path: root/net/mac80211/mlme.c
2008-06-09mac80211: Checking IBSS support while changing channel in ad-hoc modeAssaf Krauss
This patch adds a check to the set_channel flow. When attempting to change the channel while in IBSS mode, and the new channel does not support IBSS mode, the flow return with an error value with no consequences on the mac80211 and driver state. Signed-off-by: Assaf Krauss <assaf.krauss@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-09mac80211: decrease IBSS creation latencyDan Williams
Sufficient scans (at least 2 or 3) should have been done within 7 seconds to find an existing IBSS to join. This should improve IBSS creation latency; and since IBSS merging is still in effect, shouldn't have detrimental effects on eventual IBSS convergence. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-09mac80211: send association event on IBSS createDan Williams
Otherwise userspace has no idea the IBSS creation succeeded. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-28mac80211: fix alignment issue with compare_ether_addr()Senthil Balasubramanian
This addresses an alignment issue with compare_ether_addr(). The addresses passed to compare_ether_addr should be two bytes aligned. It may function properly in x86 platform. However may not work properly on IA-64 or ARM processor. This also fixes a typo in mlme.c where the sk_buff struct name is incorect. Though sizeof() works for any incorrect structure pointer name as its just a pointer length that we want, lets just fix it. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-28mac80211: Fix for NULL pointer dereference in sta_info_get()Senthil Balasubramanian
This addresses a NULL pointer dereference in sta_info_get(). TID and sta_info are extracted in ADDBA Timer expiry function through the timer handler's argument. The problem is extracging the TID (which was stored in timer_to_tid[] array of type "u8") through "int *" typecast which may also yield unwanted bytes for the MSB of TID that results in incorrect sta_info and ieee80211_local pointers. ieee80211_local pointer is NULL as illustrated below, it crashes in sta_info_get(). The problem started when extracting ieee80211_local pointer out of sta_info iteself and eventually crashed in stat_info_get(). The proper way to fix is to change the data type of TID to u8 instead of u16. However changing all the occurences requires some prototype changes as well. We should fix this in upcoming patches. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: Luis Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-28mac80211: reorder channel and freq reporting in wext scan reportTomas Winkler
This patch switch order of channel and freq (SIOCGIWFREQ) reports in scan results in order to overcome wpa_supplicant inability to handle channel numbers in 5.2Ghz band. Wext reporting channel number is ambiguous as channels 7-12 (802.11j) exist on both bands. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-28mac80211: fix ieee80211_rx_bss_put/get imbalanceTomas Winkler
This patch fixes iee80211_rx_bss_put/get imbalance introduced by 'mac80211: enable IBSS merging' patch. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-20mac80211: fix NULL pointer dereference in ieee80211_compatible_ratesHelmut Schaa
Fix a possible NULL pointer dereference in ieee80211_compatible_rates introduced in the patch "mac80211: fix association with some APs". If no bss is available just use all supported rates in the association request. Signed-off-by: Helmut Schaa <hschaa@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-16mac80211 : Association with 11n hidden ssid ap.Abhijeet Kolekar
This patch fixes the association problem with 11n hidden ssid ap. Patch fixes the problem of associating with hidden ssid when all three parameters ap,essid and channel are given to iwconfig. This patch removes the condition of checking three parameters and always checks for bss in bss list while associating. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12mac80211: fix association with some APsHelmut Schaa
Some APs refuse association if the supported rates contained in the association request do not match its own supported rates. This patch introduces a new function which builds the intersection between the AP's supported rates and the client's supported rates to work around such problems. The same approach is already used in ipw2200 for example. Signed-off-by: Helmut Schaa <hschaa@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-23mac80211: Fix race between ieee80211_rx_bss_put and lookup routines.Pavel Emelyanov
The put routine first decrements the users counter and then (if it is zero) locks the sta_bss_lock and removes one from the list and the hash. Thus, any of ieee80211_sta_config_auth, ieee80211_rx_bss_get or ieee80211_rx_mesh_bss_get can race with it by finding a bss that is about to get kfree-ed. Using atomic_dec_and_lock in ieee80211_rx_bss_put takes care of this race. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-23mac80211: Fix n-band association problemAbhijeet Kolekar
There are two structures named wmm_info and wmm_param, they are used while parsing the beacon frame. (Check the function ieee802_11_parse_elems). Certain APs like D-link does not set the fifth bit in WMM IE. While sending the association request to n-only ap it checks for wmm_ie. If it is set then only ieee80211_ht_cap is sent during association request. So n-only association fails. And this patch fixes this problem by copying the wmm_info to wmm_ie, which enables the "wmm" flag in iee80211_send_assoc. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Acked-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: rework scanning to account for probe response/beacon differenceJohannes Berg
This patch reworks the scanning code (ieee80211_rx_bss_info) to take more parameters from beacons and keep a BSS info structure alive when only beacons for it are received. This fixes a problem with iwlwifi drivers (where we don't understand the root cause of the problem yet) and another driver for some broken hardware (which cannot send probe requests unless associated, so can't always actively scan.) Signed-off-by: Bill Moss <bmoss@clemson.edu> [jmberg: reformatted comments, make probe_resp a bool] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: no BSS changes to driver from beacons processed during scanningReinette Chatre
There is no need to send BSS changes to driver from beacons processed during scanning. We are more interested in beacons from an AP with which we are associated - these will still be used to send updates to driver as the beacons are received without scanning. This change·removes the requirement that bss_info_changed needs to be atomic. The beacons received during scanning are processed from a tasklet, but if we do not call bss_info_changed for these beacons there is no need for it to be atomic. This function (bss_info_changed) is called either from workqueue or ioctl in all other instances. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Acked-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mlme.c: fixup some merge damageJohn W. Linville
This one got renamed, complicating the merge a bit...this should restore it to its intended state. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: rename filesJohannes Berg
This patch renames all mac80211 files (except ieee80211_i.h) to get rid of the useless ieee80211_ prefix. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
