[ Upstream commit 92a34ab169f9eefe29cd420ce96b0a0a2a1da853 ]
As we can see from the comment of the nla_put() that it could return
-EMSGSIZE if the tailroom of the skb is insufficient.
Therefore, it should be better to check the return value of the
nla_put_u32 and return the error code if error accurs.
Also, there are many other functions have the same problem, and if this
patch is correct, I will commit a new version to fix all.
Fixes: 955dc68cb9b2 ("net/ncsi: Add generic netlink family")
Signed-off-by: Jiasheng Jiang <jiasheng@iscas.ac.cn>
Link: https://lore.kernel.org/r/20211229032118.1706294-1-jiasheng@iscas.ac.cn
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit ac132852147ad303a938dda318970dd1bbdfda4e ]
Update NC-SI command handler (both standard and OEM) to take into
account of payload paddings in allocating skb (in case of payload
size is not 32-bit aligned).
The checksum field follows payload field, without taking payload
padding into account can cause checksum being truncated, leading to
dropped packets.
Fixes: fb4ee67529ff ("net/ncsi: Add NCSI OEM command support")
Signed-off-by: Kumar Thangavel <thangavel.k@hcl.com>
Acked-by: Samuel Mendoza-Jonas <sam@mendozajonas.com>
Reviewed-by: Paul Menzel <pmenzel@molgen.mpg.de>
[ Upstream commit 03cb4d05b4ea9a3491674ca40952adb708d549fa ]
Calling ncsi_stop_channel_monitor from channel_monitor is a guaranteed
deadlock on SMP because stop calls del_timer_sync on the timer that
invoked channel_monitor as its timer function.
Recognise the inherent race of marking the monitor disabled before
deleting the timer by just returning if enable was cleared. After
a timeout (the default case -- reset to START when response received)
just mark the monitor.enabled false.
If the channel has an entry on the channel_queue list, or if the
state is not ACTIVE or INACTIVE, then warn and mark the timer stopped
and don't restart, as the locking is broken somehow.
Fixes: 0795fb2021f0 ("net/ncsi: Stop monitor if channel times out or is inactive")
Signed-off-by: Milton Miller <miltonm@us.ibm.com>
Signed-off-by: Eddie James <eajames@linux.ibm.com>
[ Upstream commit 427c940558560bff2583d07fc119a21094675982 ]
When aggregating ncsi interfaces and dedicated interfaces to bond
interfaces, the ncsi response handler will use the wrong net device to
find ncsi_dev, so that the ncsi interface will not work properly.
Here, we use the original net device to fix it.
Fixes: 138635cc27c9 ("net/ncsi: NCSI response packet handler")
Signed-off-by: John Wang <wangzhiqiang.bj@bytedance.com>
Link: https://lore.kernel.org/r/20201223055523.2069-1-wangzhiqiang.bj@bytedance.com
[ Upstream commit 1922a46b8c18cb09d33e06a6cc2e43844ac1b9d0 ]
If a user unbinds and re-binds a NC-SI aware driver the kernel will
attempt to register the netlink interface at runtime. The structure is
marked __ro_after_init so registration fails spectacularly at this point.
# echo 1e660000.ethernet > /sys/bus/platform/drivers/ftgmac100/unbind
# echo 1e660000.ethernet > /sys/bus/platform/drivers/ftgmac100/bind
ftgmac100 1e660000.ethernet: Read MAC address 52:54:00:12:34:56 from chip
ftgmac100 1e660000.ethernet: Using NCSI interface
8<--- cut here ---
Unable to handle kernel paging request at virtual address 80a8f858
pgd = 8c768dd6
[80a8f858] *pgd=80a0841e(bad)
Internal error: Oops: 80d [#1] SMP ARM
CPU: 0 PID: 116 Comm: sh Not tainted 5.10.0-rc3-next-20201111-00003-gdd25b227ec1e #51
Hardware name: Generic DT based system
PC is at genl_register_family+0x1f8/0x6d4
LR is at 0xff26ffff
pc : [<8073f930>] lr : [<ff26ffff>] psr: 20000153
sp : 8553bc80 ip : 81406244 fp : 8553bd04
r10: 8085d12c r9 : 80a8f73c r8 : 85739000
r7 : 00000017 r6 : 80a8f860 r5 : 80c8ab98 r4 : 80a8f858
r3 : 00000000 r2 : 00000000 r1 : 81406130 r0 : 00000017
Flags: nzCv IRQs on FIQs off Mode SVC_32 ISA ARM Segment none
Control: 00c5387d Table: 85524008 DAC: 00000051
Process sh (pid: 116, stack limit = 0x1f1988d6)
Backtrace:
[<8073f738>] (genl_register_family) from [<80860ac0>] (ncsi_init_netlink+0x20/0x48)
r10:8085d12c r9:80c8fb0c r8:85739000 r7:00000000 r6:81218000 r5:85739000
r4:8121c000
[<80860aa0>] (ncsi_init_netlink) from [<8085d740>] (ncsi_register_dev+0x1b0/0x210)
r5:8121c400 r4:8121c000
[<8085d590>] (ncsi_register_dev) from [<805a8060>] (ftgmac100_probe+0x6e0/0x778)
r10:00000004 r9:80950228 r8:8115bc10 r7:8115ab00 r6:9eae2c24 r5:813b6f88
r4:85739000
[<805a7980>] (ftgmac100_probe) from [<805355ec>] (platform_drv_probe+0x58/0xa8)
r9:80c76bb0 r8:00000000 r7:80cd4974 r6:80c76bb0 r5:8115bc10 r4:00000000
[<80535594>] (platform_drv_probe) from [<80532d58>] (really_probe+0x204/0x514)
r7:80cd4974 r6:00000000 r5:80cd4868 r4:8115bc10
Jakub pointed out that ncsi_register_dev is obviously broken, because
there is only one family so it would never work if there was more than
one ncsi netdev.
