path: root/net/mac80211/mesh_pathtbl.c
2014-10-09mac80211: implement cfg80211_ops to query mesh proxy path tableHenning Rogge
Implement get_mpp and dump_mpp cfg80211_ops to export the content of the 802.11s mesh proxy path table to userspace. Signed-off-by: Henning Rogge <henning.rogge@fkie.fraunhofer.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-08-27mac80211: Replace rcu_dereference() with rcu_access_pointer()Andreea-Cristina Bernat
The "rcu_dereference()" calls are used directly in conditions. Since their return values are never dereferenced it is recommended to use "rcu_access_pointer()" instead of "rcu_dereference()". Therefore, this patch makes the replacements. The following Coccinelle semantic patch was used: @@ @@ ( if( (<+... - rcu_dereference + rcu_access_pointer (...) ...+>)) {...} | while( (<+... - rcu_dereference + rcu_access_pointer (...) ...+>)) {...} ) Signed-off-by: Andreea-Cristina Bernat <bernat.ada@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-04-29mac80211: remove BUG_ON usageJohannes Berg
These BUG_ON statements should never trigger, but in the unlikely event that somebody does manage don't stop everything but simply exit the code path with an error. Leave the one BUG_ON where changing it would result in a NULL pointer dereference. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: use put_unaligned_le in mesh when necessaryChun-Yeow Yeoh
Use put_unaligned_le16 and put_unaligned_le32 for mesh_path_error_tx and mesh_path_sel_frame_tx. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-08mac80211: return new mpath from mesh_path_add()Bob Copeland
Most times that mesh_path_add() is called, it is followed by a lookup to get the just-added mpath. We can instead just return the new mpath in the case that we allocated one (or the existing one if already there), so do that. Also, reorder the code in mesh_path_add a bit so that we don't need to allocate in the pre-existing case. Signed-off-by: Bob Copeland <bob@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-15mac80211: clean up mesh codeJohannes Berg
There's various code with strange indentation, questionable loop and locking constructs, etc. The bigger change is moving the "sdata" argument to the first argument of all functions, like all other mac80211 functions that have one. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-15mac80211: constify IE parsingJohannes Berg
Make all the parsed IE pointers const, and propagate the change to all the users etc. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-04mac80211: mesh power save basicsMarco Porsch
Add routines to - maintain a PS mode for each peer and a non-peer PS mode - indicate own PS mode in transmitted frames - track neighbor STAs power modes - buffer frames when neighbors are in PS mode - add TIM and Awake Window IE to beacons - release frames in Mesh Peer Service Periods Add local_pm to sta_info to represent the link-specific power mode at this station towards the remote station. When a peer link is established, use the default power mode stored in mesh config. Update the PS status if the peering status of a neighbor changes. Maintain a mesh power mode for non-peer mesh STAs. Set the non-peer power mode to active mode during peering. Authenticated mesh peering is currently not working when either node is configured to be in power save mode. Indicate the current power mode in transmitted frames. Use QoS Nulls to indicate mesh power mode transitions. For performance reasons, calls to the function setting the frame flags are placed in HWMP routing routines, as there the STA pointer is already available. Add peer_pm to sta_info to represent the peer's link-specific power mode towards the local station. Add nonpeer_pm to represent the peer's power mode towards all non-peer stations. Track power modes based on received frames. Add the ps_data structure to ieee80211_if_mesh (for TIM map, PS neighbor counter and group-addressed frame buffer). Set WLAN_STA_PS flag for STA in PS mode to use the unicast frame buffering routines in the tx path. Update num_sta_ps to buffer and release group-addressed frames after DTIM beacons. Announce the awake window duration in beacons if in light or deep sleep mode towards any peer or non-peer. Create a TIM IE similarly to AP mode and add it to mesh beacons. Parse received Awake Window IEs and check TIM IEs for buffered frames. Release frames towards peers in mesh Peer Service Periods. Use the corresponding trigger frames and monitor the MPSP status. Append a QoS Null as trigger frame if neccessary to properly end the MPSP. Currently, in HT channels MPSPs behave imperfectly and show large delay spikes and frame losses. Signed-off-by: Marco Porsch <marco@cozybit.com> Signed-off-by: Ivan Bezyazychnyy <ivan.bezyazychnyy@gmail.com> Signed-off-by: Mike Krinkin <krinkin.m.u@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-08-20mac80211: clean up mpath_move_to_queue()Thomas Pedersen
Use skb_queue_walk_safe instead, and fix a few issues: - didn't free old skbs on moving - didn't react to failed skb alloc - needlessly held a local pointer to the destination frame queue - didn't check destination queue length before adding skb Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-08-20mac80211: use skb_queue_walk() in mesh_path_assign_nexthopThomas Pedersen
Since all we really want is just to iterate over all skbs, do just that and avoid (de)queueing to a clusmy tmpq. Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-31mac80211: use eth_broadcast_addrJohannes Berg
