commit 7e2447075690860e2cea96b119fc9cadbaa7e83c upstream.
mac80211 doesn't handle shared skbs correctly at the moment. As a result
a possible resize can trigger a BUG in pskb_expand_head.
[ 676.030000] Kernel bug detected[#1]:
[ 676.030000] Cpu 0
[ 676.030000] $ 0 : 00000000 00000000 819662ff 00000002
[ 676.030000] $ 4 : 81966200 00000020 00000000 00000020
[ 676.030000] $ 8 : 819662e0 800043c0 00000002 00020000
[ 676.030000] $12 : 3b9aca00 00000000 00000000 00470000
[ 676.030000] $16 : 80ea2000 00000000 00000000 00000000
[ 676.030000] $20 : 818aa200 80ea2018 80ea2000 00000008
[ 676.030000] $24 : 00000002 800ace5c
[ 676.030000] $28 : 8199a000 8199bd20 81938f88 80f180d4
[ 676.030000] Hi : 0000026e
[ 676.030000] Lo : 0000757e
[ 676.030000] epc : 801245e4 pskb_expand_head+0x44/0x1d8
[ 676.030000] Not tainted
[ 676.030000] ra : 80f180d4 ieee80211_skb_resize+0xb0/0x114 [mac80211]
[ 676.030000] Status: 1000a403 KERNEL EXL IE
[ 676.030000] Cause : 10800024
[ 676.030000] PrId : 0001964c (MIPS 24Kc)
[ 676.030000] Modules linked in: mac80211_hwsim rt2800lib rt2x00soc rt2x00pci rt2x00lib mac80211 crc_itu_t crc_ccitt cfg80211 compat arc4 aes_generic deflate ecb cbc [last unloaded: rt2800pci]
[ 676.030000] Process kpktgend_0 (pid: 97, threadinfo=8199a000, task=81879f48, tls=00000000)
[ 676.030000] Stack : ffffffff 00000000 00000000 00000014 00000004 80ea2000 00000000 00000000
[ 676.030000] 818aa200 80f180d4 ffffffff 0000000a 81879f78 81879f48 81879f48 00000018
[ 676.030000] 81966246 80ea2000 818432e0 80f1a420 80203050 81814d98 00000001 81879f48
[ 676.030000] 81879f48 00000018 81966246 818432e0 0000001a 8199bdd4 0000001c 80f1b72c
[ 676.030000] 80203020 8001292c 80ef4aa2 7f10b55d 801ab5b8 81879f48 00000188 80005c90
[ 676.030000] ...
[ 676.030000] Call Trace:
[ 676.030000] [<801245e4>] pskb_expand_head+0x44/0x1d8
[ 676.030000] [<80f180d4>] ieee80211_skb_resize+0xb0/0x114 [mac80211]
[ 676.030000] [<80f1a420>] ieee80211_xmit+0x150/0x22c [mac80211]
[ 676.030000] [<80f1b72c>] ieee80211_subif_start_xmit+0x6f4/0x73c [mac80211]
[ 676.030000] [<8014361c>] pktgen_thread_worker+0xfac/0x16f8
[ 676.030000] [<8002ebe8>] kthread+0x7c/0x88
[ 676.030000] [<80008e0c>] kernel_thread_helper+0x10/0x18
[ 676.030000]
[ 676.030000]
[ 676.030000] Code: 24020001 10620005 2502001f <0200000d> 0804917a 00000000 2502001f 00441023 00531021
Fix this by making a local copy of shared skbs prior to mangeling them.
To avoid copying the skb unnecessarily move the skb_copy call below the
checks that don't need write access to the skb.
Also, move the assignment of nh_pos and h_pos below the skb_copy to point
to the correct skb.
It would be possible to avoid another resize of the copied skb by using
skb_copy_expand instead of skb_copy but that would make the patch more
complex. Also, shared skbs are a corner case right now, so the resize
shouldn't matter much.
Cc: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
In the function ieee80211_subif_start_xmit the logic related with
meshdrlen is under CONFIG_MAC80211_MESH macro, but in one place it isn't.
