path: root/net/mac80211/rx.c
2008-12-19mac80211: Remove radiotap rate-present flag for HTJouni Malinen
Since we do not currently report HT rates (MCS index) in radiotap header for HT rates, we should not claim the rate is present. The rate octet itself is used as padding in this case, so only the it_present flag needs to be removed in case of HT rates. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-19mac80211: Add HT rates into RX status reportingJouni Malinen
This patch adds option for HT-enabled drivers to report HT rates (HT20/HT40, short GI, MCS index) to mac80211. These rates are currently not in the rate table, so the rate_idx is used to indicate MCS index. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-12mac80211: misc cleanupsRami Rosen
This patch removes unneeded member (skbuff) from ieee80211_ibss_add_sta() method in its declaration (in ieee80211_i.h) and its callers (in rx.c and mlme.c) This patch removes unneeded member from struct ieee80211_rx_data in ieee80211_i.h. (Originally posted as two patches. -- JWL) Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-12mac80211: integrate sta_notify_ps cmds into sta_notifyChristian Lamparter
This patch replaces the newly introduced sta_notify_ps function, which can be used to notify the driver about every power state transition for all associated stations, by integrating its functionality back into the original sta_notify callback. Signed-off-by: Christian Lamparter <chunkeey@web.de> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-05mac80211: add sta_notify_ps callbackChristian Lamparter
This patch is necessary in order to provide a proper Access point support for p54. Unfortunately for us, there is no documented way to disable the interfering power save buffering mechanism in firmware completely. Therefore we give in and notify the driver through our new sta_notify_ps callback, so that we can update the filter state. Signed-off-by: Christian Lamparter <chunkeey@web.de> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-05mac80211: only transition STAs ps->wake on data framesJohannes Berg
When a station goes to PS mode to scan, it will then send probe requests without the PS bit set. mac80211 will take that as indication that the station woke up, but it didn't. This patch changes mac80211 to only consider doze->wake transitions on data frames to to fix that issue. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: Re-enable aggregationSujith
Wireless HW without any dedicated queues for aggregation do not need the ampdu_queues mechanism present right now in mac80211. Since mac80211 is still incomplete wrt TX MQ changes, do not allow aggregation sessions for drivers that set ampdu_queues. This is only an interim hack until Intel fixes the requeue issue. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: Luis Rodriguez <Luis.Rodriguez@Atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: allow all interfaces types to handle RX action framesAndrey Yurovsky
Eliminate the vif.type check in ieee80211_rx_h_action. This check is unnecessary (these action frames can be handled by all interface types) and currently prevents, for example, AP interfaces from handling BACK action frames such as ADDBA and DELBA requests. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: minor code cleanupsJohannes Berg
Nothing very interesting, some checkpatch inspired stuff, some other things. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27mac80211: convert to %pM away from print_macJohannes Berg
Also remove a few stray DECLARE_MAC_BUF that were no longer used at all. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-12net/mac80211/rx.c: fix build errorIngo Molnar
older versions of gcc do not recognize that ieee80211_rx_h_mesh_fwding() is unused when CONFIG_MAC80211_MESH is disabled: net/built-in.o: In function `ieee80211_rx_h_mesh_fwding': rx.c:(.text+0xd89af): undefined reference to `mpp_path_lookup' rx.c:(.text+0xd89c6): undefined reference to `mpp_path_add' as this code construct: if (ieee80211_vif_is_mesh(&sdata->vif)) CALL_RXH(ieee80211_rx_h_mesh_fwding); still causes ieee80211_rx_h_mesh_fwding() to be linked in. Protect these places with an #ifdef. commit b0dee578 ("Fix modpost failure when rx handlers are not inlined.") solved part of this problem - this patch is still needed. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-30Fix modpost failure when rx handlers are not inlined.Davide Pesavento
When CONFIG_MAC80211_MESH=n and CONFIG_MAC80211_NOINLINE=y, gcc doesn't optimize out a call to ieee80211_rx_h_mesh_fwding, even if the previous comparison is always false in this case. This leads to the following errors during modpost: ERROR: "mpp_path_lookup" [net/mac80211/mac80211.ko] undefined! ERROR: "mpp_path_add" [net/mac80211/mac80211.ko] undefined! Fix by removing the possibility of uninlining ieee80211_rx_h_mesh_fwding rx handler. Signed-off-by: Davide Pesavento <davidepesa@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-24mac80211: fix mesh action frame handlingJohannes Berg
