path: root/net/llc
2018-12-01llc: do not use sk_eat_skb()Eric Dumazet
commit 604d415e2bd642b7e02c80e719e0396b9d4a77a6 upstream. syzkaller triggered a use-after-free [1], caused by a combination of skb_get() in llc_conn_state_process() and usage of sk_eat_skb() sk_eat_skb() is assuming the skb about to be freed is only used by the current thread. TCP/DCCP stacks enforce this because current thread holds the socket lock. llc_conn_state_process() wants to make sure skb does not disappear, and holds a reference on the skb it manipulates. But as soon as this skb is added to socket receive queue, another thread can consume it. This means that llc must use regular skb_unlink() and kfree_skb() so that both producer and consumer can safely work on the same skb. [1] BUG: KASAN: use-after-free in atomic_read include/asm-generic/atomic-instrumented.h:21 [inline] BUG: KASAN: use-after-free in refcount_read include/linux/refcount.h:43 [inline] BUG: KASAN: use-after-free in skb_unref include/linux/skbuff.h:967 [inline] BUG: KASAN: use-after-free in kfree_skb+0xb7/0x580 net/core/skbuff.c:655 Read of size 4 at addr ffff8801d1f6fba4 by task ksoftirqd/1/18 CPU: 1 PID: 18 Comm: ksoftirqd/1 Not tainted 4.19.0-rc8+ #295 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x1c4/0x2b6 lib/dump_stack.c:113 print_address_description.cold.8+0x9/0x1ff mm/kasan/report.c:256 kasan_report_error mm/kasan/report.c:354 [inline] kasan_report.cold.9+0x242/0x309 mm/kasan/report.c:412 check_memory_region_inline mm/kasan/kasan.c:260 [inline] check_memory_region+0x13e/0x1b0 mm/kasan/kasan.c:267 kasan_check_read+0x11/0x20 mm/kasan/kasan.c:272 atomic_read include/asm-generic/atomic-instrumented.h:21 [inline] refcount_read include/linux/refcount.h:43 [inline] skb_unref include/linux/skbuff.h:967 [inline] kfree_skb+0xb7/0x580 net/core/skbuff.c:655 llc_sap_state_process+0x9b/0x550 net/llc/llc_sap.c:224 llc_sap_rcv+0x156/0x1f0 net/llc/llc_sap.c:297 llc_sap_handler+0x65e/0xf80 net/llc/llc_sap.c:438 llc_rcv+0x79e/0xe20 net/llc/llc_input.c:208 __netif_receive_skb_one_core+0x14d/0x200 net/core/dev.c:4913 __netif_receive_skb+0x2c/0x1e0 net/core/dev.c:5023 process_backlog+0x218/0x6f0 net/core/dev.c:5829 napi_poll net/core/dev.c:6249 [inline] net_rx_action+0x7c5/0x1950 net/core/dev.c:6315 __do_softirq+0x30c/0xb03 kernel/softirq.c:292 run_ksoftirqd+0x94/0x100 kernel/softirq.c:653 smpboot_thread_fn+0x68b/0xa00 kernel/smpboot.c:164 kthread+0x35a/0x420 kernel/kthread.c:246 ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:413 Allocated by task 18: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] kasan_kmalloc+0xc7/0xe0 mm/kasan/kasan.c:553 kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:490 kmem_cache_alloc_node+0x144/0x730 mm/slab.c:3644 __alloc_skb+0x119/0x770 net/core/skbuff.c:193 alloc_skb include/linux/skbuff.h:995 [inline] llc_alloc_frame+0xbc/0x370 net/llc/llc_sap.c:54 llc_station_ac_send_xid_r net/llc/llc_station.c:52 [inline] llc_station_rcv+0x1dc/0x1420 net/llc/llc_station.c:111 llc_rcv+0xc32/0xe20 net/llc/llc_input.c:220 __netif_receive_skb_one_core+0x14d/0x200 net/core/dev.c:4913 __netif_receive_skb+0x2c/0x1e0 net/core/dev.c:5023 process_backlog+0x218/0x6f0 net/core/dev.c:5829 napi_poll net/core/dev.c:6249 [inline] net_rx_action+0x7c5/0x1950 net/core/dev.c:6315 __do_softirq+0x30c/0xb03 kernel/softirq.c:292 Freed by task 16383: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] __kasan_slab_free+0x102/0x150 mm/kasan/kasan.c:521 kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528 __cache_free mm/slab.c:3498 [inline] kmem_cache_free+0x83/0x290 mm/slab.c:3756 kfree_skbmem+0x154/0x230 net/core/skbuff.c:582 __kfree_skb+0x1d/0x20 net/core/skbuff.c:642 sk_eat_skb include/net/sock.h:2366 [inline] llc_ui_recvmsg+0xec2/0x1610 net/llc/af_llc.c:882 sock_recvmsg_nosec net/socket.c:794 [inline] sock_recvmsg+0xd0/0x110 net/socket.c:801 ___sys_recvmsg+0x2b6/0x680 net/socket.c:2278 __sys_recvmmsg+0x303/0xb90 net/socket.c:2390 do_sys_recvmmsg+0x181/0x1a0 net/socket.c:2466 __do_sys_recvmmsg net/socket.c:2484 [inline] __se_sys_recvmmsg net/socket.c:2480 [inline] __x64_sys_recvmmsg+0xbe/0x150 net/socket.c:2480 do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe The buggy address belongs to the object at ffff8801d1f6fac0 which