path: root/net/llc/llc_sap.c
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-15net: delete all instances of special processing for token ringPaul Gortmaker
We are going to delete the Token ring support. This removes any special processing in the core networking for token ring, (aside from net/tr.c itself), leaving the drivers and remaining tokenring support present but inert. The mass removal of the drivers and net/tr.c will be in a separate commit, so that the history of these files that we still care about won't have the giant deletion tied into their history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-05-10net: Fix FDDI and TR config checks in ipv4 arp and LLC.David S. Miller
Need to check both CONFIG_FOO and CONFIG_FOO_MODULE Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-26llc: replace the socket list with a local address based hashOctavian Purdila
For the cases where a lot of interfaces are used in conjunction with a lot of LLC sockets bound to the same SAP, the iteration of the socket list becomes prohibitively expensive. Replacing the list with a a local address based hash significantly improves the bind and listener lookup operations as well as the datagram delivery. Connected sockets delivery is also improved, but this patch does not address the case where we have lots of sockets with the same local address connected to different remote addresses. In order to keep the socket sanity checks alive and fast a socket counter was added to the SAP structure. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-26llc: use a device based hash table to speed up multicast deliveryOctavian Purdila
This patch adds a per SAP device based hash table to solve the multicast delivery scalability issue when we have large number of interfaces and a large number of sockets bound to the same SAP. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-26llc: optimize multicast deliveryOctavian Purdila
Optimize multicast delivery by doing the actual delivery without holding the lock. Based on the same approach used in UDP code. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-26llc: convert the socket list to RCU lockingOctavian Purdila
For the reclamation phase we use the SLAB_DESTROY_BY_RCU mechanism, which require some extra checks in the lookup code: a) If the current socket was released, reallocated & inserted in another list it will short circuit the iteration for the current list, thus we need to restart the lookup. b) If the current socket was released, reallocated & inserted in the same list we just need to recheck it matches the look-up criteria and if not we can skip to the next element. In this case there is no need to restart the lookup, since sockets are inserted at the start of the list and the worst that will happen is that we will iterate throught some of the list elements more then once. Note that the /proc and multicast delivery was not yet converted to RCU, it still uses spinlocks for protection. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-30llc: Fix double accounting of received packetsArnaldo Carvalho de Melo
llc_sap_rcv was being preceded by skb_set_owner_r, then calling llc_state_process that calls sock_queue_rcv_skb, that in turn calls skb_set_owner_r again making the space allowed to be used by the socket to be leaked, making the socket to get stuck. Fix it by setting skb->sk at llc_sap_rcv and leave the accounting to be done only at sock_queue_rcv_skb. Reported-by: Dmitry Petukhov <dmgenp@gmail.com> Tested-by: Dmitry Petukhov <dmgenp@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-31[LLC]: skb allocation size for responsesJoonwoo Park
Allocate the skb for llc responses with the received packet size by using the size adjustable llc_frame_alloc. Don't allocate useless extra payload. Cleanup magic numbers. So, this fixes oops. Reported by Jim Westfall: kernel: skb_over_panic: text:c0541fc7 len:1000 put:997 head:c166ac00 data:c166ac2f tail:0xc166b017 end:0xc166ac80 dev:eth0 kernel: ------------[ cut here ]------------ kernel: kernel BUG at net/core/skbuff.c:95! Signed-off-by: Joonwoo Park <joonwpark81@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[LLC]: Use skb_reset_mac_header in llc_alloc_frameArnaldo Carvalho de Melo
skb->head is equal to skb->data after alloc_skb, so reset the mac header while this is true, i.e. before skb_reserve. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] LLC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-13[LLC]: multicast receive device matchStephen Hemminger
Fix from Aji_Srinivas@emc.com, STP packets are incorrectly received on all LLC datagram sockets, whichever interface they are bound to. The llc_sap datagram receive logic sends packets with a unicast destination MAC to one socket bound to that SAP and MAC, and multicast packets to all sockets bound to that SAP. STP packets are multicast, and we do need to know on which interface they were received. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-04[LLX]: SOCK_DGRAM interface fixesStephen Hemminger
The datagram interface of LLC is broken in a couple of ways. These were discovered when trying to use it to build an out-of-kernel version of STP. First it didn't pass the source address of the received packet in recvfrom(). It needs to copy the source address of received LLC packets into the socket control block. At the same time fix a security issue because there was uninitialized data leakage. Every recvfrom call was just copying out old data. Second, LLC should not merge multiple packets in one receive call on datagram sockets. LLC should preserve packet boundaries on SOCK_DGRAM. This fix goes against the old historical comments about UNIX98 semantics but without this fix SOCK_DGRAM is broken and useless. So either ANK's interpretation was incorect or UNIX98 standard was wrong. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Acked-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[LLC]: add multicast support for datagramsStephen Hemminger
Allow mulitcast reception of datagrams (similar to UDP). All sockets bound to the same SAP receive a clone. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[LLC]: fix llc_ui_recvmsg, making it behave like tcp_recvmsgArnaldo Carvalho de Melo
In fact it is an exact copy of the parts that makes sense to LLC :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-22[LLC]: Fix the accept pathArnaldo Carvalho de Melo
Borrowing the structure of TCP/IP for this. On the receive of new connections I was bh_lock_socking the _new_ sock, not the listening one, duh, now it survives the ssh connections storm I've been using to test this specific bug. Also fixes send side skb sock accounting. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-22[LLC]: Do better struct sock accounting on skbsArnaldo Carvalho de Melo
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-22[LLC]: Make llc_frame_alloc take a net_device as an argumentArnaldo Carvalho de Melo
So as to set the newly created sk_buff ->dev member with it, that way we stop using dev_base->next, that is the wrong thing to do, as there may well be several interfaces being used with LLC. This was not such a big problem after all as most of the users of llc_alloc_frame were setting the correct dev, but this way code is reduced. This also fixes another bug in llc_station_ac_send_null_dsap_xid_c, that was not setting the skb->dev field. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
