[ Upstream commit 36453c852816f19947ca482a595dffdd2efa4965 ]
If llc_conn_state_process() sees that llc_conn_service() put the skb on
a list, it will drop one fewer references to it. This is wrong because
the current behavior is that llc_conn_service() never consumes a
reference to the skb.
The code also makes the number of skb references being dropped
conditional on which of ind_prim and cfm_prim are nonzero, yet neither
of these affects how many references are *acquired*. So there is extra
code that tries to fix this up by sometimes taking another reference.
Remove the unnecessary/broken refcounting logic and instead just add an
skb_get() before the only two places where an extra reference is
actually consumed.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
[ Upstream commit fc8d5db10cbe1338a52ebc74e7feab9276721774 ]
All callers of llc_conn_state_process() except llc_build_and_send_pkt()
(via llc_ui_sendmsg() -> llc_ui_send_data()) assume that it always
consumes a reference to the skb. Fix this caller to do the same.
[ Upstream commit af1c0e4e00f3cc76cb136ebf2e2c04e8b6446285 ]
When a frame with NULL DSAP is received, llc_station_rcv is called.
In turn, llc_stat_ev_rx_null_dsap_xid_c is called to check if it is a NULL
XID frame. The return statement of llc_stat_ev_rx_null_dsap_xid_c returns 1
when the incoming frame is not a NULL XID frame and 0 otherwise. Hence, a
NULL XID response is returned unexpectedly, e.g. when the incoming frame is
a NULL TEST command.
To fix the error, simply remove the conditional operator.
A similar error in llc_stat_ev_rx_null_dsap_test_c is also fixed.
Signed-off-by: Chan Shu Tak, Alex <alexchan@task.com.hk>
[ Upstream commit 9708d2b5b7c648e8e0a40d11e8cea12f6277f33c ]
llc_sap_close() is called by llc_sap_put() which
could be called in BH context in llc_rcv(). We can't
block in BH.
There is no reason to block it here, kfree_rcu() should
be sufficient.
commit b74555de21acd791f12c4a1aeaf653dd7ac21133 upstream.
syzbot reported:
BUG: memory leak
unreferenced object 0xffff88811eb3de00 (size 224):
comm "syz-executor559", pid 7315, jiffies 4294943019 (age 10.300s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00 a0 38 24 81 88 ff ff 00 c0 f2 15 81 88 ff ff ..8$............
backtrace:
[<000000008d1c66a1>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline]
[<000000008d1c66a1>] slab_post_alloc_hook mm/slab.h:439 [inline]
[<000000008d1c66a1>] slab_alloc_node mm/slab.c:3269 [inline]
[<000000008d1c66a1>] kmem_cache_alloc_node+0x153/0x2a0 mm/slab.c:3579
[<00000000447d9496>] __alloc_skb+0x6e/0x210 net/core/skbuff.c:198
[<000000000cdbf82f>] alloc_skb include/linux/skbuff.h:1058 [inline]
[<000000000cdbf82f>] llc_alloc_frame+0x66/0x110 net/llc/llc_sap.c:54
[<000000002418b52e>] llc_conn_ac_send_sabme_cmd_p_set_x+0x2f/0x140 net/llc/llc_c_ac.c:777
[<000000001372ae17>] llc_exec_conn_trans_actions net/llc/llc_conn.c:475 [inline]
[<000000001372ae17>] llc_conn_service net/llc/llc_conn.c:400 [inline]
[<000000001372ae17>] llc_conn_state_process+0x1ac/0x640 net/llc/llc_conn.c:75
[<00000000f27e53c1>] llc_establish_connection+0x110/0x170 net/llc/llc_if.c:109
[<00000000291b2ca0>] llc_ui_connect+0x10e/0x370 net/llc/af_llc.c:477
[<000000000f9c740b>] __sys_connect+0x11d/0x170 net/socket.c:1840
The bug is that most callers of llc_conn_send_pdu() assume it consumes a
reference to the skb, when actually due to commit b85ab56c3f81 ("llc:
properly handle dev_queue_xmit() return value") it doesn't.
Revert most of that commit, and instead make the few places that need
llc_conn_send_pdu() to *not* consume a reference call skb_get() before.
