It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
Otherwise, we enable all sorts of forgeries via timing attack.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: linux-wireless@vger.kernel.org
Cc: stable@vger.kernel.org
Add a flag that indicates that the WEP ICV was stripped from an
RX packet, allowing the device to not transfer that if it's
already checked.
Signed-off-by: David Spinadel <david.spinadel@intel.com>
Mostly simple overlapping changes.
For example, David Ahern's adjacency list revamp in 'net-next'
conflicted with an adjacency list traversal bug fix in 'net'.
Currently mac80211 determines whether HW does fragmentation
by checking whether the set_frag_threshold callback is set
or not.
However, some drivers may want to set the HW fragmentation
capability depending on HW generation.
Allow this by checking a HW flag instead of checking the
callback.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
[added the flag to ath10k and wlcore]
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Some crypto implementations (such as the generic CCM wrapper in crypto/)
use scatterlists to map fields of private data in their struct aead_req.
This means these data structures cannot live in the vmalloc area, which
means that they cannot live on the stack (with CONFIG_VMAP_STACK.)
This currently occurs only with the generic software implementation, but
the private data and usage is implementation specific, so move the whole
data structures off the stack into heap by allocating every time we need
to use them.
In addition, take care not to put any of our own stack allocations into
scatterlists. This involves reserving some extra room when allocating the
aead_request structures, and referring to those allocations in the scatter-
lists (while copying the data from the stack before the crypto operation)
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Some hardware (iwlwifi an example) de-aggregate AMSDUs and copy the IV
as is to the generated MPDUs, so the same PN appears in multiple
packets without being a replay attack. Allow driver to explicitly
indicate that a frame is allowed to have the same PN as the previous
frame.
When HW crypto is used, there's no need for the CCMP/GCMP MIC to
be available to mac80211, and the hardware might have removed it
already after checking. The MIC is also useless to have when the
frame is already decrypted, so allow indicating that it's not
present.
Since we are running out of bits in mac80211_rx_flags, make
the flags field a u64.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Some drivers/devices might want to set the IVs by
themselves (and still let mac80211 generate MMIC).
Specifically, this is needed when the device does
offloading at certain times, and the driver has
to make sure that the IVs of new tx frames (from
the host) are synchronized with IVs that were
potentially used during the offloading.
Similarly to CCMP, move the TX IVs of TKIP keys to the
public part of the key struct, and export a function
to add the IV right into the crypto header.
The public tx_pn field is defined as atomic64, so define
TKIP_PN_TO_IV16/32 helper macros to convert it to iv16/32
when needed.
Since the iv32 used for the p1k cache is taken
directly from the frame, we can safely remove
iv16/32 from being protected by tkip.txlock.
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
That file contains just a single function, which itself is just a
single statement to call a different function. Remove it.
When there are multiple RX queues, the PN checks in mac80211 cannot be
used since packets might be processed out of order on different CPUs.
Allow the driver to report that the PN has been checked, drivers that
will use multi-queue RX will have to set this flag.
For now, the flag is only valid when the frame has been decrypted, in
theory that restriction doesn't have to be there, but in practice the
hardware will have decrypted the frame already.
For drivers supporting TSO or similar features, but that still have
PN assignment in software, there's a need to have some memory to
store the current PN value. As mac80211 already stores this and it's
somewhat complicated to add a per-driver area to the key struct (due
to the dynamic sizing thereof) it makes sense to just move the TX PN
to the keyconf, i.e. the public part of the key struct.
As TKIP is more complicated and we won't able to offload it in this
way right now (fast-xmit is skipped for TKIP unless the HW does it
all, and our hardware needs MMIC calculation in software) I've not
moved that for now - it's possible but requires exposing a lot of
the internal TKIP state.
As an bonus side effect, we can remove a lot of code by assuming the
keyseq struct has a certain layout - with BUILD_BUG_ON to verify it.
This might also improve performance, since now TX and RX no longer
share a cacheline.
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
When a key is installed using a cipher scheme, set a new
internal key flag (KEY_FLAG_CIPHER_SCHEME) on it, to allow
distinguishing such keys more easily.
