commit de3b58bc359a861d5132300f53f95e83f71954b3 upstream.
Revert commit 820da5357572 ("l2tp: fix missing print session offset
info"). The peer_offset parameter is removed.
Signed-off-by: James Chapman <jchapman@katalix.com>
Cc: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit eb1c28c05894a4b1f6b56c5bf072205e64cfa280 ]
Check sockaddr_len before dereferencing sp->sa_protocol, to ensure that
it actually points to valid data.
Fixes: fd558d186df2 ("l2tp: Split pppol2tp patch into separate l2tp and ppp parts")
Reported-by: syzbot+a70ac890b23b1bf29f5c@syzkaller.appspotmail.com
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 820da5357572715c6235ba3b3daa2d5b43a1198f ]
Report offset parameter in L2TP_CMD_SESSION_GET command if
it has been configured by userspace
Fixes: 309795f4bec ("l2tp: Add netlink control API for L2TP")
Reported-by: Jianlin Shi <jishi@redhat.com>
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit 17cfe79a65f98abe535261856c5aef14f306dff7 ]
syzkaller found an issue caused by lack of sufficient checks
in l2tp_tunnel_create()
RAW sockets can not be considered as UDP ones for instance.
In another patch, we shall replace all pr_err() by less intrusive
pr_debug() so that syzkaller can find other bugs faster.
Acked-by: Guillaume Nault <g.nault@alphalink.fr>
Acked-by: James Chapman <jchapman@katalix.com>
BUG: KASAN: slab-out-of-bounds in setup_udp_tunnel_sock+0x3ee/0x5f0 net/ipv4/udp_tunnel.c:69
dst_release: dst:00000000d53d0d0f refcnt:-1
Write of size 1 at addr ffff8801d013b798 by task syz-executor3/6242
CPU: 1 PID: 6242 Comm: syz-executor3 Not tainted 4.16.0-rc2+ #253
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x24d lib/dump_stack.c:53
print_address_description+0x73/0x250 mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report+0x23b/0x360 mm/kasan/report.c:412
__asan_report_store1_noabort+0x17/0x20 mm/kasan/report.c:435
l2tp_tunnel_create+0x1354/0x17f0 net/l2tp/l2tp_core.c:1596
pppol2tp_connect+0x14b1/0x1dd0 net/l2tp/l2tp_ppp.c:707
SYSC_connect+0x213/0x4a0 net/socket.c:1640
SyS_connect+0x24/0x30 net/socket.c:1621
do_syscall_64+0x280/0x940 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x42/0xb7
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 4dc12ffeaeac939097a3f55c881d3dc3523dff0c ]
l2tp_tunnel_delete does not return anything since commit 62b982eeb458
("l2tp: fix race condition in l2tp_tunnel_delete"). But call sites of
l2tp_tunnel_delete still do casts to void to avoid unused return value
warnings.
Kill these now useless casts.
Cc: Sabrina Dubroca <sd@queasysnail.net>
Cc: netdev@vger.kernel.org
[ Upstream commit 5903f594935a3841137c86b9d5b75143a5b7121c ]
When pppol2tp_session_ioctl() is called by pppol2tp_tunnel_ioctl(),
the session may be unconnected. That is, it was created by
pppol2tp_session_create() and hasn't been connected with
pppol2tp_connect(). In this case, ps->sock is NULL, so we need to check
for this case in order to avoid dereferencing a NULL pointer.
Fixes: 309795f4bec2 ("l2tp: Add netlink control API for L2TP")
[ Upstream commit 62b982eeb4589b2e6d7c01a90590e3a4c2b2ca19 ]
If we try to delete the same tunnel twice, the first delete operation
does a lookup (l2tp_tunnel_get), finds the tunnel, calls
l2tp_tunnel_delete, which queues it for deletion by
l2tp_tunnel_del_work.
The second delete operation also finds the tunnel and calls
l2tp_tunnel_delete. If the workqueue has already fired and started
running l2tp_tunnel_del_work, then l2tp_tunnel_delete will queue the
same tunnel a second time, and try to free the socket again.
Add a dead flag to prevent firing the workqueue twice. Then we can
remove the check of queue_work's result that was meant to prevent that
race but doesn't.
Reproducer:
ip l2tp add tunnel tunnel_id 3000 peer_tunnel_id 4000 local 192.168.0.2 remote 192.168.0.1 encap udp udp_sport 5000 udp_dport 6000
ip l2tp add session name l2tp1 tunnel_id 3000 session_id 1000 peer_session_id 2000
ip link set l2tp1 up
ip l2tp del tunnel tunnel_id 3000
Fixes: f8ccac0e4493 ("l2tp: put tunnel socket release on a workqueue")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
[ Upstream commit 12d656af4e3d2781b9b9f52538593e1717e7c979 ]
While destroying a network namespace that contains a L2TP tunnel a
"BUG: scheduling while atomic" can be observed.
