path: root/net/mac80211/cfg.c
2014-03-03mac80211: refactor channel switch functionMichal Kazior
The function was quite big. This splits out beacon updating into a separate function for improved maintenance and extension. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-25cfg80211: DFS get CAC time from regulatory databaseJanusz Dziedzic
Send Channel Availability Check time as a parameter of start_radar_detection() callback. Get CAC time from regulatory database. Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-20cfg80211: Pass TDLS peer capability information in tdls_mgmtSunil Dutt Undekari
While framing the TDLS Setup Confirmation frame, the driver needs to know if the TDLS peer is VHT/HT/WMM capable and thus shall construct the VHT/HT operation / WMM parameter elements accordingly. Supplicant determines if the TDLS peer is VHT/HT/WMM capable based on the presence of the respective IEs in the received TDLS Setup Response frame. The host driver should not need to parse the received TDLS Response frame and thus, should be able to rely on the supplicant to indicate the capability of the peer through additional flags while transmitting the TDLS Setup Confirmation frame through tdls_mgmt operations. Signed-off-by: Sunil Dutt Undekari <usdutt@qti.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-20Merge remote-tracking branch 'wireless-next/master' into mac80211-nextJohannes Berg
2014-02-13Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2014-02-06mac80211: remove superfluous band variableJohannes Berg
We already have a band variable, so the new one is just shadowing it, but the existing one already holds the same value so just remove the inner one. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-06mac80211: release the channel in error path in start_apEmmanuel Grumbach
When the driver cannot start the AP or when the assignement of the beacon goes wrong, we need to unassign the vif. Cc: stable@vger.kernel.org Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-06mac80211: avoid deadlock revealed by lockdepEmmanuel Grumbach
sdata->u.ap.request_smps_work can’t be flushed synchronously under wdev_lock(wdev) since ieee80211_request_smps_ap_work itself locks the same lock. While at it, reset the driver_smps_mode when the ap is stopped to its default: OFF. This solves: ====================================================== [ INFO: possible circular locking dependency detected ] 3.12.0-ipeer+ #2 Tainted: G O ------------------------------------------------------- rmmod/2867 is trying to acquire lock: ((&sdata->u.ap.request_smps_work)){+.+...}, at: [<c105b8d0>] flush_work+0x0/0x90 but task is already holding lock: (&wdev->mtx){+.+.+.}, at: [<f9b32626>] cfg80211_stop_ap+0x26/0x230 [cfg80211] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&wdev->mtx){+.+.+.}: [<c10aefa9>] lock_acquire+0x79/0xe0 [<c1607a1a>] mutex_lock_nested+0x4a/0x360 [<fb06288b>] ieee80211_request_smps_ap_work+0x2b/0x50 [mac80211] [<c105cdd8>] process_one_work+0x198/0x450 [<c105d469>] worker_thread+0xf9/0x320 [<c10669ff>] kthread+0x9f/0xb0 [<c1613397>] ret_from_kernel_thread+0x1b/0x28 -> #0 ((&sdata->u.ap.request_smps_work)){+.+...}: [<c10ae9df>] __lock_acquire+0x183f/0x1910 [<c10aefa9>] lock_acquire+0x79/0xe0 [<c105b917>] flush_work+0x47/0x90 [<c105d867>] __cancel_work_timer+0x67/0xe0 [<c105d90f>] cancel_work_sync+0xf/0x20 [<fb0765cc>] ieee80211_stop_ap+0x8c/0x340 [mac80211] [<f9b3268c>] cfg80211_stop_ap+0x8c/0x230 [cfg80211] [<f9b0d8f9>] cfg80211_leave+0x79/0x100 [cfg80211] [<f9b0da72>] cfg80211_netdev_notifier_call+0xf2/0x4f0 [cfg80211] [<c160f2c9>] notifier_call_chain+0x59/0x130 [<c106c6de>] __raw_notifier_call_chain+0x1e/0x30 [<c106c70f>] raw_notifier_call_chain+0x1f/0x30 [<c14f8213>] call_netdevice_notifiers_info+0x33/0x70 [<c14f8263>] call_netdevice_notifiers+0x13/0x20 [<c14f82a4>] __dev_close_many+0x34/0xb0 [<c14f83fe>] dev_close_many+0x6e/0xc0 [<c14f9c77>] rollback_registered_many+0xa7/0x1f0 [<c14f9dd4>] unregister_netdevice_many+0x14/0x60 [<fb06f4d9>] ieee80211_remove_interfaces+0xe9/0x170 [mac80211] [<fb055116>] ieee80211_unregister_hw+0x56/0x110 [mac80211] [<fa3e9396>] iwl_op_mode_mvm_stop+0x26/0xe0 [iwlmvm] [<f9b9d8ca>] _iwl_op_mode_stop+0x3a/0x70 [iwlwifi] [<f9b9d96f>] iwl_opmode_deregister+0x6f/0x90 [iwlwifi] [<fa405179>] __exit_compat+0xd/0x19 [iwlmvm] [<c10b8bf9>] SyS_delete_module+0x179/0x2b0 [<c1613421>] sysenter_do_call+0x12/0x32 Fixes: 687da132234f ("mac80211: implement SMPS for AP") Cc: <stable@vger.kernel.org> [3.13] Reported-by: Ilan Peer <ilan.peer@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-06mac80211: move roc cookie assignment earlierEliad Peller
ieee80211_start_roc_work() might add a new roc to existing roc, and tell cfg80211 it has already started. However, this might happen before the roc cookie was set, resulting in REMAIN_ON_CHANNEL (started) event with null cookie. Consequently, it can make wpa_supplicant go out of sync. Fix it by setting the roc cookie earlier. Cc: stable@vger.kernel.org Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-06mac80211: move VHT related RX_FLAG to another variableEmmanuel Grumbach
