commit e6436be21e77e3659b4ff7e357ab5a8342d132d2 upstream.
In the case that dev_alloc_name() fails, e.g. because the name was
given by the user and already exists, we need to clean up properly
and free the per-CPU statistics. Fix that.
Fixes: 5a490510ba5f ("mac80211: use per-CPU TX/RX statistics")
commit 2a58d42c1e018ad514d4e23fd33fb2ded95d3ee6 upstream.
The driver can access the queue simultanously
while mac80211 tears down the interface. Without
spinlock protection this could lead to corrupting
sk_buff_head and subsequently to an invalid
pointer dereference.
Fixes: ba8c3d6f16a1 ("mac80211: add an intermediate software queue implementation")
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
commit cf44012810ccdd8fd947518e965cb04b7b8498be upstream.
The ieee80211_queue_stopped() expects hw queue
number but it was given raw WMM AC number instead.
This could cause frame drops and problems with
traffic in some cases - most notably if driver
doesn't map AC numbers to queue numbers 1:1 and
uses ieee80211_stop_queues() and
ieee80211_wake_queue() only without ever calling
ieee80211_wake_queues().
On ath10k it was possible to hit this problem in
the following case:
1. wlan0 uses queue 0
(ath10k maps queues per vif)
2. offchannel uses queue 15
3. queues 1-14 are unused
4. ieee80211_stop_queues()
5. ieee80211_wake_queue(q=0)
6. ieee80211_wake_queue(q=15)
(other queues are not woken up because both
driver and mac80211 know other queues are
unused)
7. ieee80211_rx_h_mesh_fwding()
8. ieee80211_select_queue_80211() returns 2
9. ieee80211_queue_stopped(q=2) returns true
10. frame is dropped (oops!)
Fixes: d3c1597b8d1b ("mac80211: fix forwarded mesh frame queue mapping")
commit d321cd014e51baab475efbdec468255b9e0ec822 upstream.
When joining IBSS a full scan should be initiated in order to search
for existing cell, unless the fixed_channel parameter was set.
A default channel to create the IBSS on if no cell was found is
provided as well.
However - a scan is initiated only on the default channel provided
regardless of whether ifibss->fixed_channel is set or not, with the
obvious result of the cell not joining existing IBSS cell that is
on another channel.
Fixes: 76bed0f43b27 ("mac80211: IBSS fix scan request")
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 0ef049dc1167fe834d0ad5d63f89eddc5c70f6e4 upstream.
When CONFIG_OPTIMIZE_INLINING is set, the sta_info_insert_finish
function consumes more stack than normally, exceeding the
1024 byte limit on ARM:
net/mac80211/sta_info.c: In function 'sta_info_insert_finish':
net/mac80211/sta_info.c:561:1: error: the frame size of 1080 bytes is larger than 1024 bytes [-Werror=frame-larger-than=]
It turns out that there are two functions that put a 'struct station_info'
on the stack: __sta_info_destroy_part2 and sta_info_insert_finish, and
this structure alone requires up to 792 bytes.
Hoping that both are called rarely enough, this replaces the
on-stack structure with a dynamic allocation, which unfortunately
requires some suboptimal error handling for out-of-memory.
The __sta_info_destroy_part2 function is actually affected by the
stack usage twice because it calls cfg80211_del_sta_sinfo(), which
has another instance of struct station_info on its stack.
Fixes: 98b6218388e3 ("mac80211/cfg80211: add station events")
Fixes: 6f7a8d26e266 ("mac80211: send statistics with delete station event")
commit 62b14b241ca6f790a17ccd9dd9f62ce1b006d406 upstream.
The original hand-implemented hash-table in mac80211 couldn't result
in insertion errors, and while converting to rhashtable I evidently
forgot to check the errors.
This surfaced now only because Ben is adding many identical keys and
that resulted in hidden insertion errors.
Fixes: 7bedd0cfad4e1 ("mac80211: use rhashtable for station table")
Reported-by: Ben Greear <greearb@candelatech.com>
commit 1ec7bae8bec9b72e347e01330c745ab5cdd66f0e upstream.
Public Action frames use special rules for how the BSSID field (Address
3) is set. A wildcard BSSID is used in cases where the transmitter and
recipient are not members of the same BSS. As such, we need to accept
Public Action frames with wildcard BSSID.