Instead of memset(). Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-10net: Fix (nearly-)kernel-doc comments for various functionsBen Hutchings
Fix incorrect start markers, wrapped summary lines, missing section breaks, incorrect separators, and some name mismatches. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-24mac80211: clean up debuggingJohannes Berg
There are a few things that make the logging and debugging in mac80211 less useful than it should be right now: * a lot of messages should be pr_info, not pr_debug * wholesale use of pr_debug makes it require *both* Kconfig and dynamic configuration * there are still a lot of ifdefs * the style is very inconsistent, sometimes the sdata->name is printed in front Clean up everything, introducing new macros and separating out the station MLME debugging into a new Kconfig symbol. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-05net: mac80211: Convert printk(KERN_DEBUG to pr_debugJoe Perches
Standardize the debugging to be able to use dynamic_debug. Coalesce formats, align arguments. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-09mac80211: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-12mac80211: fix the assignment of PREQ's MAC address for Proactive RANNChun-Yeow Yeoh
Record the RANN sender's address only for RANNs that meet the acceptance criteria (per sections 13.10.12.4.2). Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Reviewed-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-07mac80211: fix smatch lock errors in meshThomas Pedersen
smatch was complaining: CHECK net/mac80211/mesh_pathtbl.c net/mac80211/mesh_pathtbl.c:562 mesh_path_add() error: double lock 'bottom_half:' net/mac80211/mesh_pathtbl.c:580 mesh_path_add() error: double unlock 'bottom_half:' net/mac80211/mesh_pathtbl.c:589 mesh_path_add() error: double unlock 'bottom_half:' net/mac80211/mesh_pathtbl.c:691 mpp_path_add() error: double lock 'bottom_half:' net/mac80211/mesh_pathtbl.c:707 mpp_path_add() error: double unlock 'bottom_half:' net/mac80211/mesh_pathtbl.c:716 mpp_path_add() error: double unlock 'bottom_half:' net/mac80211/mesh_pathtbl.c:814 mesh_path_flush_by_nexthop() error: double lock 'bottom_half:' net/mac80211/mesh_pathtbl.c:819 mesh_path_flush_by_nexthop() error: double unlock 'bottom_half:' net/mac80211/mesh_pathtbl.c:887 mesh_path_del() error: double lock 'bottom_half:' net/mac80211/mesh_pathtbl.c:901 mesh_path_del() error: double unlock 'bottom_half:' So don't lock / unlock with _bh() while bottom halves are already disabled. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05mac80211: use compare_ether_addr on MAC addresses instead of memcmpFelix Fietkau
Because of the constant size and guaranteed 16 bit alignment, the inline compare_ether_addr function is much cheaper than calling memcmp. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-21mac80211: Convert call_rcu() to kfree_rcu(), drop mesh_gate_node_reclaim()Paul E. McKenney
The call_rcu() in mesh_gate_del() invokes mesh_gate_node_reclaim(), which simply calls kfree(). So convert the call_rcu() to kfree_rcu(), allowing mesh_gate_node_reclaim() to be eliminated. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: netdev@vger.kernel.org
2012-02-08mac80211: rename mesh static path_lookup()Luis R. Rodriguez
If you want to use mesh support from mac80211 on a recent kernel on 2.6.24 you'll run into a name clash when compiling against include/linux/namei.h, so rename this routine. /home/mcgrof/tmp/compat-wireless-3.2.5-1/net/mac80211/mesh_pathtbl.c: At top level: /home/mcgrof/tmp/compat-wireless-3.2.5-1/net/mac80211/mesh_pathtbl.c:342:26: error: conflicting types for ‘path_lookup’ include/linux/namei.h:71:12: note: previous declaration of ‘path_lookup’ was here Although this could sit as a separate patch in compat-wireless it seems best to just merge upstream. Cc: Javier Cardona <javier@cozybit.com> Signed-off-by: Luis R. Rodriguez <mcgrof@frijolero.org> Acked-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: don't initiate path discovery when forwarding frame with unknown DAThomas Pedersen
We used to initiate a path discovery when receiving a frame for which there is no forwarding information. To cut down on PREQ spam, just send a (gated) PERR in response. Also separate path discovery logic from nexthop querying. This patch means we no longer queue frames when forwarding, so kill the PERR TX stuff in discard_frame(). Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: failed forwarded mesh frame addressingThomas Pedersen
Don't write the TA until next hop is actually known, since we might need the original TA for sending a PERR. Previously we would send a PERR to ourself if path resolution for a forwarded frame failed. Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21mac80211: fix RCU warnings in meshJohannes Berg
Sparse RCU checking reports two warnings in the mesh path table code. These are due to questionable uses of rcu_dereference. To fix the first one, get rid of mesh_gate_add() and just make mesh_path_add_gate() do the correct deref. To fix the second one, simply remove rcu_dereference() in mesh_gate_del() -- it already gets a proper pointer as indicated by the prototype (no __rcu annotation) and confirmed by the code. Cc: Javier Cardona <javier@cozybit.com> Cc: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09mac80211: simplify mesh frame queue mapping and QoSJavier Cardona
