[ Upstream commit 34b1e0e9efe101822e83cc62d22443ed3867ae7a ]
mac80211 uses the frag list to build AMSDU. When freeing
the skb, it may not be really freed, since someone is still
holding a reference to it.
In that case, when TCP skb is being retransmitted, the
pointer to the frag list is being reused, while the data
in there is no longer valid.
Since we will never get frag list from the network stack,
as mac80211 doesn't advertise the capability, we can safely
free and nullify it before releasing the SKB.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
[ Upstream commit 911a26484c33e10de6237228ca1d7293548e9f49 ]
Commit c470bdc1aaf3 ("mac80211: don't WARN on bad WMM parameters from
buggy APs") handled cases where an AP reports a zeroed WMM
IE. However, the condition that checks the validity accessed the wrong
index in the ieee80211_tx_queue_params array, thus wrongly deducing
that the parameters are invalid. Fix it.
Fixes: c470bdc1aaf3 ("mac80211: don't WARN on bad WMM parameters from buggy APs")
Signed-off-by: Ilan Peer <ilan.peer@intel.com>
[ Upstream commit c470bdc1aaf36669e04ba65faf1092b2d1c6cabe ]
Apparently, some APs are buggy enough to send a zeroed
WMM IE. Don't WARN on this since this is not caused by a bug
on the client's system.
This aligns the condition of the WARNING in drv_conf_tx
with the validity check in ieee80211_sta_wmm_params.
We will now pick the default values whenever we get
a zeroed WMM IE.
This has been reported here:
https://bugzilla.kernel.org/show_bug.cgi?id=199161
Fixes: f409079bb678 ("mac80211: sanity check CW_min/CW_max towards driver")
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 990d71846a0b7281bd933c34d734e6afc7408e7e upstream.
NullFunc packets should never be duplicate just like
QoS-NullFunc packets.
We saw a client that enters / exits power save with
NullFunc frames (and not with QoS-NullFunc) despite the
fact that the association supports HT.
This specific client also re-uses a non-zero sequence number
for different NullFunc frames.
At some point, the client had to send a retransmission of
the NullFunc frame and we dropped it, leading to a
misalignment in the power save state.
Fix this by never consider a NullFunc frame as duplicate,
just like we do for QoS NullFunc frames.
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=201449
CC: <stable@vger.kernel.org>
commit 9ec1190d065998650fd9260dea8cf3e1f56c0e8c upstream.
If the buffered broadcast queue contains packets, letting new packets bypass
that queue can lead to heavy reordering, since the driver is probably throttling
transmission of buffered multicast packets after beacons.
Keep buffering packets until the buffer has been cleared (and no client
is in powersave mode).
Cc: stable@vger.kernel.org
Signed-off-by: Felix Fietkau <nbd@nbd.name>
commit a317e65face482371de30246b6494feb093ff7f9 upstream.
Make it behave like regular ieee80211_tx_status calls, except for the lack of
filtered frame processing.
This fixes spurious low-ack triggered disconnections with powersave clients
connected to an AP.
Fixes: f027c2aca0cf4 ("mac80211: add ieee80211_tx_status_noskb")
commit 5c21e8100dfd57c806e833ae905e26efbb87840f upstream.
This fixes stale beacon-int values that would keep a netdev
from going up.
To reproduce:
Create two VAP on one radio.
vap1 has beacon-int 100, start it.
vap2 has beacon-int 240, start it (and it will fail
because beacon-int mismatch).
reconfigure vap2 to have beacon-int 100 and start it.
It will fail because the stale beacon-int 240 will be used
in the ifup path and hostapd never gets a chance to set the
new beacon interval.
Signed-off-by: Ben Greear <greearb@candelatech.com>
[ Upstream commit c42055105785580563535e6d3143cad95c7ac7ee ]
TX status reporting to ieee80211s is through ieee80211s_update_metric.
There are two problems about ieee80211s_update_metric:
1. The purpose is to estimate the fail probability
to a specific link. No need to restrict to data frame.
2. Current implementation does not work if wireless driver does not
pass tx_status with skb.
Fix this by removing ieee80211_is_data condition, passing
ieee80211_tx_status directly to ieee80211s_update_metric, and
putting it in both __ieee80211_tx_status and ieee80211_tx_status_ext.
