commit 74e2bd1fa3ae9695af566ad5a7a288898787b909 upstream.
When there is a need to restart/reconfig hw, tear down all the
aggregation queues and let the mac80211 and driver get in-sync to have
the opportunity to re-establish the aggregation queues again.
Need to wait until driver re-establish all the station information before tear
down the aggregation queues, driver(at least iwlwifi driver) will reject the
stop aggregation queue request if station is not ready. But also need to make
sure the aggregation queues are tear down before waking up the queues, so
mac80211 will not sending frames with aggregation bit set.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
commit 7236fe29fd72d17074574ba312e7f1bb9d10abaa upstream.
"mac80211: fix skb buffering issue" still left a race
between enabling the hardware queues and the virtual
interface queues. In hindsight it's totally obvious
that enabling the netdev queues for a hardware queue
when the hardware queue is enabled is wrong, because
it could well possible that we can fill the hw queue
with packets we already have pending. Thus, we must
only enable the netdev queues once all the pending
packets have been processed and sent off to the device.
In testing, I haven't been able to trigger this race
condition, but it's clearly there, possibly only when
aggregation is being enabled.
This is a backport of the mainline patches
cf0277e714a0db302a8f80e1b85fd61c32cf00b3
045cfb71a3901005bf6dcedae98cecb3360a0bfc
b49bb574e44226b332c28439999d196ddec2f643
Here is the description of the first of
those patches (the other two just fixed
bugs added by that patch):
Since I removed the master netdev, we've been
keeping internal queues only, and even before
that we never told the networking stack above
the virtual interfaces about congestion. This
means that packets are queued in mac80211 and
the upper layers never know, possibly leading
to memory exhaustion and other problems.
This patch makes all interfaces multiqueue and
uses ndo_select_queue to put the packets into
queues per AC. Additionally, when the driver
stops a queue, we now stop all corresponding
queues for the virtual interfaces as well.
The injection case will use VO by default for
non-data frames, and BE for data frames, but
downgrade any data frames according to ACM. It
needs to be fleshed out in the future to allow
chosing the queue/AC in radiotap.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Cc: John W. Linville <linville@tuxdriver.com>
commit 24feda0084722189468a65e20019cdd8ef99702b upstream.
mac80211 does not propagate failed hardware reconfiguration
requests. For suspend and resume this is important due to all
the possible issues that can come out of the suspend <-> resume
cycle. Not propagating the error means cfg80211 will assume
the resume for the device went through fine and mac80211 will
continue on trying to poke at the hardware, enable timers,
queue work, and so on for a device which is completley
unfunctional.
The least we can do is to propagate device start issues and
warn when this occurs upon resume. A side effect of this patch
is we also now propagate the start errors upon harware
reconfigurations (non-suspend), but this should also be desirable
anyway, there is not point in continuing to reconfigure a
device if mac80211 was unable to start the device.
For further details refer to the thread:
http://marc.info/?t=126151038700001&r=1&w=2
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit 1814077fd12a9cdf478c10076e9c42094e9d9250 upstream.
On a 32-bit machine, BIT() macro does not give the required
bit value if the bit is mroe than 31. In ieee802_11_parse_elems_crc(),
BIT() is suppossed to get the bit value more than 31 (42 (id of ERP_INFO_IE),
37 (CHANNEL_SWITCH_IE), (42), 32 (POWER_CONSTRAINT_IE), 45 (HT_CAP_IE),
61 (HT_INFO_IE)). As we do not get the required bit value for the above
IEs, crc over these IEs are never calculated, so any dynamic change in these
IEs after the association is not really handled on 32-bit platforms.
This patch fixes this issue.
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
When mac80211 resumes, it currently first sets suspended
to false so the driver can start doing things and we can
receive frames.
However, if we actually receive frames then it can end
up starting some work which adds timers and then later
runs into a BUG_ON in the timer code because it tries
add_timer() on a pending timer.
Fix this by keeping track of the resuming process by
introducing a new variable 'resuming' which gets set to
true early on instead of setting 'suspended' to false,
and allow queueing work but not receiving frames while
resuming.
Reported-by: Maxim Levitsky <maximlevitsky@gmail.com>
kfree_skb() should be used to free struct sk_buff pointers.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Cc: stable@kernel.org
Since configure_filter can sleep now, any multicast
configuration needed to be postponed to a work struct.