Fixes: b85ab56c3f81 ("llc: properly handle dev_queue_xmit() return value")
Reported-by: syzbot+6b825a6494a04cc0e3f7@syzkaller.appspotmail.com
commit c6ee11c39fcc1fb55130748990a8f199e76263b4 upstream.
syzbot reported:
BUG: memory leak
unreferenced object 0xffff888116270800 (size 224):
comm "syz-executor641", pid 7047, jiffies 4294947360 (age 13.860s)
00 20 e1 2a 81 88 ff ff 00 40 3d 2a 81 88 ff ff . .*.....@=*....
backtrace:
[<000000004d41b4cc>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline]
[<000000004d41b4cc>] slab_post_alloc_hook mm/slab.h:439 [inline]
[<000000004d41b4cc>] slab_alloc_node mm/slab.c:3269 [inline]
[<000000004d41b4cc>] kmem_cache_alloc_node+0x153/0x2a0 mm/slab.c:3579
[<00000000506a5965>] __alloc_skb+0x6e/0x210 net/core/skbuff.c:198
[<000000001ba5a161>] alloc_skb include/linux/skbuff.h:1058 [inline]
[<000000001ba5a161>] alloc_skb_with_frags+0x5f/0x250 net/core/skbuff.c:5327
[<0000000047d9c78b>] sock_alloc_send_pskb+0x269/0x2a0 net/core/sock.c:2225
[<000000003828fe54>] sock_alloc_send_skb+0x32/0x40 net/core/sock.c:2242
[<00000000e34d94f9>] llc_ui_sendmsg+0x10a/0x540 net/llc/af_llc.c:933
[<00000000de2de3fb>] sock_sendmsg_nosec net/socket.c:652 [inline]
[<00000000de2de3fb>] sock_sendmsg+0x54/0x70 net/socket.c:671
[<000000008fe16e7a>] __sys_sendto+0x148/0x1f0 net/socket.c:1964
The bug is that llc_sap_state_process() always takes an extra reference
to the skb, but sometimes neither llc_sap_next_state() nor
llc_sap_state_process() itself drops this reference.
Fix it by changing llc_sap_next_state() to never consume a reference to
the skb, rather than sometimes do so and sometimes not. Then remove the
extra skb_get() and kfree_skb() from llc_sap_state_process().
Reported-by: syzbot+6bf095f9becf5efef645@syzkaller.appspotmail.com
Reported-by: syzbot+31c16aa4202dace3812e@syzkaller.appspotmail.com
[ Upstream commit 8fb44d60d4142cd2a440620cd291d346e23c131e ]
If llc_mac_hdr_init() returns an error, we must drop the skb
since no llc_build_and_send_ui_pkt() caller will take care of this.
BUG: memory leak
unreferenced object 0xffff8881202b6800 (size 2048):
comm "syz-executor907", pid 7074, jiffies 4294943781 (age 8.590s)
1a 00 07 40 00 00 00 00 00 00 00 00 00 00 00 00 ...@............
backtrace:
[<00000000e25b5abe>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline]
[<00000000e25b5abe>] slab_post_alloc_hook mm/slab.h:439 [inline]
[<00000000e25b5abe>] slab_alloc mm/slab.c:3326 [inline]
[<00000000e25b5abe>] __do_kmalloc mm/slab.c:3658 [inline]
[<00000000e25b5abe>] __kmalloc+0x161/0x2c0 mm/slab.c:3669
[<00000000a1ae188a>] kmalloc include/linux/slab.h:552 [inline]
[<00000000a1ae188a>] sk_prot_alloc+0xd6/0x170 net/core/sock.c:1608
[<00000000ded25bbe>] sk_alloc+0x35/0x2f0 net/core/sock.c:1662
[<000000002ecae075>] llc_sk_alloc+0x35/0x170 net/llc/llc_conn.c:950
[<00000000551f7c47>] llc_ui_create+0x7b/0x140 net/llc/af_llc.c:173
[<0000000029027f0e>] __sock_create+0x164/0x250 net/socket.c:1430
[<000000008bdec225>] sock_create net/socket.c:1481 [inline]
[<000000008bdec225>] __sys_socket+0x69/0x110 net/socket.c:1523
[<00000000b6439228>] __do_sys_socket net/socket.c:1532 [inline]
[<00000000b6439228>] __se_sys_socket net/socket.c:1530 [inline]
[<00000000b6439228>] __x64_sys_socket+0x1e/0x30 net/socket.c:1530
[<00000000cec820c1>] do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:301
[<000000000c32554f>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
BUG: memory leak
unreferenced object 0xffff88811d750d00 (size 224):
comm "syz-executor907", pid 7074, jiffies 4294943781 (age 8.600s)
00 f0 0c 24 81 88 ff ff 00 68 2b 20 81 88 ff ff ...$.....h+ ....