In particular, use this flag on the TX path instead of
testing the sta->cipher_scheme pointer, as the station is
NULL for broad-/multicast message, and use the key's iv_len
instead of the cipher scheme information.
Signed-off-by: Cedric Izoard <cedric.izoard@ceva-dsp.com>
[add missing documentation, rewrite commit message]
This allows mac80211 to configure BIP-GMAC-128 and BIP-GMAC-256 to the
driver and also use software-implementation within mac80211 when the
driver does not support this with hardware accelaration.
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
This allows mac80211 to configure BIP-CMAC-256 to the driver and also
use software-implementation within mac80211 when the driver does not
This allows mac80211 to configure CCMP-256 to the driver and also use
software-implementation within mac80211 when the driver does not support
[squash ccmp256 -> mic_len argument change]
This allows mac80211 to configure GCMP and GCMP-256 to the driver and
also use software-implementation within mac80211 when the driver does
[remove a spurious newline]
When an IV is generated, only the MAC header is moved back. The network
header location remains the same relative to the skb head, as the new IV
is using headroom space that was reserved in advance.
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
This message occasionally triggers for some people as in
https://bugzilla.redhat.com/show_bug.cgi?id=1111740 but
it's not clear which (headroom or tailroom) is at fault.
Annotate the message a bit to get more information.
The NULL pointer access could happen when ieee80211_crypto_hw_decrypt
is called from ieee80211_rx_h_decrypt with the following condition:
1. rx->key->conf.cipher is not WEP, CCMP, TKIP or AES_CMAC
2. rx->sta is NULL
When ieee80211_crypto_hw_decrypt is called, it verifies
rx->sta->cipher_scheme and it will cause Oops if rx->sta is NULL.
This path adds an addirional rx->sta == NULL verification in
ieee80211_crypto_hw_decrypt for this case.
Signed-off-by: Max Stepanov <Max.Stepanov@intel.com>
Some chips can encrypt managment frames in HW, but
require generated IV in the frame. Add a key flag
that allows us to achieve this.
Signed-off-by: Marek Kwaczynski <marek.kwaczynski@tieto.com>
[use BIT(0) to fill that spot, fix indentation]
A few places weren't checking that the frame passed to the
function actually has enough data even though the function
clearly documents it must have a payload byte. Make this
safer by changing the function to take an skb and checking
the length inside. The old version is preserved for now as
the rtl* drivers use it and don't have a correct skb.
Commit 7ec7c4a9a686 ("mac80211: port CCMP to cryptoapi's CCM driver")
resulted in the 'encrypted' param of ccmp_special_blocks() to be no
longer used so it can be dropped from the prototype.
Not clear how this landed here.
This adds generic cipher scheme support to mac80211, such schemes
are fully under control by the driver. On hw registration drivers
may specify additional HW ciphers with a scheme how these ciphers
have to be handled by mac80211 TX/RR. A cipher scheme specifies a
cipher suite value, a size of the security header to be added to
or stripped from frames and how the PN is to be verified on RX.
Use the generic CCM aead chaining mode driver rather than a local
implementation that sits right on top of the core AES cipher.
This allows the use of accelerated implementations of either
CCM as a whole or the CTR mode which it encapsulates.
mac80211 and the Intel drivers all define crypto
constants, move them to ieee80211.h instead.
Since no driver calls the TKIP functions from interrupt
context, there's no need to use spin_lock_irqsave().
Just use spin_lock_bh() (and spin_lock() in the TX path
where we're in a BH or they're already disabled.)
The mic failure count provides the number of mic failures that
have happened on a given key (without a countermeasure being
started, since that would remove the key).
Signed-off-by: Saravana <saravanad@posedge.com>
[fix NULL pointer issues]
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
This patch fix corruption which can manifest itself by following crash
when switching on rfkill switch with rt2x00 driver:
https://bugzilla.redhat.com/attachment.cgi?id=615362
Pointer key->u.ccmp.tfm of group key get corrupted in:
ieee80211_rx_h_michael_mic_verify():
/* update IV in key information to be able to detect replays */
rx->key->u.tkip.rx[rx->security_idx].iv32 = rx->tkip_iv32;
rx->key->u.tkip.rx[rx->security_idx].iv16 = rx->tkip_iv16;
because rt2x00 always set RX_FLAG_MMIC_STRIPPED, even if key is not TKIP.