This, however, lead to a problem that we could queue
the work, stop the device and then afterwards invoke
configure_filter which may lead to driver hangs and is
a bug. To fix this, we can just cancel the filter work
since it's unnecessary to do after stopping the hw.
Since there are various places that call drv_stop, and
two of them do very similar things, the code for them
can be put into a shared function at the same time.
Reported-by: Lennert Buytenhek <buytenh@wantstofly.org>
Tested-by: Lennert Buytenhek <buytenh@marvell.com>
Over time, a whole bunch of drivers have come up
with their own scheme to delay the configure_filter
operation to a workqueue. To be able to simplify
things, allow configure_filter to sleep, and add
a new prepare_multicast callback that drivers that
need the multicast address list implement. This new
callback must be atomic, but most drivers either
don't care or just calculate a hash which can be
done atomically and then uploaded to the hardware
non-atomically.
A cursory look suggests that at76c50x-usb, ar9170,
mwl8k (which is actually very broken now), rt2x00,
wl1251, wl1271 and zd1211 should make use of this
new capability.
The mac80211 workqueue exists to enable mac80211 and drivers
to queue their own work on a single threaded workqueue. mac80211
takes care to flush the workqueue during suspend but we never
really had requirements on drivers for how they should use
the workqueue in consideration for suspend.
We extend mac80211 to document how the mac80211 workqueue should
be used, how it should not be used and finally move raw access to
the workqueue to mac80211 only. Drivers and mac80211 use helpers
to queue work onto the mac80211 workqueue:
* ieee80211_queue_work()
* ieee80211_queue_delayed_work()
These helpers will now warn if mac80211 already completed its
suspend cycle and someone is trying to queue work. mac80211
flushes the mac80211 workqueue prior to suspend a few times,
but we haven't taken the care to ensure drivers won't add more
work after suspend. To help with this we add a warning when
someone tries to add work and mac80211 already completed the
suspend cycle.
Drivers should ensure they cancel any work or delayed work
in the mac80211 stop() callback.
When enqueuing packets on the internal packet queue, we
need to ensure that we have a valid vif pointer since
that is required since the net namespace work. Add some
assertions to verify this, but also don't crash is for
some reason we don't end up with a vif pointer -- warn
and drop the packet in all these cases.
Since this code touches a number of hotpaths, it is
intended to be temporary, or maybe configurable in the
future, at least the bit that is in the path that gets
hit for every packet, ieee80211_tx_pending().
With the internal 'pending' queue system in place, we can simply
put packets there instead of pushing them off to the master dev,
getting rid of the master interface completely.
This reworks the key operation in cfg80211, and now only
allows, from userspace, configuring keys (via nl80211)
after the connection has been established (in managed
mode), the IBSS been joined (in IBSS mode), at any time
(in AP[_VLAN] modes) or never for all the other modes.
In order to do shared key authentication correctly, it
is now possible to give a WEP key to the AUTH command.
To configure static WEP keys, these are given to the
CONNECT or IBSS_JOIN command directly, for a userspace
SME it is assumed it will configure it properly after
the connection has been established.
Since mac80211 used to check the default key in IBSS
mode to see whether or not the network is protected,
it needs an update in that area, as well as an update
to make use of the WEP key passed to auth() for shared
key authentication.
If we do not disconnect when a channel switch is requested,
we end up eventually detection beacon loss from the AP and
then disconnecting, without ever really telling the AP, so
we might just as well disconnect right away.
Additionally, this fixes a problem with iwlwifi where the
driver will clear some internal state on channel changes
like this and then get confused when we actually go clear
that state from mac80211.
It may look like this patch drops the no-IBSS check, but
that is already handled by cfg80211 in the wext handler it
provides for IBSS (cfg80211_ibss_wext_siwfreq).
In order to handle powersave frames properly we had needed
to pass these out to the device queues again, and introduce
the skb->requeue bit. This, however, also has unnecessary
overhead by needing to 'clean up' already tried frames, and
this clean-up code is also buggy when software encryption
is used.
Instead of sending the frames via the master netdev queue
again, simply put them into the pending queue. This also
fixes a problem where frames for that particular station
could be reordered when some were still on the software
queues and older ones are re-injected into the software
queue after them.