Signed-off-by: Yuan-Chi Pang <fu3mo6goo@gmail.com>
[ Upstream commit cb59bc14e830028d2244861216df038165d7625d ]
If the TDLS setup happens over a connection to an AP that
doesn't have QoS, we nevertheless assign a non-zero TID
(skb->priority) and queue mapping, which may confuse us or
drivers later.
Fix it by just assigning the special skb->priority and then
using ieee80211_select_queue() just like other data frames
would go through.
[ Upstream commit 6eae4a6c2be387fec41b0d2782c4fffb57159498 ]
In our environment running lots of mesh nodes, we are seeing the
pending queue hang periodically, with the debugfs queues file showing
lines such as:
00: 0x00000000/348
i.e. there are a large number of frames but no stop reason set.
One way this could happen is if queue processing from the pending
tasklet exited early without processing all frames, and without having
some future event (incoming frame, stop reason flag, ...) to reschedule
it.
Exactly this can occur today if ieee80211_tx() returns false due to
packet drops or power-save buffering in the tx handlers. In the
past, this function would return true in such cases, and the change
to false doesn't seem to be intentional. Fix this case by reverting
to the previous behavior.
Fixes: bb42f2d13ffc ("mac80211: Move reorder-sensitive TX handlers to after TXQ dequeue")
Signed-off-by: Bob Copeland <bobcopeland@fb.com>
Acked-by: Toke Høiland-Jørgensen <toke@toke.dk>
[ Upstream commit 8682250b3c1b75a45feb7452bc413d004cfe3778 ]
If a frame is dropped for any reason, mac80211 wouldn't report the TX
status back to user space.
As the user space may rely on the TX_STATUS to kick its state
machines, resends etc, it's better to just report this frame as not
acked instead.
Signed-off-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com>
commit 211710ca74adf790b46ab3867fcce8047b573cd1 upstream.
key->sta is only valid after ieee80211_key_link, which is called later
in this function. Because of that, the IEEE80211_KEY_FLAG_RX_MGMT is
never set when management frame protection is enabled.
Fixes: e548c49e6dc6b ("mac80211: add key flag for management keys")
[ Upstream commit c6e57b3896fc76299913b8cfd82d853bee8a2c84 ]
When tracing is enabled, all the debug messages are recorded and must
not exceed MAX_MSG_LEN (100) columns. Longer debug messages grant the
user with:
WARNING: CPU: 3 PID: 32642 at /tmp/wifi-core-20180806094828/src/iwlwifi-stack-dev/net/mac80211/./trace_msg.h:32 trace_event_raw_event_mac80211_msg_event+0xab/0xc0 [mac80211]
Workqueue: phy1 ieee80211_iface_work [mac80211]
RIP: 0010:trace_event_raw_event_mac80211_msg_event+0xab/0xc0 [mac80211]
Call Trace:
__sdata_dbg+0xbd/0x120 [mac80211]
ieee80211_ibss_rx_queued_mgmt+0x15f/0x510 [mac80211]
ieee80211_iface_work+0x21d/0x320 [mac80211]
[ Upstream commit 6c18b27d6e5c6a7206364eae2b47bc8d8b2fa68f ]
If the driver fails to properly prepare for the channel
switch, mac80211 will disconnect. If the CSA IE had mode
set to 1, it means that the clients are not allowed to send
any Tx on the current channel, and that includes the
deauthentication frame.
Make sure that we don't send the deauthentication frame in
this case.
In iwlwifi, this caused a failure to flush queues since the
firmware already closed the queues after having parsed the
CSA IE. Then mac80211 would wait until the deauthentication
frame would go out (drv_flush(drop=false)) and that would
never happen.
[ Upstream commit 0007e94355fdb71a1cf5dba0754155cba08f0666 ]
When performing a channel switch flow for a managed interface, the
flow did not update the bandwidth of the AP station and the rate
scale algorithm. In case of a channel width downgrade, this would
result with the rate scale algorithm using a bandwidth that does not
match the interface channel configuration.
Fix this by updating the AP station bandwidth and rate scaling algorithm
before the actual channel change in case of a bandwidth downgrade, or
after the actual channel change in case of a bandwidth upgrade.