belongs to the cache skbuff_head_cache of size 232 The buggy address is located 228 bytes inside of 232-byte region [ffff8801d1f6fac0, ffff8801d1f6fba8) The buggy address belongs to the page: page:ffffea000747dbc0 count:1 mapcount:0 mapping:ffff8801d9be7680 index:0xffff8801d1f6fe80 flags: 0x2fffc0000000100(slab) raw: 02fffc0000000100 ffffea0007346e88 ffffea000705b108 ffff8801d9be7680 raw: ffff8801d1f6fe80 ffff8801d1f6f0c0 000000010000000b 0000000000000000 page dumped because: kasan: bad access detected Memory state around the buggy address: ffff8801d1f6fa80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb ffff8801d1f6fb00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb >ffff8801d1f6fb80: fb fb fb fb fb fc fc fc fc fc fc fc fc fc fc fc ^ ffff8801d1f6fc00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ffff8801d1f6fc80: fb fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-04llc: set SOCK_RCU_FREE in llc_sap_add_socket()Cong Wang
[ Upstream commit 5a8e7aea953bdb6d4da13aff6f1e7f9c62023499 ] WHen an llc sock is added into the sk_laddr_hash of an llc_sap, it is not marked with SOCK_RCU_FREE. This causes that the sock could be freed while it is still being read by __llc_lookup_established() with RCU read lock. sock is refcounted, but with RCU read lock, nothing prevents the readers getting a zero refcnt. Fix it by setting SOCK_RCU_FREE in llc_sap_add_socket(). Reported-by: syzbot+11e05f04c15e03be5254@syzkaller.appspotmail.com Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-22llc: use refcount_inc_not_zero() for llc_sap_find()Cong Wang
[ Upstream commit 0dcb82254d65f72333aa50ad626d1e9665ad093b ] llc_sap_put() decreases the refcnt before deleting sap from the global list. Therefore, there is a chance llc_sap_find() could find a sap with zero refcnt in this global list. Close this race condition by checking if refcnt is zero or not in llc_sap_find(), if it is zero then it is being removed so we can just treat it as gone. Reported-by: <syzbot+278893f3f7803871f7ce@syzkaller.appspotmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30llc: properly handle dev_queue_xmit() return valueCong Wang
[ Upstream commit b85ab56c3f81c5a24b5a5213374f549df06430da ] llc_conn_send_pdu() pushes the skb into write queue and calls llc_conn_send_pdus() to flush them out. However, the status of dev_queue_xmit() is not returned to caller, in this case, llc_conn_state_process(). llc_conn_state_process() needs hold the skb no matter success or failure, because it still uses it after that, therefore we should hold skb before dev_queue_xmit() when that skb is the one being processed by llc_conn_state_process(). For other callers, they can just pass NULL and ignore the return value as they are. Reported-by: Noam Rathaus <noamr@beyondsecurity.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19llc: better deal with too small mtuEric Dumazet
[ Upstream commit 2c5d5b13c6eb79f5677e206b8aad59b3a2097f60 ] syzbot loves to set very small mtu on devices, since it brings joy. We must make llc_ui_sendmsg() fool proof. usercopy: Kernel memory overwrite attempt detected to wrapped address (offset 0, size 18446612139802320068)! kernel BUG at mm/usercopy.c:100! invalid opcode: 0000 [#1] SMP KASAN Dumping ftrace buffer: (ftrace buffer empty) Modules linked in: CPU: 0 PID: 17464 Comm: syz-executor1 Not tainted 4.17.0-rc3+ #36 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 RIP: 0010:usercopy_abort+0xbb/0xbd mm/usercopy.c:88 RSP: 0018:ffff8801868bf800 EFLAGS: 00010282 RAX: 000000000000006c RBX: ffffffff87d2fb00 RCX: 0000000000000000 RDX: 000000000000006c RSI: ffffffff81610731 RDI: ffffed0030d17ef6 RBP: ffff8801868bf858 R08: ffff88018daa4200 R09: ffffed003b5c4fb0 R10: ffffed003b5c4fb0 R11: ffff8801dae27d87 R12: ffffffff87d2f8e0 R13: ffffffff87d2f7a0 R14: ffffffff87d2f7a0 R15: ffffffff87d2f7a0 FS: 00007f56a14ac700(0000) GS:ffff8801dae00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000001b2bc21000 CR3: 00000001abeb1000 CR4: 00000000001426f0 DR0: 0000000020000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000030602 Call Trace: check_bogus_address mm/usercopy.c:153 [inline] __check_object_size+0x5d9/0x5d9 mm/usercopy.c:256 check_object_size include/linux/thread_info.h:108 [inline] check_copy_size