path: root/net/mac80211/agg-rx.c
2014-09-03mac80211: fix offloaded BA session traffic after hw restartMichal Kazior
When starting an offloaded BA session it is unknown what starting sequence number should be used. Using last_seq worked in most cases except after hw restart. When hw restart is requested last_seq is (rightfully so) kept unmodified. This ended up with BA sessions being restarted with an aribtrary BA window values resulting in dropped frames until sequence numbers caught up. Instead of last_seq pick seqno of a first Rxed frame of a given BA session. This fixes stalled traffic after hw restart with offloaded BA sessions (currently only ath10k). Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-07-21mac80211: add support for Rx reordering offloadingMichal Kazior
Some drivers may be performing most of Tx/Rx aggregation on their own (e.g. in firmware) including AddBa/DelBa negotiations but may otherwise require Rx reordering assistance. The patch exports 2 new functions for establishing Rx aggregation sessions in assumption device driver has taken care of the necessary negotiations. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> [fix endian bug] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-07-21mac80211: fix Rx reordering with RX_FLAG_AMSDU_MOREMichal Kazior
Some drivers (e.g. ath10k) report A-MSDU subframes individually with identical seqno. The A-MPDU Rx reorder code did not account for that which made it practically unusable with drivers using RX_FLAG_AMSDU_MORE because it would end up dropping a lot of frames resulting in confusion in upper network transport layers. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-18mac80211: improve aggregation debug messagesJohannes Berg
A lot of the aggregation messages don't indicate the station so they're hard to understand if there are multiple sessions in progress. Make that easier by adding the MAC address to most messages. Also add the TID if it wasn't already there. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-19mac80211: introduce IEEE80211_NUM_TIDS and use itJohannes Berg
Introduce IEEE80211_NUM_TIDS in the generic 802.11 header file and use it in place of STA_TID_NUM and NUM_RX_DATA_QUEUES which are both really the number of TIDs. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-24mac80211: clean up debuggingJohannes Berg
There are a few things that make the logging and debugging in mac80211 less useful than it should be right now: * a lot of messages should be pr_info, not pr_debug * wholesale use of pr_debug makes it require *both* Kconfig and dynamic configuration * there are still a lot of ifdefs * the style is very inconsistent, sometimes the sdata->name is printed in front Clean up everything, introducing new macros and separating out the station MLME debugging into a new Kconfig symbol. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-06Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/iwlwifi/iwl-drv.c
2012-06-05net: mac80211: Add and use ht_vdbg debugging macroJoe Perches
Simplify the use of #ifdef CONFIG_MAC80211_HT_DEBUG/#endif by adding a logging macro to encapsulate the test. Convert the appropriate uses too. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05net: mac80211: Convert printk(KERN_DEBUG to pr_debugJoe Perches
Standardize the debugging to be able to use dynamic_debug. Coalesce formats, align arguments. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-04mac80211: add missing rcu_read_lock/unlock in agg-rx session timerFelix Fietkau
Fixes a lockdep warning: =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- net/mac80211/agg-rx.c:148 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 1 1 lock held by arecord/11226: #0: (&tid_agg_rx->session_timer){+.-...}, at: [<ffffffff81066bb0>] call_timer_fn+0x0/0x360 stack backtrace: Pid: 11226, comm: arecord Not tainted 3.1.0-kml #16 Call Trace: <IRQ> [<ffffffff81093454>] lockdep_rcu_dereference+0xa4/0xc0 [<ffffffffa02778c9>] sta_rx_agg_session_timer_expired+0xc9/0x110 [mac80211] [<ffffffffa0277800>] ? ieee80211_process_addba_resp+0x220/0x220 [mac80211] [<ffffffff81066c3a>] call_timer_fn+0x8a/0x360 [<ffffffff81066bb0>] ? init_timer_deferrable_key+0x30/0x30 [<ffffffff81477bb0>] ? _raw_spin_unlock_irq+0x30/0x70 [<ffffffff81067049>] run_timer_softirq+0x139/0x310 [<ffffffff81091d5e>] ? put_lock_stats.isra.25+0xe/0x40 [<ffffffff810922ac>] ? lock_release_holdtime.part.26+0xdc/0x160 [<ffffffffa0277800>] ? ieee80211_process_addba_resp+0x220/0x220 [mac80211] [<ffffffff8105cb78>] __do_softirq+0xc8/0x3c0 [<ffffffff8108f088>] ? tick_dev_program_event+0x48/0x110 [<ffffffff8108f16f>] ? tick_program_event+0x1f/0x30 [<ffffffff81153b15>] ? putname+0x35/0x50 [<ffffffff8147a43c>] call_softirq+0x1c/0x30 [<ffffffff81004c55>] do_softirq+0xa5/0xe0 [<ffffffff8105d1ee>] irq_exit+0xae/0xe0 [<ffffffff8147ac6b>] smp_apic_timer_interrupt+0x6b/0x98 [<ffffffff81479ab3>] apic_timer_interrupt+0x73/0x80 <EOI> [<ffffffff8146aac6>] ? free_debug_processing+0x1a1/0x1d5 [<ffffffff81153b15>] ? putname+0x35/0x50 [<ffffffff8146ab2b>] __slab_free+0x31/0x2ca [<ffffffff81477c3a>] ? _raw_spin_unlock_irqrestore+0x4a/0x90 [<ffffffff81253b8f>] ? __debug_check_no_obj_freed+0x15f/0x210 [<ffffffff81097054>] ? lock_release_nested+0x84/0xc0 [<ffffffff8113ec55>] ? kmem_cache_free+0x105/0x250 [<ffffffff81153b15>] ? putname+0x35/0x50 [<ffffffff81153b15>] ? putname+0x35/0x50 [<ffffffff8113ed8f>] kmem_cache_free+0x23f/0x250 [<ffffffff81153b15>] putname+0x35/0x50 [<ffffffff81146d8d>] do_sys_open+0x16d/0x1d0 [<ffffffff81146e10>] sys_open+0x20/0x30 [<ffffffff81478f42>] system_call_fastpath+0x16/0x1b Reported-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-09mac80211: optimize aggregation session timeout handlingFelix Fietkau
