffffffff811d88cd>] __netif_receive_skb+0x3a5/0x3f7 [ 452.064012] [<ffffffff811d8eba>] netif_receive_skb+0x57/0x5e [ 452.064012] [<ffffffff811cf30f>] ? __netdev_alloc_skb+0x1f/0x3b [ 452.064012] [<ffffffffa0049126>] virtnet_poll+0x4ba/0x5a4 [virtio_net] [ 452.064012] [<ffffffff811d9417>] net_rx_action+0x73/0x184 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffff810343b9>] __do_softirq+0xc3/0x1a8 [ 452.064012] [<ffffffff81013b56>] ? ack_APIC_irq+0x10/0x12 [ 452.064012] [<ffffffff81256559>] ? _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8125e0ac>] call_softirq+0x1c/0x26 [ 452.064012] [<ffffffff81003587>] do_softirq+0x45/0x82 [ 452.064012] [<ffffffff81034667>] irq_exit+0x42/0x9c [ 452.064012] [<ffffffff8125e146>] do_IRQ+0x8e/0xa5 [ 452.064012] [<ffffffff8125676e>] common_interrupt+0x6e/0x6e [ 452.064012] <EOI> [ 452.064012] [<ffffffff810b82a1>] ? kfree+0x8a/0xa3 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01b2c25>] ? l2tp_xmit_skb+0x1dd/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.064012] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.064012] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.064012] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.064012] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.064012] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.064012] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.064012] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.064012] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b [ 452.064012] Code: 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 8a 07 <eb> f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3 55 48 [ 452.064012] Call Trace: [ 452.064012] <IRQ> [<ffffffff81256559>] _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8121c64a>] spin_lock+0x9/0xb [ 452.064012] [<ffffffff8121ec7a>] udp_queue_rcv_skb+0x186/0x269 [ 452.064012] [<ffffffff8121f276>] __udp4_lib_rcv+0x297/0x4ae [ 452.064012] [<ffffffff8121c178>] ? raw_rcv+0xe9/0xf0 [ 452.064012] [<ffffffff8121f4a7>] udp_rcv+0x1a/0x1c [ 452.064012] [<ffffffff811fe385>] ip_local_deliver_finish+0x12b/0x1a5 [ 452.064012] [<ffffffff811fe54e>] ip_local_deliver+0x53/0x84 [ 452.064012] [<ffffffff811fe1d0>] ip_rcv_finish+0x2bc/0x2f3 [ 452.064012] [<ffffffff811fe78f>] ip_rcv+0x210/0x269 [ 452.064012] [<ffffffff8101911e>] ? kvm_clock_get_cycles+0x9/0xb [ 452.064012] [<ffffffff811d88cd>] __netif_receive_skb+0x3a5/0x3f7 [ 452.064012] [<ffffffff811d8eba>] netif_receive_skb+0x57/0x5e [ 452.064012] [<ffffffff811cf30f>] ? __netdev_alloc_skb+0x1f/0x3b [ 452.064012] [<ffffffffa0049126>] virtnet_poll+0x4ba/0x5a4 [virtio_net] [ 452.064012] [<ffffffff811d9417>] net_rx_action+0x73/0x184 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffff810343b9>] __do_softirq+0xc3/0x1a8 [ 452.064012] [<ffffffff81013b56>] ? ack_APIC_irq+0x10/0x12 [ 452.064012] [<ffffffff81256559>] ? _raw_spin_lock+0xe/0x10 [ 452.064012] [<ffffffff8125e0ac>] call_softirq+0x1c/0x26 [ 452.064012] [<ffffffff81003587>] do_softirq+0x45/0x82 [ 452.064012] [<ffffffff81034667>] irq_exit+0x42/0x9c [ 452.064012] [<ffffffff8125e146>] do_IRQ+0x8e/0xa5 [ 452.064012] [<ffffffff8125676e>] common_interrupt+0x6e/0x6e [ 452.064012] <EOI> [<ffffffff810b82a1>] ? kfree+0x8a/0xa3 [ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01b2c25>] ? l2tp_xmit_skb+0x1dd/0x4ac [l2tp_core] [ 452.064012] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp] [ 452.064012] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24 [ 452.064012] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6 [ 452.064012] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616 [ 452.064012] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c [ 452.064012] [<ffffffff810bbd21>] ? fget_light+0x75/0x89 [ 452.064012] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56 [ 452.064012] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b [ 452.064012] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b Reported-by: François Cachereul <f.cachereul@alphalink.fr> Tested-by: François Cachereul <f.cachereul@alphalink.fr> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04l2tp: Fix build warning with ipv6 disabled.David S. Miller