Fix the crash by registering the netlink family once on boot, and drop
the code to unregister it.
Signed-off-by: Joel Stanley <joel@jms.id.au>
Reviewed-by: Samuel Mendoza-Jonas <sam@mendozajonas.com>
Link: https://lore.kernel.org/r/20201112061210.914621-1-joel@jms.id.au
Disabling multicast filtering from NCSI if it is supported. As it
should not filter any multicast packets. In current code, multicast
filter is enabled and with an exception of optional field supported
by device are disabled filtering.
Mainly I see if goal is to disable filtering for IPV6 packets then let
it disabled for every other types as well. As we are seeing issues with
LLDP not working with this enabled filtering. And there are other issues
with IPV6.
By Disabling this multicast completely, it is working for both IPV6 as
well as LLDP.
Signed-off-by: Vijay Khemka <vijaykhemka@fb.com>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
This patch adds handlers for PLDM over NC-SI command response.
This enables NC-SI driver recognizes the packet type so the responses
don't get dropped as unknown packet type.
PLDM over NC-SI are not handled in kernel driver for now, but can be
passed back to user space via Netlink for further handling.
Signed-off-by: Ben Wei <benwei@fb.com>
Minor conflict in r8169, bug fix had two versions in net
and net-next, take the net-next hunks.
Update response packet length for the following commands per NC-SI spec
- Get Controller Packet Statistics
- Get NC-SI Statistics
- Get NC-SI Pass-through Statistics command
Reviewed-by: Justin Lee <justin.lee1@dell.com>
The request coming from Netlink should use the OEM generic handler.
The standard command handler expects payload in bytes/words/dwords
but the actual payload is stored in data if the request is coming from Netlink.
Signed-off-by: Justin Lee <justin.lee1@dell.com>
Reviewed-by: Vijay Khemka <vijaykhemka@fb.com>
The NCSI spec indicates that if the data does not end on a 32 bit
boundary, one to three padding bytes equal to 0x00 shall be present to
align the checksum field to a 32-bit boundary.
Signed-off-by: Terry S. Duncan <terry.s.duncan@linux.intel.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3029 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Add options to strictly validate messages and dump messages,
sometimes perhaps validating dump messages non-strictly may
be required, so add an option for that as well.
Since none of this can really be applied to existing commands,
set the options everwhere using the following spatch:
identifier ops;
expression X;
struct genl_ops ops[] = {
.cmd = X,
+ .validate = GENL_DONT_VALIDATE_STRICT | GENL_DONT_VALIDATE_DUMP,
For new commands one should just not copy the .validate 'opt-out'
flags and thus get strict validation.
We currently have two levels of strict validation:
1) liberal (default)
- undefined (type >= max) & NLA_UNSPEC attributes accepted
- attribute length >= expected accepted
- garbage at end of message accepted
2) strict (opt-in)
- NLA_UNSPEC attributes accepted
Split out parsing strictness into four different options:
* TRAILING - check that there's no trailing data after parsing
attributes (in message or nested)
* MAXTYPE - reject attrs > max known type
* UNSPEC - reject attributes with NLA_UNSPEC policy entries
* STRICT_ATTRS - strictly validate attribute size
The default for future things should be *everything*.
The current *_strict() is a combination of TRAILING and MAXTYPE,
and is renamed to _deprecated_strict().
The current regular parsing has none of this, and is renamed to
*_parse_deprecated().
Additionally it allows us to selectively set one of the new flags
even on old policies. Notably, the UNSPEC flag could be useful in
this case, since it can be arranged (by filling in the policy) to
not be an incompatible userspace ABI change, but would then going
forward prevent forgetting attribute entries. Similar can apply
to the POLICY flag.
We end up with the following renames:
* nla_parse -> nla_parse_deprecated
* nla_parse_strict -> nla_parse_deprecated_strict
* nlmsg_parse -> nlmsg_parse_deprecated
* nlmsg_parse_strict -> nlmsg_parse_deprecated_strict
* nla_parse_nested -> nla_parse_nested_deprecated
* nla_validate_nested -> nla_validate_nested_deprecated
Using spatch, of course:
expression TB, MAX, HEAD, LEN, POL, EXT;
-nla_parse(TB, MAX, HEAD, LEN, POL, EXT)
+nla_parse_deprecated(TB, MAX, HEAD, LEN, POL, EXT)
expression NLH, HDRLEN, TB, MAX, POL, EXT;
-nlmsg_parse(NLH, HDRLEN, TB, MAX, POL, EXT)
+nlmsg_parse_deprecated(NLH, HDRLEN, TB, MAX, POL, EXT)
-nlmsg_parse_strict(NLH, HDRLEN, TB, MAX, POL, EXT)
+nlmsg_parse_deprecated_strict(NLH, HDRLEN, TB, MAX, POL, EXT)
expression TB, MAX, NLA, POL, EXT;
-nla_parse_nested(TB, MAX, NLA, POL, EXT)
+nla_parse_nested_deprecated(TB, MAX, NLA, POL, EXT)
expression START, MAX, POL, EXT;
-nla_validate_nested(START, MAX, POL, EXT)
+nla_validate_nested_deprecated(START, MAX, POL, EXT)
expression NLH, HDRLEN, MAX, POL, EXT;
-nlmsg_validate(NLH, HDRLEN, MAX, POL, EXT)
+nlmsg_validate_deprecated(NLH, HDRLEN, MAX, POL, EXT)
For this patch, don't actually add the strict, non-renamed versions
yet so that it breaks compile if I get it wrong.