Enabling lockdep shows that this is happening because l2tp_exit_net()
is calling l2tp_tunnel_closeall() (via l2tp_tunnel_delete()) from
within an RCU critical section.
l2tp_exit_net() takes rcu_read_lock_bh()
<< list_for_each_entry_rcu() >>
__l2tp_session_unhash()
synchronize_rcu() << Illegal inside RCU critical section >>
BUG: sleeping function called from invalid context
in_atomic(): 1, irqs_disabled(): 0, pid: 86, name: kworker/u16:2
INFO: lockdep is turned off.
CPU: 2 PID: 86 Comm: kworker/u16:2 Tainted: G W O 4.4.6-at1 #2
Hardware name: Xen HVM domU, BIOS 4.6.1-xs125300 05/09/2016
Workqueue: netns cleanup_net
0000000000000000 ffff880202417b90 ffffffff812b0013 ffff880202410ac0
ffffffff81870de8 ffff880202417bb8 ffffffff8107aee8 ffffffff81870de8
0000000000000c51 0000000000000000 ffff880202417be0 ffffffff8107b024
Call Trace:
[<ffffffff812b0013>] dump_stack+0x85/0xc2
[<ffffffff8107aee8>] ___might_sleep+0x148/0x240
[<ffffffff8107b024>] __might_sleep+0x44/0x80
[<ffffffff810b21bd>] synchronize_sched+0x2d/0xe0
[<ffffffff8109be6d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff8105c7bb>] ? __local_bh_enable_ip+0x6b/0xc0
[<ffffffff816a1b00>] ? _raw_spin_unlock_bh+0x30/0x40
[<ffffffff81667482>] __l2tp_session_unhash+0x172/0x220
[<ffffffff81667397>] ? __l2tp_session_unhash+0x87/0x220
[<ffffffff8166888b>] l2tp_tunnel_closeall+0x9b/0x140
[<ffffffff81668c74>] l2tp_tunnel_delete+0x14/0x60
[<ffffffff81668dd0>] l2tp_exit_net+0x110/0x270
[<ffffffff81668d5c>] ? l2tp_exit_net+0x9c/0x270
[<ffffffff815001c3>] ops_exit_list.isra.6+0x33/0x60
[<ffffffff81501166>] cleanup_net+0x1b6/0x280
This bug can easily be reproduced with a few steps:
$ sudo unshare -n bash # Create a shell in a new namespace
# ip link set lo up
# ip addr add 127.0.0.1 dev lo
# ip l2tp add tunnel remote 127.0.0.1 local 127.0.0.1 tunnel_id 1 \
peer_tunnel_id 1 udp_sport 50000 udp_dport 50000
# ip l2tp add session name foo tunnel_id 1 session_id 1 \
peer_session_id 1
# ip link set foo up
# exit # Exit the shell, in turn exiting the namespace
$ dmesg
[942121.089216] BUG: scheduling while atomic: kworker/u16:3/13872/0x00000200
To fix this, move the call to l2tp_tunnel_closeall() out of the RCU
critical section, and instead call it from l2tp_tunnel_del_work(), which
is running from the l2tp_wq workqueue.
Fixes: 2b551c6e7d5b ("l2tp: close sessions before initiating tunnel delete")
Signed-off-by: Ridge Kennedy <ridge.kennedy@alliedtelesis.co.nz>
[ Upstream commit 249ee819e24c180909f43c1173c8ef6724d21faf ]
PPP pseudo-wire type is 7 (11 is L2TP_PWTYPE_IP).
Fixes: f1f39f911027 ("l2tp: auto load type modules")
[ Upstream commit e08293a4ccbcc993ded0fdc46f1e57926b833d63 ]
Take a reference on the sessions returned by l2tp_session_find_nth()
(and rename it l2tp_session_get_nth() to reflect this change), so that
caller is assured that the session isn't going to disappear while
processing it.
For procfs and debugfs handlers, the session is held in the .start()
callback and dropped in .show(). Given that pppol2tp_seq_session_show()
dereferences the associated PPPoL2TP socket and that
l2tp_dfs_seq_session_show() might call pppol2tp_show(), we also need to
call the session's .ref() callback to prevent the socket from going
away from under us.
Fixes: 0ad6614048cf ("l2tp: Add debugfs files for dumping l2tp debug info")
[ Upstream commit e91793bb615cf6cdd59c0b6749fe173687bb0947 ]
The Rx path may grab the socket right before pppol2tp_release(), but
nothing guarantees that it will enqueue packets before
skb_queue_purge(). Therefore, the socket can be destroyed without its
queues fully purged.