[ Upstream commit f3ffb6c3a28963657eb8b02a795d75f2ebbd5ef4 ]
We hit a problem with iwlwifi that was caused by a bug in
mac80211. A bug in iwlwifi caused the firwmare to crash in
certain cases in channel switch. Because of that bug,
drv_pre_channel_switch would fail and trigger the restart
flow.
Now we had the hw restart worker which runs on the system's
workqueue and the csa_connection_drop_work worker that runs
on mac80211's workqueue that can run together. This is
obviously problematic since the restart work wants to
reconfigure the connection, while the csa_connection_drop_work
worker does the exact opposite: it tries to disconnect.
Fix this by cancelling the csa_connection_drop_work worker
in the restart worker.
Note that this can sound racy: we could have:
driver iface_work CSA_work restart_work
<--drv_cs ---|
<FW CRASH!>
-CS FAILED-->
| cancel_work(CSA)
schedule |
CSA work |
Race between those 2
But this is not possible because we flush the workqueue
in the restart worker before we cancel the CSA worker.
That would be bullet proof if we could guarantee that
we schedule the CSA worker only from the iface_work
which runs on the workqueue (and not on the system's
workqueue), but unfortunately we do have an instance
in which we schedule the CSA work outside the context
of the workqueue (ieee80211_chswitch_done).
Note also that we should probably cancel other workers
like beacon_connection_loss_work and possibly others
for different types of interfaces, at the very least,
IBSS should suffer from the exact same problem, but for
now, do the minimum to fix the actual bug that was actually
experienced and reproduced.
[ Upstream commit 66eb02d839e8495ae6b612e2d09ff599374b80e2 ]
Initialize 'n' to 2 in order to take into account also the first
packet in the estimation of max_subframe limit for a given A-MSDU
since frag_tail pointer is NULL when ieee80211_amsdu_aggregate
routine analyzes the second frame.
Fixes: 6e0456b54545 ("mac80211: add A-MSDU tx support")
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit aa58acf325b4aadeecae2bfc90658273b47dbace ]
In the error path of changing the SKB headroom of the second
A-MSDU subframe, we would not account for the already-changed
length of the first frame that just got converted to be in
A-MSDU format and thus is a bit longer now.
Fix this by doing the necessary accounting.
It would be possible to reorder the operations, but that would
make the code more complex (to calculate the necessary pad),
and the headroom expansion should not fail frequently enough
to make that worthwhile.
Acked-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit 1eb507903665442360a959136dfa3234c43db085 ]
Do not start to aggregate packets in a A-MSDU frame (converting the
first subframe to A-MSDU, adding the header) if max_tx_fragments or
max_amsdu_subframes limits are already exceeded by it. In particular,
this happens when drivers set the limit to 1 to avoid A-MSDUs at all.
[reword commit message to be more precise]
[ Upstream commit 166ac9d55b0ab70b644e429be1f217fe8393cbd7 ]
When building building AMSDU from non-linear SKB, we hit a
kernel panic when trying to push the padding to the tail.
Instead, put the padding at the head of the next subframe.
This also fixes the A-MSDU subframes to not have the padding
accounted in the length field and not have pad at all for
the last subframe, both required by the spec.
Reviewed-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit 1f631c3201fe5491808df143d8fcba81b3197ffd ]
IEEE 802.11-2016 14.10.8.3 HWMP sequence numbering says:
If it is a target mesh STA, it shall update its own HWMP SN to
maximum (current HWMP SN, target HWMP SN in the PREQ element) + 1
immediately before it generates a PREP element in response to a
PREQ element.
[ Upstream commit 67d1ba8a6dc83d90cd58b89fa6cbf9ae35a0cf7f ]
The mod mask for VHT capabilities intends to say that you can override
the number of STBC receive streams, and it does, but only by accident.
The IEEE80211_VHT_CAP_RXSTBC_X aren't bits to be set, but values (albeit
left-shifted). ORing the bits together gets the right answer, but we
should use the _MASK macro here instead.
Signed-off-by: Danek Duvall <duvall@comfychair.org>
[ Upstream commit 77cfaf52eca5cac30ed029507e0cab065f888995 ]
The TXQ teardown code can reference the vif data structures that are
stored in the netdev private memory area if there are still packets on
the queue when it is being freed. Since the TXQ teardown code is run
after the netdevs are freed, this can lead to a use-after-free. Fix this
by moving the TXQ teardown code to earlier in ieee80211_unregister_hw().
