[ Upstream commit ba32679cac50c38fdf488296f96b1f3175532b8e ]
When trying to transmit to an unknown destination, the mesh code would
unconditionally transmit a HWMP PREQ even if HWMP is not the current
path selection algorithm.
Signed-off-by: Nicolas Cavallari <nicolas.cavallari@green-communications.fr>
Link: https://lore.kernel.org/r/20200305140409.12204-1-cavallar@lri.fr
[ Upstream commit b4201cc4fc6e1c57d6d306b1f787865043d60129 ]
This fixes:
net/mac80211/mesh_hwmp.c:603:26: warning: ‘target_metric’ may be used uninitialized in this function
target_metric is only consumed when reply = true so no bug exists here,
but not all versions of gcc realize it. Initialize to 0 to remove the
warning.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
[ Upstream commit 1f631c3201fe5491808df143d8fcba81b3197ffd ]
IEEE 802.11-2016 14.10.8.3 HWMP sequence numbering says:
If it is a target mesh STA, it shall update its own HWMP SN to
maximum (current HWMP SN, target HWMP SN in the PREQ element) + 1
immediately before it generates a PREP element in response to a
PREQ element.
Signed-off-by: Yuan-Chi Pang <fu3mo6goo@gmail.com>
[ Upstream commit fbbdad5edf0bb59786a51b94a9d006bc8c2da9a2 ]
The previous path metric update from RANN frame has not considered
the own link metric toward the transmitting mesh STA. Fix this.
Reported-by: Michael65535
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com>
Group station statistics by where they're (mostly) updated
(TX, RX and TX-status) and group them into sub-structs of
the struct sta_info.
Also rename the variables since the grouping now makes it
obvious where they belong.
This makes it easier to identify where the statistics are
updated in the code, and thus easier to think about them.
This value is only used in mesh, so move it into the new mesh
sub-struct of the station info.
This patch does the following:
- Remove unnecessary flags field used by PERR element
- Use the per target flags defined in <linux/ieee80211.h>
- Process the target only subfield based on case E2 of
IEEE802.11-2012 13.10.9.3
When processing a PREQ or PREP it's critical to use the incoming SN. If
that is improperly done routing loops and other types of badness can
happen. But the code was always processing path messages for deactivated
paths. This path fixes that so that if we have a valid SN then we use it
to verify that it is a message we can accept. For reference the relevant
section of the standard is 13.10.8.4 which doesn't address the deactivated
path case at all.
I also included a special case for when our peer reboots or restarts
networking. This is an important case because without it there can be a
very long delay before we accept path messages from that peer. It's also a
simple case and intimately associated with processing messages for
deactivated paths so I used one patch instead of two.
Signed-off-by: Alexis Green <agreen@cococorp.com>
The 2012 spec mentions that path SNs can be invalid when created (see
section 13.10.8.4 table 13-9) but AFAICT never talks about invalidating
SNs. Which makes sense: if we have figured out the path to a target at a
certain SN then we want to remember that fact. Failing to do so can lead
to routing loops because if we don't have a valid SN then we have no way
of knowing whether an incoming path message leads to or away from the
target.
However currently when discovery fails we zero out mpath->flags which
clears MESH_PATH_SN_VALID. This patch fixes that so that only the
discovery relevant flags are cleared.
When the nexthop is unable to resolve its own nexthop it will send back a
PERR with a zero target_sn. According to section 13.10.11.4.3 step b in the
2012 standard that perr should be forwarded and the associated mpath->sn
should be incremented. Neither one of those was happening which is rather
bad because the originator was not told that packets are black holing.
CC: Jesse Jones <jjones@cococorp.com>
There are now a fairly large number of mesh fields that really
aren't needed in any other modes; move those into their own
structure and allocate them separately.
This patch fixes a bug in hwmp_preq_frame_process where the wrong metric
can be used when forwarding a PREQ. This happens because the code uses
the same metric variable to record the value of the metric to the source
of the PREQ and the value of the metric to the target of the PREQ.