This is some update for this
Signed-off-by: Yuri Ershov <ext-yuri.ershov@nokia.com>
I just had the following:
WARNING: at drivers/net/wireless/iwlwifi/iwl-agn-tx.c:574 iwlagn_tx_skb+0x1576/0x15f0 [iwlagn]()
Call Trace:
<IRQ> [<ffffffff8105c5df>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8105c63a>] warn_slowpath_null+0x1a/0x20
[<ffffffffa0290b46>] iwlagn_tx_skb+0x1576/0x15f0 [iwlagn]
[<ffffffffa027076c>] iwl_mac_tx+0x5c/0x260 [iwlagn]
[<ffffffffa01bdf5b>] __ieee80211_tx+0x10b/0x1a0 [mac80211]
[<ffffffffa01bfb86>] ieee80211_tx_pending+0x186/0x2d0 [mac80211]
[<ffffffff81062ea5>] tasklet_action+0x125/0x130
[<ffffffff810634a6>] __do_softirq+0x106/0x270
[<ffffffff8100c09c>] call_softirq+0x1c/0x30
iwlagn 0000:02:00.0: Attempting to modify non-existing station 107
Note that 107 == 0x6b which is slab poison.
The reason is that mac80211 passed a freed station
pointer to mac80211, because as it happened iwlwifi
reset itself while mac80211 was disconnecting from
the network.
It turns out that we do take care to look up the
station pointer in ieee80211_tx_pending_skb, but
then don't use it, which obviously is a bug. Fix
this by removing the ieee80211_tx_h_sta handler
and assigning the station pointer directly.
When the driver or rate control requests starting
or stopping an aggregation session, that currently
causes a direct callback into the driver, which
could potentially cause locking problems. Also,
the functions need to be callable from contexts
that cannot sleep, and thus will interfere with
making the ampdu_action callback sleeping.
To address these issues, add a new work item for
each station that will process any start or stop
requests out of line.
Currently we allocate some memory for each TX
aggregation session and additionally keep a
state bitmap indicating the state it is in.
By using RCU to protect the pointer, moving
the state into the structure and some locking
trickery we can avoid locking when the TX agg
session is fully operational.
Also simplify the flags assignment into a single statement at the
end of ieee80211_beacon_get_tim.
Currently whenever rts thresold is set, every packet will use RTS
protection no matter its size exceeds the threshold or not. This is
due to a bug in the rts threshold check.
if (len > tx->local->hw.wiphy->rts_threshold) {
txrc.rts = rts = true;
Basically it is comparing an int (len) and a u32 (rts_threshold),
and the variable len is assigned as:
len = min_t(int, tx->skb->len + FCS_LEN,
tx->local->hw.wiphy->frag_threshold);
However, when frag_threshold is "-1", len is always "-1", which is
0xffffffff therefore rts is always set to true.
CC: stable@kernel.org
Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
The sta_cleanup timer is used to periodically expire buffered frames from the
tx buf. The timer is executing periodically, regardless of the need for it.
This is wasting resources.
Fix this simply by not restarting the sta_cleanup timer if the tx buffer was
empty. Restart the timer when there is some more tx-traffic.
Cc: Janne Ylälehto <janne.ylalehto@nokia.com>
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into merge
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ath5k/phy.c
drivers/net/wireless/iwlwifi/iwl-4965.c
drivers/net/wireless/iwlwifi/iwl-agn.c
drivers/net/wireless/iwlwifi/iwl-core.c
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/net/wireless/iwlwifi/iwl-tx.c
All other places except one in the TX path, which
has BHs disabled, and it also cannot be locked from
interrupts so disabling IRQs is not necessary.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
BIP (part of IEEE 802.11w) is only supposed to be used with
group-addressed frames. We ended up picking it as a default mechanism
for every management whenever we did not have a STA entry for the
destination (e.g., for Probe Response to a STA that is not
associated). While the extra MMIE in the end of management frames
should not break frames completed in most cases, there is no point in
doing this. Fix key selection to pick the default management key only
if the frame is sent to multicast/broadcast address and the frame is a
robust management frame.