Also, while at it, make nla_validate and nla_parse go down to a
common __nla_validate_parse() function to avoid code duplication.
Ultimately, this allows us to have very strict validation for every
new caller of nla_parse()/nlmsg_parse() etc as re-introduced in the
next patch, while existing things will continue to work as is.
In effect then, this adds fully strict validation for any new command.
Even if the NLA_F_NESTED flag was introduced more than 11 years ago, most
netlink based interfaces (including recently added ones) are still not
setting it in kernel generated messages. Without the flag, message parsers
not aware of attribute semantics (e.g. wireshark dissector or libmnl's
mnl_nlmsg_fprintf()) cannot recognize nested attributes and won't display
the structure of their contents.
Unfortunately we cannot just add the flag everywhere as there may be
userspace applications which check nlattr::nla_type directly rather than
through a helper masking out the flags. Therefore the patch renames
nla_nest_start() to nla_nest_start_noflag() and introduces nla_nest_start()
as a wrapper adding NLA_F_NESTED. The calls which add NLA_F_NESTED manually
are rewritten to use nla_nest_start().
Except for changes in include/net/netlink.h, the patch was generated using
this semantic patch:
@@ expression E1, E2; @@
-nla_nest_start(E1, E2)
+nla_nest_start_noflag(E1, E2)
-nla_nest_start_noflag(E1, E2 | NLA_F_NESTED)
+nla_nest_start(E1, E2)
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Acked-by: Jiri Pirko <jiri@mellanox.com>
Acked-by: David Ahern <dsahern@gmail.com>
Two easy cases of overlapping changes.
Previously BMC's MAC address is calculated by simply adding 1 to the
last byte of network controller's MAC address, and it produces incorrect
result when network controller's MAC address ends with 0xFF.
The problem can be fixed by calling eth_addr_inc() function to increment
MAC address; besides, the MAC address is also validated before assigning
to BMC.
Fixes: cb10c7c0dfd9 ("net/ncsi: Add NCSI Broadcom OEM command")
Signed-off-by: Tao Ren <taoren@fb.com>
Acked-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Since maxattr is common, the policy can't really differ sanely,
so make it common as well.
The only user that did in fact manage to make a non-common policy
is taskstats, which has to be really careful about it (since it's
still using a common maxattr!). This is no longer supported, but
we can fake it using pre_doit.
This reduces the size of e.g. nl80211.o (which has lots of commands):
398745 14323 2240 415308 6564c net/wireless/nl80211.o (before)
397913 14331 2240 414484 65314 net/wireless/nl80211.o (after)
-832 +8 0 -824
Which is obviously just 8 bytes for each command, and an added 8
bytes for the new policy pointer. I'm not sure why the ops list is
counted as .text though.
Most of the code transformations were done using the following spatch:
@ops@
identifier OPS;
expression POLICY;
struct genl_ops OPS[] = {
- .policy = POLICY,
identifier ops.OPS;
expression ops.POLICY;
identifier fam;
expression M;
struct genl_family fam = {
.ops = OPS,
.maxattr = M,
+ .policy = POLICY,
This also gets rid of devlink_nl_cmd_region_read_dumpit() accessing
the cb->data as ops, which we want to change in a later genl patch.
nla_nest_start may fail and thus deserves a check.
The fix returns -EMSGSIZE in case it fails.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
This patch adds OEM Mellanox commands and response handling. It also
defines OEM Get MAC Address handler to get and configure the device.
ncsi_oem_gma_handler_mlx: This handler send NCSI mellanox command for
getting mac address.
ncsi_rsp_handler_oem_mlx: This handles response received for all
mellanox OEM commands.
ncsi_rsp_handler_oem_mlx_gma: This handles get mac address response and
set it to device.
This patch extends the ncsi-netlink interface with two new commands and
three new attributes to configure multiple packages and/or channels at
once, and configure specific failover modes.
NCSI_CMD_SET_PACKAGE mask and NCSI_CMD_SET_CHANNEL_MASK set a whitelist
of packages or channels allowed to be configured with the
NCSI_ATTR_PACKAGE_MASK and NCSI_ATTR_CHANNEL_MASK attributes
respectively. If one of these whitelists is set only packages or
channels matching the whitelist are considered for the channel queue in
ncsi_choose_active_channel().
These commands may also use the NCSI_ATTR_MULTI_FLAG to signal that
multiple packages or channels may be configured simultaneously. NCSI
hardware arbitration (HWA) must be available in order to enable
multi-package mode. Multi-channel mode is always available.
If the NCSI_ATTR_CHANNEL_ID attribute is present in the
NCSI_CMD_SET_CHANNEL_MASK command the it sets the preferred channel as
with the NCSI_CMD_SET_INTERFACE command. The combination of preferred
channel and channel whitelist defines a primary channel and the allowed
failover channels.
If the NCSI_ATTR_MULTI_FLAG attribute is also present then the preferred
channel is configured for Tx/Rx and the other channels are enabled only
for Rx.