backtrace:
[<0000000053026172>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline]
[<0000000053026172>] slab_post_alloc_hook mm/slab.h:439 [inline]
[<0000000053026172>] slab_alloc_node mm/slab.c:3269 [inline]
[<0000000053026172>] kmem_cache_alloc_node+0x153/0x2a0 mm/slab.c:3579
[<00000000fa8f3c30>] __alloc_skb+0x6e/0x210 net/core/skbuff.c:198
[<00000000d96fdafb>] alloc_skb include/linux/skbuff.h:1058 [inline]
[<00000000d96fdafb>] alloc_skb_with_frags+0x5f/0x250 net/core/skbuff.c:5327
[<000000000a34a2e7>] sock_alloc_send_pskb+0x269/0x2a0 net/core/sock.c:2225
[<00000000ee39999b>] sock_alloc_send_skb+0x32/0x40 net/core/sock.c:2242
[<00000000e034d810>] llc_ui_sendmsg+0x10a/0x540 net/llc/af_llc.c:933
[<00000000c0bc8445>] sock_sendmsg_nosec net/socket.c:652 [inline]
[<00000000c0bc8445>] sock_sendmsg+0x54/0x70 net/socket.c:671
[<000000003b687167>] __sys_sendto+0x148/0x1f0 net/socket.c:1964
[<00000000922d78d9>] __do_sys_sendto net/socket.c:1976 [inline]
[<00000000922d78d9>] __se_sys_sendto net/socket.c:1972 [inline]
[<00000000922d78d9>] __x64_sys_sendto+0x2a/0x30 net/socket.c:1972
Reported-by: syzbot <syzkaller@googlegroups.com>
commit 604d415e2bd642b7e02c80e719e0396b9d4a77a6 upstream.
syzkaller triggered a use-after-free [1], caused by a combination of
skb_get() in llc_conn_state_process() and usage of sk_eat_skb()
sk_eat_skb() is assuming the skb about to be freed is only used by
the current thread. TCP/DCCP stacks enforce this because current
thread holds the socket lock.
llc_conn_state_process() wants to make sure skb does not disappear,
and holds a reference on the skb it manipulates. But as soon as this
skb is added to socket receive queue, another thread can consume it.
This means that llc must use regular skb_unlink() and kfree_skb()
so that both producer and consumer can safely work on the same skb.
[1]
BUG: KASAN: use-after-free in atomic_read include/asm-generic/atomic-instrumented.h:21 [inline]
BUG: KASAN: use-after-free in refcount_read include/linux/refcount.h:43 [inline]
BUG: KASAN: use-after-free in skb_unref include/linux/skbuff.h:967 [inline]
BUG: KASAN: use-after-free in kfree_skb+0xb7/0x580 net/core/skbuff.c:655
Read of size 4 at addr ffff8801d1f6fba4 by task ksoftirqd/1/18
CPU: 1 PID: 18 Comm: ksoftirqd/1 Not tainted 4.19.0-rc8+ #295
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1c4/0x2b6 lib/dump_stack.c:113
print_address_description.cold.8+0x9/0x1ff mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.9+0x242/0x309 mm/kasan/report.c:412
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x13e/0x1b0 mm/kasan/kasan.c:267
kasan_check_read+0x11/0x20 mm/kasan/kasan.c:272
llc_sap_state_process+0x9b/0x550 net/llc/llc_sap.c:224
llc_sap_rcv+0x156/0x1f0 net/llc/llc_sap.c:297
llc_sap_handler+0x65e/0xf80 net/llc/llc_sap.c:438
llc_rcv+0x79e/0xe20 net/llc/llc_input.c:208
__netif_receive_skb_one_core+0x14d/0x200 net/core/dev.c:4913
__netif_receive_skb+0x2c/0x1e0 net/core/dev.c:5023
process_backlog+0x218/0x6f0 net/core/dev.c:5829
napi_poll net/core/dev.c:6249 [inline]
net_rx_action+0x7c5/0x1950 net/core/dev.c:6315
__do_softirq+0x30c/0xb03 kernel/softirq.c:292
run_ksoftirqd+0x94/0x100 kernel/softirq.c:653
smpboot_thread_fn+0x68b/0xa00 kernel/smpboot.c:164