This comes into play when both reply and forward are set which happens
when IEEE80211_PREQ_PROACTIVE_PREP_FLAG is set and when MP_F_DO | MP_F_RF
is set. The original code had a special case to handle the first case
but not the second.
The patch uses distinct variables for the two metrics which makes the
code flow much clearer and removes the need to restore the original
value of metric when forwarding.
mesh_rx_path_sel_frame
The last hop metric should refer to link cost (this is how
hwmp_route_info_get uses it for example). But in mesh_rx_path_sel_frame
we are not dealing with link cost but with the total cost to the origin
of a PREQ or PREP.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
When a path target responds to a path request, its response
always contains the most up-to-date information; accordingly,
it should use the latest target_sn, regardless of
net_traversal_jiffies(). Otherwise, only the first path
response is considered when constructing a path, as it will
have the highest target_sn of all replies during that period.
Signed-off-by: Bob Copeland <bob@cozybit.com>
u16_field_get() is a simple wrapper around get_unaligned_le16(),
and it is being assigned to a u16, so there's no need to
promote to u32 in the middle.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
Use put_unaligned_le16 and put_unaligned_le32 for
mesh_path_error_tx and mesh_path_sel_frame_tx.
This adds generic cipher scheme support to mac80211, such schemes
are fully under control by the driver. On hw registration drivers
may specify additional HW ciphers with a scheme how these ciphers
have to be handled by mac80211 TX/RR. A cipher scheme specifies a
cipher suite value, a size of the security header to be added to
or stripped from frames and how the PN is to be verified on RX.
Signed-off-by: Max Stepanov <Max.Stepanov@intel.com>
VHT introduces multiple IEs that need to be parsed for a
wide bandwidth channel switch. Two are (currently) needed
in mac80211:
* wide bandwidth channel switch element
* channel switch wrapper element
The former is contained in the latter for beacons and probe
responses, but not for the spectrum management action frames
so the IE parser needs a new argument to differentiate them.
Most times that mesh_path_add() is called, it is followed by
a lookup to get the just-added mpath. We can instead just
return the new mpath in the case that we allocated one (or the
existing one if already there), so do that. Also, reorder the
code in mesh_path_add a bit so that we don't need to allocate
in the pre-existing case.
The mesh hwmp debug message is a bit confusing. The "sending PREP
to %p" should be the MAC address of mesh STA that has originated
the PREQ message and the "received PREP from %pM" should be the MAC
address of the mesh STA that has originated the PREP message.
There's various code with strange indentation,
questionable loop and locking constructs, etc.
The bigger change is moving the "sdata" argument
to the first argument of all functions, like all
other mac80211 functions that have one.
Make all the parsed IE pointers const, and propagate
the change to all the users etc.
Add routines to
- maintain a PS mode for each peer and a non-peer PS mode
- indicate own PS mode in transmitted frames
- track neighbor STAs power modes
- buffer frames when neighbors are in PS mode
- add TIM and Awake Window IE to beacons
- release frames in Mesh Peer Service Periods
Add local_pm to sta_info to represent the link-specific power
mode at this station towards the remote station. When a peer
link is established, use the default power mode stored in mesh
config. Update the PS status if the peering status of a neighbor
changes.
Maintain a mesh power mode for non-peer mesh STAs. Set the
non-peer power mode to active mode during peering. Authenticated
mesh peering is currently not working when either node is
configured to be in power save mode.
Indicate the current power mode in transmitted frames. Use QoS
Nulls to indicate mesh power mode transitions.
For performance reasons, calls to the function setting the frame
flags are placed in HWMP routing routines, as there the STA
pointer is already available.
Add peer_pm to sta_info to represent the peer's link-specific
power mode towards the local station. Add nonpeer_pm to
represent the peer's power mode towards all non-peer stations.
Track power modes based on received frames.
Add the ps_data structure to ieee80211_if_mesh (for TIM map, PS
neighbor counter and group-addressed frame buffer).