Signed-off-by: Samuel Mendoza-Jonas <sam@mendozajonas.com>
When the NCSI driver is stopped with ncsi_stop_dev() the channel
monitors are stopped and the state set to "inactive". However the
channels are still configured and active from the perspective of the
network controller. We should suspend each active channel but in the
context of ncsi_stop_dev() the transmit queue has been or is about to be
stopped so we won't have time to do so.
Instead when ncsi_start_dev() is called if the NCSI topology has already
been probed then call ncsi_reset_dev() to suspend any channels that were
previously active. This resets the network controller to a known state,
provides an up to date view of channel link state, and makes sure that
mode flags such as NCSI_MODE_TX_ENABLE are properly reset.
In addition to ncsi_start_dev() use ncsi_reset_dev() in ncsi-netlink.c
to update the channel configuration more cleanly.
The concepts of a channel being 'active' and it having link are slightly
muddled in the NCSI driver. Tweak this slightly so that
NCSI_CHANNEL_ACTIVE represents a channel that has been configured and
enabled, and NCSI_CHANNEL_INACTIVE represents a de-configured channel.
This distinction is important because a channel can be 'active' but have
its link down; in this case the channel may still need to be configured
so that it may receive AEN link-state-change packets.
When a package is deselected all channels of that package cease
communication. If there are other channels active on the package of the
suspended channel this will disable them as well, so only send a
deselect-package command if no other channels are active.
Currently the NCSI driver sends a select-package command to all possible
packages simultaneously to discover what packages are available. However
at this stage in the probe process the driver does not know if
hardware arbitration is available: if it isn't then this process could
cause collisions on the RMII bus when packages try to respond.
Update the probe loop to probe each package one by one, and once
complete check if HWA is universally supported.
NCSI hardware arbitration allows multiple packages to be enabled at once
and share the same wiring. If the NCSI driver recognises that HWA is
available it unconditionally enables all packages and channels; but that
is a configuration decision rather than something required by HWA.
Additionally the current implementation will not failover on link events
which can cause connectivity to be lost unless the interface is manually
bounced.
Retain basic HWA support but remove the separate configuration path to
enable all channels, leaving this to be handled by a later
implementation.
This patch adds OEM Broadcom commands and response handling. It also
ncsi_oem_gma_handler_bcm: This handler send NCSI broadcom command for
ncsi_rsp_handler_oem_bcm: This handles response received for all
broadcom OEM commands.
ncsi_rsp_handler_oem_bcm_gma: This handles get mac address response and
set it to device.
command
The new command (NCSI_CMD_SEND_CMD) is added to allow user space application
to send NC-SI command to the network card.
Also, add a new attribute (NCSI_ATTR_DATA) for transferring request and response.
The work flow is as below.
Request:
User space application
-> Netlink interface (msg)
-> new Netlink handler - ncsi_send_cmd_nl()
-> ncsi_xmit_cmd()
Response:
Response received - ncsi_rcv_rsp()
-> internal response handler - ncsi_rsp_handler_xxx()
-> ncsi_rsp_handler_netlink()
-> ncsi_send_netlink_rsp ()
-> user space application
Command timeout - ncsi_request_timeout()
-> ncsi_send_netlink_timeout ()
-> Netlink interface (msg with zero data length)
Error:
Error detected
-> ncsi_send_netlink_err ()
-> Netlink interface (err msg)
This patch adds OEM commands and response handling. It also defines OEM
command and response structure as per NCSI specification along with its
handlers.
ncsi_cmd_handler_oem: This is a generic command request handler for OEM
commands
ncsi_rsp_handler_oem: This is a generic response handler for OEM commands
Remove duplicated include.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
The ncsi_pkg_info_all_nl() .dumpit handler is missing the NLM_F_MULTI
flag, causing additional package information after the first to be lost.
Also fixup a sanity check in ncsi_write_package_info() to reject out of
range package IDs.
This moves all of the netdev_printk(KERN_DEBUG, ...) messages over to
netdev_dbg.
As Joe explains:
> netdev_dbg is not included in object code unless
> DEBUG is defined or CONFIG_DYNAMIC_DEBUG is set.
> And then, it is not emitted into the log unless
> DEBUG is set or this specific netdev_dbg is enabled
> via the dynamic debug control file.
Which is what we're after in this case.
This does not provide useful information. As the ncsi maintainer said:
> either we get a channel or broadcom has gone out to lunch
In normal operation we see this series of messages as the host drives
the network device:
ftgmac100 1e660000.ethernet eth0: NCSI: LSC AEN - channel 0 state down
ftgmac100 1e660000.ethernet eth0: NCSI: suspending channel 0
ftgmac100 1e660000.ethernet eth0: NCSI: configuring channel 0
ftgmac100 1e660000.ethernet eth0: NCSI: channel 0 link down after config
ftgmac100 1e660000.ethernet eth0: NCSI interface down
ftgmac100 1e660000.ethernet eth0: NCSI: LSC AEN - channel 0 state up
ftgmac100 1e660000.ethernet eth0: NCSI interface up
This makes all of these messages netdev_dbg. They are still useful to
debug eg. misbehaving network device firmware, but we do not need them
filling up the kernel logs in normal operation.
ncsi_rsp_handler_gc() allocates the filter arrays using GFP_KERNEL in
softirq context, causing the below backtrace. This allocation is only a
few dozen bytes during probing so allocate with GFP_ATOMIC instead.
