path: root/net/mac80211
2012-07-12mac80211 & nl80211: add support to abort a scan request on txWei Ni
This fix comes from: https://gerrit.chromium.org/gerrit/#change,5744 https://gerrit.chromium.org/gerrit/#change,5745 So that it can work with the related wpa_supplicant tool. BUG=895591 Change-Id: Ie81f6d6052bd45dab13c936f9f0c5f4eb277496a Original-Signed-off-by: Wei Ni <wni@nvidia.com> Signed-off-by: Rhyland Klein <rklein@nvidia.com> Reviewed-on: http://git-master/r/111333 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-02-03nl80211/cfg80211: Make addition of new sinfo fields saferJouni Malinen
Add a comment pointing out the use of enum station_info_flags for all new struct station_info fields. In addition, memset the sinfo buffer to zero before use on all paths in the current tree to avoid leaving uninitialized pointers in the data. (cherry picked from commit 87159de9c30dab02b84cbaffa7498140d4ebc1a1 from android.googlesource.com/common.git) Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Dmitry Shmidt <dimitrysh@google.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Change-Id: I24301d45108587e66c8421a7f2a94ea98300ebeb Reviewed-on: http://git-master/r/78887 Reviewed-by: Automatic_Commit_Validation_User
2012-01-18mac80211: fix rx->key NULL pointer dereference in promiscuous modeStanislaw Gruszka
commit 1140afa862842ac3e56678693050760edc4ecde9 upstream. Since: commit 816c04fe7ef01dd9649f5ccfe796474db8708be5 Author: Christian Lamparter <chunkeey@googlemail.com> Date: Sat Apr 30 15:24:30 2011 +0200 mac80211: consolidate MIC failure report handling is possible to that we dereference rx->key == NULL when driver set RX_FLAG_MMIC_STRIPPED and not RX_FLAG_IV_STRIPPED and we are in promiscuous mode. This happen with rt73usb and rt61pci at least. Before the commit we always check rx->key against NULL, so I assume fix should be done in mac80211 (also mic_fail path has similar check). References: https://bugzilla.redhat.com/show_bug.cgi?id=769766 http://rt2x00.serialmonkey.com/pipermail/users_rt2x00.serialmonkey.com/2012-January/004395.html Reported-by: Stuart D Gathman <stuart@gathman.org> Reported-by: Kai Wohlfahrt <kai.scorpio@gmail.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06mac80211: fix another race in aggregation startJohannes Berg
commit 15062e6a8524f5977f2cbdf6e3eb2f144262f74e upstream. Emmanuel noticed that when mac80211 stops the queues for aggregation that can leave a packet pending. This packet will be given to the driver after the AMPDU callback, but as a non-aggregated packet which messes up the sequence number etc. I also noticed by looking at the code that if packets are being processed while we clear the WANT_START bit, they might see it cleared already and queue up on tid_tx->pending. If the driver then rejects the new aggregation session we leak the packet. Fix both of these issues by changing this code to not stop the queues at all. Instead, let packets queue up on the tid_tx->pending queue instead of letting them get to the driver, and add code to recover properly in case the driver rejects the session. (The patch looks large because it has to move two functions to before their new use.) Reported-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09mac80211: fix race condition caused by late addBA responseNikolay Martynov
Upstream commit d305a6557b2c4dca0110f05ffe745b1ef94adb80. If addBA responses comes in just after addba_resp_timer has expired mac80211 will still accept it and try to open the aggregation session. This causes drivers to be confused and in some cases even crash. This patch fixes the race condition and makes sure that if addba_resp_timer has expired addBA response is not longer accepted and we do not try to open half-closed session. Signed-off-by: Nikolay Martynov <mar.kolya@gmail.com> [some adjustments] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-09mac80211: fill rate filter for internal scan requestsSimon Wunderlich
commit c72e8d335e2c6a309b6281f2abcf491f37b8b92b upstream. The rates bitmap for internal scan requests shoud be filled, otherwise there will be probe requests with zero rates supported. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09mac80211: fix race between the AGG SM and the Tx data pathEmmanuel Grumbach
