We should not forget to try for real server with port 0
in the backup server when processing the sync message. We should
do it in all cases because the backup server can use different
forwarding method.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
ip_vs_mutext is used by both netns shutdown code and startup
and both implicit uses sk_lock-AF_INET mutex.
cleanup CPU-1 startup CPU-2
ip_vs_dst_event() ip_vs_genl_set_cmd()
sk_lock-AF_INET __ip_vs_mutex
sk_lock-AF_INET
__ip_vs_mutex
* DEAD LOCK *
A new mutex placed in ip_vs netns struct called sync_mutex is added.
Comments from Julian and Simon added.
This patch has been running for more than 3 month now and it seems to work.
Ver. 3
IP_VS_SO_GET_DAEMON in do_ip_vs_get_ctl protected by sync_mutex
instead of __ip_vs_mutex as sugested by Julian.
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
After restructuring, there is some unused or empty functions
left to be removed.
Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com>
Make it more clear what the functions does,
on request by Julian.
DESCRIPTION
This patch tries to restore the initial init and cleanup
sequences that was before namspace patch.
Netns also requires action when net devices unregister
which has never been implemented. I.e this patch also
covers when a device moves into a network namespace,
and has to be released.
IMPLEMENTATION
The number of calls to register_pernet_device have been
reduced to one for the ip_vs.ko
Schedulers still have their own calls.
This patch adds a function __ip_vs_service_cleanup()
and an enable flag for the netfilter hooks.
The nf hooks will be enabled when the first service is loaded
and never disabled again, except when a namespace exit starts.
[horms@verge.net.au: minor edit to changelog]
If the sync daemons run in a name space while it crashes
or get killed, there is no way to stop them except for a reboot.
When all patches are there, ip_vs_core will handle register_pernet_(),
i.e. ip_vs_sync_init() and ip_vs_sync_cleanup() will be removed.
Kernel threads should not increment the use count of a socket.
By calling sk_change_net() after creating a socket this is avoided.
sock_release cant be used intead sk_release_kernel() should be used.
Thanks Eric W Biederman for your advices.
In preparation for not including sysctl_sync_ver in
struct netns_ipvs when CONFIG_SYCTL is not defined.
In preparation for not including sysctl_sync_threshold in
The semantic patch that makes this output is available
in scripts/coccinelle/api/memdup.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Fix get_curr_sync_buff to keep buffer for 2 seconds
as intended, not just for the current jiffie. By this way
we will sync more connection structures with single packet.
Signed-off-by: Tinggong Wang <wangtinggong@gmail.com>
'!' has higher precedence than '&'. IP_VS_STATE_MASTER is 0x1 so
the original code is equivelent to if (!ipvs->sync_state) ...
ip_vs_sync_cleanup() may be called from ip_vs_init() on error
and thus needs to be accesible from section __init
Reporte-by: Randy Dunlap <randy.dunlap@oracle.com>
Tested-by: Hans Schillstrom <hans@schillstrom.com>
The recent netns changes omitted to change
sock_create_kernel() to __sock_create() in ip_vs_sync.c
The effect of this is that the interface will be selected in the
root-namespace, from my point of view it's a major bug.
Reported-by: Hans Schillstrom <hans@schillstrom.com>
all init_net removed, (except for some alloc related
that needs to be there)
Moving global vars to ipvs struct, except for svc table lock.
Next patch for ctl will be drop-rate handling.
*v3
__ip_vs_mutex remains global
ip_vs_conntrack_enabled(struct netns_ipvs *ipvs)
Connection hash table is now name space aware.
i.e. net ptr >> 8 is xor:ed to the hash,
and this is the first param to be compared.
The net struct is 0xa40 in size ( a little bit smaller for 32 bit arch:s)
and cache-line aligned, so a ptr >> 5 might be a more clever solution ?
All lookups where net is compared uses net_eq() which returns 1 when netns
is disabled, and the compiler seems to do something clever in that case.
ip_vs_conn_fill_param() have *net as first param now.
Three new inlines added to keep conn struct smaller
when names space is disabled.
- ip_vs_conn_net()
- ip_vs_conn_net_set()
- ip_vs_conn_net_eq()
*v3
moved net compare to the end in "fast path"
All global variables moved to struct ipvs,
most external changes fixed (i.e. init_net removed)
in sync_buf create + 4 replaced by sizeof(struct..)
appcnt and timeout_table moved from struct ip_vs_protocol to
ip_vs proto_data.
struct net *net added as first param to
- register_app()
- unregister_app()
- app_conn_bind()
- ip_vs_conn_new()
[horms@verge.net.au: removed cosmetic-change-only hunk]
Services hash tables got netns ptr a hash arg,
While Real Servers (rs) has been moved to ipvs struct.