kthread+0x35a/0x420 kernel/kthread.c:246
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:413
Allocated by task 18:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xc7/0xe0 mm/kasan/kasan.c:553
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:490
kmem_cache_alloc_node+0x144/0x730 mm/slab.c:3644
__alloc_skb+0x119/0x770 net/core/skbuff.c:193
alloc_skb include/linux/skbuff.h:995 [inline]
llc_alloc_frame+0xbc/0x370 net/llc/llc_sap.c:54
llc_station_ac_send_xid_r net/llc/llc_station.c:52 [inline]
llc_station_rcv+0x1dc/0x1420 net/llc/llc_station.c:111
llc_rcv+0xc32/0xe20 net/llc/llc_input.c:220
Freed by task 16383:
__kasan_slab_free+0x102/0x150 mm/kasan/kasan.c:521
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528
__cache_free mm/slab.c:3498 [inline]
kmem_cache_free+0x83/0x290 mm/slab.c:3756
kfree_skbmem+0x154/0x230 net/core/skbuff.c:582
__kfree_skb+0x1d/0x20 net/core/skbuff.c:642
sk_eat_skb include/net/sock.h:2366 [inline]
llc_ui_recvmsg+0xec2/0x1610 net/llc/af_llc.c:882
sock_recvmsg_nosec net/socket.c:794 [inline]
sock_recvmsg+0xd0/0x110 net/socket.c:801
___sys_recvmsg+0x2b6/0x680 net/socket.c:2278
__sys_recvmmsg+0x303/0xb90 net/socket.c:2390
do_sys_recvmmsg+0x181/0x1a0 net/socket.c:2466
__do_sys_recvmmsg net/socket.c:2484 [inline]
__se_sys_recvmmsg net/socket.c:2480 [inline]
__x64_sys_recvmmsg+0xbe/0x150 net/socket.c:2480
do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
The buggy address belongs to the object at ffff8801d1f6fac0
which belongs to the cache skbuff_head_cache of size 232
The buggy address is located 228 bytes inside of
232-byte region [ffff8801d1f6fac0, ffff8801d1f6fba8)
The buggy address belongs to the page:
page:ffffea000747dbc0 count:1 mapcount:0 mapping:ffff8801d9be7680 index:0xffff8801d1f6fe80
flags: 0x2fffc0000000100(slab)
raw: 02fffc0000000100 ffffea0007346e88 ffffea000705b108 ffff8801d9be7680
raw: ffff8801d1f6fe80 ffff8801d1f6f0c0 000000010000000b 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8801d1f6fa80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8801d1f6fb00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8801d1f6fb80: fb fb fb fb fb fc fc fc fc fc fc fc fc fc fc fc
ffff8801d1f6fc00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801d1f6fc80: fb fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc
[ Upstream commit 5a8e7aea953bdb6d4da13aff6f1e7f9c62023499 ]
WHen an llc sock is added into the sk_laddr_hash of an llc_sap,
it is not marked with SOCK_RCU_FREE.
This causes that the sock could be freed while it is still being
read by __llc_lookup_established() with RCU read lock. sock is
refcounted, but with RCU read lock, nothing prevents the readers
getting a zero refcnt.
Fix it by setting SOCK_RCU_FREE in llc_sap_add_socket().
Reported-by: syzbot+11e05f04c15e03be5254@syzkaller.appspotmail.com
[ Upstream commit 0dcb82254d65f72333aa50ad626d1e9665ad093b ]
llc_sap_put() decreases the refcnt before deleting sap
from the global list. Therefore, there is a chance
llc_sap_find() could find a sap with zero refcnt
in this global list.
Close this race condition by checking if refcnt is zero
or not in llc_sap_find(), if it is zero then it is being
removed so we can just treat it as gone.