Calling mod_timer from the rx/tx hotpath is somewhat expensive, and the timeout doesn't need to be so precise. Switch to a different strategy: Schedule the timer initially, store jiffies of all last rx/tx activity which would previously modify the timer, and let the timer re-arm itself after checking the last rx/tx timestamp. Make the session timers deferrable to avoid causing extra wakeups on systems running on battery. This visibly reduces CPU load under high network load on small embedded systems. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-26mac80211: fix possible tid_rx->reorder_timer use after freeStanislaw Gruszka
Is possible that we will arm the tid_rx->reorder_timer after del_timer_sync() in ___ieee80211_stop_rx_ba_session(). We need to stop timer after RCU grace period finish, so move it to ieee80211_free_tid_rx(). Timer will not be armed again, as rcu_dereference(sta->ampdu_mlme.tid_rx[tid]) will return NULL. Debug object detected problem with the following warning: ODEBUG: free active (active state 0) object type: timer_list hint: sta_rx_agg_reorder_timer_expired+0x0/0xf0 [mac80211] Bug report (with all warning messages): https://bugzilla.redhat.com/show_bug.cgi?id=804007 Reported-by: "jan p. springer" <jsd@igroup.org> Cc: stable@vger.kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-12net: reintroduce missing rcu_assign_pointer() callsEric Dumazet
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTER) did a lot of incorrect changes, since it did a complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x, y). We miss needed barriers, even on x86, when y is not NULL. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-06mac80211: Add HT operation modes for IBSSAlexander Simon
The HT mode is set by iw (previous patchsets). The interface is set into the specified HT mode. HT mode and capabilities are announced in beacons. If we add a station that uses HT also, the fastest matching HT mode will be used for transmission. That means if we are using HT40+ and we add a station running on HT40-, we would transfer at HT20. If we join an IBSS with HT40, but the secondary channel is not available, we will fall back into HT20 as well. Allow frame aggregation to start in IBSS mode. Signed-off-by: Alexander Simon <an.alexsimon@googlemail.com> [siwu@hrz.tu-chemnitz.de: Updates] * remove implicit channel_type enum assumptions * use rate_control_rate_init() if channel type changed * remove channel flags check * activate HT IBSS feature support * slightly reword commit message * rebase on wireless-testing Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: do not pass AP VLAN vif pointers to driversFelix Fietkau
This fixes frequent WARN_ONs when using AP VLAN + aggregation, as these vifs are virtual and not registered with drivers. Use sta_info_get_bss instead of sta_info_get in aggregation callbacks, so that these callbacks can find the station entry when called with the AP vif. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: log reason and initiator when rx agg is stoppedNikolay Martynov
Add additional debug logging of initiator and reason when rx aggregation session is stopped Signed-off-by: Nikolay Martynov <mar.kolya@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: trivial: use WLAN_BACK_RECIPIENT instead of hardcoded 0Nikolay Martynov
Use WLAN_BACK_RECIPIENT instead of hardcoded 0 for clarity Signed-off-by: Nikolay Martynov <mar.kolya@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux Conflicts: drivers/net/wireless/iwlegacy/iwl-debugfs.c drivers/net/wireless/iwlegacy/iwl-rx.c drivers/net/wireless/iwlegacy/iwl-scan.c drivers/net/wireless/iwlegacy/iwl-tx.c include/net/bluetooth/bluetooth.h
2011-11-08mac80211: allow frame aggregation for meshThomas Pedersen
Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: Ashok Nagarajan <anagar6@uic.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-11Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem Conflicts: Documentation/feature-removal-schedule.txt
2011-09-30mac80211: optimise station flagsJohannes Berg
The flaglock in struct sta_info has long been something that I wanted to get rid of, this finally does the conversion to atomic bitops. The conversion itself is straight-forward in most places, a few things needed to change a bit since we can no longer use multiple bits at the same time. On x86-64, this is a fairly significant code size reduction: text data bss dec hex 427861 23648 1008 452517 6e7a5 before 425383 23648 976 450007 6ddd7 after Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-19Merge branch 'master' of ssh://infradead/~/public_git/wireless-next into ↵John W. Linville
for-davem
2011-09-13mac80211: Remove unnecessary OOM logging messagesJoe Perches