Set WLAN_STA_PS flag for STA in PS mode to use the unicast frame
buffering routines in the tx path. Update num_sta_ps to buffer
and release group-addressed frames after DTIM beacons.
Announce the awake window duration in beacons if in light or
deep sleep mode towards any peer or non-peer. Create a TIM IE
similarly to AP mode and add it to mesh beacons. Parse received
Awake Window IEs and check TIM IEs for buffered frames.
Release frames towards peers in mesh Peer Service Periods. Use
the corresponding trigger frames and monitor the MPSP status.
Append a QoS Null as trigger frame if neccessary to properly end
the MPSP. Currently, in HT channels MPSPs behave imperfectly and
show large delay spikes and frame losses.
Signed-off-by: Marco Porsch <marco@cozybit.com>
Signed-off-by: Ivan Bezyazychnyy <ivan.bezyazychnyy@gmail.com>
Signed-off-by: Mike Krinkin <krinkin.m.u@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
drivers/net/wireless/ath/ath9k/main.c
drivers/net/wireless/iwlwifi/dvm/tx.c
Mesh PERR action frames are robust and thus may be encrypted, so add
proper head/tailroom to allow this. Fixes this warning when operating
a Mesh STA on ath5k:
WARNING: at net/mac80211/wpa.c:427 ccmp_encrypt_skb.isra.5+0x7b/0x1a0 [mac80211]()
Call Trace:
[<c011c5e7>] warn_slowpath_common+0x63/0x78
[<c011c60b>] warn_slowpath_null+0xf/0x13
[<e090621d>] ccmp_encrypt_skb.isra.5+0x7b/0x1a0 [mac80211]
[<e090685c>] ieee80211_crypto_ccmp_encrypt+0x1f/0x37 [mac80211]
[<e0917113>] invoke_tx_handlers+0xcad/0x10bd [mac80211]
[<e0917665>] ieee80211_tx+0x87/0xb3 [mac80211]
[<e0918932>] ieee80211_tx_pending+0xcc/0x170 [mac80211]
[<c0121c43>] tasklet_action+0x3e/0x65
A user reported warnings in ath5k due to transmitting frames with no
rates set up. The frames were Mesh PERR frames, and some debugging
showed an empty control block with just the vif pointer:
> [ 562.522682] XXX txinfo: 00000000: 00 00 00 00 00 00 00 00 00 00 00
> 00 00 00 00 00 ................
> [ 562.522688] XXX txinfo: 00000010: 00 00 00 00 00 00 00 00 54 b8 f2
> db 00 00 00 00 ........T.......
> [ 562.522693] XXX txinfo: 00000020: 00 00 00 00 00 00 00 00 00 00 00
Set the IEEE80211_TX_INTFL_NEED_TXPROCESSING flag to ensure that
rate control gets run before the frame is sent.
One of the function names was wrong and some parameters were
missing.
Use skb_queue_walk_safe instead, and fix a few issues:
- didn't free old skbs on moving
- didn't react to failed skb alloc
- needlessly held a local pointer to the destination frame queue
- didn't check destination queue length before adding skb
Signed-off-by: Thomas Pedersen <thomas@cozybit.com>
Fix incorrect start markers, wrapped summary lines, missing section
breaks, incorrect separators, and some name mismatches.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
There are a few things that make the logging and
debugging in mac80211 less useful than it should
be right now:
* a lot of messages should be pr_info, not pr_debug
* wholesale use of pr_debug makes it require *both*
Kconfig and dynamic configuration
* there are still a lot of ifdefs
* the style is very inconsistent, sometimes the
sdata->name is printed in front
Clean up everything, introducing new macros and
separating out the station MLME debugging into
a new Kconfig symbol.
This patch fixes the problem of dropping RANN element if the TTL
is 1. If the received RANN element TTL is 1 or greater than 1, the
RANN is processed. However, forwarding of received RANN element
with TTL 1 or less is prohibited according to the standard. This
is previously reported by Monthadar Al Jaberi.