commit 2a1e0fd175dcfd72096ba9291d31e3b1b5342e60 upstream. When a packet is supposed to sent be as an a-MPDU, mac80211 sets IEEE80211_TX_CTL_AMPDU to let the driver know. On the other hand, mac80211 configures the driver for aggregration with the ampdu_action callback. There is race between these two mechanisms since the following scenario can occur when the BA agreement is torn down: Tx softIRQ drv configuration ========== ================= check OPERATIONAL bit Set the TX_CTL_AMPDU bit in the packet clear OPERATIONAL bit stop Tx AGG Pass Tx packet to the driver. In that case the driver would get a packet with TX_CTL_AMPDU set although it has already been notified that the BA session has been torn down. To fix this, we need to synchronize all the Qdisc activity after we cleared the OPERATIONAL bit. After that step, all the following packets will be buffered until the driver reports it is ready to get new packets for this RA / TID. This buffering allows not to run into another race that would send packets with TX_CTL_AMPDU unset while the driver hasn't been requested to tear down the BA session yet. This race occurs in practice and iwlwifi complains with a WARN_ON when it happens. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09mac80211: don't stop a single aggregation session twiceJohannes Berg
commit 24f50a9d165745fd0701c6e089d35f58a229ea69 upstream. Nikolay noticed (by code review) that mac80211 can attempt to stop an aggregation session while it is already being stopped. So to fix it, check whether stop is already being done and bail out if so. Also move setting the STOPPING state into the lock so things are properly atomic. Reported-by: Nikolay Martynov <mar.kolya@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26mac80211: fix bug in ieee80211_build_probe_reqJohannes Berg
commit 5b2bbf75a24d6b06afff6de0eb4819413fd81971 upstream. ieee80211_probereq_get() can return NULL in which case we should clean up & return NULL in ieee80211_build_probe_req() as well. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26mac80211: fix NULL dereference in radiotap codeJohannes Berg
commit f8d1ccf15568268c76f913b45ecdd33134387f1a upstream. When receiving failed PLCP frames is enabled, there won't be a rate pointer when we add the radiotap header and thus the kernel will crash. Fix this by not assuming the rate pointer is always valid. It's still always valid for frames that have good PLCP though, and that is checked & enforced. This was broken by my commit fc88518916793af8ad6a02e05ff254d95c36d875 Author: Johannes Berg <johannes.berg@intel.com> Date: Fri Jul 30 13:23:12 2010 +0200 mac80211: don't check rates on PLCP error frames where I removed the check in this case but didn't take into account that the rate info would be used. Reported-by: Xiaokang Qin <xiaokang.qin@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: disable powersave for broken APsJohannes Berg
commit 05cb91085760ca378f28fc274fbf77fc4fd9886c upstream. Only AID values 1-2007 are valid, but some APs have been found to send random bogus values, in the reported case an AP that was sending the AID field value 0xffff, an AID of 0x3fff (16383). There isn't much we can do but disable powersave since there's no way it can work properly in this case. Reported-by: Bill C Riemers <briemers@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: config hw when going back on-channelEliad Peller
commit 6911bf0453e0d6ea8eb694a4ce67a68d071c538e upstream. When going back on-channel, we should reconfigure the hw iff the hardware is not already configured to the operational channel. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: fix remain_off_channel regressionEliad Peller
commit eaa7af2ae582c9a8c51b374c48d5970b748a5ce2 upstream. The offchannel code is currently broken - we should remain_off_channel if the work was started, and the work's channel and channel_type are the same as local->tmp_channel and local->tmp_channel_type. However, if wk->chan_type and local->tmp_channel_type coexist (e.g. have the same channel type), we won't remain_off_channel. This behavior was introduced by commit da2fd1f ("mac80211: Allow work items to use existing channel type.") Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: fix offchannel TX cookie matchingJohannes Berg
commit 28a1bcdb57d50f3038a255741ecc83e391e5282e upstream. When I introduced in-kernel off-channel TX I introduced a bug -- the work can't be canceled again because the code clear the skb pointer. Fix this by keeping track separately of whether TX status has already been reported. Reported-by: Jouni Malinen <j@w1.fi> Tested-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-13mac80211: fix missing sta_lock in __sta_info_destroyJohannes Berg