When I split off the action frame handling I made the code drop all action frames we don't want to handle. This is wrong since some action frames are actually handled via rx_h_mgmt through being queued to the sta/mesh implementations. Thanks to Li YanBo for noticing the problem. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Li YanBo <dreamfly281@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-24mac80211: mesh portal functionality supportYanBo
Currently the mesh code doesn't support bridging mesh point interfaces with wired ethernet or AP to construct an MPP or MAP. This patch adds code to support the "6 address frame format packet" functionality to mesh point interfaces. Now the mesh network can be used as backhaul for end to end communication. Signed-off-by: Li YanBo <dreamfly281@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-24mac80211: make master iface not wirelessJohannes Berg
There's no need to register the master netdev with cfg80211, in fact, this is quite dangerous and lead to having to add checks for the master interface all over the config handlers. This patch removes the "ieee80211_ptr" from the master iface in favour of having a small netdev_priv() associated with the master interface that stores the ieee80211_local pointer. Because of this, a lot of code in the configuration handlers can go away. To make this patch easier to verify I have also removed a number of wiphy_priv() calls in favour of getting the sdata first and then the local pointer from that. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: share STA information with driverJohannes Berg
This patch changes mac80211 to share some more data about stations with drivers. Should help iwlwifi and ath9k when they get around to updating, and might also help with implementing rate control algorithms without internals. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: use nl80211 interface typesJohannes Berg
There's really no reason for mac80211 to be using its own interface type defines. Use the nl80211 types and simplify the configuration code a bit: there's no need to translate them any more now. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: clean up some commentsJohannes Berg
Some comments refer to 80211.o or similar; also remove a comment about implementing fragments better, we really have better things to do. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: clean up scan namespaceJohannes Berg
Most of the scan functions are called ieee80211_sta_scan_* or similar, make clean it up so they are all just called ieee80211_scan_*. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: make bridge_packets a virtual interface optionJohannes Berg
The bridge_packets configuration really should be per virtual interface (theoretically per AP/VLAN, but this is much easier); there currently is no way to set it yet though. Also invert the option to "NO_BRIDGE_PACKETS" so the default is to bridge. While at it, also document the flags properly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: split off mesh handling entirelyJohannes Berg
This patch splits off mesh handling from the STA/IBSS. Unfortunately it increases mesh code size a bit, but I think it makes things clearer. The patch also reduces per-interface run-time memory usage. Also clean up a few places where ifdef is not required. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: make ieee80211_rx_h_mgmt more readableJohannes Berg
That function isn't exactly easy to read especially since it does something in an if branch that continues after the if because the else returns. Express it in a more readable way. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: move spectrum management code outJohannes Berg
Like the HT code, this doesn't depend on the STA-mode implementation and can be handled entirely independently. There's only stub code for now, but when it gets filled having it in its own file will be beneficial. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: make BA session handling independent of STA modeJohannes Berg
The aggregation handling isn't dependent on anything related to our STA-mode implementation, and doesn't need to depend on it for frame processing. This patch moves the relevant code to ht.c and adds a hook in rx.c. For now, the relevant action frames are only processed in STA/IBSS modes, but that's now something we can easily change. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-08mac80211: Fix rate scale initialization in IBSSEmmanuel Grumbach
This patch address some IBSS rate issues introduced or not covered by "mac80211: eliminate IBSS warning in rate_lowest_index()" and "cfg80211 API for channels/bitrates, mac80211 and driver conversion". This patch: 1. Moves addition of IBSS station from prepare_for_handlers to ieee80211_rx_bss_info when triggered from beacon eliminating bogus supported rates. 2. Initialize properly supported rates also in IBSS merging 3. Ensure that mandatory rates are always added into supported rates. This is needed in case when station addition is triggered from non beacon/probe packet. Some management frames need to be sent 4. Remove initialization of supported rates from self rates. This path was dead code after 6bc37c06bc4 and in general incorrect. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Cc: Vladimir Koutny <vlado@work.ksp.sk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22replace net_device arguments with ieee80211_{local,sub_if_data} as appropriateJasper Bryant-Greene