[ Upstream commit 8d8a51e26a6d415e1470759f2cf5f3ee3ee86196 ] net/l2tp/l2tp_core.c: In function ‘l2tp_verify_udp_checksum’: net/l2tp/l2tp_core.c:499:22: warning: unused variable ‘tunnel’ [-Wunused-variable] Create a helper "l2tp_tunnel()" to facilitate this, and as a side effect get rid of a bunch of unnecessary void pointer casts. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04l2tp: fix kernel panic when using IPv4-mapped IPv6 addressesFrançois CACHEREUL
[ Upstream commit e18503f41f9b12132c95d7c31ca6ee5155e44e5c ] IPv4 mapped addresses cause kernel panic. The patch juste check whether the IPv6 address is an IPv4 mapped address. If so, use IPv4 API instead of IPv6. [ 940.026915] general protection fault: 0000 [#1] [ 940.026915] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core pppox ppp_generic slhc loop psmouse [ 940.026915] CPU: 0 PID: 3184 Comm: memcheck-amd64- Not tainted 3.11.0+ #1 [ 940.026915] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [ 940.026915] task: ffff880007130e20 ti: ffff88000737e000 task.ti: ffff88000737e000 [ 940.026915] RIP: 0010:[<ffffffff81333780>] [<ffffffff81333780>] ip6_xmit+0x276/0x326 [ 940.026915] RSP: 0018:ffff88000737fd28 EFLAGS: 00010286 [ 940.026915] RAX: c748521a75ceff48 RBX: ffff880000c30800 RCX: 0000000000000000 [ 940.026915] RDX: ffff88000075cc4e RSI: 0000000000000028 RDI: ffff8800060e5a40 [ 940.026915] RBP: ffff8800060e5a40 R08: 0000000000000000 R09: ffff88000075cc90 [ 940.026915] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88000737fda0 [ 940.026915] R13: 0000000000000000 R14: 0000000000002000 R15: ffff880005d3b580 [ 940.026915] FS: 00007f163dc5e800(0000) GS:ffffffff81623000(0000) knlGS:0000000000000000 [ 940.026915] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 940.026915] CR2: 00000004032dc940 CR3: 0000000005c25000 CR4: 00000000000006f0 [ 940.026915] Stack: [ 940.026915] ffff88000075cc4e ffffffff81694e90 ffff880000c30b38 0000000000000020 [ 940.026915] 11000000523c4bac ffff88000737fdb4 0000000000000000 ffff880000c30800 [ 940.026915] ffff880005d3b580 ffff880000c30b38 ffff8800060e5a40 0000000000000020 [ 940.026915] Call Trace: [ 940.026915] [<ffffffff81356cc3>] ? inet6_csk_xmit+0xa4/0xc4 [ 940.026915] [<ffffffffa0038535>] ? l2tp_xmit_skb+0x503/0x55a [l2tp_core] [ 940.026915] [<ffffffff812b8d3b>] ? pskb_expand_head+0x161/0x214 [ 940.026915] [<ffffffffa003e91d>] ? pppol2tp_xmit+0xf2/0x143 [l2tp_ppp] [ 940.026915] [<ffffffffa00292e0>] ? ppp_channel_push+0x36/0x8b [ppp_generic] [ 940.026915] [<ffffffffa00293fe>] ? ppp_write+0xaf/0xc5 [ppp_generic] [ 940.026915] [<ffffffff8110ead4>] ? vfs_write+0xa2/0x106 [ 940.026915] [<ffffffff8110edd6>] ? SyS_write+0x56/0x8a [ 940.026915] [<ffffffff81378ac0>] ? system_call_fastpath+0x16/0x1b [ 940.026915] Code: 00 49 8b 8f d8 00 00 00 66 83 7c 11 02 00 74 60 49 8b 47 58 48 83 e0 fe 48 8b 80 18 01 00 00 48 85 c0 74 13 48 8b 80 78 02 00 00 <48> ff 40 28 41 8b 57 68 48 01 50 30 48 8b 54 24 08 49 c7 c1 51 [ 940.026915] RIP [<ffffffff81333780>] ip6_xmit+0x276/0x326 [ 940.026915] RSP <ffff88000737fd28> [ 940.057945] ---[ end trace be8aba9a61c8b7f3 ]--- [ 940.058583] Kernel panic - not syncing: Fatal exception in interrupt Signed-off-by: François CACHEREUL <f.cachereul@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28l2tp: add missing .owner to struct pppox_protoWei Yongjun
[ Upstream commit e1558a93b61962710733dc8c11a2bc765607f1cd ] Add missing .owner of struct pppox_proto. This prevents the module from being removed from underneath its users. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13l2tp: Fix sendmsg() return valueGuillaume Nault
PPPoL2TP sockets should comply with the standard send*() return values (i.e. return number of bytes sent instead of 0 upon success). Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13l2tp: Fix PPP header erasure and memory leakGuillaume Nault