Commit db8e17324553 ("mac80211: ignore frames between TDLS peers when
operating as AP") added a rule that drops Action frames to TDLS-peers
based on an Action frame having different DA (Address 1) and BSSID
(Address 3) values. This is not correct since it misses the possibility
of BSSID being a wildcard BSSID in which case the Address 1 would not
necessarily match.
Fix this by allowing mac80211 to accept wildcard BSSID in an Action
frame when in AP mode.
Fixes: db8e17324553 ("mac80211: ignore frames between TDLS peers when operating as AP")
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
commit 9acc54beb474c81148e2946603d141cf8716b19f upstream.
Just like for CCMP we need to check that for GCMP the fragments
have PNs that increment by one; the spec was updated to fix this
security issue and now has the following text:
The receiver shall discard MSDUs and MMPDUs whose constituent
MPDU PN values are not incrementing in steps of 1.
Adapt the code for CCMP to work for GCMP as well, luckily the
relevant fields already alias each other so no code duplication
is needed (just check the aliasing with BUILD_BUG_ON.)
commit c36dd3eaf1a674a45b58b922258d6eaa8932e292 upstream.
RTS/CTS needs to be enabled if the rate is a fallback rate *or* if it's
a dual-stream rate and the sta is in dynamic SMPS mode.
Fixes: a3ebb4e1b763 ("mac80211: minstrel_ht: handle peers in dynamic SMPS")
Reported-by: Matías Richart <mrichart@fing.edu.uy>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit 7a36b930e6ed4702c866dc74a5ad07318a57c688 upstream.
The value 5000 was put here with the addition of the timeout field to
ieee80211_start_tx_ba_session. It was originally added in mac80211 to
save resources for drivers like iwlwifi, which only supports a limited
number of concurrent aggregation sessions.
Since iwlwifi does not use minstrel_ht and other drivers don't need
this, 0 is a better default - especially since there have been
recent reports of aggregation setup related issues reproduced with
ath9k. This should improve stability without causing any adverse
effects.
Acked-by: Avery Pennarun <apenwarr@gmail.com>
commit f39ea2690bd61efec97622c48323f40ed6e16317 upstream.
Use kzalloc instead of kmalloc for struct tid_ampdu_rx to
initialize the "removed" field (all others are initialized
manually). That fixes:
UBSAN: Undefined behaviour in net/mac80211/rx.c:932:29
load of value 2 is not a valid value for type '_Bool'
CPU: 3 PID: 1134 Comm: kworker/u16:7 Not tainted 4.5.0-rc1+ #265
Workqueue: phy0 rt2x00usb_work_rxdone
0000000000000004 ffff880254a7ba50 ffffffff8181d866 0000000000000007
ffff880254a7ba78 ffff880254a7ba68 ffffffff8188422d ffffffff8379b500
ffff880254a7bab8 ffffffff81884747 0000000000000202 0000000348620032
Call Trace:
[<ffffffff8181d866>] dump_stack+0x45/0x5f
[<ffffffff8188422d>] ubsan_epilogue+0xd/0x40
[<ffffffff81884747>] __ubsan_handle_load_invalid_value+0x67/0x70
[<ffffffff82227b4d>] ieee80211_sta_reorder_release.isra.16+0x5ed/0x730
[<ffffffff8222ca14>] ieee80211_prepare_and_rx_handle+0xd04/0x1c00
[<ffffffff8222db03>] __ieee80211_rx_handle_packet+0x1f3/0x750
[<ffffffff8222e4a7>] ieee80211_rx_napi+0x447/0x990
While at it, convert to use sizeof(*tid_agg_rx) instead.
Fixes: 788211d81bfdf ("mac80211: fix RX A-MPDU session reorder timer deletion")
Signed-off-by: Chris Bainbridge <chris.bainbridge@gmail.com>
[reword commit message, use sizeof(*tid_agg_rx)]
commit 212c5a5e6ba61678be6b5fee576e38bccb50b613 upstream.
The change from cur_tp to the function
minstrel_get_tp_avg/minstrel_ht_get_tp_avg changed the unit used for the
current throughput. For example in minstrel_ht the correct
conversion between them would be:
mrs->cur_tp / 10 == minstrel_ht_get_tp_avg(..).