This patch replaces net_device arguments to mac80211 internal functions with ieee80211_{local,sub_if_data} as appropriate. It also does the same for many 802.11s mesh functions, and changes the mesh path table to be indexed on sub_if_data rather than net_device. If the mesh part needs to be a separate patch let me know, but since mesh uses a lot of mac80211 functions which were being converted anyway, the changes go hand-in-hand somewhat. This patch probably does not convert all the functions which could be converted, but it is a large chunk and followup patches will be provided. Signed-off-by: Jasper Bryant-Greene <jasper@amiton.co.nz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22mac80211: remove rx/tx_data->fc memberHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22mac80211: use ieee80211 frame control directlyHarvey Harrison
Remove the last users of the rx/tx_data->fc data members and use the le16 frame_control from the header directly. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22mac80211: rx.c/tx.c remove more users of tx/rx_data->fcHarvey Harrison
Those functions that still use ieee80211_get_hdrlen are moved over to use the little endian frame control. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22mac80211: radiotap: assume modulation from ratesBruno Randolf
use the rates ERP flag to derive CCK or OFDM modulation for the radiotap header. (it might be more correct to get this information from the hardware itself, but it seems safe to assume this in most practical cases.) Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22mac80211: add rx status flag for short preambleBruno Randolf
and use it for the radiotap header Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-07mac80211: fix use of skb->cb for mesh forwardingLuis Carlos Cobo
Now we deal with mesh forwarding before the 802.11->802.3 conversion, thus eliminating a few unnecessary steps. The next hop lookup is called from ieee80211_master_start_xmit() instead of subif_start_xmit(). Until the next hop is found, RA in the frame will be all zeroes for frames originating from the device. For forwarded frames, RA will contain the TA of the received frame, which will be necessary to send a path error if a next hop is not found. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: fix RX sequence number checkJohannes Berg
According to 802.11-2007, we are doing the wrong thing in the sequence number checks when receiving frames. This fixes it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: Fix ieee80211_rx_reorder_ampdu: ignore QoS null packetsEmmanuel Grumbach
This patch fixes the check at the entrance to ieee80211_rx_reorder_ampdu. This check has been broken by 'mac80211: rx.c use new helpers'. Letting QoS NULL packet in ieee80211_rx_reorder_ampdu led to packet loss in RX. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: make master netdev handling saneJohannes Berg
Currently, almost every interface type has a 'bss' pointer pointing to BSS information. This BSS information, however, is for a _local_ BSS, not for the BSS we joined, so having it on a STA mode interface makes little sense, but now they have it pointing to the master device, which is an AP mode virtual interface. However, except for some bitrate control data, this pointer is only used in AP/VLAN modes (for power saving stations.) Overall, it is not necessary to even have the master netdev be a valid virtual interface, and it doesn't have to be on the list of interfaces either. This patch changes the master netdev to be special, it now - no longer is on the list of virtual interfaces, which lets me remove a lot of tests for that - no longer has sub_if_data attached, since that isn't used Additionally, this patch changes some vlan/ap mode handling that is related to these 'bss' pointers described above (but in the VLAN case they actually make sense because there they point to the AP they belong to); it also adds some debugging code to IEEE80211_DEV_TO_SUB_IF to validate it is not called on the master netdev any more. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-08mac80211: remove trivial rx_data->fc usersHarvey Harrison
2008-07-08mac80211: move QOS control helpers into ieee80211.hHarvey Harrison
Also remove the WLAN_IS_QOS_DATA inline after removing the last two users. This starts moving away from using rx->fc to using the header frame_control directly. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-02mac80211: rework debug settings and make debugging saferJohannes Berg
This patch reworks the mac80211 debug settings making them more focused and adding help text for those that didn't have one. It also removes a number of printks that can be triggered remotely and add no value, e.g. "too short deauthentication frame received - ignoring". If somebody really needs to debug that they should just add a monitor interface and look at the frames in wireshark. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-02mac80211: get rid of function pointers in RX pathJohannes Berg