Besides, this patch also avoid the processing of unicast PREQ
generation if the RANN element does not meet the acceptance
criteria mentioned in Sec. 13.10.12.4.2 of IEEE Std. 802.11-2012.
Reported-by: Monthadar Al Jaberi <monthadar@gmail.com>
As defined in section 13.10.9.3 Case D (802.11-2012), this
control variable is used to limit the mesh STA to send only
one PREQ to a root mesh STA within this interval of time
(in TUs). The default value for this variable is set to
2000 TUs. However, for current implementation, the maximum
configurable of dot11MeshHWMPconfirmationInterval is
restricted by dot11MeshHWMPactivePathTimeout.
[line-break commit log]
Generate the proactive PREP element in Proactive PREQ mode as
defined in Sec. 13.10.10.3 (Case D) of IEEE Std. 802.11-2012.
Generate the proactive PREQ element as defined in
Sec. 13.10.9.3 (Case C) of IEEE Std. 802.11-2012
based on the selection of dot11MeshHWMPRootMode as follow:
dot11MeshHWMPRootMode (2) is proactivePREQnoPREP
dot11MeshHWMPRootMode (3) is proactivePREQwithPREP
The proactive PREQ is generated based on the interval
defined by dot11MeshHWMProotInterval.
With this change, proactive RANN element is now generated
if the dot11MeshHWMPRootMode is set to (4) instead of (1).
Signed-off-by: Javier Cardona <javier@cozybit.com>
Reviewed-by: Jason Abele <jason@cozybit.com>
Standardize the debugging to be able to use dynamic_debug.
Coalesce formats, align arguments.
Forwarded PREQ is either unicast or multicast. The appropriate counters
should be incremented accordingly.
Use the new bool function ether_addr_equal to add
some clarity and reduce the likelihood for misuse
of compare_ether_addr for sorting.
Done via cocci script:
$ cat compare_ether_addr.cocci
expression a,b;
- !compare_ether_addr(a, b)
+ ether_addr_equal(a, b)
expression a,b;
- compare_ether_addr(a, b)
+ !ether_addr_equal(a, b)
expression a,b;
- !ether_addr_equal(a, b) == 0
expression a,b;
- !ether_addr_equal(a, b) != 0
expression a,b;
- ether_addr_equal(a, b) == 0
expression a,b;
- ether_addr_equal(a, b) != 0
expression a,b;
- !!ether_addr_equal(a, b)
Record the RANN sender's address only for RANNs that meet the acceptance
criteria (per sections 13.10.12.4.2).
Reviewed-by: Javier Cardona <javier@cozybit.com>
This patch is intended to solve the follwing issues in RANN propagation:
[1] The interval in propagated RANN should be based on the interval of received RANN.
[2] The aggregated path metric for propagated RANN is as received plus own link metric
towards the transmitting mesh STA (not root mesh STA).
[3] The comparison of path metric for RANN with same sequence number should be done
before deciding whether to propagate or not.
The HWMP sequence number of received RANN element is compared to decide whether to be
propagated. The sequence number is required to covert from 32bit little endian data into
CPUs endianness for comparison. The same applies to the RANN metric.
Airtime link metric estimation was broken in HT mesh, use
cfg80211_calculate_bitrate to get the right rate value.
Also factor out tx rate copying from sta_set_sinfo().
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
RANN, PREP and PERR propagation should happen only if the
dot11MeshForwarding is true. Besides, data frame should not be
forwarded if dot11MeshForwarding is false. This redundant checking
is necessary to avoid the broadcasted ARP breaking the non-forwarding
rule.
Because of the constant size and guaranteed 16 bit alignment, the inline
compare_ether_addr function is much cheaper than calling memcmp.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
According to Section Y.7.4 Actions on receipt of proactive RANN, an individually
addressed PREQ should be generated towards the neighbor peer mesh STA indicated
in the RANN Sender Address field in the forwarding information.
Some files implicitly get this via mesh.h
which itself doesn't need it, so move the
inclusion into the right files. Some other
files don't need it at all but include it,
so remove it from there.