Reported-by: <syzbot+278893f3f7803871f7ce@syzkaller.appspotmail.com>
[ Upstream commit b85ab56c3f81c5a24b5a5213374f549df06430da ]
llc_conn_send_pdu() pushes the skb into write queue and
calls llc_conn_send_pdus() to flush them out. However, the
status of dev_queue_xmit() is not returned to caller,
in this case, llc_conn_state_process().
llc_conn_state_process() needs hold the skb no matter
success or failure, because it still uses it after that,
therefore we should hold skb before dev_queue_xmit() when
that skb is the one being processed by llc_conn_state_process().
For other callers, they can just pass NULL and ignore
the return value as they are.
Reported-by: Noam Rathaus <noamr@beyondsecurity.com>
[ Upstream commit 2c5d5b13c6eb79f5677e206b8aad59b3a2097f60 ]
syzbot loves to set very small mtu on devices, since it brings joy.
We must make llc_ui_sendmsg() fool proof.
usercopy: Kernel memory overwrite attempt detected to wrapped address (offset 0, size 18446612139802320068)!
kernel BUG at mm/usercopy.c:100!
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 0 PID: 17464 Comm: syz-executor1 Not tainted 4.17.0-rc3+ #36
RIP: 0010:usercopy_abort+0xbb/0xbd mm/usercopy.c:88
RSP: 0018:ffff8801868bf800 EFLAGS: 00010282
RAX: 000000000000006c RBX: ffffffff87d2fb00 RCX: 0000000000000000
RDX: 000000000000006c RSI: ffffffff81610731 RDI: ffffed0030d17ef6
RBP: ffff8801868bf858 R08: ffff88018daa4200 R09: ffffed003b5c4fb0
R10: ffffed003b5c4fb0 R11: ffff8801dae27d87 R12: ffffffff87d2f8e0
R13: ffffffff87d2f7a0 R14: ffffffff87d2f7a0 R15: ffffffff87d2f7a0
FS: 00007f56a14ac700(0000) GS:ffff8801dae00000(0000) knlGS:0000000000000000
CR2: 0000001b2bc21000 CR3: 00000001abeb1000 CR4: 00000000001426f0
DR0: 0000000020000000 DR1: 0000000000000000 DR2: 0000000000000000
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000030602
Call Trace:
check_bogus_address mm/usercopy.c:153 [inline]
__check_object_size+0x5d9/0x5d9 mm/usercopy.c:256
check_object_size include/linux/thread_info.h:108 [inline]
check_copy_size include/linux/thread_info.h:139 [inline]
copy_from_iter_full include/linux/uio.h:121 [inline]
memcpy_from_msg include/linux/skbuff.h:3305 [inline]
llc_ui_sendmsg+0x4b1/0x1530 net/llc/af_llc.c:941
sock_sendmsg_nosec net/socket.c:629 [inline]
sock_sendmsg+0xd5/0x120 net/socket.c:639
__sys_sendto+0x3d7/0x670 net/socket.c:1789
__do_sys_sendto net/socket.c:1801 [inline]
__se_sys_sendto net/socket.c:1797 [inline]
__x64_sys_sendto+0xe1/0x1a0 net/socket.c:1797
do_syscall_64+0x1b1/0x800 arch/x86/entry/common.c:287
RIP: 0033:0x455979
RSP: 002b:00007f56a14abc68 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00007f56a14ac6d4 RCX: 0000000000455979
RDX: 0000000000000000 RSI: 0000000020000000 RDI: 0000000000000018
RBP: 000000000072bea0 R08: 00000000200012c0 R09: 0000000000000010
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff
R13: 0000000000000548 R14: 00000000006fbf60 R15: 0000000000000000
Code: 55 c0 e8 c0 55 bb ff ff 75 c8 48 8b 55 c0 4d 89 f9 ff 75 d0 4d 89 e8 48 89 d9 4c 89 e6 41 56 48 c7 c7 80 fa d2 87 e8 a0 0b a3 ff <0f> 0b e8 95 55 bb ff e8 c0 a8 f7 ff 8b 95 14 ff ff ff 4d 89 e8
RIP: usercopy_abort+0xbb/0xbd mm/usercopy.c:88 RSP: ffff8801868bf800
[ Upstream commit 3a04ce7130a7e5dad4e78d45d50313747f8c830f ]
For SOCK_ZAPPED socket, we don't need to care about llc->sap,
so we should just skip these refcount functions in this case.