Since my commit 34e895075e21be3e21e71d6317440d1ee7969ad0 ("mac80211: allow station add/remove to sleep") there is a race in mac80211 when it clears the TIM bit because a sleeping station disconnected, the spinlock isn't held around the relevant code any more. Use the right API to acquire the spinlock correctly. Cc: stable@kernel.org [2.6.34+] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-22mac80211: fix suspend/resume races with unregister hwStanislaw Gruszka
Do not call ->suspend, ->resume methods after we unregister wiphy. Also delete sta_clanup timer after we finish wiphy unregister to avoid this: WARNING: at lib/debugobjects.c:262 debug_print_object+0x85/0xa0() Hardware name: 6369CTO ODEBUG: free active (active state 0) object type: timer_list hint: sta_info_cleanup+0x0/0x180 [mac80211] Modules linked in: aes_i586 aes_generic fuse bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq mperf ext2 dm_mod uinput thinkpad_acpi hwmon sg arc4 rt2800usb rt2800lib crc_ccitt rt2x00usb rt2x00lib mac80211 cfg80211 i2c_i801 iTCO_wdt iTCO_vendor_support e1000e ext4 mbcache jbd2 sd_mod crc_t10dif sr_mod cdrom yenta_socket ahci libahci pata_acpi ata_generic ata_piix i915 drm_kms_helper drm i2c_algo_bit video [last unloaded: microcode] Pid: 5663, comm: pm-hibernate Not tainted 3.1.0-rc1-wl+ #19 Call Trace: [<c0454cfd>] warn_slowpath_common+0x6d/0xa0 [<c05e05e5>] ? debug_print_object+0x85/0xa0 [<c05e05e5>] ? debug_print_object+0x85/0xa0 [<c0454dae>] warn_slowpath_fmt+0x2e/0x30 [<c05e05e5>] debug_print_object+0x85/0xa0 [<f8a808e0>] ? sta_info_alloc+0x1a0/0x1a0 [mac80211] [<c05e0bd2>] debug_check_no_obj_freed+0xe2/0x180 [<c051175b>] kfree+0x8b/0x150 [<f8a126ae>] cfg80211_dev_free+0x7e/0x90 [cfg80211] [<f8a13afd>] wiphy_dev_release+0xd/0x10 [cfg80211] [<c068d959>] device_release+0x19/0x80 [<c05d06ba>] kobject_release+0x7a/0x1c0 [<c07646a8>] ? rtnl_unlock+0x8/0x10 [<f8a13adb>] ? wiphy_resume+0x6b/0x80 [cfg80211] [<c05d0640>] ? kobject_del+0x30/0x30 [<c05d1a6d>] kref_put+0x2d/0x60 [<c05d056d>] kobject_put+0x1d/0x50 [<c08015f4>] ? mutex_lock+0x14/0x40 [<c068d60f>] put_device+0xf/0x20 [<c069716a>] dpm_resume+0xca/0x160 [<c04912bd>] hibernation_snapshot+0xcd/0x260 [<c04903df>] ? freeze_processes+0x3f/0x90 [<c049151b>] hibernate+0xcb/0x1e0 [<c048fdc0>] ? pm_async_store+0x40/0x40 [<c048fe60>] state_store+0xa0/0xb0 [<c048fdc0>] ? pm_async_store+0x40/0x40 [<c05d0200>] kobj_attr_store+0x20/0x30 [<c0575ea4>] sysfs_write_file+0x94/0xf0 [<c051e26a>] vfs_write+0x9a/0x160 [<c0575e10>] ? sysfs_open_file+0x200/0x200 [<c051e3fd>] sys_write+0x3d/0x70 [<c080959f>] sysenter_do_call+0x12/0x28 Cc: stable@kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-27net: Audit drivers to identify those needing IFF_TX_SKB_SHARING clearedNeil Horman
After the last patch, We are left in a state in which only drivers calling ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real hardware call ether_setup for their net_devices and don't hold any state in their skbs. There are a handful of drivers that violate this assumption of course, and need to be fixed up. This patch identifies those drivers, and marks them as not being able to support the safe transmission of skbs by clearning the IFF_TX_SKB_SHARING flag in priv_flags Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Karsten Keil <isdn@linux-pingi.de> CC: "David S. Miller" <davem@davemloft.net> CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: Patrick McHardy <kaber@trash.net> CC: Krzysztof Halasa <khc@pm.waw.pl> CC: "John W. Linville" <linville@tuxdriver.com> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Marcel Holtmann <marcel@holtmann.org> CC: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-21treewide: fix potentially dangerous trailing ';' in #defined values/expressionsPhil Carmody
All these are instances of #define NAME value; or #define NAME(params_opt) value; These of course fail to build when used in contexts like if(foo $OP NAME) while(bar $OP NAME) and may silently generate the wrong code in contexts such as foo = NAME + 1; /* foo = value; + 1; */ bar = NAME - 1; /* bar = value; - 1; */ baz = NAME & quux; /* baz = value; & quux; */ Reported on comp.lang.c, Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com> Initial analysis of the dangers provided by Keith Thompson in that thread. There are many more instances of more complicated macros having unnecessary trailing semicolons, but this pile seems to be all of the cases of simple values suffering from the problem. (Thus things that are likely to be found in one of the contexts above, more complicated ones aren't.) Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-20mac80211: check sta_info_get() return valueEliad Peller
