commit 3a5c5e81d8128a9e43abc52b75dd21d3da7a0cfc upstream.
Fix a regression introduced by commit a5e70697d0c4 ("mac80211: add radiotap flag
and handling for 5/10 MHz") where the IEEE80211_CHAN_CCK channel type flag was
incorrectly replaced by the IEEE80211_CHAN_OFDM flag. This commit fixes that by
using the CCK flag again.
Fixes: a5e70697d0c4 ("mac80211: add radiotap flag and handling for 5/10 MHz")
Signed-off-by: Mathy Vanhoef <vanhoefm@gmail.com>
commit d025933e29872cb1fe19fc54d80e4dfa4ee5779c upstream.
As multicast-frames can't be fragmented, "dot11MulticastReceivedFrameCount"
stopped being incremented after the use-after-free fix. Furthermore, the
RX-LED will be triggered by every multicast frame (which wouldn't happen
before) which wouldn't allow the LED to rest at all.
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=89431 which also had the
patch.
Fixes: b8fff407a180 ("mac80211: fix use-after-free in defragmentation")
Signed-off-by: Andreas Müller <goo@stapelspeicher.org>
[rewrite commit message]
Upon receiving the last fragment, all but the first fragment
are freed, but the multicast check for statistics at the end
of the function refers to the current skb (the last fragment)
causing a use-after-free bug.
Since multicast frames cannot be fragmented and we check for
this early in the function, just modify that check to also
do the accounting to fix the issue.
Cc: stable@vger.kernel.org
Reported-by: Yosef Khyal <yosefx.khyal@intel.com>
Our legal structure changed at some point (see wikipedia), but
we forgot to immediately switch over to the new copyright
notice.
For files that we have modified in the time since the change,
add the proper copyright notice now.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
When starting an offloaded BA session it is
unknown what starting sequence number should be
used. Using last_seq worked in most cases except
after hw restart.
When hw restart is requested last_seq is
(rightfully so) kept unmodified. This ended up
with BA sessions being restarted with an aribtrary
BA window values resulting in dropped frames until
sequence numbers caught up.
Instead of last_seq pick seqno of a first Rxed
frame of a given BA session.
This fixes stalled traffic after hw restart with
offloaded BA sessions (currently only ath10k).
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
In the cfg80211_rx_mgmt(), parameter @gfp was used for the memory allocation.
But, memory get allocated under spin_lock_bh(), this implies atomic context.
So, one can't use GFP_KERNEL, only variants with no __GFP_WAIT. Actually, in all
occurrences GFP_ATOMIC is used (wil6210 use GFP_KERNEL by mistake),
and it should be this way or warning triggered in the memory allocation code.
Remove @gfp parameter as no actual choice exist, and use hard coded
GFP_ATOMIC for memory allocation.
Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com>
Some drivers (e.g. ath10k) report A-MSDU subframes
individually with identical seqno. The A-MPDU Rx
reorder code did not account for that which made
it practically unusable with drivers using
RX_FLAG_AMSDU_MORE because it would end up
dropping a lot of frames resulting in confusion in
upper network transport layers.
If the AP receives actions frames destined for other peers, it may
mistakenly toggle BA-sessions from itself to a peer.
Ignore TDLS data packets as well - the AP should not handle them.
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
It is currently possible to have a race due to the station PS
unblock work like this:
* station goes to sleep with frames buffered in the driver
* driver blocks wakeup
* station wakes up again
* driver flushes/returns frames, and unblocks, which schedules
the unblock work
* unblock work starts to run, and checks that the station is
awake (i.e. that the WLAN_STA_PS_STA flag isn't set)
* we process a received frame with PM=1, setting the flag again
* ieee80211_sta_ps_deliver_wakeup() runs, delivering all frames
to the driver, and then clearing the WLAN_STA_PS_DRIVER and
WLAN_STA_PS_STA flags
In this scenario, mac80211 will think that the station is awake,
while it really is asleep, and any TX'ed frames should be filtered
by the device (it will know that the station is sleeping) but then
passed to mac80211 again, which will not buffer it either as it
thinks the station is awake, and eventually the packets will be
dropped.
Fix this by moving the clearing of the flags to exactly where we
learn about the situation. This creates a problem of reordering,
so introduce another flag indicating that delivery is being done,
this new flag also queues frames and is cleared only while the
spinlock is held (which the queuing code also holds) so that any
concurrent delivery/TX is handled correctly.
Reported-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com>
drivers/net/ethernet/altera/altera_sgdma.c
net/netlink/af_netlink.c
net/sched/cls_api.c
net/sched/sch_api.c
The netlink conflict dealt with moving to netlink_capable() and
netlink_ns_capable() in the 'net' tree vs. supporting 'tc' operations
in non-init namespaces. These were simple transformations from
netlink_capable to netlink_ns_capable.
The Altera driver conflict was simply code removal overlapping some
void pointer cast cleanups in net-next.
Filter out incoming multicast packages before applying their bitrate
to the rx bitrate station info field to prevent them from setting the
rx bitrate to the basic multicast rate.
Signed-off-by: Henning Rogge <hrogge@gmail.com>
And some code style changes in the function, and correct a typo in
comment.