Copy user data after PPP framing header. This prevents erasure of the added PPP header and avoids leaking two bytes of uninitialised memory at the end of skb's data buffer. Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/nfc/microread/mei.c net/netfilter/nfnetlink_queue_core.c Pull in 'net' to get Eric Biederman's AF_UNIX fix, upon which some cleanups are going to go on-top. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07l2tp: fix info leak in l2tp_ip6_recvmsg()Mathias Krause
The L2TP code for IPv6 fails to initialize the l2tp_conn_id member of struct sockaddr_l2tpip6 and therefore leaks four bytes kernel stack in l2tp_ip6_recvmsg() in case msg_name is set. Initialize l2tp_conn_id with 0 to avoid the info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-22l2tp: calling the ref() instead of deref()Dan Carpenter
This is a cut and paste typo. We call ->ref() a second time instead of ->deref(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: unhash l2tp sessions on delete, not on freeTom Parkin
If we postpone unhashing of l2tp sessions until the structure is freed, we risk: 1. further packets arriving and getting queued while the pseudowire is being closed down 2. the recv path hitting "scheduling while atomic" errors in the case that recv drops the last reference to a session and calls l2tp_session_free while in atomic context As such, l2tp sessions should be unhashed from l2tp_core data structures early in the teardown process prior to calling pseudowire close. For pseudowires like l2tp_ppp which have multiple shutdown codepaths, provide an unhash hook. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: avoid deadlock in l2tp stats updateTom Parkin
l2tp's u64_stats writers were incorrectly synchronised, making it possible to deadlock a 64bit machine running a 32bit kernel simply by sending the l2tp code netlink commands while passing data through l2tp sessions. Previous discussion on netdev determined that alternative solutions such as spinlock writer synchronisation or per-cpu data would bring unjustified overhead, given that most users interested in high volume traffic will likely be running 64bit kernels on 64bit hardware. As such, this patch replaces l2tp's use of u64_stats with atomic_long_t, thereby avoiding the deadlock. Ref: http://marc.info/?l=linux-netdev&m=134029167910731&w=2 http://marc.info/?l=linux-netdev&m=134079868111131&w=2 Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: push all ppp pseudowire shutdown through .release handlerTom Parkin
If userspace deletes a ppp pseudowire using the netlink API, either by directly deleting the session or by deleting the tunnel that contains the session, we need to tear down the corresponding pppox channel. Rather than trying to manage two pppox unbind codepaths, switch the netlink and l2tp_core session_close handlers to close via. the l2tp_ppp socket .release handler. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: purge session reorder queue on deleteTom Parkin
Add calls to l2tp_session_queue_purge as a part of l2tp_tunnel_closeall and l2tp_session_delete. Pseudowire implementations which are deleted only via. l2tp_core l2tp_session_delete calls can dispense with their own code for flushing the reorder queue. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: add session reorder queue purge function to coreTom Parkin
If an l2tp session is deleted, it is necessary to delete skbs in-flight on the session's reorder queue before taking it down. Rather than having each pseudowire implementation reaching into the l2tp_session struct to handle this itself, provide a function in l2tp_core to purge the session queue. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: don't BUG_ON sk_socket being NULLTom Parkin
It is valid for an existing struct sock object to have a NULL sk_socket pointer, so don't BUG_ON in l2tp_tunnel_del_work if that should occur. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: take a reference for kernel sockets in l2tp_tunnel_sock_lookupTom Parkin
When looking up the tunnel socket in struct l2tp_tunnel, hold a reference whether the socket was created by the kernel or by userspace. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: close sessions before initiating tunnel deleteTom Parkin
