commit d0c22119f574b851e63360c6b8660fe9593bbc3c upstream.
The mesh forwarding path was not checking that data
frames were protected when running an encrypted network;
add the necessary check.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Bob Copeland <me@bobcopeland.com>
commit aa75ebc275b2a91b193654a177daf900ad6703f0 upstream.
Some APs experience problems when working with
U-APSD. Decreasing the probability of that
happening by using legacy mode for all ACs but VO
isn't enough.
Cisco 4410N originally forced us to enable VO by
default only because it treated non-VO ACs as
legacy.
However some APs (notably Netgear R7000) silently
reclassify packets to different ACs. Since u-APSD
ACs require trigger frames for frame retrieval
clients would never see some frames (e.g. ARP
responses) or would fetch them accidentally after
a long time.
It makes little sense to enable u-APSD queues by
default because it needs userspace applications to
be aware of it to actually take advantage of the
possible additional powersavings. Implicitly
depending on driver autotrigger frame support
doesn't make much sense.
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
commit 9c1c98a3bb7b7593b60264b9a07e001e68b46697 upstream.
The current minstrel_ht rate control behavior is somewhat optimistic in
trying to find optimum TX rate. While this is usually fine for normal
Data frames, there are cases where a more conservative set of retry
parameters would be beneficial to make the connection more robust.
EAPOL frames are critical to the authentication and especially the
EAPOL-Key message 4/4 (the last message in the 4-way handshake) is
important to get through to the AP. If that message is lost, the only
recovery mechanism in many cases is to reassociate with the AP and start
from scratch. This can often be avoided by trying to send the frame with
more conservative rate and/or with more link layer retries.
In most cases, minstrel_ht is currently using the initial EAPOL-Key
frames for probing higher rates and this results in only five link layer
transmission attempts (one at high(ish) MCS and four at MCS0). While
this works with most APs, it looks like there are some deployed APs that
may have issues with the EAPOL frames using HT MCS immediately after
association. Similarly, there may be issues in cases where the signal
strength or radio environment is not good enough to be able to get
frames through even at couple of MCS 0 tries.
The best approach for this would likely to be to reduce the TX rate for
the last rate (3rd rate parameter in the set) to a low basic rate (say,
6 Mbps on 5 GHz and 2 or 5.5 Mbps on 2.4 GHz), but doing that cleanly
requires some more effort. For now, we can start with a simple one-liner
that forces the minimum rate to be used for EAPOL frames similarly how
the TX rate is selected for the IEEE 802.11 Management frames. This does
result in a small extra latency added to the cases where the AP would be
able to receive the higher rate, but taken into account how small number
of EAPOL frames are used, this is likely to be insignificant. A future
optimization in the minstrel_ht design can also allow this patch to be
reverted to get back to the more optimized initial TX rate.
It should also be noted that many drivers that do not use minstrel as
the rate control algorithm are already doing similar workarounds by
forcing the lowest TX rate to be used for EAPOL frames.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
commit 3a5c5e81d8128a9e43abc52b75dd21d3da7a0cfc upstream.
Fix a regression introduced by commit a5e70697d0c4 ("mac80211: add radiotap flag
and handling for 5/10 MHz") where the IEEE80211_CHAN_CCK channel type flag was
incorrectly replaced by the IEEE80211_CHAN_OFDM flag. This commit fixes that by
using the CCK flag again.
Fixes: a5e70697d0c4 ("mac80211: add radiotap flag and handling for 5/10 MHz")
Signed-off-by: Mathy Vanhoef <vanhoefm@gmail.com>
commit 28a9bc68124c319b2b3dc861e80828a8865fd1ba upstream.
When writing the code to allow per-station GTKs, I neglected to
take into account the management frame keys (index 4 and 5) when
freeing the station and only added code to free the first four
data frame keys.
Fix this by iterating the array of keys over the right length.
Fixes: e31b82136d1a ("cfg80211/mac80211: allow per-station GTKs")
commit d025933e29872cb1fe19fc54d80e4dfa4ee5779c upstream.
As multicast-frames can't be fragmented, "dot11MulticastReceivedFrameCount"
stopped being incremented after the use-after-free fix. Furthermore, the
RX-LED will be triggered by every multicast frame (which wouldn't happen
before) which wouldn't allow the LED to rest at all.
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=89431 which also had the
patch.
Fixes: b8fff407a180 ("mac80211: fix use-after-free in defragmentation")
Signed-off-by: Andreas Müller <goo@stapelspeicher.org>
[rewrite commit message]
commit b8fff407a180286aa683d543d878d98d9fc57b13 upstream.