Removing unnecessary messages saves code and text. Site specific OOM messages are duplications of a generic MM out of memory message and aren't really useful, so just delete them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-20mac80211: check sta_info_get() return valueEliad Peller
ieee80211_stop_rx_ba_session() was calling sta_info_get() without rcu locking, and the return value was not checked. This resulted in the following panic: [<bf05726c>] (ieee80211_stop_rx_ba_session+0x0/0x60 [mac80211]) [<bf0abd94>] (wl1271_event_handle+0x0/0xdc8 [wl12xx]) [<bf0a7308>] (wl1271_irq+0x0/0x4a0 [wl12xx]) [<c00c40a8>] (irq_thread+0x0/0x254) [<c00a7398>] (kthread+0x0/0x8c) Signed-off-by: Eliad Peller <eliad@wizery.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27mac80211: reestablish mis-configured existing Rx BA sessionsArik Nemtsov
When forming a Rx BA session, sometimes the ADDBA response gets lost. This leads to a situation where the session is configured locally, but doesn't exist on the remote side. Subsequent ADDBA requests are declined by mac80211. Fix this by assuming the session state of the initiator is the correct one. When receiving an unexpected ADDBA request on a TID with an active Rx BA session, delete the existing one and establish a new session. Signed-off-by: Arik Nemtsov <arik@wizery.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-07mac80211: Stop BA session event from deviceShahar Levi
Some devices support BT/WLAN co-existence algorigthms. In order not to harm the system performance and user experience, the device requests not to allow any RX BA session and tear down existing RX BA sessions based on system constraints such as periodic BT activity that needs to limit WLAN activity (eg.SCO or A2DP). In such cases, the intention is to limit the duration of the RX PPDU and therefore prevent the peer device to use A-MPDU aggregation. Adding ieee80211_stop_rx_ba_session() callback that can be used by the driver to stop existing BA sessions. Signed-off-by: Shahar Levi <shahar_levi@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16mac80211: sparse RCU annotationsJohannes Berg
This adds sparse RCU annotations to most of mac80211, only the mesh code remains to be done. Due the the previous patches, the annotations are pretty simple. The only thing that this actually changes is removing the RCU usage of key->sta in debugfs since this pointer isn't actually an RCU-managed pointer (it only has a single assignment done before the key even goes live). As that is otherwise harmless, I decided to make it part of this patch. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-27Merge branch 'master' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2011-01-19mac80211: track receiver's aggregation reorder buffer sizeJohannes Berg
The aggregation code currently doesn't implement the buffer size negotiation. It will always request a max buffer size (which is fine, if a little pointless, as the mac80211 code doesn't know and might just use 0 instead), but if the peer requests a smaller size it isn't possible to honour this request. In order to fix this, look at the buffer size in the addBA response frame, keep track of it and pass it to the driver in the ampdu_action callback when called with the IEEE80211_AMPDU_TX_OPERATIONAL action. That way the driver can limit the number of subframes in aggregates appropriately. Note that this doesn't fix any drivers apart from the addition of the new argument -- they all need to be updated separately to use this variable! Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-19mac80211: add hw configuration for max ampdu buffer sizeLuciano Coelho
Some devices don't support the maximum AMDPU buffer size of 64, so we need to add an option to configure this in the hardware configuration. This value will be used in the ADDBA response instead of the value suggested in the request, if the latter is greater than the max supported. Signed-off-by: Luciano Coelho <coelho@ti.com> Tested-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-13mac80211: use maximum number of AMPDU frames as default in BA RXLuciano Coelho
When the buffer size is set to zero in the block ack parameter set field, we should use the maximum supported number of subframes. The existing code was bogus and was doing some unnecessary calculations that lead to wrong values. Thanks Johannes for helping me figure this one out. Cc: stable@kernel.org Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luciano Coelho <coelho@ti.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-29mac80211: fix RX aggregation lockingJohannes Berg
The RX aggregation locking documentation was wrong, which led Christian to also code the timer timeout handling for it somewhat wrongly. Fix the documentation, the two places that need to hold the reorder lock across accesses to the structure, and the debugfs code that should just use RCU. Also, remove acquiring the sta->lock across reorder timeouts since it isn't necessary, and change a few places to GFP_KERNEL because the code path here doesn't need atomic allocations as I noticed when reviewing all this. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06mac80211: avoid transmitting delBA to old APJohannes Berg