include/linux/thread_info.h:139 [inline] copy_from_iter_full include/linux/uio.h:121 [inline] memcpy_from_msg include/linux/skbuff.h:3305 [inline] llc_ui_sendmsg+0x4b1/0x1530 net/llc/af_llc.c:941 sock_sendmsg_nosec net/socket.c:629 [inline] sock_sendmsg+0xd5/0x120 net/socket.c:639 __sys_sendto+0x3d7/0x670 net/socket.c:1789 __do_sys_sendto net/socket.c:1801 [inline] __se_sys_sendto net/socket.c:1797 [inline] __x64_sys_sendto+0xe1/0x1a0 net/socket.c:1797 do_syscall_64+0x1b1/0x800 arch/x86/entry/common.c:287 entry_SYSCALL_64_after_hwframe+0x49/0xbe RIP: 0033:0x455979 RSP: 002b:00007f56a14abc68 EFLAGS: 00000246 ORIG_RAX: 000000000000002c RAX: ffffffffffffffda RBX: 00007f56a14ac6d4 RCX: 0000000000455979 RDX: 0000000000000000 RSI: 0000000020000000 RDI: 0000000000000018 RBP: 000000000072bea0 R08: 00000000200012c0 R09: 0000000000000010 R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff R13: 0000000000000548 R14: 00000000006fbf60 R15: 0000000000000000 Code: 55 c0 e8 c0 55 bb ff ff 75 c8 48 8b 55 c0 4d 89 f9 ff 75 d0 4d 89 e8 48 89 d9 4c 89 e6 41 56 48 c7 c7 80 fa d2 87 e8 a0 0b a3 ff <0f> 0b e8 95 55 bb ff e8 c0 a8 f7 ff 8b 95 14 ff ff ff 4d 89 e8 RIP: usercopy_abort+0xbb/0xbd mm/usercopy.c:88 RSP: ffff8801868bf800 Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-29llc: fix NULL pointer deref for SOCK_ZAPPEDCong Wang
[ Upstream commit 3a04ce7130a7e5dad4e78d45d50313747f8c830f ] For SOCK_ZAPPED socket, we don't need to care about llc->sap, so we should just skip these refcount functions in this case. Fixes: f7e43672683b ("llc: hold llc_sap before release_sock()") Reported-by: kernel test robot <lkp@intel.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-29llc: hold llc_sap before release_sock()Cong Wang
[ Upstream commit f7e43672683b097bb074a8fe7af9bc600a23f231 ] syzbot reported we still access llc->sap in llc_backlog_rcv() after it is freed in llc_sap_remove_socket(): Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x1b9/0x294 lib/dump_stack.c:113 print_address_description+0x6c/0x20b mm/kasan/report.c:256 kasan_report_error mm/kasan/report.c:354 [inline] kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412 __asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:430 llc_conn_ac_send_sabme_cmd_p_set_x+0x3a8/0x460 net/llc/llc_c_ac.c:785 llc_exec_conn_trans_actions net/llc/llc_conn.c:475 [inline] llc_conn_service net/llc/llc_conn.c:400 [inline] llc_conn_state_process+0x4e1/0x13a0 net/llc/llc_conn.c:75 llc_backlog_rcv+0x195/0x1e0 net/llc/llc_conn.c:891 sk_backlog_rcv include/net/sock.h:909 [inline] __release_sock+0x12f/0x3a0 net/core/sock.c:2335 release_sock+0xa4/0x2b0 net/core/sock.c:2850 llc_ui_release+0xc8/0x220 net/llc/af_llc.c:204 llc->sap is refcount'ed and llc_sap_remove_socket() is paired with llc_sap_add_socket(). This can be amended by holding its refcount before llc_sap_remove_socket() and releasing it after release_sock(). Reported-by: <syzbot+6e181fc95081c2cf9051@syzkaller.appspotmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-29llc: delete timers synchronously in llc_sk_free()Cong Wang
[ Upstream commit b905ef9ab90115d001c1658259af4b1c65088779 ] The connection timers of an llc sock could be still flying after we delete them in llc_sk_free(), and even possibly after we free the sock. We could just wait synchronously here in case of troubles. Note, I leave other call paths as they are, since they may not have to wait, at least we can change them to synchronously when needed. Also, move the code to net/llc/llc_conn.c, which is apparently a better place. Reported-by: <syzbot+f922284c18ea23a8e457@syzkaller.appspotmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-04net, llc: convert llc_sap.refcnt from atomic_t to refcount_tReshetova, Elena
refcount_t type and corresponding API should be used instead of atomic_t when the variable is used as a reference counter. This allows to avoid accidental refcounter overflows that might lead to use-after-free situations. Signed-off-by: Elena Reshetova <elena.reshetova@intel.com> Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: David Windsor <dwindsor@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-01net: convert sock.sk_refcnt from atomic_t to refcount_tReshetova, Elena
