path: root/net/mac80211/tx.c
2011-02-07mac80211: fix the skb cloned check in the tx pathFelix Fietkau
Using skb_header_cloned to check if it's safe to write to the skb is not enough - mac80211 also touches the tailroom of the skb. Initially this check was only used to increase a counter, however this commit changed the code to also skip skb data reallocation if no extra head/tailroom was needed: commit 4cd06a344db752f513437138953af191cbe9a691 mac80211: skip unnecessary pskb_expand_head calls It added a regression at least with iwl3945, which is fixed by this patch. Reported-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Tested-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-25mac80211: fix a crash in ieee80211_beacon_get_tim on change_interfaceFelix Fietkau
Some drivers (e.g. ath9k) do not always disable beacons when they're supposed to. When an interface is changed using the change_interface op, the mode specific sdata part is in an undefined state and trying to get a beacon at this point can produce weird crashes. To fix this, add a check for ieee80211_sdata_running before using anything from the sdata. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: net/bluetooth/Makefile
2011-01-04mac80211: Fix mesh portal communication with other mesh nodes.Joel A Fernandes
Fixed a bug where if a mesh interface has a different MAC address from its bridge interface, then it would not be able to send data traffic to any other mesh node. This also adds support for communication between mesh nodes and external bridged nodes by using a 6 address format if the source is a node within the mesh and the destination is an external node proxied by a mesh portal. Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22mac80211: add throughput based LED blink triggerJohannes Berg
iwlwifi and other drivers like to blink their LED based on throughput. Implement this generically in mac80211, based on a throughput table the driver specifies. That way, drivers can set the blink frequencies depending on their desired behaviour and max throughput. All the drivers need to do is provide an LED class device, best with blink hardware offload. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-20mac80211: fix potentially redundant skb data copyingFelix Fietkau
When an skb is shared, it needs to be duplicated, along with its data buffer. If the skb does not have enough headroom, using skb_copy might cause the data buffer to be copied twice (once by skb_copy and once by pskb_expand_head). Fix this by using skb_clone initially and letting ieee80211_skb_resize sort out the rest. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-20mac80211: skip unnecessary pskb_expand_head callsFelix Fietkau
If the skb is not cloned and we don't need any extra headroom, there is no point in reallocating the skb head. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-20mac80211: fix initialization of skb->cb in ieee80211_subif_start_xmitFelix Fietkau
The change 'mac80211: Fix BUG in pskb_expand_head when transmitting shared skbs' added a check for copying the skb if it's shared, however the tx info variable still points at the cb of the old skb Signed-off-by: Felix Fietkau <nbd@openwrt.org> Acked-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-20mac80211: Remove unused third address from mesh address extension header.Javier Cardona
The Mesh Control header only includes 0, 1 or 2 addresses. If there is one address, it should be interpreted as Address 4. If there are 2, they are interpreted as Addresses 5 and 6 (Address 4 being the 4th address in the 802.11 header). The address extension used to hold up to 3 addresses instead of the current 2. I'm not sure which draft version changed this, but it is very unlikely that it will change again given the state of the approval process of this draft. See section 7.1.3.6.3 in current draft (8.0). Also, note that the extra address that I'm removing was not being used, so this change has no effect on over-the-air frame formats. But I thought I better remove it before someone does start using it. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-20mac80211: Let userspace enable and configure vendor specific path selection.Javier Cardona
Userspace will now be allowed to toggle between the default path selection algorithm (HWMP, implemented in the kernel), and a vendor specific alternative. Also in the same patch, allow userspace to add information elements to mesh beacons. This is accordance with the Extensible Path Selection Framework specified in version 7.0 of the 802.11s draft. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-13mac80211: support separate default keysJohannes Berg
Add support for split default keys (unicast and multicast) in mac80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-08Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ath9k.h drivers/net/wireless/ath/ath9k/main.c drivers/net/wireless/ath/ath9k/xmit.c