When a user deletes a tunnel using netlink, all the sessions in the tunnel should also be deleted. Since running sessions will pin the tunnel socket with the references they hold, have the l2tp_tunnel_delete close all sessions in a tunnel before finally closing the tunnel socket. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: close sessions in ip socket destroy callbackTom Parkin
l2tp_core hooks UDP's .destroy handler to gain advance warning of a tunnel socket being closed from userspace. We need to do the same thing for IP-encapsulation sockets. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: export l2tp_tunnel_closeallTom Parkin
l2tp_core internally uses l2tp_tunnel_closeall to close all sessions in a tunnel when a UDP-encapsulation socket is destroyed. We need to do something similar for IP-encapsulation sockets. Export l2tp_tunnel_closeall as a GPL symbol to enable l2tp_ip and l2tp_ip6 to call it from their .destroy handlers. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20l2tp: add udp encap socket destroy handlerTom Parkin
L2TP sessions hold a reference to the tunnel socket to prevent it going away while sessions are still active. However, since tunnel destruction is handled by the sock sk_destruct callback there is a catch-22: a tunnel with sessions cannot be deleted since each session holds a reference to the tunnel socket. If userspace closes a managed tunnel socket, or dies, the tunnel will persist and it will be neccessary to individually delete the sessions using netlink commands. This is ugly. To prevent this occuring, this patch leverages the udp encapsulation socket destroy callback to gain early notification when the tunnel socket is closed. This allows us to safely close the sessions running in the tunnel, dropping the tunnel socket references in the process. The tunnel socket is then destroyed as normal, and the tunnel resources deallocated in sk_destruct. While we're at it, ensure that l2tp_tunnel_closeall correctly drops session references to allow the sessions to be deleted rather than leaking. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A moderately sized pile of fixes, some specifically for merge window introduced regressions although others are for longer standing items and have been queued up for -stable. I'm kind of tired of all the RDS protocol bugs over the years, to be honest, it's way out of proportion to the number of people who actually use it. 1) Fix missing range initialization in netfilter IPSET, from Jozsef Kadlecsik. 2) ieee80211_local->tim_lock needs to use BH disabling, from Johannes Berg. 3) Fix DMA syncing in SFC driver, from Ben Hutchings. 4) Fix regression in BOND device MAC address setting, from Jiri Pirko. 5) Missing usb_free_urb in ISDN Hisax driver, from Marina Makienko. 6) Fix UDP checksumming in bnx2x driver for 57710 and 57711 chips, fix from Dmitry Kravkov. 7) Missing cfgspace_lock initialization in BCMA driver. 8) Validate parameter size for SCTP assoc stats getsockopt(), from Guenter Roeck. 9) Fix SCTP association hangs, from Lee A Roberts. 10) Fix jumbo frame handling in r8169, from Francois Romieu. 11) Fix phy_device memory leak, from Petr Malat. 12) Omit trailing FCS from frames received in BGMAC driver, from Hauke Mehrtens. 13) Missing socket refcount release in L2TP, from Guillaume Nault. 14) sctp_endpoint_init should respect passed in gfp_t, rather than use GFP_KERNEL unconditionally. From Dan Carpenter. 15) Add AISX AX88179 USB driver, from Freddy Xin. 16) Remove MAINTAINERS entries for drivers deleted during the merge window, from Cesar Eduardo Barros. 17) RDS protocol can try to allocate huge amounts of memory, check that the user's request length makes sense, from Cong Wang. 18) SCTP should use the provided KMALLOC_MAX_SIZE instead of it's own, bogus, definition. From Cong Wang. 19) Fix deadlocks in FEC driver by moving TX reclaim into NAPI poll, from Frank Li. Also, fix a build error introduced in the merge window. 20) Fix bogus purging of default routes in ipv6, from Lorenzo Colitti. 