Upon receiving the last fragment, all but the first fragment
are freed, but the multicast check for statistics at the end
of the function refers to the current skb (the last fragment)
causing a use-after-free bug.
Since multicast frames cannot be fragmented and we check for
this early in the function, just modify that check to also
do the accounting to fix the issue.
Reported-by: Yosef Khyal <yosefx.khyal@intel.com>
commit ff1e417c7c239b7abfe70aa90460a77eaafc7f83 upstream.
Due to the time it takes to process the beacon that started the CSA
process, we may be late for the switch if we try to reach exactly
beacon 0. To avoid that, use count - 1 when calculating the switch time.
Reported-by: Jouni Malinen <j@w1.fi>
Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
commit 46238845bd609a5c0fbe076e1b82b4c5b33360b2 upstream.
When an interface is deleted, an ongoing hardware scan is canceled and
the driver must abort the scan, at the very least reporting completion
while the interface is removed.
However, if it scheduled the work that might only run after everything
is said and done, which leads to cfg80211 warning that the scan isn't
reported as finished yet; this is no fault of the driver, it already
did, but mac80211 hasn't processed it.
To fix this situation, flush the delayed work when the interface being
removed is the one that was executing the scan.
Reported-by: Sujith Manoharan <sujith@msujith.org>
Tested-by: Sujith Manoharan <sujith@msujith.org>
commit c7abf25af0f41be4b50d44c5b185d52eea360cb8 upstream.
It affects non-(V)HT rates and can lead to selecting an rts_cts rate
that is not a basic rate or way superior to the reference rate (ATM
rates[0] used for the 1st attempt of the protected frame data).
E.g, assuming drivers register growing (bitrate) sorted tables of
ieee80211_rate-s, having :
- rates[0].idx == d'2 and basic_rates == b'10100
will select rts_cts idx b'10011 & ~d'(BIT(2)-1), i.e. 1, likewise
- rates[0].idx == d'2 and basic_rates == b'10001
will select rts_cts idx b'10000
The first is not a basic rate and the second is > rates[0].
Also, wrt severity of the addressed misbehavior, ATM we only have one
rts_cts_rate_idx rather than one per rate table entry, so this idx might
still point to bitrates > rates[1..MAX_RATES].
Fixes: 5253ffb8c9e1 ("mac80211: always pick a basic rate to tx RTS/CTS for pre-HT rates")
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
commit bb512ad0732232f1d2693bb68f31a76bed8f22ae upstream.
This reverts commit 24aa11ab8ae03292d38ec0dbd9bc2ac49fe8a6dd.
That commit was wrong since it uses data that hasn't even been set
up yet, but might be a hold-over from a previous connection.
Additionally, it seems like a driver-specific workaround that
shouldn't have been in mac80211 to start with.
Fixes: 24aa11ab8ae0 ("mac80211: disable uAPSD if all ACs are under ACM")
Reviewed-by: Luciano Coelho <luciano.coelho@intel.com>
commit 448cd2e248732326632957e52ea9c44729affcb2 upstream.
In case of beacon_loss with IEEE80211_HW_CONNECTION_MONITOR
device, mac80211 probes the ap (and disconnects on timeout)
but ignores the ack.
If we already got an ack, there's no reason to continue
disconnecting. this can help devices that supports
IEEE80211_HW_CONNECTION_MONITOR only partially (e.g. take
care of keep alives, but does not probe the ap.
In case the device wants to disconnect without probing,
it can just call ieee80211_connection_loss.
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
commit 08b9939997df30e42a228e1ecb97f99e9c8ea84e upstream.
This reverts commit 277d916fc2e959c3f106904116bb4f7b1148d47a as it was
at least breaking iwlwifi by setting the IEEE80211_TX_CTL_NO_PS_BUFFER
flag in all kinds of interface modes, not only for AP mode where it is
appropriate.
To avoid reintroducing the original problem, explicitly check for probe
request frames in the multicast buffering code.
Fixes: 277d916fc2e9 ("mac80211: move "bufferable MMPDU" check to fix AP mode scan")
commit 53d045258ee2e38b1e882617cb0799a04d05f5fa upstream.
If the rate control algorithm uses a selection table, it
is leaked when the station is destroyed - fix that.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Reported-by: Christophe Prévotaux <cprevotaux@nltinc.com>
Fixes: 0d528d85c519 ("mac80211: improve the rate control API")
[add commit log entry, remove pointless NULL check]
commit 923eaf367206e01f22c97aee22300e332d071916 upstream.