ieee80211_stop_rx_ba_session() was calling sta_info_get() without rcu locking, and the return value was not checked. This resulted in the following panic: [<bf05726c>] (ieee80211_stop_rx_ba_session+0x0/0x60 [mac80211]) [<bf0abd94>] (wl1271_event_handle+0x0/0xdc8 [wl12xx]) [<bf0a7308>] (wl1271_irq+0x0/0x4a0 [wl12xx]) [<c00c40a8>] (irq_thread+0x0/0x254) [<c00a7398>] (kthread+0x0/0x8c) Signed-off-by: Eliad Peller <eliad@wizery.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-20mac80211: sync driver before TXJohannes Berg
In P2P client mode, the GO (AP) to connect to might have periods of time where it is not available due to powersave. To allow the driver to sync with it and send frames to the GO only when it is available add a new callback tx_sync (and the corresponding finish_tx_sync). These callbacks can sleep unlike the actual TX. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-19mac80211: implement scan supported ratesJohannes Berg
Scanning currently uses the TX rate mask to restrict the rate set, which is bogus. Make it use the new set of rates from userspace. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-18mac80211: reconfigure tx on device reconfigurationEliad Peller
Add tx_conf array to save the current tx queues configuration, and reconfig it on resume (ieee80211_reconfig). On resume, the driver is being reconfigured. Without reconfiguring the tx queues as well, the driver might configure the device to use wrong ac params (e.g. ps-poll instead of uapsd). Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-15mac80211: be more careful in suspend/resumeJohannes Berg
When suspending with all netdevs down, the device is stopped but we still call a number of driver callbacks that the driver might not expect. The same happens during resume, we might call a few callbacks without starting the driver. Fix this by checking open_count around more things and exiting quickly if it is 0. Also, while at this I noticed that the coverage class isn't reprogrammed after resume, so add that. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-15mac80211: let key iteration get keys in install orderJohannes Berg
ieee80211_iter_keys() currently returns keys in the backward order they were installed in, which is a bit confusing. Add them to the tail of the key list to make sure iterations go in the same order that keys were originally installed in. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-15mac80211: allow driver access to TKIP RX P1KJohannes Berg
When the driver wants to pre-program the TKIP RX phase 1 key, it needs to be able to obtain it for the peer's TA. Add API to allow it to generate it. The generation uses a dummy on-stack context since it doesn't know the RX queue. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-13mac80211: allow driver to disconnect after resumeJohannes Berg
In WoWLAN, devices may use crypto keys for TX/RX and could also implement GTK rekeying. If the driver isn't able to retrieve replay counters and similar information from the device upon resume, or if the device isn't responsive due to platform issues, it isn't safe to keep the connection up as GTK rekey messages from during the sleep time could be replayed against it. The only protection against that is disconnecting from the AP. Modifying mac80211 to do that while it is resuming would be very complex and invasive in the case that the driver requires a reconfig, so do it after it has resumed completely. In that case, however, packets might be replayed since it can then only happen after TX/RX are up again, so mark keys for interfaces that need to disconnect as "tainted" and drop all packets that are sent or received with those keys. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-13mac80211: remove a redundant checkMohammed Shafi Shajakhan
is_valid_ether_addr itself checks for is_zero_ether_addr Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-11mac80211: allocate only one RX queueJohannes Berg
We don't have multiple RX queues, so there's no use in allocating multiple, use alloc_netdev_mqs() to allocate multiple TX but only one RX queue. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-11mac80211: add driver RSSI threshold eventsMeenakshi Venkataraman