[ 42.813372] BUG: sleeping function called from invalid context at mm/slab.h:416
[ 42.820900] in_atomic(): 1, irqs_disabled(): 0, pid: 213, name: kworker/0:1
[ 42.827893] INFO: lockdep is turned off.
[ 42.832023] CPU: 0 PID: 213 Comm: kworker/0:1 Tainted: G W 4.13.16-01441-gad99b38 #65
[ 42.841007] Hardware name: Generic DT based system
[ 42.845966] Workqueue: events ncsi_dev_work
[ 42.850251] [<8010a494>] (unwind_backtrace) from [<80107510>] (show_stack+0x20/0x24)
[ 42.858046] [<80107510>] (show_stack) from [<80612770>] (dump_stack+0x20/0x28)
[ 42.865309] [<80612770>] (dump_stack) from [<80148248>] (___might_sleep+0x230/0x2b0)
[ 42.873241] [<80148248>] (___might_sleep) from [<80148334>] (__might_sleep+0x6c/0xac)
[ 42.881129] [<80148334>] (__might_sleep) from [<80240d6c>] (__kmalloc+0x210/0x2fc)
[ 42.888737] [<80240d6c>] (__kmalloc) from [<8060ad54>] (ncsi_rsp_handler_gc+0xd0/0x170)
[ 42.896770] [<8060ad54>] (ncsi_rsp_handler_gc) from [<8060b454>] (ncsi_rcv_rsp+0x16c/0x1d4)
[ 42.905314] [<8060b454>] (ncsi_rcv_rsp) from [<804d86c8>] (__netif_receive_skb_core+0x3c8/0xb50)
[ 42.914158] [<804d86c8>] (__netif_receive_skb_core) from [<804d96cc>] (__netif_receive_skb+0x20/0x7c)
[ 42.923420] [<804d96cc>] (__netif_receive_skb) from [<804de4b0>] (netif_receive_skb_internal+0x78/0x6a4)
[ 42.932931] [<804de4b0>] (netif_receive_skb_internal) from [<804df980>] (netif_receive_skb+0x78/0x158)
[ 42.942292] [<804df980>] (netif_receive_skb) from [<8042f204>] (ftgmac100_poll+0x43c/0x4e8)
[ 42.950855] [<8042f204>] (ftgmac100_poll) from [<804e094c>] (net_rx_action+0x278/0x4c4)
[ 42.958918] [<804e094c>] (net_rx_action) from [<801016a8>] (__do_softirq+0xe0/0x4c4)
[ 42.966716] [<801016a8>] (__do_softirq) from [<8011cd9c>] (do_softirq.part.4+0x50/0x78)
[ 42.974756] [<8011cd9c>] (do_softirq.part.4) from [<8011cebc>] (__local_bh_enable_ip+0xf8/0x11c)
[ 42.983579] [<8011cebc>] (__local_bh_enable_ip) from [<804dde08>] (__dev_queue_xmit+0x260/0x890)
[ 42.992392] [<804dde08>] (__dev_queue_xmit) from [<804df1f0>] (dev_queue_xmit+0x1c/0x20)
[ 43.000689] [<804df1f0>] (dev_queue_xmit) from [<806099c0>] (ncsi_xmit_cmd+0x1c0/0x244)
[ 43.008763] [<806099c0>] (ncsi_xmit_cmd) from [<8060dc14>] (ncsi_dev_work+0x2e0/0x4c8)
[ 43.016725] [<8060dc14>] (ncsi_dev_work) from [<80133dfc>] (process_one_work+0x214/0x6f8)
[ 43.024940] [<80133dfc>] (process_one_work) from [<80134328>] (worker_thread+0x48/0x558)
[ 43.033070] [<80134328>] (worker_thread) from [<8013ba80>] (kthread+0x130/0x174)
[ 43.040506] [<8013ba80>] (kthread) from [<80102950>] (ret_from_fork+0x14/0x24)
Fixes: 062b3e1b6d4f ("net/ncsi: Refactor MAC, VLAN filters")
Filling in the padding slot in the bpf structure as a bug fix in 'ne'
overlapped with actually using that padding area for something in
'net-next'.