Doing so will lead to an oops for a p2p-dev interface, since it has
no netdev.
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit c7d37a66e345df2fdf1aa7b2c9a6d3d53846ca5b upstream.
Without this fix, freshly rebooted Linux creates a new IBSS
instead of joining an existing one. Only when jiffies counter
overflows after 5 minutes the IBSS can be successfully joined.
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
[edit commit message slightly]
[ Upstream commit 87757a917b0b3c0787e0563c679762152be81312 ]
unregister_netdevice_many() API is error prone and we had too
many bugs because of dangling LIST_HEAD on stacks.
See commit f87e6f47933e3e ("net: dont leave active on stack LIST_HEAD")
In fact, instead of making sure no caller leaves an active list_head,
just force a list_del() in the callee. No one seems to need to access
the list after unregister_netdevice_many()
commit c52666aef9f2dff39276eb53f15d99e2e229870f upstream.
If the association is in progress while we suspend, the
stack will be in a messed up state. Clean it before we
suspend.
This patch completes Johannes's patch:
1a1cb744de160ee70086a77afff605bbc275d291
Author: Johannes Berg <johannes.berg@intel.com>
mac80211: fix suspend vs. authentication race
Fixes: 12e7f517029d ("mac80211: cleanup generic suspend/resume procedures")
commit b4b177a5556a686909e643f1e9b6434c10de079f upstream.
Jouni reported that if a remain-on-channel was active on the
same channel as the current operating channel, then the ROC
would start, but any frames transmitted using mgmt-tx on the
same channel would get delayed until after the ROC.
The reason for this is that the ROC starts, but doesn't have
any handling for "remain on the same channel", so it stops
the interface queues. The later mgmt-tx then puts the frame
on the interface queues (since it's on the current operating
channel) and thus they get delayed until after the ROC.
To fix this, add some logic to handle remaining on the same
channel specially and not stop the queues etc. in this case.
This not only fixes the bug but also improves behaviour in
this case as data frames etc. can continue to flow.
Cc: stable@vger.kernel.org
Tested-by: Jouni Malinen <j@w1.fi>
commit 764152ff66f4a8be1f9d7981e542ffdaa5bd7aff upstream.
Their power value is initialized to zero. This patch fixes an issue
where the configured power drops to the minimum value when AP_VLAN
interfaces are created/removed.
commit 115b943a6ea12656088fa1ff6634c0d30815e55b upstream.
Jouni reported that when doing off-channel transmissions mixed
with on-channel transmissions, the on-channel ones ended up on
the off-channel in some cases.
The reason for that is that during the refactoring of the off-
channel code, I lost the part that stopped all activity and as
a consequence the on-channel frames (including data frames)
were no longer queued but would be transmitted on the temporary
channel.
Fix this by simply restoring the lost activity stop call.
Fixes: 2eb278e083549 ("mac80211: unify SW/offload remain-on-channel")
commit 1a1cb744de160ee70086a77afff605bbc275d291 upstream.
Since Stanislaw's patch removing the quiescing code, mac80211 had
a race regarding suspend vs. authentication: as cfg80211 doesn't
track authentication attempts, it can't abort them. Therefore the
attempts may be kept running while suspending, which can lead to
all kinds of issues, in at least some cases causing an error in
iwlmvm firmware.
Fix this by aborting the authentication attempt when suspending.
commit 112c44b2df0984121a52fbda89425843b8e1a457 upstream.
commit de74a1d9032f4d37ea453ad2a647e1aff4cd2591
"mac80211: fix WPA with VLAN on AP side with ps-sta"
fixed an issue where queued multicast packets would
be sent out encrypted with the key of an other bss.
commit "7cbf9d017dbb5e3276de7d527925d42d4c11e732"
"mac80211: fix oops on mesh PS broadcast forwarding"
essentially reverted it, because vif.type cannot be AP_VLAN
due to the check to vif.type in ieee80211_get_buffered_bc before.
As the later commit intended to fix the MESH case, fix it
by checking for IFTYPE_AP instead of IFTYPE_AP_VLAN.
Fixes: 7cbf9d017dbb ("mac80211: fix oops on mesh PS broadcast forwarding")
Signed-off-by: Michael Braun <michael-dev@fami-braun.de>
commit d2722f8b87fb172ff2f31d3a2816b31d58678d40 upstream.