Fix this by purging queues in pppol2tp_session_destruct() where we're
guaranteed nothing is still referencing the socket.
Fixes: 9e9cb6221aa7 ("l2tp: fix userspace reception on plain L2TP sockets")
[ Upstream commit 51fb60eb162ab84c5edf2ae9c63cf0b878e5547e ]
l2tp_ip_backlog_recv may not return -1 if the packet gets dropped.
The return value is passed up to ip_local_deliver_finish, which treats
negative values as an IP protocol number for resubmission.
Signed-off-by: Paul Hüber <phueber@kernsp.in>
[ Upstream commit 72fb96e7bdbbdd4421b0726992496531060f3636 ]
udp_ioctl(), as its name suggests, is used by UDP protocols,
but is also used by L2TP :(
L2TP should use its own handler, because it really does not
look the same.
SIOCINQ for instance should not assume UDP checksum or headers.
Thanks to Andrey and syzkaller team for providing the report
and a nice reproducer.
While crashes only happen on recent kernels (after commit
7c13f97ffde6 ("udp: do fwd memory scheduling on dequeue")), this
probably needs to be backported to older kernels.
Fixes: 7c13f97ffde6 ("udp: do fwd memory scheduling on dequeue")
Fixes: 85584672012e ("udp: Fix udp_poll() and ioctl()")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 32c231164b762dddefa13af5a0101032c70b50ef ]
Lock socket before checking the SOCK_ZAPPED flag in l2tp_ip6_bind().
Without lock, a concurrent call could modify the socket flags between
the sock_flag(sk, SOCK_ZAPPED) test and the lock_sock() call. This way,
a socket could be inserted twice in l2tp_ip6_bind_table. Releasing it
would then leave a stale pointer there, generating use-after-free
errors when walking through the list or modifying adjacent entries.
BUG: KASAN: use-after-free in l2tp_ip6_close+0x22e/0x290 at addr ffff8800081b0ed8
Write of size 8 by task syz-executor/10987
CPU: 0 PID: 10987 Comm: syz-executor Not tainted 4.8.0+ #39
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.8.2-0-g33fbe13 by qemu-project.org 04/01/2014
ffff880031d97838 ffffffff829f835b ffff88001b5a1640 ffff8800081b0ec0
ffff8800081b15a0 ffff8800081b6d20 ffff880031d97860 ffffffff8174d3cc
ffff880031d978f0 ffff8800081b0e80 ffff88001b5a1640 ffff880031d978e0
Call Trace:
[<ffffffff829f835b>] dump_stack+0xb3/0x118 lib/dump_stack.c:15
[<ffffffff8174d3cc>] kasan_object_err+0x1c/0x70 mm/kasan/report.c:156
[< inline >] print_address_description mm/kasan/report.c:194
[<ffffffff8174d666>] kasan_report_error+0x1f6/0x4d0 mm/kasan/report.c:283
[< inline >] kasan_report mm/kasan/report.c:303
[<ffffffff8174db7e>] __asan_report_store8_noabort+0x3e/0x40 mm/kasan/report.c:329
[< inline >] __write_once_size ./include/linux/compiler.h:249
[< inline >] __hlist_del ./include/linux/list.h:622
[< inline >] hlist_del_init ./include/linux/list.h:637
[<ffffffff8579047e>] l2tp_ip6_close+0x22e/0x290 net/l2tp/l2tp_ip6.c:239
[<ffffffff850b2dfd>] inet_release+0xed/0x1c0 net/ipv4/af_inet.c:415
[<ffffffff851dc5a0>] inet6_release+0x50/0x70 net/ipv6/af_inet6.c:422
[<ffffffff84c4581d>] sock_release+0x8d/0x1d0 net/socket.c:570
[<ffffffff84c45976>] sock_close+0x16/0x20 net/socket.c:1017
[<ffffffff817a108c>] __fput+0x28c/0x780 fs/file_table.c:208
[<ffffffff817a1605>] ____fput+0x15/0x20 fs/file_table.c:244
[<ffffffff813774f9>] task_work_run+0xf9/0x170
[<ffffffff81324aae>] do_exit+0x85e/0x2a00
[<ffffffff81326dc8>] do_group_exit+0x108/0x330
[<ffffffff81348cf7>] get_signal+0x617/0x17a0 kernel/signal.c:2307
[<ffffffff811b49af>] do_signal+0x7f/0x18f0
[<ffffffff810039bf>] exit_to_usermode_loop+0xbf/0x150 arch/x86/entry/common.c:156
[< inline >] prepare_exit_to_usermode arch/x86/entry/common.c:190
[<ffffffff81006060>] syscall_return_slowpath+0x1a0/0x1e0 arch/x86/entry/common.c:259
