path: root/net/l3mdev/l3mdev.c
2016-09-10net: ipv6: Remove l3mdev_get_saddr6David Ahern
No longer needed Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net: ipv4: Remove l3mdev_get_saddrDavid Ahern
2016-09-10net: vrf: Flip IPv6 output path from FIB lookup hook to out hookDavid Ahern
Flip the IPv6 output path to use the l3mdev tx out hook. The VRF dst is not returned on the first FIB lookup. Instead, the dst on the skb is switched at the beginning of the IPv6 output processing to send the packet to the VRF driver on xmit. Link scope addresses (linklocal and multicast) need special handling: specifically the oif the flow struct can not be changed because we want the lookup tied to the enslaved interface. ie., the source address and the returned route MUST point to the interface scope passed in. Convert the existing vrf_get_rt6_dst to handle only link scope addresses. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net: flow: Add l3mdev flow updateDavid Ahern
Add l3mdev hook to set FLOWI_FLAG_SKIP_NH_OIF flag and update oif/iif in flow struct if its oif or iif points to a device enslaved to an L3 Master device. Only 1 needs to be converted to match the l3mdev FIB rule. This moves the flow adjustment for l3mdev to a single point catching all lookups. It is redundant for existing hooks (those are removed in later patches) but is needed for missed lookups such as PMTU updates. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-17net: vrf: Implement get_saddr for IPv6David Ahern
IPv6 source address selection needs to consider the real egress route. Similar to IPv4 implement a get_saddr6 method which is called if source address has not been set. The get_saddr6 method does a full lookup which means pulling a route from the VRF FIB table and properly considering linklocal/multicast destination addresses. Lookup failures (eg., unreachable) then cause the source address selection to fail which gets propagated back to the caller. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-15net: l3mdev: Remove const from flowi6 arg to get_rt6_dstDavid Ahern
Allow drivers to pass flow arg to functions where the arg is not const and allow the driver to make updates as needed (eg., setting oif). Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-08net: Add l3mdev ruleDavid Ahern
Currently, VRFs require 1 oif and 1 iif rule per address family per VRF. As the number of VRF devices increases it brings scalability issues with the increasing rule list. All of the VRF rules have the same format with the exception of the specific table id to direct the lookup. Since the table id is available from the oif or iif in the loopup, the VRF rules can be consolidated to a single rule that pulls the table from the VRF device. This patch introduces a new rule attribute l3mdev. The l3mdev rule means the table id used for the lookup is pulled from the L3 master device (e.g., VRF) rather than being statically defined. With the l3mdev rule all of the basic VRF FIB rules are reduced to 1 l3mdev rule per address family (IPv4 and IPv6). If an admin wishes to insert higher priority rules for specific VRFs those rules will co-exist with the l3mdev rule. This capability means current VRF scripts will co-exist with this new simpler implementation. Currently, the rules list for both ipv4 and ipv6 look like this: $ ip ru ls 1000: from all oif vrf1 lookup 1001 1000: from all iif vrf1 lookup 1001 1000: from all oif vrf2 lookup 1002 1000: from all iif vrf2 lookup 1002 1000: from all oif vrf3 lookup 1003 1000: from all iif vrf3 lookup 1003 1000: from all oif vrf4 lookup 1004 1000: from all iif vrf4 lookup 1004 1000: from all oif vrf5 lookup 1005 1000: from all iif vrf5 lookup 1005 1000: from all oif vrf6 lookup 1006 1000: from all iif vrf6 lookup 1006 1000: from all oif vrf7 lookup 1007 1000: from all iif vrf7 lookup 1007 1000: from all oif vrf8 lookup 1008 1000: from all iif vrf8 lookup 1008 ... 32765: from all lookup local 32766: from all lookup main 32767: from all lookup default With the l3mdev rule the list is just the following regardless of the number of VRFs: $ ip ru ls 1000: from all lookup [l3mdev table] 32765: from all lookup local 32766: from all lookup main 32767: from all lookup default (Note: the above pretty print of the rule is based on an iproute2 prototype. Actual verbage may change) Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-09net: l3mdev: Allow send on enslaved interfaceDavid Ahern
Allow udp and raw sockets to send by oif that is an enslaved interface versus the l3mdev/VRF device. For example, this allows BFD to use ifindex from IP_PKTINFO on a receive to send a response without the need to convert to the VRF index. It also allows ping and ping6 to work when specifying an enslaved interface (e.g., ping -I swp1 <ip>) which is a natural use case. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-09net: l3mdev: Move get_saddr and rt6_dstDavid Ahern
Move l3mdev_rt6_dst_by_oif and l3mdev_get_saddr to l3mdev.c. Collapse l3mdev_get_rt6_dst into l3mdev_rt6_dst_by_oif since it is the only user and keep the l3mdev_get_rt6_dst name for consistency with other hooks. A follow-on patch adds more code to these functions making them long for inlined functions. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-26net: l3mdev: address selection should only consider devices in L3 domainDavid Ahern
David Lamparter noted a use case where the source address selection fails to pick an address from a VRF interface - unnumbered interfaces. Relevant commands from his script: ip addr add 9.9.9.9/32 dev lo ip link set lo up ip link add name vrf0 type vrf table 101 ip rule add oif vrf0 table 101 ip rule add iif vrf0 table 101 ip link set vrf0 up ip addr add 10.0.0.3/32 dev vrf0 ip link add name dummy2 type dummy ip link set dummy2 master vrf0 up --> note dummy2 has no address - unnumbered device ip route add 10.2.2.2/32 dev dummy2 table 101 ip neigh add 10.2.2.2 dev dummy2 lladdr 02:00:00:00:00:02 tcpdump -ni dummy2 & And using ping instead of his socat example: $ ping -I vrf0 -c1 10.2.2.2 ping: Warning: source address might be selected on device other than vrf0. PING 10.2.2.2 (10.2.2.2) from 9.9.9.9 vrf0: 56(84) bytes of data. >From tcpdump: 12:57:29.449128 IP 9.9.9.9 > 10.2.2.2: ICMP echo request, id 2491, seq 1, length 64 Note the source address is from lo and is not a VRF local address. With this patch: $ ping -I vrf0 -c1 10.2.2.2 PING 10.2.2.2 (10.2.2.2) from 10.0.0.3 vrf0: 56(84) bytes of data. >From tcpdump: 12:59:25.096426 IP 10.0.0.3 > 10.2.2.2: ICMP echo request, id 2113, seq 1, length 64 Now the source address comes from vrf0. The ipv4 function for selecting source address takes a const argument. Removing the const requires touching a lot of places, so instead l3mdev_master_ifindex_rcu is changed to take a const argument and then do the typecast to non-const as required by netdev_master_upper_dev_get_rcu. This is similar to what l3mdev_fib_table_rcu does. IPv6 for unnumbered interfaces appears to be selecting the addresses properly. Cc: David Lamparter <david@opensourcerouting.org> Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-07net: Add netif_is_l3_slaveDavid Ahern
IPv6 addrconf keys off of IFF_SLAVE so can not use it for L3 slave. Add a new private flag and add netif_is_l3_slave function for checking it. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-29net: Introduce L3 Master device abstractionDavid Ahern
L3 master devices allow users of the abstraction to influence FIB lookups for enslaved devices. Current API provides a means for the master device to return a specific FIB table for an enslaved device, to return an rtable/custom dst and influence the OIF used for fib lookups. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