With CONFIG_CC_STACKPROTECTOR enabled the kernel panics as below when
parsing a NCSI_CMD_PKG_INFO command:
[ 150.149711] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: 805cff08
[ 150.149711]
[ 150.159919] CPU: 0 PID: 1301 Comm: ncsi-netlink Not tainted 4.13.16-468cbec6d2c91239332cb91b1f0a73aafcb6f0c6 #1
[ 150.170004] Hardware name: Generic DT based system
[ 150.174852] [<80109930>] (unwind_backtrace) from [<80106bc4>] (show_stack+0x20/0x24)
[ 150.182641] [<80106bc4>] (show_stack) from [<805d36e4>] (dump_stack+0x20/0x28)
[ 150.189888] [<805d36e4>] (dump_stack) from [<801163ac>] (panic+0xdc/0x278)
[ 150.196780] [<801163ac>] (panic) from [<801162cc>] (__stack_chk_fail+0x20/0x24)
[ 150.204111] [<801162cc>] (__stack_chk_fail) from [<805cff08>] (ncsi_pkg_info_all_nl+0x244/0x258)
[ 150.212912] [<805cff08>] (ncsi_pkg_info_all_nl) from [<804f939c>] (genl_lock_dumpit+0x3c/0x54)
[ 150.221535] [<804f939c>] (genl_lock_dumpit) from [<804f873c>] (netlink_dump+0xf8/0x284)
[ 150.229550] [<804f873c>] (netlink_dump) from [<804f8d44>] (__netlink_dump_start+0x124/0x17c)
[ 150.237992] [<804f8d44>] (__netlink_dump_start) from [<804f9880>] (genl_rcv_msg+0x1c8/0x3d4)
[ 150.246440] [<804f9880>] (genl_rcv_msg) from [<804f9174>] (netlink_rcv_skb+0xd8/0x134)
[ 150.254361] [<804f9174>] (netlink_rcv_skb) from [<804f96a4>] (genl_rcv+0x30/0x44)
[ 150.261850] [<804f96a4>] (genl_rcv) from [<804f7790>] (netlink_unicast+0x198/0x234)
[ 150.269511] [<804f7790>] (netlink_unicast) from [<804f7ffc>] (netlink_sendmsg+0x368/0x3b0)
[ 150.277783] [<804f7ffc>] (netlink_sendmsg) from [<804abea4>] (sock_sendmsg+0x24/0x34)
[ 150.285625] [<804abea4>] (sock_sendmsg) from [<804ac1dc>] (___sys_sendmsg+0x244/0x260)
[ 150.293556] [<804ac1dc>] (___sys_sendmsg) from [<804ad98c>] (__sys_sendmsg+0x5c/0x9c)
[ 150.301400] [<804ad98c>] (__sys_sendmsg) from [<804ad9e4>] (SyS_sendmsg+0x18/0x1c)
[ 150.308984] [<804ad9e4>] (SyS_sendmsg) from [<80102640>] (ret_fast_syscall+0x0/0x3c)
[ 150.316743] ---[ end Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: 805cff08
This turns out to be because the attrs array in ncsi_pkg_info_all_nl()
is initialised to a length of NCSI_ATTR_MAX which is the maximum
attribute number, not the number of attributes.
the message be freed immediately, no need to trim it
back to the previous size.
Inspired by commit 7a9b3ec1e19f ("nl80211: remove unnecessary genlmsg_cancel() calls")
We recently refactored this code and introduced a static checker
warning. Smatch complains that if cmd->index is zero then we would
underflow the arrays. That's obviously true.
The question is whether we prevent cmd->index from being zero at a
different level. I've looked at the code and I don't immediately see
a check for that.
The NCSI driver defines a generic ncsi_channel_filter struct that can be
used to store arbitrarily formatted filters, and several generic methods
of accessing data stored in such a filter.
However in both the driver and as defined in the NCSI specification
there are only two actual filters: VLAN ID filters and MAC address
filters. The splitting of the MAC filter into unicast, multicast, and
mixed is also technically not necessary as these are stored in the same
location in hardware.
To save complexity, particularly in the set up and accessing of these
generic filters, remove them in favour of two specific structs. These
can be acted on directly and do not need several generic helper
functions to use.
This also fixes a memory error found by KASAN on ARM32 (which is not
upstream yet), where response handlers accessing a filter's data field
could write past allocated memory.
[ 114.926512] ==================================================================
[ 114.933861] BUG: KASAN: slab-out-of-bounds in ncsi_configure_channel+0x4b8/0xc58
[ 114.941304] Read of size 2 at addr 94888558 by task kworker/0:2/546
[ 114.947593]
[ 114.949146] CPU: 0 PID: 546 Comm: kworker/0:2 Not tainted 4.16.0-rc6-00119-ge156398bfcad #13
[ 115.170233] The buggy address belongs to the object at 94888540
[ 115.170233] which belongs to the cache kmalloc-32 of size 32
[ 115.181917] The buggy address is located 24 bytes inside of
[ 115.181917] 32-byte region [94888540, 94888560)
[ 115.192115] The buggy address belongs to the page:
[ 115.196943] page:9eeac100 count:1 mapcount:0 mapping:94888000 index:0x94888fc1
[ 115.204200] flags: 0x100(slab)
[ 115.207330] raw: 00000100 94888000 94888fc1 0000003f 00000001 9eea2014 9eecaa74 96c003e0
[ 115.215444] page dumped because: kasan: bad access detected
[ 115.221036]
[ 115.222544] Memory state around the buggy address:
[ 115.227384] 94888400: fb fb fb fb fc fc fc fc 04 fc fc fc fc fc fc fc
[ 115.233959] 94888480: 00 00 00 fc fc fc fc fc 00 04 fc fc fc fc fc fc
[ 115.240529] >94888500: 00 00 04 fc fc fc fc fc 00 00 04 fc fc fc fc fc
[ 115.247077] ^
[ 115.252523] 94888580: 00 04 fc fc fc fc fc fc 06 fc fc fc fc fc fc fc
[ 115.259093] 94888600: 00 00 06 fc fc fc fc fc 00 00 04 fc fc fc fc fc
[ 115.265639] ==================================================================
Reported-by: Joel Stanley <joel@jms.id.au>
The call to nla_nest_start calls nla_put which can lead to a NULL
return so it's possible for attr to become NULL and we can potentially
get a NULL pointer dereference on attr. Fix this by checking for
a NULL return.
Detected by CoverityScan, CID#1466125 ("Dereference null return")
There are two error paths which are missing unlocks in this function.
We're supposed to use kfree_skb() to free these sk_buffs.