mac80211 maintains a running average of the RSSI when a STA is associated to an AP. Report threshold events to any driver that has registered callbacks for getting RSSI measurements. Implement callbacks in mac80211 so that driver can set thresholds. Add callbacks in mac80211 which is invoked when an RSSI threshold event occurs. mac80211: add tracing to rssi_reports api and remove extraneous fn argument mac80211: scale up rssi thresholds from driver by 16 before storing Signed-off-by: Meenakshi Venkataraman <meenakshi.venkataraman@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-11Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/ath/ath5k/sysfs.c net/bluetooth/l2cap_core.c net/mac80211/wpa.c
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-08rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_checkMichal Hocko
Since ca5ecddf (rcu: define __rcu address space modifier for sparse) rcu_dereference_check use rcu_read_lock_held as a part of condition automatically so callers do not have to do that as well. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-08mac80211: Restart STA timers only on associated stateRajkumar Manoharan
A panic was observed when the device is failed to resume properly, and there are no running interfaces. ieee80211_reconfig tries to restart STA timers on unassociated state. Cc: stable@kernel.org Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-08mac80211: allow driver to generate P1K for IV32Johannes Berg
In order to support pre-populating the P1K cache in iwlwifi hardware for WoWLAN, we need to calculate the P1K for the current IV32. Allow drivers to get the P1K for any given IV32 instead of for a given packet, but keep the packet-based version around as an inline. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-08mac80211: allow drivers to access key sequence counterJohannes Berg
In order to implement GTK rekeying, the device needs to be able to encrypt frames with the right PN/IV and check the PN/IV in RX frames. To be able to tell it about all those counters, we need to be able to get them from mac80211, this adds the required API. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-08mac80211: simplify RX PN/IV handlingJohannes Berg
The current rx->queue value is slightly confusing. It is set to 16 on non-QoS frames, including data, and then used for sequence number and PN/IV checks. Until recently, we had a TKIP IV checking bug that had been introduced in 2008 to fix a seqno issue. Before that, we always used TID 0 for checking the PN or IV on non-QoS packets. Go back to the old status for PN/IV checks using the TID 0 counter for non-QoS by splitting up the rx->queue value into "seqno_idx" and "security_idx" in order to avoid confusion in the future. They each have special rules on the value used for non- QoS data frames. Since the handling is now unified, also revert the special TKIP handling from my patch "mac80211: fix TKIP replay vulnerability". Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-08mac80211: use AES_BLOCK_SIZEJohannes Berg
mac80211 has a defnition of AES_BLOCK_SIZE and multiple definitions of AES_BLOCK_LEN. Remove them all and use crypto/aes.h. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-08mac80211: fix CMAC racesJohannes Berg
Just like TKIP and CCMP, CMAC has the PN race. It might not actually be possible to hit it now since there aren't multiple ACs for management frames, but fix it anyway. Also move scratch buffers onto the stack. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-08mac80211: fix CCMP racesJohannes Berg
Since we can process multiple packets at the same time for different ACs, but the PN is allocated from a single counter, we need to use an atomic value there. Use atomic64_t to make this cheaper on 64-bit platforms, other platforms will support this through software emulation, see lib/atomic64.c. We also need to use an on-stack scratch buf so that multiple packets won't corrupt each others scratch buffers. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-08mac80211: fix TKIP races, make API easier to useJohannes Berg
Our current TKIP code races against itself on TX since we can process multiple packets at the same time on different ACs, but they all share the TX context for TKIP. This can lead to bad IVs etc. Also, the crypto offload helper code just obtains the P1K/P2K from the cache, and can update it as well, but there's no guarantee that packets are really processed in order. To fix these issues, first introduce a spinlock that will protect the IV16/IV32 values in the TX context. This first step makes sure that we don't assign the same IV multiple times or get confused in other ways. Secondly, change the way the P1K cache works. I add a field "p1k_iv32" that stores the value of the IV32 when the P1K was last recomputed, and if different from the last time, then a new P1K is recomputed. This can cause the P1K computation to flip back and forth if packets are processed out of order. All this also happens under the new spinlock. Finally, because there are argument differences, split up the ieee80211_get_tkip_key() API into ieee80211_get_tkip_p1k() and ieee80211_get_tkip_p2k() and give them the correct arguments. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-07mac80211: fix TKIP replay vulnerabilityJohannes Berg