refcount_t type and corresponding API should be used instead of atomic_t when the variable is used as a reference counter. This allows to avoid accidental refcounter overflows that might lead to use-after-free situations. This patch uses refcount_inc_not_zero() instead of atomic_inc_not_zero_hint() due to absense of a _hint() version of refcount API. If the hint() version must be used, we might need to revisit API. Signed-off-by: Elena Reshetova <elena.reshetova@intel.com> Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: David Windsor <dwindsor@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-05-26net: llc: add lock_sock in llc_ui_bind to avoid a race conditionlinzhang
There is a race condition in llc_ui_bind if two or more processes/threads try to bind a same socket. If more processes/threads bind a same socket success that will lead to two problems, one is this action is not what we expected, another is will lead to kernel in unstable status or oops(in my simple test case, cause llc2.ko can't unload). The current code is test SOCK_ZAPPED bit to avoid a process to bind a same socket twice but that is can't avoid more processes/threads try to bind a same socket at the same time. So, add lock_sock in llc_ui_bind like others, such as llc_ui_connect. Signed-off-by: Lin Zhang <xiaolou4617@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-04-23Merge branch 'for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull RCU updates from Paul E. McKenney: - Documentation updates. - Miscellaneous fixes. - Parallelize SRCU callback handling (plus overlapping patches). Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-04-18mm: Rename SLAB_DESTROY_BY_RCU to SLAB_TYPESAFE_BY_RCUPaul E. McKenney
A group of Linux kernel hackers reported chasing a bug that resulted from their assumption that SLAB_DESTROY_BY_RCU provided an existence guarantee, that is, that no block from such a slab would be reallocated during an RCU read-side critical section. Of course, that is not the case. Instead, SLAB_DESTROY_BY_RCU only prevents freeing of an entire slab of blocks. However, there is a phrase for this, namely "type safety". This commit therefore renames SLAB_DESTROY_BY_RCU to SLAB_TYPESAFE_BY_RCU in order to avoid future instances of this sort of confusion. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: <linux-mm@kvack.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> [ paulmck: Add comments mentioning the old name, as requested by Eric Dumazet, in order to help people familiar with the old name find the new one. ] Acked-by: David Rientjes <rientjes@google.com>
2017-03-09net: Work around lockdep limitation in sockets that use socketsDavid Howells
Lockdep issues a circular dependency warning when AFS issues an operation through AF_RXRPC from a context in which the VFS/VM holds the mmap_sem. The theory lockdep comes up with is as follows: (1) If the pagefault handler decides it needs to read pages from AFS, it calls AFS with mmap_sem held and AFS begins an AF_RXRPC call, but creating a call requires the socket lock: mmap_sem must be taken before sk_lock-AF_RXRPC (2) afs_open_socket() opens an AF_RXRPC socket and binds it. rxrpc_bind() binds the underlying UDP socket whilst holding its socket lock. inet_bind() takes its own socket lock: sk_lock-AF_RXRPC must be taken before sk_lock-AF_INET (3) Reading from a TCP socket into a userspace buffer might cause a fault and thus cause the kernel to take the mmap_sem, but the TCP socket is locked whilst doing this: sk_lock-AF_INET must be taken before mmap_sem However, lockdep's theory is wrong in this instance because it deals only with lock classes and not individual locks. The AF_INET lock in (2) isn't really equivalent to the AF_INET lock in (3) as the former deals with a socket entirely internal to the kernel that never sees userspace. This is a limitation in the design of lockdep. Fix the general case by: (1) Double up all the locking keys used in sockets so that one set are used if the socket is created by userspace and the other set is used if the socket is created by the kernel. (2) Store the kern parameter passed to sk_alloc() in a variable in the sock struct (sk_kern_sock). This informs sock_lock_init(), sock_init_data() and sk_clone_lock() as to the lock keys to be used. Note that the child