When roaming while we have active BA session, we can end up transmitting delBA frames to the old AP while we're already on the new AP's channel, which can cause warnings. Simply avoid sending those frames, but still tear down the internal session state, since they are not really necessary anyway as we will implicitly disassociate when sending the association to the new AP. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-16mac80211: AMPDU rx reorder timeout timerChristian Lamparter
This patch introduces a new timer, which will release queued-up MPDUs from the reorder buffer, whenever they've waited for more than HT_RX_REORDER_BUF_TIMEOUT (which is at around 100 ms). The advantage of having a dedicated timer, instead of relying on a constant stream of freshly arriving aMPDUs to release the old ones, is particularly observable when even a small fraction of MPDUs are forever lost at low network speeds. Previously under these circumstances frames would become stuck in the reorder buffer and the network stack of both HT peers throttled back, instead of revving up and gunning the pipes. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-14mac80211: update aggregation documentationJohannes Berg
Even before the recent changes, the documentation for TX aggregation was somewhat out of date. Update it and also add documentation for the RX side. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-14mac80211: change RX aggregation lockingJohannes Berg
To prepare for allowing drivers to sleep in ampdu_action, change the locking in the RX aggregation code to use a mutex, so that it would already allow drivers to sleep. But explicitly disable BHs around the callback for now since the TX part cannot yet sleep, and drivers' locking might require it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-14mac80211: fix RX aggregation timerJohannes Berg
I noticed that when there was _no_ traffic at all on a given aggregation session, it would never time out. This won't happen unless you forced creating a session, but fix it anyway. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-14mac80211: defer RX agg session teardown to workJohannes Berg
Since we want the code to be able to sleep in the future, it must not be called from the timer directly. To prepare, move it out into the aggregation work. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-14mac80211: use RCU for RX aggregationJohannes Berg
Currently we allocate some memory for each RX aggregation session and additionally keep a flag indicating whether or not it is valid. By using RCU to protect the pointer and making sure that the memory is fully set up before it becomes visible to the RX path, we can remove the need for the bool that indicates validity, as well as for locking on the RX path since it is always synchronised against itself, and we can guarantee that all other modifications are done when the structure is not visible to the RX path. The net result is that since we remove locking requirements from the RX path, we can in the future use any kind of lock for the setup and teardown code paths. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-23Merge branch 'master' into for-davemJohn W. Linville
Conflicts: drivers/net/wireless/ath/ath9k/phy.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-debugfs.c
2010-04-19mac80211: fix stopping RX BA session from timerJohannes Berg
Kalle reported that his system deadlocks since my recent work in this area. The reason quickly became apparent: we try to cancel_timer_sync() a timer from within itself. Fix that by making the function aware of the context it is called from. Reported-by: Kalle Valo <kvalo@adurom.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Kalle Valo <kvalo@adurom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c drivers/net/wireless/wl12xx/wl1271_main.c
2010-04-07mac80211: clean up/fix aggregation codeJohannes Berg
The aggregation code has a number of quirks, like inventing an unneeded WLAN_BACK_TIMER value and leaking memory under certain circumstances during station destruction. Fix these issues by using the regular aggregation session teardown code and blocking new aggregation sessions, all before the station is really destructed. As a side effect, this gets rid of the long code block to destroy aggregation safely. Additionally, rename tid_state_rx which can only have the values IDLE and OPERATIONAL to tid_active_rx to make it easier to understand that there is no bitwise stuff going on on the RX side -- the TX side remains because it needs to keep track of the driver and peer states. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-07mac80211: rename WLAN_STA_SUSPEND to WLAN_STA_BLOCK_BAJohannes Berg
I want to use it during station destruction as well so rename it to WLAN_STA_BLOCK_BA which is also the only use of it now. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-07mac80211: remove ieee80211_sta_stop_rx_ba_sessionJohannes Berg
All callers of ieee80211_sta_stop_rx_ba_session can just call __ieee80211_stop_rx_ba_session instead because they already have the station struct, so do that and remove ieee80211_sta_stop_rx_ba_session. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-21mac80211: trace interface nameJohannes Berg
It's not all that useful to have the vif/sdata pointer, we'd rather refer to the interfaces by their name. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