Reported-by: Ben Greear <greearb@candelatech.com>
Tested-by: Ben Greear <greearb@candelatech.com>
Signed-off-by: Toke Høiland-Jørgensen <toke@toke.dk>
[ Upstream commit 133bf90dbb8b873286f8ec2e81ba26e863114b8c ]
As explained in ieee80211_delayed_tailroom_dec(), during roam,
keys of the old AP will be destroyed and new keys will be
installed. Deletion of the old key causes
crypto_tx_tailroom_needed_cnt to go from 1 to 0 and the new key
installation causes a transition from 0 to 1.
Whenever crypto_tx_tailroom_needed_cnt transitions from 0 to 1,
we invoke synchronize_net(); the reason for doing this is to avoid
a race in the TX path as explained in increment_tailroom_need_count().
This synchronize_net() operation can be slow and can affect the station
roam time. To avoid this, decrementing the crypto_tx_tailroom_needed_cnt
is delayed for a while so that upon installation of new key the
transition would be from 1 to 2 instead of 0 to 1 and thereby
improving the roam time.
This is all correct for a STA iftype, but deferring the tailroom_needed
decrement for other iftypes may be unnecessary.
For example, let's consider the case of a 4-addr client connecting to
an AP for which AP_VLAN interface is also created, let the initial
value for tailroom_needed on the AP be 1.
* 4-addr client connects to the AP (AP: tailroom_needed = 1)
* AP will clear old keys, delay decrement of tailroom_needed count
* AP_VLAN is created, it takes the tailroom count from master
(AP_VLAN: tailroom_needed = 1, AP: tailroom_needed = 1)
* Install new key for the station, assume key is plumbed in the HW,
there won't be any change in tailroom_needed count on AP iface
* Delayed decrement of tailroom_needed count on AP
(AP: tailroom_needed = 0, AP_VLAN: tailroom_needed = 1)
Because of the delayed decrement on AP iface, tailroom_needed count goes
out of sync between AP(master iface) and AP_VLAN(slave iface) and
there would be unnecessary tailroom created for the packets going
through AP_VLAN iface.
Also, WARN_ONs were observed while trying to bring down the AP_VLAN
interface:
(warn_slowpath_common) (warn_slowpath_null+0x18/0x20)
(warn_slowpath_null) (ieee80211_free_keys+0x114/0x1e4)
(ieee80211_free_keys) (ieee80211_del_virtual_monitor+0x51c/0x850)
(ieee80211_del_virtual_monitor) (ieee80211_stop+0x30/0x3c)
(ieee80211_stop) (__dev_close_many+0x94/0xb8)
(__dev_close_many) (dev_close_many+0x5c/0xc8)
Restricting delayed decrement to station interface alone fixes the problem
and it makes sense to do so because delayed decrement is done to improve
roam time which is applicable only for client devices.
Signed-off-by: Manikanta Pubbisetty <mpubbise@codeaurora.org>
[ Upstream commit 19103a4bfb42f320395daa5616ece3e89e759d63 ]
As part of hw reconfig, only stations linked to AP interfaces are added
back to the driver ignoring those which are tied to AP_VLAN interfaces.
It is true that there could be stations tied to the AP_VLAN interface while
serving 4addr clients or when using AP_VLAN for VLAN operations; we should
be adding these stations back to the driver as part of hw reconfig, failing
to do so can cause functional issues.
In the case of ath10k driver, the following errors were observed.
ath10k_pci : failed to install key for non-existent peer XX:XX:XX:XX:XX:XX
Workqueue: events_freezable ieee80211_restart_work [mac80211]
(unwind_backtrace) from (show_stack+0x10/0x14)
(show_stack) (dump_stack+0x80/0xa0)
(dump_stack) (warn_slowpath_common+0x68/0x8c)
(warn_slowpath_null) (ieee80211_enable_keys+0x88/0x154 [mac80211])
(ieee80211_enable_keys) (ieee80211_reconfig+0xc90/0x19c8 [mac80211])
(ieee80211_reconfig]) (ieee80211_restart_work+0x8c/0xa0 [mac80211])
(ieee80211_restart_work) (process_one_work+0x284/0x488)
(process_one_work) (worker_thread+0x228/0x360)
(worker_thread) (kthread+0xd8/0xec)
(kthread) (ret_from_fork+0x14/0x24)
Also while bringing down the AP VAP, WARN_ONs and errors related to peer
removal were observed.