created by sk_clone_lock() inherits the parent's kern setting. (3) Add a 'kern' parameter to ->accept() that is analogous to the one passed in to ->create() that distinguishes whether kernel_accept() or sys_accept4() was the caller and can be passed to sk_alloc(). Note that a lot of accept functions merely dequeue an already allocated socket. I haven't touched these as the new socket already exists before we get the parameter. Note also that there are a couple of places where I've made the accepted socket unconditionally kernel-based: irda_accept() rds_rcp_accept_one() tcp_accept_from_sock() because they follow a sock_create_kern() and accept off of that. Whilst creating this, I noticed that lustre and ocfs don't create sockets through sock_create_kern() and thus they aren't marked as for-kernel, though they appear to be internal. I wonder if these should do that so that they use the new set of lock keys. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-02sched/headers: Prepare to move signal wakeup & sigpending methods from ↵Ingo Molnar
<linux/sched.h> into <linux/sched/signal.h> Fix up affected files that include this signal functionality via sched.h. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-12net/llc: avoid BUG_ON() in skb_orphan()Eric Dumazet
It seems nobody used LLC since linux-3.12. Fortunately fuzzers like syzkaller still know how to run this code, otherwise it would be no fun. Setting skb->sk without skb->destructor leads to all kinds of bugs, we now prefer to be very strict about it. Ideally here we would use skb_set_owner() but this helper does not exist yet, only CAN seems to have a private helper for that. Fixes: 376c7311bdb6 ("net: add a temporary sanity check in skb_orphan()") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-14net: fix sleeping for sk_wait_event()WANG Cong
Similar to commit 14135f30e33c ("inet: fix sleeping inside inet_wait_for_connect()"), sk_wait_event() needs to fix too, because release_sock() is blocking, it changes the process state back to running after sleep, which breaks the previous prepare_to_wait(). Switch to the new wait API. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-17llc: switch type to bool as the timeout is only tested versus 0Alan Cox
(As asked by Dave in Februrary) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
In netdevice.h we removed the structure in net-next that is being changes in 'net'. In macsec.c and rtnetlink.c we have overlaps between fixes in 'net' and the u64 attribute changes in 'net-next'. The mlx5 conflicts have to do with vxlan support dependencies. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-04net: fix infoleak in llcKangjie Lu
The stack object “info” has a total size of 12 bytes. Its last byte is padding which is not initialized and leaked via “put_cmsg”. Signed-off-by: Kangjie Lu <kjlu@gatech.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-13sock: tigthen lockdep checks for sock_owned_by_userHannes Frederic Sowa
sock_owned_by_user should not be used without socket lock held. It seems to be a common practice to check .owned before lock reclassification, so provide a little help to abstract this check away. Cc: linux-cifs@vger.kernel.org Cc: linux-bluetooth@vger.kernel.org Cc: linux-nfs@vger.kernel.org Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-17af_llc: fix types on llc_ui_wait_for_connOne Thousand Gnomes
The timeout is a long, we return it truncated if it is huge. Basically harmless as the only caller does a boolean check, but tidy it up anyway. (64bit build tested this time. Thank you 0day) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-27tcp: fix recv with flags MSG_WAITALL | MSG_PEEKSabrina Dubroca
Currently, tcp_recvmsg enters a busy loop in sk_wait_data if called with flags = MSG_WAITALL | MSG_PEEK. sk_wait_data waits for sk_receive_queue not empty, but in this case, the receive queue is not empty, but does not contain any skb that we can use. Add a "last skb seen on receive queue" argument to sk_wait_data, so that it sleeps until the receive queue has new skbs. Link: https://bugzilla.kernel.org/show_bug.cgi?id=99461 Link: https://sourceware.org/bugzilla/show_bug.cgi?id=18493 Link: https://bugzilla.redhat.com/show_bug.cgi?id=1205258 Reported-by: Enrico Scholz <rh-bugzilla@ensc.de> Reported-by: Dan Searle <dan@censornet.com> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-11net: Pass kern from net_proto_family.create to sk_allocEric W. Biederman