Two new inline functions added to get net ptr from skb.
Since ip_vs is called from different contexts there is two
places to dig for the net ptr skb->dev or skb->sk
this is handled in skb_net() and skb_sknet()
Global functions, ip_vs_service_get() ip_vs_lookup_real_service()
etc have got struct net *net as first param.
If possible get net ptr skb etc,
- if not &init_net is used at this early stage of patching.
ip_vs_ctl.c procfs not ready for netns yet.
*v3
Comments by Julian
- __ip_vs_service_find and __ip_vs_svc_fwm_find are fast path,
net_eq(svc->net, net) so the check is at the end now.
- net = skb_net(skb) in ip_vs_out moved after check for skb_dst.
Preparation for network name-space init, in this stage
some empty functions exists.
In most files there is a check if it is root ns i.e. init_net
if (!net_eq(net, &init_net))
return ...
this will be removed by the last patch, when enabling name-space.
*v3
ip_vs_conn.c merge error corrected.
net_ipvs #ifdef removed as sugested by Jan Engelhardt
[ horms@verge.net.au: Removed whitespace-change-only hunks ]
This patch adds a sysclt net.ipv4.vs.sync_version
that can be used to send sync msg in version 0 or 1 format.
sync_version value is logical,
Value 1 (default) New version
0 Plain old version
Enable sending and removal of version 0 sending
Affected functions,
ip_vs_sync_buff_create()
ip_vs_sync_conn()
ip_vs_core.c removal of IPv4 check.
*v5
Just check cp->pe_data_len in ip_vs_sync_conn
Check if padding needed before adding a new sync_conn
to the buffer, i.e. avoid sending padding at the end.
*v4
moved sanity check and pe_name_len after sloop.
use cp->pe instead of cp->dest->svc->pe
real length in each sync_conn, not padded length
however total size of a sync_msg includes padding.
*v3
Sending ip_vs_sync_conn_options in network order.
Sending Templates for ONE_PACKET conn.
Renaming of ip_vs_sync_mesg to ip_vs_sync_mesg_v0
Functionality improvements
* flags changed from 16 to 32 bits
* fwmark added (32 bits)
* timeout in sec. added (32 bits)
* pe data added (Variable length)
* IPv6 capabilities (3x16 bytes for addr.)
* Version and type in every conn msg.
ip_vs_process_message() now handles Version 1 messages
and will call ip_vs_process_message_v0() for version 0 messages.
ip_vs_proc_conn() is common for both version, and handles the update of
connection hash.
ip_vs_conn_fill_param_sync() - Version 1 messages only
ip_vs_conn_fill_param_sync_v0() - Version 0 messages only
New structs defined for version 1 of sync.
* ip_vs_sync_v4 Ipv4 base format struct
* ip_vs_sync_v6 Ipv6 base format struct
daemon.
One struct will have fwmark added:
* ip_vs_conn
ip_vs_conn_new() and ip_vs_find_dest()
will have an extra param - fwmark
The effects of that, is in this patch.
It is assigned to a non-const variable and its contents are modified.
Acked-by: Hans Schillstrom <hans.schillstrom@ericsson.com>
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
Enhance IPVS to load balance SCTP transport protocol packets. This is done
based on the SCTP rfc 4960. All possible control chunks have been taken
care. The state machine used in this code looks some what lengthy. I tried
to make the state machine easy to understand.
Signed-off-by: Venkata Mohan Reddy Koppula <mohanreddykv@gmail.com>
Since pr_err and friends are used instead of printk there is no point
in keeping IP_VS_ERR and friends. Furthermore make use of '__func__'
instead of hard coded function names.
Signed-off-by: Hannes Eder <heder@google.com>
Acked-by: Simon Horman <horms@verge.net.au>
While being at it cleanup whitespace.
Base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u
can be replaced with %pI4
Since IPVS now has partial IPv6 support, this patch moves IPVS from
net/ipv4/ipvs to net/netfilter/ipvs. It's a result of:
$ git mv net/ipv4/ipvs net/netfilter
and adapting the relevant Kconfigs/Makefiles to the new path.
Signed-off-by: Julius Volz <juliusv@google.com>