ath10k_pci : failed to clear all peer wep keys for vdev 0: -2
ath10k_pci : failed to disassociate station: 8c:fd:f0:0a:8c:f5 vdev 0: -2
(unwind_backtrace) (show_stack+0x10/0x14)
(warn_slowpath_null) (sta_set_sinfo+0xb98/0xc9c [mac80211])
(sta_set_sinfo [mac80211]) (__sta_info_flush+0xf0/0x134 [mac80211])
(__sta_info_flush [mac80211]) (ieee80211_stop_ap+0xe8/0x390 [mac80211])
(ieee80211_stop_ap [mac80211]) (__cfg80211_stop_ap+0xe0/0x3dc [cfg80211])
(__cfg80211_stop_ap [cfg80211]) (cfg80211_stop_ap+0x30/0x44 [cfg80211])
(cfg80211_stop_ap [cfg80211]) (genl_rcv_msg+0x274/0x30c)
(genl_rcv_msg) (netlink_rcv_skb+0x58/0xac)
(netlink_rcv_skb) (genl_rcv+0x20/0x34)
(genl_rcv) (netlink_unicast+0x11c/0x204)
(netlink_unicast) (netlink_sendmsg+0x30c/0x370)
(netlink_sendmsg) (sock_sendmsg+0x70/0x84)
(sock_sendmsg) (___sys_sendmsg.part.3+0x188/0x228)
(___sys_sendmsg.part.3) (__sys_sendmsg+0x4c/0x70)
(__sys_sendmsg) (ret_fast_syscall+0x0/0x44)
These issues got fixed by adding the stations which are
tied to AP_VLANs back to the driver.
[ Upstream commit 914eac248d876f9c00cd1792ffec3d182c863f13 ]
2016 spec, section 10.24.2 specifies that the block ack
timeout in the ADD BA request is advisory.
That means we should check the value in the response and
act upon it (same as buffer size).
[ Upstream commit 407879b690ba3a6bf29be896d02dad63463bd1c0 ]
The IEEE P802.11-REVmd D1.0 specification updated the SAE authentication
timeout to be 2000 milliseconds (see dot11RSNASAERetransPeriod). Update
the SAE timeout setting accordingly.
While at it, reduce some code duplication in the timeout configuration.
[ Upstream commit b323ac19b7734a1c464b2785a082ee50bccd3b91 ]
Fixes rx for 4-addr packets in AP mode. These may be used for setting
up a 4-addr link for stations that are allowed to do so.
[ Upstream commit 3b07029729e347f288c70227cfe3c66b085d6b0b ]
In case an ADDBA request is received while there is already
an ongoing BA sessions with the same parameters, i.e., update
flow, an ADBBA response with decline status was sent twice. Fix it.
[ Upstream commit 191da271ac260700db3e5b4bb982a17ca78769d6 ]
Some APs include a non global operating class in their extended channel
switch information element. In such a case, as the operating class is not
known, mac80211 would decide to disconnect.
However the specification states that the operating class needs to be
taken from Annex E, but it does not specify from which table it should be
taken, so it is valid for an AP to use a non global operating class.
To avoid possibly unneeded disconnection, in such a case ignore the
operating class and assume that the current band is used, and if the
resulting channel and band configuration is invalid disconnect.
[ Upstream commit 95f3ce6a77893ac828ba841df44421620de4314b ]
sta_info_alloc can be called from atomic paths (such as RX path)
so we need to call pcpu_alloc with the correct gfp.
Fixes: c9c5962b56c1 ("mac80211: enable collecting station statistics per-CPU")
[ Upstream commit d78d9ee9d40aca4781d2c5334972544601a4c3a2 ]
If sta_info_alloc fails after allocating the per CPU statistics,
they are not properly freed.
[ Upstream commit c4de37ee2b55deac7d6aeac33e02e3d6be243898 ]
mesh TTL offset in Mesh Channel Switch Parameters element depends on
not only Secondary Channel Offset element, but also affected by
HT Control field and Wide Bandwidth Channel Switch element.