In preparation for changing how struct net is refcounted on kernel sockets pass the knowledge that we are creating a kernel socket from sock_create_kern through to sk_alloc. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: Remove iocb argument from sendmsg and recvmsgYing Xue
After TIPC doesn't depend on iocb argument in its internal implementations of sendmsg() and recvmsg() hooks defined in proto structure, no any user is using iocb argument in them at all now. Then we can drop the redundant iocb argument completely from kinds of implementations of both sendmsg() and recvmsg() in the entire networking stack. Cc: Christoph Hellwig <hch@lst.de> Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-25net: llc: use correct size for sysctl timeout entriesSasha Levin
The timeout entries are sizeof(int) rather than sizeof(long), which means that when they were getting read we'd also leak kernel memory to userspace along with the timeout values. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10llc: Make llc_sap_action_t function pointer arrays constJoe Perches
It's better when function pointer arrays aren't modifiable. Net change: $ size net/llc/built-in.o.* text data bss dec hex filename 61193 12758 1344 75295 1261f net/llc/built-in.o.new 47113 27030 1344 75487 126df net/llc/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10llc: Make llc_conn_ev_qfyr_t function pointer arrays constJoe Perches
It's better when function pointer arrays aren't modifiable. Net change from original: $ size net/llc/built-in.o.* text data bss dec hex filename 61065 12886 1344 75295 1261f net/llc/built-in.o.new 47113 27030 1344 75487 126df net/llc/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10llc: Make function pointer arrays constJoe Perches
It's better when function pointer arrays aren't modifiable. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-24new helper: memcpy_from_msg()Al Viro
2014-11-05net: Add and use skb_copy_datagram_msg() helper.David S. Miller
This encapsulates all of the skb_copy_datagram_iovec() callers with call argument signature "skb, offset, msghdr->msg_iov, length". When we move to iov_iters in the networking, the iov_iter object will sit in the msghdr. Having a helper like this means there will be less places to touch during that transformation. Based upon descriptions and patch from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-24net: llc: include linux/errno.h instead of asm/errno.hFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-28net_dma: simple removalDan Williams
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used and there is no plan to fix it. This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards. Reverting the remainder of the net_dma induced changes is deferred to subsequent patches. Marked for stable due to Roman's report of a memory leak in dma_pin_iovec_pages(): https://lkml.org/lkml/2014/9/3/177 Cc: Dave Jiang <dave.jiang@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: David Whipple <whipple@securedatainnovations.ch> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Cc: <stable@vger.kernel.org> Reported-by: Roman Gushchin <klamm@yandex-team.ru> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2014-01-28llc: remove noisy WARN from llc_mac_hdr_initDave Jones
Sending malformed llc packets triggers this spew, which seems excessive. WARNING: CPU: 1 PID: 6917 at net/llc/llc_output.c:46 llc_mac_hdr_init+0x85/0x90 [llc]() device type not supported: 0 CPU: 1 PID: 6917 Comm: trinity-c1 Not tainted 3.13.0+ #95 0000000000000009 00000000007e257d ffff88009232fbe8 ffffffffac737325 ffff88009232fc30 ffff88009232fc20 ffffffffac06d28d ffff88020e07f180 ffff88009232fec0 00000000000000c8 0000000000000000 ffff88009232fe70 Call Trace: [<ffffffffac737325>] dump_stack+0x4e/0x7a [<ffffffffac06d28d>] warn_slowpath_common+0x7d/0xa0 [<ffffffffac06d30c>] warn_slowpath_fmt+0x5c/0x80 [<ffffffffc01736d5>] llc_mac_hdr_init+0x85/0x90 [llc] [<ffffffffc0173759>] llc_build_and_send_ui_pkt+0x79/0x90 [llc] [<ffffffffc057cdba>] llc_ui_sendmsg+0x23a/0x400 [llc2] [<ffffffffac605d8c>] sock_sendmsg+0x9c/0xe0 [<ffffffffac185a37>] ? might_fault+0x47/0x50 [<ffffffffac606321>] SYSC_sendto+0x121/0x1c0 [<ffffffffac011847>] ? syscall_trace_enter+0x207/0x270 [<ffffffffac6071ce>] SyS_sendto+0xe/0x10 [<ffffffffac74aaa4>] tracesys+0xdd/0xe2 Until 2009, this was a printk, when it was changed in bf9ae5386bc: "llc: use dev_hard_header". Let userland figure out what -EINVAL means by itself. Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-03llc: make lock staticstephen hemminger