We already check type of the key in different path in
ieee80211_rx_h_michael_mic_verify() function, so adding additional
check here is reasonable.
Cc: stable@vger.kernel.org # 3.0+
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
The bits used in the mask were off-by-one and ended up masking PwrMgt,
MoreData, Protected fields instead of Retry, PwrMgt, MoreData. Fix this
and to mask the correct fields. While doing so, convert the code to mask
the full FC using IEEE80211_FCTL_* defines similarly to how CCMP AAD is
built.
Since BIP is used only with broadcast/multicast management frames, the
Retry field is always 0 in these frames. The Protected field is also
zero to maintain backwards compatibility. As such, the incorrect mask
here does not really cause any problems for valid frames. In theory, an
invalid BIP frame with Retry or Protected field set to 1 could be
rejected because of BIP validation. However, no such frame should show
up with standard compliant implementations, so this does not cause
problems in normal BIP use.
Signed-off-by: Jouni Malinen <j@w1.fi>
Update the location of the network header when adding encryption
specific headers to a skb. This allows low-level drivers to use the
(now correct) location of the network header.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
Add IV-room in skb also for TKIP and WEP.
Extend patch: "mac80211: support adding IV-room in the skb for CCMP keys"
Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Not linearizing every SKB will help actually pass
non-linear SKBs all the way up when on an encrypted
connection. For now, linearize TKIP completely as
it is lower performance and I don't quite grok all
the details.
In function ieee80211_tx_h_encrypt the var info was
initialized from tx->skb, since the fucntion
is called after the function ieee80211_tx_h_fragment
tx->skb is not valid anymore.
Signed-off-by: Yoni Divinsky <yoni.divinsky@ti.com>
Since:
commit 816c04fe7ef01dd9649f5ccfe796474db8708be5
Author: Christian Lamparter <chunkeey@googlemail.com>
Date: Sat Apr 30 15:24:30 2011 +0200
mac80211: consolidate MIC failure report handling
is possible to that we dereference rx->key == NULL when driver set
RX_FLAG_MMIC_STRIPPED and not RX_FLAG_IV_STRIPPED and we are in
promiscuous mode. This happen with rt73usb and rt61pci at least.
Before the commit we always check rx->key against NULL, so I assume
fix should be done in mac80211 (also mic_fail path has similar check).
References:
https://bugzilla.redhat.com/show_bug.cgi?id=769766
http://rt2x00.serialmonkey.com/pipermail/users_rt2x00.serialmonkey.com/2012-January/004395.html
Reported-by: Stuart D Gathman <stuart@gathman.org>
Reported-by: Kai Wohlfahrt <kai.scorpio@gmail.com>
We are currently linking the skbs by using skb->next
directly. This works, but the preferred way is to use
a struct sk_buff_head instead. That also prepares for
passing that to drivers directly.
While at it I noticed we calculate the duration for
fragments twice -- remove one of them.
Fixes a bug introduced in:
commit 077a9154898b374f20555adc3f620cccd02581d6
Author: Arik Nemtsov <arik@wizery.com>
Date: Sun Oct 23 08:21:41 2011 +0200
Reported-by: Arend van Spriel <arend@broadcom.com>
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Some cards can generate CCMP IVs in HW, but require the space for the IV
to be pre-allocated in the frame at the correct offset. Add a key flag
The purpose of this is two-fold:
1) by moving it out of tx_data.flags, we can in
another patch move the radiotap parsing so it
no longer is in the hotpath
2) if a device implements fragmentation but can
optionally skip it, the radiotap request for
not doing fragmentation may be honoured
The current rx->queue value is slightly confusing.
It is set to 16 on non-QoS frames, including data,
and then used for sequence number and PN/IV checks.
Until recently, we had a TKIP IV checking bug that
had been introduced in 2008 to fix a seqno issue.
Before that, we always used TID 0 for checking the
PN or IV on non-QoS packets.