21) Don't double count RTT measurements when we leave the TCP receive fast path, from Neal Cardwell." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (61 commits) tcp: fix double-counted receiver RTT when leaving receiver fast path CAIF: fix sparse warning for caif_usb rds: simplify a warning message net: fec: fix build error in no MXC platform net: ipv6: Don't purge default router if accept_ra=2 net: fec: put tx to napi poll function to fix dead lock sctp: use KMALLOC_MAX_SIZE instead of its own MAX_KMALLOC_SIZE rds: limit the size allocated by rds_message_alloc() MAINTAINERS: remove eexpress MAINTAINERS: remove drivers/net/wan/cycx* MAINTAINERS: remove 3c505 caif_dev: fix sparse warnings for caif_flow_cb ax88179_178a: ASIX AX88179_178A USB 3.0/2.0 to gigabit ethernet adapter driver sctp: use the passed in gfp flags instead GFP_KERNEL ipv[4|6]: correct dropwatch false positive in local_deliver_finish l2tp: Restore socket refcount when sendmsg succeeds net/phy: micrel: Disable asymmetric pause for KSZ9021 bgmac: omit the fcs phy: Fix phy_device_free memory leak bnx2x: Fix KR2 work-around condition ...
2013-03-01l2tp: Restore socket refcount when sendmsg succeedsGuillaume Nault
The sendmsg() syscall handler for PPPoL2TP doesn't decrease the socket reference counter after successful transmissions. Any successful sendmsg() call from userspace will then increase the reference counter forever, thus preventing the kernel's session and tunnel data from being freed later on. The problem only happens when writing directly on L2TP sockets. PPP sockets attached to L2TP are unaffected as the PPP subsystem uses pppol2tp_xmit() which symmetrically increase/decrease reference counters. This patch adds the missing call to sock_put() before returning from pppol2tp_sendmsg(). Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_fops_create to proc_createGao feng
Right now, some modules such as bonding use proc_create to create proc entries under /proc/net/, and other modules such as ipv4 use proc_net_fops_create. It looks a little chaos.this patch changes all of proc_net_fops_create to proc_create. we can remove proc_net_fops_create after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Synchronize with 'net' in order to sort out some l2tp, wireless, and ipv6 GRE fixes that will be built on top of in 'net-next'. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-08l2tp: dont play with skb->truesizeEric Dumazet
Andrew Savchenko reported a DNS failure and we diagnosed that some UDP sockets were unable to send more packets because their sk_wmem_alloc was corrupted after a while (tx_queue column in following trace) $ cat /proc/net/udp sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops ... 459: 00000000:0270 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4507 2 ffff88003d612380 0 466: 00000000:0277 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4802 2 ffff88003d613180 0 470: 076A070A:007B 00000000:0000 07 FFFF4600:00000000 00:00000000 00000000 123 0 5552 2 ffff880039974380 0 470: 010213AC:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4986 2 ffff88003dbd3180 0 470: 010013AC:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4985 2 ffff88003dbd2e00 0 470: 00FCA8C0:007B 00000000:0000 07 FFFFFB00:00000000 00:00000000 00000000 0 0 4984 2 ffff88003dbd2a80 0 ... Playing with skb->truesize is tricky, especially when skb is attached to a socket, as we can fool memory charging. Just remove this code, its not worth trying to be ultra precise in xmit path. Reported-by: Andrew Savchenko <bircoph@gmail.com> Tested-by: Andrew Savchenko <bircoph@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-05l2tp: Make ipv4 protocol handler namespace aware.David S. Miller
The infrastructure is already pretty much entirely there to allow this conversion. The tunnel and session lookups have per-namespace tables, and the ipv4 bind lookup includes the namespace in the lookup key. Set netns_ok in l2tp_ip_protocol. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-05l2tp: create tunnel sockets in the right namespaceTom Parkin
