path: root/net/mac80211/chan.c
2011-03-14mac80211: fix channel type recalculation with HT and non-HT interfacesFelix Fietkau
When running an AP interface along with the cooked monitor interface created by hostapd, adding an interface and deleting it again triggers a channel type recalculation during which the (non-HT) monitor interface takes precedence over the HT AP interface, thus causing the channel type to be set to non-HT. Fix this by ensuring that a more wide channel type will not be overwritten by a less wide channel type. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-16cfg80211/mac80211: use lockdep_assert_heldJohannes Berg
Instead of using a WARN_ON(!mutex_is_locked()) use lockdep_assert_held() which compiles away completely when lockdep isn't enabled, and also is a more accurate assertion since it checks that the current thread is holding the mutex. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-28mac80211: make a function staticJohannes Berg
sparse correctly complains that __ieee80211_get_channel_mode is not static. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-07mac80211: improve HT channel handlingJohannes Berg
Currently, when one interface switches HT mode, all others will follow along. This is clearly undesirable, since the new one might switch to no-HT while another one is operating in HT. Address this issue by keeping track of the HT mode per interface, and allowing only changes that are compatible, i.e. switching into HT40+ is not possible when another interface is in HT40-, in that case the second one needs to fall back to HT20. Also, to allow drivers to know what's going on, store the per-interface HT mode (channel type) in the virtual interface's bss_conf. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-07cfg80211/mac80211: better channel handlingJohannes Berg
Currently (all tested with hwsim) you can do stupid things like setting up an AP on a certain channel, then adding another virtual interface and making that associate on another channel -- this will make the beaconing to move channel but obviously without the necessary IEs data update. In order to improve this situation, first make the configuration APIs (cfg80211 and nl80211) aware of multi-channel operation -- we'll eventually need that in the future anyway. There's one userland API change and one API addition. The API change is that now SET_WIPHY must be called with virtual interface index rather than only wiphy index in order to take effect for that interface -- luckily all current users (hostapd) do that. For monitor interfaces, the old setting is preserved, but monitors are always slaved to other devices anyway so no guarantees. The second userland API change is the introduction of a per virtual interface SET_CHANNEL command, that hostapd should use going forward to make it easier to understand what's going on (it can automatically detect a kernel with this command). Other than mac80211, no existing cfg80211 drivers are affected by this change because they only allow a single virtual interface. mac80211, however, now needs to be aware that the channel settings are per interface now, and needs to disallow (for now) real multi-channel operation, which is another important part of this patch. One of the immediate benefits is that you can now start hostapd to operate on a hardware that already has a connection on another virtual interface, as long as you specify the same channel. Note that two things are left unhandled (this is an improvement -- not a complete fix): * different HT/no-HT modes currently you could start an HT AP and then connect to a non-HT network on the same channel which would configure the hardware for no HT; that can be fixed fairly easily * CSA An AP we're connected to on a virtual interface might indicate switching channels, and in that case we would follow it, regardless of how many other interfaces are operating; this requires more effort to fix but is pretty rare after all Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