The llc_sap_list_lock does not need to be global, only acquired in core. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-02net: llc: fix use after free in llc_ui_recvmsgDaniel Borkmann
While commit 30a584d944fb fixes datagram interface in LLC, a use after free bug has been introduced for SOCK_STREAM sockets that do not make use of MSG_PEEK. The flow is as follow ... if (!(flags & MSG_PEEK)) { ... sk_eat_skb(sk, skb, false); ... } ... if (used + offset < skb->len) continue; ... where sk_eat_skb() calls __kfree_skb(). Therefore, cache original length and work on skb_len to check partial reads. Fixes: 30a584d944fb ("[LLX]: SOCK_DGRAM interface fixes") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-27llc: "foo* bar" should be "foo *bar"Weilong Chen
Signed-off-by: Weilong Chen <chenweilong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-03llc: Use normal etherdevice.h testsJoe Perches
Convert the llc_<foo> static inlines to the equivalents from etherdevice.h and remove the llc_<foo> static inline functions. llc_mac_null -> is_zero_ether_addr llc_mac_multicast -> is_multicast_ether_addr llc_mac_match -> ether_addr_equal Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-15net: proc_fs: trivial: print UIDs as unsigned intFrancesco Fusco
UIDs are printed in the proc_fs as signed int, whereas they are unsigned int. Signed-off-by: Francesco Fusco <ffusco@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07llc: Fix missing msg_namelen update in llc_ui_recvmsg()Mathias Krause
For stream sockets the code misses to update the msg_namelen member to 0 and therefore makes net/socket.c leak the local, uninitialized sockaddr_storage variable to userland -- 128 bytes of kernel stack memory. The msg_namelen update is also missing for datagram sockets in case the socket is shutting down during receive. Fix both issues by setting msg_namelen to 0 early. It will be updated later if we're going to fill the msg_name member. Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-18net: Allow userns root to control llc, netfilter, netlink, packet, and xfrmEric W. Biederman
Allow an unpriviled user who has created a user namespace, and then created a network namespace to effectively use the new network namespace, by reducing capable(CAP_NET_ADMIN) and capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns, CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls. Allow creation of af_key sockets. Allow creation of llc sockets. Allow creation of af_packet sockets. Allow sending xfrm netlink control messages. Allow binding to netlink multicast groups. Allow sending to netlink multicast groups. Allow adding and dropping netlink multicast groups. Allow sending to all netlink multicast groups and port ids. Allow reading the netfilter SO_IP_SET socket option. Allow sending netfilter netlink messages. Allow setting and getting ip_vs netfilter socket options. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-17llc: Remove stray reference to sysctl_llc_station_ack_timeout.David S. Miller
2012-09-17llc2: Collapse remainder of state machine into simple if-else if-statementBen Hutchings
Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-17llc2: Remove explicit indexing of state action arraysBen Hutchings
These arrays are accessed by iteration in llc_exec_station_trans_actions(). There must not be any zero-filled gaps in them, so the explicit indices are pointless. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-17llc2: Remove the station send queueBen Hutchings
We only ever put one skb on the send queue, and then immediately send it. Remove the queue and call dev_queue_xmit() directly. This leaves struct llc_station empty, so remove that as well. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