Add a generic netlink family for NCSI. This supports three commands;
NCSI_CMD_PKG_INFO which returns information on packages and their
associated channels, NCSI_CMD_SET_INTERFACE which allows a specific
package or package/channel combination to be set as the preferred
choice, and NCSI_CMD_CLEAR_INTERFACE which clears any preferred setting.
The current HNCDSC handler takes the status flag from the AEN packet and
will update or change the current channel based on this flag and the
current channel status.
However the flag from the HNCDSC packet merely represents the host link
state. While the state of the host interface is potentially interesting
information it should not affect the state of the NCSI link. Indeed the
NCSI specification makes no mention of any recommended action related to
the host network controller driver state.
Update the HNCDSC handler to record the host network driver status but
take no other action.
Acked-by: Jeremy Kerr <jk@ozlabs.org>
This converts all remaining setup_timer() calls that use a nested field
to reach a struct timer_list. Coccinelle does not have an easy way to
match multiple fields, so a new script is needed to change the matches of
"&_E->_timer" into "&_E->_field1._timer" in all the rules.
spatch --very-quiet --all-includes --include-headers \
-I ./arch/x86/include -I ./arch/x86/include/generated \
-I ./include -I ./arch/x86/include/uapi \
-I ./arch/x86/include/generated/uapi -I ./include/uapi \
-I ./include/generated/uapi --include ./include/linux/kconfig.h \
--dir . \
--cocci-file ~/src/data/timer_setup-2fields.cocci
@fix_address_of depends@
expression e;
setup_timer(
-&(e)
+&e
// Update any raw setup_timer() usages that have a NULL callback, but
// would otherwise match change_timer_function_usage, since the latter
// will update all function assignments done in the face of a NULL
// function initialization in setup_timer().
@change_timer_function_usage_NULL@
expression _E;
identifier _field1;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_field1._timer, NULL, _E);
+timer_setup(&_E->_field1._timer, NULL, 0);
-setup_timer(&_E->_field1._timer, NULL, (_cast_data)_E);
-setup_timer(&_E._field1._timer, NULL, &_E);
+timer_setup(&_E._field1._timer, NULL, 0);
-setup_timer(&_E._field1._timer, NULL, (_cast_data)&_E);
@change_timer_function_usage@
expression _E;
identifier _field1;
identifier _timer;
struct timer_list _stl;
identifier _callback;
type _cast_func, _cast_data;
-setup_timer(&_E->_field1._timer, _callback, _E);
+timer_setup(&_E->_field1._timer, _callback, 0);
-setup_timer(&_E->_field1._timer, &_callback, _E);
-setup_timer(&_E->_field1._timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_field1._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_field1._timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_field1._timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_field1._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_field1._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._field1._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._field1._timer, _callback, 0);
-setup_timer(&_E._field1._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._field1._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._field1._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._field1._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._field1._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._field1._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._field1._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_field1._timer@_stl.function = _callback;
_E->_field1._timer@_stl.function = &_callback;
_E->_field1._timer@_stl.function = (_cast_func)_callback;
_E->_field1._timer@_stl.function = (_cast_func)&_callback;
_E._field1._timer@_stl.function = _callback;
_E._field1._timer@_stl.function = &_callback;
_E._field1._timer@_stl.function = (_cast_func)_callback;
_E._field1._timer@_stl.function = (_cast_func)&_callback;
// callback(unsigned long arg)
@change_callback_handle_cast
depends on change_timer_function_usage@
identifier change_timer_function_usage._callback;
identifier change_timer_function_usage._field1;
identifier change_timer_function_usage._timer;
type _origtype;
identifier _origarg;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+struct timer_list *t
... when != _origarg
_handletype *_handle =
-(_handletype *)_origarg;
+from_timer(_handle, t, _field1._timer);
-(void *)_origarg;
_handletype *_handle;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
// callback(unsigned long arg) without existing variable
@change_callback_handle_cast_no_arg
depends on change_timer_function_usage &&
!change_callback_handle_cast@
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _field1._timer);
- (_handletype *)_origarg
+ _origarg
// Avoid already converted callbacks.
@match_callback_converted
!change_callback_handle_cast &&
!change_callback_handle_cast_no_arg@
identifier t;
void _callback(struct timer_list *t)
// callback(struct something *handle)
@change_callback_handle_arg
!match_callback_converted &&
type _handletype;
identifier _handle;
void _callback(
-_handletype *_handle
+ _handletype *_handle = from_timer(_handle, t, _field1._timer);
// If change_callback_handle_arg ran on an empty function, remove
// the added handler.
@unchange_callback_handle_arg
change_callback_handle_arg@
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _field1._timer);
// We only want to refactor the setup_timer() data argument if we've found
// the matching callback. This undoes changes in change_timer_function_usage.
@unchange_timer_function_usage
!change_callback_handle_cast_no_arg &&
!change_callback_handle_arg@
expression change_timer_function_usage._E;
type change_timer_function_usage._cast_data;
-timer_setup(&_E->_field1._timer, _callback, 0);
+setup_timer(&_E->_field1._timer, _callback, (_cast_data)_E);
-timer_setup(&_E._field1._timer, _callback, 0);
+setup_timer(&_E._field1._timer, _callback, (_cast_data)&_E);
// If we fixed a callback from a .function assignment, fix the
// assignment cast now.