This changes the RX path to no longer use function pointers for RX handlers but rather invoke them directly. If debugging is enabled, mark the RX handlers noinline because otherwise they all get inlined into ieee80211_invoke_rx_handlers() which makes it harder to see where a bug is. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-27mac80211: rx.c use new frame control helpersHarvey Harrison
2008-06-14mac80211: eliminate IBSS warning in rate_lowest_index()Vladimir Koutny
In IBSS mode prior to join/creation of new IBSS it is possible that a frame from unknown station is received and an ibss_add_sta() is called. This will cause a warning in rate_lowest_index() since the list of supported rates of our station is not initialized yet. The fix is to add ibss stations with a rate we received that frame at; this single-element set will be extended later based on beacon data. Also there is no need to store stations from a foreign IBSS. Signed-off-by: Vladimir Koutny <vlado@ksp.sk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14mac80211: rx.c use new helpersHarvey Harrison
2008-06-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tg3.c drivers/net/wireless/rt2x00/rt2x00dev.c net/mac80211/ieee80211_i.h
2008-05-28mac80211: fix alignment issue with compare_ether_addr()Senthil Balasubramanian
This addresses an alignment issue with compare_ether_addr(). The addresses passed to compare_ether_addr should be two bytes aligned. It may function properly in x86 platform. However may not work properly on IA-64 or ARM processor. This also fixes a typo in mlme.c where the sk_buff struct name is incorect. Though sizeof() works for any incorrect structure pointer name as its just a pointer length that we want, lets just fix it. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: remove channel use statisticsJohannes Berg
The useless channel use statistics are quite a lot of code, currently use integer divisions in the packet fast path, are rather inaccurate since they do not account for retries and finally nobody even cares. Hence, remove them completely. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: move TX info into skb->cbJohannes Berg
This patch converts mac80211 and all drivers to have transmit information and status in skb->cb rather than allocating extra memory for it and copying all the data around. To make it fit, a union is used where only data that is necessary for all steps is kept outside of the union. A number of fixes were done by Ivo, as well as the rt2x00 part of this patch. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-15Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-4965-rs.c drivers/net/wireless/rt2x00/rt61pci.c
2008-05-14mac80211: make rx radiotap header more flexibleBruno Randolf
use hw flags and rx flags to determine which fields are present in the header and use all available information from the driver. make sure radiotap header starts at a naturally aligned address (mod 8) for all radiotap fields. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-14mac80211: use hardware flags for signal/noise unitsBruno Randolf
trying to clean up the signal/noise code. the previous code in mac80211 had confusing names for the related variables, did not have much definition of what units of signal and noise were provided and used implicit mechanisms from the wireless extensions. this patch introduces hardware capability flags to let the hardware specify clearly if it can provide signal and noise level values and which units it can provide. this also anticipates possible new units like RCPI in the future. for signal: IEEE80211_HW_SIGNAL_UNSPEC - unspecified, unknown, hw specific IEEE80211_HW_SIGNAL_DB - dB difference to unspecified reference point IEEE80211_HW_SIGNAL_DBM - dBm, difference to 1mW for noise we currently only have dBm: IEEE80211_HW_NOISE_DBM - dBm, difference to 1mW if IEEE80211_HW_SIGNAL_UNSPEC or IEEE80211_HW_SIGNAL_DB is used the driver has to provide the maximum value (max_signal) it reports in order for applications to make sense of the signal values. i tried my best to find out for each driver what it can provide and update it but i'm not sure (?) for some of them and used the more conservative guess in doubt. this can be fixed easily after this patch has been merged by changing the hardware flags of the driver. DRIVER SIGNAL MAX NOISE QUAL ----------------------------------------------------------------- adm8211 unspec(?) 100 n/a missing at76_usb unspec(?) (?) unused missing ath5k dBm dBm percent rssi b43legacy dBm dBm percent jssi(?) b43 dBm dBm percent jssi(?) iwl-3945 dBm dBm percent snr+more iwl-4965 dBm dBm percent snr+more p54 unspec 127 n/a missing rt2x00 dBm n/a percent rssi+tx/rx frame success rt2400 dBm n/a rt2500pci dBm n/a rt2500usb dBm n/a rt61pci dBm n/a rt73usb dBm n/a rtl8180 unspec(?) 65 n/a (?) rtl8187 unspec(?) 65 (?) noise(?) zd1211 dB(?) 100 n/a percent drivers/net/wireless/ath5k/base.c: Changes-licensed-under: 3-Clause-BSD Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
