path: root/net/lapb
2008-01-28[LAPB] net/lapb/lapb_iface.c: use LIST_HEAD instead of LIST_HEAD_INITDenis Cheng
single list_head variable initialized with LIST_HEAD_INIT could almost always can be replaced with LIST_HEAD declaration, this shrinks the code and looks better. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] LAPB: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-05[LAPB]: Fix windowsize checkDiego Calleja
In bug #6954, Norbert Reinartz reported the following issue: "Function lapb_setparms() in file net/lapb/lapb_iface.c checks if the given parameters are valid. If the given window size is in the range of 8 .. 127, lapb_setparms() fails and returns an error value of LAPB_INVALUE, even if bit LAPB_EXTENDED in parms->mode is set. If bit LAPB_EXTENDED in parms->mode is set and the window size is in the range of 8 .. 127, the first check "(parms->mode & LAPB_EXTENDED)" results true and the second check "(parms->window < 1 || parms->window > 127)" results false. Both checks in conjunction result to false, thus the third check "(parms->window < 1 || parms->window > 7)" is done by fault. This third check results true, so that we leave lapb_setparms() by 'goto out_put'. Seems that this bug doesn't cause any problems, because lapb_setparms() isn't used to change the default values of LAPB. We are using kernel lapb in our software project and also change the default parameters of lapb, so we found this bug" He also pasted a fix, that I've transformated into a patch: Signed-off-by: Diego Calleja <diegocg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-07-11[NET]: move config options out to individual protocolsSam Ravnborg
Move the protocol specific config options out to the specific protocols. With this change net/Kconfig now starts to become readable and serve as a good basis for further re-structuring. The menu structure is left almost intact, except that indention is fixed in most cases. Most visible are the INET changes where several "depends on INET" are replaced with a single ifdef INET / endif pair. Several new files were created to accomplish this change - they are small but serve the purpose that config options are now distributed out where they belongs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