ieee80211_rx_status.flags is full. Define a new vht_flag variable to be able to set more VHT related flags and make room in flags. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Acked-by: Kalle Valo <kvalo@qca.qualcomm.com> [ath10k] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-05mac80211: update opmode when adding new stationMarek Kwaczynski
Update the operating mode field is needed when an association request contains the operating mode notification element and it's not just changed later on the fly. Signed-off-by: Marek Kwaczynski <marek.kwaczynski@tieto.com> [clarify commit log, comments & fix whitespace] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: add missing CSA lockingMichal Kazior
The patch adds a missing sdata lock and adds a few lockdeps for easier maintenance. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: fix sdata->radar_required lockingMichal Kazior
radar_required setting wasn't protected by local->mtx in some places. This should prevent from scanning/radar detection/roc colliding. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: fix possible memory leak on AP CSA failureMichal Kazior
If CSA for AP interface failed and the interface was not stopped afterwards another CSA request would leak sdata->u.ap.next_beacon. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Reviewed-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: batch CSA bss info notificationMichal Kazior
Instead of having ieee80211_bss_info_change_notify() scattered all over the place just call it once when finalizing CSA. As a side effect this patch adds missing error checking for IBSS CSA beacon update. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Reviewed-by: Luciano Coelho <luciano.coelho@intel.com> [fix err vs. changed variable usage in ieee80211_csa_finalize()] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: make cfg80211 ops and privid constJohannes Berg
The wiphy privid (to identify wiphys) and the cfg80211 ops should both be const, so change them to be. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: Fix ROC duration == 0 handlingIlan Peer
In case the given ROC duration is 0, update it to a minimal value before setting the ieee80211_roc_work parameters, so it also would be valid for cases where scan is in progress or there are other ROCs queued. Signed-off-by: Ilan Peer <ilan.peer@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: mesh: remove mesh_id checkJohannes Berg
The mesh_id is an array so can't ever be NULL, it looks like mesh_id_len check was intended instead. However, since the previous patch, cfg80211 does the check, so just remove it here. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: fix the increment of mesh precedence valueChun-Yeow Yeoh
The mesh precedence value in ieee80211_channel_switch should be incremented or set to 1 only if this is the initiator of mesh channel switch. For non-initiator, the precedence value has updated using the Mesh Channel Switch Parameters element. Fix this. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: only set CSA beacon when at least one beacon must be transmittedLuciano Coelho
A beacon should never have a Channel Switch Announcement information element with a count of 0, because a count of 1 means switch just before the next beacon. So, if a count of 0 was valid in a beacon, it would have been transmitted in the next channel already, which is useless. A CSA count equal to zero is only meaningful in action frames or probe_responses. Fix the ieee80211_csa_is_complete() and ieee80211_update_csa() functions accordingly. With a CSA count of 0, we won't transmit any CSA beacons, because the switch will happen before the next TBTT. To avoid extra work and potential confusion in the drivers, complete the CSA immediately, instead of waiting for the driver to call ieee80211_csa_finish(). To keep things simpler, we also switch immediately when the CSA count is 1, while in theory we should delay the switch until just before the next TBTT. Additionally, move the ieee80211_csa_finish() function to cfg.c, where it makes more sense. Tested-by: Simon Wunderlich <sw@simonwunderlich.de> Acked-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: refactor ieee80211_mesh_process_chanswitch()Luciano Coelho
Refactor ieee80211_mesh_process_chanswitch() to use ieee80211_channel_switch() and avoid code duplication. Tested-by: Simon Wunderlich <sw@simonwunderlich.de> Acked-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-01-06mac80211: sync dtim_count to TSFThomas Pedersen
On starting a mesh or AP BSS, the interface dtim_count countdown should match that of the driver TSF. Signed-off-by: Thomas Pedersen <twpedersen@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-30cfg80211/mac80211: correct qos-map lockingJohannes Berg
Since the RTNL can't always be held, use wdev/sdata locking for the qos-map dereference in mac80211. This requires cfg80211 to consistently lock it, which it was missing in one place. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-19mac80211: Add support for QoS mappingKyeyoon Park
Implement set_qos_map() handler for mac80211 to enable QoS mapping functionality. Signed-off-by: Kyeyoon Park <kyeyoonp@qca.qualcomm.com> Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-19mac80211: fix iflist_mtx/mtx locking in radar detectionJohannes Berg