Signed-off-by: Jouni Malinen <j@w1.fi>
"mac80211: fix skb buffering issue" still left a race
between enabling the hardware queues and the virtual
interface queues. In hindsight it's totally obvious
that enabling the netdev queues for a hardware queue
when the hardware queue is enabled is wrong, because
it could well possible that we can fill the hw queue
with packets we already have pending. Thus, we must
only enable the netdev queues once all the pending
packets have been processed and sent off to the device.
In testing, I haven't been able to trigger this race
condition, but it's clearly there, possibly only when
aggregation is being enabled.
Cc: stable@kernel.org
We don't need "sdata" any more after:
d84f323477260e773d5317ad7cbe50f76115cb47
mac80211: remove dev_hold/put calls
Many drivers would like to sleep during station
addition and removal, and currently have a high
complexity there from not being able to.
This introduces two new callbacks sta_add() and
sta_remove() that drivers can implement instead
of using sta_notify() and that can sleep, and
the new sta_add() callback is also allowed to
fail.
The reason we didn't do this previously is that
the IBSS code wants to insert stations from the
RX path, which is a tasklet, so cannot sleep.
This patch will keep the station allocation in
that path, but moves adding the station to the
driver out of line. Since the addition can now
fail, we can have IBSS peer structs the driver
rejected -- in that case we still talk to the
station but never tell the driver about it in
the control.sta pointer. If there will ever be
a driver that has a low limit on the number of
stations and that cannot talk to any stations
that are not known to it, we need to do come up
with a new strategy of handling larger IBSSs,
maybe quicker expiry or rejecting peers.
Upstream radiotap has adopted the namespace
proposal David Young made and I then took care
of, for which I had adapted the radiotap parser
as a library outside the kernel. This brings
the in-kernel parser up to speed.
When injecting frames, mac80211 currently looks for the first AP
interface that matches the source address of the injected frame.
This breaks when such a frame is directed at a STA that has been moved
to a VLAN. This patch fixes it by using sta_info_get_bss instead of
sta_info_get, which also finds stations belonging to a VLAN interface
of the same BSS as the AP interface.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
When an injected frame gets buffered for a powersave STA or filtered
and retransmitted, mac80211 attempts to parse the radiotap header
again, which doesn't work because it's gone at that point.
This patch adds a new flag for checking the availability of a radiotap
header, so that it only attempts to parse it once, reusing the tx info
on the next call to ieee80211_tx().
This fixes severe issues with rekeying in AP mode.
What a stupid mistake. In
commit 813d76694043d00b59475baa1fbfaf54a2eb7fad
Author: Johannes Berg <johannes@sipsolutions.net>
Date: Sun Jan 17 01:47:58 2010 +0100
mac80211: move control.hw_key assignment
I inserted code testing the wrong flags field,
which means that the test is almost always true
(it's really testing for the peer's WMM support)
and thus the later parts of the stack assume hw
crypto will be done even if that's not true.
Obviously, that broke software crypto. Maxim
said so specifically, and Jochen probably uses
some cipher that iwl3945 doesn't support in
hardware, which might also explain that Maxim
reports that even hw crypto is broken.
Fix this to test the right flags field.
Reported-by: Maxim Levitsky <maximlevitsky@gmail.com>
Reported-by: Jochen Friedrich <jochen@scram.de>
Pavel Roskin reported a crash in ieee80211_tx_h_select_key():
http://marc.info/?l=linux-wireless&m=126419655108528&w=2
This is a regression from patch "mac80211: move control.hw_key assignment".
Fix it as suggested by Johannes, adding an else statement to make sure
that tx->key is not accessed when it's null.
Compile-tested only.
Reported-by: Pavel Roskin <proski@gnu.org>
Signed-off-by: Kalle Valo <kalle.valo@iki.fi>
Tested-by: Bob Copeland <me@bobcopeland.com>
ieee80211_tx_h_select_key might decide that a frame
need not be encrypted at all, in which case it will
clear tx->key. In that case it may crash if a key
was previously selected, e.g. as the default key.