Fixes: f7e43672683b ("llc: hold llc_sap before release_sock()")
Reported-by: kernel test robot <lkp@intel.com>
[ Upstream commit f7e43672683b097bb074a8fe7af9bc600a23f231 ]
syzbot reported we still access llc->sap in llc_backlog_rcv()
after it is freed in llc_sap_remove_socket():
Call Trace:
dump_stack+0x1b9/0x294 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:430
llc_conn_ac_send_sabme_cmd_p_set_x+0x3a8/0x460 net/llc/llc_c_ac.c:785
llc_conn_state_process+0x4e1/0x13a0 net/llc/llc_conn.c:75
llc_backlog_rcv+0x195/0x1e0 net/llc/llc_conn.c:891
sk_backlog_rcv include/net/sock.h:909 [inline]
__release_sock+0x12f/0x3a0 net/core/sock.c:2335
release_sock+0xa4/0x2b0 net/core/sock.c:2850
llc_ui_release+0xc8/0x220 net/llc/af_llc.c:204
llc->sap is refcount'ed and llc_sap_remove_socket() is paired
with llc_sap_add_socket(). This can be amended by holding its refcount
before llc_sap_remove_socket() and releasing it after release_sock().
Reported-by: <syzbot+6e181fc95081c2cf9051@syzkaller.appspotmail.com>
[ Upstream commit b905ef9ab90115d001c1658259af4b1c65088779 ]
The connection timers of an llc sock could be still flying
after we delete them in llc_sk_free(), and even possibly
after we free the sock. We could just wait synchronously
here in case of troubles.
Note, I leave other call paths as they are, since they may
not have to wait, at least we can change them to synchronously
when needed.
Also, move the code to net/llc/llc_conn.c, which is apparently
a better place.
Reported-by: <syzbot+f922284c18ea23a8e457@syzkaller.appspotmail.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
situations.
This patch uses refcount_inc_not_zero() instead of
atomic_inc_not_zero_hint() due to absense of a _hint()
version of refcount API. If the hint() version must
be used, we might need to revisit API.
There is a race condition in llc_ui_bind if two or more processes/threads
try to bind a same socket.
If more processes/threads bind a same socket success that will lead to
two problems, one is this action is not what we expected, another is
will lead to kernel in unstable status or oops(in my simple test case,
cause llc2.ko can't unload).
The current code is test SOCK_ZAPPED bit to avoid a process to
bind a same socket twice but that is can't avoid more processes/threads
try to bind a same socket at the same time.
So, add lock_sock in llc_ui_bind like others, such as llc_ui_connect.
Signed-off-by: Lin Zhang <xiaolou4617@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
- Documentation updates.
- Miscellaneous fixes.
- Parallelize SRCU callback handling (plus overlapping patches).
A group of Linux kernel hackers reported chasing a bug that resulted
from their assumption that SLAB_DESTROY_BY_RCU provided an existence
guarantee, that is, that no block from such a slab would be reallocated
during an RCU read-side critical section. Of course, that is not the
case. Instead, SLAB_DESTROY_BY_RCU only prevents freeing of an entire
slab of blocks.
However, there is a phrase for this, namely "type safety". This commit
therefore renames SLAB_DESTROY_BY_RCU to SLAB_TYPESAFE_BY_RCU in order
to avoid future instances of this sort of confusion.
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: <linux-mm@kvack.org>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
[ paulmck: Add comments mentioning the old name, as requested by Eric
Dumazet, in order to help people familiar with the old name find
the new one. ]
Acked-by: David Rientjes <rientjes@google.com>
Lockdep issues a circular dependency warning when AFS issues an operation
through AF_RXRPC from a context in which the VFS/VM holds the mmap_sem.