We only need to set the skb queue twice: 1. by the netdev, on local TX. 2. when forwarding a mesh frame. We only need to set the qos header twice: 1. by mac80211, on local TX. 2. when putting a frame on the mpath->frame_queue We also don't need the RA in order to set the proper queue mapping since all mesh STAs are QoS, indicate this and do it once when the frame is received. Also fixes an issue where the QoS header and queue mapping was not set for unicast forwarded frames. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-19Merge branch 'master' of ssh://infradead/~/public_git/wireless-next into ↵John W. Linville
for-davem
2011-09-14mac80211: Mesh data frames must have the QoS headerJavier Cardona
Per sec 7.1.3.5 of draft 12.0 of 802.11s, mesh frames indicate the presence of the mesh control header in their QoS header. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-14mac80211: Start implementing QoS support for mesh interfacesJavier Cardona
In order to support QoS in mesh, we need to assign queue mapping only after the next hop has been resolved, both for forwarded and locally originated frames. Also, now that this is fixed, remove the XXX comment in ieee80211_select_queue(). Also, V-Shy Ho reported that the queue mapping was not being applied to the forwarded frame (fwd_skb instead of skb). Fixed that as well. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13mac80211: handle allocation failures in mesh_pathtbl_init()Dan Carpenter
The calls to kzalloc() weren't checked here and it upsets the static checkers. Obviously they're not super likely to fail, but we might as well add some error handling. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13mac80211: Consolidate mesh path duplicated functionsJavier Cardona
2011-09-13mac80211: Consolidate {mesh,mpp}_path_flush into one functionJavier Cardona
2011-09-13mac80211: Don't iterate twice over all mpaths when once in sufficientJavier Cardona
2011-09-13mac80211: Remove redundant mesh path expiration checksJavier Cardona
2011-09-13mac80211: Improve mpath state lockingJavier Cardona
No need to take the mpath state lock when an mpath is removed. Also, no need checking the lock when reading mpath flags. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13mac80211: Remove mesh paths when an interface is removedJavier Cardona
When an interface is removed, the mesh paths associated with it should also be removed. This fixes a bug we observed when reloading a device driver module without reloading mac80211s. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13mac80211: Fix RCU pointer dereference in mesh_path_discard_frame()Javier Cardona
Reported by Pedro Larbig (ASPj) Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem
2011-08-29mac80211: refactor skb copy to failq in mesh_path_move_to_queueJohn W. Linville
This seems a bit less awkward... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-29Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2011-08-26mac80211: mesh gate fixesThomas Pedersen
Since a v1 of the mesh gate series was accidentally applied, this patch contains the changes in v2. These are: - automatically make mesh gate a root node. - use TU_TO_EXP_TIME macro. - initialize timer instead of checking for NULL timer function. - cleanups. Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-24mac80211: mesh gate implementationJavier Cardona
In this implementation, a mesh gate is a root node with a certain bit set in its RANN flags. The mpath to this root node is marked as a path to a gate, and added to our list of known gates for this if_mesh. Once a path discovery process fails, we forward the unresolved frames to a known gate. Thanks to Luis Rodriguez for refactoring and bug fix help. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-24mac80211: fix mesh path flushingJavier Cardona
Previously, mpaths were never flushed since the mpath is not active once we call this function. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-24mac80211: mesh locking fixesJavier Cardona
mesh_queue_preq is invoked invoked from both user (work queue) and softirq (timer) context, so the _bh version of spinlock needs to be used. Also, the mpath->state_lock should be softirq safe as well. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-24mac80211: fix mpath timer NULL functionJavier Cardona
If we have an mpath whose timer has not been initialized, don't try to delete it. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-24mac80211: improve mpath debuggingJavier Cardona
make hwmp_dbg print the relevant sdata->name by default and improve formatting. Also add mpath_dbg macro for debugging of mesh path operations. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-22mac80211: update mesh path selection frame formatThomas Pedersen
Make mesh path selection frames Mesh Action category, remove outdated Mesh Path Selection category and defines, use updated reason codes, add mesh_action_is_path_sel for readability, and update/correct path selection IEs. Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-12net: cleanup some rcu_dereference_rawEric Dumazet
RCU api had been completed and rcu_access_pointer() or rcu_dereference_protected() are better than generic rcu_dereference_raw() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05mac80211: fix smatch complainsChristian Lamparter
mlme.c l.757 ieee80211_dynamic_ps_enable_work(11) variable dereferenced before check 'sdata' mesh_pathtbl.c l.650 mesh_path_del(20) double lock 'bottom_half' l.663 mesh_path_del(33) double unlock 'bottom_half' Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-24Merge ↵John W. Linville
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