This is also due to my patch
In an earlier commit,
mac80211: disable software retry for now
Pavel Roskin reported a problem that seems to be due to
software retry of already transmitted frames. It turns
out that we've never done that correctly, but due to
some recent changes it now crashes in the TX code. I've
added a comment in the patch that explains the problem
better and also points to possible solutions -- which
I can't implement right now.
I disabled software retry of failed/filtered frames
because it was broken. With the work of the previous
patches, it now becomes fairly easy to re-enable it
by adding a flag indicating that the frame shouldn't
be modified, but still running it through the transmit
handlers to populate the control information.
When mac80211 asks a driver to encrypt a frame, it
must assign the control.hw_key pointer for it to
know which key to use etc. Currently, mac80211 does
this whenever it would software-encrypt a frame.
Change the logic of this code to assign the hw_key
pointer when selecting the key, and later check it
when deciding whether to encrypt the frame or let
it be encrypted by the hardware. This allows us to
later simply skip the encryption function since it
no longer modifies the TX control.
There's no value in setting a flag that will
never be checked after this point, this seems
to be legacy code -- I think previously the
flag was used to check whether to encrypt the
frame or not. Now, however, the flag need not
be set, and setting it actually interferes if
the frame will be processed again later.
This TX handler is used only for assigning the
station pointer in the control information, so
give it a better name. Also move it before rate
control.
To make U-APSD client mode effective, we must not wake up from dynamic power
save when transmitting frames. So if dynamic power save is enabled, it needs
check the queue the transmitted packet is in and decide if we need to wake
up or not.
In a perfect world, where all packets would have correct QoS tags, U-APSD
enabled queues should not trigger wakeup from power save. But in the real
world, where very few packets have correct QoS tags, this won't work. For
example, if only voip class has U-APSD enabled and we send a packet in voip
class, but the packets we receive are in best effort class, we would receive
the packets with the legacy power save method. And that would increase
latencies too much from a voip application point of view.
The workaround is to enable U-APSD for all qeueus and still use dynamic ps
wakeup for all other queues except voip. That way we can still save power
with a voip application and not sacrifice latency. Normal traffic (in
background, best effort or video class) would still trigger wakeup from
dynamic power save.
Signed-off-by: Kalle Valo <kalle.valo@nokia.com>
Currently dynamic ps check is in ieee80211_xmit(), but it's cleaner
to have a separate tx handler for this. Also this is a prerequisite for
U-APSD client mode which needs to know the queue frame is in.
Also need_dynamic_ps() function is embedded to the tx handler.
No functional changes expect that the code is run in a later phase than
originally.
If frames are transmitted on 4-addr ap vlan interfaces with no station,
they end up being transmitted unencrypted, even if the ap interface
uses WPA. This patch add some sanity checking to make sure that this
does not happen.
Certain type of hardware, for example wl1251 and wl1271, need a template
for the Probe Request. Create a function ieee80211_probereq_get() which
creates the template and drivers send it to hardware.
Some hardware, for example wl1251 and wl1271, handle the transmission
of power save related frames in hardware, but the driver is responsible
for creating the templates. It's better to create the templates in mac80211,
that way all drivers can benefit from this.
Add two new functions, ieee80211_pspoll_get() and ieee80211_nullfunc_get()
which drivers need to call to get the frame. Drivers are also responsible
for updating the templates after each association.
Also new struct ieee80211_hdr_3addr is added to ieee80211.h to make it
easy to calculate length of the Nullfunc frame.
Extend struct cfg80211_bitrate_mask to actually use a bitfield mask
instead of just a single fixed or maximum rate index. This change
itself does not modify the behavior (except for debugfs files), but it
prepares cfg80211 and mac80211 for a new nl80211 command for setting
which rates can be used in TX rate control.
Since frames are now going through the rate control algorithm
unconditionally, the internal IEEE80211_TX_INTFL_RCALGO flag can now
be removed. The RC implementations can use the rate_idx_mask value to
optimize their behavior if only a single rate is enabled.
The old max_rate_idx in struct ieee80211_tx_rate_control is maintained
(but commented as deprecated) for backwards compatibility with existing
RC implementations. Once these implementations have been updated to
use the more generic rate_idx_mask, the max_rate_idx value can be
removed.