So use element structure to manipulate mesh channel swich param IE
after removing its constant attribution to correct the miscalculation.
Signed-off-by: Peter Oh <peter.oh@bowerswilkins.com>
[ Upstream commit 3a3713ec360138f806c6fc368d1de570f692b347 ]
Instead of calling ieee80211_recalc_txpower on monitor interfaces
directly, call it using the virtual monitor interface, if one exists.
In case of a single monitor interface given, reject setting TX power,
if no virtual monitor interface exists.
That being checked, don't warn in ieee80211_bss_info_change_notify,
after setting TX power on a monitor interface.
Fixes warning:
WARNING: CPU: 0 PID: 2193 at net/mac80211/driver-ops.h:167
ieee80211_bss_info_change_notify+0x111/0x190 Modules linked in: uvcvideo
videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_core
rndis_host cdc_ether usbnet mii tp_smapi(O) thinkpad_ec(O) ohci_hcd vboxpci(O)
vboxnetadp(O) vboxnetflt(O) v boxdrv(O) x86_pkg_temp_thermal kvm_intel kvm
irqbypass iwldvm iwlwifi ehci_pci ehci_hcd tpm_tis tpm_tis_core tpm CPU: 0
PID: 2193 Comm: iw Tainted: G O 4.12.12-gentoo #2 task:
ffff880186fd5cc0 task.stack: ffffc90001b54000 RIP:
0010:ieee80211_bss_info_change_notify+0x111/0x190 RSP: 0018:ffffc90001b57a10
EFLAGS: 00010246 RAX: 0000000000000006 RBX: ffff8801052ce840 RCX:
0000000000000064 RDX: 00000000fffffffc RSI: 0000000000040000 RDI:
ffff8801052ce840 RBP: ffffc90001b57a38 R08: 0000000000000062 R09:
0000000000000000 R10: ffff8802144b5000 R11: ffff880049dc4614 R12:
0000000000040000 R13: 0000000000000064 R14: ffff8802105f0760 R15:
ffffc90001b57b48 FS: 00007f92644b4580(0000) GS:ffff88021e200000(0000)
knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 00007f9263c109f0 CR3: 00000001df850000 CR4: 00000000000406f0
Call Trace:
ieee80211_recalc_txpower+0x33/0x40
ieee80211_set_tx_power+0x40/0x180
nl80211_set_wiphy+0x32e/0x950
Reported-by: Peter Große <pegro@friiks.de>
Signed-off-by: Peter Große <pegro@friiks.de>
[ Upstream commit c7976f5272486e4ff406014c4b43e2fa3b70b052 ]
In the ieee80211_setup_sdata() we check if the interface type is valid
and, if not, call BUG(). This should never happen, but if there is
something wrong with the code, it will not be caught until the bug
happens when an interface is being set up. Calling BUG() is too
extreme for this and a WARN_ON() would be better used instead. Change
that.
[ Upstream commit 736a80bbfda709fb3631f5f62056f250a38e5804 ]
If there are multiple mesh stations with the same MAC address,
they will both get confused and start throwing warnings.
Obviously in this case nothing can actually work anyway, so just
drop frames that look like they're from ourselves early on.
Reported-by: Gui Iribarren <gui@altermundi.net>
commit bee92d06157fc39d5d7836a061c7d41289a55797 upstream.
gcc-8 warns about some obviously incorrect code:
net/mac80211/cfg.c: In function 'cfg80211_beacon_dup':
net/mac80211/cfg.c:2896:3: error: 'memcpy' source argument is the same as destination [-Werror=restrict]
From the context, I conclude that we want to copy from beacon into
new_beacon, as we do in the rest of the function.
Fixes: 73da7d5bab79 ("mac80211: add channel switch command and beacon callbacks")
[ Upstream commit fbbdad5edf0bb59786a51b94a9d006bc8c2da9a2 ]
The previous path metric update from RANN frame has not considered
the own link metric toward the transmitting mesh STA. Fix this.
Reported-by: Michael65535
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com>
[ Upstream commit 7b6ddeaf27eca72795ceeae2f0f347db1b5f9a30 ]
When connected to a QoS/WMM AP, mac80211 should use a QoS NDP
for probing it, instead of a regular non-QoS one, fix this.