The scan code creates an iflist_mtx -> mtx locking dependency, and a few other places, notably radar detection, were creating the opposite dependency, causing lockdep to complain. As scan and radar detection are mutually exclusive, the deadlock can't really happen in practice, but it's still bad form. A similar issue exists in the monitor mode code, but this is only used by channel-context drivers right now and those have to have hardware scan, so that also can't happen. Still, fix these issues by making some of the channel context code require the mtx to be held rather than acquiring it, thus allowing the monitor/radar callers to keep the iflist_mtx->mtx lock ordering. While at it, also fix access to the local->scanning variable in the radar code, and document that radar_detect_enabled is now properly protected by the mtx. All this would now introduce an ABBA deadlock between the DFS work cancelling and local->mtx, so change the locking there a bit to not need to use cancel_delayed_work_sync() but be able to just use cancel_delayed_work(). The work is also safely stopped/removed when the interface is stopped, so no extra changes are needed. Reported-by: Kalle Valo <kvalo@qca.qualcomm.com> Tested-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-19mac80211: remove unnecessary iflist_mtx lockingJohannes Berg
The radar detection code changed a few times, and due to the changes some iflist_mtx locking stayed in that isn't actually necessary - remove it. One version of the code needed it because an AP interface's VLAN list was changed to use this, but then we moved the list handling outside of the chanctx handling and thus the locking was no longer needed. Tested-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-16mac80211: read station mgmt keys via get_key callMax Stepanov
Allow to read management keys stored in a station's gtk key array with a get_key function. Signed-off-by: Max Stepanov <Max.Stepanov@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-16mac80211: check pairwise key_idx on get_key callMax Stepanov
Verify that a pairwise key index value on ieee80211_get_key call doesn't exceed the boundaries of the pairwise key array. Signed-off-by: Max Stepanov <Max.Stepanov@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-16mac80211: refactor ieee80211_ibss_process_chanswitch()Luciano Coelho
Refactor ieee80211_ibss_process_chanswitch() to use ieee80211_channel_switch() and avoid code duplication. Tested by: Simon Wunderlich <sw@simonwunderlich.de> Acked by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-16mac80211: make ieee80211_assign_beacon() staticLuciano Coelho
This function is not used anywhere else than in cfg.c, so there's no need to export it. Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-16mac80211: free all AP/VLAN keys at onceJohannes Berg
When the AP interface is stopped, free all AP and VLAN keys at once to only require synchronize_net() once. Since that does synchronize_net(), also move two such calls into the function (using the new force_synchronize parameter) to avoid doing it twice. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-16mac80211: optimise mixed AP/VLAN station removalJohannes Berg
Teach sta_info_flush() to optionally also remove stations from all VLANs associated with an AP interface to optimise the station removal (in particular, synchronize_net().) To not have to add the vlans argument throughout, do some refactoring. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-16mac80211: don't delay station destructionJohannes Berg
If we can assume that stations are never referenced by the driver after sta_state returns (and this is true since the previous iwlmvm patch and for all other drivers) then we don't need to delay station destruction, and don't need to play tricks with rcu_barrier() etc. This should speed up some scenarios like hostapd shutdown. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-16Merge remote-tracking branch 'wireless-next/master' into mac80211-nextJohannes Berg
2013-12-06Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/brcm80211/Kconfig net/mac80211/util.c
2013-12-05cfg80211: in bitrate_mask, rename mcs to ht_mcsJanusz Dziedzic
Rename NL80211_TXRATE_MCS to NL80211_TXRATE_HT and also rename mcs to ht_mcs in struct cfg80211_bitrate_mask. Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com> [reword commit message] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-02mac80211: don't leak next beacon when csa is abortedSimon Wunderlich
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-02mac80211: don't cancel csa finalize work within stop_apSimon Wunderlich
The current channel switch code has a potential deadlock: 1) * cfg80211_stop_ap acquires wdev-lock * ieee80211_stop_ap calls cancel_work_sync for the csa_finalize_work, which acquires the associated worker-lock 2) * ieee80211_csa_finalize_work holds the worker-lock when run * it calls cfg80211_ch_switch_notify which will claim the wdev-lock, and also needs to claim the sdata-lock (which is the same as the wdev-lock) to modify the beacons. It is sufficient to just set the channel switch active to false. If the worker is running later, it will find the channel switch to not be active anymore and returns immediately without changing anything. Canceling the worker is done anyway when the interface goes down (ieee80211_do_stop). Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-02cfg80211/mac80211/ath6kl: acquire wdev lock outside ch_switch_notifySimon Wunderlich