Unlike CCMP, the presence or absence of the QoS field doesn't change the encryption, only the TID is used. When no QoS field is present, zero is used as the TID value. This means that it is possible for an attacker to take a QoS packet with TID 0 and replay it as a non-QoS packet. Unfortunately, mac80211 uses different IVs for checking the validity of the packet's TKIP IV when it checks TID 0 and when it checks non-QoS packets. This means it is vulnerable to this replay attack. To fix this, use the same replay counter for TID 0 and non-QoS packets by overriding the rx->queue value to 0 if it is 16 (non-QoS). This is a minimal fix for now. I caused this issue in commit 1411f9b531f0a910cd1c85a337737c1e6ffbae6a Author: Johannes Berg <johannes@sipsolutions.net> Date: Thu Jul 10 10:11:02 2008 +0200 mac80211: fix RX sequence number check while fixing a sequence number issue (there, a separate counter needs to be used). Cc: stable@kernel.org Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-07mac80211: fix ie memory allocation for scheduled scansLuciano Coelho
We were not allocating memory for the IEs passed in the scheduled_scan request and this was causing memory corruption (buffer overflow). Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-06mac80211: support GTK rekey offloadJohannes Berg
This adds the necessary mac80211 APIs to support GTK rekey offload, mirroring the functionality from cfg80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-06mac80211: allow driver to iterate keysJohannes Berg
When in suspend/wowlan, devices might implement crypto offload differently (more features), and might require reprogramming keys for the WoWLAN (as it is the case for Intel devices that use another uCode image). Thus allow the driver to iterate all keys in this context. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-05mac80211: allow driver to impose WoWLAN restrictionsJohannes Berg
If the driver can't support WoWLAN in the current state, this patch allows it to return 1 from the suspend callback to do the normal deconfiguration instead of using suspend/resume calls. Note that if it does this, resume won't be called. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-05mac80211: fix smatch complainsChristian Lamparter
mlme.c l.757 ieee80211_dynamic_ps_enable_work(11) variable dereferenced before check 'sdata' mesh_pathtbl.c l.650 mesh_path_del(20) double lock 'bottom_half' l.663 mesh_path_del(33) double unlock 'bottom_half' Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-05mac80211: Skip tailroom reservation for full HW-crypto devices with race fixYogesh Ashok Powar
Based on inputs from Johannes Berg <johannes@sipsolutions.net> from http://article.gmane.org/gmane.linux.kernel.wireless.general/68193 and http://article.gmane.org/gmane.linux.kernel.wireless.general/71702 In xmit path, devices that do full hardware crypto (including MMIC and ICV) need no tailroom. For such devices, tailroom reservation can be skipped if all the keys are programmed into the hardware (i.e software crypto is not used for any of the keys) and none of the keys wants software to generate Michael MIC and IV. v2: Added check for IV along with MMIC. Reported-by: Fabio Rossi <rossi.f@inwind.it> Tested-by: Fabio Rossi <rossi.f@inwind.it> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Cc: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> v3: Fixing races to avoid WARNING: at net/mac80211/wpa.c:397 ccmp_encrypt_skb+0xc4/0x1f0 Reported-by: Andreas Hartmann <andihartmann@01019freenet.de> Tested-by: Andreas Hartmann <andihartmann@01019freenet.de> v4: Added links with message ID Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-29mac80211: propagate information about STA WME support downArik Nemtsov
Add a memeber to the ieee80211_sta structure to indicate whether the STA supports WME. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-28Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-tx.c