The bss struct might be freed in ieee80211_rx_bss_put(),
so we shouldn't use it afterwards.
Fixes: 817cee7675237 ("mac80211: track AP's beacon rate and give it to the driver")
commit 864a6040f395464003af8dd0d8ca86fed19866d4 upstream.
Avoid leaking data by sending uninitialized memory and setting an
invalid (non-zero) fragment number (the sequence number is ignored
anyway) by setting the seq_ctrl field to zero.
Fixes: 3f52b7e328c5 ("mac80211: mesh power save basics")
Fixes: ce662b44ce22 ("mac80211: send (QoS) Null if no buffered frames")
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit cb664981607a6b5b3d670ad57bbda893b2528d96 upstream.
When a VHT network uses 20 or 40 MHz as per the HT operation
information, the channel center frequency segment 0 field in
the VHT operation information is reserved, so ignore it.
This fixes association with such networks when the AP puts 0
into the field, previously we'd disconnect due to an invalid
channel with the message
wlan0: AP VHT information is invalid, disable VHT
Fixes: f2d9d270c15ae ("mac80211: support VHT association")
Reported-by: Tim Nelson <tim.l.nelson@gmail.com>
commit 963a1852fbac4f75a2d938fa2e734ef1e6d4c044 upstream.
The MLME code in mac80211 must track whether or not the AP changed
bandwidth, but if there's no change while tracking it shouldn't do
anything, otherwise regulatory updates can make it impossible to
connect to certain APs if the regulatory database doesn't match the
information from the AP. See the precise scenario described in the
code.
This still leaves some possible problems with CSA or if the AP
actually changed bandwidth, but those cases are less common and
won't completely prevent using it.
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=70881
Reported-and-tested-by: Nate Carlson <kernel@natecarlson.com>
commit 1d147bfa64293b2723c4fec50922168658e613ba upstream.
There is a race between the TX path and the STA wakeup: while
a station is sleeping, mac80211 buffers frames until it wakes
up, then the frames are transmitted. However, the RX and TX
path are concurrent, so the packet indicating wakeup can be
processed while a packet is being transmitted.
This can lead to a situation where the buffered frames list
is emptied on the one side, while a frame is being added on
the other side, as the station is still seen as sleeping in
the TX path.
As a result, the newly added frame will not be send anytime
soon. It might be sent much later (and out of order) when the
station goes to sleep and wakes up the next time.
Additionally, it can lead to the crash below.
Fix all this by synchronising both paths with a new lock.
Both path are not fastpath since they handle PS situations.
In a later patch we'll remove the extra skb queue locks to
reduce locking overhead.
BUG: unable to handle kernel
NULL pointer dereference at 000000b0
IP: [<ff6f1791>] ieee80211_report_used_skb+0x11/0x3e0 [mac80211]
*pde = 00000000
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
EIP: 0060:[<ff6f1791>] EFLAGS: 00210282 CPU: 1
EIP is at ieee80211_report_used_skb+0x11/0x3e0 [mac80211]
EAX: e5900da0 EBX: 00000000 ECX: 00000001 EDX: 00000000
ESI: e41d00c0 EDI: e5900da0 EBP: ebe458e4 ESP: ebe458b0
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR0: 8005003b CR2: 000000b0 CR3: 25a78000 CR4: 000407d0
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
Process iperf (pid: 3934, ti=ebe44000 task=e757c0b0 task.ti=ebe44000)
iwlwifi 0000:02:00.0: I iwl_pcie_enqueue_hcmd Sending command LQ_CMD (#4e), seq: 0x0903, 92 bytes at 3[3]:9
Stack:
e403b32c ebe458c4 00200002 00200286 e403b338 ebe458cc c10960bb e5900da0
ff76a6ec ebe458d8 00000000 e41d00c0 e5900da0 ebe458f0 ff6f1b75 e403b210
ebe4598c ff723dc1 00000000 ff76a6ec e597c978 e403b758 00000002 00000002
Call Trace:
[<ff6f1b75>] ieee80211_free_txskb+0x15/0x20 [mac80211]
[<ff723dc1>] invoke_tx_handlers+0x1661/0x1780 [mac80211]
[<ff7248a5>] ieee80211_tx+0x75/0x100 [mac80211]
[<ff7249bf>] ieee80211_xmit+0x8f/0xc0 [mac80211]
[<ff72550e>] ieee80211_subif_start_xmit+0x4fe/0xe20 [mac80211]
[<c149ef70>] dev_hard_start_xmit+0x450/0x950
[<c14b9aa9>] sch_direct_xmit+0xa9/0x250
[<c14b9c9b>] __qdisc_run+0x4b/0x150
[<c149f732>] dev_queue_xmit+0x2c2/0xca0
Reported-by: Yaara Rozenblum <yaara.rozenblum@intel.com>
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
[reword commit log, use a separate lock]
commit 1bf4bbb4024dcdab5e57634dd8ae1072d42a53ac upstream.