The theory lockdep comes up with is as follows:
(1) If the pagefault handler decides it needs to read pages from AFS, it
calls AFS with mmap_sem held and AFS begins an AF_RXRPC call, but
creating a call requires the socket lock:
mmap_sem must be taken before sk_lock-AF_RXRPC
(2) afs_open_socket() opens an AF_RXRPC socket and binds it. rxrpc_bind()
binds the underlying UDP socket whilst holding its socket lock.
inet_bind() takes its own socket lock:
sk_lock-AF_RXRPC must be taken before sk_lock-AF_INET
(3) Reading from a TCP socket into a userspace buffer might cause a fault
and thus cause the kernel to take the mmap_sem, but the TCP socket is
locked whilst doing this:
sk_lock-AF_INET must be taken before mmap_sem
However, lockdep's theory is wrong in this instance because it deals only
with lock classes and not individual locks. The AF_INET lock in (2) isn't
really equivalent to the AF_INET lock in (3) as the former deals with a
socket entirely internal to the kernel that never sees userspace. This is
a limitation in the design of lockdep.
Fix the general case by:
(1) Double up all the locking keys used in sockets so that one set are
used if the socket is created by userspace and the other set is used
if the socket is created by the kernel.
(2) Store the kern parameter passed to sk_alloc() in a variable in the
sock struct (sk_kern_sock). This informs sock_lock_init(),
sock_init_data() and sk_clone_lock() as to the lock keys to be used.
Note that the child created by sk_clone_lock() inherits the parent's
kern setting.
(3) Add a 'kern' parameter to ->accept() that is analogous to the one
passed in to ->create() that distinguishes whether kernel_accept() or
sys_accept4() was the caller and can be passed to sk_alloc().
Note that a lot of accept functions merely dequeue an already
allocated socket. I haven't touched these as the new socket already
exists before we get the parameter.
Note also that there are a couple of places where I've made the accepted
socket unconditionally kernel-based:
irda_accept()
rds_rcp_accept_one()
tcp_accept_from_sock()
because they follow a sock_create_kern() and accept off of that.
Whilst creating this, I noticed that lustre and ocfs don't create sockets
through sock_create_kern() and thus they aren't marked as for-kernel,
though they appear to be internal. I wonder if these should do that so
that they use the new set of lock keys.
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
It seems nobody used LLC since linux-3.12.
Fortunately fuzzers like syzkaller still know how to run this code,
otherwise it would be no fun.
Setting skb->sk without skb->destructor leads to all kinds of
bugs, we now prefer to be very strict about it.
Ideally here we would use skb_set_owner() but this helper does not exist yet,
only CAN seems to have a private helper for that.
Fixes: 376c7311bdb6 ("net: add a temporary sanity check in skb_orphan()")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Similar to commit 14135f30e33c ("inet: fix sleeping inside inet_wait_for_connect()"),
sk_wait_event() needs to fix too, because release_sock() is blocking,
it changes the process state back to running after sleep, which breaks
the previous prepare_to_wait().
Switch to the new wait API.
(As asked by Dave in Februrary)
Signed-off-by: Alan Cox <alan@linux.intel.com>
In netdevice.h we removed the structure in net-next that is being
changes in 'net'. In macsec.c and rtnetlink.c we have overlaps
between fixes in 'net' and the u64 attribute changes in 'net-next'.
The mlx5 conflicts have to do with vxlan support dependencies.
The stack object “info” has a total size of 12 bytes. Its last byte
is padding which is not initialized and leaked via “put_cmsg”.
Signed-off-by: Kangjie Lu <kjlu@gatech.edu>
sock_owned_by_user should not be used without socket lock held. It seems
to be a common practice to check .owned before lock reclassification, so
provide a little help to abstract this check away.
Cc: linux-cifs@vger.kernel.org
Cc: linux-bluetooth@vger.kernel.org
Cc: linux-nfs@vger.kernel.org
The timeout is a long, we return it truncated if it is huge. Basically
harmless as the only caller does a boolean check, but tidy it up anyway.
(64bit build tested this time. Thank you 0day)
Currently, tcp_recvmsg enters a busy loop in sk_wait_data if called
with flags = MSG_WAITALL | MSG_PEEK.
sk_wait_data waits for sk_receive_queue not empty, but in this case,
the receive queue is not empty, but does not contain any skb that we
can use.
Add a "last skb seen on receive queue" argument to sk_wait_data, so
that it sleeps until the receive queue has new skbs.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=99461
Link: https://sourceware.org/bugzilla/show_bug.cgi?id=18493
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1205258
Reported-by: Enrico Scholz <rh-bugzilla@ensc.de>
Reported-by: Dan Searle <dan@censornet.com>
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
The timeout entries are sizeof(int) rather than sizeof(long), which
means that when they were getting read we'd also leak kernel memory
to userspace along with the timeout values.