This factor 10 must also be included in the calculation of
minstrel_get_expected_throughput and minstrel_ht_get_expected_throughput to
return values with the unit [Kbps] instead of [10Kbps]. Otherwise routing
algorithms like B.A.T.M.A.N. V will make incorrect decision based on these
values. Its kernel based implementation expects expected_throughput always
to have the unit [Kbps] and not sometimes [10Kbps] and sometimes [Kbps].
The same requirement has iw or olsrdv2's nl80211 based statistics module
which retrieve the same data via NL80211_STA_INFO_TX_BITRATE.
Fixes: 6a27b2c40b48 ("mac80211: restructure per-rate throughput calculation into function")
Signed-off-by: Sven Eckelmann <sven@open-mesh.com>
commit 4fa11ec726a32ea6dd768dbb2e2af3453a98ec0a upstream.
During a sw scan ieee80211_iface_work ignores work items for all vifs.
However after the scan complete work is requeued only for STA, ADHOC
and MESH iftypes.
This occasionally results in event processing getting delayed/not
processed for iftype AP when it coexists with a STA. This can result
in data halt and eventually disconnection on the AP interface.
Signed-off-by: Sachin Kulkarni <Sachin.Kulkarni@imgtec.com>
An AP can send an operating channel width change in a beacon
opmode notification IE as long as there's a change in the nss as
well (See 802.11ac-2013 section 10.41).
So don't limit updating to nss only from an opmode notification IE.
Signed-off-by: Eyal Shapira <eyalx.shapira@intel.com>
When the AP is advertising limited TX power, the message can be
printed over and over again. Suppress it when the power level
isn't changing.
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=106011
During reprogramming, mac80211 currently first adds all the channel
contexts, then binds them to the vifs and then goes to reconfigure
all the interfaces. Drivers might, perhaps implicitly, rely on the
operation order for certain things that typically happen within a
single function elsewhere in mac80211. To avoid problems with that,
reorder the code in mac80211's restart/reprogramming to work fully
within the interface loop so that the order of operations is like
in normal operation.
For iwlwifi, this fixes a firmware crash when reprogramming with an
AP/GO interface active.
Reported-by: David Spinadel <david.spinadel@intel.com>
When reconfiguration during resume fails while a scan is pending
for completion work, that work will never run, and the scan will
be stuck forever. Factor out the code to recover this and call it
also in ieee80211_handle_reconfig_failure().
In the last change here, I neglected to update the cookie in one code
path: when a mgmt-tx has no real cookie sent to userspace as it doesn't
wait for a response, but is off-channel. The original code used the SKB
pointer as the cookie and always assigned the cookie to the TX SKB in
ieee80211_start_roc_work(), but my change turned this around and made
the code rely on a valid cookie being passed in.
Unfortunately, the off-channel no-wait TX path wasn't assigning one at
all, resulting in an uninitialized stack value being used. This wasn't
handed back to userspace as a cookie (since in the no-wait case there
isn't a cookie), but it was tested for non-zero to distinguish between
mgmt-tx and off-channel.
Fix this by assigning a dummy non-zero cookie unconditionally, and get
rid of a misleading comment and some dead code while at it. I'll clean
up the ACK SKB handling separately later.
Fixes: 3b79af973cf4 ("mac80211: stop using pointers as userspace cookies")
DFS channels should not be actively scanned as we can't be sure
if we are allowed or not.
If the current channel is in the DFS band, active scan might be
performed after CSA, but we have no guarantee about other channels,
therefore it is safer to prevent active scanning at all.
Cc: stable@vger.kernel.org
Signed-off-by: Antonio Quartulli <antonio@open-mesh.com>
Interfaces are being initialized (setup) on addition,
and torn down on removal.
However, p2p device is being torn down when stopped,
resulting in the next p2p start operation being done
on uninitialized interface.
Solve it by calling ieee80211_teardown_sdata() only
on interface removal (for the non-netdev case).
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
[squashed in fix to call teardown after unregister]
Advertising reordering window in ADDBA less than 64 can crash some APs,
an example is LinkSys WRT120N (with FW v1.0.07 build 002 Jun 18 2012).
On the other hand, a driver may need to limit Tx A-MPDU size for its own
reasons, like specific HW limitations.