[<ffffffff85e4d726>] entry_SYSCALL_64_fastpath+0xc4/0xc6
Object at ffff8800081b0ec0, in cache L2TP/IPv6 size: 1448
Allocated:
PID = 10987
[ 1116.897025] [<ffffffff811ddcb6>] save_stack_trace+0x16/0x20
[ 1116.897025] [<ffffffff8174c736>] save_stack+0x46/0xd0
[ 1116.897025] [<ffffffff8174c9ad>] kasan_kmalloc+0xad/0xe0
[ 1116.897025] [<ffffffff8174cee2>] kasan_slab_alloc+0x12/0x20
[ 1116.897025] [< inline >] slab_post_alloc_hook mm/slab.h:417
[ 1116.897025] [< inline >] slab_alloc_node mm/slub.c:2708
[ 1116.897025] [< inline >] slab_alloc mm/slub.c:2716
[ 1116.897025] [<ffffffff817476a8>] kmem_cache_alloc+0xc8/0x2b0 mm/slub.c:2721
[ 1116.897025] [<ffffffff84c4f6a9>] sk_prot_alloc+0x69/0x2b0 net/core/sock.c:1326
[ 1116.897025] [<ffffffff84c58ac8>] sk_alloc+0x38/0xae0 net/core/sock.c:1388
[ 1116.897025] [<ffffffff851ddf67>] inet6_create+0x2d7/0x1000 net/ipv6/af_inet6.c:182
[ 1116.897025] [<ffffffff84c4af7b>] __sock_create+0x37b/0x640 net/socket.c:1153
[ 1116.897025] [< inline >] sock_create net/socket.c:1193
[ 1116.897025] [< inline >] SYSC_socket net/socket.c:1223
[ 1116.897025] [<ffffffff84c4b46f>] SyS_socket+0xef/0x1b0 net/socket.c:1203
[ 1116.897025] [<ffffffff85e4d685>] entry_SYSCALL_64_fastpath+0x23/0xc6
Freed:
PID = 10987
[ 1116.897025] [<ffffffff8174cf61>] kasan_slab_free+0x71/0xb0
[ 1116.897025] [< inline >] slab_free_hook mm/slub.c:1352
[ 1116.897025] [< inline >] slab_free_freelist_hook mm/slub.c:1374
[ 1116.897025] [< inline >] slab_free mm/slub.c:2951
[ 1116.897025] [<ffffffff81748b28>] kmem_cache_free+0xc8/0x330 mm/slub.c:2973
[ 1116.897025] [< inline >] sk_prot_free net/core/sock.c:1369
[ 1116.897025] [<ffffffff84c541eb>] __sk_destruct+0x32b/0x4f0 net/core/sock.c:1444
[ 1116.897025] [<ffffffff84c5aca4>] sk_destruct+0x44/0x80 net/core/sock.c:1452
[ 1116.897025] [<ffffffff84c5ad33>] __sk_free+0x53/0x220 net/core/sock.c:1460
[ 1116.897025] [<ffffffff84c5af23>] sk_free+0x23/0x30 net/core/sock.c:1471
[ 1116.897025] [<ffffffff84c5cb6c>] sk_common_release+0x28c/0x3e0 ./include/net/sock.h:1589
[ 1116.897025] [<ffffffff8579044e>] l2tp_ip6_close+0x1fe/0x290 net/l2tp/l2tp_ip6.c:243
[ 1116.897025] [<ffffffff850b2dfd>] inet_release+0xed/0x1c0 net/ipv4/af_inet.c:415
[ 1116.897025] [<ffffffff851dc5a0>] inet6_release+0x50/0x70 net/ipv6/af_inet6.c:422
[ 1116.897025] [<ffffffff84c4581d>] sock_release+0x8d/0x1d0 net/socket.c:570
[ 1116.897025] [<ffffffff84c45976>] sock_close+0x16/0x20 net/socket.c:1017
[ 1116.897025] [<ffffffff817a108c>] __fput+0x28c/0x780 fs/file_table.c:208
[ 1116.897025] [<ffffffff817a1605>] ____fput+0x15/0x20 fs/file_table.c:244
[ 1116.897025] [<ffffffff813774f9>] task_work_run+0xf9/0x170
[ 1116.897025] [<ffffffff81324aae>] do_exit+0x85e/0x2a00
[ 1116.897025] [<ffffffff81326dc8>] do_group_exit+0x108/0x330
[ 1116.897025] [<ffffffff81348cf7>] get_signal+0x617/0x17a0 kernel/signal.c:2307
[ 1116.897025] [<ffffffff811b49af>] do_signal+0x7f/0x18f0
[ 1116.897025] [<ffffffff810039bf>] exit_to_usermode_loop+0xbf/0x150 arch/x86/entry/common.c:156
[ 1116.897025] [< inline >] prepare_exit_to_usermode arch/x86/entry/common.c:190
[ 1116.897025] [<ffffffff81006060>] syscall_return_slowpath+0x1a0/0x1e0 arch/x86/entry/common.c:259
[ 1116.897025] [<ffffffff85e4d726>] entry_SYSCALL_64_fastpath+0xc4/0xc6
Memory state around the buggy address:
ffff8800081b0d80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8800081b0e00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff8800081b0e80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8800081b0f00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8800081b0f80: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
The same issue exists with l2tp_ip_bind() and l2tp_ip_bind_table.