When creating unmanaged tunnel sockets we should honour the network namespace passed to l2tp_tunnel_create. Furthermore, unmanaged tunnel sockets should not hold a reference to the network namespace lest they accidentally keep alive a namespace which should otherwise have been released. Unmanaged tunnel sockets now drop their namespace reference via sk_change_net, and are released in a new pernet exit callback, l2tp_exit_net. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-05l2tp: prevent tunnel creation on netns mismatchTom Parkin
l2tp_tunnel_create is passed a pointer to the network namespace for the tunnel, along with an optional file descriptor for the tunnel which may be passed in from userspace via. netlink. In the case where the file descriptor is defined, ensure that the namespace associated with that socket matches the namespace explicitly passed to l2tp_tunnel_create. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-05l2tp: set netnsok flag for netlink messagesTom Parkin
The L2TP netlink code can run in namespaces. Set the netnsok flag in genl_family to true to reflect that fact. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-05l2tp: put tunnel socket release on a workqueueTom Parkin
To allow l2tp_tunnel_delete to be called from an atomic context, place the tunnel socket release calls on a workqueue for asynchronous execution. Tunnel memory is eventually freed in the tunnel socket destructor. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-31l2tp: correctly handle ancillary data in the ip6 recv pathTom Parkin
l2tp_ip6 is incorrectly using the IPv4-specific ip_cmsg_recv to handle ancillary data. This means that socket options such as IPV6_RECVPKTINFO are not honoured in userspace. Convert l2tp_ip6 to use the IPv6-specific handler. Ref: net/ipv6/udp.c Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: Chris Elston <celston@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-31ipv6: rename datagram_send_ctl and datagram_recv_ctlTom Parkin
The datagram_*_ctl functions in net/ipv6/datagram.c are IPv6-specific. Since datagram_send_ctl is publicly exported it should be appropriately named to reflect the fact that it's for IPv6 only. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-29l2tp: prevent l2tp_tunnel_delete racing with userspace closeTom Parkin
If a tunnel socket is created by userspace, l2tp hooks the socket destructor in order to clean up resources if userspace closes the socket or crashes. It also caches a pointer to the struct sock for use in the data path and in the netlink interface. While it is safe to use the cached sock pointer in the data path, where the skb references keep the socket alive, it is not safe to use it elsewhere as such access introduces a race with userspace closing the socket. In particular, l2tp_tunnel_delete is prone to oopsing if a multithreaded userspace application closes a socket at the same time as sending a netlink delete command for the tunnel. This patch fixes this oops by forcing l2tp_tunnel_delete to explicitly look up a tunnel socket held by userspace using sockfd_lookup(). Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-11net/l2tp: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2012-11-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c Minor conflict between the BCM_CNIC define removal in net-next and a bug fix added to net. Based upon a conflict resolution patch posted by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-02l2tp: fix oops in l2tp_eth_create() error pathTom Parkin
When creating an L2TPv3 Ethernet session, if register_netdev() should fail for any reason (for example, automatic naming for "l2tpeth%d" interfaces hits the 32k-interface limit), the netdev is freed in the error path. However, the l2tp_eth_sess structure's dev pointer is left uncleared, and this results in l2tp_eth_delete() then attempting to unregister the same netdev later in the session teardown. This results in an oops. To avoid this, clear the session dev pointer in the error path. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-26l2tp: session is an array not a pointerAlan Cox
Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/team/team.c drivers/net/usb/qmi_wwan.c net/batman-adv/bat_iv_ogm.c net/ipv4/fib_frontend.c net/ipv4/route.c net/l2tp/l2tp_netlink.c The team, fib_frontend, route, and l2tp_netlink conflicts were simply overlapping changes. qmi_wwan and bat_iv_ogm were of the "use HEAD" variety. With help from Antonio Quartulli. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-27l2tp: fix return value checkWei Yongjun
In case of error, the function genlmsg_put() returns NULL pointer not ERR_PTR(). The IS_ERR() test in the return value check should be replaced with NULL test. dpatch engine is used to auto generate this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-21l2tp: fix compile error when CONFIG_IPV6=m and CONFIG_L2TP=yAmerigo Wang
When CONFIG_IPV6=m and CONFIG_L2TP=y, I got the following compile error: LD init/built-in.o net/built-in.o: In function `l2tp_xmit_core': l2tp_core.c:(.text+0x147781): undefined reference to `inet6_csk_xmit' net/built-in.o: In function `l2tp_tunnel_create': (.text+0x149067): undefined reference to `udpv6_encap_enable' net/built-in.o: In function `l2tp_ip6_recvmsg': l2tp_ip6.c:(.text+0x14e991): undefined reference to `ipv6_recv_error' net/built-in.o: In function `l2tp_ip6_sendmsg': l2tp_ip6.c:(.text+0x14ec64): undefined reference to `fl6_sock_lookup' l2tp_ip6.c:(.text+0x14ed6b): undefined reference to `datagram_send_ctl' l2tp_ip6.c:(.text+0x14eda0): undefined reference to `fl6_sock_lookup' l2tp_ip6.c:(.text+0x14ede5): undefined reference to `fl6_merge_options' l2tp_ip6.c:(.text+0x14edf4): undefined reference to `ipv6_fixup_options' l2tp_ip6.c:(.text+0x14ee5d): undefined reference to `fl6_update_dst' l2tp_ip6.c:(.text+0x14eea3): undefined reference to `ip6_dst_lookup_flow' l2tp_ip6.c:(.text+0x14eee7): undefined reference to `ip6_dst_hoplimit' l2tp_ip6.c:(.text+0x14ef8b): undefined reference to `ip6_append_data' l2tp_ip6.c:(.text+0x14ef9d): undefined reference to `ip6_flush_pending_frames' l2tp_ip6.c:(.text+0x14efe2): undefined reference to `ip6_push_pending_frames' net/built-in.o: In function `l2tp_ip6_destroy_sock': l2tp_ip6.c:(.text+0x14f090): undefined reference to `ip6_flush_pending_frames' l2tp_ip6.c:(.text+0x14f0a0): undefined reference to `inet6_destroy_sock' net/built-in.o: In function `l2tp_ip6_connect': l2tp_ip6.c:(.text+0x14f14d): undefined reference to `ip6_datagram_connect' net/built-in.o: In function `l2tp_ip6_bind': l2tp_ip6.c:(.text+0x14f4fe): undefined reference to `ipv6_chk_addr' net/built-in.o: In function `l2tp_ip6_init': l2tp_ip6.c:(.init.text+0x73fa): undefined reference to `inet6_add_protocol' l2tp_ip6.c:(.init.text+0x740c): undefined reference to `inet6_register_protosw' net/built-in.o: In function `l2tp_ip6_exit': l2tp_ip6.c:(.exit.text+0x1954): undefined reference to `inet6_unregister_protosw' l2tp_ip6.c:(.exit.text+0x1965): undefined reference to `inet6_del_protocol' net/built-in.o:(.rodata+0xf2d0): undefined reference to `inet6_release' net/built-in.o:(.rodata+0xf2d8): undefined reference to `inet6_bind' net/built-in.o:(.rodata+0xf308): undefined reference to `inet6_ioctl' net/built-in.o:(.data+0x1af40): undefined reference to `ipv6_setsockopt' net/built-in.o:(.data+0x1af48): undefined reference to `ipv6_getsockopt' net/built-in.o:(.data+0x1af50): undefined reference to `compat_ipv6_setsockopt' net/built-in.o:(.data+0x1af58): undefined reference to `compat_ipv6_getsockopt' make: *** [vmlinux] Error 1 This is due to l2tp uses symbols from IPV6, so when IPV6 is a module, l2tp is not allowed to be builtin. Cc: David Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/netfilter/nfnetlink_log.c net/netfilter/xt_LOG.c Rather easy conflict resolution, the 'net' tree had bug fixes to make sure we checked if a socket is a time-wait one or not and elide the logging code if so. Whereas on the 'net-next' side we are calculating the UID and GID from the creds using different interfaces due to the user namespace changes from Eric Biederman. Signed-off-by: David S. Miller <davem@davemloft.net>