Signed-off-by: Gregory Greenman <gregory.greenman@intel.com>
We can't update the Tx power on the device unless it is
running.
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=101521.
When using call_rcu(), the called function may be delayed quite
significantly, and without a matching rcu_barrier() there's no
way to be sure it has finished.
Therefore, global state that could be gone/freed/reused should
never be touched in the callback.
Fix this in mesh by moving the atomic_dec() into the caller;
that's not really a problem since we already unlinked the path
and it will be destroyed anyway.
This fixes a crash Jouni observed when running certain tests in
a certain order, in which the mesh interface was torn down, the
memory reused for a function pointer (work struct) and running
that then crashed since the pointer had been decremented by 1,
resulting in an invalid instruction byte stream.
Fixes: eb2b9311fd00 ("mac80211: mesh path table implementation")
Reported-by: Jouni Malinen <j@w1.fi>
For now, this feature doesn't actually work. To avoid shipping a
kernel that has it enabled but where it can't be used disable it
for now - we can re-enable it when it's fixed.
This partially reverts 44674d9c2267 ("mac80211: advertise support
for full station state in AP mode").
Cc: Ayala Beker <ayala.beker@intel.com>
Channel context driver operations can sleep, so add might_sleep()
and document this.
Signed-off-by: Chaitanya T K <chaitanya.mgit@gmail.com>
Allow distinguishing the non-station case from the case of a
station without rates, by using -1 for the non-station case.
This value cannot be reached with a station since that many
legacy rates don't exist.
As WMM is required for HT/VHT operation, treat bad WMM parameters
more gracefully by falling back to default parameters instead of
not using WMM assocation. This makes it possible to still use HT
or VHT, although potentially with reduced quality of service due
to unintended WMM parameters.
Disabling WMM has a huge impact these days. It implies that
HT and VHT will be disabled which means that the throughput
will be drammatically reduced.
Since the AIFSN is a transmission parameter, we can play a
bit and fix it up to make it compliant with the 802.11
specification which requires it to be at least 2.
Increasing it from 1 to 2 will slightly reduce the
likelyhood to get a transmission opportunity compared to
other clients that would accept to set AIFSN=1, but at
least it will allow HT and VHT which is a huge gain.
The function currently determines this value, for use in bss_info.qos,
based on the interface type itself. Make it a parameter instead and
set it with the same logic for now.
llid_in_use needs to be limited to stations of the same VIF, otherwise it
will cause a NULL deref as the sta_info of non-mesh-VIFs don't have
sta->mesh set.
Steps to reproduce:
modprobe mac80211_hwsim channels=2
iw phy phy0 interface add ibss0 type ibss
iw phy phy0 interface add mesh0 type mp
iw phy phy1 interface add ibss1 type ibss
iw phy phy1 interface add mesh1 type mp
ip link set ibss0 up
ip link set mesh0 up
ip link set ibss1 up
ip link set mesh1 up
iw dev ibss0 ibss join foo 2412
iw dev ibss1 ibss join foo 2412
# Ensure that ibss0 and ibss1 are actually associated; I often need to
# leave and join the cell on ibss1 a second time.
iw dev mesh0 mesh join bar
iw dev mesh1 mesh join bar # crash
Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net>
When 11n peers performs a TDLS connection on a legacy BSS, the HT
operation IE must be specified according to IEEE802.11-2012 section
9.23.3.2. Otherwise HT-protection is compromised and the medium becomes
noisy for both the TDLS and the BSS links.
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
Scheduled scan has to be reconfigured only if wowlan wasn't
configured, since otherwise it should continue to run (with
the 'any' trigger) or be aborted.
The current code will end up asking the driver to start a new
scheduled scan without stopping the previous one, and leaking
some memory (from the previous request.)
Fix this by doing the abort/restart under the proper conditions.
If drv_start() fails during hw_restart, all the running
interfaces are being closed/stopped, which results in
drv_stop() being called, although the driver was never
started successfully.
This might cause drivers to perform operations on uninitialized
memory (as they assume it was initialized on drv_start)
Consider the local->started flag, and call the driver's stop()
op only if drv_start() succeeded before.
Move drv_start() and drv_stop() to driver-ops.c, as they are no
longer simple wrappers.
The recalc_smps work can run after the station disassociates.