Fixes: c51ce49735c1 ("l2tp: fix oops in L2TP IP sockets for connect() AF_UNSPEC case")
Reported-by: Baozeng Ding <sploving1@gmail.com>
Tested-by: Baozeng Ding <sploving1@gmail.com>
[ Upstream commit a5c5e2da8551eb69e5d5d09d51d526140b5db9fb ]
Unused fields of udp_cfg must be all zeros. Otherwise
setup_udp_tunnel_sock() fills ->gro_receive and ->gro_complete
callbacks with garbage, eventually resulting in panic when used by
udp_gro_receive().
[ 72.694123] BUG: unable to handle kernel paging request at ffff880033f87d78
[ 72.695518] IP: [<ffff880033f87d78>] 0xffff880033f87d78
[ 72.696530] PGD 26e2067 PUD 26e3067 PMD 342ed063 PTE 8000000033f87163
[ 72.696530] Oops: 0011 [#1] SMP KASAN
[ 72.696530] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6_udp_tunnel udp_tunnel pptp gre pppox ppp_generic slhc crc32c_intel ghash_clmulni_intel jitterentropy_rng sha256_generic hmac drbg ansi_cprng aesni_intel evdev aes_x86_64 ablk_helper cryptd lrw gf128mul glue_helper serio_raw acpi_cpufreq button proc\
essor ext4 crc16 jbd2 mbcache virtio_blk virtio_net virtio_pci virtio_ring virtio
[ 72.696530] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.7.0-rc1 #1
[ 72.696530] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Debian-1.8.2-1 04/01/2014
[ 72.696530] task: ffff880035b59700 ti: ffff880035b70000 task.ti: ffff880035b70000
[ 72.696530] RIP: 0010:[<ffff880033f87d78>] [<ffff880033f87d78>] 0xffff880033f87d78
[ 72.696530] RSP: 0018:ffff880035f87bc0 EFLAGS: 00010246
[ 72.696530] RAX: ffffed000698f996 RBX: ffff88003326b840 RCX: ffffffff814cc823
[ 72.696530] RDX: ffff88003326b840 RSI: ffff880033e48038 RDI: ffff880034c7c780
[ 72.696530] RBP: ffff880035f87c18 R08: 000000000000a506 R09: 0000000000000000
[ 72.696530] R10: ffff880035f87b38 R11: ffff880034b9344d R12: 00000000ebfea715
[ 72.696530] R13: 0000000000000000 R14: ffff880034c7c780 R15: 0000000000000000
[ 72.696530] FS: 0000000000000000(0000) GS:ffff880035f80000(0000) knlGS:0000000000000000
[ 72.696530] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 72.696530] CR2: ffff880033f87d78 CR3: 0000000033c98000 CR4: 00000000000406a0
[ 72.696530] Stack:
[ 72.696530] ffffffff814cc834 ffff880034b93468 0000001481416818 ffff88003326b874
[ 72.696530] ffff880034c7ccb0 ffff880033e48038 ffff88003326b840 ffff880034b93462
[ 72.696530] ffff88003326b88a ffff88003326b88c ffff880034b93468 ffff880035f87c70
[ 72.696530] Call Trace:
[ 72.696530] <IRQ>
[ 72.696530] [<ffffffff814cc834>] ? udp_gro_receive+0x1c6/0x1f9
[ 72.696530] [<ffffffff814ccb1c>] udp4_gro_receive+0x2b5/0x310
[ 72.696530] [<ffffffff814d989b>] inet_gro_receive+0x4a3/0x4cd
[ 72.696530] [<ffffffff81431b32>] dev_gro_receive+0x584/0x7a3
[ 72.696530] [<ffffffff810adf7a>] ? __lock_is_held+0x29/0x64
[ 72.696530] [<ffffffff814321f7>] napi_gro_receive+0x124/0x21d
[ 72.696530] [<ffffffffa000b145>] virtnet_receive+0x8df/0x8f6 [virtio_net]
[ 72.696530] [<ffffffffa000b27e>] virtnet_poll+0x1d/0x8d [virtio_net]
[ 72.696530] [<ffffffff81431350>] net_rx_action+0x15b/0x3b9
[ 72.696530] [<ffffffff815893d6>] __do_softirq+0x216/0x546
[ 72.696530] [<ffffffff81062392>] irq_exit+0x49/0xb6
[ 72.696530] [<ffffffff81588e9a>] do_IRQ+0xe2/0xfa
[ 72.696530] [<ffffffff81587a49>] common_interrupt+0x89/0x89
[ 72.696530] <EOI>
[ 72.696530] [<ffffffff810b05df>] ? trace_hardirqs_on_caller+0x229/0x270
[ 72.696530] [<ffffffff8102b3c7>] ? default_idle+0x1c/0x2d