Improves reliability of wifi connections with WPA, since authentication
frames are prioritized over normal traffic and also typically exempt
from aggregation.
commit 338f977f4eb441e69bb9a46eaa0ac715c931a67f upstream.
The "new" fragmentation code (since my rewrite almost 5 years ago)
erroneously sets skb->len rather than using skb_trim() to adjust
the length of the first fragment after copying out all the others.
This leaves the skb tail pointer pointing to after where the data
originally ended, and thus causes the encryption MIC to be written
at that point, rather than where it belongs: immediately after the
data.
The impact of this is that if software encryption is done, then
a) encryption doesn't work for the first fragment, the connection
becomes unusable as the first fragment will never be properly
verified at the receiver, the MIC is practically guaranteed to
be wrong
b) we leak up to 8 bytes of plaintext (!) of the packet out into
the air
This is only mitigated by the fact that many devices are capable
of doing encryption in hardware, in which case this can't happen
as the tail pointer is irrelevant in that case. Additionally,
fragmentation is not used very frequently and would normally have
to be configured manually.
Fix this by using skb_trim() properly.
Fixes: 2de8e0d999b8 ("mac80211: rewrite fragmentation")
commit 0297ea17bf7879fb5846fafd1be4c0471e72848d upstream.
When the driver cannot start the AP or when the assignement
of the beacon goes wrong, we need to unassign the vif.
commit 2f617435c3a6fe3f39efb9ae2baa77de2d6c97b8 upstream.
ieee80211_start_roc_work() might add a new roc
to existing roc, and tell cfg80211 it has already
started.
However, this might happen before the roc cookie
was set, resulting in REMAIN_ON_CHANNEL (started)
event with null cookie. Consequently, it can make
wpa_supplicant go out of sync.
Fix it by setting the roc cookie earlier.
Signed-off-by: Eliad Peller <eliad@wizery.com>
commit 277d916fc2e959c3f106904116bb4f7b1148d47a upstream.
The check needs to apply to both multicast and unicast packets,
otherwise probe requests on AP mode scans are sent through the multicast
buffer queue, which adds long delays (often longer than the scanning
interval).
commit 051a41fa4ee14f5c39668f0980973b9a195de560 upstream.
Multicast frames can't be transmitted as part of an aggregation
session (such a session couldn't even be set up) so don't try to
reorder them. Trying to do so would cause the reorder to stop
working correctly since multicast QoS frames (as transmitted by
the Aruba APs this was found with) would cause sequence number
confusion in the buffer.
Reported-by: Blaise Gassend <blaise@suitabletech.com>
commit 18db594a1005d908d995a2fc8f5a7bf4286fdca0 upstream.
When changing cfg80211 to use RTNL locking, this caused a
deadlock in mac80211 as it calls cfg80211_sched_scan_stopped()
from a work item that's on a workqueue that is flushed with
the RTNL held.
Fix this by simply using schedule_work(), the work only needs
to finish running before the wiphy is unregistered, no other
synchronisation (e.g. with suspend) is really required since
for suspend userspace is already blocked anyway when we flush
the workqueue so will only pick up the event after resume.
Fixes: 5fe231e87372 ("cfg80211: vastly simplify locking")
Reported-and-tested-by: Eliad Peller <eliadx.peller@intel.com>
commit 2d3db210860f1df099a35b1dd54cca35454e0361 upstream.
This reverts commit ee1f668136b2fb6640ee2d54c2a525ea41f98211.
The aformentioned commit added a check to allow
'iw wlan0 set power_save off' to work for mesh interfaces.
However, this is problematic because it also allows
'iw wlan0 set power_save on', which will crash in short order
because all of the subsequent code manipulates sdata->u.mgd.
The power-saving states for mesh interfaces can be manipulated
through the mesh config, e.g:
'iw wlan0 set mesh_param mesh_power_save=active' (which,
despite the name, actualy disables power saving since the
setting refers to the type of sleep the interface undergoes).