2010-12-08mac80211: Fix BUG in pskb_expand_head when transmitting shared skbsHelmut Schaa
mac80211 doesn't handle shared skbs correctly at the moment. As a result a possible resize can trigger a BUG in pskb_expand_head. [ 676.030000] Kernel bug detected[#1]: [ 676.030000] Cpu 0 [ 676.030000] $ 0 : 00000000 00000000 819662ff 00000002 [ 676.030000] $ 4 : 81966200 00000020 00000000 00000020 [ 676.030000] $ 8 : 819662e0 800043c0 00000002 00020000 [ 676.030000] $12 : 3b9aca00 00000000 00000000 00470000 [ 676.030000] $16 : 80ea2000 00000000 00000000 00000000 [ 676.030000] $20 : 818aa200 80ea2018 80ea2000 00000008 [ 676.030000] $24 : 00000002 800ace5c [ 676.030000] $28 : 8199a000 8199bd20 81938f88 80f180d4 [ 676.030000] Hi : 0000026e [ 676.030000] Lo : 0000757e [ 676.030000] epc : 801245e4 pskb_expand_head+0x44/0x1d8 [ 676.030000] Not tainted [ 676.030000] ra : 80f180d4 ieee80211_skb_resize+0xb0/0x114 [mac80211] [ 676.030000] Status: 1000a403 KERNEL EXL IE [ 676.030000] Cause : 10800024 [ 676.030000] PrId : 0001964c (MIPS 24Kc) [ 676.030000] Modules linked in: mac80211_hwsim rt2800lib rt2x00soc rt2x00pci rt2x00lib mac80211 crc_itu_t crc_ccitt cfg80211 compat arc4 aes_generic deflate ecb cbc [last unloaded: rt2800pci] [ 676.030000] Process kpktgend_0 (pid: 97, threadinfo=8199a000, task=81879f48, tls=00000000) [ 676.030000] Stack : ffffffff 00000000 00000000 00000014 00000004 80ea2000 00000000 00000000 [ 676.030000] 818aa200 80f180d4 ffffffff 0000000a 81879f78 81879f48 81879f48 00000018 [ 676.030000] 81966246 80ea2000 818432e0 80f1a420 80203050 81814d98 00000001 81879f48 [ 676.030000] 81879f48 00000018 81966246 818432e0 0000001a 8199bdd4 0000001c 80f1b72c [ 676.030000] 80203020 8001292c 80ef4aa2 7f10b55d 801ab5b8 81879f48 00000188 80005c90 [ 676.030000] ... [ 676.030000] Call Trace: [ 676.030000] [<801245e4>] pskb_expand_head+0x44/0x1d8 [ 676.030000] [<80f180d4>] ieee80211_skb_resize+0xb0/0x114 [mac80211] [ 676.030000] [<80f1a420>] ieee80211_xmit+0x150/0x22c [mac80211] [ 676.030000] [<80f1b72c>] ieee80211_subif_start_xmit+0x6f4/0x73c [mac80211] [ 676.030000] [<8014361c>] pktgen_thread_worker+0xfac/0x16f8 [ 676.030000] [<8002ebe8>] kthread+0x7c/0x88 [ 676.030000] [<80008e0c>] kernel_thread_helper+0x10/0x18 [ 676.030000] [ 676.030000] [ 676.030000] Code: 24020001 10620005 2502001f <0200000d> 0804917a 00000000 2502001f 00441023 00531021 Fix this by making a local copy of shared skbs prior to mangeling them. To avoid copying the skb unnecessarily move the skb_copy call below the checks that don't need write access to the skb. Also, move the assignment of nh_pos and h_pos below the skb_copy to point to the correct skb. It would be possible to avoid another resize of the copied skb by using skb_copy_expand instead of skb_copy but that would make the patch more complex. Also, shared skbs are a corner case right now, so the resize shouldn't matter much. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-06mac80211: Update last_tx_rate only for data framesHelmut Schaa
The last_tx_rate field was also updated for non-data frames that are often sent with a lower rate (for example management frames at 1 Mbps). This is confusing when the data rate is actually much higher. Hence, only update the last_tx_rate field with tx rate information gathered from last data frames. If the rate control algorithm filled in txrc.reported_rate we don't need to verify this information. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-02Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
2010-11-29mac80211: Fix frame injection using non-AP vifJouni Malinen
In order for frame injection to work properly for some use cases (e.g., finding the station entry and keys for encryption), mac80211 needs to find the correct sdata entry. This works when the main vif is in AP mode, but commit a2c1e3dad516618cb0fbfb1a62c36d0b0744573a broke this particular use case for station main vif. While this type of injection is quite unusual operation, it has some uses and we should fix it. Do this by changing the monitor vif sdata selection to allow station vif to be selected instead of limiting it to just AP vifs. We still need to skip some iftypes to avoid selecting unsuitable vif for injection. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mac80211: add support for setting the ad-hoc multicast rateFelix Fietkau
2010-11-16mac80211: support hardware TX fragmentation offloadArik Nemtsov
The lower driver is notified when the fragmentation threshold changes and upon a reconfig of the interface. If the driver supports hardware TX fragmentation, don't fragment packets in the stack. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06cfg80211/mac80211: allow per-station GTKsJohannes Berg
This adds API to allow adding per-station GTKs, updates mac80211 to support it, and also allows drivers to remove a key from hwaccel again when this may be necessary due to multiple GTKs. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05mac80211: fix for WDS interfacesBill Jordan