[ 72.696530] [<ffffffff8102b3c5>] ? default_idle+0x1a/0x2d
[ 72.696530] [<ffffffff8102bb8c>] arch_cpu_idle+0xa/0xc
[ 72.696530] [<ffffffff810a6c39>] default_idle_call+0x1a/0x1c
[ 72.696530] [<ffffffff810a6d96>] cpu_startup_entry+0x15b/0x20f
[ 72.696530] [<ffffffff81039a81>] start_secondary+0x12c/0x133
[ 72.696530] Code: ff ff ff ff ff ff ff ff ff ff 7f ff ff ff ff ff ff ff 7f 00 7e f8 33 00 88 ff ff 6d 61 58 81 ff ff ff ff 5e de 0a 81 ff ff ff ff <00> 5c e2 34 00 88 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 72.696530] RIP [<ffff880033f87d78>] 0xffff880033f87d78
[ 72.696530] RSP <ffff880035f87bc0>
[ 72.696530] ---[ end trace ad7758b9a1dccf99 ]---
[ 72.696530] Kernel panic - not syncing: Fatal exception in interrupt
[ 72.696530] Kernel Offset: disabled
[ 72.696530] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
v2: use empty initialiser instead of "{ NULL }" to avoid relying on
first field's type.
Fixes: 38fd2af24fcf ("udp: Add socket based GRO and config")
[ Upstream commit be447f305494e019dfc37ea4cdf3b0e4200b4eba ]
pskb_may_pull() can change skb->data, so we have to load ptr/optr at the
right place.
Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com>
[ Upstream commit 5745b8232e942abd5e16e85fa9b27cc21324acf0 ]
right place.
[ Upstream commit 853effc55b0f975abd6d318cca486a9c1b67e10f ]
A previous commit (33f72e6) added notification via netlink for tunnels
when created/modified/deleted. If the notification returned an error,
this error was returned from the tunnel function. If there were no
listeners, the error code ESRCH was returned, even though having no
listeners is not an error. Other calls to this and other similar
notification functions either ignore the error code, or filter ESRCH.
This patch checks for ESRCH and does not flag this as an error.
Reviewed-by: Hamish Martin <hamish.martin@alliedtelesis.co.nz>
Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
This patch addresses multiple problems :
UDP/RAW sendmsg() need to get a stable struct ipv6_txoptions
while socket is not locked : Other threads can change np->opt
concurrently. Dmitry posted a syzkaller
(http://github.com/google/syzkaller) program desmonstrating
use-after-free.
Starting with TCP/DCCP lockless listeners, tcp_v6_syn_recv_sock()
and dccp_v6_request_recv_sock() also need to use RCU protection
to dereference np->opt once (before calling ipv6_dup_options())
This patch adds full RCU protection to np->opt
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
net/dsa/slave.c
net/dsa/slave.c simply had overlapping changes.
There is a small chance that tunnel_free() is called before tunnel->del_work scheduled
resulting in a zero pointer dereference.
Signed-off-by: Alexander Couzens <lynxis@fe80.eu>
When creating a IP encapsulated tunnel the necessary l2tp module
should be loaded. It already works for UDP encapsulation, it just
doesn't work for direct IP encap.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
It should not be necessary to do explicit module loading when
configuring L2TP. Modules should be loaded as needed instead
(as is done already with netlink and other tunnel types).
This patch adds a new module alias type and code to load
the sub module on demand.
Now that sk_alloc knows when a kernel socket is being allocated modify
it to not reference count the network namespace of kernel sockets.