Fixes: ee1f668136b2 ("mac80211: allow disable power save in mesh")
If a frame's timestamp is calculated, and the bitrate
calculation goes wrong and returns zero, the system
will attempt to divide by zero and crash. Catch this
case and print the rate information that the driver
reported when this happens.
Reported-by: Thomas Lindroth <thomas.lindroth@gmail.com>
__ieee80211_scan_completed is called from a worker. This
means that the following flow is possible.
* driver calls ieee80211_scan_completed
* mac80211 cancels the scan (that is already complete)
* __ieee80211_scan_completed runs
When scan_work will finally run, it will see that the scan
hasn't been aborted and might even trigger another scan on
another band. This leads to a situation where cfg80211's
scan is not done and no further scan can be issued.
Fix this by setting a new flag when a HW scan is being
cancelled so that no other scan will be triggered.
mac80211 scan processing could get stuck if roc work for pending, but
not started when a scan request was deferred due to such roc item.
Normally the deferred scan would be started from
ieee80211_start_next_roc(), but ieee80211_sw_roc_work() calls that only
if the finished ROC was started. Fix this by calling
ieee80211_run_deferred_scan() in the case the last ROC was not actually
started.
This issue was hit relatively easily in P2P find operations where Listen
state (remain-on-channel) and Search state (scan) are repeated in a
loop.
Signed-off-by: Jouni Malinen <j@w1.fi>
When clients are idle for too long, hostapd sends nullfunc frames for
probing. When those are acked by the client, the idle time needs to be
updated.
To make this work (and to avoid unnecessary probing), update sta->last_rx
whenever an ACK was received for a tx packet. Only do this if the flag
IEEE80211_HW_REPORTS_TX_ACK_STATUS is set.
This allows calls for clients in AP_VLANs (e.g. for 4-addr) to succeed
The patch "mac80211: select and adjust bitrates according to
channel mode" causes regression and breaks the extended supported rate
IE setting. Since "i" is starting with 8, so this is not necessary
to introduce "skip" here.
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@cozybit.com>
Signed-off-by: Colleen Twitty <colleen@cozybit.com>
Reviewed-by: Jason Abele <jason@cozybit.com>
If an Ad-Hoc node receives packets with the Cell ID or its own MAC
address as source address, it hits a WARN_ON in sta_info_insert_check()
With many packets, this can massively spam the logs. One way that this
can easily happen is through having Cisco APs in the area with rouge AP
detection and countermeasures enabled.
Such Cisco APs will regularly send fake beacons, disassoc and deauth
packets that trigger these warnings.
To fix this issue, drop such spoofed packets early in the rx path.
Reported-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
drivers/net/wireless/iwlwifi/pcie/trans.c
net/mac80211/ibss.c
Jouni reported that with mac80211_hwsim, multicast TX was causing
crashes due to invalid vif->cab_queue assignment. It turns out that
this is caused by change_interface() getting invoked and not having
the vif->type/vif->p2p assigned correctly before calling the queue
check (ieee80211_check_queues). Fix this by passing the 'external'
interface type to the function and adjusting it accordingly.
While at it, also fix the error path in change_interface, it wasn't
correctly resetting to the external type but using the internal one
instead.
Fortunately this affects on hwsim because all other drivers set the
vif->type/vif->p2p variables when changing iftype. This shouldn't
be needed, but almost all implementations actually do it for their
own internal handling.
Seth reports that some APs, notably the Netgear WNDAP360, send
invalid ECSA IEs in probe response frames with the operating
class and channel number both set to zero, even when no channel
switch is being done. As a result, any scan while connected to
such an AP results in the connection being dropped.
Fix this by ignoring any channel switch announcment in probe
response frames entirely, since we're connected to the AP we
will be receiving a beacon (and maybe even an action frame) if
a channel switch is done, which is sufficient.
Cc: stable@vger.kernel.org # 3.10
Reported-by: Seth Forshee <seth.forshee@canonical.com>
Tested-by: Seth Forshee <seth.forshee@canonical.com>
Add flags intended to report various auxiliary information
and introduce the NL80211_RXMGMT_FLAG_ANSWERED flag to report
that the frame was already answered by the device.
Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com>
[REPLIED->ANSWERED, reword commit message]
According to 802.11-2012 9.3.2.10, paragraph 4, QoS
data frames with a group address in the Address 1 field
have sequence numbers allocated from the same counter
as non-QoS data and management frames. Without this
flag, some drivers may not assign sequence numbers, and
in rare cases frames might get dropped. Set the control
flag accordingly.
Signed-off-by: Bob Copeland <bob@cozybit.com>