Initialize the rate table for WDS interfaces, and add cases to allow WDS packets to pass the xmit and receive tests. Signed-off-by: Bill Jordan <bjordan@rajant.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-14mac80211: Fix dangling pointer in ieee80211_xmitSteve deRosier
hdr pointer is left dangling after call to ieee80211_skb_resize. This can cause guards around mesh path selection to fail. Signed-off-by: Steve deRosier <steve@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-27mac80211: use subqueue helpersJohannes Berg
There are subqueue helpers so that we don't need to get the TX queue and then wake/stop it, use those helpers. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-27mac80211: allow changing port control protocolJohannes Berg
Some vendor specified mechanisms for 802.1X-style functionality use a different protocol than EAP (even if EAP is vendor-extensible). Support this in mac80211 via the cfg80211 API for it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-27mac80211: allow vendor specific cipher suitesJohannes Berg
Allow drivers to specify their own set of cipher suites to advertise vendor-specific ciphers. The driver is then required to implement hardware crypto offload for it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-25mac80211: fix warning for un-used parameterWey-Yi Guy
mesh_hdr only used when CONFIG_MAC80211_MESH is defined Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-25net/mac80211: Use wiphy_<level>Joe Perches
Standardize logging messages from printk(KERN_<level> "%s: " fmt , wiphy_name(foo), args); to wiphy_<level>(foo, fmt, args); Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-16mac80211: use cipher suite selectorsJohannes Berg
Currently, mac80211 translates the cfg80211 cipher suite selectors into ALG_* values. That isn't all too useful, and some drivers benefit from the distinction between WEP40 and WEP104 as well. Therefore, convert it all to use the cipher suite selectors. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-28mac80211: Put some code under MESH macroYuri Ershov
In the function ieee80211_subif_start_xmit the logic related with meshdrlen is under CONFIG_MAC80211_MESH macro, but in one place it isn't. This is some update for this Signed-off-by: Yuri Ershov <ext-yuri.ershov@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-26mac80211: fix sta assignmentJohannes Berg
I just had the following: WARNING: at drivers/net/wireless/iwlwifi/iwl-agn-tx.c:574 iwlagn_tx_skb+0x1576/0x15f0 [iwlagn]() Call Trace: <IRQ> [<ffffffff8105c5df>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8105c63a>] warn_slowpath_null+0x1a/0x20 [<ffffffffa0290b46>] iwlagn_tx_skb+0x1576/0x15f0 [iwlagn] [<ffffffffa027076c>] iwl_mac_tx+0x5c/0x260 [iwlagn] [<ffffffffa01bdf5b>] __ieee80211_tx+0x10b/0x1a0 [mac80211] [<ffffffffa01bfb86>] ieee80211_tx_pending+0x186/0x2d0 [mac80211] [<ffffffff81062ea5>] tasklet_action+0x125/0x130 [<ffffffff810634a6>] __do_softirq+0x106/0x270 [<ffffffff8100c09c>] call_softirq+0x1c/0x30 iwlagn 0000:02:00.0: Attempting to modify non-existing station 107 Note that 107 == 0x6b which is slab poison. The reason is that mac80211 passed a freed station pointer to mac80211, because as it happened iwlwifi reset itself while mac80211 was disconnecting from the network. It turns out that we do take care to look up the station pointer in ieee80211_tx_pending_skb, but then don't use it, which obviously is a bug. Fix this by removing the ieee80211_tx_h_sta handler and assigning the station pointer directly. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-14mac80211: make TX aggregation start/stop request asyncJohannes Berg
When the driver or rate control requests starting or stopping an aggregation session, that currently causes a direct callback into the driver, which could potentially cause locking problems. Also, the functions need to be callable from contexts that cannot sleep, and thus will interfere with making the ampdu_action callback sleeping. To address these issues, add a new work item for each station that will process any start or stop requests out of line. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-14mac80211: use RCU for TX aggregationJohannes Berg
Currently we allocate some memory for each TX aggregation session and additionally keep a state bitmap indicating the state it is in. By using RCU to protect the pointer, moving the state into the structure and some locking trickery we can avoid locking when the TX agg session is fully operational. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-07mac80211: set IEEE80211_TX_CTL_FIRST_FRAGMENT for beaconsJohn W. Linville
Also simplify the flags assignment into a single statement at the end of ieee80211_beacon_get_tim. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-27mac80211: fix rts threshold checkShanyu Zhao