Keep track of if a socket needs reference counting by adding a flag to
struct sock called sk_net_refcnt.
Update all of the callers of sock_create_kern to stop using
sk_change_net and sk_release_kernel as those hacks are no longer
needed, to avoid reference counting a kernel socket.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
This is long overdue, and is part of cleaning up how we allocate kernel
sockets that don't reference count struct net.
drivers/net/ethernet/mellanox/mlx4/cmd.c
net/core/fib_rules.c
net/ipv4/fib_frontend.c
The fib_rules.c and fib_frontend.c conflicts were locking adjustments
in 'net' overlapping addition and removal of code in 'net-next'.
The mlx4 conflict was a bug fix in 'net' happening in the same
place a constant was being replaced with a more suitable macro.
Those are counterparts to nla_put_in_addr and nla_put_in6_addr.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
IP addresses are often stored in netlink attributes. Add generic functions
to do that.
For nla_put_in_addr, it would be nicer to pass struct in_addr but this is
not used universally throughout the kernel, in way too many places __be32 is
used to store IPv4 address.
Use the built-in function instead of memset.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Contrary to common expectations for an "int" return, these functions
return only a positive value -- if used correctly they cannot even
return 0 because the message header will necessarily be in the skb.
This makes the very common pattern of
if (genlmsg_end(...) < 0) { ... }
be a whole bunch of dead code. Many places also simply do
return nlmsg_end(...);
and the caller is expected to deal with it.
This also commonly (at least for me) causes errors, because it is very
common to write
if (my_function(...))
/* error condition */
and if my_function() does "return nlmsg_end()" this is of course wrong.
Additionally, there's not a single place in the kernel that actually
needs the message length returned, and if anyone needs it later then
it'll be very easy to just use skb->len there.
Remove this, and make the functions void. This removes a bunch of dead
code as described above. The patch adds lines because I did
- return nlmsg_end(...);
+ nlmsg_end(...);
+ return 0;
I could have preserved all the function's return values by returning
skb->len, but instead I've audited all the places calling the affected
functions and found that none cared. A few places actually compared
the return value with <= 0 in dump functionality, but that could just
be changed to < 0 with no change in behaviour, so I opted for the more
efficient version.
One instance of the error I've made numerous times now is also present
in net/phonet/pn_netlink.c in the route_dumpit() function - it didn't
check for <0 or <=0 and thus broke out of the loop every single time.
I've preserved this since it will (I think) have caused the messages to
userspace to be formatted differently with just a single message for
every SKB returned to userspace. It's possible that this isn't needed
for the tools that actually use this, but I don't even know what they
are so couldn't test that changing this behaviour would be acceptable.
Previously l2tp module did not provide any means for the user space to
get notified when tunnels/sessions are added/modified/deleted.
This change contains the following
- create a multicast group for the listeners to register.
- notify the registered listeners when the tunnels/sessions are
Signed-off-by: Bill Hong <bhong@brocade.com>
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
Reviewed-by: Sven-Thorsten Dietrich <sven@brocade.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Simplify l2tp implementation using common UDP tunnel APIs.
Signed-off-by: Andy Zhou <azhou@nicira.com>
This syntax error was covered by L2TP_REFCNT_DEBUG not being set by
default.
Use dst_entry held by sk_dst_get() to retrieve tunnel's PMTU.