Change all the drivers to *not* allow QoS NDP for now, even
though it looks like most of them should be OK with that.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
For the reinstall prevention, the code I had added compares the
whole key. It turns out though that iwlwifi firmware doesn't
provide the TKIP TX MIC key as it's not needed in client mode,
and thus the comparison will always return false.
For client mode, thus always zero out the TX MIC key part before
doing the comparison in order to avoid accepting the reinstall
of the key with identical encryption and RX MIC key, but not the
same TX MIC key (since the supplicant provides the real one.)
Fixes: fdf7cb4185b6 ("mac80211: accept key reinstall without changing anything")
Ben reported that when the user rate mask is rejected for not
matching any basic rate, the driver had already been configured.
This is clearly an oversight in my original change, fix this by
doing the validation before calling the driver.
Fixes: e8e4f5280ddd ("mac80211: reject/clear user rate mask if not usable")
Otherwise we risk leaking information via timing side channel.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
When a key is reinstalled we can reset the replay counters
etc. which can lead to nonce reuse and/or replay detection
being impossible, breaking security properties, as described
in the "KRACK attacks".
In particular, CVE-2017-13080 applies to GTK rekeying that
happened in firmware while the host is in D3, with the second
part of the attack being done after the host wakes up. In
this case, the wpa_supplicant mitigation isn't sufficient
since wpa_supplicant doesn't know the GTK material.
In case this happens, simply silently accept the new key
coming from userspace but don't take any action on it since
it's the same key; this keeps the PN replay counters intact.
When an RX BA session is started by the driver, and it has to tell
mac80211 about it, the corresponding bit in tid_rx_manage_offl gets
set and the BA session work is scheduled. Upon testing this bit, it
will call __ieee80211_start_rx_ba_session(), thus deadlocking as it
already holds the ampdu_mlme.mtx, which that acquires again.
Fix this by adding ___ieee80211_start_rx_ba_session(), a version of
the function that requires the mutex already held.
Fixes: 699cb58c8a52 ("mac80211: manage RX BA session offload without SKB queue")
Reported-by: Matteo Croce <mcroce@redhat.com>
Commit 7a7c0a6438b8 ("mac80211: fix TX aggregation start/stop callback race")
added a cancellation of the ampdu work after the loop that stopped the
Tx and Rx BA sessions. However, in some cases, e.g., during HW reconfig,
the low level driver might call mac80211 APIs to complete the stopping
of the BA sessions, which would queue the ampdu work to handle the actual
completion. This work needs to be performed as otherwise mac80211 data
structures would not be properly synced.
Fix this by checking if BA session STOP_CB bit is set after the BA session
cancellation and properly clean the session.
[Johannes: the work isn't flushed because that could do other things we
don't want, and the locking situation isn't clear]
When HW ROC is supported it is possible that after the HW notified
that the ROC has started, the ROC was cancelled and another ROC was
added while the hw_roc_start worker is waiting on the mutex (since
cancelling the ROC and adding another one also holds the same mutex).
As a result, the hw_roc_start worker will continue to run after the
new ROC is added but before it is actually started by the HW.
This may result in notifying userspace that the ROC has started before
it actually does, or in case of management tx ROC, in an attempt to
tx while not on the right channel.
In addition, when the driver will notify mac80211 that the second ROC
has started, mac80211 will warn that this ROC has already been
notified.
Fix this by flushing the hw_roc_start work before cancelling an ROC.
Signed-off-by: Avraham Stern <avraham.stern@intel.com>
Since drv_wake_tx_queue() is normally called in the TX path, which
is already in an RCU critical section, we should call it the same
way in the aggregation code path, so if the driver expects to be
able to use RCU, it'll already be protected without having to enter
a nested critical section.
Additionally, disable soft-IRQs, since not doing so could cause
issues in a driver that relies on them already being disabled like
in the other path.
Fixes: ba8c3d6f16a1 ("mac80211: add an intermediate software queue implementation")
This change adds null pointer check before dereferencing pointer dev on
netif_tx_start_all_queues() when an interface is added.
With iTXQ support, netif_tx_start_all_queues() is always called while
an interface is added. however, the netdev queues are not associated
and dev is null when the interface is either NL80211_IFTYPE_P2P_DEVICE
or NL80211_IFTYPE_NAN.
Signed-off-by: Chunho Lee <ch.lee@newracom.com>