Signed-off-by: Zhao, Gang <gamerh2o@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Add a bit in rx_status.vht_flags to let the low level driver
notify mac80211 about a beamformed packet. Propagate this
to the radiotap header.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
drivers/net/wireless/ath/ath9k/recv.c
drivers/net/wireless/mwifiex/pcie.c
Add missing update on the rx status vht flag of the last
data packet. Otherwise, cfg80211_calculate_bitrate_vht
may not consider the channel width resulting in wrong
calculation of the received bitrate.
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com>
Consider the following (relatively unlikely) scenario:
1) station goes to sleep while frames are buffered in driver
2) driver blocks wakeup (until no more frames are buffered)
3) station wakes up again
4) driver unblocks wakeup
In this case, the current mac80211 code will do the following:
1) WLAN_STA_PS_STA set
2) WLAN_STA_PS_DRIVER set
3) - nothing -
4) WLAN_STA_PS_DRIVER cleared
As a result, no frames will be delivered to the client, even
though it is awake, until it sends another frame to us that
triggers ieee80211_sta_ps_deliver_wakeup() in sta_ps_end().
Since we now take the PS spinlock, we can fix this while at
the same time removing the complexity with the pending skb
queue function. This was broken since my commit 50a9432daeec
("mac80211: fix powersaving clients races") due to removing
the clearing of WLAN_STA_PS_STA in the RX path.
While at it, fix a cleanup path issue when a station is
removed while the driver is still blocking its wakeup.
NAPI was originally added to mac80211 a long time ago (by John in
commit 4e6cbfd09c66 in July 2010), but then removed years later
(by Stanislaw in commit 30c97120c6c7 in February 2013). No driver
ever used it, so that was fine.
Now I'm adding support for NAPI to our driver, so add some code
to mac80211 again to support NAPI. John was originally wrapping
some (but not nearly all NAPI-related functions), but that doesn't
scale very well with the number of functions that are there, some
of which are even only inlines. Thus, instead of doing that, let
the drivers manage the NAPI struct, except for napi_add() which is
needed so mac80211 knows how to call napi_gro_receive().
Also remove some no longer needed definitions that were left when
NAPI support was removed.
Reviewed-by: Eyal Shapira <eyal@wizery.com>
This capabilities weren't propagated to the radiotap header.
We don't set here the VHT_KNOWN / MCS_HAVE flag because not
all the low level drivers will know how to properly flag
the frames, hence the low level driver will be in charge
of setting IEEE80211_RADIOTAP_MCS_HAVE_FEC,
IEEE80211_RADIOTAP_MCS_HAVE_STBC and / or
IEEE80211_RADIOTAP_VHT_KNOWN_STBC according to its
capabilities.
ieee80211_rx_status.flags is full. Define a new vht_flag
variable to be able to set more VHT related flags and make
room in flags.
Acked-by: Kalle Valo <kvalo@qca.qualcomm.com> [ath10k]
The purpose of this housekeeping is to make some room for
VHT flags. The radiotap vendor fields weren't in use.
Action, disassoc and deauth frames are bufferable, and as such don't
have the PM bit in the frame control field reserved which means we
need to react to the bit when receiving in such a frame.
Fix this by introducing a new helper ieee80211_is_bufferable_mmpdu()
and using it for the RX path that currently ignores the PM bit in
any non-data frames for doze->wake transitions, but listens to it in
all frames for wake->doze transitions, both of which are wrong.
Also use the new helper in the TX path to clean up the code.
A few places weren't checking that the frame passed to the
function actually has enough data even though the function
clearly documents it must have a payload byte. Make this
safer by changing the function to take an skb and checking
the length inside. The old version is preserved for now as
the rtl* drivers use it and don't have a correct skb.
Using an int with 0/1 is not very common, make the function
return a bool instead with the same values (false/true).
No need to assign the return value of prepare_for_handlers
to a variable if the only usage is to test it.
drivers/net/wireless/brcm80211/Kconfig
net/mac80211/util.c
Remove the unnecessary duplicate test of "if (skb) {"
when !CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS.
Remove now unnecessary __maybe_unused, neaten comment
Remove unnecessary parenthesis around align cast.
Substitute reference to deprecated compare_ether_addr
with ether_addr_equal (in the comment.)
[edit commit log slightly]
There's no reason for the variable to not be inside
the #ifdef, move it.
Use put_unaligned_le16 and put_unaligned_le32 for
mesh_path_error_tx and mesh_path_sel_frame_tx.
This adds generic cipher scheme support to mac80211, such schemes
are fully under control by the driver. On hw registration drivers
may specify additional HW ciphers with a scheme how these ciphers
have to be handled by mac80211 TX/RR. A cipher scheme specifies a
cipher suite value, a size of the security header to be added to
or stripped from frames and how the PN is to be verified on RX.
Signed-off-by: Max Stepanov <Max.Stepanov@intel.com>
Currently, frames that go into the reordering buffer are stored at
index ieee80211_sn_sub(sn, tid_rx->ssn) % tid_rx->buf_size.