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
If the basic rate set is configured to not include the lowest rate
(e.g., basic rate set = 6, 12, 24 Mbps in IEEE 802.11g mode), the AP
should not send out broadcast frames at 1 Mbps. This type of
configuration can be used to optimize channel usage in cases where
there is no need for backwards compatibility with IEEE 802.11b-only
devices.
In AP mode, mac80211 was unconditionally using the lowest rate for
Beacon frames and similarly, with all rate control algorithms that use
rate_control_send_low(), the lowest rate ended up being used for all
broadcast frames (and all unicast frames that are sent before
association). Change this to take into account the basic rate
configuration in AP mode, i.e., use the lowest rate in the basic rate
set instead of the lowest supported rate when selecting the rate.
net/mac80211/iface.c
Since I removed the master netdev, we've been
keeping internal queues only, and even before
that we never told the networking stack above
the virtual interfaces about congestion. This
means that packets are queued in mac80211 and
the upper layers never know, possibly leading
to memory exhaustion and other problems.
This patch makes all interfaces multiqueue and
uses ndo_select_queue to put the packets into
queues per AC. Additionally, when the driver
stops a queue, we now stop all corresponding
queues for the virtual interfaces as well.
The injection case will use VO by default for
non-data frames, and BE for data frames, but
downgrade any data frames according to ACM. It
needs to be fleshed out in the future to allow
chosing the queue/AC in radiotap.
Reported-by: Lennert Buytenhek <buytenh@marvell.com>
Cc: stable@kernel.org [2.6.32]
drivers/net/wireless/libertas/scan.c
Instead of always using netif_running(sdata->dev)
use ieee80211_sdata_running(sdata) now which is
just an inline containing netif_running() for now.
When mac80211 suspends it calls a driver's suspend callback
as a last step and after that the driver assumes no calls will
be made to it until we resume and its start callback is kicked.
If such calls are made, however, suspend can end up throwing
hardware in an unexpected state and making the device unusable
upon resume.
Fix this by preventing mac80211 to schedule dynamic_ps_disable_work
by checking for when mac80211 starts to suspend and starts
quiescing. Frames should be allowed to go through though as
that is part of the quiescing steps and we do not flush the
mac80211 workqueue since it was already done towards the
beginning of suspend cycle.
The other mac80211 issue will be hanled in the next patch.
For further details see refer to the thread:
http://marc.info/?t=126144866100001&r=1&w=2
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
For bluetooth 3, we will most likely not have
a netdev for a virtual interface (sdata), so
prepare for that by reducing the reliance on
having a netdev. This patch moves the name
and address fields into the sdata struct and
uses them from there all over. Some work is
needed to keep them sync'ed, but that's not
a lot of work and in slow paths anyway.
In doing so, this also reduces the number of
pointer dereferences in many places, because
of things like sdata->dev->dev_addr becoming
sdata->vif.addr.
The station management currently uses the virtual
interface, but you cannot add the same station to
multiple virtual interfaces if you're communicating
with it in multiple ways.
This restriction should be lifted so that in the
future we can, for instance, support bluetooth 3
with an access point that mac80211 is already
associated to.
We can do that by requiring all sta_info_get users
to provide the virtual interface and making the RX
code aware that an address may match more than one
station struct. Thanks to the previous patches this
one isn't all that large and except for the RX and
TX status paths changes has low complexity.
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
Right now all frames mac80211 hands to the driver
have the IEEE80211_TX_CTL_REQ_TX_STATUS flag set to
request TX status. This isn't really necessary, only
the injected frames need TX status (the latter for
hostapd) so move setting this flag.
The rate control algorithms also need TX status, but
they don't require it.
Also, rt2x00 uses that bit for its own purposes and
seems to require it being set for all frames, but
that can be fixed in rt2x00.
This doesn't really change anything for any drivers
but in the future drivers using hw-rate control may
opt to not report TX status for frames that don't
have the IEEE80211_TX_CTL_REQ_TX_STATUS flag set.