Currently whenever rts thresold is set, every packet will use RTS protection no matter its size exceeds the threshold or not. This is due to a bug in the rts threshold check. if (len > tx->local->hw.wiphy->rts_threshold) { txrc.rts = rts = true; } Basically it is comparing an int (len) and a u32 (rts_threshold), and the variable len is assigned as: len = min_t(int, tx->skb->len + FCS_LEN, tx->local->hw.wiphy->frag_threshold); However, when frag_threshold is "-1", len is always "-1", which is 0xffffffff therefore rts is always set to true. CC: stable@kernel.org Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-19mac80211: Prevent running sta_cleanup timer unnecessarilyJuuso Oikarinen
The sta_cleanup timer is used to periodically expire buffered frames from the tx buf. The timer is executing periodically, regardless of the need for it. This is wasting resources. Fix this simply by not restarting the sta_cleanup timer if the tx buffer was empty. Restart the timer when there is some more tx-traffic. Cc: Janne Ylälehto <janne.ylalehto@nokia.com> Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-08Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into merge Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c drivers/net/wireless/iwlwifi/iwl-4965.c drivers/net/wireless/iwlwifi/iwl-agn.c drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/iwlwifi/iwl-core.h drivers/net/wireless/iwlwifi/iwl-tx.c
2010-04-07mac80211: remove irq disabling for sta lockJohannes Berg
All other places except one in the TX path, which has BHs disabled, and it also cannot be locked from interrupts so disabling IRQs is not necessary. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-31mac80211: Fix BIP to be used only with group-addressed framesJouni Malinen
BIP (part of IEEE 802.11w) is only supposed to be used with group-addressed frames. We ended up picking it as a default mechanism for every management whenever we did not have a STA entry for the destination (e.g., for Probe Response to a STA that is not associated). While the extra MMIE in the end of management frames should not break frames completed in most cases, there is no point in doing this. Fix key selection to pick the default management key only if the frame is sent to multicast/broadcast address and the frame is a robust management frame. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-30mac80211: move netdev queue enabling to correct spotJohannes Berg
"mac80211: fix skb buffering issue" still left a race between enabling the hardware queues and the virtual interface queues. In hindsight it's totally obvious that enabling the netdev queues for a hardware queue when the hardware queue is enabled is wrong, because it could well possible that we can fill the hw queue with packets we already have pending. Thus, we must only enable the netdev queues once all the pending packets have been processed and sent off to the device. In testing, I haven't been able to trigger this race condition, but it's clearly there, possibly only when aggregation is being enabled. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-24mac80211: remove unneed variable from ieee80211_tx_pending()Dan Carpenter
We don't need "sdata" any more after: d84f323477260e773d5317ad7cbe50f76115cb47 mac80211: remove dev_hold/put calls Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-08mac80211: allow station add/remove to sleepJohannes Berg
Many drivers would like to sleep during station addition and removal, and currently have a high complexity there from not being able to. This introduces two new callbacks sta_add() and sta_remove() that drivers can implement instead of using sta_notify() and that can sleep, and the new sta_add() callback is also allowed to fail. The reason we didn't do this previously is that the IBSS code wants to insert stations from the RX path, which is a tasklet, so cannot sleep. This patch will keep the station allocation in that path, but moves adding the station to the driver out of line. Since the addition can now fail, we can have IBSS peer structs the driver rejected -- in that case we still talk to the station but never tell the driver about it in the control.sta pointer. If there will ever be a driver that has a low limit on the number of stations and that cannot talk to any stations that are not known to it, we need to do come up with a new strategy of handling larger IBSSs, maybe quicker expiry or rejecting peers. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-08wireless: update radiotap parserJohannes Berg
Upstream radiotap has adopted the namespace proposal David Young made and I then took care of, for which I had adapted the radiotap parser as a library outside the kernel. This brings the in-kernel parser up to speed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-01mac80211: fix sta lookup with AP VLAN interfaces and injected framesFelix Fietkau