At this stage we already released the channel, but the work
will be cancelled only when the interface stops.
In this scenario we can hit the warning in ieee80211_recalc_smps, so
just remove it.
Signed-off-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com>
Requesting hw restart during suspend might result
in the restart work being executed after mac80211
and the hw are suspended.
Solve the race by simply scheduling the restart
work on a freezable workqueue.
Note that there can be some cases of reconfiguration
on resume (besides the hardware restart):
* wowlan is not configured -
All the interfaces removed were removed on suspend,
and drv_stop() was called. At this point the driver
shouldn't expect for hw_restart anyway, so we can
simply cancel it (on resume).
* wowlan is configured, drv_resume() == 1
There is no definitive expected behavior in this case,
as each driver might have different expectations (e.g.
setting some flags on suspend/restart vs. not handling
spurious recovery).
For now, simply let the hw_restart work run again after
resume, and hope the driver will handle it well (or at
least initiate another hw restart).
Local request to deauthenticate wasn't handled while associating, thus
the association could continue even when the user space required to
disconnect.
In TDLS channel-switch operations the chandef can sometimes be NULL.
Avoid an oops in the trace code for these cases and just print a
chandef full of zeros.
Fixes: a7a6bdd0670fe ("mac80211: introduce TDLS channel switch ops")
In case of one shot NOA the interval can be 0, catch that
instead of potentially (depending on the driver) crashing
like this:
divide error: 0000 [#1] SMP
Call Trace:
<IRQ>
[<ffffffffc08e891c>] ieee80211_extend_absent_time+0x6c/0xb0 [mac80211]
[<ffffffffc08e8a17>] ieee80211_update_p2p_noa+0xb7/0xe0 [mac80211]
[<ffffffffc069cc30>] ath9k_p2p_ps_timer+0x170/0x190 [ath9k]
[<ffffffffc070adf8>] ath_gen_timer_isr+0xc8/0xf0 [ath9k_hw]
[<ffffffffc0691156>] ath9k_tasklet+0x296/0x2f0 [ath9k]
[<ffffffff8107ad65>] tasklet_action+0xe5/0xf0
Cc: stable@vger.kernel.org [3.16+, due to d463af4a1c34 using it]
Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Johannes Berg says:
Here's another set of patches for the current cycle:
* I merged net-next back to avoid a conflict with the
* cfg80211 scheduled scan API extensions
* preparations for better scan result timestamping
* regulatory cleanups
* mac80211 statistics cleanups
* a few other small cleanups and fixes
Group station statistics by where they're (mostly) updated
(TX, RX and TX-status) and group them into sub-structs of
the struct sta_info.
Also rename the variables since the grouping now makes it
obvious where they belong.
This makes it easier to identify where the statistics are
updated in the code, and thus easier to think about them.
There's little point in keeping (and even sending to userspace)
the beacon_loss_count value per station, since it can only apply
to the AP on a managed-mode connection. Move the value to ifmgd,
advertise it only in managed mode, and remove it from ethtool as
it's available through better interfaces.
This file only feeds a debugfs file that isn't very useful, so remove
it. If necessary, we can add other ways to get this information, for
example in the NL80211_CMD_PROBE_CLIENT response.
drivers/net/usb/asix_common.c
net/ipv4/inet_connection_sock.c
net/switchdev/switchdev.c
In the inet_connection_sock.c case the request socket hashing scheme
is completely different in net-next.
The other two conflicts were overlapping changes.
That file contains just a single function, which itself is just a
single statement to call a different function. Remove it.
The file contains just a single declaration that can easily
move to another file - remove it.
There's only a single caller of this function, so it can
be moved to the same file and made static.
Reduce indentation a bit to make the condition more readable.
As this API has never really seen any use and most drivers don't
ever use the value derived from it, remove it.
Change the only driver using it (rt2x00) to simply use the DTIM
period instead of the "max sleep" time.
The new API is more easily extensible with a metadata struct
passed to it, use it in mac80211.
If multiple scan plans were set for scheduled scan, do not restart
scheduled scan on reconfig because it is possible that some scan
plans were already completed and there is no need to run them all
over again. Instead, notify userspace that scheduled scan stopped
so it can configure new scan plans for scheduled scan.
Signed-off-by: Avraham Stern <avraham.stern@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