The channel switch notification should be sent under the wdev/sdata-lock, preferably in the same moment as the channel change happens, to avoid races by other callers (e.g. start/stop_ap). This also adds the previously missing sdata_lock protection in csa_finalize_work. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-02mac80211: modify beacon using sdata/wdev-lock, not rtnl lockSimon Wunderlich
The csa finalize worker needs to change the beacon information (for different modes). These are normally protected under rtnl lock, but the csa finalize worker is called by drivers and should not acquire the RTNL lock. Therefore change access protection for beacons to sdata/wdev lock. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> [fix sdata_dereference] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-02cfg80211: aggregate mgmt_tx parameters into a structAndrei Otcheretianski
Change cfg80211 and mac80211 to use cfg80211_mgmt_tx_params struct to aggregate parameters for mgmt_tx functions. This makes the functions' signatures less clumsy and allows less painful parameters extension. Signed-off-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com> [fix all other drivers] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: move csa_chandef to sdataLuciano Coelho
There is no reason why we should have only one channel switch announcement at a time for a single phy. When support for channel switch with multiple contexts and multiple vifs per context is implemented, we will need the chandef data for each vif. Move the csa_chandef structure to sdata to prepare for this. Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> [Fixed compilation with mesh] Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: use put_unaligned_le16 in mesh_plink_frame_txChun-Yeow Yeoh
Use put_unaligned_le16 in mesh_plink_frame_tx. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: add generic cipher scheme supportMax Stepanov
This adds generic cipher scheme support to mac80211, such schemes are fully under control by the driver. On hw registration drivers may specify additional HW ciphers with a scheme how these ciphers have to be handled by mac80211 TX/RR. A cipher scheme specifies a cipher suite value, a size of the security header to be added to or stripped from frames and how the PN is to be verified on RX. Signed-off-by: Max Stepanov <Max.Stepanov@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25cfg80211/mac80211: DFS setup chandef for cac eventJanusz Dziedzic
To report channel width correctly we have to send correct channel parameters from mac80211 when calling cfg80211_cac_event(). This is required in case of using channel width higher than 20MHz and we have to set correct dfs channel state after CAC (NL80211_DFS_AVAILABLE). Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com> Reviewed-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: fix the mesh channel switch supportChun-Yeow Yeoh
Mesh STA receiving the mesh CSA action frame is not able to trigger the mesh channel switch due to the incorrect handling and comparison of mesh channel switch parameters element (MCSP)'s TTL. Make sure the MCSP's TTL is updated accordingly before calling the ieee80211_mesh_process_chnswitch. Also, we update the beacon before forwarding the CSA action frame, so MCSP's precedence value and initiator flag need to be updated prior to this. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: fix for mesh beacon update on powersaveJavier Lopez
Mesh beacon was not being rebuild after user triggered a mesh powersave change. To solve this issue use ieee80211_mbss_info_change_notify instead of ieee80211_bss_info_change_notify. This helper function forces mesh beacon to be rebuild and then notifies the driver about the beacon change. Signed-off-by: Javier Lopez <jlopex@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25Revert "mac80211: allow disable power save in mesh"Bob Copeland
This reverts commit ee1f668136b2fb6640ee2d54c2a525ea41f98211. The aformentioned commit added a check to allow 'iw wlan0 set power_save off' to work for mesh interfaces. However, this is problematic because it also allows 'iw wlan0 set power_save on', which will crash in short order because all of the subsequent code manipulates sdata->u.mgd. The power-saving states for mesh interfaces can be manipulated through the mesh config, e.g: 'iw wlan0 set mesh_param mesh_power_save=active' (which, despite the name, actualy disables power saving since the setting refers to the type of sleep the interface undergoes). Cc: stable@vger.kernel.org Fixes: ee1f668136b2 ("mac80211: allow disable power save in mesh") Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-05Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next Conflicts: net/wireless/reg.c
2013-11-04Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/iwlwifi/pcie/drv.c