Go back to the old status for PN/IV checks using
the TID 0 counter for non-QoS by splitting up the
rx->queue value into "seqno_idx" and "security_idx"
in order to avoid confusion in the future. They
each have special rules on the value used for non-
QoS data frames.
Since the handling is now unified, also revert the
special TKIP handling from my patch
"mac80211: fix TKIP replay vulnerability".
mac80211 has a defnition of AES_BLOCK_SIZE and
multiple definitions of AES_BLOCK_LEN. Remove
them all and use crypto/aes.h.
Just like TKIP and CCMP, CMAC has the PN race.
It might not actually be possible to hit it now
since there aren't multiple ACs for management
frames, but fix it anyway.
Also move scratch buffers onto the stack.
Since we can process multiple packets at the
same time for different ACs, but the PN is
allocated from a single counter, we need to
use an atomic value there. Use atomic64_t to
make this cheaper on 64-bit platforms, other
platforms will support this through software
emulation, see lib/atomic64.c.
We also need to use an on-stack scratch buf
so that multiple packets won't corrupt each
others scratch buffers.
Our current TKIP code races against itself on TX
since we can process multiple packets at the same
time on different ACs, but they all share the TX
context for TKIP. This can lead to bad IVs etc.
Also, the crypto offload helper code just obtains
the P1K/P2K from the cache, and can update it as
well, but there's no guarantee that packets are
really processed in order.
To fix these issues, first introduce a spinlock
that will protect the IV16/IV32 values in the TX
context. This first step makes sure that we don't
assign the same IV multiple times or get confused
in other ways.
Secondly, change the way the P1K cache works. I
add a field "p1k_iv32" that stores the value of
the IV32 when the P1K was last recomputed, and
if different from the last time, then a new P1K
is recomputed. This can cause the P1K computation
to flip back and forth if packets are processed
out of order. All this also happens under the new
spinlock.
Finally, because there are argument differences,
split up the ieee80211_get_tkip_key() API into
ieee80211_get_tkip_p1k() and ieee80211_get_tkip_p2k()
and give them the correct arguments.
Sometimes when reporting a MIC failure rx->key may be unset. This
code path is hit when receiving a packet meant for a multicast
address, and decryption is performed in HW.
Fortunately, the failing key_idx is not used for anything up to
(and including) usermode, so we allow ourselves to drop it on the
way up when a key cannot be retrieved.
Cc: stable@kernel.org
Currently, mac80211 handles MIC failures differently
depending on whenever they are detected by the stack's
own software crypto or when are handed down from the
driver.
This patch tries to unify both by moving the special
branch out of mac80211 rx hotpath and into into the
software crypto part. This has the advantage that we
can run a few more sanity checks on the data and verify
if the key type was TKIP. This is very handy because
several devices generate false postive MIC failure
reports. Like carl9170, ath9k and wl12xx:
<http://www.spinics.net/lists/linux-wireless/msg68494.html>
"mac80211: report MIC failure for truncated packets in AP mode"
Cc: Luciano Coelho <coelho@ti.com>
Cc: Arik Nemtsov <arik@wizery.com>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
TKIP countermeasures depend on devices being able to detect Michael
MIC failures on received frames and for stations to report errors to
the AP. In order to test that behavior, it is useful to be able to
send out TKIP frames with incorrect Michael MIC. This testing behavior
has minimal effect on the TX path, so it can be added to mac80211 for
convenient use.
The interface for using this functionality is a file in mac80211
netdev debugfs (tkip_mic_test). Writing a MAC address to the file
makes mac80211 generate a dummy data frame that will be sent out using
invalid Michael MIC value. In AP mode, the address needs to be for one
of the associated stations or ff:ff:ff:ff:ff:ff to use a broadcast
frame. In station mode, the address can be anything, e.g., the current
BSSID. It should be noted that this functionality works correctly only
when associated and using TKIP.
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
The TKIP implementation was originally prepared to be a bit more
flexible in the way Michael MIC TX/RX keys are configured. However, we
are now taking care of the TX/RX MIC key swapping in user space, so
this code will not be needed. Similarly, there were some remaining WPA
testing code that won't be used in their current form. Remove the
unneeded extra complexity.
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