To be easier on drivers and users, have cfg80211 register an
rfkill structure that drivers can access. When soft-killed,
simply take down all interfaces; when hard-killed the driver
needs to notify us and we will take down the interfaces
after the fact. While rfkilled, interfaces cannot be set UP.
I accidentally transposed these in the patch that "fixed" the defaults,
leading to extremely low throughput because of the huge min CW.
The patch moves some utility functions from mac80211 to cfg80211.
Because these functions are doing generic 802.11 operations so they
are not mac80211 specific. The moving allows some fullmac drivers
to be also benefit from these utility functions.
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com>
We forgot to cancel all timers in mac80211 when suspending.
In particular we forgot to deal with some things that can
cause hardware reconfiguration -- while it is down.
While at it we go ahead and add a warning in ieee80211_sta_work()
if its run while the suspend->resume cycle is in effect. This
should not happen and if it does it would indicate there is
a bug lurking in either mac80211 or mac80211 drivers.
With this now wpa_supplicant doesn't blink when I go to suspend
and resume where as before there where issues with some timers
running during the suspend->resume cycle. This caused a lot of
incorrect assumptions and would at times bring back the device
in an incoherent, but mostly recoverable, state.
We've never really cared about the default QoS (WMM) values, but
we really should if the AP doesn't send any. This patch makes
mac80211 use the default values according to 802.11-2007, and
additionally syncs the default values when we disassociate so
whatever the last AP said gets "unconfigured".
In order to later add tracing or verifications to the driver
calls mac80211 makes, this patch adds static inline wrappers
for all operations.
All calls are now written as
drv_<op>(local, ...);
instead of
local->ops-><op>(&local->hw, ...);
Where necessary, the wrappers also do existence checking and
return default values as appropriate.
The config_interface method is a little strange, it contains the
BSSID and beacon updates, while bss_info_changed contains most
other BSS information for each interface. This patch removes
config_interface and rolls all the information it previously
passed to drivers into bss_info_changed.
The TIM IE must not be shorter than 4 bytes, so verify that
when parsing it and use the proper type. To ease that adjust
struct ieee80211_tim_ie to have a virtual bitmap of size
at least 1.
Also check that the TIM IE is actually present before trying
to parse it!
Because other people may need the function, make it a static
inline in ieee80211.h.
(The original "mac80211: validate TIM IE length" was a minimal fix for
2.6.30. This purports to be the full, correct fix. -- JWL)
Add new nl80211 attributes that can be used with NL80211_CMD_SET_WIPHY
and NL80211_CMD_GET_WIPHY to manage fragmentation/RTS threshold and
retry limits.
Since these values are stored in struct wiphy, remove the local copy
from mac80211 where feasible (frag & rts threshold). The retry limits
are currently needed in struct ieee80211_conf, but these could be
eventually removed since the driver should have access to the values
in struct wiphy.
Signed-off-by: Jouni Malinen <j@w1.fi>
Regardless of whether the hardware implements beacon filtering,
there's no need to process all beacons in software all the time
throughout the stack (mac80211 does a lot, then cfg80211, then
in the future possibly userspace).
This patch implements the "best possible" beacon filtering in
mac80211. "Best possible" means that it can look for changes in
all requested information elements, and distinguish vendor IEs
by their OUI.
In the future, we will add nl80211 API for userspace to request
information elements and vendor IE OUIs to watch -- drivers can
then implement the best they can do while software implements
it fully.
It is unclear whether or not this actually saves CPU time, but
the data is all in the cache already so it should be fairly
cheap. The additional _testing_, however, has great benefit;
Without this, and on hardware that doesn't implement beacon
filtering, wrong assumptions about, for example, scan result
updates could quickly creep into code.
Some hardware defects may require the hardware to be re-initialised
completely from scratch. Drivers would need much information (for
instance the current MAC address, crypto keys, beaconing information,
etc.) stored duplicated from mac80211 to be able to do this, so let
mac80211 help them.
The new ieee80211_restart_hw() function requires the same code as
resuming, so move that code into a new ieee80211_reconfig() function
in util.c and leave only the suspend code in pm.c.
Include the HT capabilities in the probe request frame.
Instead of just passing the cfg80211-requested IEs, pass
the locally generated ones as well.