Acked-by: Ivo van Doorn <IvDoorn@gmail.com> [rt2x00 bits]
It's very likely that not many devices will support
four-address mode in station or AP mode so introduce
capability bits for both modes, set them in mac80211
and check them when userspace tries to use the mode.
Also, keep track of 4addr in cfg80211 (wireless_dev)
and not in mac80211 any more. mac80211 can also be
improved for the VLAN case by not looking at the
4addr flag but maintaining the station pointer for
it correctly. However, keep track of use_4addr for
station mode in mac80211 to avoid all the derefs.
Since the flags moved into skb->cb, there's no
longer a need to have the encrypt bool passed
into the function, anyone who requires it set
to 0 (false) can just set the flag directly.
Some devices implement the entire rate control in
firmware in some way, like wl1271 or like iwlwifi
which does some things in software but not a lot.
Therefore generic software rate control is rather
useless for them and just adds avoidable overhead
to the transmit path.
It's fairly simple to let drivers indicate that
they do not need rate control, but they need to
fulfil a number of conditions that we encode in
WARN_ONs.
The netdev broadcast address cannot change from
all-ones so there's no need to use it; we can
instead hard-code it. Since we already have an
instance in tkip.c, which will be shared if it
is marked static const, doing this reduces text
size at no data/bss cost.
The real motivation for this is, of course, the
desire to get rid of almost all uses of netdevs
in mac80211 so that auditing their use becomes
easier.
If we move the rcu sections a little, there's
no need to touch the device refcount.
BSSID is now set to the TA.
Signed-off-by: Rui Paulo <rpaulo@gmail.com>
Signed-off-by: Javier Cardona <javier@cozybit.com>
Reviewed-by: Andrey Yurovsky <andrey@cozybit.com>
Tested-by: Brian Cavagnolo <brian@cozybit.com>
In some situations it might be useful to run a network with an
Access Point and multiple clients, but with each client bridged
to a network behind it. For this to work, both the client and the
AP need to transmit 4-address frames, containing both source and
destination MAC addresses.
With this patch, you can configure a client to communicate using
only 4-address frames for data traffic.
On the AP side you can enable 4-address frames for individual
clients by isolating them in separate AP VLANs which are configured
in 4-address mode.
Such an AP VLAN will be limited to one client only, and this client
will be used as the destination for all traffic on its interface,
regardless of the destination MAC address in the packet headers.
The advantage of this mode compared to regular WDS mode is that it's
easier to configure and does not require a static list of peer MAC
addresses on any side.
Some devices require that all frames to a station
are flushed when that station goes into powersave
mode before being able to send frames to that
station again when it wakes up or polls -- all in
order to avoid reordering and too many or too few
frames being sent to the station when it polls.
Normally, this is the case unless the station
goes to sleep and wakes up very quickly again.
But in that case, frames for it may be pending
on the hardware queues, and thus races could
happen in the case of multiple hardware queues
used for QoS/WMM. Normally this isn't a problem,
but with the iwlwifi mechanism we need to make
sure the race doesn't happen.
This makes mac80211 able to cope with the race
with driver help by a new WLAN_STA_PS_DRIVER
per-station flag that can be controlled by the
driver and tells mac80211 whether it can transmit
frames or not. This flag must be set according to
very specific rules outlined in the documentation
for the function that controls it.
When we buffer new frames for the station, we
normally set the TIM bit right away, but while
the driver has blocked transmission to that sta
we need to avoid that as well since we cannot
respond to the station if it wakes up due to the
TIM bit. Once the driver unblocks, we can set
the TIM bit.
Similarly, when the station just wakes up, we
need to wait until all other frames are flushed
before we can transmit frames to that station,
so the same applies here, we need to wait for
the driver to give the OK.
The multi-line code in this macro wasn't wrapped
in do {} while (0) so we cannot use it in an if()
branch safely in the future -- fix that.
When mac80211 is asked to buffer multicast frames
in AP mode, it will not set the flag indicating
that the frames should be sent after the DTIM
beacon for those frames buffered in software. Fix
this little inconsistency by always setting that
flag in the buffering code path.