When injecting frames, mac80211 currently looks for the first AP interface that matches the source address of the injected frame. This breaks when such a frame is directed at a STA that has been moved to a VLAN. This patch fixes it by using sta_info_get_bss instead of sta_info_get, which also finds stations belonging to a VLAN interface of the same BSS as the AP interface. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-01mac80211: fix monitor mode tx radiotap header handlingFelix Fietkau
When an injected frame gets buffered for a powersave STA or filtered and retransmitted, mac80211 attempts to parse the radiotap header again, which doesn't work because it's gone at that point. This patch adds a new flag for checking the availability of a radiotap header, so that it only attempts to parse it once, reusing the tx info on the next call to ieee80211_tx(). This fixes severe issues with rekeying in AP mode. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-25mac80211: fix sw cryptoJohannes Berg
What a stupid mistake. In commit 813d76694043d00b59475baa1fbfaf54a2eb7fad Author: Johannes Berg <johannes@sipsolutions.net> Date: Sun Jan 17 01:47:58 2010 +0100 mac80211: move control.hw_key assignment I inserted code testing the wrong flags field, which means that the test is almost always true (it's really testing for the peer's WMM support) and thus the later parts of the stack assume hw crypto will be done even if that's not true. Obviously, that broke software crypto. Maxim said so specifically, and Jochen probably uses some cipher that iwl3945 doesn't support in hardware, which might also explain that Maxim reports that even hw crypto is broken. Fix this to test the right flags field. Reported-by: Maxim Levitsky <maximlevitsky@gmail.com> Reported-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-23mac80211: fix tx select key null pointer crash with hostapdKalle Valo
Pavel Roskin reported a crash in ieee80211_tx_h_select_key(): http://marc.info/?l=linux-wireless&m=126419655108528&w=2 This is a regression from patch "mac80211: move control.hw_key assignment". Fix it as suggested by Johannes, adding an else statement to make sure that tx->key is not accessed when it's null. Compile-tested only. Reported-by: Pavel Roskin <proski@gnu.org> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Tested-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-22mac80211: add missing key checkJohannes Berg
ieee80211_tx_h_select_key might decide that a frame need not be encrypted at all, in which case it will clear tx->key. In that case it may crash if a key was previously selected, e.g. as the default key. This is also due to my patch "mac80211: move control.hw_key assignment". Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-19mac80211: re-enable re-transmission of filtered framesJohannes Berg
In an earlier commit, mac80211: disable software retry for now Pavel Roskin reported a problem that seems to be due to software retry of already transmitted frames. It turns out that we've never done that correctly, but due to some recent changes it now crashes in the TX code. I've added a comment in the patch that explains the problem better and also points to possible solutions -- which I can't implement right now. I disabled software retry of failed/filtered frames because it was broken. With the work of the previous patches, it now becomes fairly easy to re-enable it by adding a flag indicating that the frame shouldn't be modified, but still running it through the transmit handlers to populate the control information. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-19mac80211: move control.hw_key assignmentJohannes Berg
When mac80211 asks a driver to encrypt a frame, it must assign the control.hw_key pointer for it to know which key to use etc. Currently, mac80211 does this whenever it would software-encrypt a frame. Change the logic of this code to assign the hw_key pointer when selecting the key, and later check it when deciding whether to encrypt the frame or let it be encrypted by the hardware. This allows us to later simply skip the encryption function since it no longer modifies the TX control. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-19mac80211: remove useless setting of IEEE80211_TX_INTFL_DONT_ENCRYPTJohannes Berg
There's no value in setting a flag that will never be checked after this point, this seems to be legacy code -- I think previously the flag was used to check whether to encrypt the frame or not. Now, however, the flag need not be set, and setting it actually interferes if the frame will be processed again later. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-19mac80211: move and rename misc tx handlerJohannes Berg
This TX handler is used only for assigning the station pointer in the control information, so give it a better name. Also move it before rate control. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