This patch introduces a new attribute for a wiphy that tells
userspace how long the information elements added to a probe
request frame can be at most. It also updates the at76 to
advertise that it cannot support that, and, for now until I
can fix that, iwlwifi too.
This patch removes all the virtual A-MPDU-queue bookkeeping from
mac80211. Curiously, iwlwifi already does its own bookkeeping, so
it doesn't require much changes except where it needs to handle
starting and stopping the queues in mac80211.
To handle the queue stop/wake properly, we rewrite the software
queue number for aggregation frames and internally to iwlwifi keep
track of the queues that map into the same AC queue, and only talk
to mac80211 about the AC queue. The implementation requires calling
two new functions, iwl_stop_queue and iwl_wake_queue instead of the
mac80211 counterparts.
Cc: Reinette Chattre <reinette.chatre@intel.com>
The pending packets code is quite incomprehensible, uses memory barriers
nobody really understands, etc. This patch reworks it entirely, using
the queue spinlock, proper stop bits and the skb queues themselves to
indicate whether packets are pending or not (rather than a separate
variable like before).
Reviewed-by: Luis R. Rodriguez <lrodriguez@atheros.com>
Fragmentation currently uses an allocated array to store the
fragment skbs, and then keeps track of which have been sent
and which are still pending etc. This is rather complicated;
make it simpler by just chaining the fragments into skb->next
and removing from that list when sent. Also simplifies all
code that needs to touch fragments, since it now only needs
to walk the skb->next list.
This is a prerequisite for fixing the stored packet code,
which I need to do for proper aggregation packet storing.
The functionality that NL80211_CMD_SET_MGMT_EXTRA_IE provided can now
be achieved with cleaner design by adding IE(s) into
NL80211_CMD_TRIGGER_SCAN, NL80211_CMD_AUTHENTICATE,
NL80211_CMD_ASSOCIATE, NL80211_CMD_DEAUTHENTICATE, and
NL80211_CMD_DISASSOCIATE.
Since this is a very recently added command and there are no known (or
known planned) applications using NL80211_CMD_SET_MGMT_EXTRA_IE and
taken into account how much extra complexity it adds to the IE
processing we have now (and need to add in the future to fix IE order
in couple of frames), it looks like the best option is to just remove
the implementation of this command for now. The enum values themselves
are left to avoid changing the nl80211 command or attribute numbers.
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
This extends the NL80211_CMD_TRIGGER_SCAN command to allow applications
to specify a set of information element(s) to be added into Probe
Request frames with NL80211_ATTR_IE. This provides support for the
MLME-SCAN.request primitive parameter VendorSpecificInfo and can be
used, e.g., to implement WPS scanning.
This patch splits out the ibss code and data from managed (station) mode.
The reason to do this is to better separate the state machines, and have
the code be contained better so it gets easier to determine what exactly
a given change will affect, that in turn makes it easier to understand.
This is quite some churn, especially because I split sdata->u.sta into
sdata->u.mgd and sdata->u.ibss, but I think it's easier to maintain that
way. I've also shuffled around some code -- null function sending is only
applicable to managed interfaces so put that into that file, some other
functions are needed from various places so put them into util, and also
rearranged the prototypes in ieee80211_i.h accordingly.
Hardware with AMPDU queues currently has broken aggregation.
This patch fixes it by making all A-MPDUs go over the regular AC queues,
but keeping track of the hardware queues in mac80211. As a first rough
version, it actually stops the AC queue for extended periods of time,
which can be removed by adding buffering internal to mac80211, but is
currently not a huge problem because people rarely use multiple TIDs
that are in the same AC (and iwlwifi currently doesn't operate as AP).
This is a short-term fix, my current medium-term plan, which I hope to
execute soon as well, but am not sure can finish before .30, looks like
this:
1) rework the internal queuing layer in mac80211 that we use for
fragments if the driver stopped queue in the middle of a fragmented
frame to be able to queue more frames at once (rather than just a
single frame with its fragments)
2) instead of stopping the entire AC queue, queue up the frames in a
per-station/per-TID queue during aggregation session initiation,
when the session has come up take all those frames and put them
onto the queue from 1)
3) push the ampdu queue layer abstraction this patch introduces in
mac80211 into the driver, and remove the virtual queue stuff from
mac80211 again
This plan will probably also affect ath9k in that mac80211 queues the
frames instead of passing them down, even when there are no ampdu queues.