@change_timer_function_assignment
(change_callback_handle_cast ||
change_callback_handle_cast_no_arg ||
change_callback_handle_arg)@
type _cast_func;
typedef TIMER_FUNC_TYPE;
_E->_field1._timer.function =
-_callback
+(TIMER_FUNC_TYPE)_callback
-&_callback
-(_cast_func)_callback;
-(_cast_func)&_callback
_E._field1._timer.function =
-_callback
-&_callback;
// Sometimes timer functions are called directly. Replace matched args.
@change_timer_function_calls
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_field1._timer
-(_cast_data)&_E
+&_E._field1._timer
-_E
// If a timer has been configured without a data argument, it can be
// converted without regard to the callback argument, since it is unused.
@match_timer_function_unused_data@
expression _E;
identifier _field1;
identifier _timer;
-setup_timer(&_E->_field1._timer, _callback, 0);
-setup_timer(&_E->_field1._timer, _callback, 0L);
-setup_timer(&_E->_field1._timer, _callback, 0UL);
-setup_timer(&_E._field1._timer, _callback, 0);
-setup_timer(&_E._field1._timer, _callback, 0L);
-setup_timer(&_E._field1._timer, _callback, 0UL);
-setup_timer(&_field1._timer, _callback, 0);
+timer_setup(&_field1._timer, _callback, 0);
-setup_timer(&_field1._timer, _callback, 0L);
-setup_timer(&_field1._timer, _callback, 0UL);
-setup_timer(_field1._timer, _callback, 0);
+timer_setup(_field1._timer, _callback, 0);
-setup_timer(_field1._timer, _callback, 0L);
-setup_timer(_field1._timer, _callback, 0UL);
@change_callback_unused_data
depends on match_timer_function_unused_data@
identifier match_timer_function_unused_data._callback;
type _origtype;
void _callback(
-_origtype _origarg
+struct timer_list *unused
This converts all remaining cases of the old setup_timer() API into using
timer_setup(), where the callback argument is the structure already
holding the struct timer_list. These should have no behavioral changes,
since they just change which pointer is passed into the callback with
the same available pointers after conversion. It handles the following
examples, in addition to some other variations.
Casting from unsigned long:
void my_callback(unsigned long data)
struct something *ptr = (struct something *)data;
setup_timer(&ptr->my_timer, my_callback, ptr);
and forced object casts:
void my_callback(struct something *ptr)
setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr);
become:
void my_callback(struct timer_list *t)
struct something *ptr = from_timer(ptr, t, my_timer);
timer_setup(&ptr->my_timer, my_callback, 0);
Direct function assignments:
ptr->my_timer.function = my_callback;
have a temporary cast added, along with converting the args:
ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback;
And finally, callbacks without a data assignment:
setup_timer(&ptr->my_timer, my_callback, 0);
have their argument renamed to verify they're unused during conversion:
void my_callback(struct timer_list *unused)
The conversion is done with the following Coccinelle script:
--dir . \
--cocci-file ~/src/data/timer_setup.cocci
@fix_address_of@
expression e;
setup_timer(
-&(e)
+&e
expression _E;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_timer, NULL, _E);
+timer_setup(&_E->_timer, NULL, 0);
-setup_timer(&_E->_timer, NULL, (_cast_data)_E);
-setup_timer(&_E._timer, NULL, &_E);
+timer_setup(&_E._timer, NULL, 0);
-setup_timer(&_E._timer, NULL, (_cast_data)&_E);
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, _E);
+timer_setup(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, &_callback, _E);
-setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_timer@_stl.function = _callback;
_E->_timer@_stl.function = &_callback;
_E->_timer@_stl.function = (_cast_func)_callback;
_E->_timer@_stl.function = (_cast_func)&_callback;
_E._timer@_stl.function = _callback;
_E._timer@_stl.function = &_callback;
_E._timer@_stl.function = (_cast_func)_callback;
_E._timer@_stl.function = (_cast_func)&_callback;
type _origtype;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+from_timer(_handle, t, _timer);
-(void *)_origarg;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _timer);
+ _origarg
identifier t;
type _handletype;
identifier _handle;
void _callback(
+ _handletype *_handle = from_timer(_handle, t, _timer);
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _timer);
-timer_setup(&_E->_timer, _callback, 0);
+setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-timer_setup(&_E._timer, _callback, 0);
+setup_timer(&_E._timer, _callback, (_cast_data)&_E);
type _cast_func;
_E->_timer.function =
-_callback
-&_callback
_E._timer.function =
-_callback
-&_callback;
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_timer
-(_cast_data)&_E
+&_E._timer
-_E
+&_E->_timer
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, _callback, 0L);
-setup_timer(&_E->_timer, _callback, 0UL);
-setup_timer(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, 0L);
-setup_timer(&_E._timer, _callback, 0UL);
-setup_timer(&_timer, _callback, 0);
+timer_setup(&_timer, _callback, 0);
-setup_timer(&_timer, _callback, 0L);
-setup_timer(&_timer, _callback, 0UL);
-setup_timer(_timer, _callback, 0);
+timer_setup(_timer, _callback, 0);
-setup_timer(_timer, _callback, 0L);
-setup_timer(_timer, _callback, 0UL);
type _origtype;
void _callback(
-_origtype _origarg
Several response handlers return EBUSY if the data corresponding to the
command/response pair is already set. There is no reason to return an
error here; the channel is advertising something as enabled because we
told it to enable it, and it's possible that the feature has been
enabled previously.
The NCSI driver is mostly silent which becomes a headache when trying to
determine what has occurred on the NCSI connection. This adds additional
logging in a few key areas such as state transitions and calling out
certain errors more visibly.