The dst_mtu(__sk_dst_get(tunnel->sock)) call was racy. __sk_dst_get()
could return NULL if tunnel->sock->sk_dst_cache was reset just before the
call, thus making dst_mtu() dereference a NULL pointer:
[ 1937.661598] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
[ 1937.664005] IP: [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] PGD daf0c067 PUD d9f93067 PMD 0
[ 1937.664005] Oops: 0000 [#1] SMP
[ 1937.664005] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6table_filter ip6_tables iptable_filter ip_tables ebtable_nat ebtables x_tables udp_tunnel pppoe pppox ppp_generic slhc deflate ctr twofish_generic twofish_x86_64_3way xts lrw gf128mul glue_helper twofish_x86_64 twofish_common blowfish_generic blowfish_x86_64 blowfish_common des_generic cbc xcbc rmd160 sha512_generic hmac crypto_null af_key xfrm_algo 8021q garp bridge stp llc tun atmtcp clip atm ext3 mbcache jbd iTCO_wdt coretemp kvm_intel iTCO_vendor_support kvm pcspkr evdev ehci_pci lpc_ich mfd_core i5400_edac edac_core i5k_amb shpchp button processor thermal_sys xfs crc32c_generic libcrc32c dm_mod usbhid sg hid sr_mod sd_mod cdrom crc_t10dif crct10dif_common ata_generic ahci ata_piix tg3 libahci libata uhci_hcd ptp ehci_hcd pps_core usbcore scsi_mod libphy usb_common [last unloaded: l2tp_core]
[ 1937.664005] CPU: 0 PID: 10022 Comm: l2tpstress Tainted: G O 3.17.0-rc1 #1
[ 1937.664005] Hardware name: HP ProLiant DL160 G5, BIOS O12 08/22/2008
[ 1937.664005] task: ffff8800d8fda790 ti: ffff8800c43c4000 task.ti: ffff8800c43c4000
[ 1937.664005] RIP: 0010:[<ffffffffa049db88>] [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] RSP: 0018:ffff8800c43c7de8 EFLAGS: 00010282
[ 1937.664005] RAX: ffff8800da8a7240 RBX: ffff8800d8c64600 RCX: 000001c325a137b5
[ 1937.664005] RDX: 8c6318c6318c6320 RSI: 000000000000010c RDI: 0000000000000000
[ 1937.664005] RBP: ffff8800c43c7ea8 R08: 0000000000000000 R09: 0000000000000000
[ 1937.664005] R10: ffffffffa048e2c0 R11: ffff8800d8c64600 R12: ffff8800ca7a5000
[ 1937.664005] R13: ffff8800c439bf40 R14: 000000000000000c R15: 0000000000000009
[ 1937.664005] FS: 00007fd7f610f700(0000) GS:ffff88011a600000(0000) knlGS:0000000000000000
[ 1937.664005] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1937.664005] CR2: 0000000000000020 CR3: 00000000d9d75000 CR4: 00000000000027e0
[ 1937.664005] Stack:
[ 1937.664005] ffffffffa049da80 ffff8800d8fda790 000000000000005b ffff880000000009
[ 1937.664005] ffff8800daf3f200 0000000000000003 ffff8800c43c7e48 ffffffff81109b57
[ 1937.664005] ffffffff81109b0e ffffffff8114c566 0000000000000000 0000000000000000
[ 1937.664005] Call Trace:
[ 1937.664005] [<ffffffffa049da80>] ? pppol2tp_connect+0x235/0x41e [l2tp_ppp]
[ 1937.664005] [<ffffffff81109b57>] ? might_fault+0x9e/0xa5
[ 1937.664005] [<ffffffff81109b0e>] ? might_fault+0x55/0xa5
[ 1937.664005] [<ffffffff8114c566>] ? rcu_read_unlock+0x1c/0x26
[ 1937.664005] [<ffffffff81309196>] SYSC_connect+0x87/0xb1
[ 1937.664005] [<ffffffff813e56f7>] ? sysret_check+0x1b/0x56
[ 1937.664005] [<ffffffff8107590d>] ? trace_hardirqs_on_caller+0x145/0x1a1
[ 1937.664005] [<ffffffff81213dee>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[ 1937.664005] [<ffffffff8114c262>] ? spin_lock+0x9/0xb
[ 1937.664005] [<ffffffff813092b4>] SyS_connect+0x9/0xb
[ 1937.664005] [<ffffffff813e56d2>] system_call_fastpath+0x16/0x1b
[ 1937.664005] Code: 10 2a 84 81 e8 65 76 bd e0 65 ff 0c 25 10 bb 00 00 4d 85 ed 74 37 48 8b 85 60 ff ff ff 48 8b 80 88 01 00 00 48 8b b8 10 02 00 00 <48> 8b 47 20 ff 50 20 85 c0 74 0f 83 e8 28 89 83 10 01 00 00 89
[ 1937.664005] RIP [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] RSP <ffff8800c43c7de8>
[ 1939.559375] ---[ end trace 82d44500f28f8708 ]---
Fixes: f34c4a35d879 ("l2tp: take PMTU from tunnel UDP socket")
Signed-off-by: Tom Herbert <therbert@google.com>
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
The l2tp [get|set]sockopt() code has fallen back to the UDP functions
for socket option levels != SOL_PPPOL2TP since day one, but that has
never actually worked, since the l2tp socket isn't an inet socket.
As David Miller points out:
"If we wanted this to work, it'd have to look up the tunnel and then
use tunnel->sk, but I wonder how useful that would be"
Since this can never have worked so nobody could possibly have depended
on that functionality, just remove the broken code and return -EINVAL.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Acked-by: David Miller <davem@davemloft.net>
Cc: Phil Turnbull <phil.turnbull@oracle.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: stable@vger.kernel.org
In l2tp driver call common function udp_sock_create to create the
listener UDP port.
Call common functions to set checksum for UDP tunnel.
Added new L2TP configuration options to allow TX and RX of
zero checksums in IPv6. Default is not to use them.