Using only the RTNL has a number of problems, most notably that
ieee80211_iterate_active_interfaces() and other interface list
traversals cannot be done from the internal workqueue because it
needs to be flushed under the RTNL.
This patch introduces a new mutex that protects the interface list
against modifications. A more detailed explanation is part of the
code change.
If a driver is given a wiphy and it wants to get to its private
mac80211 driver area it can use wiphy_to_ieee80211_hw() to get first
to its ieee80211_hw and then access the private structure via hw->priv. The
wiphy_priv() is already being used internally by mac80211 and drivers
should not use this. This can be helpful in a drivers reg_notifier().
Since the standards only define 12 legacy rates, 32 is certainly
a sane upper limit and we don't need to use u64 everywhere. Add
sanity checking that no more than 32 rates are registered and
change the variables to u32 throughout.
The separate Association Comeback Time IE was removed from IEEE 802.11w
and the Timeout Interval IE (from IEEE 802.11r) is used instead. The
editing on this is still somewhat incomplete in IEEE 802.11w/D7.0, but
still, the use of Timeout Interval IE is the expected mechanism.
When MFP is enabled, the AP does not allow a STA to associate if an
existing security association exists without first going through SA
Query process. When this happens, the association request is denied
with a new status code ("temporarily rejected") ans Association
Comeback IE is used to notify when the association may be tried again
(i.e., when the SA Query procedure has timed out).
Use the comeback time to update the mac80211 client MLME timer for
next association attempt to minimize waiting time if association is
temporarily rejected.
Fixes sparse warnings:
net/mac80211/util.c:355:6: warning: symbol
'ieee80211_wake_queue_by_reason' was not declared. Should it be static?
net/mac80211/util.c:385:6: warning: symbol
'ieee80211_stop_queue_by_reason' was not declared. Should it be static?
Thanks to Johannes Berg for reporting this.
Signed-off-by: Kalle Valo <kalle.valo@iki.fi>
This is a preparation for the dynamic power save support. In future there are
two paths to stop the master queues and we need to track this properly to
avoid starting queues incorrectly. Implement this by adding a status
array for each queue.
The original idea and design is from Johannes Berg, I just did
the implementation based on his notes. All the bugs are mine, of course.
Signed-off-by: Kalle Valo <kalle.valo@nokia.com>
HT management is done differently for AP and STA modes, unify
to just the ->config() callback since HT is fundamentally a
PHY property and cannot be per-BSS.
Rename enum nl80211_sec_chan_offset as nl80211_channel_type to denote
the channel type ( NO_HT, HT20, HT40+, HT40- ).
Signed-off-by: Sujith <Sujith.Manoharan@atheros.com>
This patch adds new NL80211_CMD_SET_WIPHY attributes
NL80211_ATTR_WIPHY_FREQ and NL80211_ATTR_WIPHY_SEC_CHAN_OFFSET to allow
userspace to set the operating channel (e.g., hostapd for AP mode).
"Clearing" the rate control algorithm is pointless, none of
the algorithms actually uses this operation and it's not even
invoked properly for all channel switching. Also, there's no
need to since rate control algorithms work per station.
Move bss_conf into the vif struct so that drivers can
access it during ->tx without having to store it in
the private data or similar. No driver updates because
this is only for when they want to start using it.
This makes mac80211 notify the driver which configuration
actually changed, e.g. channel etc.
No driver changes, this is just plumbing, driver authors are
expected to act on this if they want to.
Also remove the HW CONFIG debug printk, it's incorrect, often
we configure something else.
This patch cleans up a number of things:
* the unusable definition of the HT capabilities/HT information
* variable names that are hard to understand
* mac80211: move ieee80211_handle_ht to ht.c and remove the unused
enable_ht parameter
* mac80211: fix bug with MCS rate 32 in ieee80211_handle_ht
* mac80211: fix bug with casting the result of ieee80211_bss_get_ie
to an information element _contents_ rather than the
whole element, add size checking (another out-of-bounds
access bug fixed!)
* mac80211: remove some unused return values in favour of BUG_ON
checking
* a few minor other things
Warn when ieee80211_hw_config returns an error, it shouldn't
happen; remove a number of printks that would happen in such
a case and one printk that is user-triggerable.