It's better when function pointer arrays aren't modifiable.
Net change:
$ size net/llc/built-in.o.*
61193 12758 1344 75295 1261f net/llc/built-in.o.new
47113 27030 1344 75487 126df net/llc/built-in.o.old
Net change from original:
61065 12886 1344 75295 1261f net/llc/built-in.o.new
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used
and there is no plan to fix it.
This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards.
Reverting the remainder of the net_dma induced changes is deferred to
subsequent patches.
Marked for stable due to Roman's report of a memory leak in
dma_pin_iovec_pages():
https://lkml.org/lkml/2014/9/3/177
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: David Whipple <whipple@securedatainnovations.ch>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: <stable@vger.kernel.org>
Reported-by: Roman Gushchin <klamm@yandex-team.ru>
Sending malformed llc packets triggers this spew, which seems excessive.
WARNING: CPU: 1 PID: 6917 at net/llc/llc_output.c:46 llc_mac_hdr_init+0x85/0x90 [llc]()
device type not supported: 0
CPU: 1 PID: 6917 Comm: trinity-c1 Not tainted 3.13.0+ #95
0000000000000009 00000000007e257d ffff88009232fbe8 ffffffffac737325
ffff88009232fc30 ffff88009232fc20 ffffffffac06d28d ffff88020e07f180
ffff88009232fec0 00000000000000c8 0000000000000000 ffff88009232fe70
Call Trace:
[<ffffffffac737325>] dump_stack+0x4e/0x7a
[<ffffffffac06d28d>] warn_slowpath_common+0x7d/0xa0
[<ffffffffac06d30c>] warn_slowpath_fmt+0x5c/0x80
[<ffffffffc01736d5>] llc_mac_hdr_init+0x85/0x90 [llc]
[<ffffffffc0173759>] llc_build_and_send_ui_pkt+0x79/0x90 [llc]
[<ffffffffc057cdba>] llc_ui_sendmsg+0x23a/0x400 [llc2]
[<ffffffffac605d8c>] sock_sendmsg+0x9c/0xe0
[<ffffffffac185a37>] ? might_fault+0x47/0x50
[<ffffffffac606321>] SYSC_sendto+0x121/0x1c0
[<ffffffffac011847>] ? syscall_trace_enter+0x207/0x270
[<ffffffffac6071ce>] SyS_sendto+0xe/0x10
[<ffffffffac74aaa4>] tracesys+0xdd/0xe2
Until 2009, this was a printk, when it was changed in
bf9ae5386bc: "llc: use dev_hard_header".
Let userland figure out what -EINVAL means by itself.
Signed-off-by: Dave Jones <davej@fedoraproject.org>
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c
net/ipv6/ip6_tunnel.c
net/ipv6/ip6_vti.c
ipv6 tunnel statistic bug fixes conflicting with consolidation into
generic sw per-cpu net stats.
qlogic conflict between queue counting bug fix and the addition
of multiple MAC address support.
The llc_sap_list_lock does not need to be global, only acquired
in core.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
While commit 30a584d944fb fixes datagram interface in LLC, a use
after free bug has been introduced for SOCK_STREAM sockets that do
not make use of MSG_PEEK.
The flow is as follow ...
if (!(flags & MSG_PEEK)) {
sk_eat_skb(sk, skb, false);
if (used + offset < skb->len)
continue;
... where sk_eat_skb() calls __kfree_skb(). Therefore, cache
original length and work on skb_len to check partial reads.
Fixes: 30a584d944fb ("[LLX]: SOCK_DGRAM interface fixes")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Signed-off-by: Weilong Chen <chenweilong@huawei.com>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Convert the llc_<foo> static inlines to the
equivalents from etherdevice.h and remove
the llc_<foo> static inline functions.
llc_mac_null -> is_zero_ether_addr
llc_mac_multicast -> is_multicast_ether_addr
llc_mac_match -> ether_addr_equal
UIDs are printed in the proc_fs as signed int, whereas
they are unsigned int.
Signed-off-by: Francesco Fusco <ffusco@redhat.com>