The offset calculation to the starting sequence number (SSN) is
useless and just adds overhead so simply use sn % tid_rx->buf_size.
This means the reordering buffer will start to be filled somewhere
in the middle (at SSN % buf_size) and continue to get used from
there, but there's no reason to start from the beginning.
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
Multicast frames can't be transmitted as part of an aggregation
session (such a session couldn't even be set up) so don't try to
reorder them. Trying to do so would cause the reorder to stop
working correctly since multicast QoS frames (as transmitted by
the Aruba APs this was found with) would cause sequence number
confusion in the buffer.
Reported-by: Blaise Gassend <blaise@suitabletech.com>
net/wireless/reg.c
drivers/net/wireless/iwlwifi/pcie/drv.c
Implement the required procedures for mesh channel switching as defined
in the IEEE Std 802.11-2012 section 10.9.8.4.3 and also handle the CSA
and MCSP elements as followed:
* Add the function for updating the beacon and probe response frames
with CSA and MCSP elements during the period of switching to the new
channel. Both CSA and MCSP elements must be included in beacon and
probe response frames until the intended channel switch time.
* The ifmsh->csa_settings is set to NULL and the CSA and MCSP elements
will then be removed from the beacon or probe response frames once the
new channel is switched to.
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@cozybit.com>
Some devices may not be able to report A-MSDUs in
single buffers. Drivers for such devices were
forced to re-assemble A-MSDUs which would then
be eventually disassembled by mac80211. This could
lead to CPU cache thrashing and poor performance.
Since A-MSDU has a single sequence number all
subframes share it. This was in conflict with
retransmission/duplication recovery
(IEEE802.11-2012: 9.3.2.10).
Patch introduces a new flag that is meant to be
set for all individually reported A-MSDU subframes
except the last one. This ensures the
last_seq_ctrl is updated after the last subframe
is processed. If an A-MSDU is actually a duplicate
transmission all reported subframes will be
properly discarded.
[johannes: add braces that were missing even before]
If an Ad-Hoc node receives packets with the Cell ID or its own MAC
address as source address, it hits a WARN_ON in sta_info_insert_check()
With many packets, this can massively spam the logs. One way that this
can easily happen is through having Cisco APs in the area with rouge AP
detection and countermeasures enabled.
Such Cisco APs will regularly send fake beacons, disassoc and deauth
packets that trigger these warnings.
To fix this issue, drop such spoofed packets early in the rx path.
Reported-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
This function adds the channel switch announcement implementation for the
IBSS code. It is triggered by userspace (mac80211/cfg) or by external
channel switch announcement, which have to be adopted. Both CSAs in
beacons and action frames are supported. As for AP mode, the channel
switch is applied after some time. However in IBSS mode, the channel
switch IEs are generated in the kernel.
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
Add flags intended to report various auxiliary information
and introduce the NL80211_RXMGMT_FLAG_ANSWERED flag to report
that the frame was already answered by the device.
[REPLIED->ANSWERED, reword commit message]
This patch decouples the power save processing from the frame decryption
by running the decrypt rx handler after sta_process. In the case where
the decryption failed for some reason, the stack used to not process
the PM and MOREDATA bits for that frame. The stack now always performs
power save processing regardless of the decryption result. That means that
encrypted data frames and NULLFUNC frames are now handled in the same way
regarding power save processing, making the stack more robust.
Signed-off-by: Johan Almbladh <ja@anyfi.net>
The various components accessing the bitrates table must use consider
the used channel bandwidth to select only available rates or calculate
the bitrate correctly.
There are some rates in reduced bandwidth modes which can't be
represented as multiples of 500kbps, like 2.25 MBit/s in 5 MHz mode. The
standard suggests to round up to the next multiple of 500kbps, just do
that in mac80211 as well.
[make rate unsigned in ieee80211_add_tx_radiotap_header(), squash fix]
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Wireshark already defines radiotap channel flags for 5 and 10 MHz, so
just use them in Linux radiotap too. Furthermore, add rx status flags to
allow drivers to report when they received data on 5 or 10 MHz channels.
When per-chain signal information is available, don't add
the antenna field once but instead add a radiotap namespace
for each chain containing the chain/antenna number and the
signal strength on that chain.
The duplicate retransmission detection code in mac80211
erroneously attempts to do the check for every frame,
even frames that don't have a sequence control field or
that don't use it (QoS-Null frames.)
This is problematic because it causes the code to access
data beyond the end of the SKB and depending on the data
there will drop packets erroneously.
Correct the code to not do duplicate detection for such
frames.
I found this error while testing AP powersave, it lead
to retransmitted PS-Poll frames being dropped entirely
as the data beyond the end of the SKB was always zero.
Cc: stable@vger.kernel.org [all versions]
Do some cleanups in the cfg80211 SME APIs, which are
only used by mac80211.
Most of these functions get a frame passed, and there
isn't really any reason to export multiple functions
as cfg80211 can check the frame type instead, do that.
Additionally, the API functions have confusing names
like cfg80211_send_...() which was meant to indicate
that it sends an event to userspace, but gets a bit
confusing when there's both TX and RX and they're not
all clearly labeled.
